BCRH104R-150M-NL
BCRH104R-150M-NL
    BC(台湾诚阳)
    SMD
    BCRH104R-150M-NL
BCRH104R-150M-NL 数据手册
ROH S Compliant 承 認 書 SPECIFICATION FOR APPROVAL CUSTOMER: CUSTOMER P/N PART NO: DESCRIPTION: PRODUCTS NO: PRODUCTS REV: DATE: SMD POWER INDUCTORS BCRH104R-150M 01 2018-6-11 PURCHASER CONFIRMED. APPROVAL BY CHECK BY DRAWN BY REMARK PROVIDER ENGINEER DEPT. APPROVAL BY CHECK BY chenlinli 誠 陽 實 業 有 限 公 司 TAIPEI OFF ICE TAIWAN CHENG YANG COMPONENT CORP 2F-1, NO. 176, Chine-Yi Road., Zhonghe District, New Taipei City, TAIWAN(R.O.C) 新北市中和區建一路 176 號 2 樓之一 POSTAL CODE: 23500 TEL NO.:+886-2- 8228-0930 FAX NO.:+886-2-8228-0929 E-mail:h21803@ms29.hinet.net 寶 誠 電 子 有 限 公 司 CHINA FACTORY ZHUHAI BAO CHENG ELECTRONICSCO.,LTD Guan Tang Industrial Park, Tang Jia Wan Town, Zhuhai City, Guangdong Province, CHINA 中國廣東省珠海市塘家灣鎮官塘工業區 POSTAL CODE: 519085 TEL NO:86-756-3383187 FAX NO:86-756-3380704 E-mail: baocheng@baocheng.biz 昆 山 誠 陽 電 子 有 限 公 司 CHINA FACTORY KUNSHAN CHENG YANG ELECTRONICSCO.,LTDP Qiang-An Road., High-Tech. Industrial Park, Kunshan City, Jiangsu Province, China 江蘇省昆山市高科技工業園區強安路 35 號 POSTAL CODE: 215300 TEL NO:86-512-57823500 FAX NO:86-512-57823503 E-mail: kscy@taiwan-chengyang.com.tw ROHS Compliant TEST DATA DIMENSION&ELECTRIC CHARACTER CUSTOMER: PART NO.: DESCRIPTION: SMD INDUCTOR SERIES NO: BCRH104R-150M 1.MECHANICAL DIMENSION UNIT:mm 150 2 .RECOMMEND LAND PATTERN DIMENSIONS A 10.3MAX B 10.5MAX C 4.0MAX D 3.0+0.1 E 7.7+0.3 F 1.2+0.15 G H I 3.SEPCIFICATIONS Part Number BCRH104R-150M (1). (2). (3). (4). (5). L Inductance (uH) @(0A) 15.0 Rdc (mOHM) Typical Max 44 50 Heat Rating Current DC Amps.Idc(A) Saturation Current DC Amps.ldc(A) Typical Typical 3.1 3.6 All test data is referenced to 25℃ ambient. Operating Tenperature Rangr-30℃ to +100℃. DC current(A)that will cause an approaimate△T of 40℃. DC current(A)that will cause Lo to drop approximately 35%. The part temperature(ambient+temp rise)should not exeed 100℃ under worst case operating conditions.Circuit design,component placement,PWB trace size and thickness,airflow and oter aooting provisions all affsct the part temperature part temperature should be verified in the end appliation. 4.PACKAGING INFORMATION paets are packaged on 13"reels 800 parts per reel. A0= 10.3mm B0=10.5mm K0=4.1mm APPROVED BY: CHECKED BY: DRAWN BY:chenlinli Rohs Compliant ZHUHAI BAOCHENG ELECTRONICS CO.,LTD TEST DATA FOR PREPRODUCTION SAMPLE CUSTOMER: PART NAME: SMD INDUCTOR CUSTOMER P/N: CUSTOMER REV: TEST DATE:2018-6-11 BC PART NO: BCRH104R-150M BC REV: QUANTITY:10PCS TEST ITEM A B C SPEC. 10.3 10.5 4.0 MAX MAX MAX 01 10.00 10.25 3.81 02 9.99 10.24 3.79 03 10.00 10.28 3.83 04 10.03 10.29 3.82 05 10.19 10.31 3.82 06 10.18 10.38 3.79 07 10.05 10.29 3.83 08 10.06 10.19 3.81 09 10.18 10.32 3.86 10 10.09 10.27 3.84 X 10.08 10.28 3.82 σ 0.075 0.048 0.020 Cpk 0.99 1.50 2.93 D E F G H I J 11 12 13 14 15 APPROVED BY CHECKED BY PREPARED BY chenlinli K Rohs Compliant ZHUHAI BAOCHENG ELECTRONICS CO.,LTD TEST DATA FOR PREPRODUCTION SAMPLE CUSTOMER: PART NAME: TEST ITEM SMD INDUCTOR L(0A) TEST 100KHZ CONDITION CUSTOMER P/N: CUSTOMER REV: TEST DATE:2018-6-11 BC PART NO: BCRH104R-150M BC REV: QUANTITY:10PCS L(3.6A)/L(0A)·100% DCR(S-F) 0.25V SPEC. 15uH +20% = 65% AT DC 3.6A 01 14.36 73% 50m Ω MAX 43.66 02 14.22 78% 44.52 03 15.84 80% 45.78 04 14.67 78% 44.23 05 15.06 75% 43.43 06 14.05 89% 42.89 07 15.85 80% 42.56 08 14.82 78% 44.83 09 14.75 79% 45.18 10 14.32 73% 43.81 11 12 13 14 15 X 14.79 44.09 σ 0.600 0.963 Cpk 2.39 2.05 1. TEST INSTRUMENTS: □HP-4284A METER ■HP-4285A METER □HP-4191A METER □VR116+VR7220 METER □CH-3200 METER □CH-310 METER □CH-3305 METER ■CD1068+CD1320 METER □VR113+VR712+R712 METER □WK3260B+WK3265B METER □VR562 METER ■CH-502B DCR METER 2.CONDITION TEMPERATURE: 25℃ HUMIDITY: 65%RH APPROVED BY CHECKED BY PREPARED BY chenlinli ROHS Compliant ELECTRONICS CHARACTER TEST CHART CUSTOMER: PART NAME: SMD INDUCTOR TEMPERATURE RISE CURRENT DC:3.1A CUSTOMER P/N: TEST DATE:2018-6-11 BC P/N: BCRH104R-150M SAMPLE CO: TEST INSTRUMENTS CD1068+CD1320 METER 80.0 21.0 64.0 16.8 48.0 12.6 32.0 8.4 16.0 4.2 0.0 0min 15.10 INDUCTORS(uH) TEMPERATURE(℃) 29.0 3min 12.30 49.2 100KHZ 0.25V TEST TERM: 2.INDUCTCMCE VS CURRENT 6min 12.20 54.2 9min 12.10 56.7 12min 12.10 58.3 15min 12.00 58.9 18min 12.00 59.1 TEST INSTRUMENTS: 20min 12.00 59.9 TIME WK3260B+WK3265B METER 21.0 INDUCTORS(uH) 0.0 INDUCTORS(uH) TEMPERATURE (℃) 1.CURVES OF TEMPERATURE AND INDUCTAME VARIED WITH TP CARRENT ● Saturated Current point 16.8 12.6 ■DTL=-35% 8.4 ▲DTL=-50% 4.2 0.0 INDUCTORS 0A 14.70 1.2A 14.50 0.25V TEST TERM: 3.INDUCTCMCE VS FREQUENCUY 1.8A 14.00 2.4A 13.30 3A 12.40 3.6A 11.10 TEST INSTRUMENTS: 4.1A 9.39 4.72A 7.02 CURRENT (A) WK3260B+WK3265B METER INDUCTORS(uH) 21.0 16.8 12.6 8.4 4.2 0.0 INDUCTORS 1KHz 10KHz 50KHz 100KHz 300KHz 500KHz 800KHz 1MHZ 15.30 15.20 15.10 14.90 14.80 14.70 14.60 14.50 1.TEST CONDITION TEMPERATURE: 25℃ HUMIDITY: ≦ 65% RH APPROVED BY CHECKED BY FREQUENCY(Hz) PREPARED BY chenlinli PACKAGE STANDARD BCRH104R PART NO. 1 NO SERIES A B C MODEL φ330*24 SMD-BC BC-10 QUANTITY 800PCS 800PCS 4000PCS ■GENERAL CHARACTERISTICS P.1 Operation Temperature -30℃ to +100℃ (Includes temperature when the coil is heated) External Appearance On visual inspection, the coil has no external defects. 1.More than 90% of terminal electrode should be covered with solder. Solder Ability Test  After fluxing, component shall be dipped in a melted.  Solder: bath at 230℃±5℃ for 5±0.5 seconds. 1.Components should have not evidence of electrical and mechanical damage. 2.Inductance: within±10% of initial value. 3.Impedance: within±30% of initial value. Solder Heat Resistance     Preheat:150±5℃ 60seconds. Solder temperature: 260±5℃. Flux: rosin. Dip time:10±0.5seconds. After soldering of X,Y withstanding at below conditions .The terminal should not Peel off. (Refer to figure at below)  5N:60sec. Terminal Strength Insulating Resistance BC Series, BCB Series, BCDB Series, BCEI Series BCEP Series, BCH Series, BCMD Series, BCMS Series, BCPF Series, BCPS Series BCR Series, BCRH Series, BCRHB Series, BCX Series, BCIHP Series, BCLQ72, BCRM135, BCPH73, BCC5D23, BCHP1210.  10N:10sec. BC73, BC75, BC4020FH, BC74B.  15N:10sec. BC104, BC105, BC105B, BC108, BC5022FH.  20N:10sec. BCR125B. Over 100MO at 100V D.C. between coil and core. Dielectric Strength No dielectric breakdown at 100V D.C. for 1 minute between coil and core. Inductance deviation within +3% after vibration for 1 hour. In each of three Vibration Resistance orientations at Sweep vib ration (10~55~10HZ) with 1.5mmP-P amplitudes. Inductance deviation within +3% after being dropped once with 981m/s2 (100G) shock Attitude upon a rubber block method shock testing machine, in Shock Resistance three different orientations.  Application Notice/Handling 1. Storage Conditions To maintain the solder ability of terminal electrodes: (1) Temperature and humidity conditions: less than 40℃ and 70% RH. (2) Products should be used within 6 months. (3) The packaging material should be kept where no chlorine or sulfur exists in the air. 2. Handling (1) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of solderability. (2) The use of tweezers or vacuum pick-ups is strongly recommended for individual components. (3) Bulk handling should ensure that abrasion and mechanical shock are minimized. BC-GC-2005-July-21 ■THE CONDITION OF REFLOW(RECOMMENDATION) TYPICAL WAVE SOLDER PROFILE FOR LEADED AND LEAD-FREE THROUGH-HOLE PACKAGES P.2 TYPICAL IR REFLOW PROFILE FOR LEADED AND LEAD-FREE SURFACE MOUNT PACKAGES IPC/JEDEC J-STD-020C, Figure 5-1 BC-GC-2005-june-10 ▓GENERAL CHARACTERISTICS TEST High Temperature Storage Test Reference documents: MIL-STD-202G Method 108A Low Temperature Storage Test Required Characteristics 1.No case deformation or change in appearance 2.△L/L≦10% 3.△Q/Q≦30% 4.△DCR/DCR≦10% 1.No case deformation or change in appearance. 2.△L/L≦10% 3.△Q/Q≦30% 4.△DCR/DCR≦10% Reference documents: IEC 68-2-1A 6.1 6.2 Test Method/Condition P.3 Temperature:85℃±2℃ Time:96±2 hours. Tested not less than 1 hour, nor more than 2 hours at room. Temperature:-25℃±2℃ Time:96±2 hours. Tested not less than 1 hour, nor more than 2 hours at room. 1.No case deformation or change in appearance. 2.△L/L≦10% 3.△Q/Q≦30% 4.△DCR/DCR≦10% Humidity Test Reference documents: MIL-STD-202G Method103B 1. Dry oven at a temperature of 40℃±5℃ for 24 hours. 2. Measurements At the end of this period 3. Exposure: Temperature: 40℃±5℃.Humidity:93±2hoyrs. 4. Tested while the the chamber. 5. Tested not less than 1 hour. Nor more than 2 hours at room temperature. 1. No case deformation or change in appearance. 2. △L/L≦10% 3. △Q/Q≦30% Thermal Shock Test 4. △DCR/DCR≦10% Reference documents: For T: weight≦28g : 15Min MIL-STD-202G Method107G 28g≦weight≦136g:30Min First – 40℃ for T time, last 125℃ T time as 1 cycle. Go through 20 cycles. ¦Application Notice/Handling (4) Temperature and humidity conditions : less than 40℃ and 70% RH. (5) Products should be used within 6 months. (6) The packaging material should be kept where no chlorine or sulfur exists in the air. (7) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of solder ability (8) The use of tweezers or vacuum pick-ups is strongly recommended for individual components. (9) Bulk handling should ensure that abrasion and mechanical shock are minimized. BC-GC-2005-june-10
BCRH104R-150M-NL 价格&库存
很抱歉,暂时无法提供与“BCRH104R-150M-NL”相匹配的价格&库存,您可以联系我们找货
BCRH104R-150M-NL
    • 5+2.03148
    • 50+1.61234
    • 150+1.43273
    库存:109
