UMW
R
UMW AO3413A
20V P-Channel MOSFET
Features
VDS = -20V
IDD = -3A
RDS(ON)
66mΩ
DS(ON) < 80mΩ
RDS(ON)
100m
Ω
80mΩ
DS(ON)
SOT–23
(VGS = -4.5V)
(VGS =- 4.5V)-15
-2.5V)
(V(V
GS
GS==-2.5V)
1. GATE
2. SOURCE
3. DRAIN
D
G
S
Absolute Maximum Ratings TA=25°C unless otherwise noted
Parameter
Symbol
Drain-Source Voltage
VDS
VGS
Gate-Source Voltage
TA=25°C
Continuous Drain
Current A
TA=70°C
Pulsed Drain Current
B
Power Dissipation
TA=70°C
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A t ≤ 10s
Maximum Junction-to-Ambient A Steady-State
Steady-State
Maximum Junction-to-Lead C
www.umw-ic.com
Units
V
±8
V
-3
ID
A
-2.4
IDM
TA=25°C
A
Maximum
-20
-15
1.4
PD
W
0.9
-55 to 150
TJ, TSTG
Symbol
RθJA
RθJL
1
Typ
70
100
63
°C
Max
90
125
80
Units
°C/W
°C/W
°C/W
友台半导体有限公司
UMW
R
UMW AO3413A
Electrical Characteristics (TJ =25°C unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
Conditions
ID=-250µA, VGS=0V
IDSS
Zero Gate Voltage Drain Current
IGSS
Gate-Body leakage current
VDS=0V, VGS=±8V
VGS(th)
Gate Threshold Voltage
VDS=VGS ID=-250µA
-0.4
ID(ON)
On state drain current
VGS=-4.5V, VDS=-5V
-15
RDS(ON)
Static Drain-Source On-Resistance
gFS
VSD
IS
Maximum Body-Diode Continuous Current
Min
-20
VDS=-20V, VGS=0V
TJ=55°C
Units
V
-1
µA
-5
±100
V
VGS=-4.5V, ID=-3A
66
80
Forward Transconductance
VGS=-2.5V, ID=-2.6A
VDS=-5V, ID=-3A
mΩ
S
Diode Forward Voltage
IS=-1A,VGS=0V
-1
V
-1.4
A
745
pF
Output Capacitance
Reverse Transfer Capacitance
Rg
Gate resistance
12
-0.7
560
VGS=0V, VDS=-10V, f=1MHz
80
pF
70
VGS=0V, VDS=0V, f=1MHz
SWITCHING PARAMETERS
Total Gate Charge
Qg
Gate Source Charge
-0.65
nA
A
mΩ
Crss
Qgs
Max
-1
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Coss
Typ
VGS=-4.5V, VDS=-10V, ID=-3A
pF
15
23
8.5
11
Ω
nC
1.2
nC
Qgd
Gate Drain Charge
2.1
nC
tD(on)
Turn-On DelayTime
7.2
ns
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
trr
Turn-Off Fall Time
IF=-3A, dI/dt=100A/µs
37
Qrr
Body Diode Reverse Recovery Charge IF=-3A, dI/dt=100A/µs
27
Body Diode Reverse Recovery Time
VGS=-4.5V, VDS=-10V, RL=3.3Ω,
RGEN=6Ω
36
ns
53
ns
56
ns
49
ns
nC
A: The value of R θJA is measured with the device mounted on 1 in 2 FR-4 board with 2oz. copper, in a still air environment with TA=25°C. The
value in any given application depends on the user's specific board design. The current rating is based on the t ≤10s thermal resistance rating.
B: Repetitive rating, pulse width limited by junction temperature.
C. The R θJA is the sum of the thermal impedence from junction to lead R θJL and lead to ambient.
D. The static characteristics in Figures 1 to 6 are obtained using 300µs pulse width, duty cycle 0.5% max.
E. These tests are performed with the device mounted on 1 in 2 FR-4 board with 2oz. Copper, in a still air environment with T A=25°C. The SOA
12
curve provides a single pulse rating.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
UMW AO3413A
TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS
25
VDS=-5V
-3.0V
-4.5V
-2.5V
15
-ID(A)
-ID (A)
15
-2.0V
10
-15
10
125°C
5
VGS=-1.5V
5
25°C
2
3
4
5
-VDS (Volts)
Figure 1: On-Region Characteristics
150
Normalized On-Resistance
RDS(ON) (mΩ
Ω)
1
1.5
2
2.5
-VGS(Volts)
Figure 2: Transfer Characteristics
3
1.6
130
VGS=-1.8V
110
90
VGS=-2.5V
70
VGS=-4.5V
50
VGS=-2.5V
ID=-2.6A
1.4
VGS=-4.5V
ID=-3A
1.2
VGS=-1.8V
ID=-1A
1
0.8
4
6
8
10
-ID (A)
Figure 3: On-Resistance vs. Drain Current and
Gate Voltage
25
50
75
100
125
150
175
Temperature (°C)
Figure 4: On-Resistance vs. Junction Temperature
1E+02
180
ID=-3A
160
1E+01
12
140
1E+00
120
-IS (A)
RDS(ON) (mΩ
Ω)
0.5
125°C
100
125°C
1E-01
1E-02
25°C
80
1E-03
60
25°C
1E-04
40
4
6
1E-05
8
-VGS (Volts)
Figure 5: On-Resistance vs. Gate-Source Voltage
www.umw-ic.com
0.0
0.2
0.4
0.6
0.8
1.0
1.2
-VSD (Volts)
Figure 6: Body-Diode Characteristics
3
友台半导体有限公司
R
UMW
UMW AO3413A
5
1400
VDS=-10V
ID=-3A
1200
Capacitance (pF)
-VGS (Volts)
4
3
2
1000
800
Ciss
600
-15
400
1
Coss
200
Crss
4
6
8
10
Qg (nC)
Figure 7: Gate-Charge Characteristics
100.00
15
RDS(ON)
limited
TJ(Max)=150°C
TA=25°C
10µs
100
100µs
Power (W)
-ID (Amps)
10.00
10
-VDS (Volts)
Figure 8: Capacitance Characteristics
1ms
1.00
10ms
0.1s
TJ(Max)=150°C
TA=25°C
0.10
10
1
1s
DC
0.1
0.01
0.1
1
10
0.00001
100
-VDS (Volts)
0.001
0.1
10
1000
Pulse Width (s)
Figure 10: Single Pulse Power Rating Junctionto-Ambient (Note E)
Figure 9: Maximum Forward Biased Safe
Operating Area (Note E)
Zθ JA Normalized Transient
Thermal Resistance
10
1
In descending order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pulse
D=Ton/T
TJ,PK=TA+PDM.ZθJA.RθJA
RθJA=125°C/W
12
0.1
PD
0.01
Ton
T
Single Pulse
0.001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
1000
Pulse Width (s)
Figure 11: Normalized Maximum Transient Thermal Impedance (Note E)
www.umw-ic.com
4
友台半导体有限公司
UMW
R
UMW AO3413A
G ate C harge Test C ircuit & W aveform
V
gs
Vgs
Qg
-10V
V DC
Qgd
DUT
Qgs
V
ds
Vds
VD C
V
gs
Vgs
Ig
C harge
Resistive Switching Test Circuit & W aveform s
RL
Vds
t off
t on
td(on
d(on))
Vgs
D UT
Vgs
tf
t dd(off)
(o ff)
tr
90%
Vdd
VDC
Rg
Vgs
10%
Vds
Diode Recovery Test Circuit & Waveforms
Q rr = - Idt
Vds +
DUT
Vgs
Vds Isd
Vgs
Ig
www.umw-ic.com
-Isd
L
+ Vdd
-I F
t rr
dI/dt
-I RM
Vdd
VDC
-Vds
5
友台半导体有限公司
UMW
R
UMW AO3413A
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
ADRV
1K
Marking
U
Ordering information
Order code
Package
Baseqty
Deliverymode
UMW AO3413A
SOT-23
3000
Tape and reel
www.umw-ic.com
6
友台半导体有限公司
很抱歉,暂时无法提供与“AO3413A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.970723000+0.12605
- 9000+0.835229000+0.10845
- 国内价格 香港价格
- 1+4.410601+0.57270
- 10+2.7200510+0.35319
- 50+1.9658750+0.25526
- 100+1.72120100+0.22349
- 500+1.28850500+0.16731
- 国内价格
- 10+0.34431
- 100+0.26590
- 300+0.22670
- 3000+0.19732
- 6000+0.17378
- 9000+0.16200
- 国内价格
- 1+0.34944
- 200+0.22620
- 1500+0.19500
- 3000+0.17316
