RS2MG
RS2MG
    PINGWEI(平伟)
    SMB(DO-214AA)
RS2MG 数据手册
RS2MG 规格书 RS2MG 2.0AMPS. FAST RECOVERY SURFACE MOUNT RECTIFIERS FEATURE SMB(DO-214AA) .Fast switching .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed: 260℃/10 seconds at terminals. .For surface mounted application. .Easy pick and place. .083(2.11) .075(1.91) .155(3.94) .130(3.30) .185(4.70) .160(4.06) .012(0.305) .006(0.152) .103(2.60) .078(1.98) MECHANICAL DATA .060((1.52) .032(0.80) .Case: Molded plastic .Epoxy: UL94V-0 rate flame retardant .Lead: MIL-STD- 202E, Method 208 guaranteed .Polarity:Color band denotes cathode end .Packaging:12mm tape per EIA STD RS-481 .Mounting position: Any .008(0.203) .002(0.051) .217(5.50) .193(4.9) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TA=55°C SYMBOL RS2MG units VRRM VRMS VDC 1000 V 700 V 1000 V IF(AV) 2.0 A IFSM 60.0 A VF 1.3 V Peak Forward Surge Current 8.3ms single half sine- wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 2.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =100°C Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Typical Thermal Resistance (Note 3) Storage Temperature Operation Junction Temperature 5.0 IR 100.0 trr CJ R(JA) TSTG TJ Note: 1. Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 3. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas. 1 µA 500 nS 30 pF 50 °C /W -55 to +150 °C -55 to +150 °C RS2MG 规格书 RATING AND CHARACTERISTIC CURVES (RS2MG) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 2.0 1.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 150 100 1.0 .1 .01 200 TJ=25 ℃ Pulse Width=300 μs 1% Duty Cycle 1.4 1.0 .6 1.8 2.2 AMBIENT TEMPERTURE,(℃) INSTANEOUS FORWARD VOLTAGE,(V) FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT FIG.4-TYPICAL REVERSE CHARACTERISTICS 80 INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) 10 8.3ms Single Half Sine-Wave (JEDEC Method) 60 40 20 1.0 TJ=25 ℃ .1 .01 0 1 100 10 0 20 40 60 NUMBER OF CYCLES AT 60Hz FIG.5-TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERSITIC 50 Ω NONINDUCTIVE (+) 25Vdc (approx) (-) 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) 10 Ω NONINDUCTIVE +0.5A (+) 0 PULSE GENERATOR -0.25A (NOTE 2) 1Ω (NOTE 1) NON- OSCILOSCOPE INDUCTIVE (-) -1.0A NOTES:1. Rise Time=7ns max, Input Impedance= 1 megohm.22pF. 2. Rise Time=10ns max, Souce Impedance= 50 ohms. 2 trr 140
RS2MG 价格&库存
很抱歉,暂时无法提供与“RS2MG”相匹配的价格&库存,您可以联系我们找货
