EKXJ451ELL470MM20S
EKXJ451ELL470MM20S
    NCC(贵弥功)
    AEC_D18X20MM_TM
    EKXJ451ELL470MM20S
EKXJ451ELL470MM20S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS 160 to 500Vdc, long life, 105℃ KXJ Series KXJ ・Downsized and Longer life from current KXG series ・Endurance with ripple current : 8,000 to 12,000 hours at 105℃ ・Rated voltage range : 160 to 500V, Capacitance range : 6.8 to 680µF Downsized ・For electronic ballast circuits and other long life applications KXG P5-57 ・Non solvent resistant type ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current –40 to +105℃ (160 to 450Vdc) -25 to +105℃ (500Vdc) 160 to 500Vdc ±20% (M) (at 20℃, 120Hz) After 1 minute After 5 minutes CV≦1000 I=0.1CV+40 I=0.03CV+15 CV>1000 I=0.04CV+100 I=0.02CV+25 Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃) Rated voltage (Vdc) 160 to 250V 350 to 500V tanδ (Max.) 0.20 0.24 (at 20℃, 120Hz) Rated voltage (Vdc) 160 to 250V 350, 400V 420 to 500V Z(-25℃)/Z(+20℃) 3 5 6 Z(-40℃)/Z(+20℃) 6 6 (at 120Hz) - The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied(the peak voltage shall not exceed the rated voltage) for the specified time at 105℃. Rated voltage (Vdc) 160 to 450V 500V 16L to 20L:10,000hours, 25L to 50L:12,000hours φ10:8,000hours, φ12.5 to φ18:10.000hours Time Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦500% of the initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] F±0.5 Code : E φD' φd Sleeve (PET : Brown) F±0.5 ●Terminal φD φd F φD' L' Vent 15min. 4min. (φ12.5 to φ18) (φ10) L' 10 0.6 5.0 12.5 14.5 16 0.6 0.8 0.8 5.0 7.5 7.5 φD+0.5max. L+1.5max. 18 0.8 7.5 Gas escaped end seal ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KX J AAA E AA AAA M AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 6.8µF:6R8,10µF:100,100µF:101) Lead forming·taping code T erminal code Voltage code (ex. 160V:161,400V:401) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 5-53 CAT. No. E1001R MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS 160 to 500Vdc, long life, 105℃ KXJSeries ◆STANDARD RATINGS WV (Vdc) 160 200 Cap (µF) Case size tanδ φD×L(mm) 39 56 82 82 100 120 120 150 150 150 180 180 180 180 220 220 220 270 270 270 270 330 330 330 330 390 390 470 470 470 470 470 560 560 680 680 27 47 56 68 82 100 100 100 120 120 120 120 150 150 150 180 180 180 220 220 220 220 270 270 270 270 270 330 330 330 390 390 470 470 470 560 10×16 10×20 10×25 10×30 12.5×20 10×35 14.5×20 10×40 10×45 12.5×25 10×50 12.5×30 14.5×25 16×20 12.5×35 16×25 18×20 12.5×40 12.5×45 14.5×31.5 14.5×35.5 12.5×50 14.5×40 16×31.5 18×25 14.5×45 16×35.5 14.5×50 16×40 16×45 18×31.5 18×35.5 16×50 18×40 18×45 18×50 10×16 10×20 10×25 10×30 12.5×20 10×35 12.5×25 14.5×20 10×40 10×45 12.5×30 16×20 10×50 12.5×35 14.5×25 14.5×31.5 16×25 18×20 12.5×40 12.5×45 14.5×35.5 18×25 12.5×50 14.5×40 14.5×45 16×31.5 16×35.5 14.5×50 16×40 18×31.5 16×45 18×35.5 16×50 18×40 18×45 18×50 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 Rated ripple current (mArms/105℃, 120Hz) 245 315 415 445 575 570 675 665 695 765 785 885 890 855 1,040 1,020 990 1,190 1,230 1,170 1,210 1,400 1,385 1,350 1,290 1,545 1,500 1,735 1,700 1,730 1,660 1,715 1,920 1,905 2,130 2,145 200 290 345 405 520 520 625 615 595 620 725 695 720 860 810 955 925 895 1,075 1,110 1,095 1,050 1,265 1,250 1,290 1,220 1,250 1,450 1,425 1,395 1,575 1,565 1,755 1,745 1,770 1,945 Part No. EKXJ161E□□390MJ16S EKXJ161E□□560MJ20S EKXJ161E□□820MJ25S EKXJ161E□□820MJ30S EKXJ161E□□101MK20S EKXJ161E□□121MJ35S EKXJ161E□□121MU20S EKXJ161E□□151MJ40S EKXJ161E□□151MJ45S EKXJ161E□□151MK25S EKXJ161E□□181MJ50S EKXJ161E□□181MK30S EKXJ161E□□181MU25S EKXJ161E□□181ML20S EKXJ161E□□221MK35S EKXJ161E□□221ML25S EKXJ161E□□221MM20S EKXJ161E□□271MK40S EKXJ161E□□271MK45S EKXJ161E□□271MUN3S EKXJ161E□□271MUP1S EKXJ161E□□331MK50S EKXJ161E□□331MU40S EKXJ161E□□331MLN3S EKXJ161E□□331MM25S EKXJ161E□□391MU45S EKXJ161E□□391MLP1S EKXJ161E□□471MU50S EKXJ161E□□471ML40S EKXJ161E□□471ML45S EKXJ161E□□471MMN3S EKXJ161E□□471MMP1S EKXJ161E□□561ML50S EKXJ161E□□561MM40S EKXJ161E□□681MM45S EKXJ161E□□681MM50S EKXJ201E□□270MJ16S EKXJ201E□□470MJ20S EKXJ201E□□560MJ25S EKXJ201E□□680MJ30S EKXJ201E□□820MK20S EKXJ201E□□101MJ35S EKXJ201E□□101MK25S EKXJ201E□□101MU20S EKXJ201E□□121MJ40S EKXJ201E□□121MJ45S EKXJ201E□□121MK30S EKXJ201E□□121ML20S EKXJ201E□□151MJ50S EKXJ201E□□151MK35S EKXJ201E□□151MU25S EKXJ201E□□181MUN3S EKXJ201E□□181ML25S EKXJ201E□□181MM20S EKXJ201E□□221MK40S EKXJ201E□□221MK45S EKXJ201E□□221MUP1S EKXJ201E□□221MM25S EKXJ201E□□271MK50S EKXJ201E□□271MU40S EKXJ201E□□271MU45S EKXJ201E□□271MLN3S EKXJ201E□□271MLP1S EKXJ201E□□331MU50S EKXJ201E□□331ML40S EKXJ201E□□331MMN3S EKXJ201E□□391ML45S EKXJ201E□□391MMP1S EKXJ201E□□471ML50S EKXJ201E□□471MM40S EKXJ201E□□471MM45S EKXJ201E□□561MM50S WV (Vdc) 220 250 Cap (µF) Case size tanδ φD×L(mm) 27 39 56 56 68 82 82 100 100 100 120 120 120 120 150 150 150 180 180 180 220 220 220 220 220 270 270 270 270 330 330 330 390 390 390 470 22 33 47 47 56 68 68 82 82 82 100 100 100 100 120 120 120 150 150 150 180 180 180 180 180 220 220 220 220 270 270 270 330 330 330 390 10×16 10×20 10×25 10×30 12.5×20 10×35 14.5×20 10×40 10×45 12.5×25 10×50 12.5×30 14.5×25 16×20 12.5×35 16×25 18×20 12.5×40 12.5×45 14.5×31.5 12.5×50 14.5×35.5 14.5×40 16×31.5 18×25 14.5×45 14.5×50 16×35.5 18×31.5 16×40 16×45 18×35.5 16×50 18×40 18×45 18×50 10×16 10×20 10×25 10×30 12.5×20 10×35 14.5×20 10×40 10×45 12.5×25 10×50 12.5×30 14.5×25 16×20 12.5×35 16×25 18×20 12.5×40 12.5×45 14.5×31.5 12.5×50 14.5×35.5 14.5×40 16×31.5 18×25 14.5×45 14.5×50 16×35.5 18×31.5 16×40 16×45 18×35.5 16×50 18×40 18×45 18×50 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 Rated ripple current (mArms/105℃, 120Hz) 200 265 345 370 475 470 555 545 565 625 645 725 725 695 860 845 815 975 1,005 955 1,145 1,095 1,130 1,100 1,050 1,285 1,315 1,245 1,260 1,425 1,450 1,440 1,600 1,590 1,620 1,785 185 240 315 340 430 430 505 495 515 565 585 660 665 635 770 755 730 890 920 870 1,035 990 1,020 995 950 1,160 1,185 1,125 1,135 1,285 1,310 1,300 1,475 1,460 1,485 1,625 Part No. EKXJ221E□□270MJ16S EKXJ221E□□390MJ20S EKXJ221E□□560MJ25S EKXJ221E□□560MJ30S EKXJ221E□□680MK20S EKXJ221E□□820MJ35S EKXJ221E□□820MU20S EKXJ221E□□101MJ40S EKXJ221E□□101MJ45S EKXJ221E□□101MK25S EKXJ221E□□121MJ50S EKXJ221E□□121MK30S EKXJ221E□□121MU25S EKXJ221E□□121ML20S EKXJ221E□□151MK35S EKXJ221E□□151ML25S EKXJ221E□□151MM20S EKXJ221E□□181MK40S EKXJ221E□□181MK45S EKXJ221E□□181MUN3S EKXJ221E□□221MK50S EKXJ221E□□221MUP1S EKXJ221E□□221MU40S EKXJ221E□□221MLN3S EKXJ221E□□221MM25S EKXJ221E□□271MU45S EKXJ221E□□271MU50S EKXJ221E□□271MLP1S EKXJ221E□□271MMN3S EKXJ221E□□331ML40S EKXJ221E□□331ML45S EKXJ221E□□331MMP1S EKXJ221E□□391ML50S EKXJ221E□□391MM40S EKXJ221E□□391MM45S EKXJ221E□□471MM50S EKXJ251E□□220MJ16S EKXJ251E□□330MJ20S EKXJ251E□□470MJ25S EKXJ251E□□470MJ30S EKXJ251E□□560MK20S EKXJ251E□□680MJ35S EKXJ251E□□680MU20S EKXJ251E□□820MJ40S EKXJ251E□□820MJ45S EKXJ251E□□820MK25S EKXJ251E□□101MJ50S EKXJ251E□□101MK30S EKXJ251E□□101MU25S EKXJ251E□□101ML20S EKXJ251E□□121MK35S EKXJ251E□□121ML25S EKXJ251E□□121MM20S EKXJ251E□□151MK40S EKXJ251E□□151MK45S EKXJ251E□□151MUN3S EKXJ251E□□181MK50S EKXJ251E□□181MUP1S EKXJ251E□□181MU40S EKXJ251E□□181MLN3S EKXJ251E□□181MM25S EKXJ251E□□221MU45S EKXJ251E□□221MU50S EKXJ251E□□221MLP1S EKXJ251E□□221MMN3S EKXJ251E□□271ML40S EKXJ251E□□271ML45S EKXJ251E□□271MMP1S EKXJ251E□□331ML50S EKXJ251E□□331MM40S EKXJ251E□□331MM45S EKXJ251E□□391MM50S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 5-54 CAT. No. E1001R MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS 160 to 500Vdc, long life, 105℃ KXJSeries ◆STANDARD RATINGS WV (Vdc) 350 400 Cap (µF) Case size tanδ φD×L(mm) 12 22 27 27 33 39 47 47 47 56 56 56 68 68 68 68 82 82 82 100 100 100 100 100 120 120 120 150 150 150 150 180 180 180 220 220 10 18 22 27 27 33 39 39 39 39 47 47 56 56 56 56 68 68 68 82 82 82 82 82 100 100 100 120 120 120 120 120 150 150 180 220 10×16 10×20 10×25 10×30 12.5×20 10×35 10×40 12.5×25 14.5×20 10×45 12.5×30 16×20 10×50 12.5×35 14.5×25 18×20 12.5×40 14.5×31.5 16×25 12.5×45 12.5×50 14.5×35.5 16×31.5 18×25 14.5×40 14.5×45 16×35.5 14.5×50 16×40 16×45 18×31.5 16×50 18×35.5 18×40 18×45 18×50 10×16 10×20 10×25 10×30 12.5×20 10×35 10×40 10×45 12.5×25 14.5×20 12.5×30 16×20 10×50 12.5×35 14.5×25 18×20 12.5×40 14.5×31.5 16×25 12.5×45 12.5×50 14.5×35.5 16×31.5 18×25 14.5×40 14.5×45 16×35.5 14.5×50 16×40 16×45 18×31.5 18×35.5 16×50 18×40 18×45 18×50 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 Rated ripple current (mArms/105℃, 120Hz) 135 200 240 255 330 325 375 425 420 425 495 475 485 580 545 550 655 645 625 750 770 740 740 710 835 860 830 980 960 975 940 1,090 1,065 1,080 1,210 1,220 125 180 215 255 300 300 340 355 390 385 455 435 440 525 495 500 600 585 570 680 700 670 670 640 760 785 760 875 860 875 840 870 995 985 1,095 1,220 Part No. EKXJ351E□□120MJ16S EKXJ351E□□220MJ20S EKXJ351E□□270MJ25S EKXJ351E□□270MJ30S EKXJ351E□□330MK20S EKXJ351E□□390MJ35S EKXJ351E□□470MJ40S EKXJ351E□□470MK25S EKXJ351E□□470MU20S EKXJ351E□□560MJ45S EKXJ351E□□560MK30S EKXJ351E□□560ML20S EKXJ351E□□680MJ50S EKXJ351E□□680MK35S EKXJ351E□□680MU25S EKXJ351E□□680MM20S EKXJ351E□□820MK40S EKXJ351E□□820MUN3S EKXJ351E□□820ML25S EKXJ351E□□101MK45S EKXJ351E□□101MK50S EKXJ351E□□101MUP1S EKXJ351E□□101MLN3S EKXJ351E□□101MM25S EKXJ351E□□121MU40S EKXJ351E□□121MU45S EKXJ351E□□121MLP1S EKXJ351E□□151MU50S EKXJ351E□□151ML40S EKXJ351E□□151ML45S EKXJ351E□□151MMN3S EKXJ351E□□181ML50S EKXJ351E□□181MMP1S EKXJ351E□□181MM40S EKXJ351E□□221MM45S EKXJ351E□□221MM50S EKXJ401E□□100MJ16S EKXJ401E□□180MJ20S EKXJ401E□□220MJ25S EKXJ401E□□270MJ30S EKXJ401E□□270MK20S EKXJ401E□□330MJ35S EKXJ401E□□390MJ40S EKXJ401E□□390MJ45S EKXJ401E□□390MK25S EKXJ401E□□390MU20S EKXJ401E□□470MK30S EKXJ401E□□470ML20S EKXJ401E□□560MJ50S EKXJ401E□□560MK35S EKXJ401E□□560MU25S EKXJ401E□□560MM20S EKXJ401E□□680MK40S EKXJ401E□□680MUN3S EKXJ401E□□680ML25S EKXJ401E□□820MK45S EKXJ401E□□820MK50S EKXJ401E□□820MUP1S EKXJ401E□□820MLN3S EKXJ401E□□820MM25S EKXJ401E□□101MU40S EKXJ401E□□101MU45S EKXJ401E□□101MLP1S EKXJ401E□□121MU50S EKXJ401E□□121ML40S EKXJ401E□□121ML45S EKXJ401E□□121MMN3S EKXJ401E□□121MMP1S EKXJ401E□□151ML50S EKXJ401E□□151MM40S EKXJ401E□□181MM45S EKXJ401E□□221MM50S WV (Vdc) 420 450 Cap (µF) Case size tanδ φD×L(mm) 6.8 12 15 18 22 27 27 27 27 33 33 33 39 39 47 47 47 56 56 56 68 68 68 68 68 82 82 82 100 100 100 100 120 120 120 150 6.8 12 15 18 18 22 27 27 27 27 33 33 33 39 39 39 47 47 47 56 56 56 56 68 68 68 68 82 82 82 82 100 100 120 120 150 10×16 10×20 10×25 10×30 12.5×20 10×35 10×40 12.5×25 14.5×20 10×45 12.5×30 16×20 10×50 14.5×25 12.5×35 16×25 18×20 12.5×40 12.5×45 14.5×31.5 12.5×50 14.5×35.5 14.5×40 16×31.5 18×25 14.5×45 16×35.5 18×31.5 14.5×50 16×40 16×45 18×35.5 16×50 18×40 18×45 18×50 10×16 10×20 10×25 10×30 12.5×20 10×35 10×40 10×45 12.5×25 14.5×20 12.5×30 14.5×25 16×20 10×50 12.5×35 18×20 12.5×40 14.5×31.5 16×25 12.5×45 14.5×35.5 16×31.5 18×25 12.5×50 14.5×40 14.5×45 16×35.5 14.5×50 16×40 16×45 18×31.5 16×50 18×35.5 18×40 18×45 18×50 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 Rated ripple current (mArms/105℃, 120Hz) 105 150 185 215 285 275 290 340 335 335 400 385 375 435 505 500 480 570 590 560 670 640 660 645 615 750 725 730 845 825 840 835 935 930 945 1,060 105 150 185 215 255 250 290 305 340 335 400 400 385 375 460 440 525 515 500 590 580 585 560 670 660 680 660 765 750 760 730 855 835 930 945 1,060 Part No. EKXJ421E□□6R8MJ16S EKXJ421E□□120MJ20S EKXJ421E□□150MJ25S EKXJ421E□□180MJ30S EKXJ421E□□220MK20S EKXJ421E□□270MJ35S EKXJ421E□□270MJ40S EKXJ421E□□270MK25S EKXJ421E□□270MU20S EKXJ421E□□330MJ45S EKXJ421E□□330MK30S EKXJ421E□□330ML20S EKXJ421E□□390MJ50S EKXJ421E□□390MU25S EKXJ421E□□470MK35S EKXJ421E□□470ML25S EKXJ421E□□470MM20S EKXJ421E□□560MK40S EKXJ421E□□560MK45S EKXJ421E□□560MUN3S EKXJ421E□□680MK50S EKXJ421E□□680MUP1S EKXJ421E□□680MU40S EKXJ421E□□680MLN3S EKXJ421E□□680MM25S EKXJ421E□□820MU45S EKXJ421E□□820MLP1S EKXJ421E□□820MMN3S EKXJ421E□□101MU50S EKXJ421E□□101ML40S EKXJ421E□□101ML45S EKXJ421E□□101MMP1S EKXJ421E□□121ML50S EKXJ421E□□121MM40S EKXJ421E□□121MM45S EKXJ421E□□151MM50S EKXJ451E□□6R8MJ16S EKXJ451E□□120MJ20S EKXJ451E□□150MJ25S EKXJ451E□□180MJ30S EKXJ451E□□180MK20S EKXJ451E□□220MJ35S EKXJ451E□□270MJ40S EKXJ451E□□270MJ45S EKXJ451E□□270MK25S EKXJ451E□□270MU20S EKXJ451E□□330MK30S EKXJ451E□□330MU25S EKXJ451E□□330ML20S EKXJ451E□□390MJ50S EKXJ451E□□390MK35S EKXJ451E□□390MM20S EKXJ451E□□470MK40S EKXJ451E□□470MUN3S EKXJ451E□□470ML25S EKXJ451E□□560MK45S EKXJ451E□□560MUP1S EKXJ451E□□560MLN3S EKXJ451E□□560MM25S EKXJ451E□□680MK50S EKXJ451E□□680MU40S EKXJ451E□□680MU45S EKXJ451E□□680MLP1S EKXJ451E□□820MU50S EKXJ451E□□820ML40S EKXJ451E□□820ML45S EKXJ451E□□820MMN3S EKXJ451E□□101ML50S EKXJ451E□□101MMP1S EKXJ451E□□121MM40S EKXJ451E□□121MM45S EKXJ451E□□151MM50S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 5-55 CAT. No. E1001R MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS 160 to 500Vdc, long life, 105℃ KXJSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) 500 Case size tanδ φD×L(mm) 6.8 8.2 10 12 15 15 15 18 18 22 22 27 33 39 10 × 20 10 × 25 10 × 30 12.5× 20 10× 35 10 × 40 12.5 × 25 10× 45 12.5× 30 10 ×50 12.5 × 35 12.5 ×40 12.5× 45 12.5× 50 Rated ripple current (mArms/105℃, 120Hz) 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 90 110 130 135 170 175 165 190 190 230 220 260 285 330 Part No. EKXJ501E□□6R8MJ20S EKXJ501E□□8R2MJ25S EKXJ501E□□100MJ30S EKXJ501E□□120MK20S EKXJ501E□□150MJ35S EKXJ501E□□150MJ40S EKXJ501E□□150MK25S EKXJ501E□□180MJ45S EKXJ501E□□180MK30S EKXJ501E□□220MJ50S EKXJ501E□□220MK35S EKXJ501E□□270MK40S EKXJ501E□□330MK45S EKXJ501E□□390MK50S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers (160 to 450Vdc) Capacitance(µF) Frequency(Hz) 6.8 to 82 100 to 680 120 1.00 1.00 (500Vdc) 1k 1.75 1.67 10k 2.25 2.05 100k 2.50 2.25 Capacitance(µF) Frequency(Hz) 6.8 to 22 27 to 39 120 1.00 1.00 1k 1.78 1.75 10k 2.30 2.25 100k 2.59 2.50 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 5-56 CAT. No. E1001R
EKXJ451ELL470MM20S 价格&库存
很抱歉,暂时无法提供与“EKXJ451ELL470MM20S”相匹配的价格&库存,您可以联系我们找货
