CUSTOMER :
(客戶) : 志盛翔
DATE :
(日期) : 2020-08-24
: ELECTRIC DOUBLE LAYER CAPACITORS
CATEGORY (品名)
DESCRIPTION (型号) : DRL 2.7V15F (φ12.5X25)
: 01
VERSION (版本)
Customer P/N
SUPPLIER
SUPPLIER
PREPARED
(拟定)
邓文文
CUSTOMER
CHECKED
(审核)
付婷婷
APPROVAL
(批准)
SIGNATURE
(签名)
ELECTRIC DOUBLE LAYER CAPACITORS SPECIFICATIONS
DRL SERIES
SPECIFICATION
Rev.
Date
DRL SERIES
Mark
Page
Issued-date: 2020-08-24
Version
Name
ALTERNATION HISTORY
RECORDS
Contents
Purpose
Drafter
Approver
Specification Sheet – DRL
01
Page
STANDARD MANUAL
1
DRL SERIES
CONTENTS
Sheet
1.
2.
3.
Application
Part Number System
Characteristics
3
3
4~10
3.1 Rated voltage & Surge voltage
3.2 Capacitance (Tolerance)
3.3 ESR
3.4 Leakage current
3.5 Temperature characteristic
3.6 Load life test
3.7 Damp heat test
3.8 Lead strength
3.9 Resistance to vibration
3.10 Solderability
3.1 1 Resistance to soldering heat
4. Product Dimensions
5. Notice item
Version
11
12
Name
01
Page
STANDARD MANUAL
2
DRL SERIES
1.
Applicati on
The specification applies to electric double layer capacitors used in electronic equipment.
2.
Part Number System
DRL 156 S 0T
I 25 CB
Type (2.3)
Case Length (2.6)
Diameter (2.5)
Voltage (2.2)
Tolerance (2.4)
Capacitance (2.1)
Series
2.1
2.2
2.3
2.4
2.5
2.6
Capacitance code
Code
156
Capacitance (F)
15
Rated voltage code
Code
Voltage (W.V.)
0T
2.7
Type
Code
Type
CB
Lead Cut
Capacitance tolerance
“S” stands for -20% ~ +50%
Diameter
Code
Diameter
I
12.5
Case length
25=25mm
Version
Name
01
Page
STANDARD MANUAL
3
DRL SERIES
3. Characteristics
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurements and tests is as
follows:
Ambient temperature: 15C to 35C
Relative humidity : 25% to75%
Air Pressure
: 86kPa to 106kPa
If there is any doubt about the results, measurement shall be made within the following conditions:
Ambient temperature: 20C 2C
Relative humidity : 60% to 70%
Air Pressure
: 86kPa to 106kPa
Operating temperature range
The ambient temperature range at which the capacitor can be operated continuously at rated voltage
is -40C to 70C.
Version
Name
01
Page
STANDARD MANUAL
4
DRL SERIES
ITEM
PERFORMANCE
Rated voltage
(WV)
3.1
WV (V.DC)
2.7
SV (V.DC)
2.8
Surge voltage
(SV)
Constant current discharge method:
Measuring circuit:
A
S
Constant current /
constant voltage
power supply
V Cx
Constant Current
Discharger
Key
A
3.2
Nominal
capacitance
(Tolerance)
V
S
Cx
d.c. ammeter
d.c. voltmeter
changeover switch
capacitor under test
Figure 1- Circuit for constant current discharge method
Measuring method
a) Set the d.c.voltage at the rated voltage (UR)
b) Set the constant current value of the constant current discharger to the discharge
current specified in Table 1.
c) Turn the switch S to the d.c.power supply ,apply voltage and charge for 30 min
after the constant current / constant voltage power supply has achieved the rated
voltage.
d) After a charge for 30 min has finished ,change over the switch S to the constant
current discharger ,and discharge with a constant current.
e) Measure the time t1 and t2 where the voltage between capacitor terminals at the
time of discharge reduces from U1 to U2 as shown in Figure 2 ,and calculate the
capacitance value by the following formula:
Version
Name
01
Page
STANDARD MANUAL
5
DRL SERIES
△U3
UR
U1
△U3:IR drop
Voltage (V)
U2
t1
30 min
t2
Time (s)
Figure 2- Voltage characteristic between capacitor terminals
C=
Ix(t2-t1)
U1-U2
3.2
Nominal
capacitance
(Tolerance)
Where
C is the capacitance(F);
I
is the discharge current (A);
U1 is the measurement starting voltage (V);
U2 is the measurement end voltage (V);
t1 is the time from discharge start to reach U1 (s);
t2 is the time from discharge start to reach U2 (s).
f) The discharge current I and the voltages U1 and U2 at the time of discharge voltage
drop shall be as per Table 1 .The method classification shall be in accordance with
the individual standards.
Table 1 – Discharge conditions
Charge time 30 min
I(mA)
4 x CUR
U1
The value to be 80% of the charging voltage (0.8xUR)
U2
The value to be 40% of the charging voltage (0.4xUR)
NOTE CR is the rated capacitance in F(Farad),and UR is the rated voltage in V (Volt)
Version
Name
01
Page
STANDARD MANUAL
6
DRL SERIES
3.3
ESR
Measuring frequency :1kHz
Measuring temperature:20±2℃
Measuring point
: 2mm max from the surface of a sealing resin on the lead wire.
(20℃)Less than the initial limit:
Rated
Dimension
ESR,AC(mΩ )(max)
Capacitanc
Voltage
e (F)
(D×L, mm)
at 1kHz/20℃
(V)
2.7
3.4
Leakage
current
15
12.5X25
80
1. Ambient temperature: 25C 2C.
2.The electrification time:72H
3. Desistance value of protective resistor less than 1Ω .
Less than the initial limit(25C 2C):
I≤ 0.030mA
I is the Leakage current
STEP
Temperature(℃)
1
20±2
Item
Capacitance、
ESR
△ C/C
2
-40+3
ESR
3.5
Temperature
characteristic
Keep at 15 to 35℃ for
15 minutes or more
3
4
Characteristics
----------Within ±30% of
initial capacitance
Less than or equal to
4 times of the value
of item 3.3
△ C/C
Within ±30% of
initial capacitance
The limit specified in
3.3
70±2
ESR
a. ESR -40℃/ ESR 20℃: ESR ratio at 1kHz;
b. ΔC/C 20℃: Capacitance change ;
Version
Name
01
Page
STANDARD MANUAL
7
DRL SERIES
The Capacitor is stored at a temperature of 70 ±2 °C with rated
voltage for 1000 +48/0 hours .The result should meet the following table:
Item
Performance
Capacitance Change
3.6
Load
life
test
ESR
Appearance
Within ±30% of initial capacitance
Less than or equal to 4 times of the value of item
3.3
No visible damage and no leakage of electrolyte
Humidity Test:
The capacitor shall be exposed for 240±48 hours in an atmosphere of 90~95%RH at
40±2℃, the characteristic change shall meet the following requirement.
Item
3.7
Damp
heat
test
Capacitance Change
ESR
Less than or equal to 4 times of the value of item 3.3
Appearance
Version
Performance
Name
01
Page
STANDARD MANUAL
8
DRL SERIES
a) Lead pull strength
A static load force shall be applied to the terminal in the axial direction and
acting in a direction away from the body for 10±1 s.
Lead wire diameter (mm)
Load force (N)
10
0.5 < d ≤0.8
3.8
Lead strength
b) Lead bending
When the capacitor is placed in a vertical position and the weight specified in the
table above is applied to one lead and then the capacitor is slowly rotated 900 to a
horizontal position and then returned to a vertical position thus completing bends
for 2~3seconds.
The additional bends are made in the opposite direction
Load force (N)
0.5 < d ≤0.8
5
Performance: The characteristic shall meet the following value after a) or b) test.
Item
Performance
Capacitance Change
No visible damage Legible marking and no
Appearance
Frequency: 10 to 55 Hz (1minute interval / 10 → 55 → 10Hz
Amplitude: 0.75mm(Total excursion 1.5mm)
Direction :X、 Y、 Z (3 axes)
Duration: 2hours/ axial (Total 6 hours)
The capacitors are supported as the following Fig2
3.9
≤0.3mm
Resistance to
vibration
Fig2
Performance: Capacitance value shall not show drastic change compared to the initial
capacitance when the value is measured within 30 minutes. Prior to the completion of
exam, Capacitance difference shall be within ±10% compared to the initial value the
exam.
Version
Name
01
Page
STANDARD MANUAL
9
DRL SERIES
T
T
3.10
Solderability
The capacitor shall be tested under the following conditions:
Solder
: Sn-3Ag-0.5Cu
Soldering temperature: 2453C
Immersing time
: 2.00.5s
Immersing depth
: 1.5~ 2.0mm from the root.
Flux
: Approx .25% rosin (JIS K5902) in ETHANOL (JIS K1501)
Performance: At least 75% of the dipped portion of the terminal shall be covered
with new solder.
A) Solder bath method
Lead terminals of a capacitor are placed on the heat isolation board with thickness of
1.60.5mm. It will dip into the flux of isopropylaehol solution of colophony.
Then it will be immersed at the surface of the solder with the following condition:
Solder
: Sn-3Ag-0.5Cu
: 260 5C
Immersing time
: 50.5s
Heat protector: t=1.6mm glass –epoxy board
3.11
Resistance
to soldering
heat
B) Soldering iron method
Bit temperature
: 350 10C
Application time
: 3.5 0.5 s
For both methods, after the capacitor at thermal stability, the following items shall be
measured:
Item
Performance
Capacitance Change
Within ±10% of initial capacitance
No visible damage legible marking and no leakage
Appearance
of electrolyte
Version
Name
01
Page
STANDARD MANUAL
10
DRL SERIES
Unit: mm
L+2.0max
d±0.05
F±0.5
D+0.5
H±0.5
Version
φD
12.5
L
25
F
5.0
φd
0.6
H
3.5
Name
01
Page
STANDARD MANUAL
11
DRL SERIES
5 . Notice item
(1)The capacitor has fixed polarity.
(2)The capacitor should be used under rated voltage.
(3)The capacitor should not be used in the charge and discharge circuit with high frequency.
(4)The ambient temperature affects the super capacitor life.
(5)Voltage reduction ΔV=IR will happen at the moment of discharge.
(6)The capacitor cannot be stored on the place with humidity over 85%RH or place with toxic gas.
(7)The capacitor should stored in the environment within -30℃~50℃ temperature and less than 60% relative humidity.
(8)If the capacitor is applied on the double-side PCB, the connection should not be around the place on which the super
capacitor can contact.
(9)Don't twist capacitor or make it slanting after installing.
(10)Need avoid over heat on the capacitor during soldering (The temperature should be 260℃ with the time less than 5s
during soldering on 1.6mm printed PCB.)
(11)There is voltage balance problem between each capacitor unit during series connection between super capacitor.
Version
Name
01
Page
STANDARD MANUAL
12
