KLPX-0848A-2-Y
KLPX-0848A-2-Y
    KYCON
    KLPX-0848A-2-Y
KLPX-0848A-2-Y 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLPX-0848A-2-B-G Part Number Builder RCA PHONO JACKS: KLPX Series KLPX 0848A-2 B G Series Type Color Option Plating Option RCA Phono Jack PCB Mount Product Features Audio Applications for Computers and Multimedia Two Contact Cost Efficient Design Right Angle and Vertical Mount Available Performance Specifications Materials and Finish Housing PBT Thermoplastic, UL94V-0 Rated Terminals Brass,Tin Plated Color Option B - Black R - Red W - White Y - Yellow Barrel Plating Option Blank - Nickel Plating Contact Kycon for other options KLPX Dimensions in mm 10.00 Mechanical Characteristics 9.50 10.00 ¯8.30 5.00 Ø3.30 8.00 8.00 Insertion Force 0.3kg - 3.0kg Extraction Force 0.3kg - 3.0kg Durability 5000 Mating Cycles Min. Operating Temperature -25°C to +80°C 4.00 3.50 Contact Resistance 30 milliohms Max. Insulation Resistance 100 Megohms Min.at 500V DC Dielectric Withstanding Voltage 500V AC RMS for 1 Minute Type 0848-2 - Vertical Mount 0848A-2 - Right Angle Mount 6.50 Electrical Characteristics Series KLPX - RCA Phono Jack 4.00 2.00 4.00 1.50 4.50 1 2 Schematic Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0316
KLPX-0848A-2-Y 价格&库存
很抱歉,暂时无法提供与“KLPX-0848A-2-Y”相匹配的价格&库存,您可以联系我们找货
KLPX-0848A-2-Y
    • 1+9.99000
    • 200+3.86640
    • 500+3.73680
    • 1000+3.66120
    KLPX-0848A-2-Y
    • 1+9.015081+1.15628
    • 10+7.6318410+0.97887
    • 25+7.1548125+0.91769
    • 50+6.8138650+0.87395
    • 100+6.48701100+0.83203
    • 250+6.08069250+0.77992
    • 500+5.79010500+0.74265
    • 1000+5.513711000+0.70720
    • 2500+5.168532500+0.66292
    库存:4
