KVF500L104M31NLT00
KVF500L104M31NLT00
    NCC(贵弥功)
    KVF500L104M31NLT00
KVF500L104M31NLT00 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS KVF RoHS2 RoHS Compliant Compliant Series Temperature cycle : 1000 cycles AECQ200 High temperature 150℃ ◆FEATURES 1. Temperature range : -55 to +150℃ 2. Temperature characteristics : X8L 3. Exellent noise absorption. 4. Automotive grade (AEC-Q200) ◆APPLICATIONS 1. Noise filter for automotive equipment (ECU etc.) 2. Equipment used in a high temperature environment ◆CONSTRUCTION Ceramic Dielectric Termination (Tin Plating) Internal Electrode ◆RATINGS 1. 2. 3. 4. 5. 6. Category Temperature Range Rated Voltage Range Rated Capacitance Range Rated Capacitance Tolerance Temperature Characteristics Rated Ripple Current -55~+150℃ 25, 50, 100 Vdc 0.033~15μF M(±20%) X8L See No.5 on the following table ◆SPECIFICATIONS No. Items Specification Test Condition 1 Withstand Voltage No abnormality. 250% of rated voltage shall be applied for 5 seconds. 2 Insulation Resistance 100/CR(MΩ) or 4000(MΩ) whichever is less. Rated voltage shall be applied for 60±5 seconds at temperature 25±2℃. 3 Rated Capacitance Within specified tolerance. CR>10µF CR≦10µF Temperature 4 5 Dissipation Factor 5.0% maximum. Rated Ripple Current Size code 31 32 43 55 Arms 0.3 0.5 1.0 2.0 25±2℃ Frequency 1±0.1kHz 120±12Hz Voltage 1±0.2Vrms 0.5±0.2Vrms 10kHz~1MHz (sine curve) Ripple voltage Vp shall be less than the rated voltage. The surface temperature MLCC must not exceed the maximum category temperature when the ripple current is applied. As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic capacitors. Please contact us for more information. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 19 CAT. No. E1002Z Ver.2 MULTILAYER CERAMIC CHIP CAPACITORS KVF Series ◆SPECIFICATIONS No. Items 6 High Temperature Exposure (Storage) 7 Temperature Cycle Specification Test Condition Temperature:Max. category temperature±3℃ Time:1000 ±48 0 hours Appearance : No abnormality. ΔC/C : ±20% D.F. : 10% maximum I.R.:50/CR(MΩ) or 1000(MΩ) whichever is less. Appearance : No visible damage. ΔC/C : ±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Step 1 2 3 4 Temperature (℃) Min.Category temperature±3 Room temperature Max. Category temperature±3 Room temperature (min.) 30±3 3 max. 30±3 3 max. (Epoxy resin PCB t=1.6mm) For 1000 cycles 8 9 Biased Humidity Appearance : No abnormality. ΔC/C : ±20% D.F. : 10% maximum I.R. : 25/CR(MΩ) or 1000(MΩ) whichever is less. Temperature:85℃±3℃ Humidity:80 ~ 85%RH Voltage:Rated voltage Time:1000 ±48 0 hours Operational Life Appearance : No abnormality. ΔC/C : ±20% D.F. : 10% maximum I.R. : 50/CR(MΩ) or 1000(MΩ) whichever is less. Temperature:Max. category temperature±3℃ Voltage:Rated voltage Time:1000 ±48 0 hours Appearance : No abnormality. ΔC/C:To meet the initial specification. D.F. : To meet the initial specification. MIL-STD-202 Method213 Condition F Peak value:1,500 G Normal duration:0.5 ms Velocity change:15.4 ft/sec (4.7m/s) Direction and time:3 times each in X,Y, Z axis. Total 18 times 10 Mechanical Shock 11 Resistance to Soldering Heat Appearance : No visible damage. ΔC/C : ±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Preheating temperature : 150±10℃ Preheating time:1 to 2 minute Solder temp.:260±5℃ Dipping Time:10±1s 12 ESD Appearance : No abnormality. ΔC/C:To meet the initial specification. D.F. : To meet the initial specification. I.R. : To meet the initial specification. AEC-Q200-002 Connection:Between terminals Direct Contact:8kV (150pF 2000Ω) Times:±1time 13 Solderability Min. 75% of surface of the termination shall be covered with new solder. Solder Solder Temperature Dipping Time Appearance : No visible damage. ΔC/C : ±15% Pb Free 245 ±5℃ 2±0.5s The substrate shall be bend at rate of 1mm/s for 5 seconds. Press Press bar Capacitor 14 Substrate Board Flex Bending capability* 45±2mm 45±2mm Support * Bending capability :1mm or 2mm No visible damage. 15 Substrate Terminal Strength (SMD) 17.7N 60±1 seconds Capacitor *CR : Rated Capacitance(µF) Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 20 CAT. No. E1002Z MULTILAYER CERAMIC CHIP CAPACITORS KVF Series ◆STANDARD RATINGS Rated voltage (Vdc) Dimensions(mm) Rated Capacitance (μF) 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10 15 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 0.033 0.047 0.068 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 25 50 100 Maximum ripple current (Arms) L W T max. a 3.2±0.3 1.6±0.2 1.8 0.7±0.2 0.3 3.2±0.4 2.5±0.3 2.6 0.7±0.2 0.5 4.5±0.4 3.2±0.4 2.8 0.7±0.2 1.0 5.7±0.4 5.0±0.4 2.8 1.0±0.4 2.0 3.2±0.3 1.6±0.2 1.8 0.7±0.2 0.3 3.2±0.4 2.5±0.3 2.6 0.7±0.2 0.5 4.5±0.4 3.2±0.4 2.8 0.7±0.2 1.0 5.7±0.4 5.0±0.4 1.0±0.4 2.0 3.2±0.3 1.6±0.2 1.8 0.7±0.2 0.3 3.2±0.4 2.5±0.3 2.6 0.7±0.2 0.5 4.5±0.4 3.2±0.4 2.8 0.7±0.2 1.0 5.7±0.4 5.0±0.4 2.8 1.0±0.4 2.0 2.8 3.2 Part Number KVF250L334M31NLT00 KVF250L474M31NLT00 KVF250L684M31NLT00 KVF250L105M31NLT00 KVF250L155M32NHT00 KVF250L225M32NHT00 KVF250L335M32NHT00 KVF250L475M43NHT00 KVF250L685M43NHT00 KVF250L106M55NHT00 KVF250L156M55NHT00 KVF500L104M31NLT00 KVF500L154M31NLT00 KVF500L224M31NLT00 KVF500L334M31NLT00 KVF500L474M31NLT00 KVF500L684M32NLT00 KVF500L105M32NHT00 KVF500L155M43NHT00 KVF500L225M43NHT00 KVF500L335M55NLT00 KVF500L475M55NHT00 KVF500L685M55NHT00 KVF101L333M31NLT00 KVF101L473M31NLT00 KVF101L683M31NLT00 KVF101L104M31NLT00 KVF101L154M32NLT00 KVF101L224M32NLT00 KVF101L334M32NLT00 KVF101L474M43NLT00 KVF101L684M43NLT00 KVF101L105M55NLT00 KVF101L155M55NLT00 Taping Quantity per reel (pcs. / reel) 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 3,000 3,000 3,000 3,000 3,000 1,600 1,600 800 800 800 800 800 3,000 3,000 3,000 3,000 1,600 1,600 1,600 800 800 800 800 ※ Please consult with us when you consider the rating other than a standard table. 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ◆DIMENSIONS 18 Size Code Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category Size Code Code JIS T 1 K VF 5 0 0 L 6 8 5 M 5 5 NH T 0 0 3216 1206 43 4532 1812 32 55 76 3225 5750 7563 L EIA 31 1210 2220 W ◆PART NUMBERING SYSTEM a 3025 Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 21 CAT. No. E1002Z
KVF500L104M31NLT00 价格&库存
很抱歉,暂时无法提供与“KVF500L104M31NLT00”相匹配的价格&库存,您可以联系我们找货
KVF500L104M31NLT00
    • 1+1.45466
    • 200+0.56301
    • 500+0.54324
    • 1000+0.53342
