ALC5672-VB-CGT
ALC5672-VB-CGT
    REALTEK(瑞昱)
    QFN-48
    高性能、低功耗的双I2S接口音频编解码器,带有嵌入式低功耗/高性能语音DSP。支持多种数字信号处理功能,包括动态范围控制(DRC)、14段参数均衡器等。
ALC5672-VB-CGT 数据手册
ALC5672-VB Multi-Channel Audio Hub/CODEC with Gen.3 Voice DSP and SounzRealTM Post-Processing for Mobile Devices DATASHEET Rev. 0.91 21 January 2014 Realtek Semiconductor Corp. No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan Tel.: +886-3-578-0211. Fax: +886-3-577-6047 www.realtek.com ALC5672-VB Datasheet COPYRIGHT ©2014 Realtek Semiconductor Corp. All rights reserved. No part of this document may be reproduced, transmitted, transcribed, stored in a retrieval system, or translated into any language in any form or by any means without the written permission of Realtek Semiconductor Corp. DISCLAIMER Realtek provides this document “as is”, without warranty of any kind. Realtek may make improvements and/or changes in this document or in the product described in this document at any time. This document could include technical inaccuracies or typographical errors. TRADEMARKS Realtek is a trademark of Realtek Semiconductor Corporation. Other names mentioned in this document are trademarks/registered trademarks of their respective owners. USING THIS DOCUMENT This document is intended for the hardware and software engineer’s general information on the Realtek ALC5672 Audio Codec IC. Though every effort has been made to ensure that this document is current and accurate, more information may have become available subsequent to the production of this guide. ii Rev. 0.91 ALC5672-VB Datasheet REVISION HISTORY Revision 0.9 0.91 Release Date 2014/1/13 2014/1/21 Summary First release for ALC5672-VB Modify TDM function iii Rev. 0.91 ALC5672-VB Datasheet Table of Contents 1. GENERAL DESCRIPTION .............................................................................................................................................. 1 2. FEATURES ......................................................................................................................................................................... 2 3. POWER/GROUND OPERATION CONDITIONS ......................................................................................................... 4 4. SYSTEM APPLICATION ................................................................................................................................................. 4 5. FUNCTION BLOCK AND MIXER PATH ..................................................................................................................... 5 5.1. 5.2. 5.3. FUNCTION BLOCK ........................................................................................................................................................ 5 AUDIO MIXER PATH..................................................................................................................................................... 6 DIGITAL MIXER PATH .................................................................................................................................................. 7 6. PIN ASSIGNMENTS ......................................................................................................................................................... 8 7. PIN DESCRIPTIONS......................................................................................................................................................... 9 7.1. 7.2. 7.3. 7.4. 8. FUNCTION DESCRIPTION .......................................................................................................................................... 12 8.1. 9. DIGITAL I/O PINS ......................................................................................................................................................... 9 ANALOG I/O PINS ...................................................................................................................................................... 10 FILTER/REFERENCE.................................................................................................................................................... 11 POWER/GROUND ........................................................................................................................................................ 11 SYSTEM CONNECTION ................................................................................................................................................ 12 POWER ............................................................................................................................................................................. 13 9.1. POWER SUPPLY ON/OFF SEQUENCE ........................................................................................................................... 14 9.2. RESET ........................................................................................................................................................................ 16 9.2.1. Power-On Reset (POR) ........................................................................................................................................ 16 9.2.2. Software Reset ...................................................................................................................................................... 16 9.3. CLOCKING .................................................................................................................................................................. 17 9.3.1. Phase-Locked Loop .............................................................................................................................................. 18 9.3.2. I2C and Two I2S/PCM Interface ........................................................................................................................... 19 9.4. DIGITAL DATA INTERFACE ........................................................................................................................................ 22 9.4.1. Two I2S/PCM Interface ......................................................................................................................................... 22 9.5. AUDIO DATA PATH .................................................................................................................................................... 27 9.5.1. 2 Analog ADCs with 6-Channel Record Path ...................................................................................................... 27 9.5.2. 4 DACs with 4-Channel Playback Path................................................................................................................ 28 9.5.3. Mixers ................................................................................................................................................................... 29 9.6. ANALOG AUDIO INPUT PORT ..................................................................................................................................... 30 9.7. ANALOG AUDIO OUTPUT PORT .................................................................................................................................. 31 9.8. MULTI-FUNCTION PINS .............................................................................................................................................. 32 9.9. DRC AND AGC FUNCTION ........................................................................................................................................ 35 9.10. SOUNZREALTM POST-PROCESSING ............................................................................................................................. 41 9.11. EQUALIZER BLOCK .................................................................................................................................................... 41 9.12. WIND NOISE REDUCTION FILTER ............................................................................................................................... 41 9.13. I2C CONTROL INTERFACE .......................................................................................................................................... 44 9.13.1. Address Setting ................................................................................................................................................ 44 9.13.2. Complete Data Transfer .................................................................................................................................. 44 9.14. GPIO, INTERRUPT AND JACK DETECTION .................................................................................................................. 46 9.15. PUSH BUTTON DETECTION ......................................................................................................................................... 49 iv Rev. 0.91 ALC5672-VB Datasheet 9.16. 9.17. 9.18. 10. POWER MANAGEMENT............................................................................................................................................... 51 GEN.3 VOICE DSP FUNCTION .................................................................................................................................... 52 MULTI-JACK JACK DETECTION PIN (JD1) .................................................................................................................. 54 REGISTERS LIST....................................................................................................................................................... 55 10.1. 10.2. 10.3. 10.4. 10.5. 10.6. 10.7. 10.8. 10.9. 10.10. 10.11. 10.12. 10.13. 10.14. 10.15. 10.16. 10.17. 10.18. 10.19. 10.20. 10.21. 10.22. 10.23. 10.24. 10.25. 10.26. 10.27. 10.28. 10.29. 10.30. 10.31. 10.32. 10.33. 10.34. 10.35. 10.36. 10.37. 10.38. 10.39. 10.40. 10.41. 10.42. 10.43. 10.44. 10.45. 10.46. 10.47. 10.48. 10.49. 10.50. REGISTER MAP .......................................................................................................................................................... 55 MX-00H: S/W RESET & DEVICE ID ........................................................................................................................... 59 MX-02H: HEADPHONE OUTPUT CONTROL................................................................................................................. 59 MX-03H: LINE OUTPUT CONTROL ........................................................................................................................... 60 MX-0AH: IN1 PORT CONTROL - 1 ............................................................................................................................. 62 MX-0BH: IN1 PORT CONTROL - 2 ............................................................................................................................. 62 MX-0CH: IN1 PORT CONTROL - 3 ............................................................................................................................. 63 MX-0EH: IN2 INPUT CONTROL ................................................................................................................................. 63 MX-0FH: INL & INR VOLUME CONTROL ................................................................................................................. 64 MX-19H: DACL1/R1 DIGITAL VOLUME .............................................................................................................. 65 MX-1AH: DACL2/R2 DIGITAL VOLUME ............................................................................................................. 65 MX-1BH: DACL2/R2 MUTE/UN-MUTE CONTROL............................................................................................... 67 MX-1CH: STEREO1 ADC DIGITAL VOLUME CONTROL ........................................................................................ 68 MX-1DH: MONO ADC DIGITAL VOLUME CONTROL ............................................................................................ 69 MX-1EH: ADC DIGITAL BOOST GAIN CONTROL.................................................................................................. 70 MX-1FH: STEREO2 ADC DIGITAL VOLUME CONTROL......................................................................................... 71 MX-20H: MONO ADC DIGITAL BOOST GAIN CONTROL ....................................................................................... 72 MX-26H: STEREO2 ADC DIGITAL MIXER CONTROL ............................................................................................ 72 MX-27H: STEREO1 ADC DIGITAL MIXER CONTROL ............................................................................................ 73 MX-28H: MONO ADC DIGITAL MIXER CONTROL ................................................................................................ 74 MX-29H: STEREO ADC TO DAC DIGITAL MIXER CONTROL ................................................................................ 75 MX-2AH: STEREO DAC DIGITAL MIXER CONTROL ............................................................................................. 75 MX-2BH: MONO DAC DIGITAL MIXER CONTROL ............................................................................................... 76 MX-2CH: DAC DIGITAL MIXER CONTROL........................................................................................................... 77 MX-2DH: VOICE DSP PATH CONTROL 1 .............................................................................................................. 78 MX-2EH: VOICE DSP VOLUME CONTROL ............................................................................................................ 79 MX-2FH: INTERFACE DAC/ADC DATA CONTROL ............................................................................................... 80 MX-31H: SPEAKER CONTROL 1 ............................................................................................................................ 80 MX-3BH: RECMIXL CONTROL 1 ........................................................................................................................ 81 MX-3CH: RECMIXL CONTROL 2 ........................................................................................................................ 81 MX-3DH: RECMIXR CONTROL 1 ........................................................................................................................ 82 MX-3EH: RECMIXR CONTROL 2 ........................................................................................................................ 82 MX-45H: HPOMIX CONTROL .............................................................................................................................. 83 MX-4FH: OUTMIXL CONTROL ........................................................................................................................... 83 MX-52H: OUTMIXR CONTROL ........................................................................................................................... 84 MX-53H: LOUTMIX CONTROL ........................................................................................................................... 84 MX-61H: POWER MANAGEMENT CONTROL 1 ....................................................................................................... 85 MX-62H: POWER MANAGEMENT CONTROL 2 ....................................................................................................... 86 MX-63H: POWER MANAGEMENT CONTROL 3 ....................................................................................................... 86 MX-64H: POWER MANAGEMENT CONTROL 4 ....................................................................................................... 87 MX-65H: POWER MANAGEMENT CONTROL 5 ....................................................................................................... 88 MX-66H: POWER MANAGEMENT CONTROL 6 ....................................................................................................... 89 MX-6AH: PRIVATE REGISTER INDEX .................................................................................................................... 89 MX-6CH: PRIVATE REGISTER DATA ..................................................................................................................... 89 MX-70H: I2S1 DIGITAL INTERFACE CONTROL ..................................................................................................... 90 MX-71H: I2S2 DIGITAL INTERFACE CONTROL ..................................................................................................... 90 MX-73H: ADC/DAC CLOCK CONTROL................................................................................................................ 91 MX-74H: ADC/DAC HPF CONTROL .................................................................................................................... 92 MX-75H: DIGITAL MICROPHONE CONTROL 1 ....................................................................................................... 93 MX-76H: DIGITAL MICROPHONE CONTROL 2 ....................................................................................................... 94 v Rev. 0.91 ALC5672-VB Datasheet 10.51. 10.52. 10.53. 10.54. 10.55. 10.56. 10.57. 10.58. 10.59. 10.60. 10.61. 10.62. 10.63. 10.64. 10.65. 10.66. 10.67. 10.68. 10.69. 10.70. 10.71. 10.72. 10.73. 10.74. 10.75. 10.76. 10.77. 10.78. 10.79. 10.80. 10.81. 10.82. 10.83. 10.84. 10.85. 10.86. 10.87. 10.88. 10.89. 10.90. 10.91. 10.92. 10.93. 10.94. 10.95. 10.96. 10.97. 10.98. 10.99. 10.100. 10.101. 10.102. 10.103. 10.104. 10.105. MX-77H: TDM INTERFACE CONTROL 1 ............................................................................................................... 95 MX-78H: TDM INTERFACE CONTROL 2 ............................................................................................................... 96 MX-79H: TDM INTERFACE CONTROL 3 ............................................................................................................... 97 MX-7FH: CLOCK CONTROL 1 ............................................................................................................................... 98 MX-80H: GLOBAL CLOCK CONTROL .................................................................................................................... 98 MX-81H: PLL CONTROL 1 .................................................................................................................................... 99 MX-82H: PLL CONTROL 2 .................................................................................................................................... 99 MX-83H: ASRC CONTROL 1 .............................................................................................................................. 100 MX-84H: ASRC CONTROL 2 .............................................................................................................................. 101 MX-85H: ASRC CONTROL 3 .............................................................................................................................. 102 MX-8AH: ASRC CONTROL 4 .............................................................................................................................. 103 MX-8CH: ASRC CONTROL 5 .............................................................................................................................. 103 MX-8EH: HP AMP CONTROL 1 ........................................................................................................................... 104 MX-8FH: HP AMP CONTROL 2 ........................................................................................................................... 104 MX-93H: MICBIAS CONTROL ........................................................................................................................... 105 MX-94H: JD1 CONTROL ..................................................................................................................................... 105 MX-AEH: ADC PATH EQ CONTROL 1................................................................................................................ 106 MX-AFH: ADC PATH EQ CONTROL 2 ................................................................................................................ 107 MX-B0H: DAC PATH EQ CONTROL 1 ................................................................................................................ 108 MX-B1H: EQ CONTROL 2 ................................................................................................................................... 109 MX-B2H: DRC CONTROL 1 ................................................................................................................................ 110 MX-B3H: DRC CONTROL 2 ................................................................................................................................ 110 MX-B4H: DRC CONTROL 3 ................................................................................................................................ 111 MX-B5H: DRC CONTROL 4 ................................................................................................................................ 112 MX-B6H: DRC CONTROL 5 ................................................................................................................................ 113 MX-B7H: DRC CONTROL 6 ................................................................................................................................ 114 MX-BBH: JACK DETECTION CONTROL 1 ............................................................................................................ 114 MX-BDH: IRQ CONTROL 1 ................................................................................................................................ 115 MX-BEH: IRQ CONTROL 2 ................................................................................................................................. 116 MX-BFH: IRQ CONTROL 3 ................................................................................................................................. 117 MX-C0H: GPIO CONTROL 1 ............................................................................................................................... 117 MX-C1H: GPIO CONTROL 2 ............................................................................................................................... 118 MX-C2H: GPIO CONTROL 3 ............................................................................................................................... 119 MX-CFH: SOUNZREALTM BASSBACK CONTROL ................................................................................................ 120 MX-D0H: SOUNZREALTM TRUTREBLE CONTROL 1 ............................................................................................ 120 MX-D1H: SOUNZREALTM TRUTREBLE CONTROL 2 ............................................................................................ 121 MX-D3H: STEREO1 ADC WIND FILTER CONTROL 1 .......................................................................................... 121 MX-D4H: STEREO1 ADC WIND FILTER CONTROL 2 .......................................................................................... 122 MX-D9H: SOFT VOLUME & ZCD CONTROL 1 .................................................................................................... 123 MX-DAH: SOFT VOLUME & ZCD CONTROL 2 ................................................................................................... 124 MX-DBH: INLINE COMMAND CONTROL 1 .......................................................................................................... 124 MX-DCH: INLINE COMMAND CONTROL 2 .......................................................................................................... 125 MX-DDH: INLINE COMMAND CONTROL 3 .......................................................................................................... 126 MX-E0H: VOICE DSP CONTROL 1 ...................................................................................................................... 126 MX-E1H: VOICE DSP CONTROL 2 ...................................................................................................................... 127 MX-E2H: VOICE DSP CONTROL 3 ...................................................................................................................... 127 MX-E3H: VOICE DSP CONTROL 4 ...................................................................................................................... 127 MX-E4H: VOICE DSP CONTROL 5 ...................................................................................................................... 128 MX-E5H: VOICE DSP CONTROL 6 ...................................................................................................................... 128 MX-ECH: MONO ADC WIND FILTER CONTROL 1 .............................................................................................. 128 MX-EDH: MONO ADC WIND FILTER CONTROL 2 .............................................................................................. 129 MX-EEH: STEREO2 ADC WIND FILTER CONTROL 1 .......................................................................................... 129 MX-EFH: STEREO2 ADC WIND FILTER CONTROL 2 .......................................................................................... 131 MX-F8H: JACK DETECTION CONTROL ................................................................................................................ 131 MX-F9H: JACK DETECTION CONTROL ................................................................................................................ 132 vi Rev. 0.91 ALC5672-VB Datasheet 10.106. 10.107. 10.108. 10.109. 10.110. 10.111. 10.112. 10.113. 10.114. 10.115. 10.116. 10.117. 10.118. 10.119. 10.120. 10.121. 10.122. 10.123. 10.124. 10.125. 10.126. 10.127. 10.128. 10.129. 10.130. 10.131. 10.132. 10.133. 10.134. 10.135. 10.136. 10.137. 10.138. 10.139. 10.140. 10.141. 10.142. 10.143. 10.144. 10.145. 10.146. 10.147. 10.148. 10.149. 10.150. 10.151. 10.152. 10.153. 10.154. 10.155. 10.156. 10.157. 10.158. 10.159. 10.160. MX-FAH: GENERAL CONTROL 1 ........................................................................................................................ 132 MX-FBH: GENERAL CONTROL 2......................................................................................................................... 133 MX-FCH: GENERAL CONTROL 3......................................................................................................................... 134 PR-3DH: ADC/DAC RESET CONTROL ............................................................................................................. 134 PR-A4H: DAC_L EQ (LPF:A1) .......................................................................................................................... 135 PR-A5H: DAC_L EQ (LPF:H0).......................................................................................................................... 135 PR-A6H: DAC_R EQ (LPF:A1) .......................................................................................................................... 135 PR-A7H: DAC_R EQ (LPF:H0) ......................................................................................................................... 135 PR-AEH: DAC_L EQ (BPF2:A1) ....................................................................................................................... 136 PR-AFH: DAC_L EQ (BPF2:A2) ........................................................................................................................ 136 PR-B0H: DAC_L EQ (BPF2:H0) ....................................................................................................................... 136 PR-B1H: DAC_R EQ (BPF2:A1) ........................................................................................................................ 136 PR-B2H: DAC_R EQ (BPF2:A2) ........................................................................................................................ 137 PR-B3H: DAC_R EQ (BPF2:H0) ....................................................................................................................... 137 PR-B4H: DAC_L EQ (BPF3:A1) ........................................................................................................................ 137 PR-B5H: DAC_L EQ (BPF3:A2) ........................................................................................................................ 137 PR-B6H: DAC_L EQ (BPF3:H0) ....................................................................................................................... 138 PR-B7H: DAC_R EQ (BPF3:A1) ........................................................................................................................ 138 PR-B8H: DAC_R EQ (BPF3:A2) ........................................................................................................................ 138 PR-B9H: DAC_R EQ (BPF3:H0) ....................................................................................................................... 138 PR-BAH: DAC_L EQ (BPF4:A1) ....................................................................................................................... 139 PR-BBH: DAC_L EQ (BPF4:A2) ....................................................................................................................... 139 PR-BCH: DAC_L EQ (BPF4:H0) ....................................................................................................................... 139 PR-BDH: DAC_R EQ (BPF4:A1) ....................................................................................................................... 139 PR-BEH: DAC_R EQ (BPF4:A2) ....................................................................................................................... 140 PR-BFH: DAC_R EQ (BPF4:H0) ....................................................................................................................... 140 PR-C0H: DAC_L EQ (HPF1:A1) ........................................................................................................................ 140 PR-C1H: DAC_L EQ (HPF1:H0) ....................................................................................................................... 140 PR-C2H: DAC_R EQ (HPF1:A1) ........................................................................................................................ 141 PR-C3H: DAC_R EQ (HPF1:H0) ....................................................................................................................... 141 PR-C4H: DAC_L EQ (HPF2:A1) ........................................................................................................................ 141 PR-C5H: DAC_L EQ (HPF2:A2) ........................................................................................................................ 141 PR-C6H: DAC_L EQ (HPF2:H0) ....................................................................................................................... 142 PR-C7H: DAC_R EQ (HPF2:A1) ........................................................................................................................ 142 PR-C8H: DAC_R EQ (HPF2:A2) ........................................................................................................................ 142 PR-C9H: DAC_R EQ (HPF2:H0) ....................................................................................................................... 142 PR-CAH: DAC_L EQ PRE-VOLUME CONTROL .................................................................................................. 143 PR-CBH: DAC_R EQ PRE-VOLUME CONTROL .................................................................................................. 143 PR-CCH: DAC_L EQ POST-VOLUME CONTROL ................................................................................................ 143 PR-CDH: DAC_R EQ POST-VOLUME CONTROL ................................................................................................ 144 PR-CEH: ADC EQ (LPF:A1) .............................................................................................................................. 144 PR-CFH: ADC EQ (LPF:H0) .............................................................................................................................. 144 PR-D0H: ADC EQ (BPF1:A1) ............................................................................................................................ 144 PR-D1H: ADC EQ (BPF1:A2) ............................................................................................................................ 145 PR-D2H: ADC EQ (BPF1:H0) ............................................................................................................................ 145 PR-D3H: ADC EQ (BPF2:A1) ............................................................................................................................ 145 PR-D4H: ADC EQ (BPF2:A2) ............................................................................................................................ 145 PR-D5H: ADC EQ (BPF2:H0) ............................................................................................................................ 146 PR-D6H: ADC EQ (BPF3:A1) ............................................................................................................................ 146 PR-D7H: ADC EQ (BPF3:A2) ............................................................................................................................ 146 PR-D8H: ADC EQ (BPF3:H0) ............................................................................................................................ 146 PR-D9H: ADC EQ (BPF4:A1) ............................................................................................................................ 147 PR-DAH: ADC EQ (BPF4:A2) ........................................................................................................................... 147 PR-DBH: ADC EQ (BPF4:H0) ........................................................................................................................... 147 PR-DCH: ADC EQ (HPF1:A1) ........................................................................................................................... 147 vii Rev. 0.91 ALC5672-VB Datasheet 10.161. 10.162. 10.163. 10.164. 10.165. 10.166. 10.167. 10.168. 10.169. 10.170. 10.171. 10.172. 10.173. 10.174. 10.175. 10.176. 10.177. 10.178. 10.179. 10.180. 10.181. 10.182. 10.183. 10.184. 11. PR-DDH: ADC EQ (HPF1:H0)........................................................................................................................... 148 PR-E1H: ADC EQ PRE-VOLUME CONTROL ........................................................................................................ 148 PR-E2H: ADC EQ POST-VOLUME CONTROL ...................................................................................................... 148 PR-E5H: DAC_L BIQUAD EQ (BPF1:H0-1) ....................................................................................................... 148 PR-E6H: DAC_L BIQUAD EQ (BPF1:H0-2) ....................................................................................................... 149 PR-E7H: DAC_L BIQUAD EQ (BPF1:B1-1)........................................................................................................ 149 PR-E8H: DAC_L BIQUAD EQ (BPF1:B1-2)........................................................................................................ 149 PR-E9H: DAC_L BIQUAD EQ (BPF1:B2-1)........................................................................................................ 149 PR-EAH: DAC_L BIQUAD EQ (BPF1:B2-2)....................................................................................................... 150 PR-EBH: DAC_L BIQUAD EQ (BPF1:A1-1) ....................................................................................................... 150 PR-ECH: DAC_L BIQUAD EQ (BPF1:A1-2) ....................................................................................................... 150 PR-EDH: DAC_L BIQUAD EQ (BPF1:A2-1) ...................................................................................................... 150 PR-EEH: DAC_L BIQUAD EQ (BPF1:A2-2) ....................................................................................................... 151 PR-EFH: DAC_R BIQUAD EQ (BPF1:H0-1) ....................................................................................................... 151 PR-F0H: DAC_R BIQUAD EQ (BPF1:H0-2) ....................................................................................................... 151 PR-F1H: DAC_R BIQUAD EQ (BPF1:B1-1)........................................................................................................ 151 PR-F2H: DAC_R BIQUAD EQ (BPF1:B1-2)........................................................................................................ 152 PR-F3H: DAC_R BIQUAD EQ (BPF1:B2-1)........................................................................................................ 152 PR-F4H: DAC_R BIQUAD EQ (BPF1:B2-2)........................................................................................................ 152 PR-F5H: DAC_R BIQUAD EQ (BPF1:A1-1) ....................................................................................................... 152 PR-F6H: DAC_R BIQUAD EQ (BPF1:A1-2) ....................................................................................................... 153 PR-F7H: DAC_R BIQUAD EQ (BPF1:A2-1) ....................................................................................................... 153 PR-F8H: DAC_R BIQUAD EQ (BPF1:A2-2) ....................................................................................................... 153 MX-FEH: VENDOR ID ........................................................................................................................................ 153 ELECTRICAL CHARACTERISTICS.................................................................................................................... 154 11.1. DC CHARACTERISTICS ............................................................................................................................................. 154 11.1.1. Absolute Maximum Ratings ........................................................................................................................... 154 11.1.2. Recommended Operating Conditions ............................................................................................................ 154 11.1.3. Static Characteristics..................................................................................................................................... 154 11.2. ANALOG PERFORMANCE CHARACTERISTICS ............................................................................................................ 155 11.3. SIGNAL TIMING ........................................................................................................................................................ 157 11.3.1. I2C Control Interface ..................................................................................................................................... 157 11.3.2. I2S/PCM Interface Master Mode ................................................................................................................... 158 11.3.3. I2S/PCM Interface Slave Mode ...................................................................................................................... 159 11.3.4. Digital Microphone Interface ........................................................................................................................ 160 12. APPLICATION CIRCUITS ..................................................................................................................................... 161 13. PACKAGE INFORMATION ................................................................................................................................... 163 13.1. 13.2. 14. MECHANICAL DIMENSIONS ...................................................................................................................................... 163 PACKAGE THERMAL INFORMATION ......................................................................................................................... 164 ORDERING INFORMATION ................................................................................................................................. 165 viii Rev. 0.91 ALC5672-VB Datasheet List of Tables TABLE 1. TABLE 2. TABLE 3. TABLE 4. TABLE 5. TABLE 6. TABLE 7. TABLE 8. TABLE 9. TABLE 10. TABLE 11. TABLE 12. TABLE 13. TABLE 14. TABLE 15. TABLE 16. TABLE 17. TABLE 18. TABLE 19. TABLE 20. TABLE 21. TABLE 22. TABLE 23. TABLE 24. TABLE 25. TABLE 26. TABLE 27. TABLE 28. TABLE 29. TABLE 30. TABLE 31. TABLE 32. TABLE 33. TABLE 34. TABLE 35. TABLE 36. TABLE 37. TABLE 38. TABLE 39. TABLE 40. TABLE 41. TABLE 42. TABLE 43. TABLE 44. TABLE 45. TABLE 46. TABLE 47. TABLE 48. TABLE 49. TABLE 50. TABLE 51. TABLE 52. DIGITAL I/O PINS .......................................................................................................................................................... 9 ANALOG I/O PINS ........................................................................................................................................................ 10 FILTER/REFERENCE ..................................................................................................................................................... 11 POWER/GROUND ......................................................................................................................................................... 11 POWER SUPPLY FOR BEST PERFORMANCE................................................................................................................... 13 POWER SUPPLY CONDITION FOR POWER DOWN LEAKAGE.......................................................................................... 13 RESET OPERATION ...................................................................................................................................................... 16 POWER-ON RESET VOLTAGE....................................................................................................................................... 16 CLOCK SETTING TABLE FOR 48K (UNIT: MHZ) .......................................................................................................... 18 CLOCK SETTING TABLE FOR 44.1K (UNIT: MHZ) ..................................................................................................... 18 THE RELATIVE OF SYSCLK/BCLK/LRCK ............................................................................................................... 19 REGISTER SETTINGS FOR ASRC FUNCTION ON SLAVE MODE ................................................................................... 21 SAMPLE RATE WITH FILTER COEFFICIENT FOR WIND FILTER..................................................................................... 42 ADDRESS SETTING (0X38H) ...................................................................................................................................... 44 WRITE WORD PROTOCOL ........................................................................................................................................ 45 READ WORD PROTOCOL .......................................................................................................................................... 45 REGISTER MAP .......................................................................................................................................................... 55 MX-00H: S/W RESET ................................................................................................................................................ 59 MX-02H: HEADPHONE OUTPUT CONTROL ................................................................................................................ 59 MX-03H: LINE OUTPUT CONTROL ........................................................................................................................... 60 MX-0DH: IN1 INPUT CONTROL - 1 ........................................................................................................................... 62 MX-0BH: IN1 INPUT CONTROL - 2 ............................................................................................................................ 62 MX-0CH: IN1 INPUT CONTROL - 3 ............................................................................................................................ 63 MX-0EH: IN2 INPUT CONTROL ................................................................................................................................. 63 MX-0FH: INL & INR VOLUME CONTROL................................................................................................................. 64 MX-19H: DACL1/R1 DIGITAL VOLUME .................................................................................................................. 65 MX-1AH: DACL2/R2 DIGITAL VOLUME.................................................................................................................. 65 MX-1BH: DACL2/R2 MUTE/UN-MUTE CONTROL ................................................................................................... 67 MX-1CH: STEREO1 ADC DIGITAL VOLUME CONTROL ............................................................................................ 68 MX-1DH: MONO ADC DIGITAL VOLUME CONTROL ................................................................................................ 69 MX-1EH: ADC DIGITAL BOOST GAIN CONTROL ...................................................................................................... 70 MX-1FH: STEREO2 ADC DIGITAL VOLUME CONTROL ............................................................................................. 71 MX-20H: MONO ADC DIGITAL BOOST GAIN CONTROL ........................................................................................... 72 MX-26H: STEREO2 ADC DIGITAL MIXER CONTROL ................................................................................................ 72 MX-27H: STEREO1 ADC DIGITAL MIXER CONTROL ................................................................................................ 73 MX-28H: MONO ADC DIGITAL MIXER CONTROL .................................................................................................... 74 MX-29H: STEREO ADC TO DAC DIGITAL MIXER CONTROL .................................................................................... 75 MX-2AH: STEREO DAC DIGITAL MIXER CONTROL ................................................................................................. 75 MX-2BH: MONO DAC DIGITAL MIXER CONTROL.................................................................................................... 76 MX-2CH: DAC DIGITAL MIXER CONTROL ............................................................................................................... 77 MX-2DH: VOICE DSP PATH CONTROL 1 .................................................................................................................. 78 MX-2EH: VOICE DSP VOLUME CONTROL ................................................................................................................ 79 MX-2FH: INTERFACE DAC/ADC DATA CONTROL ................................................................................................... 80 MX-31H: SPEAKER CONTROL 1 ................................................................................................................................ 80 MX-3BH: RECMIXL CONTROL 1 ............................................................................................................................ 81 MX-3CH: RECMIXL CONTROL 2 ............................................................................................................................ 81 MX-3DH: RECMIXR CONTROL 1 ............................................................................................................................ 82 MX-3EH: RECMIXR CONTROL 2 ............................................................................................................................ 82 MX-45H: HPOMIX CONTROL .................................................................................................................................. 83 MX-4FH: OUTMIXL CONTROL ............................................................................................................................... 83 MX-52H: OUTMIXR CONTROL 3 ............................................................................................................................ 84 MX-53H: LOUTMIX CONTROL ............................................................................................................................... 84 ix Rev. 0.91 ALC5672-VB Datasheet TABLE 53. MX-61H: POWER MANAGEMENT CONTROL 1 ........................................................................................................... 85 TABLE 54. MX-62H: POWER MANAGEMENT CONTROL 2 ........................................................................................................... 86 TABLE 55. MX-63H: POWER MANAGEMENT CONTROL 3 ........................................................................................................... 86 TABLE 56. MX-64H: POWER MANAGEMENT CONTROL 4 ........................................................................................................... 87 TABLE 57. MX-65H: POWER MANAGEMENT CONTROL 5 ........................................................................................................... 88 TABLE 58. MX-66H: POWER MANAGEMENT CONTROL 6 ........................................................................................................... 89 TABLE 59. MX-6AH: PRIVATE REGISTER INDEX ........................................................................................................................ 89 TABLE 60. MX-6CH: PRIVATE REGISTER DATA ......................................................................................................................... 89 TABLE61. MX-70H: I2S1 DIGITAL INTERFACE CONTROL .......................................................................................................... 90 TABLE 61. MX-71H: I2S2 DIGITAL INTERFACE CONTROL.......................................................................................................... 90 TABLE 62. MX-73H: ADC/DAC CLOCK CONTROL .................................................................................................................... 91 TABLE 63. MX-74H: ADC/DAC HPF CONTROL ........................................................................................................................ 92 TABLE 64. MX-75H: DIGITAL MICROPHONE CONTROL 1 ........................................................................................................... 93 TABLE 65. MX-76H: DIGITAL MICROPHONE CONTROL 2 ........................................................................................................... 94 TABLE 66. MX-77H: TDM INTERFACE CONTROL 1 .................................................................................................................... 95 TABLE 67. MX-78H: TDM INTERFACE CONTROL 2 .................................................................................................................... 96 TABLE 68. MX-79H: TDM INTERFACE CONTROL 3 .................................................................................................................... 97 TABLE 69. MX-7FH: CLOCK CONTROL 1.................................................................................................................................... 98 TABLE 70. MX-80H: GLOBAL CLOCK CONTROL ........................................................................................................................ 98 TABLE 71. MX-81H: PLL CONTROL 1 ........................................................................................................................................ 99 TABLE 72. MX-82H: PLL CONTROL 2 ........................................................................................................................................ 99 TABLE 73. MX-83H: ASRC CONTROL 1 ................................................................................................................................... 100 TABLE 74. MX-84H: ASRC CONTROL 2 ................................................................................................................................... 101 TABLE 75. MX-85H: ASRC CONTROL 3 ................................................................................................................................... 102 TABLE 76. MX-8AH: ASRC CONTROL 4 .................................................................................................................................. 103 TABLE 77. MX-8CH: ASRC CONTROL 5 .................................................................................................................................. 103 TABLE 78. MX-8EH: HP AMP CONTROL 1 ............................................................................................................................... 104 TABLE 79. MX-8FH: HP AMP CONTROL 2 ............................................................................................................................... 104 TABLE 80. MX-93H: MICBIAS CONTROL ............................................................................................................................... 105 TABLE 81. MX-94H: JD1 CONTROL ......................................................................................................................................... 105 TABLE 82. MX-AEH: ADC PATH EQ CONTROL 1 .................................................................................................................... 106 TABLE 83. MX-AFH: ADC PATH EQ CONTROL 2 .................................................................................................................... 107 TABLE 84. MX-B0H: DAC PATH EQ CONTROL 1 .................................................................................................................... 108 TABLE 85. MX-B1H: EQ CONTROL 2 ....................................................................................................................................... 109 TABLE 86. MX-B2H: DRC CONTROL 1 .................................................................................................................................... 110 TABLE 87. MX-B3H: DRC CONTROL 2 .................................................................................................................................... 110 TABLE 88. MX-B4H: DRC CONTROL 3 .................................................................................................................................... 111 TABLE 89. MX-B5H: DRC CONTROL 4 .................................................................................................................................... 112 TABLE 90. MX-B6H: DRC CONTROL 5 .................................................................................................................................... 113 TABLE 91. MX-B7H: DRC CONTROL 6 .................................................................................................................................... 114 TABLE 92. MX-BBH: JACK DETECTION CONTROL 1 ................................................................................................................ 114 TABLE 93. MX-BDH: IRQ CONTROL 1 ..................................................................................................................................... 115 TABLE 94. MX-BEH: IRQ CONTROL 2 ..................................................................................................................................... 116 TABLE 95. MX-BFH: IRQ CONTROL 3 ..................................................................................................................................... 117 TABLE 96. MX-C0H: GPIO CONTROL 1 ................................................................................................................................... 118 TABLE 97. MX-C1H: GPIO CONTROL 2 ................................................................................................................................... 118 TABLE 98. MX-C2H: GPIO CONTROL 3 ................................................................................................................................... 119 TABLE 99. MX-CFH: SOUNZREALTM BASSBACK CONTROL..................................................................................................... 120 TABLE 100. MX-D0H: SOUNZREALTM TRUTREBLE CONTROL 1 .............................................................................................. 120 TABLE 101. MX-D1H: SOUNZREALTM L TRUTREBLE CONTROL 2 ............................................................................................ 121 TABLE 102. MX-D3H: STEREO1 ADC WIND FILTER CONTROL 1 ............................................................................................ 121 TABLE 103. MX-D4H: STEREO1 ADC WIND FILTER CONTROL 2 ............................................................................................ 122 TABLE 104. MX-D9H: SOFT VOLUME & ZCD CONTROL 1 ...................................................................................................... 123 TABLE 105. MX-DAH: SOFT VOLUME & ZCD CONTROL 2...................................................................................................... 124 TABLE 106. MX-DBH: INLINE COMMAND CONTROL 1 ............................................................................................................ 124 x Rev. 0.91 ALC5672-VB Datasheet TABLE 107. TABLE 108. TABLE 109. TABLE 110. TABLE 111. TABLE 112. TABLE 113. TABLE 114. TABLE 115. TABLE 116. TABLE 117. TABLE 118. TABLE 119. TABLE 120. TABLE 121. TABLE 122. TABLE 123. TABLE 124. TABLE 125. TABLE 126. TABLE 127. TABLE 128. TABLE 129. TABLE 130. TABLE 131. TABLE 132. TABLE 133. TABLE 134. TABLE 135. TABLE 136. TABLE 137. TABLE 138. TABLE 139. TABLE 140. TABLE 141. TABLE 142. TABLE 143. TABLE 144. TABLE 145. TABLE 146. TABLE 147. TABLE 148. TABLE 149. TABLE 150. TABLE 151. TABLE 152. TABLE 153. TABLE 154. TABLE 155. TABLE 156. TABLE 157. TABLE 158. TABLE 159. TABLE 160. TABLE 161. MX-DCH: INLINE COMMAND CONTROL 2 ............................................................................................................ 125 MX-DDH: INLINE COMMAND CONTROL 3 ............................................................................................................ 126 MX-E0H: VOICE DSP CONTROL 1 ........................................................................................................................ 126 MX-E1H: VOICE DSP CONTROL 2 ........................................................................................................................ 127 MX-E2H: VOICE DSP CONTROL 3 ........................................................................................................................ 127 MX-E3H: VOICE DSP CONTROL 4 ........................................................................................................................ 127 MX-E4H: VOICE DSP CONTROL 5 ........................................................................................................................ 128 MX-E5H: VOICE DSP CONTROL 6 ........................................................................................................................ 128 MX-ECH: MONO ADC WIND FILTER CONTROL 1 ................................................................................................ 128 MX-EDH: MONO ADC WIND FILTER CONTROL 2 ................................................................................................ 129 MX-EEH: STEREO2 ADC WIND FILTER CONTROL 1 ............................................................................................ 129 MX-EFH: STEREO2 ADC WIND FILTER CONTROL 2 ............................................................................................. 131 MX-F8H: JACK DETECTION CONTROL .................................................................................................................. 131 MX-F9H: JACK DETECTION CONTROL .................................................................................................................. 132 MX-FAH: GENERAL CONTROL 1........................................................................................................................... 132 MX-FBH: GENERAL CONTROL 2 ........................................................................................................................... 133 MX-FCH: GENERAL CONTROL 3 ........................................................................................................................... 134 PR-3DH: ADC/DAC RESET CONTROL................................................................................................................ 134 PR-A4H: DAC_L EQ (LPF2:A1) .......................................................................................................................... 135 PR-A5H: DAC_L EQ (LPF2:H0) .......................................................................................................................... 135 PR-A6H: DAC_R EQ (LPF2:A1) .......................................................................................................................... 135 PR-A7H: DAC_R EQ (LPF:H0) ........................................................................................................................... 135 PR-AEH: DAC_L EQ (BPF2:A1).......................................................................................................................... 136 PR-AFH: DAC_L EQ (BPF2:A2) .......................................................................................................................... 136 PR-B0H: DAC_L EQ (BPF2:H0) .......................................................................................................................... 136 PR-B1H: DAC_R EQ (BPF2:A1) .......................................................................................................................... 136 PR-B2H: DAC_R EQ (BPF2:A2) .......................................................................................................................... 137 PR-B3H: DAC_R EQ (BPF2:H0) ......................................................................................................................... 137 PR-B4H: DAC_L EQ (BPF3:A1) .......................................................................................................................... 137 PR-B5H: DAC_L EQ (BPF3:A2) .......................................................................................................................... 137 PR-B6H: DAC_L EQ (BPF3:H0) .......................................................................................................................... 138 PR-B7H: DAC_R EQ (BPF3:A1) .......................................................................................................................... 138 PR-B8H: DAC_R EQ (BPF3:A2) .......................................................................................................................... 138 PR-B9H: DAC_R EQ (BPF3:H0) ......................................................................................................................... 138 PR-BAH: DAC_L EQ (BPF4:A1) ......................................................................................................................... 139 PR-BBH: DAC_L EQ (BPF4:A2).......................................................................................................................... 139 PR-BCH: DAC_L EQ (BPF4:H0) ......................................................................................................................... 139 PR-BDH: DAC_R EQ (BPF4:A1) ......................................................................................................................... 139 PR-BEH: DAC_R EQ (BPF4:A2).......................................................................................................................... 140 PR-BFH: DAC_R EQ (BPF4:H0) ......................................................................................................................... 140 PR-C0H: DAC_L EQ (HPF1:A1) .......................................................................................................................... 140 PR-C1H: DAC_L EQ (HPF1:H0) ......................................................................................................................... 140 PR-C2H: DAC_R EQ (HPF1:A1) .......................................................................................................................... 141 PR-C3H: DAC_R EQ (HPF1:H0) ......................................................................................................................... 141 PR-C4H: DAC_L EQ (HPF2:A1) .......................................................................................................................... 141 PR-C5H: DAC_L EQ (HPF2:A2) .......................................................................................................................... 141 PR-C6H: DAC_L EQ (HPF2:H0) ......................................................................................................................... 142 PR-C7H: DAC_R EQ (HPF2:A1) .......................................................................................................................... 142 PR-C8H: DAC_R EQ (HPF2:A2) .......................................................................................................................... 142 PR-C9H: DAC_R EQ (HPF2:H0) ......................................................................................................................... 142 PR-CAH: DAC_L EQ PRE-VOLUME CONTROL .................................................................................................... 143 PR-CBH: DAC_R EQ PRE-VOLUME CONTROL .................................................................................................... 143 PR-CCH: DAC_L EQ POST-VOLUME CONTROL ................................................................................................... 143 PR-CDH: DAC_R EQ POST-VOLUME CONTROL .................................................................................................. 144 PR-CEH: ADC EQ (LPF:A1) ................................................................................................................................ 144 xi Rev. 0.91 ALC5672-VB Datasheet TABLE 162. TABLE 163. TABLE 164. TABLE 165. TABLE 166. TABLE 167. TABLE 168. TABLE 169. TABLE 170. TABLE 171. TABLE 172. TABLE 173. TABLE 174. TABLE 175. TABLE 176. TABLE 177. TABLE 178. TABLE 179. TABLE 180. TABLE 181. TABLE 182. TABLE 183. TABLE 184. TABLE 185. TABLE 186. TABLE 187. TABLE 188. TABLE 189. TABLE 190. TABLE 191. TABLE 192. TABLE 193. TABLE 194. TABLE 195. TABLE 196. TABLE 197. TABLE 198. TABLE 199. TABLE 200. TABLE 201. TABLE 202. TABLE 203. TABLE 204. TABLE 205. TABLE 206. TABLE 207. TABLE 208. TABLE 209. PR-CFH: ADC EQ (LPF:H0) ................................................................................................................................ 144 PR-D0H: ADC EQ (BPF1:A1) .............................................................................................................................. 144 PR-D1H: ADC EQ (BPF1:A2) .............................................................................................................................. 145 PR-D2H: ADC EQ (BPF1:H0) .............................................................................................................................. 145 PR-D3H: ADC EQ (BPF2:A1) .............................................................................................................................. 145 PR-D4H: ADC EQ (BPF2:A2) .............................................................................................................................. 145 PR-D5H: ADC EQ (BPF2:H0) .............................................................................................................................. 146 PR-D6H: ADC EQ (BPF3:A1) .............................................................................................................................. 146 PR-D7H: ADC EQ (BPF3:A2) .............................................................................................................................. 146 PR-D8H: ADC EQ (BPF3:H0) .............................................................................................................................. 146 PR-D9H: ADC EQ (BPF4:A1) .............................................................................................................................. 147 PR-DAH: ADC EQ (BPF4:A2).............................................................................................................................. 147 PR-DBH: ADC EQ (BPF4:H0) ............................................................................................................................. 147 PR-DCH: ADC EQ (HPF1:A1).............................................................................................................................. 147 PR-DDH: ADC EQ (HPF1:H0) ............................................................................................................................. 148 PR-E1H: ADC EQ PRE-VOLUME CONTROL .......................................................................................................... 148 PR-E2H: ADC EQ POST-VOLUME CONTROL ........................................................................................................ 148 PR-E5H: DAC_L BIQUAD EQ (BPF1:H0-1).......................................................................................................... 148 PR-E6H: DAC_L BIQUAD EQ (BPF1:H0-2).......................................................................................................... 149 PR-E7H: DAC_L BIQUAD EQ (BPF1:B1-1) .......................................................................................................... 149 PR-E8H: DAC_L BIQUAD EQ (BPF1:B1-2) .......................................................................................................... 149 PR-E9H: DAC_L BIQUAD EQ (BPF1:B2-1) .......................................................................................................... 149 PR-EAH: DAC_L BIQUAD EQ (BPF1:B2-2) ......................................................................................................... 150 PR-EBH: DAC_L BIQUAD EQ (BPF1:A1-1) ......................................................................................................... 150 PR-ECH: DAC_L BIQUAD EQ (BPF1:A1-2) ......................................................................................................... 150 PR-EDH: DAC_L BIQUAD EQ (BPF1:A2-1)......................................................................................................... 150 PR-EEH: DAC_L BIQUAD EQ (BPF1:A2-2) ......................................................................................................... 151 PR-EFH: DAC_R BIQUAD EQ (BPF1:H0-1) ......................................................................................................... 151 PR-F0H: DAC_R BIQUAD EQ (BPF1:H0-2).......................................................................................................... 151 PR-F1H: DAC_R BIQUAD EQ (BPF1:B1-1) .......................................................................................................... 151 PR-F2H: DAC_R BIQUAD EQ (BPF1:B1-2) .......................................................................................................... 152 PR-F3H: DAC_R BIQUAD EQ (BPF1:B2-1) .......................................................................................................... 152 PR-F4H: DAC_R BIQUAD EQ (BPF1:B2-2) .......................................................................................................... 152 PR-F5H: DAC_R BIQUAD EQ (BPF1:A1-1).......................................................................................................... 152 PR-F6H: DAC_R BIQUAD EQ (BPF1:A1-2).......................................................................................................... 153 PR-F7H: DAC_R BIQUAD EQ (BPF1:A2-1).......................................................................................................... 153 PR-F8H: DAC_R BIQUAD EQ (BPF1:A2-2).......................................................................................................... 153 MX-FEH: VENDOR ID........................................................................................................................................... 153 ABSOLUTE MAXIMUM RATINGS ............................................................................................................................ 154 RECOMMENDED OPERATING CONDITIONS............................................................................................................. 154 STATIC CHARACTERISTICS .................................................................................................................................... 154 ANALOG PERFORMANCE CHARACTERISTICS ......................................................................................................... 155 I2C TIMING ............................................................................................................................................................ 157 TIMING OF I2S/PCM MASTER MODE ..................................................................................................................... 158 I2S/PCM SLAVE MODE TIMING ............................................................................................................................. 159 DIGITAL MICROPHONE INTERFACE TIMING ........................................................................................................... 160 THERMAL INFORMATION ....................................................................................................................................... 164 ORDERING INFORMATION ...................................................................................................................................... 165 xii Rev. 0.91 ALC5672-VB Datasheet List of Figures FIGURE 1. FIGURE 2. FIGURE 3. FIGURE 4. FIGURE 5. FIGURE 6. FIGURE 7. FIGURE 8. FIGURE 9. FIGURE 10. FIGURE 11. FIGURE 12. FIGURE 13. FIGURE 14. FIGURE 15. FIGURE 16. FIGURE 17. FIGURE 18. FIGURE 19. FIGURE 20. FIGURE 21. FIGURE 22. FIGURE 23. FIGURE 24. FIGURE 25. FIGURE 26. FIGURE 27. FIGURE 28. FIGURE 29. FIGURE 30. FIGURE 31. FIGURE 32. FIGURE 33. FIGURE 34. FIGURE 35. FIGURE 36. FIGURE 37. FIGURE 38. FIGURE 39. AUDIO MIXER PATH ................................................................................................................................................... 5 AUDIO MIXER PATH ................................................................................................................................................... 6 DIGITAL MIXER PATH ................................................................................................................................................ 7 PIN ASSIGNMENTS ...................................................................................................................................................... 8 GENERAL SYSTEM CONNECTION .............................................................................................................................. 12 POWER ON/OFF TIMING ........................................................................................................................................... 15 AUDIO CLOCK TREE ................................................................................................................................................. 17 SYSTEM CONNECTION FOR ASRC FUNCTION ........................................................................................................... 20 MONO PCM DATA MODE A FORMAT (BCLK POLARITY=0) ................................................................................ 22 MONO PCM DATA MODE B FORMAT (BCLK POLARITY=0) .............................................................................. 23 PCM STEREO DATA MODE A FORMAT (BCLK POLARITY=0) ............................................................................ 23 TDM MODE-1 PCM DATA MODE A FORMAT (BCLK POLARITY=0) ................................................................. 23 PCM STEREO DATA MODE B FORMAT (BCLK POLARITY=0) ............................................................................ 24 TDM MODE-1 PCM DATA MODE B FORMAT (BCLK POLARITY=0) ................................................................... 24 TDM MODE-2 PCM DATA MODE B FORMAT (BCLK POLARITY=0) ................................................................... 24 I2S DATA FORMAT (BCLK POLARITY=0)............................................................................................................. 25 I2S TDM DATA FORMAT (BCLK POLARITY=0) ................................................................................................... 25 LEFT-JUSTIFIED DATA FORMAT (BCLK POLARITY=0) ........................................................................................ 25 LEFT-JUSTIFIED TDM DATA FORMAT (BCLK POLARITY=0) ............................................................................... 26 4-CHANNEL RECORDING PATH ................................................................................................................................ 27 4-CHANNEL PLAYBACK PATH .................................................................................................................................. 28 STEREO BTL SPEAKER OUTPUT ............................................................................................................................... 31 DAC DRC FUNCTION BLOCK .................................................................................................................................. 35 ADC AGC FUNCTION BLOCK .................................................................................................................................. 35 PLAYBACK DRC OUTPUT CURVE ............................................................................................................................ 36 RECORD DRC OUTPUT CURVE - 1............................................................................................................................ 37 RECORD DRC OUTPUT CURVE - 2............................................................................................................................ 38 DRC/AGC FOR PLAYBACK/RECORDING MODE ....................................................................................................... 39 DRC/AGC FOR NOISE GATE MODE ......................................................................................................................... 40 DATA TRANSFER OVER I2C CONTROL INTERFACE ................................................................................................... 44 GPIO FUNCTION BLOCK .......................................................................................................................................... 46 IRQ FUNCTION BLOCK............................................................................................................................................. 47 POWER MANAGEMENT ............................................................................................................................................. 51 I2C CONTROL INTERFACE ....................................................................................................................................... 157 TIMING OF I2S/PCM MASTER MODE ...................................................................................................................... 158 I2S/PCM SLAVE MODE TIMING ............................................................................................................................. 159 DIGITAL MICROPHONE INTERFACE TIMING............................................................................................................ 160 APPLICATION CIRCUIT ........................................................................................................................................... 162 PACKAGE DIMENSION ............................................................................................................................................ 163 xiii Rev. 0.91 ALC5672-VB Datasheet 1. General Description The ALC5672 is a high performance, low power, dual I2S interface audio CODEC with embedded low power/high performance Voice DSP. Dual I2S interface can connect to different devices and let the ALC5672 to be an Audio Hub. Each device can pass through the Audio Hub and then perform as input or output application. Asynchronous Sample Rate Converter (ASRC) provides independent and asynchronous connections to different processors, such as an application processor, baseband processor or wireless transceiver(BT). Stereo Class-D speaker amplifiers provide 1.5W per channel into 8Ω or 2.8W per channel into 4Ω with a 5V supply, with high THD+N performance, excellent PSRR and low EMI. A mono differential earpiece amplifier is also provided, providing output from any DAC or Analog-in. The ALC5672 features a Class-G type ultra low power cap-free headphone amplifier. It is a high efficiency audio amplifier with an integrated Class-G voltage converter that enhances efficiency at low output power. It consumes only around 5mW power during playback, providing mobile system longer battery life under headphone listening mode. The integrated multi-section DRC(Dynamic Range Controller) and 14-band parametric Equalizer provide further digital sound processing capability of audio playback paths. The multi-section DRC in ALC5672 continuously monitors the DAC output level. When the power level is low, it increases the input signal gain to make it sound louder. At the same time, if a peaking signal is detected, it autonomously reduces the applied gain to avoid hard clipping. It ensures the maximum/consistent signal amplitude without producing audio clipping and speaker damage. The 14-band parametric Equalizer contains each channel has 7 independent filters with programmable gain, center frequency and bandwidth to tailor the frequency characteristics of embedded speaker system according to user preferences. For microphone recording, the DRC in ALC5672 can be used as AGC(Auto Gain Controller) to maintain a constant recording volume. Besides, a dynamic wind reduction filter is built in on recording path. The filter can detect the level of wind noise and on/off dynamically to keep the recording quality. The ALC5672 also integrates independent 6-band parametric Equalizer for recording path. They can use to compensate microphone device frequency response. ALC5672 embedded a low power, high performance voice processor. The 140MIPS voice processor provides advanced voice processing features, including exceptional noise suppression, echo cancellation and advanced Beam-Forming under low power consumption. The voice processor is optimized for advanced voice processing to improve voice quality for voice communication and recording in noisy environments. SounzRealTM post-processing technology is configurable to provide better listening experience. BassBack EXPTM bring LFE(low frequency effect) to listeners without subwoofer needed. TruTreble EXPTM adds processed harmonic tones at high frequency, bringing more melody and details for music listening. 1 Rev. 0.9 ALC5672-VB Datasheet 2.   Features Digital Super Wideband Voice DSP  Voice communication enhancement (AEC, NS…etc.)  Advanced Beam-Forming (Voice Tracking)  Stereo Far field pick-up recording (48KHz Sample Rate) SounzRealTM post-processing  TruTreble  BassBack  Parametric 14 bands equalizer (EQ) – each 7 bands for L/R playback path independent control  Parametric 6 bands equalizer (EQ) for recording path  Advanced DRC with multi-section compressor function for playback/recording path  Sound detection wake up technology  Wind noise reduction filter  One 24bit/8kHz ~ 192kHz I2S/PCM/TDM digital interface  One 24bit/8kHz ~ 192kHz I2S/PCM digital interface  Digital asynchronous sampling rate converter (ASRC) function  I2C control interface  3 stereo digital microphone interfaces  4 Digital-to-Analog Converter with 100dBA SNR  2 Analog-to-Digital Converter with 94dBA SNR  2 single-ended analog microphone inputs with pre-amplifiers (+20/24/30/35/40/44/50/52dB) and low noise microphone bias    MIC input to ADC with 50dB Boost, SNR>66dBA, THD+N 48KHz * 25Bit * 8CH) (Only support for I2S-1)   BCLK clock rate only support 50FS/100FS/150FS/200FS (FS is sample rate) I2S mode  Normal I2S mode (Support for all I2S port)  Left justified mode (Support for all I2S port)  TDM mode-1 (Max. BCLK Rate is 12.288MHz => 48KHz * 32Bit * 8CH) (Only support for I2S-1) 1/Fs LRCK BLCK DACDAT/ ADCDAT X 1 2 3 4 5 6 7 8 MSB Figure 9. 9 1 0 1 1 1 2 1 3 1 4 1 5 1 X 6 LSB Mono PCM Data Mode A Format (BCLK POLARITY=0) 22 Rev. 0.91 ALC5672-VB Datasheet 1/Fs LRCK BLCK DACDAT/ ADCDAT 1 6 1 2 3 4 5 6 7 8 1 1 1 0 9 1 2 1 3 1 4 1 5 MSB Figure 10. 1 1 6 LSB Mono PCM Data Mode B Format (BCLK POLARITY=0) 1/ Fs LRCK BLCK DACDAT/ ADCDAT 1 2 3 n-1 n MSB 1 LSB MSB n-1 n LSB Right-Channel Left-Channel Figure 11. 3 2 PCM Stereo Data Mode A Format (BCLK POLARITY=0) 1/ Fs LRCK BLCK DACDAT / ADCDAT 1 2 MSB Channel Length: 16/20/24/32Bit Figure 12. ------ n 1 2 LSB MSB Channel-1 ------ n 1 2 LSB MSB Channel-2 ------ n 1 2 LSB MSB Channel-3 n 1 2 LSB MSB ------ Channel-8 TDM Mode-1 PCM Data Mode A Format (BCLK POLARITY=0) 23 Rev. 0.91 ALC5672-VB Datasheet 1/Fs LRCK BLCK DACDAT/ ADCDAT 1 3 2 1 n-1 n MSB n-1 n LSB MSB LSB Left-Channel Figure 13. 3 2 Right-Channel PCM Stereo Data Mode B Format (BCLK POLARITY=0) 1/ Fs LRCK BLCK DACDAT / ADCDAT 1 2 MSB Channel Length: 16/20/24/32Bit ------ n 1 2 LSB MSB Channel-1 ------ n 1 2 LSB MSB ------ n 1 2 LSB MSB Channel-3 Channel-2 ------ n 1 2 LSB MSB Channel-8 Figure 14. TDM Mode-1 PCM Data Mode B Format (BCLK POLARITY=0) 1/ Fs LRCK BLCK Channel Length DACDAT / ADCDAT Channel Length: 16/20/24Bit Data Length: 16/20/24Bit 1 2 MSB ------ n 1 2 LSB MSB Channel-1 ------ n 1 2 LSB MSB ------ x 1 2 LSB Channel-8 Channel-2 n x x MSB Don’t Care Figure 15. TDM Mode-2 PCM Data Mode B Format (BCLK POLARITY=0) 24 Rev. 0.91 ALC5672-VB Datasheet 1/ Fs Left Channel Right Channel LRCK BLCK DACDAT/ ADCDAT 1 n-1 n 2 1 LSB MSB 2 n-1 n LSB MSB 2 Figure 16. I S Data Format (BCLK POLARITY=0) 1/ Fs LRCK BLCK DACDAT / ADCDAT 1 2 Channel Length: 16/20/24/32Bit ------ MSB n 1 2 LSB MSB n 1 2 ------ LSB MSB Channel-7 Channel-1 Data Length: 16/20/24Bit ------ n 1 2 LSB MSB Channel-2 ------ n 1 2 3 LSB Channel-8 2 Figure 17. I S TDM Data Format (BCLK POLARITY=0) 1/ Fs Left Channel Right Channel LRCK BLCK DACDAT/ ADCDAT 1 MSB 2 n-1 n 1 LSB MSB 2 n-1 n LSB Figure 18. Left-Justified Data Format (BCLK POLARITY=0) 25 Rev. 0.91 ALC5672-VB Datasheet 1/ Fs LRCK BLCK DACDAT / ADCDAT Channel Length: 16/20/24/32Bit Data Length: 16/20/24Bit 1 2 MSB ------ n 1 2 LSB MSB Channel-1 ------ n 1 2 LSB MSB Channel-7 ------ n 1 2 LSB MSB Channel-2 ------ n 1 2 3 LSB Channel-8 Figure 19. Left-Justified TDM Data Format (BCLK POLARITY=0) 26 Rev. 0.91 ALC5672-VB Datasheet 9.5. Audio Data Path The ALC5672 provides 4-channel analog DACs for playback and 2-channel analog ADCs for recording. 9.5.1. 2 Analog ADCs with 6-Channel Record Path There are two analog ADCs and with up to 6-channel recording path. You can use two analog microphones pass to analog ADCs and four digital microphones to reach 6-channel recording. Or use three digital microphone interfaces to reach 6-channel recording. These 6-channel data can through I2S1 interface for recording. The I2S1 interface supports TDM interface and up to 8-CH, 24-bit/CH recording. The full scale input of analog ADC is around 0.55Vrms. In order to save power, the left and right analog ADC can be powered down separately by setting pow_adc_l (MX-61[2]) and pow_adc_r (MX-61[1]). And the volume control of the stereo ADC is also separately controlled by ad_gain_l (MX-1C[14:8]) and ad_gain_r (MX-1C[6:0]). DMIC1_L DMIC1_L DMIC1_L DMIC2_L DMIC2_L DMIC2_L DMIC3_L DMIC3_L DAC_MIXL DMIC3_L DAC_MIXL Mono_DAC_MIXL CH1 IF_ADC1_L DAC_MIXL CH3 IF_ADC2_L Mono_DAC_MIXL Analog ADC_L Analog ADC_L DMIC1_R DMIC1_R DMIC1_R DMIC2_R DMIC2_R DMIC2_R DMIC3_R DMIC3_R DMIC3_R DAC_MIXR Mono_DAC_MIXR CH2 DAC_MIXR Analog ADC_R IF_ADC1_R IF_ADC3_L CH6 IF_ADC3_L DAC_MIXR CH4 Mono_DAC_MIXR IF_ADC2_R DAC_MIXR Analog ADC_R IF_ADC1_L CH5 DAC_MIXL Analog ADC_L Analog ADC_R IF_ADC1_R IF_ADC2_L IF_ADC2_R IF_ADC3_L IF_ADC3_R TDM Format Figure 20. 4-Channel Recording Path 27 Rev. 0.91 ALC5672-VB Datasheet 9.5.2. 4 DACs with 4-Channel Playback Path There are four analog DACs and with up to 4-channel playback path. Two I2S interfaces provide four channels data to analog DACs. And analog DAC can output audio signal to speaker output, headphone output or line output. That also can use I2S1 TDM interface to support 4-channel playback. The full scale output of analog DAC is around 1Vrms at line output port. In order to save power, the four analog DACs can be powered down separately by setting pow_dac_l_1 (MX-61[12]), pow_dac_r_1 (MX-61[11]), pow_dac_l_2 (MX-61[7]) and pow_dac_r_2 (MX-61[6]). And the digital volume control of the four DACs are also separately controlled by vol_dac1_l (MX-19[15:8]), vol_dac1_r (MX-19[7:0]), vol_mono_dacl (MX-1A[15:8] and vol_mono_dacr (MX-1A[7:0]). L L CH1 IF1_DAC Analog DACL1 IF1_DAC I2S1 R L IF2_DAC Analog DACL1 CH2 Analog DACR1 CH3 Analog DACL2 CH4 Analog DACR2 R CH2 Analog DACR1 CH3 Analog DACL2 L I2S1 TDM I2S2 R CH1 I2S1 TDM CH4 Analog DACR2 R Figure 21. 4-Channel Playback Path 28 Rev. 0.91 ALC5672-VB Datasheet 9.5.3. Mixers The ALC5672 has digital and analog mixers build-in.  Output mixer - OUTMIXL/R The stereo analog mixer can do mixing for DAC output and analog input. The mixer output is mainly for line output. Each input path has it’s mute control to the mixer block in MX-53. pow_outmixl and pow_outmixr can be used to power on/off OUTMIXL/R  Record mixer – RECMIXL/R The stereo analog mixer can do mixing for analog input and OUTMIX output. The mixer output is for ADC input. Each input path has it’s mute control to the mixer block in MX-3B ~ MX-3E. pow_recmixl and pow_recmixr can be used to power on/off RECMIXL/R.  HP mixer – HPMIXL/R The stereo analog mixer can do mixing for headphone volume and DAC output. The mixer output directly output to external headphone device. Each input path has it’s mute control to the mixer block in MX-45.  Digital mixer There are twelve digital mixers in ALC5672. Six digital mixers are assigned for ADC recording. These six mixers can mix analog line input, analog microphone input and digital microphone input then output to I2S interface to other device. Another four digital mixers are assigned for DAC playback. These mixers can mix digital data from I2S interface or ADC data from external analog signal. The mixed data is output to analog DAC and output port to drive external device. The other two mixers are used for DA-AD processing. The incoming data from two I2S interfaces (DACDAT) uses these two mixers to do mixing and output to I2S interface (ADCDAT). 29 Rev. 0.91 ALC5672-VB Datasheet 9.6. Analog Audio Input Port The ALC5672 has two type analog input ports: microphone input and line input.  IN1P_RING2/IN1N_SLEEVE The port is a microphone type input port. The input port only can be configured as single-ended mode. The microphone input port has its microphone bias and microphone boost. The low noise microphone bias can improve recording performance and enhance recording quality. Build-in short current detection scheme can be used for switch detection. Multi-steps microphone boost gain set by sel_bst1 (MX-0D[15:12]) is easy to use for microphone application. Pow_bst1 can be used to power down the MIC1 boost and pow_micbias1 can be used to power down the microphone bias 1.  IN2P/N The IN2P/N is a dual type input port: microphone input and line input. Microphone input can be configured to differential input or single-ended input by MX-0E[7]. Multi-steps microphone boost gain set by sel_bst2 (MX-0E[15:12]) is easy to use for microphone application. Pow_bst2 can be used to power down the MIC2 boost. If as line input, it has volume control for tuning by MX-0F[12:8] and MX-0F[4:0]. 30 Rev. 0.91 ALC5672-VB Datasheet 9.7. Analog Audio Output Port The ALC5672 supports three type output ports:  SPO_L/R_P/N The speaker output of ALC5672 is a stereo BTL output with Class-D type amplifier. The power of speaker amplifier is an individual power pin and higher than AVDD. So the input and output of speaker amplifier has a gain ratio to enlarge or reduce the income analog signal. The ratio gain is auto tuning. The input source of the speaker output port can be selected from Stereo_DAC_MIXL/R or Mono_DAC_MIXL/R. SPKVDDL Stereo_DAC_MIXL LP Gate Drive Mono_DAC_MIXL SPOLP SPKGND SPKVDDL Stereo_DAC_MIXL LN SPOLN Gate Drive Mono_DAC_MIXL SPKGND SPKVDDR Stereo_DAC_MIXR RP Gate Drive Mono_DAC_MIXR SPORP SPKGND SPKVDDR Stereo_DAC_MIXR LN Gate Drive Mono_DAC_MIXR SPORN SPKGND Figure 22. Stereo BTL Speaker Output 31 Rev. 0.91 ALC5672-VB Datasheet  HPO_L/R The headphone output of ALC5672 is a stereo output with cap-free type headphone amplifier. It does not need to connect external capacitor and can connect to earphone device directly. The headphone output source can mix from output mixer (HPMIX) and DAC by setting MX-45. The front stage of headphone output has volume control and gain control. The volume range is from +12dB to -46.5dB with 1.5dB/step by MX-02. En_l_hp and en_r_hp (MX-63[7/6]) can be used to power on/off Headphone Amplifier, and pow_hpo_voll and pow_hpo_volr (MX-66[11/10]) can be used to power on/off headphone volume control. In addition, pow_pump_hp (MX-8E[3]) can be used to power on/off charge pump circuit for Headphone Amplifier.  Line_OUT_L/R The output type is line type output. The output is a stereo single ended output or mono differential. The input can be selected from OUTMIX or DAC output by setting MX-53[15:12]. The front stage of LOUT output has gain control for attenuation. The gain control is 0dB or -6dB by MX-53[11]. 9.8. Multi-Function Pins There are eight multi-function pins in ALC5672. For different functions of each pin are controlled by register. You need to set the right register settings for each multi-function pins by your application. 32 Rev. 0.91 ALC5672-VB Datasheet  GPIO1/IRQ – Pin 41 The pin default is GPIO function. It can change to IRQ output, write MX-C0[15] to 1’b will switch to IRQ function.  GPIO2/DMIC_SCL – Pin 42 The pin default is GPIO function. It can change to DMIC clock output, write MX-C0[14] to 1’b will switch to DMIC clock output function.  IN2P/INL/DMIC1_DAT – Pin 4 The pin can as analog microphone positive input or as line input. If as analog microphone input function needs to power on the power – MX-64[13] & MX64[4]. If as analog input function needs to power on the power – MX-66[9] & MX66[8]. Digital microphone input function: 1. Power down analog microphone input and line input. 2. Mute IN2 to each analog mixer - (RECMIXLR/OUTMIXLR/HPMIXLR). 3. Change IN2P pin share function, set MX-75[1:0] to 01’b. 4. Turn on digital microphone function – MX-75[14] = 1’b  IN2N/INR/DMIC2_DAT/JD2 – Pin 5 There are four functions share this pin. For each function switching shows below: Analog microphone input function, power on MX-64[13] & MX-64[4] and power off other functions. Analog line input function, power on MX-66[9] & MX-66[8] and power off other functions. Digital microphone input function: 1. Power down analog microphone input, line input and JD2 function 2. Mute IN2 to each analog mixer - (RECMIXLR/OUTMIXLR/HPMIXLR). 3. Change IN2N pin share function, set MX-75[10] to 1’b. 4. Turn on digital microphone function – MX-75[14] = 1’b Jack detection function: 1. Power down analog microphone input, line input and digital microphone function. 2. Mute IN2 to each analog mixer - (RECMIXLR/OUTMIXLR/HPMIXLR). 3. Turn on JD2 power – MX-64[1] = 1’b  BCLK2/GPIO3 – Pin 31 MX-C0[8] use to control pin31 is BCLK2 function or GPIO function. 33 Rev. 0.91 ALC5672-VB Datasheet  LRCK2/GPIO4 – Pin 30 MX-C0[8] use to control pin31 is LRCK2 function or GPIO function.  DACDAT2/GPIO5/DMIC3_SDA – Pin 32 MX-C0[8] use to control pin31 is LRCK2 function or GPIO function. MX-C0[7] use to control pin31 is GPIO function or DMIC_SDA3 function.  ADCDAT2/GPIO6/DMIC1_SDA – Pin 33 MX-C0[8] use to control pin31 is LRCK2 function or GPIO function. MX-C0[6] use to control pin31 is GPIO function or DMIC_SDA1 function. 34 Rev. 0.91 ALC5672-VB Datasheet 9.9. DRC and AGC Function The Dynamic Range Controller (DRC) dynamically adjusts the input signal and let the output signal achieve the target level. The ALC5672 supports playback DRC for DAC path, and the DRC can also be used as AGC(Auto Gain Controller) for ADC path. The control register is at MX-B4[15:14]. The function block is shown as below. The signal input pass through the Pre-Gain first, then DRC volume and Post-Gain then output. The Pre-Gain is use to enlarge the input signal. The DRC volume is use to attenuate the signal after detected by DRC. The Post-Gain is use to fine tune the signal after pass DRC tuning. 0 ~ 28.5dB, 1.5/step MXB5[4:0] -95.625 ~ 0dB 0.375/step -11.625 ~ 12dB, 0.375/step MXB5[13:8] Pre-Gain DRC Volume Post-Gain I2C Interface DAC DRC 1. Limiter level 2. Attack / Release time 3. Zero data Figure 23. DAC DRC Function Block Analog Pre-Boost ADC 0 ~ 28.5dB, 1.5/step MXB5[4:0] -95.625 ~ 0dB 0.375/step -11.625 ~ 12dB, 0.375/step MXB5[13:8] Pre-Gain AGC Volume Post-Gain I2S Interface AGC 1. Limiter level 2. Attack / Release time 3. Noise gate Figure 24. ADC AGC Function Block 35 Rev. 0.9 ALC5672-VB Datasheet DRC Output Curve - Playback Mode: The Figure 24. shows DRC output curve for DAC playback application. Alc_thmax(MX-B7[5:0]): The parameter limits the maximum output level when 0dB full scale input. The limit range is from 0dBFS to -23.625dBFS. Ratio_1(MX-B5[6:5]): The parameter determines the slope begin from start point. There are 4 slopes can be selected. Alc_thmax2(MX-B7[11:6]): The parameter determines the first knee from ratio_1 curve. The range is from 0dBFS to -45dBFS. Ratio_2(MX-B5[15:14]): The parameter determines the slope begin from first knee. There are 4 slopes can be selected. The second knee is calculated by internal circuit. It bases on ratio_2 and alc_thmin to calculate. Alc_thmin(MX-B2[5:0]): The parameter determines the third knee from previous curve. The range is from -60dBFS to -94.5dBFS. Ratio_3(MX-B5[1:0]): The slope is determined by third knee and end point. The end point is determined by boost gain on MX-B3[11:6] register. Vout (db) Segment1 Segment2 Segment_thmin 0 alc_thmax=-6db (REG.) -6 ratio_1=¼ (REG.) Start Point -12 -18 2nd Knee st -24 1: 1 Bo o -30 -36 ration_2=½ (REG.) 1st Knee -42 -48 3rd Knee -54 -60 ration_3 (H/W) -66 -72 -78 -84 boost_gain = 12db (REG.) -90 End Point -95.625 -90 -84 -78 -72 -66 -60 -54 -48 -42 alc_thmin = -60db (REG.) -36 -30 -24 Knee (H/W) -18 -12 -6 0 Vin (db) alc_thmax2 = -12db (REG.) Figure 25. Playback DRC Output Curve 36 Rev. 0.91 ALC5672-VB Datasheet DRC Output Curve - Record Mode 1: The Figure 25. shows DRC output curve for ADC record application. Alc_thmax(MX-B7[5:0]): The parameter limits the maximum output level when 0dB full scale input. The limit range is from 0dBFS to -23.625dBFS. Ratio_1(MX-B5[6:5]): The parameter determines the slope begin from start point. There are 4 slopes can be selected. Alc_thmax2(MX-B7[11:6]): The parameter determines the first knee from ratio_1 curve. The range is from 0dBFS to -45dBFS. Ratio_2(MX-B5[15:14]): The parameter determines the slope begin from first knee. There are 4 slopes can be selected. The second knee is calculated by internal circuit. It bases on ratio_2 and alc_thnoise to calculate. Alc_thnoise(MX-B6[4:0]): The parameter determines the third knee from previous curve. The range is from -24dBFS to -70.5dBFS. Noise_gate_ratio(MX-B5[1:0]): The parameter determines the slope begin from third knee. There are 4 slopes can be selected. The end point is determined by third knee and noise_gate_ratio. Vout (db) Segment1 Segment2 Segment_noise_gate 0 alc_thmax=-6db (REG.) Start Point -12 ratio_1=¼ (REG.) -6 -18 Bo o st 2nd Knee 1: 1 -24 -30 -36 3rd Knee ratio_2=½ (REG.) 1st Knee -42 -48 -54 noise_gate_ratio=2 (REG.) -60 -66 -72 -78 -84 boost_gain = 12db (REG.) -90 -95.625 End Point -90 -84 -78 -72 -66 -60 -54 -48 -42 alc_thnoise = -48db (REG.) -36 -30 -24 -18 Knee (H/W) -12 -6 0 Vin (db) alc_thmax2 = -12db (REG.) Figure 26. Record DRC Output Curve - 1 37 Rev. 0.91 ALC5672-VB Datasheet DRC Output Curve - Record Mode 2: The Figure 26. shows another DRC output curve for ADC record application. Alc_thmax(MX-B7[5:0]): The parameter limits the maximum output level when 0dB full scale input. The limit range is from 0dBFS to -23.625dBFS. Ratio_1(MX-B5[6:5]): The parameter determines the slope begin from start point. There are 4 slopes can be selected. Alc_thmax2(MX-B7[11:6]): The parameter determines the first knee from ratio_1 curve. The range is from 0dBFS to -45dBFS. Ratio_2(MX-B5[15:14]): The parameter determines the slope begin from first knee. There are 4 slopes can be selected. The second knee is calculated by internal circuit. It bases on ratio_2 and alc_thnoise to calculate. Alc_thnoise(MX-B6[4:0]): The parameter determines the third knee from previous curve. The range is from -24dBFS to -70.5dBFS. From third knee to fourth knee is a noise drop function by enable noise gate drop mode at MX-B5[4]. The drop level is determined by boost_gain (MX-B3[11:6]) and alc_noise_gate_exp (MX-B6[15:12]). Noise_gate_ratio(MX-B5[1:0]): The parameter determines the slope begin from fourth knee. There are 4 slopes can be selected. The end point is determined by fourth knee and noise_gate_ratio. Vout (db) Segment1 Segment2 Segment_noise_gate 0 alc_thmax=-6db (REG.) -6 Start Point ratio_1=¼ (REG.) -12 -18 2nd Knee -24 -30 3rd Knee -36 ratio_2=½ (REG.) 1st Knee boost_gain = 12db -42 Drop_all = 12 + 6 =18db -48 alc_noise_gate_exp = 6db -54 4th Knee -60 noise_gate_ratio=2 (REG.) -66 -72 -78 -84 boost_gain = 12db (REG.) -90 End Point -95.625 -90 -84 -78 -72 -66 -60 -54 -48 -42 alc_thnoise = -48db (REG.) -36 -30 -24 Knee (H/W) -18 -12 -6 0 Vin (db) alc_thmax2 = -12db (REG.) Figure 27. Record DRC Output Curve - 2 38 Rev. 0.91 ALC5672-VB Datasheet Playback/Recording Mode: For DAC playback or ADC recording mode, when the input signal exceeds target threshold, the signal will decrease “DRC/AGC Digital Volume” (0.375dB/step at every zero-crossing) until drop to target level then keep the digital volume. When input signal is below the target threshold, the signal will step-up “DRC/AGC Digital Volume” (0.375dB/step every zero-crossing) until return to original level. If want to return to the target level, need to set the pre-gain to achieve. Fine tune parameters:  Limiter Threshold: 0 ~ -46.5dB, 1.5dB/step, MX-B7[5:0]  Attack Rate: T=(4*2^n)/sample rate, n = MX-B4[12:8]  Recovery Rate: T=(4*2^n)/sample rate, n = MX-B4[4:0] Input signal Target Level Volume 0dB Attack Rate Recovery Rate Output signal Figure 28. DRC/AGC for Playback/Recording Mode 39 Rev. 0.91 ALC5672-VB Datasheet Noise Gate Mode: The Noise Gate Function is use to reduce the noise floor for DAC path or ADC path. When input signal is below noise gate level, the input signal will be reduced by DRC/AGC volume in order to suppress the background noise. The reducing level can be set by register. And when input signal is above noise gate, the input signal will be boosted to target level. Fine tune parameters:  Noise Gate Threshold: -36 ~ -82.5dB, 1.5dB/step, MX-B6[4:0]  Noise Gate Attack Rate: T=(4*2^n)/sample rate, n = PR-06[4:0]  Noise Gate Recovery Rate: T=(4*2^n)/sample rate, n = PR-02[12:8]  Reducing Noise Level: 0 ~ 45dB, 3dB/step, MX-B6[15:12] Input signal Target Level Noise Gate Volume 0dB Attack Rate Recovery Rate Attack Rate Recovery Rate Noise Reduction Output signal Target Level Noise Gate Figure 29. DRC/AGC for Noise Gate Mode 40 Rev. 0.91 ALC5672-VB Datasheet 9.10. SounzRealTM Post-Processing The Realtek’s SounzRealTM post-processing is composed of:   TruTreble BassBack 9.11. Equalizer Block The equalizer block cascades 7 bands of equalizer to each channel to tailor the frequency characteristics of embedded speaker system according to user preferences and to emulate environment sound. The 7 bands equalizer includes two high pass filters, three band pass filters, one low pass filter and one biquad filter. One high pass filter cascaded in the front end is used to drop low frequency tone, The tone has a large amplitude and may damage a mini speaker. The high pass filter can be used to adjust Treble strength with gain control. One low pass filter with gain control can adjust the Bass strength. Three bands of band pass filters are used to emulate environment sounds, e.g., ‘Pub’, ‘Live’, ‘Rock’,… etc.. The gain, center frequency and bandwidth of each filter are all programmable. One biquad filter can switch to high-pass, low-pass or band-pass filter by register settings. 9.12. Wind Noise Reduction Filter The wind filter is implemented by a high pass filter equalizer. The wind filter is mainly for ADC recording used. The cut-off freqnecy of wind filter is programmable and is varied accroding to different sample rate. The filter is used to remove DC offset at normal condition, and to remove wind noise at application mode. There are three wind filters for three ADC filters: Stereo 1 ADC Wind Filter => MX-D3 & MX-D4 Mono ADC Wind Filter => MX-EC & MX-ED Stereo 2 ADC Wind Filter => MX-EE & MX-EF 41 Rev. 0.91 ALC5672-VB Datasheet Wind filter setting procedure (For Stereo 1 ADC Filter): Step1: Disable wind filter – MX-D3[15] Step2: Select filter coarse coefficient – MX-D3[14:12] and MX-D3[10:8] Step3: Select filter fine coefficient – MX-D4[13:8] and MX-D4[5:0] Step4: Enable wind filter – MX-D3[15] The following table (Table 13.) is shown the Fc with sample rate selection. For the formula of Fc calculation is also shown as: Fc = (Fs * tan-1(a/(2-a))) / π Where: Sample rate = 8K/12K/16K (MX-D3[14:12] and [10:8]), a = 2-6 + n * 2-6 (n is MX-D4[13:8] & MX-D4[5:0]) Sample rate = 24K/32K (MX-D3[14:12] and [10:8]), a = 2-7 + n * 2-7 (n is MX-D4[13:8] & MX-D4[5:0]) Sample rate = 44.1K/48L (MX-D3[14:12] and [10:8]), a = 2-8 + n * 2-8 (n is MX-D4[13:8] & MX-D4[5:0]) Sample rate = 88.2K/96L (MX-D3[14:12] and [10:8]), a = 2-9 + n * 2-9 (n is MX-D4[13:8] & MX-D4[5:0]) Sample rate = 176.4K/192L (MX-D3[14:12] and [10:8]), a = 2-10 + n * 2-10 (n is MX-D4[13:8] & MX-D4[5:0]) PR-6E[11:6] n 000000’b, 0 000001’b, 1 000010’b, 2 000011’b, 3 000100’b, 4 000101’b, 5 000110’b, 6 000111’b, 7 001000’b, 8 001001’b, 9 001010’b, 10 001011’b, 11 001100’b, 12 001101’b, 13 001110’b, 14 001111’b, 15 010000’b, 16 010001’b, 17 010010’b, 18 010011’b, 19 010100’b, 20 010101’b, 21 010110’b, 22 010111’b, 23 011000’b, 24 011001’b, 25 011010’b, 26 011011’b, 27 Table 13. Sample Rate with filter coefficient for Wind Filter L & R Channel Sample Rate Setting 8K 16K 32K 44.1K 20.0 40.1 39.9 27.4 40.4 80.8 80.2 55.0 61.1 122.2 120.7 82.7 82.1 164.2 161.6 110.5 103.4 206.9 202.8 138.4 125.1 250.2 244.4 166.4 147.1 294.3 286.2 194.5 169.5 339.0 328.4 222.7 192.2 384.4 371.0 251.1 215.2 430.5 413.8 279.5 238.7 477.4 457.0 308.1 262.4 524.9 500.5 336.8 286.6 573.2 544.4 365.6 311.1 622.3 588.6 394.5 336.0 672.1 633.2 423.5 361.3 722.6 678.1 452.6 386.9 773.9 723.3 481.9 413.0 826.0 768.9 511.2 439.4 878.9 814.9 540.7 466.2 932.5 861.2 570.3 493.5 987.0 907.8 600.0 521.1 1042.2 954.9 629.8 549.1 1098.2 1002.2 659.7 577.5 1155.0 1050.0 689.8 606.3 1212.7 1098.1 719.9 635.5 1271.1 1146.6 750.2 665.1 1330.3 1195.5 780.6 695.2 1390.4 1244.7 811.1 42 48K 29.8 59.9 90.0 120.3 150.6 181.1 211.7 242.5 273.3 304.3 335.4 366.6 397.9 429.4 460.9 492.6 524.5 556.4 588.5 620.7 653.0 685.5 718.1 750.8 783.6 816.6 849.6 882.9 Rev. 0.91 ALC5672-VB Datasheet PR-6E[11:6] n 011100’b, 28 011101’b, 29 011110’b, 30 011111’b, 31 100000’b, 32 100001’b, 33 100010’b, 34 100011’b, 35 100100’b, 36 100101’b, 37 100110’b, 38 100111’b, 39 101000’b, 40 101001’b, 41 101010’b, 42 101011’b, 43 101100’b, 44 101101’b, 45 101110’b, 46 101111’b, 47 110000’b, 48 110001’b, 49 110010’b, 50 110011’b, 51 110100’b, 52 110101’b, 53 110110’b, 54 110111’b, 55 111000’b, 56 111001’b, 57 111010’b, 58 111011’b, 59 111100’b, 60 111101’b, 61 111110’b, 62 111111’b, 63 8K 725.6 756.4 787.6 819.3 851.3 883.7 916.6 949.8 983.3 1017.3 1051.6 1086.3 1121.4 1156.8 1192.6 1228.7 1265.1 1301.8 1338.8 1376.1 1413.7 1451.5 1489.6 1528.0 1566.5 1605.3 1644.2 1683.3 1722.5 1761.9 1801.4 1841.0 1880.7 1920.4 1960.2 2000.0 L & R Channel Sample Rate Setting 16K 32K 44.1K 1451.2 1294.3 841.8 1512.9 1344.3 872.5 1575.3 1394.7 903.4 1638.6 1445.4 934.4 1702.7 1496.5 965.5 1767.5 1548.0 996.8 1822.3 1599.9 1028.1 1899.6 1652.2 1059.6 1966.7 1704.9 1091.2 2034.7 1757.9 1122.9 2103.3 1811.4 1154.8 2172.7 1865.2 1186.7 2242.9 1919.5 1218.8 2313.7 1974.1 1251.0 2385.2 2029.1 1283.4 2457.4 2084.6 1315.8 2530.2 2140.4 1348.4 2603.6 2196.6 1381.1 2677.7 2253.3 1414.0 2752.3 2310.3 1447.0 2827.5 2367.7 1480.0 2903.1 2425.5 1513.3 2979.3 2483.8 1546.6 3056.0 2542.4 1580.1 3133.1 2601.5 1613.7 3210.6 2660.9 1647.4 3288.4 2720.8 1681.3 3366.6 2781.0 1715.3 3445.1 2841.7 1749.4 3523.9 2902.7 1783.6 3602.9 2964.2 1818.0 3682.1 3026.1 1852.5 3761.4 3088.3 1887.1 3840.8 3151.0 1921.9 3920.4 3214.1 1956.8 4000.0 3277.5 1991.8 43 48K 916.2 949.7 983.3 1017.0 1050.9 1084.9 1119.0 1153.3 1187.7 1222.2 1256.9 1291.7 1326.6 1361.7 1396.9 1432.2 1467.7 1503.3 1539.0 1574.9 1610.9 1647.1 1683.4 1719.8 1756.4 1793.1 1830.0 1867.0 1904.1 1941.4 1978.8 2016.3 2054.0 2091.9 2129.9 2168.0 Rev. 0.91 ALC5672-VB Datasheet 9.13. I2C Control Interface I2C is a 2-wire (SCL/SDA) half-duplex serial communication interface, supporting only slave mode. SCL is used for clock and SDA is for data. SCL clock supports up to 400KHz rate and SDA data is a open drain structure. The input has built-in spike filter and can remove less than 50ns spike at SCL and SDA. 9.13.1. Address Setting Table 14. (MSB) 0 0 1 Address Setting (0x38h) BIT 1 1 0 0 (LSB) R/W 9.13.2. Complete Data Transfer Data Transfer over I2C Control Interface 2 Figure 30. Data Transfer Over I C Control Interface 44 Rev. 0.91 ALC5672-VB Datasheet Write WORD Protocol Table 15. Write WORD Protocol 1 7 S Device Address 1 1 Wr A 8 1 8 1 8 1 1 Register Address A Data Byte High A Data Byte Low A P Read WORD Protocol Table 16. Read WORD Protocol 1 7 S Device Address 1 1 Wr A 8 1 Register Address A 7 S 1 Device Address Rd A S: Start Condition Slave Address: 7-bit Device Address 8 1 8 Data Byte High A Data Byte Low 1 1 NA P A: 0 for ACK, 1 for NACK Data Byte: 16-bit Mixer data : Master-to-Slave : Slave-to-Master Wr: 0 for Write Command Rd: 1 for Read Command Command Code: 8-bit Register Address 45 Rev. 0.91 ALC5672-VB Datasheet 9.14. GPIO, Interrupt and Jack Detection The ALC5672 supports six GPIOs – GPIO1/GPIO2/GPIO3/GPIO4/GPIO5/GPIO6. For GPIO function, the GPIO can be configured to input or output. For input type, the internal circuit can read pin status and report to register table. For output type, the internal circuit can drive this pin to high or low to control external device. In GPIO function, the pin polarity can be controlled by register at output type. MX-C1[0] MX-C1[3] MX-C1[1] MX-C1[4] GPIO1 High GPIO2 High EN_OBUF Low EN_OBUF Low MX-BF[8] MX-BF[7] EN_IBUF EN_IBUF MX-C1[2] MX-C1[5] MX-C1[6] MX-C1[9] MX-C1[7] MX-C1[10] GPIO3 High GPIO4 High EN_OBUF Low EN_OBUF Low MX-BF[6] MX-BF[5] EN_IBUF EN_IBUF MX-C1[8] MX-C1[11] MX-C1[12] MX-C2[0] MX-C1[13] MX-C2[1] GPIO5 High GPIO6 High EN_OBUF Low Low MX- MX-BF[9] EN_OBUF BF[10] EN_IBUF EN_IBUF MX-C1[14] MX-C2[2] Figure 31. GPIO Function Block For the jack detection function, there are four GPIOs (GPIO3/4/5/6) can be configured as jack detection pins and also have JD1 and JD2 can as jack detection pin. For GPIO jack detection pin source selection is controlled by MX-BB[15:13]. It’s JD status is sta_gpio_jd1 – MX-BF[4]. For JD1, it can detect two ports. Which JD statuses are sta_jd1_1 – MX-BF[12] & sta_jd1_2 – MX-BF[13]. For JD2, it can detect one port. Which JD status is sta_jd2 – MX-BF[14]. MX-BB[15:13] GPIO3 GPIO4 Sta_gpio_jd1 GPIO5 GPIO6 46 Rev. 0.91 ALC5672-VB Datasheet For IRQ function as shown at Figure 24, the IRQ output source can be selected from JD1 Status, JD2 Status, GPIO JD Status, InLine Command Status and MICBIAS1 Over-Current Status. When either status is trigged, the GPIO will output a flag as interrupt signal. MX-BB[15:13] MX-BD[13] MX-BD[14] GPIO3 MX-BD[15] GPIO4 Sticky Control GPIO5 GPIO6 MX-BD[7] MX-BD[8] MX-BD[9] Sticky Control Sta_jd1_1_internal MX-BD[4] MX-BD[5] MX-BD[6] Sticky Control Sta_jd1_2_internal MX-BD[1] MX-BD[2] MX-BD[3] OR Gate Sticky Control IRQ Sta_jd2_internal MX-BE[11] MX-BE[13] MX-BE[15] Sticky Control Sta_micbias1_ovcd_internal MX-BF[0] MX-BF[1] MX-BF[3] Sticky Control Sta_inline_command_internal Figure 32. IRQ Function Block 47 Rev. 0.91 ALC5672-VB Datasheet In general, the IRQ output needs to combine with JD function. When JD is trigger, IRQ will output a flag to host to notice S/W driver. The S/W driver will do some settings by system design. The behavior flow chard as following: Initial Settings (For JD and IRQ) Device Plug-In JD Triggered IRQ Flag Output to Host S/W Driver Settings Clear JD Status for Next JD Trigger The MICBIAS supports short current detection function. When MICBIAS circuit detects over-current happen, MICBIAS circuit will generate an over-current flag. The flag can generate an interrupt signal to notice host and let S/W do follow-up processes. The jack detect function can be used to turn-on or turn-off the related output ports. When jack detect pin is trigged, the selected output ports will be turn-on or turn-off. For example on HP and SPK auto switch when JD is trigger. Setting procedure: 1. Select JD status source: use sta_jd1_1 as JD source. MX-F8[2:0] = 001’b & MX-F9[11:9] = 001’b 2. Set JD status polarity for HP and SPK MX-BB[11:10] = 10’b, JD status low to trigger HPO MX-BB[9:6] = 1111’b, JD status high to trigger SPK 3. When JD status is low, HP_OUT is un-mute and SPK is mute. When JD status is low go high, HP is mute and SPK is un-mute. Note: For HP and SPK port switch function, driver need to turn-on DAC to HP path and DAC to SPK path first. 48 Rev. 0.91 ALC5672-VB Datasheet 9.15. Push Button Detection The ALC5672 has built-in push button detection circuit inside. It can supports up to three push buttons. Each button support three behaviors and shows on register (MX-DBh) – one click, double click and hold. The push button event will also cause an interrupt to IRQ output to notice external host. Ring2 U U C C D MIC D R2 R1 R3 Sleeve Sleeve Ring Tip Ring2 Push Button Resistance Up button, R2 Center button, R1 Down button, R3 Resistance Range 150 ~ 280 Ohm 0 ~ 50 Ohm 550 ~ 650 Ohm Recommend Value 220 Ohm 20 Ohm 620 Ohm Button Behavior One click Double click Hold One click Double click Hold One click Double click Hold Register Status MX-DBh[15] MX-DBh[14] MX-DBh[13] MX-DBh[12] MX-DBh[11] MX-DBh[10] MX-DBh[9] MX-DBh[8] MX-DBh[7] Push Button Detection Status: Button # Up button Center button Down button 49 Rev. 0.91 ALC5672-VB Datasheet Push Button Detection Flow Chart: Initial Settings (Power-On) Push Button Trigger (Press push button) IRQ Output (Codec issue a interrupt) Status? (Codec driver check codec register status) Configuration (Codec driver set settings by push button event) Clear Status for Next Push Button Trigger 50 Rev. 0.91 ALC5672-VB Datasheet 9.16. Power Management ALC5672 detailed Power Management control registers are supported in MX-61h, 62h, 63h, 64h, 65h and 66h. Each particular block will only be active when each bit MX-61h, 62h, 63h, 64h, 65h and 66h is set to enable. MX-61 I2S-1 Power DACL1/R1 Power I2S-2 Power DACL2/R2 Power ADCL/R Power MX-62 DAC Digital Filter ADC Digital Filter DSP Power MX-63 Analog MBias Power Analog Vref Power Headphone Amp Power LOUT Mixer Power MX-64 MIC BST1 Power MIC BST2 Power JD Power MICBIAS1 Power PLL Power MX-65 OUTMIXL Power OUTMIXR Power RECMIXL Power RECMIXR Power INLVOL Power INRVOL Power MX-66 HPMIXL Power HPMIXR Power Figure 33. Power Management 51 Rev. 0.91 ALC5672-VB Datasheet 9.17. Gen.3 Voice DSP Function The on-chip Voice Processor provides microphone beam-forming with voice tracking to allow for acoustic echo cancellation, far-field pickup, stationary and non-stationary noise suppression, and voice recognition rate enhancement. Data Input/Output Command Control Data Interface Control Interface PLL/Clock Gen Master Clock Voice Provessor Dual-Core DSP SRAM ROM Accelerators Power Management VDD / VSS Acoustic Echo Cancellation: The voice DSP suppresses echo effectively under all occasions, and the performance of which could be easily optimized for different types of acoustics set-up and applications for tablet computers. The AEC performs robustly under prolonged double talk periods and provides a face-to-face like conversation in full-duplex without any cut-off, drop-out, howling, voice level pumping, and annoying echoes. 52 Rev. 0.91 ALC5672-VB Datasheet Noise Suppression: The advanced noise suppression is specifically designed for tablets to benefit users that invoke voice communication applications on these devices. Ambient noise pickup is reduced by the advanced microphone array beam-forming which could run in 2- or 3- microphone configurations. The technology further reduces both stationary noise and non-stationary noises, and enhances user experiences in video and voice chats. Noise reduction is available on both downstream and upstream signals and is highly effectively against hums, fan-noises, tones, background babbles, and a variety of unwanted interferences. 48kHz Stereo Recording with Far-Field Pickup The vioce DSP provides specific pure 48kHz audio recording with FFP technology. It can suppress stationary noise for each channel with 24kHz bandwidth. Far-Field Pickup technology is also considered in this mode for long distance audio catch up with high signal to noise ratio. The dual feature sculpture the tablet computer to be a real stereo recording device with stationary noise suppression for long distance range. Voice Recognition Rate Enhancement The advanced voice processing could be configured to run in Voice Recognition Rate Enhancement mode which would perform beam-forming, acoustic echo cancellation and other processing in a way that helps to improve recognition rates in poor signal-to-noise conditions for the common commercial voice recognition engines. Advanced Beam-Forming The advanced beam-forming algorithm performs Voice Tracking which could follow the incidence angle of the talkers’ voice and hence reduces background noise pick-up and reverberations. It also allows for exceptional widened talking angle in handheld mode to accommodate for a wide variety of user holding positions, and avoids any annoying voice drop-outs and fade-outs. 53 Rev. 0.91 ALC5672-VB Datasheet 9.18. Multi-Jack Jack Detection Pin (JD1) The JD1 pin supports up to two ports jack detection. When supports two ports jack detection, the external pull-high voltage is 3.3V. When supports one ports jack detection, the external pull-high voltage is 1.8V. The application schematic as shows below: 3.3V 1.8V VDD 0.5 R CP1 R Vt1=1.485V VDD VDD CP2 Port-1 CP2 Vt2=1.95V Port-2 Vt2=0.9V Port-1 VDD R 0.5 R VDD CP3 Vt3=2.7V Mode-0 Mode-1 MX-94h: JD1 Control Name reserved Sel_mode_jd1 Bits 15:2 1:0 Read/Write R/W R/W Reset State Description 0’h Reserved 0’h JD1 Mode Control 00’b: Mode-0, two port jack detection 01’b: Mode-1, one port jack detection Others: Reserved MX-BFh: JD1 Status Name sta_jd1_2 (Port-2) Bits 13 Read/Write R sta_jd1_1 (Port-1) 12 R Reset State Description 0’h Status of JD1_2 Jack detection . Read: Return status of Jack Detect Select output Write: Write ‘0’ to clear stick bit 0’h Status of JD1_1 Jack detection . Read: Return status of Jack Detect Select output Write: Write ‘0’ to clear stick bit 54 Rev. 0.9 ALC5672-VB Datasheet 10. Registers List ALC5672 register map as shown as following and accessing unimplemented registers, will return a 0. 10.1. Register Map Type Reset Digital Gain/Volume Name S/W Reset HPOUT LOUT IN1 IN1 IN1 IN2 INL/INR DACL1/R1 DACL2/R2-1 DACL2/R2-2 ADC ADC ADC ADC Digital Mixer Speaker Input Mixer Output Mixer Power Management ADC ADC ADC ADC ADC DAC DAC DAC Voice DSP Voice DSP Copy Mode Table 17. Register Map Description S/W Reset & Device ID Headphone Output Volume & Mute/Un-Mute Line Output Volume & Mute/Un-Mute IN1 Control 1 IN1 Control 2 IN1 Control 3 IN2 Mode and Gain Boost Control INL/INR Volume Control DACL1/R1 Digital Volume Control DACL2/R2 Digital Volume Control DACL2/R2 Digital Mute/Un-Mute Control Stereo1 ADCL/R Digital Volume & Mute/Un-Mute Control Mono ADCL/R Digital Path Volume Control ADC Boost Gain for DMIC Stereo2 ADCL/R Digital Volume & Mute/Un-Mute Control ADC Boost Gain for DMIC Stereo2 ADC Digital Mixer Control Stereo1 ADC Digital Mixer Control Mono ADC Digital Mixer Control ADC to DAC Digital Mixer Control DAC Stereo Digital Mixer Control DAC Mono Digital Mixer Control DAC Stereo to Mono Mixer Control Voice DSP Path Control Voice DSP Volume Control ADC/DAC Data Copy Mode Control Speaker Control 1 RECMIXL Gain Control RECMIXL Gain & Selection Control RECMIXR Gain Control RECMIXR Gain & Selection Control HPOMIX Gain & Selection Control OUTMIXL Selection Control OUTMIXR Selection Control LOUTMIX Gain & Selection Control RECMIXL-1 RECMIXL-2 RECMIXR-1 RECMIXR-2 HPOMIX OUTMIXL OUTMIXR LOUTMIX ManagementI2S & DAC & ADC Power Control 1 ManagementDigital Filter & DSP & SPK Power Control 2 ManagementVREF & MBias & LOUTMIX & HP Power Control 3 55 Register Address MX-00h MX-02h MX-03h MX-0Ah MX-0Bh MX-0Ch MX-0Eh MX-0Fh MX-19h MX-1Ah MX-1Bh Reset State 0x0004’h 0x8888’h 0x8888’h 0x0001’h 0x0827’h 0x0000’h 0x0000’h 0x0808’h 0xAFAF’h 0xAFAF’h 0x0000’h MX-1Ch 0x2F2F’h MX-1Dh MX-1Eh 0x2F2F’h 0x0000’h MX-1Fh 0x2F2F’h MX-20h MX-26h MX-27h MX-28h MX-29h MX-2Ah MX-2Bh MX-2Ch MX-2Dh MX-2Eh MX-2Fh MX-31h MX-3Bh MX-3Ch MX-3Dh MX-3Eh MX-45h MX-4Fh MX-52h MX-53h 0x0000’h 0x7860’h 0x7860’h 0x7871’h 0x8080’h 0x5656’h 0x5454’h 0xAAA0’h 0x0000’h 0x2F2F’h 0x1002’h 0x5F00’h 0x0000’h 0x007F’h 0x0000’h 0x007F’h 0x600F’h 0x0073’h 0x00D3’h 0xF000’h MX-61h 0x0000’h MX-62h 0x0000’h MX-63h 0x00C0’h Rev. 0.91 ALC5672-VB Datasheet Type PR Register Digital Interface Name Management4 Management5 Management6 PR Index PR Data I2S1 Port Ctrl I2S2 Port Ctrl ADC/DAC Clock ADC/DAC HPF Digital MIC TDM Global Clock Clock Clock PLL PLL ASRC ASRC ASRC ASRC ASRC HP Amp HP MICBIAS JD1 MICBIAS JD1 ADC EQ ADC EQ DAC EQ DAC EQ EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ Description Register Address Reset State MICBST & MICBIAS & PLL & JD Power Control MX-64h 0x0000’h OUTMIX & RECMIX Power Control MX-65h 0x0000’h MX-66h 0x0000’h MX-6Ah Mx-6Ch MX-70h MX-71h 0x0000’h 0x0000’h 0x8000’h 0x8000’h ADC/DAC Clock Control MX-73h 0x1114’h ADC/DAC HPF Control MX-74h 0x0E00’h Digital Microphone Control Digital Microphone Control TDM Interface Control TDM Interface Control TDM Interface Control DSP Clock Control Global Clock Control PLL Control 1 PLL Control 2 ASRC Control 1 ASRC Control 2 ASRC Control 3 ASRC Control 4 ASRC Control 5 HP Output De-Pop Control 1 HP Output De-Pop Control 2 MICBIAS Control JD1 Control ADC EQ Control 1 ADC EQ Control 2 DAC EQ Control 1 DAC EQ Control 2 DAC_L EQ (LPF: a1) DAC_L EQ (LPF: H0) DAC_R EQ (LPF: a1) DAC_R EQ (LPF: H0) DAC_L EQ (BPF2: a1) DAC_L EQ (BPF2: a2) DAC_L EQ (BPF2: H0) DAC_R EQ (BPF2: a1) DAC_R EQ (BPF2: a2) DAC_R EQ (BPF2: H0) DAC_L EQ (BPF3: a1) DAC_L EQ (BPF3: a2) DAC_L EQ (BPF3: H0) DAC_R EQ (BPF3: a1) DAC_R EQ (BPF3: a2) MX-75h MX-76h MX-77h MX-78h MX-79h MX-7Fh MX-80h MX-81h MX-82h MX-83h MX-84h MX-85h MX-8Ah MX-8Ch MX-8Eh MX-8Fh MX-93h MX-94h MX-AE MX-AF MX-B0h MX-B1h PR-A4h PR-A5h PR-A6h PR-A7h PR-AEh PR-AFh PR-B0h PR-B1h PR-B2h PR-B3h PR-B4h PR-B5h PR-B6h PR-B7h PR-B8h 0x1505’h 0x0015’h 0x0C00’h 0x4000’h 0x0123’h 0x1100’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0007’h 0x0004’h 0x1100’h 0x0000’h 0x0000h 0x6000’h 0x0000’h 0x6000’h 0x0000’h 0x1C10’h 0x01F4’h 0x1C10’h 0x01F4’h 0xC882’h 0x1C10’h 0x01F4’h 0xC882’h 0x1C10’h 0x01F4’h 0xE904’h 0x1C10’h 0x01F4’h 0xE904’h 0x1C10’h MICBIAS & OUTVOL & HPOVOL & INVOL Power Control PR Register Index PR Register Data I2S-1 Interface Control I2S-2 Interface Control 56 Rev. 0.91 ALC5672-VB Datasheet Type Name EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter Description DAC_R EQ (BPF3: H0) DAC_L EQ (BPF4: a1) DAC_L EQ (BPF4: a2) DAC_L EQ (BPF4: H0) DAC_R EQ (BPF4: a1) DAC_R EQ (BPF4: a2) DAC_R EQ (BPF4: H0) DAC_L EQ (HPF1: a1) DAC_L EQ (HPF1: H0) DAC_R EQ (HPF1: a1) DAC_R EQ (HPF1: H0) DAC_L EQ (HPF2: a1) DAC_L EQ (HPF2: a2) DAC_L EQ (HPF2: H0) DAC_R EQ (HPF2: a1) DAC_R EQ (HPF2: a2) DAC_R EQ (HPF2: H0) DAC_L EQ Pre-Volume Control DAC_R EQ Pre-Volume Control DAC_L EQ Post-Volume Control DAC_R EQ Post-Volume Control ADC EQ (LPF: a1) ADC EQ (LPF: H0) ADC EQ (BPF1: a1) ADC EQ (BPF1: a2) ADC EQ (BPF1: H0) ADC EQ (BPF2: a1) ADC EQ (BPF2: a2) ADC EQ (BPF2: H0) ADC EQ (BPF3: a1) ADC EQ (BPF3: a2) ADC EQ (BPF3: H0) ADC EQ (BPF4: a1) ADC EQ (BPF4: a2) ADC EQ (BPF4: H0) ADC EQ (HPF1: a1) ADC EQ (HPF1: H0) ADC EQ Pre-Volume Control ADC EQ Post-Volume Control DAC_L Biquad EQ (BPF1: h0-1) DAC_L Biquad EQ (BPF1: h0-2) DAC_L Biquad EQ (BPF1: b1-1) DAC_L Biquad EQ (BPF1: b1-2) DAC_L Biquad EQ (BPF1: b2-1) DAC_L Biquad EQ (BPF1: b2-2) DAC_L Biquad EQ (BPF1: a1-1) DAC_L Biquad EQ (BPF1: a1-2) DAC_L Biquad EQ (BPF1: a2-1) DAC_L Biquad EQ (BPF1: a2-2) DAC_R Biquad EQ (BPF1: h0-1) DAC_R Biquad EQ (BPF1: h0-2) 57 Register Address PR-B9h PR-BAh PR-BBh PR-BCh PR-BDh PR-BEh PR-BFh PR-C0h PR-C1h PR-C2h PR-C3h PR-C4h PR-C5h PR-C6h PR-C7h PR-C8h PR-C9h PR-CAh PR-CBh PR-CCh PR-CDh PR-CEh PR-CFh PR-D0h PR-D1h PR-D2h PR-D3h PR-D4h PR-D5h PR-D6h PR-D7h PR-D8h PR-D9h PR-DAh PR-DBh PR-DCh PR-DDh PR-E1h PR-E2h PR-E5h PR-E6h PR-E7h PR-E8h PR-E9h PR-EAh PR-EBh PR-ECh PR-EDh PR-EEh PR-EFh PR-F0h Reset State 0x01F4’h 0xE904’h 0x1C10’h 0x01F4’h 0xE904’h 0x1C10’h 0x01F4’h 0x1C10’h 0x01F4’h 0x1C10’h 0x01F4’h 0x2000’h 0x0000’h 0x1FF1’h 0x2000’h 0x0000’h 0x1FF1’h 0x0800’h 0x0800’h 0x0800’h 0x0800’h 0x1C10’h 0x01F4’h 0xE904’h 0x1C10’h 0x01F4’h 0xE904’h 0x1C10’h 0x01F4’h 0xE904’h 0x1C10’h 0x01F4’h 0xE904’h 0x1C10’h 0x01F4’h 0x1C10’h 0x01F4’h 0x0800’h 0x0800’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h Rev. 0.91 ALC5672-VB Datasheet Type Name EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter EQ-Parameter DRC/AGC DRC/AGC DRC/AGC DRC/AGC DRC/AGC DRC/AGC DRC/AGC JD Jack Detection JD JD IRQ IRQ IRQ IRQ GPIO GPIO GPIO GPIO SounzRealTM BassBack Post-Processin TruTreble g TruTreble Stereo1 Stereo1 Mono Wind Filter Mono Stereo2 Stereo2 Description DAC_R Biquad EQ (BPF1: b1-1) DAC_R Biquad EQ (BPF1: b1-2) DAC_R Biquad EQ (BPF1: b2-1) DAC_R Biquad EQ (BPF1: b2-2) DAC_R Biquad EQ (BPF1: a1-1) DAC_R Biquad EQ (BPF1: a1-2) DAC_R Biquad EQ (BPF1: a2-1) DAC_R Biquad EQ (BPF1: a2-2) DRC/AGC Control 1 DRC/AGC Control 2 DRC/AGC Control 3 DRC/AGC Control 4 DRC/AGC Control 5 DRC/AGC Control 6 Jack Detection Control Jack Detection Control Jack Detection Control IRQ Control 1 IRQ Control 2 IRQ Control 3 GPIO Control 1 GPIO Control 2 GPIO Control 3 BassBack Control TruTreble Control 1 TruTreble Control 2 Stereo1 ADC Wind Filter Control 1 Stereo1 ADC Wind Filter Control 2 Mono ADC Wind Filter Control 1 Mono ADC Wind Filter Control 2 Stereo2 ADC Wind Filter Control 1 Stereo2 ADC Wind Filter Control 2 Soft Volume and ZCD Control 1 SVOL & ZCD SVOL & ZCD Soft Volume and ZCD Control 2 Inline Command Control 1 InLine Inline Command Control 2 Command Inline Command Control 3 Voice DSP Control 1 Voice DSP Control 2 Voice DSP Control 3 Voice DSP Voice DSP Control 4 Voice DSP Control 5 Voice DSP Control 6 General Control 1 General Control 2 General Control General Control 3 ADC/DAC RESET Control Vendor ID ID Vendor ID 58 Register Address PR-F1h PR-F2h PR-F3h PR-F4h PR-F5h PR-F6h PR-F7h PR-F8h MX-B2h MX-B3h MX-B4h MX-B5h MX-B6h MX-B7h MX-BBh MX-F8h MX-F9h MX-BDh MX-BEh MX-BFh MX-C0h MX-C2h MX-C3h MX-CFh MX-D0h MX-D1h MX-D3h MX-D4h MX-ECh MX-EDh MX-EEh MX-EFh MX-D9h MX-DAh MX-DBh MX-DCh MX-DDh MX-E0h MX-E1h MX-E2h MX-E3h MX-E4h MX-E5h MX-FAh MX-FBh MX-FCh PR-3D MX-FEh Reset State 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x001F’h 0x2206’h 0x1F00’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0013’h 0x0680’h 0x1C17’h 0xAA20’h 0x0000’h 0xAA20’h 0x0000’h 0xAA20’h 0x0000’h 0x0809’h 0x0000’h 0x0001’h 0x0049’h 0x0003’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x0000’h 0x8010’h 0x0033’h 0x0080’h 0x2808’h 0x10EC’h Rev. 0.91 ALC5672-VB Datasheet 10.2. MX-00h: S/W Reset & Device ID Default: 0004’h Table 18. MX-00h: S/W Reset Port Name Bits Read/Write Reset State Description 15:3 R 0’h Reserved Reserved 2:1 R 2’h Device_id ALC5672 0 R 0’h Reserved Reserved Note: Writes to this register will reset all registers to their default values. 10.3. MX-02h: Headphone Output Control Default: 8888’h Name mu_hpo_l Bits 15 Table 19. MX-02h: Headphone Output Control Read/Write Reset State Description R/W 1’h Mute Control for Left Headphone Output Port (HPOL) 0’b: Un-Mute 1’b: Mute Reserved 14 R 0’h Reserved vol_hpol 13:8 R/W 8’h Left Headphone Channel Volume Control (HPOVOLL)  00’h: +12dB … 08’h: 0dB … 27’h: -46.5dB, with 1.5dB/step mu_hpo_r 7 R/W 1’h Mute Control Right Headphone Output Port (HPOR) 0’b: Un-Mute 1’b: Mute Reserved 6 R 0’h Reserved Vol_hpor 5:0 R/W 8’h Right Headphone Channel Volume Control (HPOVOLR) 00’h: +12dB … 08’h: 0dB … 27’h: -46.5dB, with 1.5dB/step 59 Rev. 0.91 ALC5672-VB Datasheet Volume Table DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain 0 0 12 16 10 -12 32 20 -36 1 1 10.5 17 11 -13.5 33 21 -37.5 2 2 9 18 12 -15 34 22 -39 3 3 7.5 19 13 -16.5 35 23 -40.5 4 4 6 20 14 -18 36 24 -42 5 5 4.5 21 15 -19.5 37 25 -43.5 6 6 3 22 16 -21 38 26 -45 7 7 1.5 23 17 -22.5 39 27 -46.5 8 8 0 24 18 -24 9 9 -1.5 25 19 -25.5 10 A -3 26 1A -27 11 B -4.5 27 1B -28.5 12 C -6 28 1C -30 13 D -7.5 29 1D -31.5 14 E -9 30 1E -33 15 F -10.5 31 1F -34.5 10.4. MX-03h: LINE Output Control Default: 8888’h Name Mu_lout_l Bits 15 En_dfo1 14 Vol_outl 13:8 Table 20. MX-03h: LINE Output Control Read/Write Reset State Description R/W 1’h Mute Control for Left Line Output Port(LOUTL) 0’b: Un-Mute 1’b: Mute R/W 0’h LOUT Differential Mode Control 0’b: Disable (Single-ended mode) 1’b: Enable (Differential mode) R/W 08’h Left Output Volume Control (OUTVOLL)  00’h: +12dB … 08’h: 0dB … Mu_lout_r 7 R/W 1’h Reserved 6 R 0’h 27’h: -46.5dB, with 1.5dB/step Mute Control for Right Line Output Port (LOUTR) 0’b: Un-Mute 1’b: Mute Reserved 60 Rev. 0.91 ALC5672-VB Datasheet Name Vol_outr Bits 5:0 Read/Write R/W Reset State Description 08’h Right Output Volume Control  00’h: +12dB … 08’h: 0dB … 27’h: -46.5dB, with 1.5dB/step Volume Table DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain 0 0 12 16 10 -12 32 20 -36 1 1 10.5 17 11 -13.5 33 21 -37.5 2 2 9 18 12 -15 34 22 -39 3 3 7.5 19 13 -16.5 35 23 -40.5 4 4 6 20 14 -18 36 24 -42 5 5 4.5 21 15 -19.5 37 25 -43.5 6 6 3 22 16 -21 38 26 -45 7 7 1.5 23 17 -22.5 39 27 -46.5 8 8 0 24 18 -24 9 9 -1.5 25 19 -25.5 10 A -3 26 1A -27 11 B -4.5 27 1B -28.5 12 C -6 28 1C -30 13 D -7.5 29 1D -31.5 14 E -9 30 1E -33 15 F -10.5 31 1F -34.5 61 Rev. 0.91 ALC5672-VB Datasheet 10.5. MX-0Ah: IN1 Port Control - 1 Default: 0001’h Name Sel_bst1 Bits 15:12 reserved 11:3 En_bst1 2 Table 21. MX-0Dh: IN1 Input Control - 1 Read/Write Reset State Description R/W 0’h IN1 Boost Control (BST1) 0000’b: Bypass 0001’b: +20dB 0010’b: +24dB 0011’b: +30dB 0100’b: +35dB 0101’b: +40dB 0110’b: +44dB 0111’b: +50dB 1000’b: +52dB Others : Reserved R/W 0’h Reserved R/W 0’h IN1 Port Enable Control 0’b: Disable 1’b: Enable reserved 1:0 R/W 1’h Reserved 10.6. MX-0Bh: IN1 Port Control - 2 Default: 0827’h Name Reserved Bits 15:13 Table 22. MX-0Bh: IN1 Input Control - 2 Read/Write Reset State Description R 0’h Reserved Manual_tri_in1 12 R/W 0’h Capless_gat_en 11 R/W 1’h 10:8 R/W 0’h Reserved 7 R/W 1’h IN1 Port Mode Control reserved Reg_mode Manual Trigger For IN1 Port 0’b: Low trigger 1’b: High trigger Capless Power Gating with IN1 Control 0’b: Register control 1’b: Auto mode 0’b: Auto mode 1’b: Manual mode reserved 6:0 R/W 27’h Reserved 62 Rev. 0.91 ALC5672-VB Datasheet 10.7. MX-0Ch: IN1 Port Control - 3 Default: 0000’h Name Reserved Bits 15:3 In1_result 2:0 Table 23. MX-0Ch: IN1 Input Control - 3 Read/Write Reset State Description R 0’h Reserved R 0’h IN1 Port Final Status 001’b: Type1 010’b: Type2 100’b: Type3 10.8. MX-0Eh: IN2 Input Control Default: 0000’h Name Sel_bst2 Bits 15:12 Reserved 11:8 En_in2_df 7 Table 24. MX-0Eh: IN2 Input Control Read/Write Reset State Description R/W 0’h IN2 Boost Control (BST2) 0000’b: Bypass 0001’b: +20dB 0010’b: +24dB 0011’b: +30dB 0100’b: +35dB 0101’b: +40dB 0110’b: +44dB 0111’b: +50dB 1000’b: +52dB Others : Reserved R/W 0’h Reserved R/W 0’h IN2 Input Mode Control 0’b: Single Ended Mode 1’b: Differential Mode Reserved 6:0 R 0’h Reserved 63 Rev. 0.91 ALC5672-VB Datasheet 10.9. MX-0Fh: INL & INR Volume Control Default: 0808’h Name reserved Bits 15:13 Vol_inl 12:8 Table 25. MX-0Fh: INL & INR Volume Control Read/Write Reset State Description R 0’h Reserved R/W 8’h INL Channel Volume Control  00’h: +12dB … 08’h: 0dB … Reserved 7:5 R 0’h Vol_inr 4:0 R/W 8’h 1F’h: -34.5dB, with 1.5dB/step Reserved INR Channel Volume Control  00’h: +12dB … 08’h: 0dB … 1F’h: -34.5dB, with 1.5dB/step Volume Table: DEC HEX Boost Gain DEC HEX Boost Gain 0 0 12 16 10 -12 1 1 10.5 17 11 -13.5 2 2 9 18 12 -15 3 3 7.5 19 13 -16.5 4 4 6 20 14 -18 5 5 4.5 21 15 -19.5 6 6 3 22 16 -21 7 7 1.5 23 17 -22.5 8 8 0 24 18 -24 9 9 -1.5 25 19 -25.5 10 A -3 26 1A -27 11 B -4.5 27 1B -28.5 12 C -6 28 1C -30 13 D -7.5 29 1D -31.5 14 E -9 30 1E -33 15 F -10.5 31 1F -34.5 64 Rev. 0.91 ALC5672-VB Datasheet 10.10. MX-19h: DACL1/R1 Digital Volume Default: AFAF’h Name vol_dac1_l Bits 15:8 Table 26. MX-19h: DACL1/R1 Digital Volume Read/Write Reset State Description R/W AF’h DAC1 Left Channel Digital Volume 00’h: -65.625dB … AF’h: 0dB, with 0.375dB/Step vol_dac1_r 7:0 R/W AF’h DAC1 Right Channel Digital Volume 00’h: -65.625dB … AF’h: 0dB, with 0.375dB/Step 10.11. MX-1Ah: DACL2/R2 Digital Volume Default: AFAF’h Name vol_dac2_l Bits 15:8 Table 27. MX-1Ah: DACL2/R2 Digital Volume Read/Write Reset State Description R/W AF’h DAC2 Left Channel Digital Volume 00’h: -65.625dB … AF’h: 0dB, with 0.375dB/Step vol_dac2_r 7:0 R/W AF’h DAC2 Right Channel Digital Volume 00’h: -65.625dB … AF’h: 0dB, with 0.375dB/Step Volume Table: DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain 0 0 -65.625 53 35 -45.75 106 6A -25.875 159 9F -6 212 D4 1 1 -65.25 54 36 -45.375 107 6B -25.5 160 A0 -5.625 213 D5 2 2 -64.875 55 37 -45 108 6C -25.125 161 A1 -5.25 214 D6 3 3 -64.5 56 38 -44.625 109 6D -24.75 162 A2 -4.875 215 D7 4 4 -64.125 57 39 -44.25 110 6E -24.375 163 A3 -4.5 216 D8 5 5 -63.75 58 3A -43.875 111 6F -24 164 A4 -4.125 217 D9 6 6 -63.375 59 3B -43.5 112 70 -23.625 165 A5 -3.75 218 DA 7 7 -63 60 3C -43.125 113 71 -23.25 166 A6 -3.375 219 DB 65 Rev. 0.91 ALC5672-VB Datasheet 8 8 -62.625 61 3D -42.75 114 72 -22.875 167 A7 -3 220 DC 9 9 -62.25 62 3E -42.375 115 73 -22.5 168 A8 -2.625 221 DD 10 A -61.875 63 3F -42 116 74 -22.125 169 A9 -2.25 222 DE 11 B -61.5 64 40 -41.625 117 75 -21.75 170 AA -1.875 223 DF 12 C -61.125 65 41 -41.25 118 76 -21.375 171 AB -1.5 224 E0 13 D -60.75 66 42 -40.875 119 77 -21 172 AC -1.125 225 E1 14 E -60.375 67 43 -40.5 120 78 -20.625 173 AD -0.75 226 E2 15 F -60 68 44 -40.125 121 79 -20.25 174 AE -0.375 227 E3 16 10 -59.625 69 45 -39.75 122 7A -19.875 175 AF 0 228 E4 17 11 -59.25 70 46 -39.375 123 7B -19.5 176 B0 229 E5 18 12 -58.875 71 47 -39 124 7C -19.125 177 B1 230 E6 19 13 -58.5 72 48 -38.625 125 7D -18.75 178 B2 231 E7 20 14 -58.125 73 49 -38.25 126 7E -18.375 179 B3 232 E8 21 15 -57.75 74 4A -37.875 127 7F -18 180 B4 233 E9 22 16 -57.375 75 4B -37.5 128 80 -17.625 181 B5 234 EA 23 17 -57 76 4C -37.125 129 81 -17.25 182 B6 235 EB 24 18 -56.625 77 4D -36.75 130 82 -16.875 183 B7 236 EC 25 19 -56.25 78 4E -36.375 131 83 -16.5 184 B8 237 ED 26 1A -55.875 79 4F -36 132 84 -16.125 185 B9 238 EE 27 1B -55.5 80 50 -35.625 133 85 -15.75 186 BA 239 EF 28 1C -55.125 81 51 -35.25 134 86 -15.375 187 BB 240 F0 29 1D -54.75 82 52 -34.875 135 87 -15 188 BC 241 F1 30 1E -54.375 83 53 -34.5 136 88 -14.625 189 BD 242 F2 31 1F -54 84 54 -34.125 137 89 -14.25 190 BE 243 F3 32 20 -53.625 85 55 -33.75 138 8A -13.875 191 BF 244 F4 33 21 -53.25 86 56 -33.375 139 8B -13.5 192 C0 245 F5 34 22 -52.875 87 57 -33 140 8C -13.125 193 C1 246 F6 35 23 -52.5 88 58 -32.625 141 8D -12.75 194 C2 247 F7 36 24 -52.125 89 59 -32.25 142 8E -12.375 195 C3 248 F8 37 25 -51.75 90 5A -31.875 143 8F -12 196 C4 249 F9 38 26 -51.375 91 5B -31.5 144 90 -11.625 197 C5 250 FA 39 27 -51 92 5C -31.125 145 91 -11.25 198 C6 251 FB 40 28 -50.625 93 5D -30.75 146 92 -10.875 199 C7 252 FC 41 29 -50.25 94 5E -30.375 147 93 -10.5 200 C8 253 FD 42 2A -49.875 95 5F -30 148 94 -10.125 201 C9 254 FE 43 2B -49.5 96 60 -29.625 149 95 -9.75 202 CA 255 FF 66 Rev. 0.91 ALC5672-VB Datasheet 44 2C -49.125 97 61 -29.25 150 96 -9.375 203 CB 45 2D -48.75 98 62 -28.875 151 97 -9 204 CC 46 2E -48.375 99 63 -28.5 152 98 -8.625 205 CD 47 2F -48 100 64 -28.125 153 99 -8.25 206 CE 48 30 -47.625 101 65 -27.75 154 9A -7.875 207 CF 49 31 -47.25 102 66 -27.375 155 9B -7.5 208 D0 50 32 -46.875 103 67 -27 156 9C -7.125 209 D1 51 33 -46.5 104 68 -26.625 157 9D -6.75 210 D2 52 34 -46.125 105 69 -26.25 158 9E -6.375 211 D3 10.12. MX-1Bh: DACL2/R2 Mute/Un-Mute Control Default: 0000’h Name reserved Mu_dac2_l Bits 15:14 13 Table 28. MX-1Bh: DACL2/R2 Mute/Un-Mute Control Read/Write Reset State Description R 0’h Reserved R/W 0’h Mute Control for Left DAC2 Volume 0’b: Un-Mute 1’b: Mute Mu_dac2_r 12 R/W 0’h Mute Control for Right DAC2 Volume 0’b: Un-Mute 1’b: Mute reserved 11:7 R 0’h Reserved Sel_dacl2 6:4 R/W 1’h Select DACL2 Data Source 000’b: IF1_DAC2_L 001’b: IF2_DAC_L 010’b: Reserved 011’b: TxDC_DAC_L Others: Reserved reserved 3 R 0’h Reserved 67 Rev. 0.91 ALC5672-VB Datasheet Sel_dacr2 2:0 R/W 1’h Select DACR2 Data Source 000’b: IF1_DAC2_R 001’b: IF2_DAC_R 010’b: Reserved 011’b: TxDC_DAC_R 100’b: TxDP_DAC_L Others: Reserved 10.13. MX-1Ch: Stereo1 ADC Digital Volume Control Default: 2F2F’h Name Mu_adc_vol_l Table 29. MX-1Ch: Stereo1 ADC Digital Volume Control Bits Read/Write Reset State Description 15 R/W 0’h Mute Control for Stereo1 ADC Left Volume Channel 0’b: Un-Mute 1’b: Mute Ad_gain_l 14:8 R/W 2F’h Stereo1 ADC Left Channel Volume Control 00’h: -17.625dB … 2F’h: 0dB … 7F’h: +30dB, with 0.375dB/Step Mu_adc_vol_r 7 R/W 0’h Mute Control for Stereo1 ADC Right Volume Channel 0’b: Un-Mute 1’b: Mute Ad_gain_r 6:0 R/W 2F’h Stereo1 ADC Right Channel Volume Control 00’h: -17.625dB … 2F’h: 0dB … 7F’h: +30dB, with 0.375dB/Step 68 Rev. 0.91 ALC5672-VB Datasheet 10.14. MX-1Dh: Mono ADC Digital Volume Control Default: 2F2F’h Name reserved Bits 15 Mono_ad_gain_l 14:8 Table 30. MX-1Dh: Mono ADC Digital Volume Control Read/Write Reset State Description R 0’h Reserved R/W 2F’h Mono ADC Left Channel Volume Control  00’h: -17.625dB … 2F’h: 0dB … 7F’h: +30dB, with 0.375dB/Step reserved Mono_ad_gain_r 7 R 0’h Reserved 6:0 R/W 2F’h Mono ADC Right Channel Volume Control  00’h: -17.625dB … 2F’h: 0dB … 7F’h: +30dB, with 0.375dB/Step Volume Table: DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain -17.625 -7.875 1.875 11.625 0 0 26 1A 52 34 78 4E -17.25 -7.5 2.25 12 1 1 27 1B 53 35 79 4F 2 2 -16.875 28 1C -7.125 54 36 2.625 80 50 12.375 -16.5 -6.75 3 12.75 3 3 29 1D 55 37 81 51 4 4 -16.125 30 1E -6.375 56 38 3.375 82 52 13.125 -15.75 -6 3.75 13.5 5 5 31 1F 57 39 83 53 -15.375 -5.625 4.125 13.875 6 6 32 20 58 3A 84 54 -15 -5.25 4.5 14.25 7 7 33 21 59 3B 85 55 -14.625 -4.875 4.875 14.625 8 8 34 22 60 3C 86 56 9 9 -14.25 35 23 -4.5 61 3D 5.25 87 57 15 -13.875 -4.125 5.625 15.375 10 A 36 24 62 3E 88 58 -13.5 -3.75 6 15.75 11 B 37 25 63 3F 89 59 -13.125 -3.375 6.375 16.125 12 C 38 26 64 40 90 5A -12.75 -3 6.75 16.5 13 D 39 27 65 41 91 5B 14 E -12.375 40 28 -2.625 66 42 7.125 92 5C 16.875 -12 -2.25 7.5 17.25 15 F 41 29 67 43 93 5D 16 10 -11.625 42 2A -1.875 68 44 7.875 94 5E 17.625 -11.25 -1.5 8.25 18 17 11 43 2B 69 45 95 5F -10.875 -1.125 8.625 18.375 18 12 44 2C 70 46 96 60 -10.5 -0.75 9 18.75 19 13 45 2D 71 47 97 61 -10.125 -0.375 9.375 19.125 20 14 46 2E 72 48 98 62 21 15 -9.75 47 2F 0 73 49 9.75 99 63 19.5 69 DEC HEX Boost Gain 21.375 104 68 21.75 105 69 106 6A 22.125 22.5 107 6B 108 6C 22.875 23.25 109 6D 23.625 110 6E 24 111 6F 24.375 112 70 113 71 24.75 25.125 114 72 25.5 115 73 25.875 116 74 26.25 117 75 118 76 26.625 27 119 77 120 78 27.375 27.75 121 79 28.125 122 7A 28.5 123 7B 28.875 124 7C 125 7D 29.25 Rev. 0.91 ALC5672-VB Datasheet 22 23 24 25 16 17 18 19 -9.375 -9 -8.625 -8.25 48 49 50 51 30 31 32 33 0.375 0.75 1.125 1.5 74 75 76 77 4A 4B 4C 4D 10.125 10.5 10.875 11.25 100 101 102 103 64 65 66 67 19.875 20.25 20.625 21 126 127 7E 7F 29.625 30 10.15. MX-1Eh: ADC Digital Boost Gain Control Default: 0000’h Name Stereo1_ad_boost_ Bits 15:14 Table 31. MX-1Eh: ADC Digital Boost Gain Control Read/Write Reset State Description R/W 0’h Stereo1 ADC Left Channel Digital Boost Gain gain_l 00’b: 0dB 01’b: 12dB 10’b: 24dB 11’b: 36dB Stereo1_ad_boost_ 13:12 R/W 0’h gain_r Stereo1 ADC Right Channel Digital Boost Gain 00’b: 0dB 01’b: 12dB 10’b: 24dB 11’b: 36dB Stereo1_ad_comp_ 11:10 R/W 0’h gain Stereo1 ADC Compensation Gain 00’b: 0dB 01’b: 1dB 10’b: 2dB 11’b: 3dB Stereo2_ad_boost_ 9:8 R/W 0’h gain_l Stereo2 ADC Left Channel Digital Boost Gain 00’b: 0dB 01’b: 12dB 10’b: 24dB 11’b: 36dB Stereo2_ad_boost_ gain_r 7:6 R/W 0’h Stereo2 ADC Right Channel Digital Boost Gain 00’b: 0dB 01’b: 12dB 10’b: 24dB 11’b: 36dB 70 Rev. 0.91 ALC5672-VB Datasheet Stereo2_ad_comp_ 5:4 R/W 0’h gain Stereo2 ADC Compensation Gain 00’b: 0dB 01’b: 1dB 10’b: 2dB 11’b: 3dB reserved 3:0 R/W 0’h Reserved 10.16. MX-1Fh: Stereo2 ADC Digital Volume Control Default: 2F2F’h Name Mu_adc2_vol_l Bits 15 Table 32. MX-1Fh: Stereo2 ADC Digital Volume Control Read/Write Reset State Description R/W 0’h Mute Control for Stereo2 ADC Left Volume Channel 0’b: Un-Mute 1’b: Mute Ad2_gain_l 14:8 R/W 2F’h Stereo2 ADC Left Channel Volume Control 00’h: -17.625dB … 2F’h: 0dB … 7F’h: +30dB, with 0.375dB/Step Mu_adc2_vol_r 7 R/W 0’h Mute Control for Stereo2 ADC Right Volume Channel 0’b: Un-Mute 1’b: Mute Ad2_gain_r 6:0 R/W 2F’h Stereo2 ADC Right Channel Volume Control 00’h: -17.625dB … 2F’h: 0dB … 7F’h: +30dB, with 0.375dB/Step 71 Rev. 0.91 ALC5672-VB Datasheet 10.17. MX-20h: Mono ADC Digital Boost Gain Control Default: 0000’h Table 33. MX-20h: Mono ADC Digital Boost Gain Control Name Bits Read/Write Reset State Description mono_ad_boost_ga 15:14 R/W 0’h Mono ADC Left Channel Digital Boost Gain in_l 00’b: 0dB 01’b: 12dB 10’b: 24dB 11’b: 36dB mono_ad_boost_ga 13:12 R/W 0’h in_r Mono ADC Right Channel Digital Boost Gain 00’b: 0dB 01’b: 12dB 10’b: 24dB 11’b: 36dB mono_ad_comp_ga 11:10 R/W 0’h in Mono ADC Compensation Gain 00’b: 0dB 01’b: 1dB 10’b: 2dB 11’b: 3dB Reserved 9:0 R 0’h Reserved 10.18. MX-26h: Stereo2 ADC Digital Mixer Control Default: 7860’h Name Sel_stereo2_lr_mix Bits 15 mu_stereo2_adcl1 14 mu_stereo2_adcl2 13 sel_stereo2_adc1 12 Table 34. MX-26h: Stereo2 ADC Digital Mixer Control Read/Write Reset State Description R/W 0’h Mixing Control for Stereo2 ADC Left channel 0’b: L 1’b: L+R R/W 1’h Mute Source1 to Stereo2 ADC Left Channel 0’b:UnMute 1’b:Mute R/W 1’h Mute Source2 to Stereo2 ADC Left Channel 0’b:UnMute 1’b:Mute R/W 1’h Select Stereo2 ADC L/R Channel Source 1 0’b: DAC_MIXL / DAC_MIXR 1’b: ADC1 72 Rev. 0.91 ALC5672-VB Datasheet sel_stereo2_adc2 11 R/W 1’h Reserved Sel_stereo2_dmic 10 9:8 R/W R/W 0’h 0’h reserved mu_stereo2_adcr1 7 6 R R/W 0’h 1’h mu_stereo2_adcr2 5 R/W 1’h 4:0 R 0’h reserved Select Stereo2 ADC L/R Channel Source 2 0’b: DAC_MIXL / DAC_MIXR 1’b: DMIC1/DMIC2/DMIC3 Reserved Select Stereo2 DMIC Source 00’b: DMIC1 01’b: DMIC2 10’b: DMIC3 11’b: Reserved Reserved Mute Source1 to Stereo2 ADC Right Channel 0’b:UnMute 1’b:Mute Mute Source2 to Stereo2 ADC Right Channel 0’b:UnMute 1’b:Mute reserved 10.19. MX-27h: Stereo1 ADC Digital Mixer Control Default: 7860’h Name reserved mu_stereo1_adcl1 Bits 15 14 mu_stereo1_adcl2 13 sel_stereo1_adc1 12 sel_stereo1_adc2 11 reserved Sel_stereo1_dmic 10 9:8 reserved mu_stereo1_adcr1 7 6 mu_stereo1_adcr2 5 Table 35. MX-27h: Stereo1 ADC Digital Mixer Control Read/Write Reset State Description R 0’h Reserved R/W 1’h Mute Source 1 to Stereo1 ADC Left Channel 0’b:UnMute 1’b:Mute R/W 1’h Mute Source 2 to Stereo1 ADC Left Channel 0’b:UnMute 1’b:Mute R/W 1’h Select Stereo1 ADC L/R Channel Source 1 0’b: DAC_MIXL / DAC_MIXR 1’b: ADC1 R/W 1’h Select Stereo1 ADC L/R Channel Source 2 0’b: DAC_MIXL / DAC_MIXR 1’b: DMIC1/DMIC2/DMIC3 R/W 0’h Reserved R/W 0’h Select Stereo1 DMIC Source 00’b: DMIC1 01’b: DMIC2 10’b: DMIC3 11’b: Reserved R 0’h Reserved R/W 1’h Mute Source 1 to Stereo1 ADC Right Channel 0’b:UnMute 1’b:Mute R/W 1’h Mute Source 2 to Stereo1 ADC Right Channel 0’b:UnMute 1’b:Mute 73 Rev. 0.91 ALC5672-VB Datasheet reserved 4:0 R 0’h reserved 10.20. MX-28h: Mono ADC Digital Mixer Control Default: 7871’h Name reserved mu_mono_adcl1 Bits 15 14 mu_mono_adcl2 13 sel_mono_adcl1 12 sel_mono_adcl2 11 reserved Sel_mono_dmic_l 10 9:8 reserved mu_mono_adcr1 7 6 mu_mono_adcr2 5 sel_mono_adcr1 4 sel_mono_adcr2 3 reserved Sel_mono_dmic_r 2 1:0 Table 36. MX-28h: Mono ADC Digital Mixer Control Read/Write Reset State Description R 0’h Reserved R/W 1’h Mute Source 1 to Mono ADC Left channel 0’b:UnMute 1’b:Mute R/W 1’h Mute Source 2 to Mono ADC Left channel 0’b:UnMute 1’b:Mute R/W 1’h Select Mono ADC Left channel source 1 0’b: Mono_DAC_Mixer_L 1’b: ADC1 R/W 1’h Select Mono ADC Left channel source 2 0’b: Mono_DAC_Mixer_L 1’b: DMIC1_L or DMIC2_L or DMIC3_L R/W 0’h Reserved R/W 0’h Select Mono Left Channel DMIC Source 00’b: DMIC1_L 01’b: DMIC2_L 10’b: DMIC3_L 11’b: Reserved R 0’h Reserved R/W 1’h Mute Source 1 to Mono ADC Right channel 0’b:UnMute 1’b:Mute R/W 1’h Mute Source 2 to Mono ADC Right channel 0’b:UnMute 1’b:Mute R/W 1’h Select Mono ADC Right channel source 1 0’b: Mono_DAC_Mixer_R 1’b: ADC2 R/W 0’h Select Mono ADC Right channel source 2 0’b: Mono_DAC_Mixer_R 1’b: DMIC1_R or DMIC2_R or DMIC3_R R/W 0’h Reserved R/W 1’h Select Mono Right Channel DMIC Source 00’b: DMIC1_R 01’b: DMIC2_R 10’b: DMIC3_R 11’b: Reserved 74 Rev. 0.91 ALC5672-VB Datasheet 10.21. MX-29h: Stereo ADC to DAC Digital Mixer Control Default: 8080’h Table 37. MX-29h: Stereo ADC to DAC Digital Mixer Control Name Bits Read/Write Reset State Description Mu_stereo1_adc_mix 15 R/W 1’h Mute Stereo1 ADC to DAC1 Left Channel er_l 0’b:UnMute 1’b:Mute Mu_dac1_l 14 R/W 0’h Mute IF1 DAC Left Channel 0’b:UnMute 1’b:Mute reserved 13:12 R 0’h Reserved Sel_dacr1 11:10 R/W 0’h DACR1 Source Selection 00’b: IF1_DAC1_R 01’b: IF2_DAC_R 10’b: Reserved 11’b: Reserved Sel_dacl1 9:8 R/W 0’h DACL1 Source Selection 00’b: IF1_DAC1_L 01’b: IF2_DAC_L 10’b: Reserved 11’b: Reserved Mu_stereo1_adc_mix 7 R/W 1’h Mute Stereo1 ADC to DAC1 Right Channel er_r 0’b:UnMute 1’b:Mute Mu_dac1_r 6 R/W 0’h Mute IF1 DAC Right Channel 0’b:UnMute 1’b:Mute reserved 5:0 R 0’h reserved 10.22. MX-2Ah: Stereo DAC Digital Mixer Control Default: 5656’h Name Bits reserved 15 mu_stereo_dacl1_mix 14 l gain_dacl1_to_stereo _l 13 mu_stereo_dacl2_mix l 12 gain_dacl2_to_stereo _l 11 Table 38. MX-2Ah: Stereo DAC Digital Mixer Control Read/Write Reset State Description R 0’h Reserved R/W 1’h Mute Stereo DAC1 Left channel 0’b:UnMute 1’b:Mute R/W 0’h Gain Control for DACL1 to Stereo Left Mixer 0’b: 0dB 1’b: -6dB R/W 1’h Mute Stereo DAC2 Left channel 0’b:UnMute 1’b:Mute R/W 0’h Gain Control for DACL2 to Stereo Left Mixer 0’b: 0dB 1’b: -6dB 75 Rev. 0.91 ALC5672-VB Datasheet Name reserved mu_stereo_dacr1_mi xl Bits 10 9 Read/Write R/W R/W gain_dacr1_to_stereo _l 8 R/W reserved mu_stereo_dacr1_mi xr 7 6 R R/W gain_dacr1_to_stereo _r 5 R/W mu_stereo_dacr2_mi xr 4 R/W gain_dacr2_to_stereo _r 3 R/W Reserved mu_stereo_dacl1_mix r 2 1 R/W R/W gain_dacl1_to_stereo _r 0 R/W Reset State Description 1’h Reserved 1’h Mute Stereo DAC1 Right channel to Left Mixer 0’b:UnMute 1’b:Mute 0’h Gain Control for DACR1 to Stereo Left Mixer 0’b: 0dB 1’b: -6dB 0’h reserved 1’h Mute Stereo DAC1 Right channel 0’b:UnMute 1’b:Mute 0’h Gain Control for DACR1 to Stereo Right Mixer 0’b: 0dB 1’b: -6dB 1’h Mute Stereo DAC2 Right channel 0’b:UnMute 1’b:Mute 0’h Gain Control for DACR2 to Stereo Right Mixer 0’b: 0dB 1’b: -6dB 1’h Reserved 1’h Mute Stereo DAC1 Left channel to Right Mixer 0’b:UnMute 1’b:Mute 0’h Gain Control for DACL1 to Stereo Right Mixer 0’b: 0dB 1’b: -6dB 10.23. MX-2Bh: Mono DAC Digital Mixer Control Default: 5454’h Name Bits reserved 15 mu_mono_dacl1_mix 14 l gain_mono_l_dacl1 13 mu_mono_dacl2_mix l 12 gain_mono_l_dacl2 11 Table 39. MX-2Bh: Mono DAC Digital Mixer Control Read/Write Reset State Description R 0’h Reserved R/W 1’h Mute DAC1 Left channel to Mono DAC Left Mixer 0’b:UnMute 1’b:Mute R/W 0’h Gain Control for DAC1 Left channel to Mono DAC Left Mixer 0’b: 0dB 1’b: -6dB R/W 1’h Mute DAC2 Left channel to Mono DAC Left Mixer 0’b:UnMute 1’b:Mute R/W 0’h Gain Control for DAC2 Left channel to Mono DAC Left Mixer 0’b: 0dB 1’b: -6dB 76 Rev. 0.91 ALC5672-VB Datasheet Name Bits mu_mono_dacr2_mix 10 l gain_mono_l_dacr2 9 Read/Write R/W R/W reserved 8:7 mu_mono_dacr1_mix 6 r R R/W gain_mono_r_dacr1 5 R/W mu_mono_dacr2_mix r 4 R/W gain_mono_r_dacr2 3 R/W mu_mono_dacl2_mix r 2 R/W gain_mono_r_dacl2 1 R/W reserved 0 R Reset State Description 1’h Mute DAC2 Right channel to Mono DAC Left Mixer 0’b:UnMute 1’b:Mute 0’h Gain Control for DAC2 Right channel to Mono DAC Left Mixer 0’b: 0dB 1’b: -6dB 0’h reserved 1’h Mute DAC1 Right channel to Mono DAC Right Mixer 0’b:UnMute 1’b:Mute 0’h Gain Control for DAC1 Right channel to Mono DAC Right Mixer 0’b: 0dB 1’b: -6dB 1’h Mute DAC2 Right channel to Mono DAC Right Mixer 0’b:UnMute 1’b:Mute 0’h Gain Control for DAC2 Right channel to Mono DAC Right Mixer 0’b: 0dB 1’b: -6dB 1’h Mute DAC2 Left channel to Mono DAC Right Mixer 0’b:UnMute 1’b:Mute 0’h Gain Control for DAC2 Left channel to Mono DAC Right Mixer 0’b: 0dB 1’b: -6dB 0’h reserved 10.24. MX-2Ch: DAC Digital Mixer Control Default: AAA0’h Name Bits Mu_stereomixl_to_da 15 cmixl gain_stereomixl_to_d acmixl 14 Mu_dacl2_to_dacmix l 13 gain_dacl2_to_dacmi xl 12 Table 40. MX-2Ch: DAC Digital Mixer Control Read/Write Reset State Description R/W 1’h Mute Stereo_DAC_Mixer_L to DAC_MIXL 0’b:UnMute 1’b:Mute R/W 0’h Gain Control for Stereo_DAC_Mixer_L to DAC_MIXL 0’b: 0dB 1’b: -6dB R/W 1’h Mute DACL2 to DAC_MIXL 0’b:UnMute 1’b:Mute R/W 0’h Gain Control for DACL2 to DAC_MIXL 0’b: 0dB 1’b: -6dB 77 Rev. 0.91 ALC5672-VB Datasheet Name Bits Mu_stereomixr_to_da 11 cmixr Read/Write R/W gain_stereomixr_to_d acmixr 10 R/W Mu_dacr2_to_dacmix r 9 R/W gain_dacr2_to_dacmi xr 8 R/W Mu_dacr2_to_dacmix l 7 R/W gain_dacr2_to_dacmi xl 6 R/W Mu_dacl2_to_dacmix r 5 R/W gain_dacl2_to_dacmi xr 4 R/W 3:0 R reserved Reset State Description 1’h Mute Stereo_DAC_Mixer_R to DAC_MIXR 0’b:UnMute 1’b:Mute 0’h Gain Control for Stereo_DAC_Mixer_R to DAC_MIXR 0’b: 0dB 1’b: -6dB 1’h Mute DACR2 to DAC_MIXR 0’b:UnMute 1’b:Mute 0’h Gain Control for DACR2 to DAC_MIXR 0’b: 0dB 1’b: -6dB 1’h Mute DACR2 to DAC_MIXL 0’b:UnMute 1’b:Mute 0’h Gain Control for DACR2 to DAC_MIXL 0’b: 0dB 1’b: -6dB 1’h Mute DACL2 to DAC_MIXR 0’b:UnMute 1’b:Mute 0’h Gain Control for DACL2 to DAC_MIXR 0’b: 0dB 1’b: -6dB 0’h Reserved 10.25. MX-2Dh: Voice DSP Path Control 1 Default: 0000’h Name Sel_rxdp_in Sel_src_to_rxdp Reserved Table 41. MX-2Dh: Voice DSP Path Control 1 Bits Read/Write Reset State Description 15:13 R/W 0’h RxDP Input Selection 000’b: IF2_DAC_L/R 001’b: IF1_DAC2_L/R 010’b: Stereo1_ADC_Mixer_L/R 011’b: Stereo2_ADC_Mixer_L/R 100’b: Mono_ADC_Mixer_L 101’b: Mono_ADC_Mixer_R 110’b: DACL1/R1 (After EQ/ALC/ SounzRealTM) 111’b: Reserved 12:11 R/W 0’h Select SRC to RxDP 00’b: Bypass 01’b: /2 10’b: /3 11’b: Reserved 10 R 0’h Reserved 78 Rev. 0.91 ALC5672-VB Datasheet Name Sel_txdp_data Bits 9:8 Read/Write R/W Sel_txdc_data 7:6 R/W Sel_src_to_txdp 5:4 R/W Sel_tdm_txdp_slot 3:2 R/W Sel_dsp_ul_bypass 1 R/W Sel_dsp_dl_bypass 0 R/W Reset State Description 0’h TxDP Output Data Swap 00’b: L/R 01’b: R/L 10’b: L/L 11’b: R/R 0’h TxDC Output Data Swap 00’b: L/R 01’b: R/L 10’b: L/L 11’b: R/R 0’h Select SRC to TxDP 00’b: Bypass (Stereo signal) 01’b: /2 (Mono signal) 10’b: /3 (Mono signal) 11’b: Reserved 0’h TXDP TDM Channel Slot Selection to Stereo Channel 00’b: Slot 0/1 01’b: Slot 2/3 10’b: Slot 4/5 11’b: Slot 6/7 0’h Select DSP Uplink Bypass 0’b: Pass DSP 1’b: Bypass DSP 0’h Select DSP Downlink Bypass 0’b: Pass DSP 1’b: Bypass DSP 10.26. MX-2Eh: Voice DSP Volume Control Default: 2F2F’h Name Reserved Vol_txdp_l Bits 15 14:8 Reserved Vol_txdp_r 7 6:0 Table 42. MX-2Eh: Voice DSP Volume Control Read/Write Reset State Description R 0’h Reserved R/W 2F’h Mono ADC left channel digital volume in 0.375 dB step 00’h: -17.625dB 2F’h: 0dB 7F’h: 30dB, 0.375dB/Step R 0’h Reserved R/W 2F’h Mono ADC right channel digital volume in 0.375 dB step 00’h: -17.625dB 2F’h: 0dB 7F’h: 30dB, 0.375dB/Step 79 Rev. 0.91 ALC5672-VB Datasheet 10.27. MX-2Fh: Interface DAC/ADC Data Control Default: 1002’h Table 43. MX-2Fh: Interface DAC/ADC Data Control Name Bits Read/Write Reset State Description Sel_if1_adc2_data_in 15 R/W 0’h Select Interface1 ADC2 Data Input 0’b: IF_ADC2 1’b: Reserved Sel_if2_adc_data_in 14:12 R/W 1’h Select Interface2 ADC Data Input 000’b: IF_ADC1 001’b: IF_ADC2 010’b: Reserved 011’b: TxDC_DAC 100’b: TxDP_ADC 101’b: Reserved 110’b: Reserved 111’b: Reserved sel_if2_dac_data 11:10 R/W 0’h Select Interface2 DAC Data Swap 00’b: L/R 01’b: R/L 10’b: L/L 11’b: R/R sel_if2_adc_data 9:8 R/W 0’h Select Interface2 ADC Data Swap 00’b: L/R 01’b: R/L 10’b: L/L 11’b: R/R reserved 7:0 R 2’h Reserved 10.28. MX-31h: Speaker Control 1 Default: 5F00’h Name sel_spk_l Bits 15 mu_spk_l 14 sel_spk_r 13 mu_spk_r 12 Table 44. MX-31h: Speaker Control 1 Read/Write Reset State Description R/W 0’h Select Speaker Left channel source 0’b: Mono_DAC_MIXL 1’b: Stereo_DAC_MIXL R/W 1’h Mute Speaker Left channel data 0’b: UnMute 1’b: Mute R/W 0’h Select Speaker Right channel source 0’b: Mono_DAC_MIXR 1’b: Stereo_DAC_MIXR R/W 1’h Mute Speaker Right channel data 0’b: UnMute 1’b: Mute 80 Rev. 0.91 ALC5672-VB Datasheet Name Reserved Bits 11:0 Read/Write R Reset State Description F00’h Reserved 10.29. MX-3Bh: RECMIXL Control 1 Default: 0000’h Name reserved gain_inl_recmixl reserved gain_bst2_recmixl reserved Table 45. MX-3Bh: RECMIXL Control 1 Bits Read/Write Reset State Description 15:13 R/W 0’h Reserved 12:10 R/W 0’h Gain Control for INL1 to REC Left Mixer 000’b: 0dB 001’b: -3dB 010’b: 011’b: -9dB 100’b: -12dB 101’b: 110’b: -18dB 9:7 R/W 0’h Reserved 6:4 R/W 0’h Gain Control for Boost 2 to REC Left Mixer 000’b: 0dB 001’b: -3dB 010’b: 011’b: -9dB 100’b: -12dB 101’b: 110’b: -18dB 3:0 R 0’h reserved -6dB -15dB -6dB -15dB 10.30. MX-3Ch: RECMIXL Control 2 Default: 007F’h Name gain_bst1_recmixl reserved Mu_inl_recmixl reserved Mu_bst2_recmixl reserved Mu_bst1_recmixl reserved Table 46. MX-3Ch: RECMIXL Control 2 Bits Read/Write Reset State Description 15:13 R/W 0’h Gain Control for Boost 1 to REC Left Mixer 000’b: 0dB 001’b: -3dB 010’b: 011’b: -9dB 100’b: -12dB 101’b: 110’b: -18dB 12:6 R 1’h Reserved 5 R/W 1’h INL1 to RECMIXL Mute Control 0’b : Un-Mute 1’b: Mute (- dB) 4 R/W 1’h Reserved 3 R/W 1’h MIC BST2 to RECMIXL Mute Control 0’b : Un-Mute 1’b: Mute (- dB) 2 R/W 1’h Reserved 1 R/W 1’h MIC BST1 to RECMIXL Mute Control 0’b : Un-Mute 1’b: Mute (- dB) 0 R/W 1’h Reserved 81 -6dB -15dB Rev. 0.91 ALC5672-VB Datasheet 10.31. MX-3Dh: RECMIXR Control 1 Default: 0000’h Name reserved gain_inr_recmixr reserved gain_bst2_recmixr reserved Table 47. MX-3Dh: RECMIXR Control 1 Bits Read/Write Reset State Description 15:13 R/W 0’h Reserved 12:10 R/W 0’h Gain Control for INR1 to REC Right Mixer 000’b: 0dB 001’b: -3dB 010’b: 011’b: -9dB 100’b: -12dB 101’b: 110’b: -18dB 9:7 R/W 0’h Reserved 6:4 R/W 0’h Gain Control for Boost 2 to REC Right Mixer 000’b: 0dB 001’b: -3dB 010’b: 011’b: -9dB 100’b: -12dB 101’b: 110’b: -18dB 3:0 R 0’h reserved -6dB -15dB -6dB -15dB 10.32. MX-3Eh: RECMIXR Control 2 Default: 007F’h Name gain_bst1_recmixr reserved Mu_inr_recmixr reserved Mu_bst2_recmixr reserved Mu_bst1_recmixr reserved Table 48. MX-3Eh: RECMIXR Control 2 Bits Read/Write Reset State Description 15:13 R/W 0’h Gain Control for Boost 1 to REC Right Mixer 000’b: 0dB 001’b: -3dB 010’b: 011’b: -9dB 100’b: -12dB 101’b: 110’b: -18dB 12:6 R 1’h Reserved 5 R/W 1’h INR1 to RECMIXR Mute Control 0’b : Un-Mute 1’b: Mute (- dB) 4 R/W 1’h Reserved 3 R/W 1’h MIC BST2 to RECMIXR Mute Control 0’b : Un-Mute 1’b: Mute (- dB) 2 R/W 1’h Reserved 1 R/W 1’h MIC BST1 to RECMIXR Mute Control 0’b : Un-Mute 1’b: Mute (- dB) 0 R/W 1’h Reserved 82 -6dB -15dB Rev. 0.91 ALC5672-VB Datasheet 10.33. MX-45h: HPOMIX Control Default: E00F’h Name reserved Mu_hpvol_hpo Bits 15 14 Mu_dac1_hpo 13 En_bst_hp 12 reserved Mu_inr1_hpmixr 11:4 3 Mu_dacr1_hpomixr 2 Mu_inl1_hpomixl 1 Mu_dacl1_hpomixl 0 Table 49. MX-45h: HPOMIX Control Read/Write Reset State Description R 1‘h Reserved R/W 1’h HPOVOL to HPO Mute Control 0’b: Un-Mute 1’b: Mute (- dB) R/W 1’h DAC1 to HPO Mute Control 0’b: Un-Mute 1’b: Mute (- dB) R/W 0’h HPO Gain Control 0’b: 0dB 1’b: -6dB R 0’h Reserved R/W 1’h INR to HPMIXR Mute Control 0’b: Un-Mute 1’b: Mute (- dB) R/W 1’h DACR1 to HPMIXR Mute Control 0’b : Un-Mute 1’b: Mute (- dB) R/W 1’h INL to HPMIXL Mute Control 0’b : Un-Mute 1’b: Mute (- dB) R/W 1’h DACL1 to HPMIXL Mute Control 0’b : Un-Mute 1’b: Mute (- dB) 10.34. MX-4Fh: OUTMIXL Control Default: 0073’h Name Reserved Mu_bst1_outmixl1 Mu_inl_outmixl1 Reserved Mu_dacl2_outmixl1 Bits 15:6 5 4 3:2 1 Table 50. MX-4Fh: OUTMIXL Control Read/Write Reset State Description R 1’h reserved R/W 1’h Mute Control for BST1 to OUTMIXL1 0’b: Un-Mute 1’b: Mute (- dB) R/W 1’h Mute Control for INL1 to OUTMIXL1 0’b: Un-Mute 1’b: Mute (- dB) R 0’h reserved R/W 1’h Mute Control for DACL2 to OUTMIXL1 0’b: Un-Mute 1’b: Mute (- dB) 83 Rev. 0.91 ALC5672-VB Datasheet Name Mu_dacl1_outmixl1 Bits 0 Read/Write R/W Reset State Description 1’h Mute Control for DACL1 to OUTMIXL1 0’b: Un-Mute 1’b: Mute (- dB) 10.35. MX-52h: OUTMIXR Control Default: 00D3’h Name reserved Mu_bst2_outmixr1 Bits 15:7 6 reserved Mu_inr_outmixr1 5 4 reserved Mu_dacr2_outmixr1 3:2 1 Mu_dacr1_outmixr1 0 Table 51. MX-52h: OUTMIXR Control 3 Read/Write Reset State Description R 1’h reserved R/W 1’h Mute Control for BST2 to OUTMIXR1 0’b: Un-Mute 1’b: Mute (- dB) R 0’h reserved R/W 1’h Mute Control for INR1 to OUTMIXR1 0’b: Un-Mute 1’b: Mute (- dB) R 0’h reserved R/W 1’h Mute Control for DACR2 to OUTMIXR1 0’b: Un-Mute 1’b: Mute (- dB) R/W 1’h Mute Control for DACR1 to OUTMIXR1 0’b: Un-Mute 1’b: Mute (- dB) 10.36. MX-53h: LOUTMIX Control Default: F000’h Name mu_dacl1_lout1 Bits 15 mu_dacr1_lout1 14 mu_outmixl1_lout1 13 mu_outmixr1_lout1 12 Table 52. MX-53h: LOUTMIX Control Read/Write Reset State Description R/W 1’h Mute DACL1 to LOUT1 Mixer 0’b: Un-Mute 1’b: Mute (- dB) R/W 1’h Mute DACR1 to LOUT1 Mixer 0’b: Un-Mute 1’b: Mute (- dB) R/W 1’h Mute Output Left Volume 1 to LOUT1 Mixer 0’b: Un-Mute 1’b: Mute (- dB) R/W 1’h Mute Output Right Volume 1 to LOUT1 Mixer 0’b: Un-Mute 1’b: Mute (- dB) 84 Rev. 0.91 ALC5672-VB Datasheet Name bst_lout1 Bits 11 Read/Write R/W reserved 10:0 R Reset State Description 0’h Gain Control for ALL path to LOUT1 Mixer 0’b: 0dB 1’b: -6dB 0’h Reserved 10.37. MX-61h: Power Management Control 1 Default: 0000’h Name En_i2s1 Bits 15 En_i2s2 14 reserved Pow_dac_l_1 13 12 Pow_dac_r_1 11 reserved Pow_dac_l_2 10:8 7 Pow_dac_r_2 6 reserved Pow_adc_l 5:3 2 Pow_adc_r 1 reserved 0 Table 53. MX-61h: Power Management Control 1 Read/Write Reset State Description R/W 0’h I2S1 Digital Interface Power Control 0’b: Power Down 1’b: Power On R/W 0’h I2S2 Digital Interface Power Control 0’b: Power Down 1’b: Power On R/W 0’h Reserved R/W 0’h Analog DACL1 Power Control 0’b: Power Down 1’b: Power On R/W 0’h Analog DACR1 Power Control 0’b: Power Down 1’b: Power On R 0’h Reserved R/W 0’h Analog DACL2 Power Control 0’b: Power Down 1’b: Power On R/W 0’h Analog DACR2 Power Control 0’b: Power Down 1’b: Power On R 0’h Reserved R/W 0’h Analog ADCL Power Control 0’b: Power Down 1’b: Power On R/W 0’h Analog ADCR Power Control 0’b: Power Down 1’b: Power On R 0’h Reserved 85 Rev. 0.91 ALC5672-VB Datasheet 10.38. MX-62h: Power Management Control 2 Default: 0000’h Name Bits Pow_adc_stereo_filte 15 r Pow_adc_monol_filte r 14 Pow_adc_monor_filte r 13 Pow_i2s_dsp 12 pow_dac_stereo1_filt er 11 pow_dac_monol_filte r 10 pow_dac_monor_filte r 9 pow_adc_stereo2_filt er 8 Pow_spk 7 reserved 6:0 Table 54. MX-62h: Power Management Control 2 Read/Write Reset State Description R/W 0’h Stereo1 ADC Digital Filter Power Control 0’b: Power Down 1’b: Power On R/W 0’h Mono ADC_L Digital Filter Power Control 0’b: Power Down 1’b: Power On R/W 0’h Mono ADC_R Digital Filter Power Control 0’b: Power Down 1’b: Power On R/W 0’h I2S Interface for DSP Power Control 0’b: Power Down 1’b: Power On R/W 0’h Power on DAC stereo1 filter 0’b: Power Down 1’b: Power On R/W 0’h Power on DAC mono left filter 0’b: Power Down 1’b: Power On R/W 0’h Power on DAC mono right filter 0’b: Power Down 1’b: Power On R/W 0’h Power on ADC stereo2 filter 0’b: Power Down 1’b: Power On R/W 0’h Power on Speaker 0’b: Power down 1’b: Power on R 0’h Reserved 10.39. MX-63h: Power Management Control 3 Default: 00C0’h Name Pow_vref1 Bits 15 En_fastb1 14 Table 55. MX-63h: Power Management Control 3 Read/Write Reset State Description R/W 0’h VREF1 Power Control 0’b: Power Down 1’b: Power On R/W 0’h VREF1 Fast Mode Control 0’b: Fast VREF 1’b: Slow VREF, (For good analog performance) 86 Rev. 0.91 ALC5672-VB Datasheet Name Pow_main_bias Bits 13 Read/Write R/W Pow_lout 12 R/W Pow_bg_bias 11 R/W reserved En_l_hp 10:8 7 R R/W En_r_hp 6 R/W En_amp_hp 5 R/W Pow_vref2 4 R/W En_fastb2 3 R/W Dvo_ldo 2:0 R/W Reset State Description 0’h MBIAS Power Control 0’b: Power Down 1’b: Power On 0’h LOUTMIX Power Control 0’b: Power Down 1’b: Power On 0’h MBIAS Bandgap Power Control 0’b: Power Down 1’b: Power On 0’h Reserved 1’h Left Headphone Amp Power Control 0’b: Power Down 1’b: Power On 1’h Right Headphone Amp Power Control 0’b: Power Down 1’b: Power On 0’h Improve HP Amp Driving 0’b: Disable 1’b: Enable 0’h VREF2 Power Control 0’b: Power Down 1’b: Power On 0’h VREF2 Fast Mode Control 0’b: Fast VREF 1’b: Slow VREF, (For good analog performance) 3’h Selection of the LDO output 000’b: Reserved 001’b: Reserved 010’b: 1.0V 011’b: 1.2V 100’b: 1.25V 101’b: 1.3V 110’b: 1.35V 111’b: 1.4V 10.40. MX-64h: Power Management Control 4 Default: 0000’h Name Pow_bst1_1 Bits 15 reserved Pow_bst2_1 14 13 Table 56. MX-64h: Power Management Control 4 Read/Write Reset State Description R/W 0’h MIC BST1 Power Control 1 0’b: Power Down 1’b: Power On R/W 0’h reserved R/W 0’h MIC BST2 Power Control 1 0’b: Power Down 1’b: Power On 87 Rev. 0.91 ALC5672-VB Datasheet Name reserved Pow_micbias1_1 Bits 12 11 Read/Write R/W R/W reserved Pow_pll 10 9 R/W R/W reserved Pow_bst1_2 8:7 6 R R/W reserved Pow_bst2_2 5 4 R R/W reserved Pow_jd1 3 2 R R/W Pow_jd2 1 R/W reserved 0 R Reset State Description 0’h reserved 0’h MICBIAS1 Power Control 1 0’b: Power Down 1’b: Power On 0’h reserved 0’h PLL Power Control 0’b: Power Down 1’b: Power On 0’h Reserved 0’h MIC BST1 Power Control 2 0’b: Power Down 1’b: Power On 0’h Reserved 0’h MIC BST2 Power Control 2 0’b: Power Down 1’b: Power On 0’h Reserved 0’h JD1 Power Control 0’b: Power Down 1’b: Power On 0’h JD2 Power Control 0’b: Power Down 1’b: Power On 0’h Reserved 10.41. MX-65h: Power Management Control 5 Default: 0000’h Name Pow_outmixl Pow_outmixr reserved Pow_recmixl Pow_recmixr reserved Table 57. MX-65h: Power Management Control 5 Bits Read/Write Reset State Description 15 R/W 0’h OUTMIXL & VOL Power Control 0’b: Power Down 1’b: Power On 14 R/W 0’h OUTMIXR & VOL Power Control 0’b: Power Down 1’b: Power On 13:12 R 0’h Reserved 11 R/W 0’h RECMIXL Power Control 0’b: Power Down 1’b: Power On 10 R/W 0’h RECMIXR Power Control 0’b: Power Down 1’b: Power On 9:0 R 0’h Reserved 88 Rev. 0.91 ALC5672-VB Datasheet 10.42. MX-66h: Power Management Control 6 Default: 0000’h Name reserved Pow_hpovoll Pow_hpovolr Pow_inlvol Pow_inrvol reserved Pow_mic_in_det reserved Pow_micbias1_2 Table 58. MX-66h: Power Management Control 6 Bits Read/Write Reset State Description 15:12 R 0’h Reserved 11 R/W 0’h HPMIXL & VOL Power Control 0’b: Power Down 1’b: Power On 10 R/W 0’h HPMIXR & VOL Power Control 0’b: Power Down 1’b: Power On 9 R/W 0’h INLVOL Power Control 0’b: Power Down 1’b: Power On 8 R/W 0’h INRVOL Power Control 0’b: Power Down 1’b: Power On 7:6 R 0’h Reserved 5 R/W 0’h MIC_IN_DET Power Control 0’b: Power Down 1’b: Power On 4:1 R 0’h Reserved 0 R/W 0’h MICBIAS1 Power Control 2 0’b: Power Down 1’b: Power On 10.43. MX-6Ah: Private Register Index Default: 0000’h Name reserved Pr_index Bits 15:8 7:0 Table 59. MX-6Ah: Private Register Index Read/Write Reset State Description R 0’h reserved R/W 0’h PR Register Index 10.44. MX-6Ch: Private Register Data Default: 0000’h Name Pr_data Bits 15:0 Table 60. MX-6Ch: Private Register Data Read/Write Reset State Description R/W 0’h PR Register Data 89 Rev. 0.91 ALC5672-VB Datasheet 10.45. MX-70h: I2S1 Digital Interface Control Default: 8000’h Name Sel_i2s1_ms reserved en_i2s1_out_comp en_i2s1_in_comp Inv_i2s1_bclk reserved sel_i2s1_len sel_i2s1_format Table61. MX-70h: I2S1 Digital Interface Control Bits Read/Write Reset State Description 15 R/W 1’h I2S1 Digital Interface Mode Control 0’b: Master Mode 1’b: Slave Mode 14:12 R 0’h Reserved 11:10 R/W 0’h I2S1 Output Data Compress (For ADCDAT1 Output) 00’b: OFF 01’b: µ law 10’b: A law 11’b: Reserved 9:8 R/W 0’h I2S1 Input Data Compress (For DACDAT1 Input) 00’b: OFF 01’b: µ law 10’b: A law 11’b: Reserved 7 R/W 0’h I2S1 BCLK Polarity Control 0’b: Normal 1’b: Invert 6:4 R 0’h Reserved 3:2 R/W 0’h I2S1 Data Length Selection 00’b: 16 bits 01’b: 20 bits 10’b: 24 bits 11’b: 8 bits 1:0 R/W 0’h I2S1 PCM Data Format Selection 00’b: I2S format 01’b: Left justified 10’b: PCM Mode A (LRCK One Plus at Master Mode) 11’b: PCM Mode B (LRCK One Plus at Master Mode) 10.46. MX-71h: I2S2 Digital Interface Control Default: 8000’h Name Sel_i2s2_ms reserved Table 61. MX-71h: I2S2 Digital Interface Control Read/Write Reset State Description R/W 1’h I2S2 Digital Interface Mode Control 0’b: Master Mode 1’b: Slave Mode 14:12 R 0’h Reserved Bits 15 90 Rev. 0.91 ALC5672-VB Datasheet Name en_i2s2_out_comp en_i2s2_in_comp Bits Read/Write 11:10 R/W 9:8 R/W 7 R/W reserved sel_i2s2_len 6:4 3:2 R R/W sel_i2s2_format 1:0 R/W inv_i2s2_bclk Reset State Description 0’h I2S2 Output Data Compress (For ADCDAT2 Output) 00’b: OFF 01’b: µ law 10’b: A law 11’b: Reserved 0’h I2S2 Input Data Compress (For DACDAT2 Input) 00’b: OFF 01’b: µ law 10’b: A law 11’b: Reserved 0’h I2S2 BCLK Polarity Control 0’b: Normal 1’b: Invert 0’h Reserved 0’h I2S2 Data Length Selection 00’b: 16 bits 01’b: 20 bits 10’b: 24 bits 11’b: 8bits 0’h I2S2 PCM Data Format Selection 00’b: I2S format 01’b: Left justified 10’b: PCM Mode A (LRCK One Plus at Master Mode) 11’b: PCM Mode B (LRCK One Plus at Master Mode) 10.47. MX-73h: ADC/DAC Clock Control Default: 1114’h Name reserved sel_i2s_pre_div1 sel_i2s_bclk_ms2 Table 62. MX-73h: ADC/DAC Clock Control Bits Read/Write Reset State Description Reserved 15 R 0’h 14:12 R/W 1’h I2S Clock Pre-Divider 1 000’b: ÷ 1 001’b: ÷ 2 010’b: ÷ 3 011’b: ÷ 4 100’b: ÷ 6 101’b: ÷ 8 110’b: ÷ 12 111’b: ÷ 16 I2S2 Master Mode Clock Relative of BCLK and LRCK 11 R/W 0’h 0’b: 16Bits (32FS) 1’b: 32Bits (64FS) 91 Rev. 0.91 ALC5672-VB Datasheet Name sel_i2s_pre_div2 Bits 10:8 Read/Write R/W reserved sel_dac_osr 7:4 3:2 R/W R/W sel_adc_osr 1:0 R/W Reset State Description 1’h I2S Pre-Divider 2 000’b: ÷ 1 001’b: ÷ 2 010’b: ÷ 3 011’b: ÷ 4 100’b: ÷ 6 101’b: ÷ 8 110’b: ÷ 12 111’b: ÷ 16 Reserved 1’h 1’h Stereo DAC Over Sample Rate Select 00’b: 128Fs 01’b: 64Fs 10’b: 32Fs 11’b: Reserved 0’h Stereo ADC Over Sample Rate Select 00’b: 128Fs 01’b: 64Fs 10’b: 32Fs 11’b: Reserved 10.48. MX-74h: ADC/DAC HPF Control Default: 0E00’h Name reserved Dehpf_en Adhpf_en Mono_adhpf_en Reserved Table 63. MX-74h: ADC/DAC HPF Control Bits Read/Write Reset State Description 15:12 R 0’h Reserved 11 R/W 1’h Enable Stereo/Mono DAC High Pass Filter 0’b: Disable 1’b: Enable 10 R/W 1’h Enable Stereo1/2 ADC High Pass Filter 0’b: Disable 1’b: Enable 9 R/W 1’h Enable Mono ADC High Pass Filter 0’b: Disable 1’b: Enable 8:0 R 0’h Reserved 92 Rev. 0.91 ALC5672-VB Datasheet 10.49. MX-75h: Digital Microphone Control 1 Default: 1505’h Name en_dmic1 Bits 15 en_dmic2 14 sel_dmic_l_edge_ster eo1 13 sel_dmic_r_edge_ster eo1 12 reserved Dmic2_data_pin_shar e 11 10 sel_dmic_l_edge_ster eo2 9 sel_dmic_r_edge_ster eo2 8 sel_dmic_clk 7:5 en_dmic3 4 sel_dmic_l_edge_mo no 3 sel_dmic_r_edge_mo no 2 Table 64. MX-75h: Digital Microphone Control 1 Read/Write Reset State Description R/W 0’h Enable DMIC1 Interface 0’b: Disable 1’b: Enable (Output DMIC clock) R/W 0’h Enable DMIC2 Interface 0’b: Disable 1’b: Enable (Output DMIC clock) R/W 0’h Stereo1 ADC Filter DMIC Left Channel (Synchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 1’h Stereo1 ADC Filter DMIC Right Channel (Synchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 0’h Reserved R/W 1’h Select the Pin share of DMIC2_DATA 0’b:GPIO8 1’b:IN3N R/W 0’h Stereo2 ADC Filter DMIC Left Channel (Synchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 1’h Stereo2 ADC Filter DMIC Right Channel (Synchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 0’h DMIC Clock Rate Control 000’b: 256*fs/2 001’b: 256*fs/3 010’b: 256*fs/4 011’b: 256*fs/6 100’b: 256*fs/8 101’b: 256*fs/12 R/W 0’h Enable DMIC3 Interface 0’b: Disable 1’b: Enable (Output DMIC clock) R/W 0’h Mono ADC Filter DMIC Left Channel (Synchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 1’h Mono ADC Filter DMIC Right Channel (Synchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge 93 Source Control Source Control Source Control Source Control Source Control Source Control Rev. 0.91 ALC5672-VB Datasheet Name dmic1_data_pin_shar e Bits 1:0 Read/Write R/W Reset State Description 1’h Select the Pin share of DMIC1_DATA 00’b: GPIO6 01’b: IN2P 10’b: Reserved 11’b: Reserved 10.50. MX-76h: Digital Microphone Control 2 Default: 0015’h Name Bits Reserved 15:8 Dmic3_data_pin_shar 7:6 e sel_dmic3_lpf_l_edge 5 sel_dmic3_lpf_r_edg e 4 sel_dmic2_lpf_l_edge 3 sel_dmic2_lpf_r_edg e 2 sel_dmic1_lpf_l_edge 1 sel_dmic1_lpf_r_edg e 0 Table 65. MX-76h: Digital Microphone Control 2 Read/Write Reset State Description R 0’h Reserved R/W 0’h Select the Pin share of DMIC3_DATA 00’b: Reserved 01’b: Reserved 10’b: GPIO5 (DACDAT2) 11’b: Reserved R/W 0’h DMIC3 Data Left Channel Source Control (Asynchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 1’h DMIC3 Data Right Channel Source Control (Asynchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 0’h DMIC2 Data Left Channel Source Control (Asynchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 1’h DMIC2 Data Right Channel Source Control (Asynchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 0’h DMIC1 Data Left Channel Source Control (Asynchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge R/W 1’h DMIC1 Data Right Channel Source Control (Asynchronous Mode) 0’b: Latch from falling edge 1’b: Latch from rising edge 94 Rev. 0.91 ALC5672-VB Datasheet 10.51. MX-77h: TDM Interface Control 1 Default: 0C00’h Name reserved mode_sel Tdmslot_sel Channel_length rx_adc_data_sel reserved sel_i2s_rx_ch2 sel_i2s_rx_ch4 sel_i2s_rx_ch6 sel_i2s_rx_ch8 Table 66. MX-77h: TDM Interface Control 1 Bits Read/Write Reset State Description 15 R/W 0’h Reserved 14 R/W 0’h I2S / TDM Mode Control 0’b: Normal I2S Mode 1’b: TDM Mode 13:12 R/W 0’h TDM Channel Number Select 00’b: 2ch 01’b: 4ch 10’b: 6ch 11’b: 8ch TDM Channel Length 11:10 R/W 3’h 00’b: 16bit (For Slave Mode and Master Mode) 01’b: 20bit (For Slave Mode) 10’b: 24bit (For Slave Mode) 11’b: 32bit (For Slave Mode and Master Mode) 9 R/W 0’h ADC Data to ADCDAT Data Location 0’b: 1L/1R/2L/2R/3L/3R/4L/4R 1’b: 2L/2R/1L/1R/4L/4R/3L/3R 8 R 0’h Reserved 7:6 R/W 0’h Data Swap for Slot0/1 in ADCDAT1 00’b: L/R 01’b: R/L 10’b: L/L 11’b: R/R 5:4 R/W 0’h Data Swap for Slot2/3 in ADCDAT1 00’b: L/R 01’b: R/L 10’b: L/L 11’b: R/R 3:2 R/W 0’h Data Swap for Slot4/5 in ADCDAT1 00’b: L/R 01’b: R/L 10’b: L/L 11’b: R/R 1:0 R/W 0’h Data Swap for Slot6/7 in ADCDAT1 00’b: L/R 01’b: R/L 10’b: L/L 11’b: R/R 95 Rev. 0.91 ALC5672-VB Datasheet 10.52. MX-78h: TDM Interface Control 2 Default: 4000’h Table 67. MX-78h: TDM Interface Control 2 Name Bits Read/Write Reset State Description sel_i2s_lrck_polarity 15 R/W 0’h TDM Interface LRCK Polarity Inverter 0’b: Normal 1’b: Invert reserved 14:12 R/W 4’h Reserved lrck_pulse_sel 11 R/W 0’h LRCK Pulse Width Select (Master Mode Only) 0’b: One BCLK width 1’b: One channel slot width reserved 10:8 R/W 0’h Reserved mute_tdm2_outl 7 R/W 0’h IF1_ADC1 Left Data Mute/Un-mute Control 0’b : Un-Mute 1’b : Mute mute_tdm2_outr 6 R/W 0’h IF1_ADC1 Right Data Mute/Un-mute Control 0’b : Un-Mute 1’b : Mute mute_tdm4_outl 5 R/W 0’h IF1_ADC2 Left Data Mute/Un-mute Control 0’b : Un-Mute 1’b : Mute mute_tdm4_outr 4 R/W 0’h IF1_ADC2 Right Data Mute/Un-mute Control 0’b : Un-Mute 1’b : Mute mute_tdm6_outl 3 R/W 0’h IF1_ADC3 Left Data Mute/Un-mute Control 0’b : Un-Mute 1’b : Mute mute_tdm6_outr 2 R/W 0’h IF1_ADC3 Right Data Mute/Un-mute Control 0’b : Un-Mute 1’b : Mute mute_tdm8_outl 1 R/W 0’h IF1_ADC4 Left Data Mute/Un-mute Control 0’b : Un-Mute 1’b : Mute mute_tdm8_outr 0 R/W 0’h IF1_ADC4 Right Data Mute/Un-mute Control 0’b : Un-Mute 1’b : Mute 96 Rev. 0.91 ALC5672-VB Datasheet 10.53. MX-79h: TDM Interface Control 3 Default: 0123’h Name Reserved sel_i2s_tx_l_ch2 Reserved sel_i2s_tx_r_ch2 Reserved sel_i2s_tx_l_ch4 Reserved sel_i2s_tx_r_ch4 Table 68. MX-79h: TDM Interface Control 3 Bits Read/Write Reset State Description 15 R 0’h Reserved 14:12 R/W 0’h IF1_DAC1_L Data Selection 000’b: Slot0 001’b: Slot1 010’b: Slot2 011’b: Slot3 100’b: Slot4 101’b: Slot5 110’b: Slot6 111’b: Slot7 11 R 0’h Reserved 10:8 R/W 1’h IF1_DAC1_R Data Selection 000’b: Slot0 001’b: Slot1 010’b: Slot2 011’b: Slot3 100’b: Slot4 101’b: Slot5 110’b: Slot6 111’b: Slot7 7 R 0’h Reserved IF1_DAC2_L Data Selection 6:4 R/W 2’h 000’b: Slot0 001’b: Slot1 010’b: Slot2 011’b: Slot3 100’b: Slot4 101’b: Slot5 110’b: Slot6 111’b: Slot7 3 R 0’h Reserved 2:0 R/W 3’h IF1_DAC2_R Data Selection 000’b: Slot0 001’b: Slot1 010’b: Slot2 011’b: Slot3 100’b: Slot4 101’b: Slot5 110’b: Slot6 111’b: Slot7 97 Rev. 0.91 ALC5672-VB Datasheet 10.54. MX-7Fh: Clock Control 1 Default: 1100’h Name Reserved sel_dsp_asrc0 Bits 15:4 3:0 Table 69. MX-7Fh: Clock Control 1 Read/Write Reset State Description R 110’h Reserved R/W 0’h Select the Clock Source for DSP 0000’b: clk_sys 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved 10.55. MX-80h: Global Clock Control Default: 0000’h Name sel_sysclk1 sel_pll_sour reserved sel_pll_pre_div reserved Table 70. MX-80h: Global Clock Control Bits Read/Write Reset State Description 15:14 R/W 0’h System Clock Source MUX Control 00’b: MCLK 01’b: PLL 10’b: Internal Clock 11’b: Reserved 13:11 R/W 0’h PLL Source Selection 000’b: From MCLK 001’b: From BCLK1 010’b: From BCLK2 Others: Reserved 10:4 R 0’h Reserved 3 R/W 0’h PLL Pre-Divider 0’b: ÷ 1 1’b: ÷ 2 2:0 R 0’h Reserved 98 Rev. 0.91 ALC5672-VB Datasheet 10.56. MX-81h: PLL Control 1 Default: 0000’h Name Pll_n_code Bits 15:7 Reserved Pll_k_code 6:5 4:0 Table 71. MX-81h: PLL Control 1 Read/Write Reset State Description R/W 0’h PLL N[8:0] Code 000000000’b: Div 2 000000001’b: Div 3 … 111111111’b: Div 513 R 0’h Reserved R/W 0’h PLL K[4:0] Code 00000’b: Div 2 00001’b: Div 3 … 11111’b: Div 33 10.57. MX-82h: PLL Control 2 Default: 0000’h Name Pll_m_code Pll_m_bypass Reserved Table 72. MX-82h: PLL Control 2 Bits Read/Write Reset State Description 15:12 R/W 0’h PLL M[3:0] Code 0000’b: Div 2 0001’b: Div 3 … 1111’b: Div 17 11 R/W 0’h Bypass PLL M Code 0’b : No bypass 1’b : Bypass 10:0 R 0’h Reserved 99 Rev. 0.91 ALC5672-VB Datasheet 10.58. MX-83h: ASRC Control 1 Default: 0000’h Table 73. MX-83h: ASRC Control 1 Name Bits Read/Write Reset State Description Reserved 15:13 R 0’h Reserved En_i2s2_asrc 12 R/W 0’h Enable I2S2 ASRC Function 0’b: Disable 1’b: Enable En_i2s1_asrc 11 R/W 0’h Enable I2S1 ASRC Function 0’b: Disable 1’b: Enable Sel_stereo_dac_mode 10 R/W 0’h Enable DAC ASRC for Stereo DAC 0’b : Disable 1’b : Enable Sel_mono_dac_l_mo 9 R/W 0’h Enable DAC ASRC for mono left path de 0’b : Disable 1’b : Enable Sel_mono_dac_r_mo 8 R/W 0’h Enable DAC ASRC for mono right path de 0’b : Disable 1’b : Enable en_dmic_asrc_stereo 7 R/W 0’h Enable DMIC ASRC for stereo1 path 1 0’b : Disable 1’b : Enable en_dmic_asrc_stereo 6 R/W 0’h Enable DMIC ASRC for stereo2 path 2 0’b : Disable 1’b : Enable en_dmic_asrc_monol 5 R/W 0’h Enable DMIC ASRC for mono left path 0’b : Disable 1’b : Enable en_dmic_asrc_monor 4 R/W 0’h Enable DMIC ASRC for mono right path 0’b : Disable 1’b : Enable en_adc_asrc_stereo1 3 R/W 0’h Enable ADC ASRC for stereo1 path 0’b : Disable 1’b : Enable en_adc_asrc_stereo2 2 R/W 0’h Enable ADC ASRC for stereo2 path 0’b : Disable 1’b : Enable en_adc_asrc_monol 1 R/W 0’h Enable ADC ASRC for mono left path 0’b : Disable 1’b : Enable en_adc_asrc_monor 0 R/W 0’h Enable ADC ASRC for mono right path 0’b : Disable 1’b : Enable 100 Rev. 0.91 ALC5672-VB Datasheet 10.59. MX-84h: ASRC Control 2 Default: 0000’h Table 74. MX-84h: ASRC Control 2 Name Bits Read/Write Reset State Description sel_da_filter_stereo_a 15:12 R/W 0’h Select the ASRC Clock Source for DA Stereo Filter src 0000’b : CLK_sys 0001’b : clk_i2s1_asrc 0010’b : clk_i2s2_asrc 0011’b : Reserved 0100’b : Reserved 0101’b : clk_sys2 Others: Reserved Select the ASRC Clock Source for DA Mono Left Filter sel_da_filter_monol_ 11:8 R/W 0’h 0000’b: clk_sysy_div_out asrc 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved Select the ASRC Clock Source for DA Mono Right Filter sel_da_filter_monor_ 7:4 R/W 0’h 0000’b: clk_sysy_div_out asrc 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved Select the ASRC Clock Source for AD Stereo1 Filter sel_ad_filter_stereo1_ 3:0 R/W 0’h 0000’b: clk_sysy_div_out asrc 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved 101 Rev. 0.91 ALC5672-VB Datasheet 10.60. MX-85h: ASRC Control 3 Default: 0000’h Table 75. MX-85h: ASRC Control 3 Name Bits Read/Write Reset State Description sel_up_filter_asrc 15:12 R/W 0’h Select the ASRC Clock Source for Up Sample Rate Filter 0000’b: clk_sysy_div_out 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved sel_down_filter_asrc 11:8 R/W 0’h Select the ASRC Clock Source for Down Sample Rate Filter 0000’b: clk_sysy_div_out 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved sel_ad_filter_monol_ 7:4 R/W 0’h Select the ASRC Clock Source for AD Mono Left Filter asrc 0000’b: clk_sysy_div_out 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved sel_ad_filter_monor_ 3:0 R/W 0’h Select the ASRC Clock Source for AD Mono Right Filter asrc 0000’b: clk_sysy_div_out 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved 102 Rev. 0.91 ALC5672-VB Datasheet 10.61. MX-8Ah: ASRC Control 4 Default: 0000’h Name i2s1_asrc_prediv sel_i2s1_asrc i2s2_asrc_prediv sel_i2s2_asrc reserved Table 76. MX-8Ah: ASRC Control 4 Bits Read/Write Reset State Description 15:14 R/W 0’h Set the I2S1 Clock Division for ASRC Mode 00’b: div1 01’b: div2 10’b: div3 11’b: reserved 13:12 R/W 0’h Select the ASRC source of ASRC 00’b: ASRC1 01’b: ASRC2 10’b: Reserved 11’b: Reserved 11:10 R/W 0’h Set the I2S2 Clock Division for ASRC Mode 00’b: div1 01’b: div2 10’b: div3 11’b: Reserved 9:8 R/W 0’h Select the ASRC Source of I2S2 00’b: ASRC1 01’b: ASRC2 10’b: Reserved 11’b: Reserved 7:0 R/W 0’h Reserved 10.62. MX-8Ch: ASRC Control 5 Default: 0007’h Table 77. MX-8Ch: ASRC Control 5 Bits Read/Write Reset State Description sel_ad_filter_stereo2_asrc 15:12 R/W 0’h Select the ASRC Clock Source for AD Stereo2 Filter 0000’b: clk_sysy_div_out 0001’b: clk_i2s1_asrc 0010’b: clk_i2s2_asrc 0011’b: Reserved 0100’b: Reserved 0101’b: clk_sys2 Others: Reserved Reserved reserved 11:0 R/W 7’h Name 103 Rev. 0.91 ALC5672-VB Datasheet 10.63. MX-8Eh: HP Amp Control 1 Default: 0004’h Name Smttrig_hp reserved En_smt_l_hp En_smt_r_hp Pdn_hp Softgen_rstn Softgen_rstp En_out_hp Pow_pump_hp En_softgen_hp reserved Pow_capless Table 78. MX-8Eh: HP Amp Control 1 Bits Read/Write Reset State Description Enable Softgen Trigger for Soft Mute Depop 15 R/W 0’h 0’b: Disable 1’b: Enable Reserved 14:10 R/W 0’h Enable HP_L Mute/Un-Mute Depop 9 R/W 0’h 0’b: Disbale 1’b: Enable Enable HP_R Mute/Un-Mute Depop 8 R/W 0’h 0’b: Disbale 1’b: Enable Capless Depop Power Down Control 7 R/W 0’h 0’b: Disbale 1’b: Enable Reset Softgen to Initialize SOFTP=1 6 R/W 0’h 0’b: Disbale 1’b: Reset Reset Softgen to Initialize SOFTP=0 5 R/W 0’h 0’b: Disbale 1’b: Reset Enable Headphone Output 4 R/W 0’h 0’b: Disable 1’b: Enable Charge Pump Power Control 3 R/W 0’h 0’b: Power Down 1’b: Power On Power On Soft Generator 2 R/W 1’h 0’b: Power down 1’b: Power on Reserved 1 R/W 0’h HP Amp All Power On Control 0 R/W 0’h 0’b: Power Down 1’b: Power On 10.64. MX-8Fh: HP Amp Control 2 Default: 1100’h Name reserved Depop_mode_hp reserved Table 79. MX-8Fh: HP Amp Control 2 Bits Read/Write Reset State Description Reserved 15:14 R 0’h Select HP Depop Mode 13 R/W 0’h 0’b: Depop mode 1 1’b: Depop mode 2 Reserved 12:7 R/W 22’h 104 Rev. 0.91 ALC5672-VB Datasheet Name En_depop_mode1 Bits 6 Read/Write R/W reserved 5:0 R/W Reset State Description HP Depop Mode 1 Control 0’h 0’b: Disbale 1’b: Enable Reserved 0’h 10.65. MX-93h: MICBIAS Control Default: 0000’h Name Sel_micbias1 reserved Pow_mic1_ovcd Mic1_ovcd_th_sel reserved Ckn_micbias Pow_clk_int Sel_irq_debounce reserved Table 80. MX-93h: MICBIAS Control Read/Write Reset State Description R/W 0’h MICBIAS1 Output Voltage Control 0’b: 0.9 * MICVDD 1’b: 0.75 * MICVDD 14:12 R/W 0’h Reserved 11 R/W 0’h MICBIAS1 Short Current Detector Control 0’b: Disable 1’b: Enable 10:9 R/W 0’h MICBIAS1 Short Current Detector Threshold 00’b: 640uA 01’b: 1280uA 1x’b: 1920uA Note: tolerance is 200uA 8:6 R/W 0’h reserved 5 R/W 0’h MICBIAS Clock Power 0’b: Disable 1’b: Enable 4 R/W 0’h Internal Clock Power 0’b: Disable 1’b: Enable 3 R/W 0’h Select IRQ De-bounce Clock 0’b: MCLK 1’b: Internal clock 2:0 R 0’h reserved Bits 15 10.66. MX-94h: JD1 Control Default: 0000’h Name reserved Sel_mode_jd1 Table 81. MX-94h: JD1 Control Bits Read/Write Reset State Description 15:2 R/W 0’h Reserved 1:0 R/W 0’h JD1 Mode Control 00’b: Mode-0, two port jack detection 01’b: Mode-1, one port jack detection Others: Reserved 105 Rev. 0.91 ALC5672-VB Datasheet 10.67. MX-AEh: ADC Path EQ Control 1 Default: 6000’h Name Reserved ad_eq_param_update Bits 15 Table 82. MX-AEh: ADC Path EQ Control 1 Read/Write Reset State Description R 0’h Reserved 14 R/W 1’h Reserved Ad_eq_hpf1_status 13:6 5 R/W R 80’h 0’h Ad_eq_bpf4_status 4 R 0’h Ad_eq_bpf3_status 3 R 0’h Ad_eq_bpf2_status 2 R 0’h Ad_eq_bpf1_status 1 R 0’h Ad_eq_lpf_status 0 R 0’h ADC Path EQ Parameter Update Control 0’b: Busy (Waiting for cross) 1’b: Stand-by Write “1” to update parameter Reserved ADC Path EQ High Pass Filter (HPF1) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. ADC Path EQ Band-4 (BP4) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. ADC Path EQ Band-3 (BP3) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. ADC Path EQ Band-2 (BP2) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. ADC Path EQ Band-1 (BP1) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. ADC Path EQ Low Pass Filter (LPF) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. 106 Rev. 0.91 ALC5672-VB Datasheet 10.68. MX-AFh: ADC Path EQ Control 2 Default: 0000’h Name reserved Bits 15:9 Table 83. MX-AFh: ADC Path EQ Control 2 Read/Write Reset State Description R 0’h Reserved ad_eq_lpf_tpy 8 R/W 0’h ad_eq_hpf1_tpy 7 R/W 0’h Reserved 6 R 0’h ad_eq_hpf1_en 5 R/W 0’h ad_eq_bpf4_en 4 R/W 0’h Ad_eq_bpf3_en 3 R/W 0’h Ad_eq_bpf2_en 2 R/W 0’h Ad_eq_bpf1_en 1 R/W 0’h Ad_eq_lpf_en 0 R/W 0’h ADC Path 1st EQ Low Pass Filter Mode Control (LPF) 0’b: Low frequency shelving filter 1’b: 1st order Butterworth LPF (-20dB per decade) ADC Path 1st EQ High Pass Filter1 Mode Control (HPF1) 0’b: High frequency shelving filter 1’b: 1st order Butterworth HPF (-20dB per decade) Reserved ADC Path EQ 1st High Pass Filter (HPF1) Control. 0’b: Disabled (bypass) and reset 1’b: Enabled ADC Path 2nd EQ Band-4 (BP4) shelving Filter Control. 0’b: Disabled and reset 1’b: Enabled. ADC Path 2nd EQ Band-3 (BP3) shelving Filter Control. 0’b: Disabled and reset 1’b: Enabled. ADC Path 2nd EQ Band-2 (BP2) shelving Filter Control. 0’b: Disabled and reset 1’b: Enabled. ADC Path 2nd EQ Band-1 (BP1) shelving Filter Control. 0’b: Disabled and reset 1’b: Enabled. ADC Path 1st EQ Low Pass Filter (LPF) Filter Control. 0’b: Disabled and reset 1’b: Enabled. 107 Rev. 0.91 ALC5672-VB Datasheet 10.69. MX-B0h: DAC Path EQ Control 1 Default: 6000’h Name reserved Da_eq_param_update Bits 15 Table 84. MX-B0h: DAC Path EQ Control 1 Read/Write Reset State Description R 0’h Reserved 14 R/W 1’h reserved Da_eq_lpf1_status 13:8 7 R/W R 20’h 0’h Da_eq_hpf2_status 6 R 0’h Da_eq_hpf1_status 5 R 0’h Da_eq_bpf4_status 4 R 0’h Da_eq_bpf3_status 3 R 0’h Da_eq_bpf2_status 2 R 0’h Eq_biquad_wclr 1 R 0’h Reserved 0 R 0’h DAC Path EQ parameter update control 0’b: Busy (Waiting for cross) 1’b: Stand-by Write “1” to update parameter Reserved DAC Path EQ Low Pass Filter (LPF2) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. DAC Path EQ High Pass Filter (HPF2) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. DAC Path EQ High Pass Filter (HPF1) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. DAC Path EQ Band-4 (BP4) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. DAC Path EQ Band-3 (BP3) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. DAC Path EQ Band-2 (BP2) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. DAC Path EQ Band-1 (Biquad Type) Status. 0’b: Normal 1’b: Overflow. This bit is set if overflow had ever occurred. Write 1 to clear it. Reserved 108 Rev. 0.91 ALC5672-VB Datasheet 10.70. MX-B1h: EQ Control 2 Default: 0000’h Name reserved Table 85. MX-B1h: EQ Control 2 Bits Read/Write Reset State Description 15:14 R 0’h Reserved Da_eq_lpf1_tpy_r 13 R/W 0’h Da_eq_lpf1_tpy_l 12 R/W 0’h 11:10 R 0’h Da_eq_hpf1_tpy_r 9 R/W 0’h Da_eq_hpf1_tpy_l 8 R/W 0’h Da_eq_lpf1_en 7 R/W 0’h Da_eq_hpf2_en 6 R/W 0’h Da_eq_hpf1_en 5 R/W 0’h Da_eq_bpf4_en 4 R/W 0’h Da_eq_bpf3_en 3 R/W 0’h Da_eq_bpf2_en 2 R/W 0’h Eq_biquad_en 1 R/W 0’h Reserved 0 R 0’h Reserved DAC Path Right Channel 1st EQ Low Pass Filter Mode Control (LPF2) 0’b: Low frequency shelving filter 1’b: 1st order Butterworth LPF (-20dB per decade) DAC Path Left Channel 1st EQ Low Pass Filter Mode Control (LPF2) 0’b: Low frequency shelving filter 1’b: 1st order Butterworth LPF (-20dB per decade) Reserved DAC Path Right Channel 1st EQ High Pass Filter1 Mode Control 0’b: High frequency shelving filter 1’b: 1st order Butterworth HPF (-20dB per decade) DAC Path Left Channel 1st EQ High Pass Filter1 Mode Control 0’b: High frequency shelving filter 1’b: 1st order Butterworth HPF (-20dB per decade) DAC Path 1st EQ Low Pass Filter (LPF2) Filter Control. 0’b: Disabled and reset 1’b: Enabled. DAC Path EQ 2nd High Pass Butterworth Filter (HPF) Control. 0’b: Disabled (bypass) and reset 1’b: Enabled DAC Path EQ 1st High Pass Filter (HPF1) Control. 0’b: Disabled (bypass) and reset 1’b: Enabled DAC Path 2nd EQ Band-4 (BP4) shelving Filter Control. 0’b: Disabled and reset 1’b: Enabled. DAC Path 2nd EQ Band-3 (BP3) shelving Filter Control. 0’b: Disabled and reset 1’b: Enabled. DAC Path 2nd EQ Band-2 (BP2) shelving Filter Control. 0’b: Disabled and reset 1’b: Enabled. DAC Path 2nd EQ Band-1 (Biquad Type) shelving Filter Control. 0’b: Disabled and reset 1’b: Enabled. Reserved 109 Rev. 0.91 ALC5672-VB Datasheet 10.71. MX-B2h: DRC Control 1 Default: 0000’h Name Reserved Alc_thmin_fast_rc_e n Alc_thmin Bits 15:7 Table 86. MX-B2h: DRC Control 1 Read/Write Reset State Description R 0’h Reserved 6 R/W 0’h 5:0 R/W 0’h DRC THMIN Mode Fast Recover Control 0’b: Disable fast recover 1’b: Enable fast recover DRC THMIN Mode Threshold Level Control 00’h: -60dB 01’h: -60.75dB 02’h: -61.5dB … 2E’h: -94.5dB, 0.75dB/Step 10.72. MX-B3h: DRC Control 2 Default: 001F’h Name reserved Bits 15 Table 87. MX-B3h: DRC Control 2 Read/Write Reset State Description R 0’h Reserved Alc_noise_gate_ht 14:12 R/W 0’h alc_ft_boost 11:6 R/W 0’h alc_bk_gain_r 5:0 R/W 1f’h ALC Noise Gate Hold Time Control 000’b: 0 sample 001’b: 128 samples 010’b: 256 samples … 111’b: 896 samples ALC Digital Pre-BOOST (0.75dB/step) 00’h= 0dB 01’h= 0.75dB 02’h= 1.5dB 03’h= 2.25dB … 27’h= 29.25dBFS Others: Reserved ALC Right Channel Digital Post-BOOST (0.375dB/step) 00’h= -11.625dB … 3F’h= 12dB 110 Rev. 0.91 ALC5672-VB Datasheet 10.73. MX-B4h: DRC Control 3 Default: 2206’h Name sel_drc_agc Bits 15:14 Table 88. MX-B4h: DRC Control 3 Read/Write Reset State Description R/W 0’h DRC Enable Control 00’b: Disable DRC 01’b: Enable DRC to DAC Path 10’b: Disable DRC 11’b: Enable DRC to ADC Path update_drc_agc_para 13 R 1’h m sel_drc_agc_atk Update DRC Parameter Write 1’b to update all DRC parameter 12:8 R/W 2’h Select DRC attack rate (0.375dB/TU) 00’h: 83 uSec 01’h: 0.167 mSec … 10’h: 5.46 Sec Others: Reserved Drc_agc_rate_sel 7:5 R/W 0’h DRC Rate Control for Sample Rate Change 001’b: 48kHz 010’b: 96kHz 011’b: 192kHz 101’b: 44.1kHz 110’b: 88.2kHz 111’b: 176.4kHz Others: Reserved sel_rc_rate 4:0 R/W 6’h Select DRC recovery rate (0.375dB/TU) 00’h: 83 uSec 01’h: 0.167 mSec … 10’h: 5.46 Sec Others: Reserved  attack time=(4*2^n)/Sample_Rate, n=MX-B4[12:8], default=0.33mS  recovery time=(4*2^n)/Sample_Rate, n= MX-B4 [4:0], default=5.3mS  When change I2S’s sample rate, the DRC/AGC rate control is need to be changed same with I2S’s sample rate. When change the DRC/AGC rate, the parameter of DRC/AGC isn’t need be modified. When I2S’s sample rate is below 48kHz, that need to set the DRC/AGC rate to 48kHz and re-calculate the DRC/AGC’s parameter by I2S’s sample rate. 111 Rev. 0.91 ALC5672-VB Datasheet 10.74. MX-B5h: DRC Control 4 Default: 1F00’h Name Alc_drc_ratio_sel2 Bits 15:14 sel_drc_agc_post_bst 13:8 Table 89. MX-B5h: DRC Control 4 Read/Write Reset State Description R/W 0’h DRC Compression-2 Ratio Selection 00’b: 1:1 01’b: 1:2 10’b: 1:4 11’b: 1:8 R/W 1f’h DRC Digital Post-Boost Gain (0.375dB/step) 00’h= -11.625dB … 3F’h= 12dB Others: Reserved En_drc_agc_compres 7 R/W 0’h s DRC Compression Function Control 0’b: Disable 1’b: Enable Sel_ratio 6:5 R/W 0’h DRC Compression Ratio Selection 00’b: 1:1 01’b: 1:2 10’b: 1:4 11’b: 1:8 Alc_noise_gate_drop _en 4 R/W 0’h Reserved 3:2 R 0’h noise_gate_ratio_sel 1:0 R/W 0’h Gain table: DRC Noise Gate Drop Mode Control 0’b: Disable 1’b: Enable Reserved DRC Expansion Ratio Control when Noise Gate is Enabled 00’b: 1:1 01’b: 2:1 10’b: 4:1 11’b: 8:1 DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain DEC HEX Boost Gain 0 0 -11.625 16 10 -5.625 32 20 0.375 48 30 6.375 64 40 1 1 -11.25 17 11 -5.25 33 21 0.75 49 31 6.75 65 41 2 2 -10.875 18 12 -4.875 34 22 1.125 50 32 7.125 66 42 3 3 -10.5 19 13 -4.5 35 23 1.5 51 33 7.5 67 43 4 4 -10.125 20 14 -4.125 36 24 1.875 52 34 7.875 68 44 5 5 -9.75 21 15 -3.75 37 25 2.25 53 35 8.25 69 45 6 6 -9.375 22 16 -3.375 38 26 2.625 54 36 8.625 70 46 112 Rev. 0.91 ALC5672-VB Datasheet 7 7 -9 23 17 -3 39 27 3 55 37 9 71 47 8 8 -8.625 24 18 -2.625 40 28 3.375 56 38 9.375 72 48 9 9 -8.25 25 19 -2.25 41 29 3.75 57 39 9.75 73 49 10 A -7.875 26 1A -1.875 42 2A 4.125 58 3A 10.125 74 4A 11 B -7.5 27 1B -1.5 43 2B 4.5 59 3B 10.5 75 4B 12 C -7.125 28 1C -1.125 44 2C 4.875 60 3C 10.875 76 4C 13 D -6.75 29 1D -0.75 45 2D 5.25 61 3D 11.25 14 E -6.375 30 1E -0.375 46 2E 5.625 62 3E 11.625 15 F -6 31 1F 0 47 2F 6 63 3F 12 10.75. MX-B6h: DRC Control 5 Default: 0000’h Name Noise_gate_boost Bits 15:12 Table 90. MX-B6h: DRC Control 5 Read/Write Reset State Description R/W 0’h Select Compensation Gain When Signal is Below Noise Gate 0’h: 0dB 1’h: 3dB 2’h: 6dB … E’h: 42dB F’h: 45dB Reserved en_drc_agc_noise_ga 11:7 R 0’h Reserved 6 R/W 0’h Enable Noise Gate function te 0’b: Diaable 1’b: Enable En_drc_agc_noise_ga 5 R/W 0’h te_hold Enable Noise Gate Hold Data Function 0’b: Disable 1’b: Enable sel_drc_agc_noise_th 4:0 R/W 0’h Noise Gate Threshold (-1.5dB/step) 00’h: -24dBFS 01’h: -25.5dBFS ……………….. 1F’h: -70.5 dBFS 113 Rev. 0.91 ALC5672-VB Datasheet 10.76. MX-B7h: DRC Control 6 Default: 0000’h Name Reserved alc_thmax2 Bits 15:12 11:6 alc_thmax 5:0 Table 91. MX-B7h: DRC Control 6 Read/Write Reset State Description R 0’h Reserved R/W 0’h DRC Limiter Threshold 2 Control (0.75dB/step) 00’h= 0dBFS 01’h= -0.75dBFS 02’h= -1.5dBFS 03’h= -2.25dBFS ……………….. 1F’h= -45dBFS R/W 0’h DRC Limiter Threshold Control (0.375dB/step) 00’h= 0dBFS 01’h= -0.375dBFS 02’h= -0.75dBFS 03’h= -1.125dBFS ……………….. 1F’h= -23.625dBFS 10.77. MX-BBh: Jack Detection Control 1 Default: 0000’h Name sel_gpio_jd1 Bits 15:13 reserved en_jd_hpo 12 11 polarity_jd_tri_hpo 10 en_jd_spk_l 9 Table 92. MX-BBh: Jack Detection Control 1 Read/Write Reset State Description R/W 0’h GPIO Jack Detect – 1 Source Selection 000’b: OFF 001’b: GPIO3 010’b: GPIO4 011’b: GPIO5 100’b: GPIO6 101’b: Reserved 110’b: Reserved 111’b: Reserved R 0’h reserved R/W 0’h Enable jack detect trigger HPOUT 0’b: Disable 1’b: Enable R/W 0’h Select jack detect polarity trigger HPOUT 0’b: Low trigger 1’b: High trigger R/W 0’h Enable jack detect trigger SPK_L 0’b: Disable 1’b: Enable 114 Rev. 0.91 ALC5672-VB Datasheet Name polarity_jd_tri_spk_l Bits 8 Read/Write R/W en_jd_spk_r 7 R/W polarity_jd_tri_spk_r 6 R/W 5:4 3 R/W R/W 2 R/W 1:0 R Reserved en_jd_lout1 polarity_jd_tri_lout1 Reserved Reset State Description 0’h Select jack detect polarity trigger SPK_L 0’b: Low trigger 1’b: High trigger 0’h Enable jack detect trigger SPK_R 0’b: Disable 1’b: Enable 0’h Select jack detect polarity trigger SPK_R 0’b: Low trigger 1’b: High trigger 0’h Reserved 0’h Enable jack detect trigger LOUT1 0’b: Disable 1’b: Enable 0’h Select jack detect polarity trigger LOUT1 0’b: Low trigger 1’b: High trigger 0’h Reserved 10.78. MX-BDh: IRQ Control 1 Default: 0000’h Name en_irq_gpio_jd1 Bits 15 en_gpio_jd1_sticky 14 inv_gpio_jd1 13 reserved en_irq_jd1_1 12:10 9 en_jd1_1_sticky 8 inv_jd1_1 7 Table 93. MX-BDh: IRQ Control 1 Read/Write Reset State Description R/W 0’h IRQ Output Source Configure of GPIO Jack Detection 1 Status 0’b: bypass 1’b: Normal R/W 0’h Sticky Control for GPIO Jack Detect 1 0’b: Disable 1’b: Enable R/W 0’h GPIO Jack Detection 1 Status Polarity 0’b: Normal 1’b: Output Invert R/W 0’h Reserved R/W 0’h IRQ Output Source Configure of JD1_1 Jack Detection Status 0’b: bypass 1’b: Normal R/W 0’h Sticky Control for JD1_1 Jack Detect 0’b: Disable 1’b: Enable R/W 0’h JD1_1 Jack Detection Status Polarity 0’b: Normal 1’b: Output Invert 115 Rev. 0.91 ALC5672-VB Datasheet Name en_irq_jd1_2 Bits 6 Read/Write R/W en_jd1_2_sticky 5 R/W inv_jd1_2 4 R/W en_irq_jd2 3 R/W en_jd2_sticky 2 R/W inv_jd2 1 R/W reserved 0 R Reset State Description 0’h IRQ Output Source Configure of JD1_2 Jack Detection Status 0’b: bypass 1’b: Normal 0’h Sticky Control for JD1_2 Jack Detect 0’b: Disable 1’b: Enable 0’h JD1_2 Jack Detection Status Polarity 0’b: Normal 1’b: Output Invert 0’h IRQ Output Source Configure of JD2 Jack Detection Status 0’b: bypass 1’b: Normal 0’h Sticky Control for JD2 Jack Detect 0’b: Disable 1’b: Enable 0’h JD2 Jack Detection Status Polarity 0’b: Normal 1’b: Output Invert 0’h Reserved 10.79. MX-BEh: IRQ Control 2 Default: 0000’h Name en_irq_micbias1_ovc d Bits 15 reserved en_micbias1_ovcd_st icky 14 13 reserved inv_micbias1_ovcd 12 11 reserved Sta_micbias1_ovcd 10 9 reserved 8:0 Table 94. MX-BEh: IRQ Control 2 Read/Write Reset State Description R/W 0’h IRQ Output Source Configure of MICBIAS1 Over Current Status 0’b: bypass 1’b: Normal R/W 0’h Reserved R/W 0’h Sticky Control for MICBIAS1 Over Current 0’b: Disable 1’b: Enable R/W 0’h Reserved R/W 0’h MICBIAS1 over current status polarity 0’b: Normal 1’b: Output Invert R/W 0’h Reserved R 0’h MICBIAS1 over current status Read: return status of each status pin Write: Write ‘0’ to clear stick bit R/W 0’h Reserved 116 Rev. 0.91 ALC5672-VB Datasheet 10.80. MX-BFh: IRQ Control 3 Default: 0000’h Name reserved sta_jd2 Bits 15 14 sta_jd1_2 13 sta_jd1_1 12 reserved sta_gpio6 11 10 sta_gpio5 9 sta_gpio1 8 sta_gpio2 7 sta_gpio3 6 sta_gpio4 5 sta_gpio_jd1 4 en_irq_inline 3 sta_inline 2 en_inline_sticky 1 inv_inline 0 Table 95. MX-BFh: IRQ Control 3 Read/Write Reset State Description R 0’h Reserved R 0’h Status of JD2 Jack detection . Read: Return status of Jack Detect Select output Write: Write ‘0’ to clear stick bit R 0’h Status of JD1_2 Jack detection . Read: Return status of Jack Detect Select output Write: Write ‘0’ to clear stick bit R 0’h Status of JD1_1 Jack detection . Read: Return status of Jack Detect Select output Write: Write ‘0’ to clear stick bit R 0’h Reserved R 0’h GPIO6 Pin Status Read: return status of each GPIO pin R 0’h GPIO5 Pin Status Read: return status of each GPIO pin R 0’h GPIO1 Pin Status Read: return status of each GPIO pin R 0’h GPIO2 Pin Status Read: return status of each GPIO pin R 0’h GPIO3 Pin Status Read: return status of each GPIO pin R 0’h GPIO4 Pin Status Read: return status of each GPIO pin R 0’h Status of GPIO Jack detection 1 Read: Return status of Jack Detect Select output Write: Write ‘0’ to clear stick bit R/W 0’h IRQ Output Source Configure of InLine Command Status 0’b: bypass 1’b: Normal R 0’h Status of InLine Command Trigger Read: Return status of InLine Command Trigger Write: Write ‘0’ to clear stick bit R/W 0’h Sticky Control for InLine Command 0’b: Disable 1’b: Enable R/W 0’h InLine Command Status Polarity 0’b: Normal 1’b: Output Invert 10.81. MX-C0h: GPIO Control 1 Default: 0000’h 117 Rev. 0.91 ALC5672-VB Datasheet Name sel_gpio1_type Bits 15 sel_gpio2_type 14 Reserved Sel_i2s2_pin 13:9 8 sel_gpio5_type 7 sel_gpio6_type 6 Reserved 5:0 Table 96. MX-C0h: GPIO Control 1 Read/Write Reset State Description R/W 0’h GPIO1 Pin Function Select 0’b: GPIO1 1’b: IRQ output R/W 0’h GPIO2 Pin Function Select 0’b: GPIO2 1’b: DMIC1_SCL R/W 0’h Reserved R/W 0’h I2S-2 Pin Function Selection 0’b: I2S function pins 1’b: GPIO function pins R/W 0’h GPIO5 Pin Function Select 0’b: GPIO5 1’b: DMIC3_SDA R/W 0’h GPIO6 Pin Function Select 0’b: GPIO6 1’b: DMIC1_SDA R/W 0’h Reserved 10.82. MX-C1h: GPIO Control 2 Default: 0000’h Name reserved sel_gpio5 Bits 15 14 sel_gpio5_logic 13 inv_gpio5 12 sel_gpio4 11 sel_gpio4_logic 10 inv_gpio4 9 sel_gpio3 8 Table 97. MX-C1h: GPIO Control 2 Read/Write Reset State Description R/W 0’h Reserved R/W 0’h GPIO5 Pin Configuration 0’b: Input 1’b: Output R/W 0’h GPIO5 Output Pin Control 0’b: Drive Low 1’b: Drive High R/W 0’h GPIO5 Pin Polarity 0’b: Normal 1’b: Output Invert R/W 0’h GPIO4 Pin Configuration 0’b: Input 1’b: Output R/W 0’h GPIO4 Output Pin Control 0’b: Drive Low 1’b: Drive High R/W 0’h GPIO4 Pin Polarity 0’b: Normal 1’b: Output Invert R/W 0’h GPIO3 Pin Configuration 0’b: Input 1’b: Output 118 Rev. 0.91 ALC5672-VB Datasheet Name sel_gpio3_logic Bits 7 Read/Write R/W inv_gpio3 6 R/W sel_gpio2 5 R/W sel_gpio2_logic 4 R/W inv_gpio2 3 R/W sel_gpio1 2 R/W sel_gpio1_logic 1 R/W inv_gpio1 0 R/W Reset State Description 0’h GPIO3 Output Pin Control 0’b: Drive Low 1’b: Drive High 0’h GPIO3 Pin Polarity 0’b: Normal 1’b: Output Invert 0’h GPIO2 Pin Configuration 0’b: Input 1’b: Output 0’h GPIO2 Output Pin Control 0’b: Drive Low 1’b: Drive High 0’h GPIO2 Pin Polarity 0’b: Normal 1’b: Output Invert 0’h GPIO1 Pin Configuration 0’b: Input 1’b: Output 0’h GPIO1 Output Pin Control 0’b: Drive Low 1’b: Drive High 0’h GPIO1 Pin Polarity 0’b: Normal 1’b: Output Invert 10.83. MX-C2h: GPIO Control 3 Default: 0000’h Name reserved sel_gpio6 Bits 15:3 2 sel_gpio6_logic 1 inv_gpio6 0 Table 98. MX-C2h: GPIO Control 3 Read/Write Reset State Description R/W 0’h Reserved R/W 0’h GPIO6 Pin Configuration 0’b: Input 1’b: Output R/W 0’h GPIO6 Output Pin Control 0’b: Drive Low 1’b: Drive High R/W 0’h GPIO6 Pin Polarity 0’b: Normal 1’b: Output Invert 119 Rev. 0.91 ALC5672-VB Datasheet 10.84. MX-CFh: SounzRealTM BassBack Control Default: 0013’h TM Name En_bb Bits 15 Sel_bb_coef 14:12 Reserved Bb_boost_gain 11:6 5:0 Table 99. MX-CFh: SounzReal BassBack Control Read/Write Reset State Description R/W 0’h Enable BassBack Function 0’b: Disable 1’b: Enable R/W 0’h Select Control for BassBack Coefficient Type 000’b: Type A 001’b: Type B 010’b: Type C 011’b: Type D 1xx’b: Reserved R 0’h Reserved R/W 13’h Select Control BassBack Boost Gain 000001’b: 1.5dB 000010’b: 3dB ……… 010011’b: 24dB ……… 011111’b: 42dB, with 1.5dB/Step 10.85. MX-D0h: SounzRealTM TruTreble Control 1 Default: 0680’h TM Name reserved En_mp Mp_eg reserved  Eg 1 Table 100. MX-D0h: SounzReal TruTreble Control 1 Bits Read/Write Reset State Description 15:14 R/W 0’h Reserved 13 R/W 0’h Enable TruTreble Function 0’b: Disable 1’b: Enable 12:8 R/W 6’h TruTreble Enhanced Gain Control  00000’b: -11.625dB 00001’b: -10.5dB ………. 00110’b: -3dB ........... 10100’b: 7.5dB 7:0 R/W 80’h Reserved Enhanced Gain Eg Enhanced Gain -11.625dB 11 2.25 dB 120 Rev. 0.91 ALC5672-VB Datasheet 2 -10.5 dB 12 3 dB 3 -9 dB 13 3.75 dB 4 -6.75 dB 14 4.5 dB 5 -4.5 dB 15 4.875 dB 6 -3 dB 16 5.625 dB 7 -1.875 dB 17 6 dB 8 -0.375 dB 18 6.375 dB 9 0.375 dB 19 7.125 dB 10 1.5 dB 20 7.5 dB 10.86. MX-D1h: SounzRealTM TruTreble Control 2 Default: 1C17’h TM Name reserved mp_hp_wt mp_og reserved mp_hg Table 101. MX-D1h: SounzReal l TruTreble Control 2 Bits Read/Write Reset State Description 15:14 R 0’h Reserved 13 R/W 0’h Select The Harmonic Weighting 0’b: a = 1/4(default) 1’b: a = 1/2 12:8 R/W 1C’h Select The Origin Signal Gain 00000’b: -5.8125dB 00001’b: -5.625dB … 10111’b: -0.5625 dB ... 11111’b: 12dB, with 0.1875dB/Step 7:6 R 0’h Reserved 5:0 R/W 17’h Select High Frequency Harmonic Gain 000000’b: -11.625dB 000001’b: -11.25dB … 010111’b: -3dB ... 111111’b: 12dB, with 0.375dB/Step (0.375 /step) 10.87. MX-D3h: Stereo1 ADC Wind Filter Control 1 Default: A220’h Name adj_hpf_2nd_en_stere o1 Table 102. MX-D3h: Stereo1 ADC Wind Filter Control 1 Bits Read/Write Reset State Description 15 R/W 1’h Stereo1 ADC Wind Filter Enable Control 0’b : Disable and bypass 1’b : Enable 121 Rev. 0.91 ALC5672-VB Datasheet Name Bits adj_hpf_coef_l_sel_st 14:12 ereo1 Read/Write R/W Reserved adj_hpf_coef_r_sel_st ereo1 11 10:8 R R/W reserved 7:0 R/W Reset State Description 2’h Stereo1 ADC Wind Filter Left Channel Coefficient Coarse Selection 000’b : fs=8k, fc = 20~2000Hz fs=12k, fc = 30~3000Hz fs=16k, fc = 40~4000Hz 001’b : fs=24k, fc = 30~2458Hz fs=32k, fc = 40~3278Hz 010’b : fs=44.1k, fc = 28~1992Hz fs=48k, fc = 30~2168Hz 011’b : fs=88.2k, fc = 28~1869Hz fs=96k, fc = 30~2034Hz 100’b : fs=176.4k, fc = 27~1811Hz fs=192k, fc = 30~1971Hz Others: Reserved 0’h Reserved 2’h Stereo1 ADC Wind Filter Right Channel Coefficient Coarse Selection 000’b : fs=8k, fc = 20~2000Hz fs=12k, fc = 30~3000Hz fs=16k, fc = 40~4000Hz 001’b : fs=24k, fc = 30~2458Hz fs=32k, fc = 40~3278Hz 010’b : fs=44.1k, fc = 28~1992Hz fs=48k, fc = 30~2168Hz 011’b : fs=88.2k, fc = 28~1869Hz fs=96k, fc = 30~2034Hz 100’b : fs=176.4k, fc = 27~1811Hz fs=192k, fc = 30~1971Hz Others: Reserved 20’h Reserved 10.88. MX-D4h: Stereo1 ADC Wind Filter Control 2 Default: 0000’h Name reserved Table 103. MX-D4h: Stereo1 ADC Wind Filter Control 2 Bits Read/Write Reset State Description 15:14 R 0’h Reserved 122 Rev. 0.91 ALC5672-VB Datasheet Name adj_hpf_coef_l_num_ stereo1 reserved adj_hpf_coef_r_num_ stereo1 Bits 13:8 Read/Write R/W 7:6 5:0 R R/W Reset State Description 0’h Stereo1 ADC Wind Filter Right Channel Coefficient Fine Selection (0~63) 0’h Reserved 0’h Stereo1 ADC Wind Filter Left Channel Coefficient Fine Selection (0~63) 10.89. MX-D9h: Soft Volume & ZCD Control 1 Default: 0809’h Name en_softvol Bits 15 reserved en_o_svol 14 13 en_hpo_svol 12 en_zcd_digital 11 pow_zcd 10 reserved sel_svol 9:4 3:0 Table 104. MX-D9h: Soft Volume & ZCD Control 1 Read/Write Reset State Description R/W 0’h Digital Soft Volume Delay Control 0’b: Disable 1’b: Enable R/W 0’h Reserved R/W 0’h OUTVOLL/R Soft Volume Delay Control 0’b: Disable 1’b: Enable R/W 0’h HPOVOLL/R Soft Volume Delay Control 0’b: Disable 1’b: Enable R/W 1’h Digital Volume Zero Crossing Detection Control 0’b: Disable 1’b: Enable R/W 0’h Power On Zero Crossing 0’b: Power Down 1’b: Power On R 0’h Reserved R/W 9’h Soft Volume Change Delay Time 0000: 1 SVSYNC 0001: 2 SVSYNC 0010: 4 SVSYNC 0011: 8 SVSYNC 0100: 16 SVSYNC 0101: 32 SVSYNC 0110: 64 SVSYNC 0111: 128 SVSYNC 1000: 256 SVSYNC 1001: 512 SVSYNC 1010: 1024 SVSYNC Others: Reserved Note: SVSYNC=1/Fs, Step:-1.5dBFS 123 Rev. 0.91 ALC5672-VB Datasheet 10.90. MX-DAh: Soft Volume & ZCD Control 2 Default: 0000’h Name reserved en_zcd_outmixr en_zcd_outmixl en_zcd_hpmixr en_zcd_hpmixl reserved en_zcd_recmixr en_zcd_recmixl Table 105. MX-DAh: Soft Volume & ZCD Control 2 Bits Read/Write Reset State Description 15:7 R/W 0’h Reserved 6 R/W 0’h OUTMIXR ZCD Control 0’b: Disable 1’b: Enable 5 R/W 0’h OUTMIXL ZCD Control 0’b: Disable 1’b: Enable 4 R/W 0’h HPMIXR ZCD Control 0’b: Disable 1’b: Enable 3 R/W 0’h HPMIXL ZCD Control 0’b: Disable 1’b: Enable 2 R/W 0’h Reserved 1 R/W 0’h RECMIXR ZCD Control 0’b: Disable 1’b: Enable 0 R/W 0’h RECMIXL ZCD Control 0’b: Disable 1’b: Enable 10.91. MX-DBh: Inline Command Control 1 Default: 0001’h Name sta_one_up_button Bits 15 sta_double_up_button 14 sta_hold_up_button 13 sta_one_center_butto n sta_double_center_bu tton sta_hold_center_butto n sta_one_down_button 12 sta_double_down_but ton 8 11 10 9 Table 106. MX-DBh: Inline Command Control 1 Read/Write Reset State Description R 0’h Status of One Click Command for Up Button Write “1” to clear it R 0’h Status of Double Click Command for Up Button Write “1” to clear it R 0’h Status of Hold Command for Up Button Write “1” to clear it R 0’h Status of One Click Command for Center Button Write “1” to clear it R 0’h Status of Double Click Command for Center Button Write “1” to clear it R 0’h Status of Hold Command for Center Button Write “1” to clear it R 0’h Status of One Click Command for Down Button Write “1” to clear it R 0’h Status of Double Click Command for Down Button Write “1” to clear it 124 Rev. 0.91 ALC5672-VB Datasheet Name sta_hold_down_butto n En_inline Bits 7 Read/Write R 6 R/W reserved Sel_clk_mic 5 4:3 R R/W Mic_in_det_0_th 2:0 R/W Reset State Description 0’h Status of Hold Command for Down Button Write “1” to clear it 0’h Enable InLine Command 0’b: Disable 1’b: Enable 0’h Reserved 0’h Select InLine Command Debounce Clock 00’b: OSC/2^17 01’b: OSC/2^16 10’b: OSC/2^15 11’b: OSC/2^14 1’h MIC Input Voltage Threshold Control (CMP0) 000’b: 0.09V 001’b: 0.12V 010’b: 0.15V 011’b: 0.18V 100’b: 0.17V 101’b: 0.23V 110’b: 0.29V 111’b: 0.34V 10.92. MX-DCh: Inline Command Control 2 Default: 0049’h Name en_inline_vol Bits 15 sel_inline_ctl_if 14 Conti_hold_up 13 Conti_hold_center 12 Conti_hold_down 11 in_det_window 10:0 Table 107. MX-DCh: Inline Command Control 2 Read/Write Reset State Description R/W 0’h Enable Inline Command Direct to Control Digital Volume 0’b: Disable 1’b: Enable R/W 0’h Select The Inline Command Control Path 0’b: IF1 DAC Volume/Mute(Un-Mute) 1’b: IF2 DAC Volume/Mute(Un-Mute) R/W 0’h Select Hold Command Behavior for Up Button 0’b: One pulse trigger 1’b: Continue pulse trigger R/W 0’h Select Hold Command Behavior for Center Button 0’b: One pulse trigger 1’b: Continue pulse trigger R/W 0’h Select Hold Command Behavior for Down Button 0’b: One pulse trigger 1’b: Continue pulse trigger Inline Command Click Window Control R/W 49’h MX-DB[4:3]=00’b => (1/OSC)*16384*n MX-DB[4:3]=01’b => (1/OSC)*8192*n MX-DB[4:3]=10’b => (1/OSC)*4096*n MX-DB[4:3]=11’b => (1/OSC)*2048*n (n=0~127) 125 Rev. 0.91 ALC5672-VB Datasheet 10.93. MX-DDh: Inline Command Control 3 Default: 0009’h Name Reserved Mic_in_det_1_th Bits 15:6 5:3 Mic_in_det_2_th 2:0 Table 108. MX-DDh: Inline Command Control 3 Read/Write Reset State Description R 0’h Reserved R/W 1’h MIC Input Voltage Threshold Control (CMP1) 000’b: 0.36V 001’b: 0.39V 010’b: 0.42V 011’b: 0.45V 100’b: 0.68V 101’b: 0.74V 110’b: 0.80V 111’b: 0.86V R/W 1’h MIC Input Voltage Threshold Control (CMP2) 000’b: 0.69V 001’b: 0.71V 010’b: 0.74V 011’b: 0.77V 100’b: 1.31V 101’b: 1.37V 110’b: 1.43V 111’b: 1.48V 10.94. MX-E0h: Voice DSP Control 1 Default: 0000’h Name Aec_cmd dsp_clk_sel Bits 15:8 7:6 Aec_busy 5 Sel_dsp_cmd 4 Table 109. MX-E0h: Voice DSP Control 1 Read/Write Reset State Description R/W 0’h Voice DSP Command R/W 0’h Voice DSP Control Interface Clock Select 00’b: SYSCLK/3/16 01’b: SYSCLK/4/16 10’b: SYSCLK/6/16 11’b: SYSCLK/8/16 R 0’h Voice DSP R/W Busy 0’b: Normal 1’b: Busy R/W 0’h Voice DSP R/W Command 0’b: Write 1’b: Read 126 Rev. 0.91 ALC5672-VB Datasheet Name Sel_dsp_data_len Bits 3:2 Read/Write R/W Sel_dsp_addr_len 1 R/W Aec_cmd_start 0 R/W Reset State Description 0’h Voice DSP Control Interface Data Length 00’b: 0 byte 01’b: 1 byte 10’b: 2 byte 11’b: 3 byte 0’h Voice DSP Control Interface Address Length 0’b: 8 bit 1’b: 16 bit 0’h Write “1” to start Voice DSP Control Interface Command 10.95. MX-E1h: Voice DSP Control 2 Default: 0000’h Name Aec_addr Bits 15:0 Table 110. MX-E1h: Voice DSP Control 2 Read/Write Reset State Description R/W 0’h Voice DSP Address 10.96. MX-E2h: Voice DSP Control 3 Default: 0000’h Name Aec_write_data Bits 15:0 Table 111. MX-E2h: Voice DSP Control 3 Read/Write Reset State Description R/W 0’h Voice DSP Write Data 10.97. MX-E3h: Voice DSP Control 4 Default: 0000’h Name Reserved Aec_write_data2 Bits 15:8 7:0 Table 112. MX-E3h: Voice DSP Control 4 Read/Write Reset State Description R 0’h Reserved R/W 0’h Voice DSP Write Data 127 Rev. 0.91 ALC5672-VB Datasheet 10.98. MX-E4h: Voice DSP Control 5 Default: 0000’h Name read_data_aec Bits 15:0 Table 113. MX-E4h: Voice DSP Control 5 Read/Write Reset State Description R 0’h Voice DSP Read Data 10.99. MX-E5h: Voice DSP Control 6 Default: 0000’h Name Reserved read_data_aec2 Bits 15:8 7:0 Table 114. MX-E5h: Voice DSP Control 6 Read/Write Reset State Description R 0’h Reserved R 0’h Voice DSP Read Data 10.100. MX-ECh: Mono ADC Wind Filter Control 1 Default: A200’h Name adj_hpf_2nd_en_mon o adj_hpf_coef_l_sel_ mono Reserved Table 115. MX-ECh: Mono ADC Wind Filter Control 1 Read/Write Reset State Description R/W 1’h Mono ADC Wind Filter Enable Control 0’b : Disable and bypass 1’b : Enable 14:12 R/W 2’h Mono ADC Wind Filter Left Channel Coefficient Coarse Selection 000’b : fs=8k, fc = 20~2000Hz fs=12k, fc = 30~3000Hz fs=16k, fc = 40~4000Hz 001’b : fs=24k, fc = 30~2458Hz fs=32k, fc = 40~3278Hz 010’b : fs=44.1k, fc = 28~1992Hz fs=48k, fc = 30~2168Hz 011’b : fs=88.2k, fc = 28~1869Hz fs=96k, fc = 30~2034Hz 100’b : fs=176.4k, fc = 27~1811Hz fs=192k, fc = 30~1971Hz Others: Reserved 11 R 0’h Reserved Bits 15 128 Rev. 0.91 ALC5672-VB Datasheet Name adj_hpf_coef_r_sel_ mono Bits 10:8 Read/Write R/W reserved 7:0 R Reset State Description 2’h Mono ADC Wind Filter Right Channel Coefficient Coarse Selection 000’b : fs=8k, fc = 20~2000Hz fs=12k, fc = 30~3000Hz fs=16k, fc = 40~4000Hz 001’b : fs=24k, fc = 30~2458Hz fs=32k, fc = 40~3278Hz 010’b : fs=44.1k, fc = 28~1992Hz fs=48k, fc = 30~2168Hz 011’b : fs=88.2k, fc = 28~1869Hz fs=96k, fc = 30~2034Hz 100’b : fs=176.4k, fc = 27~1811Hz fs=192k, fc = 30~1971Hz Others: Reserved 0’h Reserved 10.101. MX-EDh: Mono ADC Wind Filter Control 2 Default: 0000’h Table 116. MX-EDh: Mono ADC Wind Filter Control 2 Name Bits Read/Write Reset State Description reserved 15:14 R 0’h Reserved adj_hpf_coef_l_num_ 13:8 R/W 0’h Mono ADC Wind Filter Right Channel Coefficient Fine mono Selection (0~63) Reserved 7:6 R 0’h Reserved adj_hpf_coef_r_num_ 5:0 R/W 0’h Mono ADC Wind Filter Left Channel Coefficient Fine mono Selection (0~63) 10.102. MX-EEh: Stereo2 ADC Wind Filter Control 1 Default: A200’h Name adj_hpf_2nd_en_stere o2 Table 117. MX-EEh: Stereo2 ADC Wind Filter Control 1 Bits Read/Write Reset State Description 15 R/W 1’h Stereo2 ADC Wind Filter Enable Control 0’b : Disable and bypass 1’b : Enable 129 Rev. 0.91 ALC5672-VB Datasheet Name Bits adj_hpf_coef_l_sel_st 14:12 ereo2 Read/Write R/W Reserved adj_hpf_coef_r_sel_st ereo2 11 10:8 R R/W reserved 7:0 R Reset State Description 2’h Stereo2 ADC Wind Filter Left Channel Coefficient Coarse Selection 000’b : fs=8k, fc = 20~2000Hz fs=12k, fc = 30~3000Hz fs=16k, fc = 40~4000Hz 001’b : fs=24k, fc = 30~2458Hz fs=32k, fc = 40~3278Hz 010’b : fs=44.1k, fc = 28~1992Hz fs=48k, fc = 30~2168Hz 011’b : fs=88.2k, fc = 28~1869Hz fs=96k, fc = 30~2034Hz 100’b : fs=176.4k, fc = 27~1811Hz fs=192k, fc = 30~1971Hz Others: Reserved 0’h Reserved 2’h Stereo2 ADC Wind Filter Right Channel Coefficient Coarse Selection 000’b : fs=8k, fc = 20~2000Hz fs=12k, fc = 30~3000Hz fs=16k, fc = 40~4000Hz 001’b : fs=24k, fc = 30~2458Hz fs=32k, fc = 40~3278Hz 010’b : fs=44.1k, fc = 28~1992Hz fs=48k, fc = 30~2168Hz 011’b : fs=88.2k, fc = 28~1869Hz fs=96k, fc = 30~2034Hz 100’b : fs=176.4k, fc = 27~1811Hz fs=192k, fc = 30~1971Hz Others: Reserved 0’h Reserved 130 Rev. 0.91 ALC5672-VB Datasheet 10.103. MX-EFh: Stereo2 ADC Wind Filter Control 2 Default: 0000’h Table 118. MX-EFh: Stereo2 ADC Wind Filter Control 2 Name Bits Read/Write Reset State Description Reserved 15:14 R 0’h Reserved adj_hpf_coef_l_num_ 13:8 R/W 0’h Stereo2 ADC Wind Filter Right Channel Coefficient Fine stereo2 Selection (0~63) Reserved 7:6 R 0’h Reserved adj_hpf_coef_r_num_ 5:0 R/W 0’h Stereo2 ADC Wind Filter Left Channel Coefficient Fine stereo2 Selection (0~63) 10.104. MX-F8h: Jack Detection Control Default: 0000’h Name reserved en_jd_combo_jack Bits 15:8 7 polarity_jd_tri_cbj 6 Sel_jd_trigger_cbj 5:3 Sel_jd_trigger_hpo 2:0 Table 119. MX-F8h: Jack Detection Control Read/Write Reset State Description R 0’h Reserved R/W 0’h Enable Jack Detect to Trigger Combo Jack 0’b: Disable 1’b: Enable R/W 0’h Select Jack Detect Polarity to Trigger Combo Jack 0’b: Low trigger 1’b: High trigger R/W 0’h JD Trigger Source Selection for Combo Jack 000’b: From sta_gpio_jd1 001’b: From sta_jd1_1 010’b: From sta_jd1_2 011’b: From sta_jd2 100’b: Reserved 101’b: Reserved 110’b: From MX0B[12] Others: Reserved R/W 0’h JD Trigger Source Selection for HPO 000’b: From sta_gpio_jd1 001’b: From sta_jd1_1 010’b: From sta_jd1_2 011’b: From sta_jd2 100’b: Reserved 101’b: Reserved Others: Reserved 131 Rev. 0.91 ALC5672-VB Datasheet 10.105. MX-F9h: Jack Detection Control Default: 0000’h Name reserved Sel_jd_trigger_spk Bits 15:12 11:9 Reserved Sel_jd_trigger_lout1 8:6 5:3 Reserved 2:0 Table 120. MX-F9h: Jack Detection Control Read/Write Reset State Description R 0’h Reserved R/W 0’h JD Trigger Source Selection for SPK_OUT 000’b: From sta_gpio_jd1 001’b: From sta_jd1_1 010’b: From sta_jd1_2 011’b: From sta_jd2 100’b: Reserved 101’b: Reserved Others: Reserved R 0’h Reserved R/W 0’h JD Trigger Source Selection for LOUT1 000’b: From sta_gpio_jd1 001’b: From sta_jd1_1 010’b: From sta_jd1_2 011’b: From sta_jd2 100’b: Reserved 101’b: Reserved Others: Reserved R/W 0’h Reserved 10.106. MX-FAh: General Control 1 Default: 8010’h Name Reserved Rst_dsp Bits 15:14 13 Sel_if1_adc1_data_in 1 12 Sel_if1_adc1_data_in 2 11 Sel_if1_adc2_data_in 1 10 Reserved 9:4 Table 121. MX-FAh: General Control 1 Read/Write Reset State Description R/W 2’h Reserved R/W 0’h Voice DSP Reset Control 0’b: Normal 1’b: Reset R/W 0’h Selection-1 for IF1 ADC1 Input Data 0’b: IF_ADC1 1’b: IF_ADC3 R/W 0’h Selection-2 for IF1 ADC1 Input Data 0’b: IF_ADC1 or IF1_ADC3 1’b: TxDP_ADC R/W 0’h Selection for IF1 ADC2 Input Data 0’b: IF_ADC2 1’b: TxDP_ADC R/W 1’h Reserved 132 Rev. 0.91 ALC5672-VB Datasheet Name En_detect_clk_sys Bits 3 Read/Write R/W Reserved digital_gate_ctrl 2:1 0 R R/W Reset State Description 0’h Enable MCLK Detection and Auto Switch to RC Clock When MCLK is Remove 0’b: Disable 1’b: Enable 0’h Reserved 0’h Enable MCLK Gating Control 0’b: Disable 1’b: Enable 10.107. MX-FBh: General Control 2 Default: 0033’h Name Reserved Sel_adcdat1 Reserved Sel_headset_mode Bits 15 14 13:12 11 Sel_pow_capless 10 En_sel_in1_p 9 En_sel_in1_n 8 Reserved Hp_depop_ctrl 7:5 4 Reserved 3:0 Table 122. MX-FBh: General Control 2 Read/Write Reset State Description R/W 0’h Reserved R/W 0’h Select ADCDAT1 Pin Configuration 0’b: Output 1’b: Input R/W 0’h Reserved R/W 0’h SLEEVE and RING2 Control for Headset Mode 0'b: For Normal Mode 1'b: For D3 Mode (Tie SLEEVE and RING2 to GND) R/W 0’h Headphone Capless Power Control 0’b: Controlled by combo jack function 1’b: Controlled by register (MX-8Eh) R/W 0’h IN1P Input Path Control 0’b: Disable 1’b: Enable R/W 0’h IN1N Input Path Control 0’b: Disable 1’b: Enable R/W 1’h Reserved R/W 1’h Headphone De-pop Mode Control 0’b: Disable 1’b: Enable R/W 3’h Reserved 133 Rev. 0.91 ALC5672-VB Datasheet 10.108. MX-FCh: General Control 3 Default: 0080’h Name Sel_power_saving_ir q_1 Bits 15:14 reserved En_i2s2_mono_mode 13 12 En_i2s_tdm_modeb 11 En_power_saving_irq 10 Sel_power_saving_ir q_2 9:8 Reserved 7:0 Table 123. MX-FCh: General Control 3 Read/Write Reset State Description R/W 0’h Select Option-1 JD Source for IRQ Power Saving Mode 00’b: JD1_1 01’b: JD1_2 10’b: JD2 11’b: JD3 R/W 0’h Reserved R/W 0’h Enable I2S2 Mono Mode 0'b: Disable 1'b: Enable R/W 0’h Enable I2S TDM Mode-2 0'b: Disable (TDM Mode-1) 1'b: Enable (TDM Mode-2) R/W 0’h Enable IRQ Power Saving Mode 0’b: Disable 1’b: Enable R/W 0’h Select Option-2 JD Source for IRQ Power Saving Mode 00’b: JD1_1 01’b: JD1_2 10’b: JD2 11’b: JD3 R/W 0’h Reserved 10.109. PR-3Dh: ADC/DAC RESET Control Default: 2808’h Name Reserved En_ckgen_adc Bits 15:13 12 Reserved Ckxen_dac 11 10 En_ckgen_dac 9 En_psv_dac 8 Reserved 7:0 Table 124. PR-3Dh: ADC/DAC RESET Control Read/Write Reset State Description R/W 1’h Reserved R/W 0’h Enable ADC Clock Generator 0’b: Disable 1’b: Enable R/W 1’h Reserved R/W 0’h Enable Chopper Function of DAC 0’b: Disable 1’b: Enable R/W 0’h Enable DAC Clock Generator 0’b: Disable 1’b: Enable R/W 0’h Enable Power Saving Mode of DAC 0’b: Disable 1’b: Enable R/W 8’h Reserved 134 Rev. 0.91 ALC5672-VB Datasheet 10.110. PR-A4h: DAC_L EQ (LPF:a1) Default: 1C10’h Name lpf_a1 Bits 15:0 Table 125. PR-A4h: DAC_L EQ (LPF2:a1) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.111. PR-A5h: DAC_L EQ (LPF:H0) Default: 01F4’h Name lpf_h0 Bits 15:0 Table 126. PR-A5h: DAC_L EQ (LPF2:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.112. PR-A6h: DAC_R EQ (LPF:a1) Default: 1C10’h Name lpf_a1 Bits 15:0 Table 127. PR-A6h: DAC_R EQ (LPF2:a1) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.113. PR-A7h: DAC_R EQ (LPF:H0) Default: 01F4’h Name lpf_h0 Bits 15:0 Table 128. PR-A7h: DAC_R EQ (LPF:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 135 Rev. 0.91 ALC5672-VB Datasheet 10.114. PR-AEh: DAC_L EQ (BPF2:a1) Default: C882’h Name Bpf2_a1 Bits 15:0 Table 129. PR-AEh: DAC_L EQ (BPF2:a1) Read/Write Reset State Description R/W C882’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.115. PR-AFh: DAC_L EQ (BPF2:a2) Default: 1C10’h Name Bpf2_a2 Bits 15:0 Table 130. PR-AFh: DAC_L EQ (BPF2:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.116. PR-B0h: DAC_L EQ (BPF2:H0) Default: 01F4’h Name Bpf2_h0 Bits 15:0 Table 131. PR-B0h: DAC_L EQ (BPF2:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.117. PR-B1h: DAC_R EQ (BPF2:a1) Default: C882’h Name Bpf2_a1 Bits 15:0 Table 132. PR-B1h: DAC_R EQ (BPF2:a1) Read/Write Reset State Description R/W C882’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 136 Rev. 0.91 ALC5672-VB Datasheet 10.118. PR-B2h: DAC_R EQ (BPF2:a2) Default: 1C10’h Name Bpf2_a2 Bits 15:0 Table 133. PR-B2h: DAC_R EQ (BPF2:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.119. PR-B3h: DAC_R EQ (BPF2:H0) Default: 01F4’h Name Bpf2_h0 Bits 15:0 Table 134. PR-B3h: DAC_R EQ (BPF2:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.120. PR-B4h: DAC_L EQ (BPF3:a1) Default: E904’h Name Bpf3_a1 Bits 15:0 Table 135. PR-B4h: DAC_L EQ (BPF3:a1) Read/Write Reset State Description R/W E904’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.121. PR-B5h: DAC_L EQ (BPF3:a2) Default: 1C10’h Name Bpf3_a2 Bits 15:0 Table 136. PR-B5h: DAC_L EQ (BPF3:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 137 Rev. 0.91 ALC5672-VB Datasheet 10.122. PR-B6h: DAC_L EQ (BPF3:H0) Default: 01F4’h Name Bpf3_h0 Bits 15:0 Table 137. PR-B6h: DAC_L EQ (BPF3:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.123. PR-B7h: DAC_R EQ (BPF3:a1) Default: E904’h Name Bpf3_a1 Bits 15:0 Table 138. PR-B7h: DAC_R EQ (BPF3:a1) Read/Write Reset State Description R/W E904’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.124. PR-B8h: DAC_R EQ (BPF3:a2) Default: 1C10’h Name Bpf3_a2 Bits 15:0 Table 139. PR-B8h: DAC_R EQ (BPF3:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.125. PR-B9h: DAC_R EQ (BPF3:H0) Default: 01F4’h Name Bpf3_h0 Bits 15:0 Table 140. PR-B9h: DAC_R EQ (BPF3:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 138 Rev. 0.91 ALC5672-VB Datasheet 10.126. PR-BAh: DAC_L EQ (BPF4:a1) Default: E904’h Name Bpf4_a1 Bits 15:0 Table 141. PR-BAh: DAC_L EQ (BPF4:a1) Read/Write Reset State Description R/W E904’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.127. PR-BBh: DAC_L EQ (BPF4:a2) Default: 1C10’h Name Bpf4_a2 Bits 15:0 Table 142. PR-BBh: DAC_L EQ (BPF4:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.128. PR-BCh: DAC_L EQ (BPF4:H0) Default: 01F4’h Name Bpf4_h0 Bits 15:0 Table 143. PR-BCh: DAC_L EQ (BPF4:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.129. PR-BDh: DAC_R EQ (BPF4:a1) Default: E904’h Name Bpf4_a1 Bits 15:0 Table 144. PR-BDh: DAC_R EQ (BPF4:a1) Read/Write Reset State Description R/W E904’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 139 Rev. 0.91 ALC5672-VB Datasheet 10.130. PR-BEh: DAC_R EQ (BPF4:a2) Default: 1C10’h Name Bpf4_a2 Bits 15:0 Table 145. PR-BEh: DAC_R EQ (BPF4:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.131. PR-BFh: DAC_R EQ (BPF4:H0) Default: 01F4’h Name Bpf4_h0 Bits 15:0 Table 146. PR-BFh: DAC_R EQ (BPF4:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.132. PR-C0h: DAC_L EQ (HPF1:a1) Default: 1C10’h Name Hpf1_a1 Bits 15:0 Table 147. PR-C0h: DAC_L EQ (HPF1:a1) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.133. PR-C1h: DAC_L EQ (HPF1:H0) Default: 01F4’h Name Hpf1_h0 Bits 15:0 Table 148. PR-C1h: DAC_L EQ (HPF1:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 140 Rev. 0.91 ALC5672-VB Datasheet 10.134. PR-C2h: DAC_R EQ (HPF1:a1) Default: 1C10’h Name Hpf1_a1 Bits 15:0 Table 149. PR-C2h: DAC_R EQ (HPF1:a1) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.135. PR-C3h: DAC_R EQ (HPF1:H0) Default: 01F4’h Name Hpf1_h0 Bits 15:0 Table 150. PR-C3h: DAC_R EQ (HPF1:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.136. PR-C4h: DAC_L EQ (HPF2:a1) Default: 2000’h Name Hpf2_a1 Bits 15:0 Table 151. PR-C4h: DAC_L EQ (HPF2:a1) Read/Write Reset State Description R/W 2000’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.137. PR-C5h: DAC_L EQ (HPF2:a2) Default: 0000’h Name Hpf2_a2 Bits 15:0 Table 152. PR-C5h: DAC_L EQ (HPF2:a2) Read/Write Reset State Description R/W 0000’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 141 Rev. 0.91 ALC5672-VB Datasheet 10.138. PR-C6h: DAC_L EQ (HPF2:H0) Default: 1FF1’h Name Hpf2_h0 Bits 15:0 Table 153. PR-C6h: DAC_L EQ (HPF2:H0) Read/Write Reset State Description R/W 1FF1’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.139. PR-C7h: DAC_R EQ (HPF2:a1) Default: 2000’h Name Hpf2_a1 Bits 15:0 Table 154. PR-C7h: DAC_R EQ (HPF2:a1) Read/Write Reset State Description R/W 2000’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.140. PR-C8h: DAC_R EQ (HPF2:a2) Default: 0000’h Name Hpf2_a2 Bits 15:0 Table 155. PR-C8h: DAC_R EQ (HPF2:a2) Read/Write Reset State Description R/W 0000’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.141. PR-C9h: DAC_R EQ (HPF2:H0) Default: 1FF1’h Name Hpf2_h0 Bits 15:0 Table 156. PR-C9h: DAC_R EQ (HPF2:H0) Read/Write Reset State Description R/W 1FF1’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 142 Rev. 0.91 ALC5672-VB Datasheet 10.142. PR-CAh: DAC_L EQ Pre-Volume Control Default: 0800’h Name Da_eq_pre_vol_l Table 157. PR-CAh: DAC_L EQ Pre-Volume Control Bits Read/Write Reset State Description 15:0 R/W 0800’h DAC Left Channel EQ Pre-Volume Control 2’s Complement in 5.11 Format. (Default is 0dB) The range is from -16 ~ 15.99, pre-gain should be in 0 ~ 15.99 [+24dB ~ -66dB] 10.143. PR-CBh: DAC_R EQ Pre-Volume Control Default: 0800’h Name Da_eq_pre_vol_l Bits 15:0 Table 158. PR-CBh: DAC_R EQ Pre-Volume Control Read/Write Reset State Description R/W 0800’h DAC Right Channel EQ Pre-Volume Control 2’s Complement in 5.11 Format. (Default is 0dB) The range is from -16 ~ 15.99, pre-gain should be in 0 ~ 15.99 [+24dB ~ -66dB] 10.144. PR-CCh: DAC_L EQ Post-Volume Control Default: 0800’h Name Da_eq_post_vol_l Table 159. PR-CCh: DAC_L EQ Post-Volume Control Bits Read/Write Reset State Description 15:0 R/W 0800’h DAC Left Channel EQ Post-Volume Control 2’s Complement in 5.11 Format. (Default is 0dB) The range is from -16 ~ 15.99, pre-gain should be in 0 ~ 15.99 [+24dB ~ -66dB] 143 Rev. 0.91 ALC5672-VB Datasheet 10.145. PR-CDh: DAC_R EQ Post-Volume Control Default: 0800’h Name Da_eq_post_vol_l Table 160. PR-CDh: DAC_R EQ Post-Volume Control Bits Read/Write Reset State Description 15:0 R/W 0800’h DAC Right Channel EQ Post-Volume Control 2’s Complement in 5.11 Format. (Default is 0dB) The range is from -16 ~ 15.99, pre-gain should be in 0 ~ 15.99 [+24dB ~ -66dB] 10.146. PR-CEh: ADC EQ (LPF:a1) Default: 1C10’h Name ad_eq_lpf_a1 Bits 15:0 Table 161. PR-CEh: ADC EQ (LPF:a1) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.147. PR-CFh: ADC EQ (LPF:H0) Default: 01F4’h Name ad_eq_lpf_h0 Bits 15:0 Table 162. PR-CFh: ADC EQ (LPF:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.148. PR-D0h: ADC EQ (BPF1:a1) Default: E904’h Name ad_eq_Bpf1_a1 Bits 15:0 Table 163. PR-D0h: ADC EQ (BPF1:a1) Read/Write Reset State Description R/W E904’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 144 Rev. 0.91 ALC5672-VB Datasheet 10.149. PR-D1h: ADC EQ (BPF1:a2) Default: 1C10’h Name Ad_eq_Bpf1_a2 Bits 15:0 Table 164. PR-D1h: ADC EQ (BPF1:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.150. PR-D2h: ADC EQ (BPF1:H0) Default: 01F4’h Name ad_eq_Bpf1_h0 Bits 15:0 Table 165. PR-D2h: ADC EQ (BPF1:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.151. PR-D3h: ADC EQ (BPF2:a1) Default: E904’h Name ad_eq_Bpf2_a1 Bits 15:0 Table 166. PR-D3h: ADC EQ (BPF2:a1) Read/Write Reset State Description R/W E904’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.152. PR-D4h: ADC EQ (BPF2:a2) Default: 1C10’h Name Ad_eq_Bpf2_a2 Bits 15:0 Table 167. PR-D4h: ADC EQ (BPF2:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 145 Rev. 0.91 ALC5672-VB Datasheet 10.153. PR-D5h: ADC EQ (BPF2:H0) Default: 01F4’h Name ad_eq_Bpf2_h0 Bits 15:0 Table 168. PR-D5h: ADC EQ (BPF2:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.154. PR-D6h: ADC EQ (BPF3:a1) Default: E904’h Name ad_eq_Bpf3_a1 Bits 15:0 Table 169. PR-D6h: ADC EQ (BPF3:a1) Read/Write Reset State Description R/W E904’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.155. PR-D7h: ADC EQ (BPF3:a2) Default: 1C10’h Name Ad_eq_Bpf3_a2 Bits 15:0 Table 170. PR-D7h: ADC EQ (BPF3:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.156. PR-D8h: ADC EQ (BPF3:H0) Default: 01F4’h Name ad_eq_Bpf3_h0 Bits 15:0 Table 171. PR-D8h: ADC EQ (BPF3:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 146 Rev. 0.91 ALC5672-VB Datasheet 10.157. PR-D9h: ADC EQ (BPF4:a1) Default: E904’h Name ad_eq_Bpf4_a1 Bits 15:0 Table 172. PR-D9h: ADC EQ (BPF4:a1) Read/Write Reset State Description R/W E904’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 10.158. PR-DAh: ADC EQ (BPF4:a2) Default: 1C10’h Name Ad_eq_Bpf4_a2 Bits 15:0 Table 173. PR-DAh: ADC EQ (BPF4:a2) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a2 should be in -2 ~ 1.99) 10.159. PR-DBh: ADC EQ (BPF4:H0) Default: 01F4’h Name ad_eq_Bpf4_h0 Bits 15:0 Table 174. PR-DBh: ADC EQ (BPF4:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.160. PR-DCh: ADC EQ (HPF1:a1) Default: 1C10’h Name Ad_eq_hpf1_a1 Bits 15:0 Table 175. PR-DCh: ADC EQ (HPF1:a1) Read/Write Reset State Description R/W 1C10’h 2’s complement in 3.13 format. (The range is from –4~3.99, the a1 should be in -2 ~ 1.99) 147 Rev. 0.91 ALC5672-VB Datasheet 10.161. PR-DDh: ADC EQ (HPF1:H0) Default: 01F4’h Name ad_eq_hpf1_h0 Bits 15:0 Table 176. PR-DDh: ADC EQ (HPF1:H0) Read/Write Reset State Description R/W 01F4’h 2’s complement in 3.13 format. (The range is from –4~3.99, the H0 should be in -4 ~ 3.99) 10.162. PR-E1h: ADC EQ Pre-Volume Control Default: 0800’h Name ad_eq_pre_vol Bits 15:0 Table 177. PR-E1h: ADC EQ Pre-Volume Control Read/Write Reset State Description R/W 0800’h ADC Left Channel EQ Pre-Volume Control 2’s Complement in 5.11 Format. (Default is 0dB) The range is from -16 ~ 15.99, pre-gain should be in 0 ~ 15.99 [+24dB ~ -66dB] 10.163. PR-E2h: ADC EQ Post-Volume Control Default: 0800’h Name Ad_eq_post_vol Bits 15:0 Table 178. PR-E2h: ADC EQ Post-Volume Control Read/Write Reset State Description R/W 0800’h ADC Left Channel EQ Post-Volume Control 2’s Complement in 5.11 Format. (Default is 0dB) The range is from -16 ~ 15.99, pre-gain should be in 0 ~ 15.99 [+24dB ~ -66dB] 10.164. PR-E5h: DAC_L Biquad EQ (BPF1:h0-1) Default: 0000’h Name Reserved Bits 15:13 Eq_biquad_h0_l_msb 12:0 Table 179. PR-E5h: DAC_L Biquad EQ (BPF1:h0-1) Read/Write Reset State Description R 0’h Reserved R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 148 Rev. 0.91 ALC5672-VB Datasheet 10.165. PR-E6h: DAC_L Biquad EQ (BPF1:h0-2) Default: 0000’h Name Eq_biquad_h0_l_lsb Table 180. PR-E6h: DAC_L Biquad EQ (BPF1:h0-2) Bits Read/Write Reset State Description 15:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.166. PR-E7h: DAC_L Biquad EQ (BPF1:b1-1) Default: 0000’h Name Reserved Bits 15:13 Eq_biquad_b1_l_msb 12:0 Table 181. PR-E7h: DAC_L Biquad EQ (BPF1:b1-1) Read/Write Reset State Description R 0’h Reserved R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.167. PR-E8h: DAC_L Biquad EQ (BPF1:b1-2) Default: 0000’h Name Eq_biquad_b1_l_lsb Bits 15:0 Table 182. PR-E8h: DAC_L Biquad EQ (BPF1:b1-2) Read/Write Reset State Description R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.168. PR-E9h: DAC_L Biquad EQ (BPF1:b2-1) Default: 0000’h Name Reserved Table 183. PR-E9h: DAC_L Biquad EQ (BPF1:b2-1) Bits Read/Write Reset State Description 15:13 R 0’h Reserved Eq_biquad_b2_l_msb 12:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 149 Rev. 0.91 ALC5672-VB Datasheet 10.169. PR-EAh: DAC_L Biquad EQ (BPF1:b2-2) Default: 0000’h Name Eq_biquad_b2_l_lsb Table 184. PR-EAh: DAC_L Biquad EQ (BPF1:b2-2) Bits Read/Write Reset State Description 15:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.170. PR-EBh: DAC_L Biquad EQ (BPF1:a1-1) Default: 0000’h Name Reserved Bits 15:13 Eq_biquad_a1_l_msb 12:0 Table 185. PR-EBh: DAC_L Biquad EQ (BPF1:a1-1) Read/Write Reset State Description R 0’h Reserved R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.171. PR-ECh: DAC_L Biquad EQ (BPF1:a1-2) Default: 0000’h Name Eq_biquad_a1_l_lsb Bits 15:0 Table 186. PR-ECh: DAC_L Biquad EQ (BPF1:a1-2) Read/Write Reset State Description R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.172. PR-EDh: DAC_L Biquad EQ (BPF1:a2-1) Default: 0000’h Name Reserved Table 187. PR-EDh: DAC_L Biquad EQ (BPF1:a2-1) Bits Read/Write Reset State Description 15:13 R 0’h Reserved Eq_biquad_a2_l_msb 12:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 150 Rev. 0.91 ALC5672-VB Datasheet 10.173. PR-EEh: DAC_L Biquad EQ (BPF1:a2-2) Default: 0000’h Name Eq_biquad_a2_l_lsb Table 188. PR-EEh: DAC_L Biquad EQ (BPF1:a2-2) Bits Read/Write Reset State Description 15:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.174. PR-EFh: DAC_R Biquad EQ (BPF1:h0-1) Default: 0000’h Name Reserved Bits 15:13 Eq_biquad_h0_r_msb 12:0 Table 189. PR-EFh: DAC_R Biquad EQ (BPF1:h0-1) Read/Write Reset State Description R 0’h Reserved R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.175. PR-F0h: DAC_R Biquad EQ (BPF1:h0-2) Default: 0000’h Name Eq_biquad_h0_r_lsb Bits 15:0 Table 190. PR-F0h: DAC_R Biquad EQ (BPF1:h0-2) Read/Write Reset State Description R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.176. PR-F1h: DAC_R Biquad EQ (BPF1:b1-1) Default: 0000’h Name Reserved Table 191. PR-F1h: DAC_R Biquad EQ (BPF1:b1-1) Bits Read/Write Reset State Description 15:13 R 0’h Reserved Eq_biquad_b1_r_msb 12:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 151 Rev. 0.91 ALC5672-VB Datasheet 10.177. PR-F2h: DAC_R Biquad EQ (BPF1:b1-2) Default: 0000’h Name Eq_biquad_b1_r_lsb Table 192. PR-F2h: DAC_R Biquad EQ (BPF1:b1-2) Bits Read/Write Reset State Description 15:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.178. PR-F3h: DAC_R Biquad EQ (BPF1:b2-1) Default: 0000’h Name Reserved Bits 15:13 Eq_biquad_b2_r_msb 12:0 Table 193. PR-F3h: DAC_R Biquad EQ (BPF1:b2-1) Read/Write Reset State Description R 0’h Reserved R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.179. PR-F4h: DAC_R Biquad EQ (BPF1:b2-2) Default: 0000’h Name Eq_biquad_b2_r_lsb Bits 15:0 Table 194. PR-F4h: DAC_R Biquad EQ (BPF1:b2-2) Read/Write Reset State Description R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.180. PR-F5h: DAC_R Biquad EQ (BPF1:a1-1) Default: 0000’h Name Reserved Table 195. PR-F5h: DAC_R Biquad EQ (BPF1:a1-1) Bits Read/Write Reset State Description 15:13 R 0’h Reserved Eq_biquad_a1_r_msb 12:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 152 Rev. 0.91 ALC5672-VB Datasheet 10.181. PR-F6h: DAC_R Biquad EQ (BPF1:a1-2) Default: 0000’h Name Eq_biquad_a1_r_lsb Table 196. PR-F6h: DAC_R Biquad EQ (BPF1:a1-2) Bits Read/Write Reset State Description 15:0 R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.182. PR-F7h: DAC_R Biquad EQ (BPF1:a2-1) Default: 0000’h Name Reserved Bits 15:13 Eq_biquad_a2_r_msb 12:0 Table 197. PR-F7h: DAC_R Biquad EQ (BPF1:a2-1) Read/Write Reset State Description R 0’h Reserved R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.183. PR-F8h: DAC_R Biquad EQ (BPF1:a2-2) Default: 0000’h Name Eq_biquad_a2_r_lsb Bits 15:0 Table 198. PR-F8h: DAC_R Biquad EQ (BPF1:a2-2) Read/Write Reset State Description R/W 0’h 2’s complement in 4.25 format. (The range is from –8~7.99) 10.184. MX-FEh: Vendor ID Default: 10EC’h Name Vendor_id Bits 15:0 Table 199. MX-FEh: Vendor ID Read/Write Reset State Description R 10EC’h Vendor ID 153 Rev. 0.91 ALC5672-VB Datasheet 11. Electrical Characteristics 11.1. DC Characteristics 11.1.1. Absolute Maximum Ratings Table 200. Absolute Maximum Ratings Parameter Symbol Min Typ Power Supplies Digital IO Buffer DBVDD -0.3 Digital Core DCVDD -0.3 Analog AVDD -0.3 Headphone CPVDD -0.3 Micbias MICVDD -0.3 Speaker SPKVDD -0.3 Operating Ambient Temperature Ta -25 Storage Temperature Ts -55 Note 1: SPKVDD=5V with 3.5% duty cycle Power bouncing up to SPKVDD=7V is acceptable. Max Units 3.63 1.4 1.98 1.98 3.63 71 +85 +125 V V V V V V o C o C 11.1.2. Recommended Operating Conditions Table 201. Recommended Operating Conditions Parameter Symbol Min Typ Max Units Digital IO Buffer DBVDD 1.71 1.8 3.6 V Digital Core DCVDD 1.05 1.2 1.3 V Analog AVDD 1.71 1.8 1.9 V Analog DACREF 1.71 1.8 1.9 V Headphone CPVDD 1.71 1.8 1.9 V Micbias MICVDD 3.0 3.3 3.6 V Speaker SPKVDD1 3.0 3.6/5.0 5.5 V Note 1: A 10µF Capacitor must be connected from SPKVDD to SPKGND, and should be placed as close as possible to the SPKVDD pin. 11.1.3. Static Characteristics Table 202. Static Characteristics Parameter Symbol Min Typ Input Voltage Range VIN -0.30 Low Level Input Voltage VIL High Level Input Voltage VIH 0.65DBVDD High Level Output Voltage VOH 0.9DBVDD Low Level Output Voltage VOL Output Buffer High Drive Current 15 Output Buffer Low Drive Current 14.7 Input Buffer Pull-Up Resistor 125 148 Input Buffer Pull-Down Resistor 193 225 Note: DBVDD=1.8V, DCVDD=1.2V, Tambient=40C. 154 Max DBVDD+0.30 0.35DBVDD 0.1DBVDD 180 266 Units V V V V V mA mA K K Rev. 0.91 ALC5672-VB Datasheet 11.2. Analog Performance Characteristics Table 203. Analog Performance Characteristics Parameter Min Typ Full Scale Input Voltage Line Inputs (Single-ended) 0.6 MIC Inputs (Single-ended ) 0.6 MIC Inputs (Differential) 1.2 Full Scale Output Voltage Line Outputs (Single-ended) 1.0 Line Outputs (Differential) 1.0 Headphone Amplifiers Outputs (For 10KOhm Load) 1.0 Headphone Amplifiers Outputs (For 16Ohm Load) 0.9 Headphone Amplifiers Outputs (For 32Ohm Load) 1.0 Speaker Amplifiers Outputs 2.9 (SPKVDD=5.0V with 4 Load, 1% THD+N) S/N Ratio Stereo DAC Direct to HP_L/R with 16/32/10KOhm 100 Stereo DAC Direct to SPK_OUT with 8Ohm/5V (Differential) 93 Line_In to Stereo ADC with 0dB (Single-end) MIC_In to Stereo ADC with 0dB (Differential or Single-end) MIC_In to Stereo ADC with 20dB and MICBIAS (Differential or Single-end) MIC_In to Stereo ADC with 40dB and MICBIAS (Differential or Single-end) MIC_In to Stereo ADC with 50dB and MICBIAS (Differential or Single-end) Total Harmonic Distortion + Noise DAC Direct to HP_L/R with 16Ohm Po = 20mW/CH (16Ohm) (with AES17 Filter) Po = 20mW/CH (32Ohm) (with AES17 Filter) 93 93 85 Max Units - Vrms Vrms Vrms - Vrms Vrms Vrms Vrms Vrms Vrms 102 dBA dBA 95 95 dBA dBA dBA 72 dBA 65 dBA -81 -81 -83 -83 dB dB DAC Direct to HP_L/R with 10KOhm -3dBFS -85 dB DAC Direct to SPK_OUT (Differential) Po=1.2W (5V/8Ohm) Po=2.1W (5V/4Ohm) Po=920mW (4.2V/8Ohm) Po=650mW (3.6V/8Ohm)
ALC5672-VB-CGT 价格&库存
很抱歉,暂时无法提供与“ALC5672-VB-CGT”相匹配的价格&库存,您可以联系我们找货
