B6B-PH-K-S-GW
B6B-PH-K-S-GW
    JST
    插件,P=2mm
    线对板针座 1x6P 直插 间距:2mm
B6B-PH-K-S-GW 数据手册
PH CONNECTOR Emboss Tape 2.0 mm pitch/Disconnectable Crimp style connectors 2 5 6 PH CONNECTOR Specifications 4 3 This is a thin, low-profile 2.0 mm pitch connector 8.0 mm in height after mounting and 4.5 mm in width. It is designed to meet the demand for high-density connection of internal wires to printed circuit boards. It is compact, highly reliable and low in cost. ● Reliable contact ● Fully shrouded header ● Printed circuit board retention mechanism ● Surface mount model (SMT) • Current rating: 2 A AC/DC (AWG #24) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/ minute • Applicable wire: AWG #32 to #24 • Applicable PC board thickness: 0.8 to 1.6 mm * In using the products,refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * Contact JST for details. * RoHS2 compliance   Standards Recognized E60389 R75087 PC board layout and Assembly layout 〈Through-hole type (viewed from soldering side) 〉 Side entry type Top entry type 2 2 4.5 ± 0.05 ± 0.05 (9.6) (8) φ0.7 +0.1 0 6 +0.1 0 φ0.7 4.8 7.6 6.25 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. Hole dimensions differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 〈SMT type (viewed from component side) 〉 SM4 type Top entry type ±0.1 1.6 ±0.1 2 ±0.05 5 ±0.1 1.6 ±0.1 2 ±0.05 End face of wafer on the mating side 5.5 max. 3.4 (1) 7.6 5.5 (8.6) ±0.1 (9.6) 6.6 Circuit No.1 7.5 min. 3 2 max. ±0.1 1 0.2 End face of wafer on the mating side 1.5 (2) 9 min. 1.6 SM4 type Side entry type 1 min. 1min. Circuit No.1 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. 1 PH CONNECTOR Contact 1 2.05 mm2 SPH-002T-P0.5S SPH-002T-P0.5L SPH-004T-P0.5S 2.08 2.85 Applicable wire Model No. 1.5 5.7 0.05 ~ 0.22 0.08 ~ 0.22 0.032~0.08 AWG # Insulation O.D. (mm) 30~24 0.8~1.5 28~24 0.8~1.5 32~28 0.5~0.9 Q'ty/ reel 8,000 10,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) Applicator Crimping machine Crimp applicator Contact SPH-002T-P0.5S MKS-L SPH-002T-P0.5L AP-K2N SPH-004T-P0.5S Dies Crimp applicator with dies MK/SPH-002-05S APLMK SPH002-05S MK/SPH-002-05L APLMK SPH002-05L MK/SPH-002-05S APLMK SPH004-05S MKS-L-10 RoHS2 compliance Note: 1. Contact JST for gold-plated products. 2. S  PH-002T-P0.5L is low-insertion force type contact, for easier insertion/ withdrawal, which would be less resistant to the vibration. The crimp height is different from the standard. 3. C  ontact JST for details. Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits B A 2 2 4.5 0.5 Circuit No.1 1.9 3 4 5 7 6.35 H JST 8 6 8 9 10 □0.6 11 12 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PHR-2-oo- 13 14 15 16 (blank)...natural (white) BK...black R...red TR...tomato red BL...blue Y...yellow L...lemon yellow M...green D...orange N...brown P...purple PK...pink H...gray LE...light blue FY...vivid yellow DPK...dark pink Model No. PHR-2 PHR-3 PHR-4 PHR-5 PHR-6 PHR-7 PHR-8 PHR-9 PHR-10 PHR-11 PHR-12 PHR-13 PHR-14 PHR-15 PHR-16 A Dimensions (mm) B Q'ty/ box 2.0 5.8 1,000 4.0 7.8 1,000 6.0 9.8 1,000 8.0 11.8 1,000 10.0 13.8 1,000 12.0 15.8 1,000 14.0 17.8 1,000 16.0 19.8 1,000 18.0 21.8 1,000 20.0 23.8 1,000 22.0 25.8 1,000 24.0 27.8 1,000 26.0 29.8 1,000 28.0 31.8 1,000 30.0 33.8 1,000 Material and Finish PA 66, UL94V-0, natural (white) RoHS2 compliance Through-hole type Header No. of circuits Top entry type 2 (2 circuits) (3 circuits or more) 3 4.5 4.5 1.7 B 4 5 1.7 B 6 7 6 6 8 9 10 Circuit No.1 □0.5 2 1.95 □0.5 A Circuit No.1 16 Dimensions (mm) Q'ty/box A B Top entry type Side entry type 2.0 5.9 1,000 1,000 4.0 7.9 1,000 1,000 6.0 9.9 1,000 500 8.0 11.9 1,000 500 10.0 13.9 1,000 500 12.0 15.9 500 500 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 500 250 20.0 23.9 500 250 22.0 25.9 400 250 24.0 27.9 250 250 26.0 29.9 250 250 28.0 31.9 250 200 30.0 33.9 250 200 Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) 4.8 1.7 2 A □0.5 Circuit No.1 1.6 6 B 2 13 15 Side entry type 1.95 12 14 6.25 1.95 A 3.4 3.4 11 Model No. Top entry type Side entry type B2B-PH-K-S S2B-PH-K-S B3B-PH-K-S S3B-PH-K-S B4B-PH-K-S S4B-PH-K-S B5B-PH-K-S S5B-PH-K-S B6B-PH-K-S S6B-PH-K-S B7B-PH-K-S S7B-PH-K-S B8B-PH-K-S S8B-PH-K-S B9B-PH-K-S S9B-PH-K-S B10B-PH-K-S S10B-PH-K-S B11B-PH-K-S S11B-PH-K-S B12B-PH-K-S S12B-PH-K-S B13B-PH-K-S S13B-PH-K-S B14B-PH-K-S S14B-PH-K-S B15B-PH-K-S S15B-PH-K-S B16B-PH-K-S S16B-PH-K-S 3.4 RoHS2 compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-PH-K-oo S...natural (white) K...black R...red TR...tomato red E...blue Y...yellow L...lemon yellow M...green O...orange N...brown P...purple PK...pink H...gray LE...light blue FY...vivid yellow (blank)...ivory PH CONNECTOR Through-hole type Header〈Low insertion force type〉 No. of circuits Top entry type (2 circuits) 2 (3 circuits or more) 3 B 1.7 B 4 4.5 4.5 5 1.7 6 6 6 7 8 9 3.4 3.4 10 1.95 A Circuit No.1 □0.5 12 □0.5 2 1.95 11 Circuit No.1 A 13 14 15 Side entry type 16 Dimensions (mm) A B Q'ty/box Top entry type Side entry type 2.0 5.9 1,000 1,000 4.0 7.9 1,000 1,000 6.0 9.9 1,000 500 8.0 11.9 1,000 500 10.0 13.9 1,000 500 12.0 15.9 500 500 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 500 250 20.0 23.9 500 250 22.0 25.9 400 250 24.0 27.9 250 250 26.0 29.9 250 200 28.0 31.9 250 200 30.0 33.9 250 200 Material and Finish 4.8 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, gray 1.7 B Model No. Top entry type Side entry type B2B-PH-KL S2B-PH-KL B3B-PH-KL S3B-PH-KL B4B-PH-KL S4B-PH-KL B5B-PH-KL S5B-PH-KL B6B-PH-KL S6B-PH-KL B7B-PH-KL S7B-PH-KL B8B-PH-KL S8B-PH-KL B9B-PH-KL S9B-PH-KL B10B-PH-KL S10B-PH-KL B11B-PH-KL S11B-PH-KL B12B-PH-KL S12B-PH-KL B13B-PH-KL S13B-PH-KL B14B-PH-KL S14B-PH-KL B15B-PH-KL S15B-PH-KL B16B-PH-KL S16B-PH-KL 6 6.25 RoHS2 compliance This product displays (LF)(SN) on a label. A Circuit No.1 3.4 1.6 □0.5 2 1.95 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-PH-KL-oo (blank)...gray R...red E...blue S...natural (white) SMT type Header Top entry type No. of circuits B 2.975 2 (2) 5 A 3 1.9 2 4 5 6.6 6 7 8 Circuit No.1 1.4 2.2 9 10 11 Side entry type 12 13 2.4 14 5.5 15 Circuit No.1 2.95 16 1.6 2 A B 6 (2.6) Model No. Top entry type Side entry type B2B-PH-SM4-TB B3B-PH-SM4-TB B4B-PH-SM4-TB B5B-PH-SM4-TB B6B-PH-SM4-TB B7B-PH-SM4-TB B8B-PH-SM4-TB B9B-PH-SM4-TB B10B-PH-SM4-TB B11B-PH-SM4-TB B12B-PH-SM4-TB B13B-PH-SM4-TB B14B-PH-SM4-TB B15B-PH-SM4-TB B16B-PH-SM4-TB S2B-PH-SM4-TB S3B-PH-SM4-TB S4B-PH-SM4-TB S5B-PH-SM4-TB S6B-PH-SM4-TB S7B-PH-SM4-TB S8B-PH-SM4-TB S9B-PH-SM4-TB S10B-PH-SM4-TB S11B-PH-SM4-TB S12B-PH-SM4-TB S13B-PH-SM4-TB S14B-PH-SM4-TB S15B-PH-SM4-TB — Dimensions (mm) B A Top entry type Side entry type Q'ty/ reel 2.0 7.95 7.9 1,000 4.0 9.95 9.9 1,000 6.0 11.95 11.9 1,000 8.0 13.95 13.9 1,000 10.0 15.95 15.9 1,000 12.0 17.95 17.9 1,000 14.0 19.95 19.9 1,000 16.0 21.95 21.9 1,000 18.0 23.95 23.9 1,000 20.0 25.95 25.9 1,000 22.0 27.95 27.9 1,000 24.0 29.95 29.9 1,000 26.0 31.95 31.9 1,000 28.0 33.95 33.9 1,000 30.0 35.95 – 1,000 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. Note: Contact JST for the top entry type headers with suction cap. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-PH-SM4-oo-TB (blank)...natural (ivory) R...red E...blue M...green L...lemon yellow K...black DPK...dark pink 3
B6B-PH-K-S-GW 价格&库存
很抱歉,暂时无法提供与“B6B-PH-K-S-GW”相匹配的价格&库存,您可以联系我们找货
B6B-PH-K-S-GW
  • 1+7.186801+0.93280
  • 10+6.3364010+0.82240
  • 25+5.7974025+0.75240
  • 100+5.22240100+0.67780
  • 250+4.76720250+0.61870
  • 1000+3.952701000+0.51300
  • 3000+3.701203000+0.48040
  • 5000+3.533505000+0.45860
  • 10000+3.3538010000+0.43530
库存:1995
