DM1_E_6P_210108_02追加.qxd 21.1.8 16:24 ページ 1
SD Memory Card Connectors
DM1 Series
Withstands higher force of card insertion.
Card
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Standard type
Metal cover extends over the back of the connector.
■Features
1. Withstands higher force of card insertion
Card
allowing it to withstand force of up to 400N (static load)
when dropped or accidentally hit. (Fig.1)
2. No damage to the card when accidentally
pulled-out
The connectors will release the card when a moderate
pull-out force of about 4N is applied. There will be no
damage to the lock components and all connector
functions will not be affected. (Fig.2)
Reverse type
Fig.1
accidentally pulled-out.
3. Accidental card fall-out prevention
Built-in lock feature holds the card securely in place.
(Fig.3)
4. Reliable Card Insertion and Withdrawal
Built-in Push-in / Push-out ejection mechanism assures
simple and reliable card insertion and withdrawal.
5. Designed to accept Secure Digital I/O card
(Built-in Ground Contact)
The connector allows use of various expansion
modules, including the Bluetooth communication
modules.
Fig.2
Accidental card
fall-out prevention
Fig.3
2021.2②
1
DM1_E_6P_210108_02追加.qxd 21.1.8 16:24 ページ 2
DM1 Series●SD Memory Card Connectors
■Product Specifications
Rating
Current rating 0.5A DC
Voltage rating 125V AC
Item
Operating temperature range : -25ç to +85ç (Note 1) Operating humidity range : Relative humidity 95%
max. (No condensation)
Storage temperature range : -40ç to +85ç (Note 2)
Specification
Conditions
1. Insulation resistance
2. Withstanding voltage
3. Contact resistance
4. Vibration
1000Mø min. (Initial value)
No flashover or insulation breakdown
100mø max. (Initial value)
No electrical discontinuity of 100ns or more
500V DC
500V AC / one minute
100mA DC
Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours / 3 axis
5. Humidity
Contact resistance : 40mø max. from initial value
Insulation resistance : 100Mø min.
96 hours at temperature of 40ç ± 2ç and
humidity of 90% to 95%
6. Temperature cycle
Temperature : -55ç/ +5ç to +35ç/ +85ç/ +5ç to +35ç
Duration : 30 / 5 / 30 / 5 (Minutes) 5 cycles
7. Durability (mating/un-mating) Contact resistance : 40mø max. from initial value
10000 cycles at 400 to 600 cycles per hour
8. Resistance to soldering heat No deformation of components affecting performance.
Reflow : At the recommended temperature profile
Manual soldering : 350ç for 3 seconds
Note1 : Includes temperature rise caused by current flow.
Note2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature
Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during
transportation.
■Materials / Finish
Component
Insulator
Material
Heat resistant thermoplastic compound
Finish
Color : Black
Contact area : Gold plating
Termination area : Tinned copper plating
Remarks
UL94V-0
Contacts
Phosphor bronze
Cover
Stainless steel
Others
Stainless steel
Piano wire
-------------------Nickel plating
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
DM1 AA - SF - PEJ
1
1 Series name
2 Connector type
2
2
: DM1
: AA : Standard receptacle
: B : Reverse receptacle
3
4
3 Terminal type
SF : Right angle surface mount
DSF : Reverse right angle surface mount
4 Eject mechanism codes
PEJ : Card Push insert/Push withdraw
DM1_E_6P_210108_02追加.qxd 21.1.8 16:24 ページ 3
■Standard type
BPCB mounting pattern
1.7±0.05
P=2.5±0.05
1.35±0.05
2±0.05
4.125±0.05
9-1.1±0.05
2 +0.1
DM1AA-SF-PEJ(82)
609-0004-8 82
23.2±0.05
4.55±0.05
4-2 +0.1
2-Ø
1.
3-1 +0.1
Card detection switch
+0
0 .1
1.6±0.05
20.75±0.05
18.15±0.05
9.2±0.05
HRS No.
2
Write protection switch
2 +0.1
1.2±0.05
C
L
1
1
1
28
13.2
9.75
8.05
t=0.2,W=0.6
P2.5
No.6
No.7
No.1
2.5
5.625
No.4
No.2 No.3
No.5
2.9
15
No.8
3-0.5
23.2
4.55
18.15
20.75
9.2
No.9
4-1.5
30.5
1
1
C
L
C
L
C
Lindicates the center line of card slot.
1
24.15 (Card slot dimension)
0.55
1
1
C
L
When card is inserted
When card is When card When card is
No yet inserted is inserted No yet inserted WRITE PROTECT WRITE ENABLE
2-Ø1.2
OPEN
22.4
CLOSE
OPEN
OPEN
CLOSE
Weight:2.2g
5
11
6
1
BCard insertion/withdrawal dimensions
5
Part No.
1.2±0.05
2 +0.1
25.4±0.05
22.4±0.05
15±0.05
SD Card
Card pushed-in for insertion
SD Card
Card fully inserted
SD Card
Card ejected
(Card ejected dimension)
3
DM1_E_6P_210108_02追加.qxd 21.1.8 16:24 ページ 4
■Reverse type
9.47±0.05
12.8±0.05
11.2±0.05
9.75±0.05
28.5±0.05
23.48±0.05
26.98±0.05
1.4±0.05
B
Center of Card dimension
+0.1
(Through
(Land)
+0.1
-0.1
1.9
1.2
+0.1
(Land)
+0.1
(Through
hole)
1.2
+0.1
(Land)
+0.1
(Through
hole)
+0.1
(Through
hole)
hole)
C(5:1)
(R0
.6)
1.2
+0.1
(Land)
+0.1
(Through
(R0
.6)
.6)
.4)
.4)
(R0
2
WP
11.93±0.05
B(5:1)
hole)
+0.1
(Through
0.8±0.05
1.05±0.05
14.13±0.05
.4)
2
2
2.03±0.05
11.23±0.05
C
(R0
8.63
5.62
3
(R0
18.68
16.85
2
6.95
7.65
2
5.62
C
L
1
6-0.65
2
A
14.25±0.05
A(5:1)
+0.1
(Land)
A
8-1.1±0.05
12.57±0.05
3
1.7
COMMON FOR CD & WP
2
609-0003-5 92
1.4±0.05
CARD DETECT
1.25±0.05
+0.1
-0.1 (Land)
DM1B-DSF-PEJ(92)
0.8±0.05
5.625±0.05
2.4
HRS No.
28.25±0.05
Part No.
12.5±0.05
P=2.5±0.05
(R0
11-2.5±0.05
8.05±0.05
28
No.7
(14.35)
No.5
No.4
No.3
No.2
No.1
1.05
No.9
0.35
2
27.2
27.45
(1.77)
2
29
2
(5):Card pushed for insertion
(6):Card fully inserted
29.9
10:Card ejected(Card ejected dimension)
2
1.5
2.9
2
1.85
No.8
C
L
1
No.6
1
C
L
(0.25)
SD Card
1
2
C
Lindicates the center line of the card slot.
indicates the dimension of DIP terminals.
not yet inserted is inserted
1
C
L
OPEN
Weight:2.1g
4
CLOSE
When card is
not yet inserted WRITE PROTECT WRITE ENABLE
OPEN
OPEN
CLOSE
hole)
DM1_E_6P_210108_02追加.qxd 21.1.8 16:24 ページ 5
BPackaging specifications
.5
Ø1
4.35±0.3
3.4±0.3
36±0.1
4±0.1
2±0.15
44±0.3
Unreeling direction
4±0.1
36±0.1
4.6±0.3
3.4±0.3
2±0.15
44±0.3
40.4±0.1
20.2±0.1
.1
+0
1.75±0.1
●Embossed Carrier Tape Dimensions(Reverse type) 450 pcs/reel
.5
Ø1
Unreeling direction
●Reel dimensions
44.4
+2
Unreeling direction
End section
Blank section(160mm min.)
Mounting section(450)
(Ø380)
D
(Ø150)
40.4±0.1
20.2±0.1
.1
+0
1.75±0.1
●Embossed Carrier Tape Dimensions (Standard type) 450 pcs/reel
Lead section (400mm min.)
Embossed carrier tape Blank section (100mm min.)
Top cover tape
5
DM1_E_6P_210108_02追加.qxd 21.1.8 16:24 ページ 6
BRecommended Temperature Profile
(ç)
Peak : 250ç MAX
250
230ç min.
50
seconds
Temperature
200
200ç
150
100
Soldering
150ç
90 to 120 seconds
Preheating
50
Time (Seconds)
6
HRS test condition
Solder method
: Reflow, IR/hot air
Environment
: Room air
Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu
(Senju Metal Industry, Co., Ltd.'s
Part Number:M705-GRN360-K2-V)
Test board
: Glass epoxy 60mm∞100mm∞1.0mm thick
Metal mask
: 0.15mm thick
Number of reflow cycles : 2cycles max.
The temperature profiles shown are based on the above
conditions.
In individual applications the actual temperature may vary,
depending on solder paste type, volume / thickness and board
size / thickness. Consult your solder paste and equipment
manufacturer for specific recommendations.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 02/2021. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“DM1AA-SF-PEJ-(21)”相匹配的价格&库存,您可以联系我们找货
