EKHE401ELL820MK40S
EKHE401ELL820MK40S
    NCC(贵弥功)
    插件
    铝电解电容器 Radial
EKHE401ELL820MK40S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS 400 to 450Vdc, Downsized, 105℃ KHE KHF Series Downsized ・Ideal for low profile power supply applications ・Downsize, high ripple design ・Rated voltage range : 400 to 450Vdc, Capacitance range : 27 to 120µF ・Endurance with ripple current : 2,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant KHE Downsized PAG ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 400 to 450Vdc ±20% (M) (at 20℃, 120Hz) After 1 minute After 5 minutes CV≦1,000 I=0.1CV+40 I=0.03CV+15 CV>1,000 I=0.04CV+100 I=0.02CV+25 Where, I : Max. leakage current(µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃) Rated voltage (Vdc) 400V 420V 450V tanδ (Max.) 0.15 0.20 0.20 (at 20℃, 120Hz) Rated voltage (Vdc) 400V 420V 450V Z(-25℃)/Z(+20℃) 5 6 6 Z(-40℃)/Z(+20℃) 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 2,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦500% of the initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] Code : E φD' φd Sleeve (PET : Brown) φ10 F±0.5 ●Terminal φD φd F φD' 15min. L' Vent 4min. L' (φ10) 10 0.6 5.0 12.5 14.5 16 0.6 0.8 0.8 5.0 7.5 7.5 φD+0.5 max. L+2.0 max. 18 0.8 7.5 φD' φd Sleeve (PET : Brown) ≧φ12.5 F±0.5 Gas escape end seal L' Vent 15min. 4min. (φ12.5 to φ18) ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KHE AAA E AA AAA M AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 400V:401,450V:451) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001W 2022 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS 400 to 450Vdc, Downsized, 105℃ KHESeries ◆STANDARD RATINGS WV (Vdc) 400 420 Cap (µF) Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 33 39 47 56 56 68 82 82 100 100 100 120 120 120 33 39 47 56 56 68 82 82 100 100 100 120 120 120 10×30 10×35 10×40 10×45 12.5×30 12.5×35 12.5×40 14.5×31.5 12.5×45 14.5×35 16×31.5 14.5×40 16×35 18×31.5 10×30 10×35 10×40 10×50 12.5×30 12.5×35 12.5×40 14.5×31.5 12.5×50 14.5×40 16×31.5 14.5×45 16×35 18×31.5 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 335 385 445 505 480 560 640 625 730 715 720 810 810 815 335 385 445 520 480 560 640 625 750 740 720 835 810 815 Part No. EKHE401E□□330MJ30S EKHE401E□□390MJ35S EKHE401E□□470MJ40S EKHE401E□□560MJ45S EKHE401E□□560MK30S EKHE401E□□680MK35S EKHE401E□□820MK40S EKHE401E□□820MUN3S EKHE401E□□101MK45S EKHE401E□□101MU35S EKHE401E□□101MLN3S EKHE401E□□121MU40S EKHE401E□□121ML35S EKHE401E□□121MMN3S EKHE421E□□330MJ30S EKHE421E□□390MJ35S EKHE421E□□470MJ40S EKHE421E□□560MJ50S EKHE421E□□560MK30S EKHE421E□□680MK35S EKHE421E□□820MK40S EKHE421E□□820MUN3S EKHE421E□□101MK50S EKHE421E□□101MU40S EKHE421E□□101MLN3S EKHE421E□□121MU45S EKHE421E□□121ML35S EKHE421E□□121MMN3S WV (Vdc) Cap (µF) Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 450 27 33 39 47 47 56 68 68 82 82 82 100 100 120 10×30 10×35 10×40 10×45 12.5×30 12.5×35 12.5×40 14.5×31.5 12.5×45 14.5×35 16×31.5 14.5×40 16×35 18×31.5 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 305 355 405 460 440 505 580 570 660 650 655 740 740 815 Part No. EKHE451E□□270MJ30S EKHE451E□□330MJ35S EKHE451E□□390MJ40S EKHE451E□□470MJ45S EKHE451E□□470MK30S EKHE451E□□560MK35S EKHE451E□□680MK40S EKHE451E□□680MUN3S EKHE451E□□820MK45S EKHE451E□□820MU35S EKHE451E□□820MLN3S EKHE451E□□101MU40S EKHE451E□□101ML35S EKHE451E□□121MMN3S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 27 to 82 100 to 120 120 1.00 1.00 1k 1.50 1.30 10k 1.75 1.40 100k 1.80 1.50 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001W 2022
EKHE401ELL820MK40S 价格&库存
很抱歉,暂时无法提供与“EKHE401ELL820MK40S”相匹配的价格&库存,您可以联系我们找货
