Wire Wound Chip Common Mode Choke Coil – SDCW Series
Operating Temp. : -40℃~+85℃
FEATURES
Winding type realizes small size and low profile
Prevention of common mode noise at high frequency
30Ω~2200Ω are optional for different noise level and signal frequency
Excellent solderability
APPLICATIONS
USB2.0 of PC, peripheral equipments, small digital AV equipments, etc.
LVDS lines of Note PC, LCD
Audio lines
PRODUCT IDENTIFICATION
SDCW
2012
(L)
-2
①
②
③
④
Type
Winding Type Common
Mode Choke Coil
External Dimensions (L×W) (mm)
2012 [0805]
2.0×1.2
3216 [1206]
3.2×1.6
F
⑥
⑦
Code
L
Larger Current
⑦
Number of Lines
2
Hazardous Substance
Free Products
Packing
⑤
T
③
⑥
④
Example
900
⑤
②
①
SDCW
-900
T
Tape & Reel
F
Impedance
Nominal Value
90Ω
SHAPE AND DIMENSIONS
SDCW2012 Type
Recommended Land Pattern
Sunlord
Specifications subject to change without notice. Please check our website for latest information.
Unit: mm
Revised 2020/06/26
Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
SDCW3216 Type
Unit: mm
1.8±0.2
SPECIFICATIONS
SDCW2012(L) TYPE
Part Number
Units
Symbol
SDCW2012-2-300TF
SDCW2012-2-670TF
SDCW2012-2-750TF
SDCW2012-2-900TF
SDCW2012-2-121TF
SDCW2012-2-181TF
SDCW2012-2-201TF
SDCW2012-2-221TF
SDCW2012-2-261TF
SDCW2012-2-361TF
SDCW2012-2-371TF
SDCW2012-2-601TF
SDCW2012-2-751TF
SDCW2012-2-901TF
SDCW2012-2-102TF
SDCW2012L-2-900TF
SDCW2012L-2-121TF
SDCW2012L-2-201TF
Common Mode
Impedance @100MHz
Ω
Z
30±25%
67±25%
75±25%
90±25%
120±25%
180±25%
200±25%
220±25%
260±25%
360±25%
370±25%
600±25%
750±25%
900±25%
1000±25%
90±25%
120±25%
200±25%
Max. DC
Resistance
Ω
DCR
0.20
0.25
0.25
0.35
0.30
0.35
0.40
0.40
0.40
0.45
0.45
0.55
0.70
0.80
0.80
0.19
0.22
0.25
Max. Rated
Current
mA
Ir
450
400
400
330
370
330
300
300
300
280
280
200
180
150
150
400
370
350
Common Mode
Impedance @100MHz
Ω
Z
90±25%
160±25%
260±25%
600±25%
1000±25%
2200±25%
Max. DC
Resistance
Ω
DCR
0.30
0.40
0.50
0.80
1.00
1.20
Max. Rated
Current
mA
Ir
370
340
310
260
230
200
Rated Voltage
Volts
VDC
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
Min. Insulation
Resistance
MΩ
IR
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
SDCW3216 TYPE
Part Number
Units
Symbol
SDCW3216-2-900TF
SDCW3216-2-161TF
SDCW3216-2-261TF
SDCW3216-2-601TF
SDCW3216-2-102TF
SDCW3216-2-222TF
Rated Voltage
Volts
VDC
50
50
50
50
50
50
Min. Insulation
Resistance
MΩ
IR
10
10
10
10
10
10
※: Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales.
Sunlord
Revised 2020/06/26
EQUIVALENT CIRCUIT
TYPICAL ELECTRICAL CHARACTERISTICS
Impedance vs. Frequency
SDCW2012 TYPE
(30~260Ω)
SDCW2012 TYPE
(360~1000Ω)
SDCW3216 TYPE
(90~2200Ω)
Sunlord
Revised 2020/06/26
很抱歉,暂时无法提供与“SDCW3216-2-161TF”相匹配的价格&库存,您可以联系我们找货
