NXS0101GSH
NXS0101GSH
    NEXPERIA(安世)
    XSON6
    NXS0101GSH
NXS0101GSH 数据手册
NXS0101 Dual supply translating transceiver; open drain; auto direction sensing Rev. 1.1 — 6 April 2020 Product data sheet 1. General description The NXS0101 is a 1-bit, dual supply translating transceiver with auto direction sensing, that enables bidirectional voltage level translation. It features one 1-bit input-output port (A and B), one output enable input (OE) and two supply pins (VCC(A) and VCC(B)). VCC(A) can be supplied at any voltage between 1.65 V and 3.6 V and VCC(B) can be supplied at any voltage between 2.3 V and 5.5 V, making the device suitable for translating between any of the voltage nodes (1.8 V, 2.5 V, 3.3 V and 5.0 V). Pins A and OE are referenced to VCC(A) and pin B is referenced to VCC(B). A LOW level at pin OE causes the output to assume a high-impedance OFF-state. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • Wide supply voltage range: • VCC(A): 1.65 V to 3.6 V and VCC(B): 2.3 V to 5.5 V Maximum data rates: • Push-pull: 24 Mbps IOFF circuitry provides partial Power-down mode operation Inputs accept voltages up to 5.5 V ESD protection: • HBM: ANSI/ESDA/Jedec JS-001 Class 2 exceeds 2.5 kV for A port • HBM: ANSI/ESDA/Jedec JS-001 Class 3B exceeds 8 kV for B port • CDM: ANSI/ESDA/Jedec JS-002 Class C3 exceeds 1.5 kV Latch-up performance exceeds 100 mA per JESD 78B Class II Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Applications • • • • Desktop PC Handset Smartphone Tablet 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version NXS0101GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1 × 1.45 × 0.5 mm NXS0101GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 × 1.0 × 0.35 mm SOT1202 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 5. Marking Table 2. Marking Type number Marking code[1] NXS0101GM m1 NXS0101GS m1 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram VCC(A) VCC(B) OE T1 ONE SHOT ONE SHOT T2 10 kΩ 10 kΩ GATE BIAS T3 A B aaa-030598 Fig. 1. Functional diagram 7. Pinning information 7.1. Pinning NXS0101 NXS0101 VCC(A) 1 6 VCC(B) GND 2 5 OE A 3 4 B VCCA(A) 1 6 VCC(B) GND 2 5 OE A 3 4 B aaa-030599 aaa-030600 Transparent top view Transparent top view Fig. 2. Pin configuration SOT886 (XSON6) NXS0101 Product data sheet Fig. 3. Pin configuration SOT1202 (XSON6) All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 2 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 7.2. Pin description Table 3. Pin description Symbol Pin Description VCC(A) 1 supply voltage A GND 2 ground (0 V) A 3 data input or output (referenced to VCC(A)) B 4 data input or output (referenced to VCC(B)) OE 5 output enable input (active HIGH; referenced to VCC(A)) VCC(B) 6 supply voltage B 8. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Input Input/output VCC(A)[1] VCC(B) OE A B 1.65 V to 3.6 V 2.3 V to 5.5 V L Z Z 1.65 V to 3.6 V 2.3 V to 5.5 V H input or output output or input GND 2.3 V to 5.5 V X Z Z 1.65 V to 3.6 V GND X Z Z Supply voltage [1] VCC(A) must be less than or equal to VCC(B). 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max Unit VCC(A) supply voltage A Conditions -0.5 +6.5 V VCC(B) supply voltage B -0.5 +6.5 V VI input voltage [1] -0.5 +6.5 V [1] -0.5 +6.5 V [1][2][3] -0.5 VCCI + 0.5 V [1] -0.5 +6.5 V [1][3][4] -0.5 VCCO + 0.5 V OE Power-down or 3-state mode A, B Active mode A, B VO output voltage Power-down or 3-state mode A, B Active mode A, B NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 3 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing Symbol Parameter Conditions Min Max Unit IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO < 0 V -50 - mA IO output current VO = 0 V to VCCO - ±50 mA ICC supply current ICC(A) or ICC(B) - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] [3] [4] [5] Tamb = -40 °C to +125 °C [4] [5] The minimum input and minimum output voltage ratings may be exceeded if the input and output current ratings are observed. VCCI is the supply voltage associated with the input. VCCI + 0.5 V or VCCO) + 0.5 V should not exceed 6.5 V. VCCO is the supply voltage associated with the output. For SOT886 (XSON6) package: Ptot derates linearly with 3.3 mW/K above 74 °C. For SOT1202 (XSON6) package: Ptot derates linearly with 3.3 mW/K above 74 °C. 10. Recommended operating conditions Table 6. Recommended operating conditions [1][2] Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A 1.65 3.6 V VCC(B) supply voltage B 2.3 5.5 V VI input voltage 0 5.5 V A 0 3.6 V B 0 5.5 V 0 VCCI V A 0 3.6 V B 0 5.5 V OE Power-down or 3-state mode Active mode A, B VO [3] Power-down or 3-state mode output voltage Active mode A, B Tamb ambient temperature Δt/ΔV input transition rise and fall rate [4] 0 VCCO V -40 +125 °C - 10 ns/V - 10 ns/V A or B port; push-pull driving VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V OE input VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V [1] [2] [3] [4] The A and B sides of an unused I/O pair must be held in the same state, both at VCCI or both at GND. VCC(A) must be less than or equal to VCC(B). VCCI is the supply voltage associated with the input. VCCO is the supply voltage associated with the output. NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 4 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 11. Static characteristics Table 7. Typical static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); Tamb = 25 °C.[1] Symbol Parameter Conditions Min Typ Max II input leakage current OE input; VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V IOZ OFF-state output A or B port; current VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V; OE = 0 V IOFF power-off leakage current - - ±1 μA - - ±1 μA A port; VCC(A) = 0 V; VCC(B) = 0 V to 5.5 V - - ±1 μA B port; VCC(B) = 0 V; VCC(A) = 0 V to 3.6 V - - ±1 μA - 1.6 - pF enabled - 10 - pF disabled - 4 - pF enabled - 10 - pF disabled - 7 - pF CI input capacitance OE input; VCC(A) = 3.3 V; VCC(B) = 3.3 V CI/O input/output capacitance Unit A port; VCC(A) = 3.3 V; VCC(B) = 3.3 V B port; VCC(A) = 3.3 V; VCC(B) = 3.3 V [1] VCC(A) must be less than or equal to VCC(B). Table 8. Typical supply current At recommended operating conditions; voltages are referenced to GND (ground = 0 V); Tamb = 25 °C. VCC(A) VCC(B) 2.5 V Unit 3.3 V 5.0 V ICC(A) ICC(B) ICC(A) ICC(B) ICC(A) ICC(B) 1.8 V 0.1 0.5 0.1 1.5 0.1 4.6 μA 2.5 V 0.1 0.1 0.1 0.8 0.1 3.8 μA 3.3 V - - 0.1 0.1 0.1 2.8 μA Table 9. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V).[1] Symbol Parameter VIH HIGH-level input voltage Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max VCC(A) = 1.65 V to 1.95 V; VCC(B) = 2.3 V to 5.5 V VCC(A) - 0.2 VCC(A) VCC(A) - 0.2 VCC(A) V VCC(A) = 2.3 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V VCC(A) - 0.4 VCC(A) VCC(A) - 0.4 VCC(A) V VCC(B) - 0.4 VCC(B) VCC(B) - 0.4 VCC(B) V 0.65VCC(A) VCC(A) 0.65VCC(A) VCC(A) V A port B port VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V OE input VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 5 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing Symbol Parameter VIL LOW-level input voltage Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max 0 0.15 0 0.15 0 0.35VCC(A) 0 0.67VCC(A) - 0.67VCC(A) - V 0.67VCC(B) - 0.67VCC(B) - V - 0.4 - 0.4 V A or B port VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V V OE input VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V VOH A port; IO = -20 μA; VI ≥ VCC(B) - 0.4 V HIGH-level output voltage VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V 0.35VCC(A) V B port; IO = -20 μA; VI ≥ VCC(A) - 0.2 V VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V A or B port; IO = 1 mA; VI ≤ 0.15 V LOW-level output voltage VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V VOL II input leakage current OE input; VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V - ±2 - ±12 μA IOZ OFF-state output current A or B port; VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V - ±2 - ±12 μA IOFF power-off leakage current A port; VCC(A) = 0 V; VCC(B) = 0 V to 5.5 V - ±2 - ±12 μA B port; VCC(B) = 0 V; VCC(A) = 0 V to 3.6 V - ±2 - ±12 μA VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V - 2.4 - 15 μA VCC(A) = 3.6 V; VCC(B) = 0 V - 2.2 - 15 μA VCC(A) = 0 V; VCC(B) = 5.5 V - -1 - -8 μA VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V - 12 - 30 μA VCC(A) = 3.6 V; VCC(B) = 0 V - -1 - -5 μA VCC(A) = 0 V; VCC(B) = 5.5 V - 1 - 6 μA - 14.4 - 30 μA supply current OE = 0 V or VCC(A); An, Bn open ICC ICC(A) ICC(B) ICC(A) + ICC(B) VCC(A) = 1.65 V to 3.6 V; VCC(B) = 2.3 V to 5.5 V [1] VCC(A) must be less than or equal to VCC(B). NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 6 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 12. Dynamic characteristics Table 10. Dynamic characteristics for temperature range -40 °C to +85 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7; for waveforms see Fig. 4 to Fig. 6. Symbol Parameter Conditions VCC(B) Unit 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max VCC(A) = 1.8 V ± 0.15 V tPHL HIGH to LOW A to B propagation delay - 4.6 - 4.7 - 5.8 ns tPLH LOW to HIGH A to B propagation delay - 7.1 - 6.8 - 7.0 ns tPHL HIGH to LOW B to A propagation delay - 4.4 - 4.5 - 4.7 ns tPLH LOW to HIGH B to A propagation delay - 5.3 - 4.5 - 0.5 ns ten enable time OE to A, B - 200 - 200 - 200 ns tdis disable time OE to A, B; no external load - 25 - 25 - 25 ns OE to A - 230 - 230 - 230 ns OE to B - 200 - 200 - 200 ns [1][2] LOW to HIGH output transition time A port 3.2 9.5 2.3 9.3 1.8 7.6 ns B port 3.3 10.8 2.7 9.1 2.7 7.6 ns HIGH to LOW output transition time A port 2.0 5.9 1.9 6.0 1.7 13.3 ns B port 2.9 7.6 2.8 7.9 2.8 10.5 ns tW pulse width data inputs 41 - 41 - 41 - ns fdata data rate - 24 - 24 - 24 Mbps tTLH tTHL VCC(A) = 2.5 V ± 0.2 V tPHL HIGH to LOW A to B propagation delay - 3.2 - 3.3 - 3.4 ns tPLH LOW to HIGH A to B propagation delay - 3.5 - 4.4 - 4.6 ns tPHL HIGH to LOW B to A propagation delay - 3.0 - 3.6 - 4.3 ns tPLH LOW to HIGH B to A propagation delay - 2.5 - 1.6 - 0.7 ns ten enable time OE to A, B - 200 - 200 - 200 ns tdis disable time OE to A, B; no external load - 20 - 20 - 20 ns OE to A - 200 - 200 - 200 ns OE to B - 200 - 200 - 200 ns [1][2] LOW to HIGH output transition time A port 2.8 7.5 2.6 6.6 1.8 6.5 ns B port 3.2 8.5 2.9 7.9 2.4 6.8 ns HIGH to LOW output transition time A port 1.9 5.7 1.9 5.5 1.8 5.3 ns B port 2.2 7.8 2.4 6.7 2.6 6.9 ns tW pulse width data inputs 41 - 41 - 41 - ns fdata data rate - 24 - 24 - 24 tTLH tTHL NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Mbps Nexperia B.V. 2020. All rights reserved 7 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing Symbol Parameter Conditions VCC(B) Unit 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max VCC(A) = 3.3 V ± 0.3 V tPHL HIGH to LOW A to B propagation delay - - - 2.4 - 3.1 ns tPLH LOW to HIGH A to B propagation delay - - - 4.2 - 4.4 ns tPHL HIGH to LOW B to A propagation delay - - - 2.5 - 3.3 ns tPLH LOW to HIGH B to A propagation delay - - - 2.5 - 2.6 ns ten enable time OE to A, B - - - 200 - 200 ns tdis disable time OE to A, B; no external load - - - 15 - 15 ns OE to A - - - 260 - 260 ns OE to B - - - 200 - 200 ns LOW to HIGH output transition time A port - - 2.3 6.2 1.9 6.3 ns B port - - 2.5 6.9 2.1 7.4 ns HIGH to LOW output transition time A port - - 2.0 5.4 1.9 5.0 ns B port - - 2.3 7.4 2.4 7.6 ns tW pulse width data inputs - - 41 - 41 - ns fdata data rate - - - 24 - 24 tTLH tTHL [1] [2] [1][2] Mbps tdis is the same as tPLZ and tPHZ. The disable time with no external load indicates the delay between when OE goes LOW and when outputs actually become disabled. NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 8 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing Table 11. Dynamic characteristics for temperature range -40 °C to +125 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7; for waveforms see Fig. 4 to Fig. 6. Symbol Parameter Conditions VCC(B) Unit 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max VCC(A) = 1.8 V ± 0.15 V tPHL HIGH to LOW A to B propagation delay - 5.8 - 5.9 - 7.3 ns tPLH LOW to HIGH A to B propagation delay - 8.5 - 8.5 - 8.8 ns tPHL HIGH to LOW B to A propagation delay - 5.5 - 5.7 - 5.9 ns tPLH LOW to HIGH B to A propagation delay - 6.7 - 5.7 - 0.7 ns ten enable time OE to A, B - 200 - 200 - 200 ns tdis disable time OE to A, B; no external load - 30 - 30 - 30 ns OE to A - 250 - 250 - 250 ns OE to B - 220 - 220 - 220 ns [1][2] LOW to HIGH output transition time A port 3.2 11.9 2.3 11.7 1.8 9.5 ns B port 3.3 13.5 2.7 11.4 2.7 9.5 ns HIGH to LOW output transition time A port 2.0 7.4 1.9 7.5 1.7 16.7 ns B port 2.9 9.5 2.8 9.4 2.8 12.5 ns tW pulse width data inputs 50 - 41 - 41 - ns fdata data rate - 20 - 24 - 24 Mbps tTLH tTHL VCC(A) = 2.5 V ± 0.2 V tPHL HIGH to LOW A to B propagation delay - 4.0 - 4.2 - 4.3 ns tPLH LOW to HIGH A to B propagation delay - 4.4 - 5.2 - 5.5 ns tPHL HIGH to LOW B to A propagation delay - 3.8 - 4.5 - 5.4 ns tPLH LOW to HIGH B to A propagation delay - 3.2 - 2.0 - 0.9 ns ten enable time OE to A, B - 200 - 200 - 200 ns tdis disable time OE to A, B; no external load - 25 - 25 - 25 ns OE to A - 220 - 220 - 220 ns OE to B - 220 - 220 - 220 ns [1][2] LOW to HIGH output transition time A port 2.8 9.3 2.6 8.3 1.8 7.8 ns B port 3.2 10.4 2.9 9.7 2.4 8.3 ns HIGH to LOW output transition time A port 1.9 7.2 1.9 6.9 1.8 6.7 ns B port 2.2 9.8 2.4 8.4 2.6 8.3 ns tW pulse width data inputs 50 - 41 - 41 - ns fdata data rate - 20 - 24 - 24 tTLH tTHL NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Mbps Nexperia B.V. 2020. All rights reserved 9 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing Symbol Parameter Conditions VCC(B) Unit 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max VCC(A) = 3.3 V ± 0.3 V tPHL HIGH to LOW A to B propagation delay - - - 3.0 - 3.9 ns tPLH LOW to HIGH A to B propagation delay - - - 5.3 - 5.5 ns tPHL HIGH to LOW B to A propagation delay - - - 3.2 - 4.2 ns tPLH LOW to HIGH B to A propagation delay - - - 3.2 - 3.3 ns ten enable time OE to A, B - - - 200 - 200 ns tdis disable time OE to A, B; no external load - - - 20 - 20 ns OE to A - - - 280 - 280 ns OE to B - - - 220 - 220 ns LOW to HIGH output transition time A port - - 2.3 7.0 1.9 7.4 ns B port - - 2.5 8.0 2.1 9.3 ns HIGH to LOW output transition time A port - - 2.0 6.8 1.9 6.3 ns B port - - 2.3 9.3 2.4 9.5 ns tW pulse width data inputs - - 41 - 41 - ns fdata data rate - - - 24 - 24 tTLH tTHL [1] [2] [1][2] Mbps tdis is the same as tPLZ and tPHZ. The disable time with no external load indicates the delay between when OE goes LOW and when outputs actually become disabled. 12.1. Waveforms and test circuit VI A, B input VM GND tPHL VOH B, A output tPLH 90 % VM VOL 10 % tTHL tTLH aaa-030601 Measurement points are given in Table 12. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 4. The data input (An, Bn) to data output (Bn, An) propagation delay times NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 10 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing VI VM OE input GND t PLZ VCCO output LOW-to-OFF VX VOL tPHZ VOH VY output HIGH-to-OFF GND outputs enabled outputs disabled aaa-029700 Measurement points are given in Table 12. VOL and VOH are typical output voltage levels that occur with the output load. VCCO is the supply voltage associated with the output. Fig. 5. Disable times VI OE input VM GND VI A, B input VM VM GND ten(1) VCCO B, A output VM VOL aaa-030602 (1) The enable time (ten) indicates the amount of time the user must allow for one one-shot circuitry to become operational after OE is taken HIGH. See also Section 13.6 Measurement points are given in Table 12. VOL is a typical output voltage level that occur with the output load. VCCO is the supply voltage associated with the output. Fig. 6. Enable times Table 12. Measurement points Supply voltage Input Output VCCO VM[1] VM[2] VX VY 1.8 V ± 0.15 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 2.5 V ± 0.2 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 3.3 V ± 0.3 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V 5.0 V ± 0.5 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V [1] [2] VCCI is the supply voltage associated with the input. VCCO is the supply voltage associated with the output. NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 11 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing tW VI 90 % negative pulse VM VM 10 % 0V tf tr tr VI tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC(A) VCC(B) G VI RL VO DUT CL RL aaa-029721 Test data is given in Table 13. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; ZO = 50 Ω; dV/dt ≥ 1.0 V/ns. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. VEXT = External voltage for measuring switching times. Fig. 7. Test circuit for measuring switching times Table 13. Test data Supply voltage Input VCC(A) VI[1] Δt/ΔV CL RL[2] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ[3] VCCI ≤ 1.0 ns/V 15 pF 50 kΩ, 1 MΩ open open 2VCCO VCC(B) 1.65 V to 3.6 V 2.3 V to 5.5 V [1] [2] [3] Load VEXT VCCI is the supply voltage associated with the input. For measuring data rate, pulse width, propagation delay and output rise and fall measurements, RL = 1 MΩ; for measuring enable and disable times, RL = 50 kΩ. VCCO is the supply voltage associated with the output. NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 12 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 13. Application information 13.1. Applications Voltage level-translation applications. The NXS0101 can be used in point-to-point applications to interface between devices or systems operating at different supply voltages. The device is primarily 2 targeted at I C or 1-wire which use open-drain drivers, it may also be used in applications where push-pull drivers are connected to the ports, however the NXB0101 may be more suitable. 1.8 V 3.3 V 0.1 µF 1.8 V VCC(A) SYSTEM CONTROLLER DATA VCC(B) 3.3 V 0.1 µF 1 µF OE NXS0101 A GND SYSTEM B DATA aaa-030603 Fig. 8. Typical operating circuit 13.2. Architecture The architecture of the NXS0101 is shown in Fig. 9. The device does not require an extra input signal to control the direction of data flow from A to B or B to A. VCC(A) VCC(B) OE T1 ONE SHOT ONE SHOT 10 kΩ T2 10 kΩ GATE BIAS T3 A B aaa-030598 Fig. 9. Architecture of NXS0101 I/O cell The NXS0101 is a "switch" type voltage translator, it employs two key circuits to enable voltage translation: 1. A pass-gate transistor (N-channel) that ties the ports together. 2. An output edge-rate accelerator that detects and accelerates rising edges on the I/O pins. The gate bias voltage of the pass gate transistor (T3) is set at approximately one threshold voltage above the VCC(A) level of the low-voltage side. During a rising edge, the one shots turn on the PMOS transistors (T1, T2) for a short duration, accelerating the low-to-high transition. The one-shot is activated once the input transition reaches approximately 0.5VCCI. During the acceleration time the driver output resistance is between approximately 50 Ω and 70 Ω. To avoid signal contention and minimize dynamic ICC, the user should wait for the one-shot circuit to turn-off before applying a signal in the opposite direction. Pull-up resistors are included in the device for DC current sourcing capability. NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 13 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 13.3. Input driver requirements As the NXS0101 is a switch type translator, properties of the input driver directly effect the output signal. The external open-drain or push-pull driver applied to an I/O determines the static current sinking capability of the system. The max data rate, HIGH-to-LOW output transition time (tTHL) and propagation delay (tPHL) are dependent upon the output impedance and edge-rate of the external driver. The limits provided for these parameters in the datasheet assume a driver with output impedance below 50 Ω is used. 13.4. Output load considerations The maximum lumped capacitive load that can be driven is dependant upon the one-shot pulse duration. In cases with very heavy capacitive loading there is a risk that the output will not reach the positive rail within the one-shot pulse duration.To avoid excessive capacitive loading and to ensure correct triggering of the one-shot it's recommended to use short trace lengths and low capacitance connectors on NXS0101 PCB layouts. To ensure low impedance termination and avoid output signal oscillations and one-shot re-triggering, the length of the PCB trace should be such that the round trip delay of any reflection is within the one-shot pulse duration. 13.5. Power up During operation VCC(A) must never be higher than VCC(B), however during power-up VCC(A) ≥ VCC(B) does not damage the device, so any power supply can be ramped up first. There is no special power-up sequencing required. The NXS0101 includes circuitry that disables all output ports when either VCC(A) or VCC(B) is switched off. 13.6. Enable and disable An output enable input (OE) is used to disable the device. Setting OE to LOW causes all I/Os to assume the high-impedance OFF-state. The disable time (tdis with no external load) indicates the delay between when OE goes LOW and when outputs actually become disabled. The enable time (ten) indicates the amount of time the user must allow for one one-shot circuitry to become operational after OE is taken HIGH. To ensure the high-impedance OFF-state during power-up or power-down, pin OE should be tied to GND through a pull-down resistor, the minimum value of the resistor is determined by the current-sourcing capability of the driver. 13.7. Pull-up or pull-down resistors on I/O lines Each A port I/O has an internal 10 kΩ pull-up resistor to VCC(A), and each B port I/O has an internal 10 kΩ pull-up resistor to VCC(B). If a smaller value of pull-up resistor is required, an external resistor must be added parallel to the internal 10 kΩ, this will effect the VOL level. When OE goes LOW the internal pull-ups of the NXS0101 are disabled. NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 14 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 14. Package outline SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig. 10. Package outline SOT886 (XSON6) NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 15 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig. 11. Package outline SOT1202 (XSON6) NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 16 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 15. Abbreviations Table 14. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 2 I C Inter-Integrated Circuit PCB Printed Circuit Board PRR Pulse Rate Repetition 16. Revision history Table 15. Revision history Document ID Release date Data sheet status Change notice Supersedes NXS0101 v.1.1 Product data sheet - - NXS0101 Product data sheet 20200406 All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 17 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing 17. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal NXS0101 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 18 / 19 NXS0101 Nexperia Dual supply translating transceiver; open drain; auto direction sensing Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Marking.......................................................................... 2 6. Functional diagram.......................................................2 7. Pinning information......................................................2 7.1. Pinning.........................................................................2 7.2. Pin description............................................................. 3 8. Functional description................................................. 3 9. Limiting values............................................................. 3 10. Recommended operating conditions........................4 11. Static characteristics..................................................5 12. Dynamic characteristics............................................ 7 12.1. Waveforms and test circuit...................................... 10 13. Application information........................................... 13 13.1. Applications..............................................................13 13.2. Architecture..............................................................13 13.3. Input driver requirements.........................................14 13.4. Output load considerations...................................... 14 13.5. Power up................................................................. 14 13.6. Enable and disable.................................................. 14 13.7. Pull-up or pull-down resistors on I/O lines............... 14 14. Package outline........................................................ 15 15. Abbreviations............................................................ 17 16. Revision history........................................................17 17. Legal information......................................................18 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 April 2020 NXS0101 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1.1 — 6 April 2020 © Nexperia B.V. 2020. All rights reserved 19 / 19
NXS0101GSH 价格&库存
很抱歉,暂时无法提供与“NXS0101GSH”相匹配的价格&库存,您可以联系我们找货
NXS0101GSH
  • 5000+1.448275000+0.18115
库存:108
NXS0101GSH
  • 1+3.451431+0.43170
  • 10+2.4170710+0.30232
  • 25+2.1511525+0.26906
  • 100+1.85783100+0.23238
  • 250+1.71850250+0.21495
  • 500+1.63456500+0.20445
  • 1000+1.565421000+0.19580
  • 2500+1.559562500+0.19507
库存:108
