EGXF250ELL432MK35S
EGXF250ELL432MK35S
    NCC(贵弥功)
EGXF250ELL432MK35S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS High ripple, 125℃ GXF Series ・Downsizing and high-ripple current version of GXE series ・For automobile modules and networking equipment and other high temperature applications Downsized ・Endurance with ripple current : 3,000 hours at 125℃ Higher ripple current ・Solvent resistant type except 160 to 400Vdc GXE ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. GXF ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +125℃ 25 to 400Vdc ±20% (M) 25 to 100Vdc I=0.03CV or 4μA, whichever is greater. (20℃, 120Hz) 160 to 400Vdc CV≦1,000 I=0.1CV+40 CV>1,000 I=0.04CV+100 Where, I : Max. leakage current(μA) , C : Nominal capacitance(μF), V : Rated voltage(V) (at 20℃ after 1 minute) Dissipation Factor Rated voltage(Vdc) 25V 35V 50V 63V 80V 100V 160 to 250V 350 to 400V (tanδ) tanδ 0.14 0.12 0.10 0.10 0.08 0.08 0.15 0.20 (Max.) When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase. (at 20℃, 120Hz) Low Temperature Rated voltage(Vdc) 25V 35V 50V 63V 80V 100V 160 to 250V 350 to 400V Characteristics Z /Z(+20℃) 2 2 2 2 2 2 3 6 (-25℃) (Max. Impedance Ratio) Z(-40℃)/Z(+20℃) 4 4 4 4 4 4 6 12 (at 120Hz) Endurance The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied(the peak voltage shall not exceed the rated voltage)for the 3,000 hours at 125℃. Rated Voltage 25 to 100Vdc 160 to 400Vdc Capacitance change ≦±30% of the initial value ≦±20% of the initial value D.F.(tanδ) ≦300% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value Shelf Life The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours (500hours for 160 to 400Vdc)at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated Voltage 25 to 100Vdc 160 to 400Vdc Capacitance change ≦±30% of the initial value ≦±20% of the initial value D.F.(tanδ) ≦300% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦500% of the initial specified value ◆DIMENSIONS [mm] F±0.5 Code : E ΦD Φd φD' φd Sleeve (PET : Brown) F±0.5 ●Terminal F ΦD' L' Vent 15min. 4min. (φ10) (φ12.5 t o φ18) L' 10 0.6 5.0 12.5 14.5 16 0.6 0.8 0.8 5.0 7.5 7.5 ΦD+0.5max. L+1.5max. 18 0.8 7.5 Gas escape end seal ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E GXF AAA E AA AAA M AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex.,39µF:390,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 25V:250,100V:101) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS High ripple, 125℃ GXFSeries ◆STANDARD RATINGS Rated ripple ESR Cap WV Case size (Ωmax./100kHz) current (mArms/ (Vdc) (μF) φDxL (mm) 125℃, 20℃ -40℃ 100kHz) 25 35 50 510 750 910 1,200 1,200 1,500 1,600 1,800 2,000 2,200 2,400 2,700 3,000 3,300 3,600 4,300 4,300 4,300 4,700 5,100 5,100 5,100 5,600 6,800 6,800 7,500 8,200 9,100 11,000 300 510 560 680 750 820 1,100 1,100 1,200 1,500 1,500 1,500 2,000 2,000 2,200 2,400 2,400 2,400 2,700 2,700 3,000 3,300 3,300 3,900 4,300 4,300 4,700 5,100 6,200 160 240 270 330 390 430 510 560 560 10×12.5 10×16 12.5×15 10×20 14.5×15 10×25 16×15 12.5×20 10×30 14.5×20 18×15 12.5×25 16×20 12.5×30 14.5×25 12.5×35 16×25 18×20 14.5×30 12.5×40 14.5×35 16×30 18×25 14.5×40 16×35 18×30 16×40 18×35 18×40 10×12.5 10×16 12.5×15 10×20 14.5×15 10×25 12.5×20 16×15 10×30 12.5×25 14.5×20 18×15 12.5×30 16×20 14.5×25 12.5×35 16×25 18×20 12.5×40 14.5×30 14.5×35 16×30 18×25 14.5×40 16×35 18×30 16×40 18×35 18×40 10×12.5 10×16 12.5×15 10×20 14.5×15 10×25 12.5×20 10×30 16×15 0.14 0.094 0.082 0.073 0.067 0.042 0.063 0.038 0.033 0.030 0.053 0.030 0.029 0.025 0.025 0.022 0.022 0.028 0.020 0.019 0.018 0.018 0.020 0.016 0.016 0.016 0.015 0.015 0.014 0.14 0.094 0.082 0.073 0.067 0.042 0.038 0.063 0.033 0.030 0.030 0.053 0.025 0.029 0.025 0.022 0.022 0.028 0.019 0.020 0.018 0.018 0.020 0.016 0.016 0.016 0.015 0.015 0.014 0.24 0.16 0.14 0.12 0.12 0.055 0.049 0.041 0.11 2.1 1.5 1.1 1.1 0.80 0.24 0.76 0.19 0.19 0.17 0.51 0.14 0.13 0.10 0.11 0.080 0.092 0.10 0.081 0.068 0.065 0.071 0.078 0.054 0.056 0.060 0.048 0.049 0.043 2.1 1.5 1.1 1.1 0.80 0.24 0.19 0.76 0.19 0.14 0.17 0.51 0.10 0.13 0.11 0.080 0.092 0.10 0.068 0.081 0.065 0.071 0.078 0.054 0.056 0.060 0.048 0.049 0.043 3.6 2.5 1.8 1.8 1.4 0.31 0.24 0.25 1.3 900 1,300 1,220 1,540 1,320 1,880 1,430 1,590 2,150 1,780 1,630 2,280 1,890 2,760 2,760 3,120 3,030 1,930 3,090 3,610 3,430 3,330 3,200 3,820 3,630 3,480 3,930 3,750 4,040 900 1,300 1,220 1,540 1,320 1,880 1,590 1,430 2,150 2,280 1,780 1,630 2,760 1,890 2,760 3,120 3,030 1,930 3,610 3,090 3,430 3,330 3,200 3,820 3,630 3,480 3,930 3,750 4,040 730 1,080 1,020 1,290 1,090 1,740 1,410 2,020 1,190 Part No. EGXF250E□□511MJC5S EGXF250E□□751MJ16S EGXF250E□□911MK15S EGXF250E□□122MJ20S EGXF250E□□122MU15S EGXF250E□□152MJ25S EGXF250E□□162ML15S EGXF250E□□182MK20S EGXF250E□□202MJ30S EGXF250E□□222MU20S EGXF250E□□242MM15S EGXF250E□□272MK25S EGXF250E□□302ML20S EGXF250E□□332MK30S EGXF250E□□362MU25S EGXF250E□□432MK35S EGXF250E□□432ML25S EGXF250E□□432MM20S EGXF250E□□472MU30S EGXF250E□□512MK40S EGXF250E□□512MU35S EGXF250E□□512ML30S EGXF250E□□562MM25S EGXF250E□□682MU40S EGXF250E□□682ML35S EGXF250E□□752MM30S EGXF250E□□822ML40S EGXF250E□□912MM35S EGXF250E□□113MM40S EGXF350E□□301MJC5S EGXF350E□□511MJ16S EGXF350E□□561MK15S EGXF350E□□681MJ20S EGXF350E□□751MU15S EGXF350E□□821MJ25S EGXF350E□□112MK20S EGXF350E□□112ML15S EGXF350E□□122MJ30S EGXF350E□□152MK25S EGXF350E□□152MU20S EGXF350E□□152MM15S EGXF350E□□202MK30S EGXF350E□□202ML20S EGXF350E□□222MU25S EGXF350E□□242MK35S EGXF350E□□242ML25S EGXF350E□□242MM20S EGXF350E□□272MK40S EGXF350E□□272MU30S EGXF350E□□302MU35S EGXF350E□□332ML30S EGXF350E□□332MM25S EGXF350E□□392MU40S EGXF350E□□432ML35S EGXF350E□□432MM30S EGXF350E□□472ML40S EGXF350E□□512MM35S EGXF350E□□622MM40S EGXF500E□□161MJC5S EGXF500E□□241MJ16S EGXF500E□□271MK15S EGXF500E□□331MJ20S EGXF500E□□391MU15S EGXF500E□□431MJ25S EGXF500E□□511MK20S EGXF500E□□561MJ30S EGXF500E□□561ML15S Rated ripple ESR Cap Case size (Ωmax./100kHz) current WV (mArms/ (mm) (Vdc) (μF) φDxL 125℃, 20℃ -40℃ 100kHz) 50 63 80 100 680 750 750 910 1,000 1,000 1,200 1,200 1,300 1,300 1,500 1,500 1,600 1,800 2,000 2,000 2,200 2,400 2,700 3,300 390 510 510 620 680 680 820 820 910 910 1,000 1,100 1,100 1,200 1,300 1,300 1,500 1,800 2,000 2,400 240 330 330 390 430 470 560 560 560 620 620 680 680 750 820 910 910 1,100 1,300 1,500 130 180 200 240 240 270 330 14.5×20 12.5×25 18×15 16×20 12.5×30 14.5×25 12.5×35 18×20 14.5×30 16×25 12.5×40 14.5×35 16×30 18×25 14.5×40 16×35 18×30 16×40 18×35 18×40 12.5×20 12.5×25 14.5×20 16×20 12.5×30 14.5×25 12.5×35 18×20 14.5×30 16×25 12.5×40 14.5×35 16×30 18×25 14.5×40 16×35 18×30 16×40 18×35 18×40 12.5×20 12.5×25 14.5×20 16×20 12.5×30 14.5×25 12.5×35 16×25 18×20 12.5×40 14.5×30 14.5×35 16×30 18×25 14.5×40 16×35 18×30 16×40 18×35 18×40 12.5×20 14.5×20 12.5×25 12.5×30 16×20 14.5×25 12.5×35 0.038 0.038 0.085 0.037 0.031 0.031 0.027 0.036 0.026 0.027 0.023 0.023 0.023 0.025 0.020 0.020 0.021 0.018 0.019 0.017 0.097 0.072 0.072 0.062 0.052 0.054 0.044 0.055 0.042 0.047 0.038 0.037 0.037 0.044 0.032 0.031 0.037 0.028 0.028 0.023 0.097 0.072 0.072 0.062 0.052 0.054 0.044 0.047 0.055 0.038 0.042 0.037 0.037 0.044 0.032 0.031 0.037 0.028 0.028 0.023 0.12 0.082 0.082 0.062 0.071 0.064 0.051 0.22 0.18 0.87 0.17 0.14 0.14 0.11 0.14 0.11 0.13 0.090 0.085 0.094 0.11 0.072 0.074 0.079 0.063 0.065 0.058 0.75 0.55 0.59 0.39 0.37 0.40 0.29 0.29 0.30 0.27 0.26 0.24 0.23 0.22 0.20 0.17 0.18 0.15 0.13 0.10 0.75 0.55 0.59 0.39 0.37 0.40 0.29 0.27 0.29 0.26 0.30 0.24 0.23 0.22 0.20 0.17 0.18 0.15 0.13 0.10 0.94 0.69 0.70 0.52 0.53 0.52 0.38 1,610 2,030 1,370 1,740 2,510 2,480 2,900 1,830 2,870 2,690 3,260 3,160 3,150 2,900 3,560 3,470 3,330 3,800 3,590 3,850 1,310 1,880 1,510 1,630 2,410 2,130 2,760 1,750 2,700 2,300 3,080 2,940 2,940 2,440 3,350 3,220 3,100 3,590 3,450 3,690 1,310 1,880 1,510 1,630 2,410 2,130 2,760 2,300 1,750 3,080 2,700 2,940 2,940 2,440 3,350 3,220 3,100 3,590 3,450 3,690 1,210 1,450 1,800 2,290 1,580 2,050 2,680 Part No. EGXF500E□□681MU20S EGXF500E□□751MK25S EGXF500E□□751MM15S EGXF500E□□911ML20S EGXF500E□□102MK30S EGXF500E□□102MU25S EGXF500E□□122MK35S EGXF500E□□122MM20S EGXF500E□□132MU30S EGXF500E□□132ML25S EGXF500E□□152MK40S EGXF500E□□152MU35S EGXF500E□□162ML30S EGXF500E□□182MM25S EGXF500E□□202MU40S EGXF500E□□202ML35S EGXF500E□□222MM30S EGXF500E□□242ML40S EGXF500E□□272MM35S EGXF500E□□332MM40S EGXF630E□□391MK20S EGXF630E□□511MK25S EGXF630E□□511MU20S EGXF630E□□621ML20S EGXF630E□□681MK30S EGXF630E□□681MU25S EGXF630E□□821MK35S EGXF630E□□821MM20S EGXF630E□□911MU30S EGXF630E□□911ML25S EGXF630E□□102MK40S EGXF630E□□112MU35S EGXF630E□□112ML30S EGXF630E□□122MM25S EGXF630E□□132MU40S EGXF630E□□132ML35S EGXF630E□□152MM30S EGXF630E□□182ML40S EGXF630E□□202MM35S EGXF630E□□242MM40S EGXF800E□□241MK20S EGXF800E□□331MK25S EGXF800E□□331MU20S EGXF800E□□391ML20S EGXF800E□□431MK30S EGXF800E□□471MU25S EGXF800E□□561MK35S EGXF800E□□561ML25S EGXF800E□□561MM20S EGXF800E□□621MK40S EGXF800E□□621MU30S EGXF800E□□681MU35S EGXF800E□□681ML30S EGXF800E□□751MM25S EGXF800E□□821MU40S EGXF800E□□911ML35S EGXF800E□□911MM30S EGXF800E□□112ML40S EGXF800E□□132MM35S EGXF800E□□152MM40S EGXF101E□□131MK20S EGXF101E□□181MU20S EGXF101E□□201MK25S EGXF101E□□241MK30S EGXF101E□□241ML20S EGXF101E□□271MU25S EGXF101E□□331MK35S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS High ripple, 125℃ GXFSeries ◆STANDARD RATINGS is not solvent resistant. Rated ripple ESR Cap WV Case size (Ωmax./100kHz) current (mArms/ (Vdc) (μF) φDxL (mm) 125℃, 20℃ -40℃ 100kHz) 330 330 360 390 390 390 430 510 510 560 620 680 820 51 62 75 82 100 100 110 120 130 150 150 180 180 180 200 200 220 240 270 36 43 56 62 75 75 82 82 100 100 110 130 130 130 150 150 160 180 200 24 30 36 100 160 200 250 16×25 18×20 14.5×30 12.5×40 14.5×35 16×30 18×25 14.5×40 16×35 18×30 16×40 18×35 18×40 10×20 10×25 12.5×20 10×30 10×35 14.5×20 12.5×25 10×40 16×20 12.5×30 14.5×25 12.5×35 14.5×30 18×20 12.5×40 16×25 14.5×35 18×25 14.5×40 10×20 10×25 12.5×20 10×30 10×35 14.5×20 10×40 12.5×25 12.5×30 16×20 14.5×25 12.5×35 14.5×30 18×20 12.5×40 16×25 14.5×35 18×25 14.5×40 10×20 10×25 12.5×20 0.057 0.069 0.050 0.044 0.044 0.044 0.054 0.038 0.037 0.043 0.032 0.034 0.029 - 0.39 0.39 0.40 0.33 0.33 0.33 0.32 0.26 0.26 0.26 0.21 0.19 0.16 - 2,190 1,690 2,620 2,970 2,850 2,770 2,310 3,230 3,010 2,830 3,320 3,210 3,410 900 1,200 1,220 1,410 1,600 1,340 1,510 1,790 1,500 1,770 1,610 1,970 1,880 1,730 2,150 1,850 2,030 2,050 2,250 900 1,200 1,220 1,410 1,600 1,340 1,790 1,510 1,770 1,500 1,610 1,970 1,880 1,730 2,150 1,850 2,030 2,050 2,250 900 1,200 1,220 Rated ripple ESR Cap Case size (Ωmax./100kHz) current WV (mArms/ (mm) (Vdc) (μF) φDxL 125℃, 20℃ -40℃ 100kHz) Part No. EGXF101E□□331ML25S EGXF101E□□331MM20S EGXF101E□□361MU30S EGXF101E□□391MK40S EGXF101E□□391MU35S EGXF101E□□391ML30S EGXF101E□□431MM25S EGXF101E□□511MU40S EGXF101E□□511ML35S EGXF101E□□561MM30S EGXF101E□□621ML40S EGXF101E□□681MM35S EGXF101E□□821MM40S EGXF161E□□510MJ20S EGXF161E□□620MJ25S EGXF161E□□750MK20S EGXF161E□□820MJ30S EGXF161E□□101MJ35S EGXF161E□□101MU20S EGXF161E□□111MK25S EGXF161E□□121MJ40S EGXF161E□□131ML20S EGXF161E□□151MK30S EGXF161E□□151MU25S EGXF161E□□181MK35S EGXF161E□□181MU30S EGXF161E□□181MM20S EGXF161E□□201MK40S EGXF161E□□201ML25S EGXF161E□□221MU35S EGXF161E□□241MM25S EGXF161E□□271MU40S EGXF201E□□360MJ20S EGXF201E□□430MJ25S EGXF201E□□560MK20S EGXF201E□□620MJ30S EGXF201E□□750MJ35S EGXF201E□□750MU20S EGXF201E□□820MJ40S EGXF201E□□820MK25S EGXF201E□□101MK30S EGXF201E□□101ML20S EGXF201E□□111MU25S EGXF201E□□131MK35S EGXF201E□□131MU30S EGXF201E□□131MM20S EGXF201E□□151MK40S EGXF201E□□151ML25S EGXF201E□□161MU35S EGXF201E□□181MM25S EGXF201E□□201MU40S EGXF251E□□240MJ20S EGXF251E□□300MJ25S EGXF251E□□360MK20S 250 350 400 39 47 51 51 56 62 68 68 82 82 91 91 100 100 120 130 16 20 24 27 33 33 36 36 43 47 47 56 56 56 62 68 68 75 91 12 16 20 20 24 24 27 30 33 36 36 43 43 47 47 51 56 62 68 10×30 10×35 12.5×25 14.5×20 10×40 16×20 12.5×30 14.5×25 12.5×35 18×20 14.5×30 16×25 12.5×40 14.5×35 18×25 14.5×40 10×20 10×25 12.5×20 10×30 10×35 14.5×20 10×40 12.5×25 16×20 12.5×30 14.5×25 12.5×35 16×25 18×20 14.5×30 12.5×40 14.5×35 18×25 14.5×40 10×20 10×25 10×30 12.5×20 10×35 14.5×20 12.5×25 10×40 16×20 12.5×30 14.5×25 12.5×35 18×20 14.5×30 16×25 12.5×40 14.5×35 18×25 14.5×40 - - 1,410 1,600 1,510 1,340 1,790 1,500 1,770 1,610 1,970 1,730 1,880 1,850 2,150 2,030 2,050 2,250 460 610 680 720 820 870 940 980 970 1,210 1,210 1,330 1,130 1,060 1,410 1,450 1,590 1,200 1,820 460 610 720 680 820 870 980 940 970 1,210 1,210 1,330 1,060 1,410 1,130 1,450 1,590 1,200 1,820 Part No. EGXF251E□□390MJ30S EGXF251E□□470MJ35S EGXF251E□□510MK25S EGXF251E□□510MU20S EGXF251E□□560MJ40S EGXF251E□□620ML20S EGXF251E□□680MK30S EGXF251E□□680MU25S EGXF251E□□820MK35S EGXF251E□□820MM20S EGXF251E□□910MU30S EGXF251E□□910ML25S EGXF251E□□101MK40S EGXF251E□□101MU35S EGXF251E□□121MM25S EGXF251E□□131MU40S EGXF351E□□160MJ20S EGXF351E□□200MJ25S EGXF351E□□240MK20S EGXF351E□□270MJ30S EGXF351E□□330MJ35S EGXF351E□□330MU20S EGXF351E□□360MJ40S EGXF351E□□360MK25S EGXF351E□□430ML20S EGXF351E□□470MK30S EGXF351E□□470MU25S EGXF351E□□560MK35S EGXF351E□□560ML25S EGXF351E□□560MM20S EGXF351E□□620MU30S EGXF351E□□680MK40S EGXF351E□□680MU35S EGXF351E□□750MM25S EGXF351E□□910MU40S EGXF401E□□120MJ20S EGXF401E□□160MJ25S EGXF401E□□200MJ30S EGXF401E□□200MK20S EGXF401E□□240MJ35S EGXF401E□□240MU20S EGXF401E□□270MK25S EGXF401E□□300MJ40S EGXF401E□□330ML20S EGXF401E□□360MK30S EGXF401E□□360MU25S EGXF401E□□430MK35S EGXF401E□□430MM20S EGXF401E□□470MU30S EGXF401E□□470ML25S EGXF401E□□510MK40S EGXF401E□□560MU35S EGXF401E□□620MM25S EGXF401E□□680MU40S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers (25 to 100Vdc) Frequency(Hz) Capacitance(µF) 130 270 620 2,200 4,700 to to to to to 240 560 2,000 4,300 11,000 120 0.40 0.50 0.60 0.75 0.85 (160 to 400Vdc) 1k 0.82 0.85 0.87 0.90 0.95 10k 0.93 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 Capacitance(µF) Frequency(Hz) 12 to 33 36 to 270 50 0.15 0.25 120 0.30 0.35 300 0.45 0.50 1k 0.65 0.70 10k 0.95 0.96 100k 1.00 1.00 Please contact us for lifetime estimation. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EGXF250ELL432MK35S 价格&库存
很抱歉,暂时无法提供与“EGXF250ELL432MK35S”相匹配的价格&库存,您可以联系我们找货
