GS1M
GS1M
    LGE(鲁光)
    SMA(DO-214AC)
    整流二极管 VRRM=1KV If=1A VF=1.1V CJ=15pF SMA
GS1M 数据手册
GS1A-GS1M Surface Mount Rectifiers VOLTAGE RANGE: 50 ---- 1000V CURRENT: 1.0 A Features       For surface mounted applications Low leakage Low forward voltage drop High current capability Easily cleaned with Alcohol,Isopropnol and similar solvents The plastic material carries U/L recognition 94V-0 SMA/DO-214AC 0. 181( 4. 60) 0. 161( 4. 10) 0. 108( 2. 75) 0. 096( 2. 45) 0. 063(1.60) 0. 051(1.30) 0. 209( 5. 30) 0. 193( 4. 90) Mechanical Data      0. 012(0.30) 0. 006(0.15) Case: JEDEC DO-214AC,molded plastic Terminals: Solder plated, solderable per MIL- STD-202,Method 208 Polarity: Color band denotes cathode end Weight: 0.002 ounces, 0.064 grams Mounting position: Any 0.096(2.45) 0.078(2.00) 0. 059( 1. 50) 0. 035( 0. 90) 0.008(0.20) 0. 002(0.05) Dimensions in inches and(millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ambient temperature unless otherwise specified. Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%. GS1A GS1B GS1D GS1G GS1J GS1K GS1M UNITS Maximum recurrent peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current @TL=110 I(AV) 1.0 A I FSM 30 A Maximum instantaneous forward voltage at 1.0 A Maximum reverse current @TA=25 at rated DC blocking voltage @TA=100 VF 1.1 V IR 5.0 50 µA Typical junction capacitance (Note1) CJ 15 pF RθJA 75 TJ - 55 --- + 150 TSTG - 55 --- + 150 Peak forward surge current 8.3ms single half-sine-wave superimposed on rated load TJ=125 Typical thermal resistance (Note2) Operating temperature range Storage temperature range /W NOTE: 1. Measured at 1.0MHz and applied reverse voltage of 4.0V DC. 2. Thermal resistance from junction to ambient ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com GS1A-GS1M Surface Mount Rectifiers Ratings AND Charactieristic Curves FIG.1 -- FORWARD DERATING CURVE FIG.2 PEAK FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT,AMPERES AVERAGE FORWARD CURRENT,AMPERES 1.2 Resistive or inductive Load 1.0 0.8 0.6 0.4 0.2X0.2(5.0X5.0mm) THICK COPPERPAND AREAS 0.2 0 0 20 40 60 80 100 120 140 160 10 0 O T L = 11 0 C 8 .3 m s S in g le H a lf S in e (J E D E C M e th o d ) 30 10 1 1 AMBIENT TEMPERATURE INSTANTANEOUS FORWARD CURRENT,AMPERES O TJ=25 C 1 0.6 0.8 1.0. S 1.2 1.4 1.6 1.8 100 INSTANTANEOUS REVERSE CURRENT MICROAMPERES 10 0.01 0.4 2.0 INSTANTANEOUS FORWARD VOLTAGE,VOLTS 10 O TJ=125 C 1 O TJ=25OC 0.01 0.001 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE, FIG.6-TRANSIENT THERMAL IMPEDANCE 100 100 TRANSIENT THERMAL IMPEDANCE, /W JUNCTION CAPACITANCE pF TJ=75 C 0.1 FIG.5-TYPICAL JUNCTION CAPACITANCE 0 TJ=25 C f=1.0MHZ Vsig=50mVp-p 10 1 0.01 0.1 1 10 100 10 1 UNITS MOUNTED on 0.20x0.20''(5.0X5.0mm)X0.5mil INCHES(0.013mm) THICK COPPERLAND AREAS 0.1 0.01 REVERSE VOLTAGE,VOLTS 0.1 1 10 100 PULSE DURATON,SEC PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMA 5000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 10 0 FIG.4 -- TYPICAL REVERSE CHARACTERISTICS 100 Puise Width=300 1%DUTY CYCLE 10 NUMBER OF CYCLES AT 60Hz FIG.3 -- TYPICAL FORWARD CHARACTERISTICS 0.1 W a ve www.lgesemi .c o m mail:lge@lgesemi.com
很抱歉,暂时无法提供与“GS1M”相匹配的价格&库存,您可以联系我们找货
GS1M
  • 1+0.09750
  • 100+0.09100
  • 300+0.08450
  • 500+0.07800
  • 2000+0.07475
  • 5000+0.07280
