S6A THRU S6M
FEATURES
Plastic package has Underwrites Laboratory Flammability Classification 94V-0
Metal-Silicon Junction
For surface mount applications
Guard ring for over voltage protection
High forward surge current capability
Super Low forward voltage
High temperature soldering guaranteed: 260℃/10 seconds at terminals
MECHANICAL DATA
Case: Transfer molded plastic
Epoxy: UL94V-O rate flame retardant
Polarity: Color band denotes cathode end
Lead: Plated axial lead, solderable per MIL-STD-750 method 2026
Mounting position: Surface Mounted
Weight: 0.007 ounce, 0.25 grams
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25OC ambient temperature unless otherwise specified
Single Phase, half wave, 60Hz, resistive or inductive load
For capacitive load derate current by 20%
SYMBOLS
S6A
S6B
S6D
S6G
S6J
S6K
S6M
UNIT
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
Volts
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
720
Volts
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
Volts
Maximum Average Forward Rectified Current
I(AV)
6.0
Amp
Peak Forward Surge Current
8.3ms single half sine-wave superimposed on
rated load
IFSM
120
Amps
Maximum Instantaneous Forward Voltage at
6.0A (Note 1)
VF
1.2
Volts
Maximum DC Reverse Current at
rated DC Blocking Voltage
TA = 25℃
Maximum reverse recovery time(Note 2)
Typical Thermal Resistance
100
uA
Trr
>800
us
RθJL
10
℃/W
RθJA
100
℃/W
TJ
-55 to +150
TSTG
-55 to +150
Operating Temperature Range
Storage Temperature Range
10
IR
TA = 100℃
Notes:
1. Pulse test: 300μs pulse width, 1% duty cycle
2. Test conditions : IF=0.5A,IR=1.0A,IRR=0.25A
ht t p : //
Revision:20160808-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
S6A THRU S6M
RATINGS AND CHARACTERISTIC CURVES
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
AVERAGE FORWARD CURRENT. (A)
7
6
4
2
RESISTIVE OR
INDUCTIVE LOAD
P. C. BOARD MOUNTED ON 8.0mm2
PAD AREAS
1
60
70
80
90
100
110
120
130
140
150
165
o
LEAD TEMPERATURE. ( C)
100
INSTANTANEOUS REVERSE CURRENT. ( A)
FIG.3- TYPICAL REVERSE CHARACTERISTICS
1000
INSTANTANEOUS FORWARD CURRENT. (A)
FIG.2- TYPICAL FORWARD CHARACTERISTICS
100
30
Tj=25 0C
PULSE WIDTH-300 S
2% DUTY CYCLE
10
3
1
0.1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
10
Tj=100 0C
1
0.01
2.0
Tj=25 0C
0.1
FORWARD VOLTAGE. (V)
40
60
80
100
120
140
FIG.5- TYPICAL JUNCTION CAPACITANCE
FIG.4- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
1000
250
JUNCTION CAPACITANCE.(pF)
PEAK FORWARD SURGE CURRENT. (A)
300
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
200
Tj=25 0C
150
100
500
120
Tj=25 0C
100
50
50
1
5
10
50
100
1
NUMBER OF CYCLES AT 60Hz
ht t p : //
www.lgesemi .c o m
10
50
100
REVERSE VOLTAGE. (V)
S6A THRU S6M
OUTLINE DIMENSION
All Dimension in inches and (millimeters)
SMC(DO-214AB)
0.114(2.90)
0.126(3.20)
0.220(5.59)
0.245(6.22)
0.260(6.60)
0.280(7.11)
0.305(7.75)
0.320(8.13)
0.012(0.305)
0.006(0.152)
0.079(2.06)
0.103(2.62)
0.060(1.50)
0.030(0.76)
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMC
3000/REEL
42000
36X36X36.5
18.50
15.50
ht t p : //
0.008(0.203)Max.
www.lgesemi .c o m
很抱歉,暂时无法提供与“S6MC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.58894
- 50+0.48688
- 150+0.43585
- 500+0.39765
- 3000+0.32038
- 6000+0.30511
