8221LEM0809H2RR00O
8221LEM0809H2RR00O
    RELON(瑞隆)
    AEC_D8X9MM_TM
    8221LEM0809H2RR00O
8221LEM0809H2RR00O 数据手册
H2 Series ●Low ESR, high ripple current, high voltage ● Load life of 2000 hours at 105℃ ● RoHS Compliant ◆ 规格表 Specifications 项目Items 特性参数Characteristics 使用温度范围 Category Temperture Range 额定工作电压范围 Rated Voltage Range 静电容量允许偏差 Capacitance tolerance 漏电流 Leakage Current 损耗角正切值tanδ Dissipation Factor 温度特性 Low Temperture Characteristics (Max.Impedance Ratio) 耐久性 Endurence 耐湿负荷特性 Damp Heat (Steady State) 浪涌电压特性 (Surge Voltage) -55 ~ +105℃ 35 ~ 100V ±20%(M) (at 20℃,120Hz) 施加额定工作电压2分钟后读数,小于或等于规格值 (at 20℃) I≤0.1CV 或299μA(取大值) Less than or equal to the specified value. After 2 minutes application of rated Voltage at 20℃ Rated voltage (V) 35~100 (at 20℃,120Hz) tanδ (Max.) 0.12 Z(-25℃)/Z(+20℃) ≦1.25 Z(-55℃)/Z(+20℃) ≦1.25 (100KHz) 105℃施加额定工作电压2000小时,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be satisfied when the capacitors are restored to 20℃ after application of rated voltage for 2000 hours at 105℃. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value 在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be satisfied when the capacitors are restored to 20℃after application of rated voltage for 1000 hours at 60℃,90%~ 95% RH. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value 浪涌电压=额定电压× 1.15(V) Surge Voltage=Rated voltage × 1.15(V) 在105℃环境中,按充电30秒;放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复后测试,应满足以下要求 The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified at 105℃ for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value ◆ 外形图Dimensions (mm) ΦD P Φd α -1- 5 2.0 0.5 6.3 2.5 0.6 8 3.5 0.6 10 5.0 0.6 (L﹤16)1.0 (16≦L﹤22)1.5 (L≧22)2.0 H2 Series ◆ 纹波电流补正系数 Rated Ripple Current Coefficient 10kHz ≦ f ﹤ 100kHz 100kHz≦ f ﹤ 500kHz 0.30 0.70 1.00 Case size ΦD×L(mm) ESR(mΩ) at 20℃,100 KHz Leakage Current (μA) Rated ripple current (mArms/105℃/100kHz) Catalog Part Number 10 5*8 120 299 1100 8100LEM0508H2RR00O 22 6.3*8 100 299 1350 8220LEMAA08H2RR00O 33 5*8 120 299 1100 8330LEM0508H2RR00O 39 6.3*8 90 299 1350 8390LEMAA08H2RR00O 39 8*9 60 299 1800 8390LEM0809H2RR00O 47 5*7 80 299 1350 8470LEM0507H2RR00O 47 6.3*8 60 299 1800 8470LEMAA08H2RR00O 56 6.3*8 80 299 1350 8560LEMAA08H2RR00O 56 8*9 60 299 1800 8560LEM0809H2RR00O 68 6.3*8 70 299 1500 8680LEMAA08H2RR00O 68 8*9 50 299 2000 8680LEM0809H2RR00O 82 6.3*11 60 299 1800 8820LEMAA11H2RR00O 82 8*9 40 299 2000 8820LEM0809H2RR00O 100 5*11 45 350 1800 8101LEM0511H2RR00O 100 6.3*8 40 350 2000 8101LEMAA08H2RR00O 150 6.3*12 35 525 2500 8151LEMAA12H2RR00O 220 8*9 35 770 2350 8221LEM0809H2RR00O 220 8*12 35 770 2500 8221LEM0812H2RR00O 220 10*12.5 30 770 2750 8221LEM10ABH2RR00O 330 10*12.5 30 1155 2900 8331LEM10ABH2RR00O 470 10*13 30 1645 2900 8471LEM1013H2RR00O 10 5*8 120 299 550 8100LFM0508H2RR00O 15 6.3*8 100 299 800 8150LFMAA08H2RR00O 22 6.3*8 100 299 850 8220LFMAA08H2RR00O 33 8*9 50 299 1300 8330LFM0809H2RR00O 33 8*12 40 299 1500 8330LFM0812H2RR00O 39 8*9 50 299 1300 8390LFM0809H2RR00O 39 8*12 40 299 1500 8390LFM0812H2RR00O 47 8*12 40 299 1500 8470LFM0812H2RR00O 56 8*12 40 299 1500 8560LFM0812H2RR00O 82 10*12.5 35 410 2100 8820LFM10ABH2RR00O 100 10*12.5 35 500 2100 8101LFM10ABH2RR00O 220 10*12.5 35 1100 2500 8221LFM10ABH2RR00O 频率Frequency(Hz) 系数 Coefficient 120Hz ≦ f ﹤1kHz 1kHz≦ f ﹤ 10kHz 0.05 ◆ 尺寸与个技术参数一览表 Standard Ratings Cap(uF) W Rated Rated voltage capacitance (V) (uF) 35 50 -2常规插件的固态电容是不适用于回流焊的 ,需需过回流焊工艺的即需要贴片的固态 . H2 Series ◆ 尺寸与个技术参数一览表 Standard Ratings Cap(uF) Rated voltage W Rated capacitance (V) (uF) 63 80 100 Case size ΦD×L(mm) Rated ripple current ESR(mΩ) Leakage Current (μA) at 20℃,100 KHz (mArms/105℃/100kHz) Catalog Part Number 10 5*8 120 299 500 8100LGM0508H2RR00O 15 6.3*8 100 299 750 8150LGMAA08H2RR00O 22 6.3*8 100 299 750 8220LGMAA08H2RR00O 33 8*9 55 299 1100 8330LGM0809H2RR00O 39 8*9 55 299 1100 8390LGM0809H2RR00O 47 8*12 45 299 1300 8470LGM0812H2RR00O 56 8*12 45 353 1300 8560LGM0812H2RR00O 82 10*12.5 38 517 1800 8820LGM10ABH2RR00O 100 10*12.5 38 630 1800 8101LGM10ABH2RR00O 10 6.3*8 120 299 550 8100LHMAA08H2RR00O 15 6.3*8 120 299 550 8150LHMAA08H2RR00O 22 8*9 80 299 1100 8220LHM0809H2RR00O 22 8*12 60 299 1300 8220LHM0812H2RR00O 33 10*12.5 45 299 1700 8330LHM10ABH2RR00O 39 10*12.5 45 312 1700 8390LHM10ABH2RR00O 47 10*12.5 45 376 1800 8470LHM10ABH2RR00O 56 10*12.5 45 448 1800 8560LHM10ABH2RR00O 10 8*9 90 299 850 8100MAM0809H2RR00O 15 8*12 70 299 1190 8150MAM0812H2RR00O 22 10*12.5 60 299 1550 8220MAM10ABH2RR00O 33 10*12.5 60 330 1550 8330MAM10ABH2RR00O 常规插件的固态电容是不适用于回流焊的 ,需需过回流焊工艺的即需要贴片的固态 . -3-
8221LEM0809H2RR00O 价格&库存
很抱歉,暂时无法提供与“8221LEM0809H2RR00O”相匹配的价格&库存,您可以联系我们找货
8221LEM0809H2RR00O
  • 5+1.78362
  • 50+1.41092
  • 150+1.25118
  • 1000+1.05182
  • 2000+0.96304
  • 5000+0.90980
