DRL106S0TI20RRASP
DRL106S0TI20RRASP
    MANYUE(万裕科技)
    插件
    10F -20%~+50% 2.7V
DRL106S0TI20RRASP 数据手册
CUSTOMER : DATE : (客戶) : CATEGORY (品名) (日期) : 2019-10-18 : ELECTRIC DOUBLE LAYER CAPACITORS DESCRIPTION (型号) : DRL 2.7V10 F (φ12.5x20) : 01 VERSION (版本) Customer P/N : / SUPPLIER : / SUPPLIER PREPARED (拟定) 赵安平 CUSTOMER CHECKED (审核) 刘渭清 APPROVAL (批准) SIGNATURE (签名) SAMXON ELECTRONIC COMPONENTS LIMITED ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES SPECIFICATION Rev. Date Issued-date: Version DRL SERIES Mark Page Name ALTERNATION HISTORY RECORDS Contents Purpose Drafter Approver Specification Sheet – DRL 01 Page STANDARD MANUAL 1 ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES SAMXON ELECTRONIC COMPONENTS LIMITED CONTENTS Sheet 1. 2. 3. 3.1 3.2 3.3 Application Part Number System Characteristics 3 3 4~10 Rated voltage & Surge voltage Capacitance (Tolerance) ESR 3.4 Leakage current 3.5 Temperature characteristic 3.6 Load life test 3.7 Damp heat test 3.8 Lead strength 3.9 Resistance to vibration 3.10 Solderability 3.1 1 Resistance to soldering heat 4. Product Dimensions 5. Notice item Issued-date: Version 11 12 Name Specification Sheet – DRL 01 Page STANDARD MANUAL 2 ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES SAMXON ELECTRONIC COMPONENTS LIMITED 1. Application The specification applies to electric double layer capacitors used in electronic equipment. 2. Part Number System DRL 106 S 0T I 20 RR Type (2.3) Case Length (2.6) Diameter (2.5) Voltage (2.2) Tolerance (2.4) Capacitance (2.1) Series 2.1 2.2 Capacitance code Code 106 Capacitance (F) 10 Rated voltage code Code Voltage (W.V.) 2.3 2.4 2.5 Type Code Type RR Bulk Capacitance tolerance “S” stands for -20% ~ +50% Diameter Code Diameter 2.6 0T 2.7 I 12.5 Case length 20=20mm Issued-date: Version Name Specification Sheet – DRL 01 Page STANDARD MANUAL 3 SAMXON ELECTRONIC COMPONENTS LIMITED ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES 3. Characteristics Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurements and tests is as follows: Ambient temperature: 15C to 35C Relative humidity : 25% to75% Air Pressure : 86kPa to 106kPa If there is any doubt about the results, measurement shall be made within the following conditions: Ambient temperature: 20C  2C Relative humidity : 60% to 70% Air Pressure : 86kPa to 106kPa Operating temperature range The ambient temperature range at which the capacitor can be operated continuously at rated voltage is -40C to 70C. Issued-date: Version Name Specification Sheet – DRL 01 Page STANDARD MANUAL 4 SAMXON ELECTRONIC COMPONENTS LIMITED ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES ITEM PERFORMANCE Rated voltage (WV) 3.1 WV (V.DC) 2.7 SV (V.DC) 2.8 Surge voltage (SV) Constant current discharge method: Measuring circuit: A S Constant current / constant voltage power supply V Cx Constant Current Discharger Key A 3.2 Nominal capacitance (Tolerance) V S Cx d.c. ammeter d.c. voltmeter changeover switch capacitor under test Figure 1- Circuit for constant current discharge method Measuring method a) Set the d.c.voltage at the rated voltage (UR) b) Set the constant current value of the constant current discharger to the discharge current specified in Table 1. c) Turn the switch S to the d.c.power supply ,apply voltage and charge for 30 min after the constant current / constant voltage power supply has achieved the rated voltage. d) After a charge for 30 min has finished ,change over the switch S to the constant current discharger ,and discharge with a constant current. e) Measure the time t1 and t2 where the voltage between capacitor terminals at the time of discharge reduces from U1 to U2 as shown in Figure 2 ,and calculate the capacitance value by the following formula: Issued-date: Version Name Specification Sheet – DRL 01 Page STANDARD MANUAL 5 SAMXON ELECTRONIC COMPONENTS LIMITED ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES △U3 UR U1 △U3:IR drop Voltage (V) U2 t1 30 min t2 Time (s) Figure 2- Voltage characteristic between capacitor terminals C= Ix(t2-t1) U1-U2 3.2 Nominal capacitance (Tolerance) Where C is the capacitance(F); I is the discharge current (A); U1 is the measurement starting voltage (V); U2 is the measurement end voltage (V); t1 is the time from discharge start to reach U1 (s); t2 is the time from discharge start to reach U2 (s). f) The discharge current I and the voltages U1 and U2 at the time of discharge voltage drop shall be as per Table 1 .The method classification shall be in accordance with the individual standards. Table 1 – Discharge conditions Charge time 30 min I(mA) 4 x CUR U1 The value to be 80% of the charging voltage (0.8xUR) U2 The value to be 40% of the charging voltage (0.4xUR) NOTE CR is the rated capacitance in F(Farad),and UR is the rated voltage in V (Volt) Issued-date: Version Name Specification Sheet – DRL 01 Page STANDARD MANUAL 6 ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES SAMXON ELECTRONIC COMPONENTS LIMITED 3.3 3.4 ESR Leakage current Measuring frequency :1kHz Measuring temperature:20±2℃ Measuring point : 2mm max from the surface of a sealing resin on the lead wire. (20℃)Less than the initial limit: ESR≤80mΩ 1. Ambient temperature: 25C  2C. 2.The electrification time:72H 3. Desistance value of protective resistor less than 1Ω . Less than the initial limit(25C  2C): I≤0.03mA I is the Leakage current STEP Temperature(℃) 1 20±2 Item Capacitance、 ESR △ C/C 2 -40+3 ESR 3.5 Temperature characteristic Keep at 15 to 35℃ for 15 minutes or more 3 4 Characteristics ----------Within ±30% of initial capacitance Less than or equal to 4 times of the value of item 3.3 --------- --------- △ C/C Within ±30% of initial capacitance The limit specified in 3.3 70±2 ESR a. ESR -40℃/ ESR 20℃: ESR ratio at 1kHz; b. ΔC/C 20℃: Capacitance change ; Issued-date: Version Name Specification Sheet – DRL 01 Page STANDARD MANUAL 7 ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES SAMXON ELECTRONIC COMPONENTS LIMITED The Capacitor is stored at a temperature of 70±2 °C with rated voltage for 1000 +48/0 hours .The result should meet the following table: Item Performance Capacitance Change 3.6 Load life test ESR Appearance Within ±30% of initial capacitance Less than or equal to 4 times of the value of item 3.3 No visible damage and no leakage of electrolyte Humidity Test: The capacitor shall be exposed for 240±48 hours in an atmosphere of 90~95%RH at 40±2℃, the characteristic change shall meet the following requirement. Item 3.7 Damp heat test Issued-date: Version Performance Capacitance Change Within ±30% of initial capacitance ESR Less than or equal to 4 times of the value of item 3.3 Appearance No visible damage and no leakage of electrolyte Name Specification Sheet – DRL 01 Page STANDARD MANUAL 8 SAMXON ELECTRONIC COMPONENTS LIMITED ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES a) Lead pull strength A static load force shall be applied to the terminal in the axial direction and acting in a direction away from the body for 10±1 s. Lead wire diameter (mm) Load force (N) 10 0.5 < d ≤0.8 3.8 Lead strength b) Lead bending When the capacitor is placed in a vertical position and the weight specified in the table above is applied to one lead and then the capacitor is slowly rotated 900 to a horizontal position and then returned to a vertical position thus completing bends for 2~3seconds. The additional bends are made in the opposite direction Lead wire diameter (mm) Load force (N) 0.5 < d ≤0.8 5 Performance: The characteristic shall meet the following value after a) or b) test. Item Performance Capacitance Change Within ±30% of initial capacitance No visible damage Legible marking and no Appearance leakage of electrolyte Frequency: 10 to 55 Hz (1minute interval / 10 → 55 → 10Hz Amplitude: 0.75mm(Total excursion 1.5mm) Direction :X、 Y、 Z (3 axes) Duration: 2hours/ axial (Total 6 hours) The capacitors are supported as the following Fig2 3.9 ≤0.3mm Resistance to vibration Fig2 Performance: Capacitance value shall not show drastic change compared to the initial capacitance when the value is measured within 30 minutes. Prior to the completion of exam, Capacitance difference shall be within ±10% compared to the initial value the exam. Issued-date: Version Name Specification Sheet – DRL 01 Page STANDARD MANUAL 9 SAMXON ELECTRONIC COMPONENTS LIMITED T T 3.10 Solderability ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES The capacitor shall be tested under the following conditions: Solder : Sn-3Ag-0.5Cu Soldering temperature: 2453C Immersing time : 2.00.5s Immersing depth : 1.5~ 2.0mm from the root. Flux : Approx .25% rosin Performance: At least 75% of the dipped portion of the terminal shall be covered with new solder. A) Solder bath method Lead terminals of a capacitor are placed on the heat isolation board with thickness of 1.60.5mm. It will dip into the flux of isopropylaehol solution of colophony. Then it will be immersed at the surface of the solder with the following condition: Solder : Sn-3Ag-0.5Cu Soldering temperature : 260 5C Immersing time : 50.5s Heat protector: t=1.6mm glass –epoxy board 3.11 Resistance to soldering heat Issued-date: Version B) Soldering iron method Bit temperature : 350 10C Application time : 3.5 0.5 s Heat protector: t=1.6mm glass –epoxy board For both methods, after the capacitor at thermal stability, the following items shall be measured: Item Performance Capacitance Change Within ±10% of initial capacitance No visible damage legible marking and no leakage Appearance of electrolyte Name Specification Sheet – DRL 01 Page STANDARD MANUAL 10 SAMXON ELECTRONIC COMPONENTS LIMITED ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES 4. Product Dimensions Unit: mm Safety vent for ф d±0.05 F±0.5 L +2.0 15 min -1.0 Issued-date: Version Φ D±0.5 4 min φD 12.5 L 20 F 5.0 φd 0.6 Name Specification Sheet – DRL 01 Page STANDARD MANUAL 11 ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATION DRL SERIES SAMXON ELECTRONIC COMPONENTS LIMITED 5 . Notice item (1)The capacitor has fixed polarity. (2)The capacitor should be used under rated voltage. (3)The capacitor should not be used in the charge and discharge circuit with high frequency. (4)The ambient temperature affects the super capacitor life. (5)Voltage reduction ΔV=IR will happen at the moment of discharge. (6)The capacitor cannot be stored on the place with humidity over 85%RH or place with toxic gas. (7)The capacitor should stored in the environment within -30℃~50℃ temperature and less than 60% relative humidity. (8)If the capacitor is applied on the double-side PCB, the connection should not be around the place on which the super capacitor can contact. (9)Don't twist capacitor or make it slanting after installing. (10)Need avoid over heat on the capacitor during soldering (The temperature should be 260℃ with the time less than 5s during soldering on 1.6mm printed PCB.) (11)There is voltage balance problem between each capacitor unit during series connection between super capacitor. Issued-date: Version Name Specification Sheet – DRL 01 Page STANDARD MANUAL 12
DRL106S0TI20RRASP 价格&库存
很抱歉,暂时无法提供与“DRL106S0TI20RRASP”相匹配的价格&库存,您可以联系我们找货
