Approval sheet
MULTILAYER CERAMIC ANTENNA
RFANT Series – RoHS Compliance
2.4 GHz ISM Band Working Frequency
P/N: RFANT3216120A1T Series
*Contents in this sheet are subject to change without prior notice.
Page 1 of 9
ASC_RFANT3216120A1T_V04
Apr. 2010
Approval sheet
FRATURES
3
1. Surface Mounted Devices with a small dimension of 3.2 X 1.6 X1.2 mm meet future miniaturization trend.
2. LTCC process
3. High stability in Temperature / Humidity Change
APPLICATIONS
1. 2.4GHz ISM band RF applications
2. Bluetooth, Wireless, HomeRF
CONSTRUCTION
1. Feeding
2. Identification Mark
3. Soldering terminal
DIMENSIONS
Figure
aa
A
W
aa
L
Page 2 of 9
Symbol
Dimension (mm)
L
3.20 ± 0.20
W
1.60 ± 0.10
T
1.20 ± 0.10
a
0.25 ± 0.15
T
Apr. 2010
Approval sheet
ELECTRICAL CHARACTERISTICS
RFANT3216120A1T
Specification
Working Frequency Range
2450 ± 50 MHz
Fc (GHz)
2.5
Gain (dBi)
2 (Typical)
Matching component valve
Series 1
2.7nH
Series 2
* This frequency must be adjusted to 2.45GHz with matching circuit.
SOLDER LAND PATTERN DESIGN
Series 2
Figure
Series 1
Empty Area
6x6 mm
19.4
45mm
Unit : mm
Soldering Pad
50Ω
Ω Feed
line
Ground
50 Ω Transmission Line
20mm
6
1.83
1.6
0.88
1.63
0.54
2.3
0.8
0.8
1.66
6
0.34
Page 3 of 9
1.36
1.88
0.36
3.43
Apr. 2010
Approval sheet
Antenna on Test Board ( Thickness 1.2mm)
A
0.8mm
1.6mm
1.66mm
Empty Area
6x6 mm
19.4mm
50Ω
Ω Feed
line
GROUND
Antenna S11 on Test Board
Page 4 of 9
Apr. 2010
Approval sheet
RADIATION PATTERN
Radiation Pattern and Gain were dependent on measurement board design. The specification of RFANT3216120A1T
antenna was measured based on the PCB size and installation position as shown in the below figure Test Board
Z
X
Y
GROUND
Vertical
Horizontal
Y-Z
Plane
Average
Gain=
0.859 dBi
Peak Gain = 2.13dBi
Average Gain = 0.62 dBi
Peak Gain= -6.47dBi
Average Gain=-11.86dBi
Peak Gain= -7.43 dBi
Average Gain= -12.30dBi
Peak Gain= 1.07 dBi
Average Gain= -2.21 dBi
Peak Gain= -9.98 dBi
Average Gain= -15.53dBi
Peak Gain= 1.84 dBi
Average Gain= -2.57 dBi
X-Z
Plane
Average
Gain=
-1.804 dBi
X-Y
Plane
Average
Gain=
-2.365 dBi
Page 5 of 9
Apr. 2010
Approval sheet
RELIABILITY TEST
Test item
Test condition / Test method
Specification
Solderability
JIS C 0050-4.6
*Solder bath temperature:235 ± 5°C
At least 95% of a surface of each terminal
JESD22-B102D
*Immersion time:2 ± 0.5 sec
electrode must be covered by fresh solder.
*Solder:Sn3Ag0.5Cu for lead-free
Leaching
*Solder bath temperature:260 ± 5°C
Loss of metallization on the edges of each
of metallization)
*Leaching immersion time:30 ± 0.5 sec
electrode shall not exceed 25%.
IEC 60068-2-58
*Solder : SN63A
(Resistance to dissolution
Resistance to soldering heat
*Preheating temperature:120~150℃,
No mechanical damage.
JIS C 0050-5.4
Samples shall satisfy electrical specification
1 minute.
*Solder temperature:270±5°C
*Immersion time:10±1 sec
after test.
Measurement to be made after keeping at
room temperature for 24±2 hrs
Drop Test
JIS C 0044
*Height:75 cm
*Test Surface:Rigid surface of concrete or
after test.
steel.
*Times:6 surfaces for each units;2 times
for each side.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
*Pressurizing force:
5N(≦0603);10N(>0603)
No remarkable damage or removal of the
termination.
*Test time:10±1 sec
Bending test
The middle part of substrate shall be
JIS C 0051- 7.4.1
pressurized by means of the pressurizing
rod at a rate of about 1 mm/s per second
after test.
until the deflection becomes 1mm/s and
then pressure shall be maintained for 5±1
sec.
room temperature for 24±2 hours
Page 6 of 9
Apr. 2010
Approval sheet
Temperature cycle
JIS C 0025
1. 30±3 minutes at -40°C±3°C,
2. 10~15 minutes at room temperature,
3. 30±3 minutes at +85°C±3°C,
after test.
4. 10~15 minutes at room temperature,
Total 100 continuous cycles
Vibration
JIS C 0040
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
after test.
mutually perpendicular directions)
High temperature
JIS C 0021
*Temperature:85°C±2°C
*Test duration:1000+24/-0 hours
after test.
Humidity
(steady conditions)
*Humidity:90% to 95% R.H.
*Temperature:40±2°C
JIS C 0022
*Time:1000+24/-0 hrs.
after test.
keeping at room temperature for 24±2
hrs
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40°C±2°C
after test.
Page 7 of 9
Apr. 2010
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2
Fig 2. Infrared soldering profile
ORDERIND CODE
RF
Walsin
ANT
321612
Product code
Dimension code
Unit of
dimension
RF device
ANT : Antenna
Per 2 digits of
Length, Width,
Thickness :
A
0 : 0.1 mm
1
T
Application
Specification
Packing
A : 2.4GHZ ISM
Band
Design Code
T : 7” Reeled
1 : 1.0 mm
e.g. :
321612 =
Length 32,
Width 16,
Thickness 12
Minimum Ordering Quantity:
2000 pcs per reel.
PACKAGING
Plastic Tape specifications (unit :mm)
A
Index
Dimension (mm)
Index
Dimension (mm)
Page 8 of 9
A
A
A
A
Ao
Bo
ΦD
T
W
1.95 ± 0.10
3.45 ± 0.10
1.55 ± 0.05
1.30 ± 0.10
8.20 +0.10
-0.30
E
F
Po
P1
P2
1.75 ± 0.10
3.50 ± 0.05
4.00 ± 0.10
4.00 ± 0.10
2.00 ± 0.10
Apr. 2010
Approval sheet
Reel dimensions
C
Index
Dimension (mm)
A
B
A
B
C
Φ178
Φ60.0
Φ13.5
Typing Quantity: 2000 pieces per 7” reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for the
prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1) Aircraft equipment
(2) Aerospace equipment
(3) Undersea equipment
(4) Medical equipment
(5) Disaster prevention / crime prevention equipment
(6) Traffic signal equipment
(7) Transportation equipment (vehicles, trains, ships, etc.)
(8) Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1) Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be
confirmed.
(2) Storage environment condition.
Products should be storage in the warehouse on the following conditions.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Page 9 of 9
Temperature
: -10 to +40℃
Humidity
: 30 to 70% relative humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Apr. 2010
很抱歉,暂时无法提供与“RFANT3216120A1T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+2.072765+0.25086
- 25+1.1764325+0.14238
- 100+1.07373100+0.12995
- 500+0.96169500+0.11639
- 2000+0.896332000+0.10848
