EMVE160ARA100MD55G
EMVE160ARA100MD55G
    NCC(贵弥功)
    AEC-D4X5.2MM_SM
    贴片铝电解电容 SMD
EMVE160ARA100MD55G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 105C MVE @Rated voltage range : 6.3 to 450V, capacitance range : 0.47 to 6800MF @Endurance : 1000 to 2000 hours at 105C @Case size range : F4B5.2L to F18B21.5L @Solvent-proof type except 100 to 450Vdc (see PRECAUTIONS AND GUIDELINES) @Pb-free design downsized size extended MVK ?SPECIFICATIONS Items Characteristics Category Temperature Range -40 to +105C Rated Voltage Range Capacitance Tolerance Leakage Current 6.3 to 450Vdc P20%(M) Rated voltage(Vdc) 6.3 to 100V 160 to 450V D55 to JA0 I=0.01CV or 3MA, whichever is greater (2 minutes) KE0 to MN0 I=0.03CV or 4MA, whichever is greater (1 minute) I=0.04CV+100MA (1minute) Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V) See STANDARD RATINGS Dissipation Factor (tane) Endurance Shelf Life ?DIMENSIONS [mm] @Terminal Code : A @Size code : D55 to KG5 @Terminal Code : G @Size code : LH0 to MN0 W 0.3max. 0.3max. LP0.3 (Note) AP0.2 LP0.5 AP0.2 P CP0.2 BP0.2 FDP0.5 P CP0.2 BP0.2 FDP0.5 W Note : LP0.5 for HA0 to KG5 : Dummy terminals ?PART NUMBERING SYSTEM 2 3 4 5 6 7 (20C) (20C, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 400 to 450V Z(-25C)/Z(+20C) 2 2 2 2 2 3 4 3 D55 to JA0 Z(-40C)/Z(+20C) 3 3 3 4 6 8 12 4 Z(-25C)/Z(+20C) 2 2 2 2 3 4 5 2 3 6 KE0 to MN0 Z(-40C)/Z(+20C) (120Hz) 3 3 3 4 6 8 10 3 6 10 The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for the specified period of time at 105C. Size code D55 to F80 HA0 to MN0 2000 hours Time 1000 hours [P20% of the initial value Capacitance change [P30% of the initial value [200% of the initial specified value D.F. (tanE) [300% of the initial specified value [The initial specified value Leakage current [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1000 hours (500 hours for B55 to F80 size) at 105C without voltage applied. HA0 to MN0 Size code D55 to F80 Capacitance change [P25% of the initial value [P20% of the initial value D.F. (tanE) [200% of the initial specified value [200% of the initial specified value Leakage current [The initial specified value [The initial specified value Low Temperature Characteristics (Max. Impedance Ratio) 1 (20C, 120Hz) 8 9 10 11 12 13 14 15 16 C B A L Size code D 5.2 4.3 4.3 5.1 4 D55 5.2 5.3 5.3 5.9 5 E55 6.3 5.2 6.6 6.6 7.2 F55 6.3 5.7 6.6 6.6 7.2 F60 6.3 7.7 6.6 6.6 7.2 F80 8 10.0 8.3 8.3 9.0 HA0 10 10.0 10.3 10.3 11.0 JA0 12.5 13.5 13.0 13.0 13.7 KE0 12.5 16.0 13.0 13.0 13.7 KG5 16 16.5 17.0 17.0 18.0 LH0 16 21.5 17.0 17.0 18.0 LN0 18 16.5 19.0 19.0 20.0 MH0 18 21.5 19.0 19.0 20.0 MN0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.0 1.4 1.9 1.9 1.9 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 ?MARKING 17 18 E MV E AAA A AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 0.47MF:R47,100MF:101) Taping·Tray code Terminal code (A, G) Voltage code (ex. 6.3V:6R3,100V:101,450V:451) Series code Category D55 to JA0 Ex)16V22MF 7hE 22 16V KE0 to MN0 Ex)25V1000MF 0V MVE 1000 25V Please refer to "A guide to global code (surface mount type)" (1/2) CAT. No. E1001E SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 105C ?STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 Cap (mF) Size code 22 33 47 100 220 330 470 680 1000 1500 2200 2200 3300 3300 4700 4700 6800 6800 22 33 47 100 150 220 330 470 1000 2200 2200 3300 3300 4700 4700 10 22 33 47 100 150 220 330 470 680 1000 1000 2200 2200 3300 3300 10 22 33 47 100 150 220 330 470 1000 1000 2200 2200 4.7 10 22 33 47 100 150 220 330 D55 E55 E55 F55 F80 HA0 HA0 HA0 JA0 JA0 KE0 LH0 KG5 MH0 LN0 MH0 LN0 MN0 E55 E55 F55 F55 F80 F80 HA0 HA0 JA0 KG5 LH0 LH0 MH0 LN0 MN0 D55 E55 F55 F55 F55 F80 F80 HA0 HA0 JA0 KE0 LH0 LH0 MH0 LN0 MH0 E55 F55 F55 F55 F80 HA0 HA0 JA0 JA0 LH0 MH0 LN0 MN0 D55 E55 F55 F60 F80 F80 HA0 JA0 JA0 is non solvent-proof. Rated ripple current tane (mArms/ 105c,120Hz) 0.30 0.30 0.30 0.30 0.45 0.40 0.45 0.45 0.40 0.45 0.40 0.40 0.42 0.42 0.44 0.44 0.48 0.48 0.24 0.24 0.24 0.30 0.35 0.35 0.35 0.35 0.35 0.36 0.36 0.38 0.38 0.40 0.40 0.20 0.20 0.20 0.20 0.26 0.28 0.28 0.28 0.28 0.28 0.30 0.30 0.32 0.32 0.34 0.34 0.16 0.16 0.16 0.16 0.18 0.18 0.18 0.16 0.18 0.26 0.26 0.28 0.28 0.14 0.14 0.14 0.14 0.16 0.16 0.16 0.16 0.16 22 34 38 69 120 290 320 340 410 550 680 840 850 1000 1200 1200 1200 1350 30 34 48 69 100 120 290 320 410 750 850 1000 1100 1300 1350 17 30 45 48 69 100 120 290 320 470 550 650 950 1000 1200 1200 27 44 50 60 100 240 320 450 490 820 880 1250 1300 16 27 44 54 80 100 260 375 450 Part No. EMVE6R3ADA220MD55G EMVE6R3ADA330ME55G EMVE6R3ADA470ME55G EMVE6R3ADA101MF55G EMVE6R3ADA221MF80G EMVE6R3ADA331MHA0G EMVE6R3ADA471MHA0G EMVE6R3ADA681MHA0G EMVE6R3ADA102MJA0G EMVE6R3ADA152MJA0G EMVE6R3ASS222MKE0S EMVE6R3GTR222MLH0S EMVE6R3ASS332MKG5S EMVE6R3GTR332MMH0S EMVE6R3GTR472MLN0S EMVE6R3GTR472MMH0S EMVE6R3GTR682MLN0S EMVE6R3GTR682MMN0S EMVE100ADA220ME55G EMVE100ADA330ME55G EMVE100ADA470MF55G EMVE100ADA101MF55G EMVE100ADA151MF80G EMVE100ADA221MF80G EMVE100ADA331MHA0G EMVE100ADA471MHA0G EMVE100ADA102MJA0G EMVE100ASS222MKG5S EMVE100GTR222MLH0S EMVE100GTR332MLH0S EMVE100GTR332MMH0S EMVE100GTR472MLN0S EMVE100GTR472MMN0S EMVE160ADA100MD55G EMVE160ADA220ME55G EMVE160ADA330MF55G EMVE160ADA470MF55G EMVE160ADA101MF55G EMVE160ADA151MF80G EMVE160ADA221MF80G EMVE160ADA331MHA0G EMVE160ADA471MHA0G EMVE160ADA681MJA0G EMVE160ASS102MKE0S EMVE160GTR102MLH0S EMVE160GTR222MLH0S EMVE160GTR222MMH0S EMVE160GTR332MLN0S EMVE160GTR332MMH0S EMVE250ADA100ME55G EMVE250ADA220MF55G EMVE250ADA330MF55G EMVE250ADA470MF55G EMVE250ADA101MF80G EMVE250ADA151MHA0G EMVE250ADA221MHA0G EMVE250ADA331MJA0G EMVE250ADA471MJA0G EMVE250GTR102MLH0S EMVE250GTR102MMH0S EMVE250GTR222MLN0S EMVE250GTR222MMN0S EMVE350ADA4R7MD55G EMVE350ADA100ME55G EMVE350ADA220MF55G EMVE350ADA330MF60G EMVE350ADA470MF80G EMVE350ADA101MF80G EMVE350ADA151MHA0G EMVE350ADA221MJA0G EMVE350ADA331MJA0G WV (Vdc) 35 50 63 100 160 200 250 400 450 Cap (mF) Size code 470 470 1000 1000 2200 0.47 1.0 2.2 3.3 4.7 10 22 33 47 100 220 330 330 470 470 1000 0.47 1.0 2.2 3.3 4.7 10 22 33 47 100 220 220 330 330 470 470 22 33 47 68 100 100 220 220 330 33 47 68 68 100 10 22 33 47 47 68 4.7 10 22 33 33 47 4.7 10 22 3.3 4.7 10 22 KE0 LH0 LH0 MH0 MN0 D55 D55 D55 D55 E55 F55 F60 F80 F80 HA0 JA0 KE0 LH0 LH0 MH0 MN0 D55 D55 D55 E55 F55 F55 F80 HA0 HA0 JA0 KE0 LH0 LH0 MH0 LN0 MH0 HA0 JA0 KE0 KE0 KE0 LH0 LN0 MH0 MN0 KE0 LH0 LN0 MH0 LN0 KE0 KG5 LH0 LN0 MH0 MN0 KE0 KG5 LH0 LN0 MH0 MN0 KG5 LH0 MN0 KE0 KG5 LH0 MN0 Rated ripple current tane (mArms/ 105c,120Hz) 0.22 0.22 0.22 0.22 0.24 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.14 0.14 0.14 0.18 0.18 0.18 0.18 0.18 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.14 0.14 0.14 0.14 0.14 0.12 0.12 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 520 650 750 1000 1450 5.0 8.0 12 15 20 32 47 65 80 230 375 500 600 700 750 1200 5.0 8.0 12 17 22 32 58 140 170 310 470 560 700 750 900 900 100 150 250 300 380 450 750 750 980 95 260 320 320 380 80 110 220 270 270 330 65 105 180 230 230 280 50 85 130 40 50 85 130 Part No. EMVE350ASS471MKE0S EMVE350GTR471MLH0S EMVE350GTR102MLH0S EMVE350GTR102MMH0S EMVE350GTR222MMN0S EMVE500ADAR47MD55G EMVE500ADA1R0MD55G EMVE500ADA2R2MD55G EMVE500ADA3R3MD55G EMVE500ADA4R7ME55G EMVE500ADA100MF55G EMVE500ADA220MF60G EMVE500ADA330MF80G EMVE500ADA470MF80G EMVE500ADA101MHA0G EMVE500ADA221MJA0G EMVE500ASS331MKE0S EMVE500GTR331MLH0S EMVE500GTR471MLH0S EMVE500GTR471MMH0S EMVE500GTR102MMN0S EMVE630ADAR47MD55G EMVE630ADA1R0MD55G EMVE630ADA2R2MD55G EMVE630ADA3R3ME55G EMVE630ADA4R7MF55G EMVE630ADA100MF55G EMVE630ADA220MF80G EMVE630ADA330MHA0G EMVE630ADA470MHA0G EMVE630ADA101MJA0G EMVE630ASS221MKE0S EMVE630GTR221MLH0S EMVE630GTR331MLH0S EMVE630GTR331MMH0S EMVE630GTR471MLN0S EMVE630GTR471MMH0S EMVE101ADA220MHA0G EMVE101ADA330MJA0G EMVE101ASS470MKE0S EMVE101ASS680MKE0S EMVE101ASS101MKE0S EMVE101GTR101MLH0S EMVE101GTR221MLN0S EMVE101GTR221MMH0S EMVE101GTR331MMN0S EMVE161ASS330MKE0S EMVE161GTR470MLH0S EMVE161GTR680MLN0S EMVE161GTR680MMH0S EMVE161GTR101MLN0S EMVE201ASS100MKE0S EMVE201ASS220MKG5S EMVE201GTR330MLH0S EMVE201GTR470MLN0S EMVE201GTR470MMH0S EMVE201GTR680MMN0S EMVE251ASS4R7MKE0S EMVE251ASS100MKG5S EMVE251GTR220MLH0S EMVE251GTR330MLN0S EMVE251GTR330MMH0S EMVE251GTR470MMN0S EMVE401ASS4R7MKG5S EMVE401GTR100MLH0S EMVE401GTR220MMN0S EMVE451ASS3R3MKE0S EMVE451ASS4R7MKG5S EMVE451GTR100MLH0S EMVE451GTR220MMN0S SS : Taping / Tray code (2/2) CAT. No. E1001E
EMVE160ARA100MD55G 价格&库存
很抱歉,暂时无法提供与“EMVE160ARA100MD55G”相匹配的价格&库存,您可以联系我们找货
