SS56F
SS56F
    YFW(佑风微)
SS56F 数据手册
SS52F THRU SS520F SMAF Surface Mount Schottky Barrier Rectifier Pinning Reverse Voltage - 20 to 200 V 1.Cathode Forward Current - 5 A 2.Anode         1 FEATURES  Metal silicon junction, majority carrier conduction  For surface mounted applications  Low power loss, high efficiency   2     SMAF  High forward surge current capability Marking Code  For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications SS52F SS52 SS54F SS54  Lead free in comply with EU RoHS 2011/65/EU directives SS56F SS56 MECHANICAL DATA  Case: SMAF  Terminals: Solderable per MIL-STD-750, Method 2026 SS58F SS58 SS510F SS510 SS512F SS512 SS515F SS515 SS520F SS520  Approx. Weight: 27mg / 0.00095oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS52F SS54F SS56F SS58F SS510F SS512F SS515F SS520F Units Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method) IFSM Maximum Instantaneous Forward Voltage at 5 A VF Maximum Instantaneous Reverse Current TA = 25°C at Rated DC Reverse Voltage TA = 100°C IR Typical Junction Capacitance(1) Cj Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range 5.0 A 175 0.45 0.55 0.70 1.0 50 700 150 A 0.85 V mA 500 pF RθJA 50 °C/W Tj -55 ~ +150 °C Tstg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. SS52F THRU SS520F SMAF Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 0.0 25 50 75 100 125 150 10 4 T J =100°C 10 3 10 1 T J =25°C 10 0 0 Case Temperature (°C) 60 100 80 Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1 SS52F SS54F SS56F/SS58F SS510F/SS520F 0.1 0.5 0 1.0 1.5 500 100 SS52F/SS54F SS54F/SS520F SS56F-SS520F 20 10 0.1 10 1 100 Instaneous Forward Voltage (V) Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 180 SS52F~SS58F 175 SS510F~SS520F 150 125 100 75 50 25 1000 2.0 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) T J =75°C 10 2 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz www.yfwdiode.com 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) 2/3 Dongguan YFW Electronics Co, Ltd. SS52F THRU SS520F SMAF SMAF Package Outline Plastic surface mounted package; 2 leads ∠ALL ROUND C A ∠ALL ROUND HE g g pad e E A pad D E A V M Top View A C D E e g HE max 1.1 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 43 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm mil Bottom View ∠ 7° The recommended mounting pad size 1.6 (63) 2.2 (86) 1.8 (71) 1.6 (63) mm Unit : (mil) Summary of Packing Options Package SMAF www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 10000 EIA-481-1 Tape/Reel,7”reel 3000 EIA-481-1 3/3 Dongguan YFW Electronics Co, Ltd.
SS56F
物料型号:SS52F至SS520F 器件简介:表面贴装肖特基势垒整流器,金属硅结,主要载流子传导,适用于表面贴装应用。
引脚分配:1. 阴极 2. 阳极 参数特性:反向电压20至200V,正向电流5A,低功耗,高效率,高正向浪涌电流能力,符合欧盟RoHS 2011/65/EU指令的无铅要求。
功能详解:用于低电压、高频逆变器、自由轮流通路和极性保护应用。
应用信息:适用于低电压、高频逆变器、自由轮流通路和极性保护应用。
封装信息:SMAF塑料表面贴装包,2引线,推荐安装垫尺寸为2.2mm x 1.6mm,包装选项包括13英寸卷带(10000个/卷)和7英寸卷带(3000个/卷),符合EIA-481-1标准。
SS56F 价格&库存
很抱歉,暂时无法提供与“SS56F”相匹配的价格&库存,您可以联系我们找货
