VDA3010CTA
VDA3010CTA
    ANASEM(安纳森)
    SOT-23
    VDA3010CTA
VDA3010CTA 数据手册
AnaSem 安纳森 Analog Semiconductor IC VDA Series Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector (IMPORTANT: Please check the last page for Genuine Product Labeling) Website: Tel: Email: Rev. E13-01 www.anasemi.com +852-3590-8442 sales@anasemi.com AnaSem .......... Future of the analog world Rev. E13-01 Products Data Sheet AnaSem Analog Semiconductor IC Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series GENERAL DESCRIPTIONS The VDA series are voltage detectors with low voltage, low power consumption and high accuracy. The accuracy of the detection voltage is detected based on a voltage reference of high accuracy that the temperature coefficient is controlled. The detection voltage is made in high accuracy by using the laser trimming technology. HALOGEN RoHS COMPLIANCE FEATURES 0.8V~6.0V (selectable with a step of 0.1V) Detection voltage range ·································································· 0.7V~6.0V Operating voltage range ·································································· ±1% (VDET=1.8V~6.0V) / ±2% (VDET=0.8V~1.7V) High accuracy detection voltage ····················································· Typ. ±20ppm/°C (VDET = 1.8V~6.0V) Detection voltage temperature characteristics ·································································· CMOS or N-channel open drain Output types ························································································· Typ. 0.6µA (VIN = 1.5V) Low current consumption ·································································· –40°C ~ +85°C Operating temperature range ·································································· SOT-23 (2.9×2.8×1.1mm) Small package ························································································· APPLICATIONS Reset of microprocessor Power-on reset of system Charge detection of battery Battery back-up of memory Monitoring of battery life time AnaSem 1 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 PRODUCTS NUMBERING GUIDE VDA Design version A : TOPR = –40°C ~ +85°C Package form T : SOT-23 Output type C : CMOS output N : N-channel open drain output Detection accuracy rate 10 : ±1% 20 : ±2% Detection voltage 08 ~ 60 : Selectable with a step of 0.1V in the range of 0.8V ~ 6.0V e.g.) 18 : 1.8V 30 : 3.0V PIN CONFIGURATION / MARKING SPECIFICATION (SOT-23) Pin Configuration Vin 3 A B C D E No. Symbol Descriptions 1 VOUT 2 VSS Power ground 3 VIN Voltage input Output F F F F Marking Specification 1 2 Vout Vss (Top view) Code Mark Contents A C or N Output type BC 08~60 Detection voltage D 1 or 2 Detection accuracy rate E A F Internal rule Version Lot number AnaSem 2 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TYPICAL APPLICATION CIRCUITS CMOS output N-channel open drain output 100KΩ VOUT VOUT VIN VIN VSS VSS BLOCK DIAGRAM CMOS output N-channel open drain output VIN VIN + Voltage Reference + VOUT Voltage Reference _ Vss VOUT _ Vss ABSOLUTE MAXIMUM RATINGS Items Symbol Ratings Unit Input voltage range VIN –0.3 ~ +7.0 V Output current IOUT 50 mA Output voltage range VOUT VSS –0.3 ~ VIN +0.3 V PD 400 mW Operating temperature range TOPR –40 ~ +85 °C Storage temperature range TSTG –55 ~ +125 °C Power dissipation ※1) SOT-23 Note : ※1) Power dissipation depends on conditions of mounting on boards. PCB dimension is 50mm×50mm×1.6mm. AnaSem 3 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 ELECTRICAL CHARACTERISTICS (Ta=25°C unless otherwise specified) Items Symbol Operating voltage Typ. Max. Unit Test circuit 1 VDET = 0.8V ~ 6.0V 0.7 - 6.0 V VDET VDET = 1.8V ~ 6.0V Ta = –40°C ~ +85°C VDET ×0.99 VDET VDET ×1.01 V VDET VDET = 0.8V ~ 1.7V Ta = –40°C ~ +85°C VDET ×0.98 VDET VDET ×1.02 V VDET ×0.02 VDET ×0.05 VDET ×0.08 V VIN=0.7V 0.1 0.35 - mA VIN=1.0V 1.0 2.3 - mA VIN=2.0V 3.0 8.2 - mA VIN=3.0V 5.0 11.1 - mA VIN=4.0V 6.0 12.8 - mA VIN=5.0V 7.0 13.8 - mA CMOS P-ch VDS=2.1V VIN=6.0V - -9.5 -1.5 mA 4 CMOS N-ch VDS=2.1V VIN=6.0V 1.5 9.5 - mA 3 VIN=1.5V - 0.6 2.1 µA VIN=2.0V - 0.7 2.5 µA VIN=3.0V - 0.8 2.8 µA VIN=4.0V - 0.9 3.0 µA VIN=5.0V - 1.0 3.4 µA VIN=6.0V VOUT=6.0V - 10 100 nA VDET = 1.8V ~ 6.0V Ta = –40°C ~ +85°C - ±20 - ppm/°C VDET = 0.8V ~ 1.7V Ta = –40°C ~ +85°C - ±100 - ppm/°C Inverts from VDR to VOUT - 0.03 0.2 ms VHYS N-ch VDS=0.5V Output current Min. VIN Detection voltage Hysteresis range Conditions 1 1 3 IOUT Current consumption Leak current ISS ILEAK Detection voltage temperature coefficient Delay time VDR→VOUT inversion ∆VDET / ∆Ta•VDET TDLY 2 3 1 5 AnaSem 4 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TEST CIRCUITS Circuit (1) – Operating voltage, Detection voltage, Hysteresis range, Detection voltage temperature coefficient R VIN 100KΩ *1) VIN VOUT V VSS V Note 1) : The resistor (100KΩ) is not necessary for CMOS output products. Circuit (3) – N-ch driver output current Circuit (2) – Current consumption A VIN VIN VIN VIN VOUT VOUT A VSS VSS VDS Circuit (4) – P-ch driver output current VIN Circuit (5) – Delay time (VDR→VOUT inversion) VIN VOUT R VIN VDS A 100KΩ *1) VOUT VSS VSS Measurement of wave form Note 1) : The resistor (100KΩ) is not necessary for CMOS output products. AnaSem 5 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 DESCRIPTION OF OPERATION General operation (CMOS Output) In reference to following the block diagram of CMOS output VDA series ; VIN + Voltage Reference P-ch _ VOUT N-ch Vss A. When the input voltage (VIN) is higher than the release voltage (VREL), the input voltage (VIN) is provided at the output terminal because N-ch transistor is OFF and the P-ch transistor is ON. And, the output maintains the same level of input as long as the input voltage remains above the detection voltage (VDET). B. When the input voltage (VIN) falls below the detection voltage (VDET), the N-ch transistor is ON and the P-ch transistor is OFF. And, the output voltage (VOUT) is same as ground level (VSS). [ TIMING CHART ] Input voltage (VIN) Release voltage (VREL) C. When the input voltage (VIN) falls below the minimum operating voltage, the output becomes unstable, or goes to VIN when the output is pulled up to VIN. Detection voltage (VDET) Min. operating voltage Power ground (VSS) D. When the input voltage (VIN) rises above the minimum voltage, the ground voltage (VSS) level is maintained even though the input voltage (VIN) rises above the detection voltage (VDET) as long as it does not exceed the release voltage (VREL) level. Output voltage (VOUT) Release voltage (VREL) Detection voltage (VDET) E. When the input voltage (VIN) rises above the release voltage (VREL), the N-ch transistor becomes OFF and the P-Ch transistor becomes ON. And, the output voltage (VOUT) is equal to input voltage (VIN). This difference between VDET and VREL is hysteresis range (VHYS). Hysteresis range (VHYS) Min. operating voltage Power ground (VSS) A B C D E AnaSem 6 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TYPICAL CHARACTERISTICS – Supply Current vs. Input Voltage VDA2010CTA (CMOS 2.0V) VDA2510CTA (CMOS 2.5V) VIN=0V~6.0V, Step=0.2V VIN=0V~6.0V, Step=0.2V 1.8 1.8 Ta=+85°C 1.6 Supply Current : IDD (µA) Supply Current : IDD (µA) 1.6 1.4 Ta=+25°C 1.2 1.0 Ta=-40°C 0.8 0.6 0.4 0.2 Ta=+85°C 1.4 1.2 Ta=+25°C 1.0 Ta=-40°C 0.8 0.6 0.4 0.2 0 0 0 1 2 3 4 5 Input Voltage : VIN (V) 6 0 7 VDA1020NTA (N-ch 1.0V) 1 2 3 4 5 Input Voltage : VIN (V) VIN=0V~6.0V, Step=0.2V VIN=0V~6.0V, Step=0.2V 1.8 Ta=+85°C 1.6 Supply Current : IDD (µA) 1.6 Supply Current : IDD (µA) 7 VDA1810NTA (N-ch 1.8V) 1.8 1.4 1.2 Ta=+25°C 1.0 0.8 Ta=-40°C 0.6 0.4 0.2 1.4 Ta=+85°C 1.2 1.0 Ta=+25°C 0.8 0.6 Ta=-40°C 0.4 0.2 0 0 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 Input Voltage : VIN (V) Input Voltage : VIN (V) VDA2710NTA (N-ch 2.7V) VDA4010NTA (N-ch 4.0V) VIN=0V~6.0V, Step=0.2V VIN=0V~6.0V, Step=0.2V 1.8 1.8 1.6 Supply Current : IDD (µA) 1.6 Supply Current : IDD (µA) 6 Ta=+85°C 1.4 1.2 Ta=+25°C 1.0 Ta=-40°C 0.8 0.6 0.4 0.2 1.4 Ta=+85°C 1.2 1.0 Ta=+25°C 0.8 Ta=-40°C 0.6 0.4 0.2 0 0 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 Input Voltage : VIN (V) Input Voltage : VIN (V) AnaSem 7 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TYPICAL CHARACTERISTICS – Detect & Release Voltage vs. Ambient Temperature VDA2510CTA (CMOS 2.5V) VIN=0V~6.0V, Step=0.2V 2.15 2.13 2.11 2.09 Release Voltage 2.07 2.05 2.03 2.01 1.99 Detect Voltage 1.97 1.95 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Detect & Release Voltage : VDET & VREL (V) Detect & Release Voltage : VDET & VREL (V) VDA2010CTA (CMOS 2.0V) VIN=0V~6.0V, Step=0.2V 2.68 2.66 2.64 2.62 2.60 2.58 2.56 2.54 2.52 2.48 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Ambient Temperature : Ta (°C) VDA1810NTA (N-ch 1.8V) VIN=0V~6.0V, Step=0.2V 1.07 1.06 Release Voltage 1.04 1.03 1.02 1.01 1.00 Detect Voltage 1.99 0.98 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Detect & Release Voltage : VDET & VREL (V) Detect & Release Voltage : VDET & VREL (V) VDA1020NTA (N-ch 1.0V) 1.05 1.93 1.91 1.87 1.85 1.83 1.81 1.79 VIN=0V~6.0V, Step=0.2V Release Voltage 2.82 2.80 2.78 2.76 2.74 Detect Voltage 2.70 2.68 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Detect & Release Voltage : VDET & VREL (V) Detect & Release Voltage : VDET & VREL (V) Detect Voltage 1.77 1.75 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 VDA4010NTA (N-ch 4.0V) 2.86 2.72 Release Voltage 1.89 Ambient Temperature : Ta (°C) VDA2710NTA (N-ch 2.7V) 2.84 VIN=0V~6.0V, Step=0.2V 1.95 Ambient Temperature : Ta (°C) 2.88 Detect Voltage 2.50 Ambient Temperature : Ta (°C) 1.08 Release Voltage VIN=0V~6.0V, Step=0.2V 4.30 4.25 Release Voltage 4.20 4.15 4.10 4.05 Detect Voltage 4.00 3.95 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Ambient Temperature : Ta (°C) Ambient Temperature : Ta (°C) AnaSem 8 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Input Voltage VDA2010CTA (CMOS 2.0V) VDA2510CTA (CMOS 2.5V) Ta=25°C Ta=25°C 3.0 VDET VREL Output Voltage : VOUT (V) Output Voltage : VOUT (V) 2.5 2.0 1.5 1.0 0.5 0 VDET VREL 2.5 2.0 1.5 1.0 0.5 0 0 0.5 1.0 1.5 2.0 2.5 0 0.5 1.0 Input Voltage : VIN (V) 1.5 2.0 2.5 VDA1020NTA (N-ch 1.0V) VDA1810NTA (N-ch 1.8V) Ta=25°C Ta=25°C 3.0 VDET VREL Output Voltage : VOUT (V) Output Voltage : VOUT (V) 2.5 2.0 1.5 1.0 0.5 0 VDET VREL 2.5 2.0 1.5 1.0 0.5 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0 0.5 Input Voltage : VIN (V) 1.5 2.0 2.5 VDA4010NTA (N-ch 4.0V) Ta=25°C Output Voltage : VOUT (V) VDET VREL 2.0 1.5 1.0 0.5 Ta=25°C 4.5 3.0 2.5 1.0 Input Voltage : VIN (V) VDA2710NTA (N-ch 2.7V) Output Voltage : VOUT (V) 3.0 Input Voltage : VIN (V) VDET VREL 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 0 0 0.5 1.0 1.5 2.0 2.5 3.0 0 Input Voltage : VIN (V) 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 Input Voltage : VIN (V) AnaSem 9 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TYPICAL CHARACTERISTICS – N-ch Driver Output Current vs. VDS VDA2010CTA (CMOS 2.0V) VDA2510CTA (CMOS 2.5V) Ta=25°C Ta=25°C 1.2 VIN=0.8V 1.0 Output Current : IOUT (mA) Output Current : IOUT (mA) 1.2 0.8 0.6 VIN=0.7V 0.4 0.2 0 VIN=0.8V 1.0 0.8 0.6 VIN=0.7V 0.4 0.2 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0 0.1 0.2 0.3 VDS (V) 0.6 0.7 0.8 0.9 VDA1810NTA (N-ch 1.8V) Ta=25°C 1.2 VIN=0.8V 1.0 0.8 0.6 VIN=0.7V 0.4 0.2 Ta=25°C 1.2 Output Current : IOUT (mA) Output Current : IOUT (mA) 0.5 VDS (V) VDA1020NTA (N-ch 1.0V) 0 VIN=0.8V 1.0 0.8 0.6 VIN=0.7V 0.4 0.2 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0 0.1 0.2 0.3 VDS (V) 0.4 0.5 0.6 0.7 0.8 0.9 VDS (V) VDA2710NTA (N-ch 2.7V) VDA4010NTA (N-ch 4.0V) Ta=25°C 1.2 1.0 VIN=0.8V 0.8 0.6 VIN=0.7V 0.4 0.2 0 Ta=25°C 1.2 Output Current : IOUT (mA) Output Current : IOUT (mA) 0.4 1.0 VIN=0.8V 0.8 0.6 VIN=0.7V 0.4 0.2 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0 VDS (V) 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 VDS (V) AnaSem 10 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TYPICAL CHARACTERISTICS – N-ch Driver Output Current vs. VDS (continued) VDA2010CTA (CMOS 2.0V) VDA2510CTA (CMOS 2.5V) Ta=25°C 8.0 VIN=1.5V 7.0 6.0 5.0 4.0 3.0 VIN=1.0V 2.0 Ta=25°C 18.0 Output Current : IOUT (mA) Output Current : IOUT (mA) 9.0 VIN=2.0V 16.0 14.0 12.0 10.0 VIN=1.5V 8.0 6.0 4.0 VIN=1.0V 2.0 1.0 0 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 0 0.5 1.0 VDS (V) Ta=25°C 2.5 2.5 VIN=1.0V 2.0 VIN=0.9V 1.5 1.0 0.5 Ta=25°C 9.0 Output Current : IOUT (mA) 3.0 Output Current : IOUT (mA) 2.0 VDA1810NTA (N-ch 1.8V) VDA1020NTA (N-ch 1.0V) 8.0 VIN=1.5V 7.0 6.0 5.0 4.0 3.0 VIN=1.0V 2.0 1.0 0 0 0 02 0.4 0.6 0.8 1.0 1.2 0 0.2 0.4 0.6 VDS (V) Ta=25°C 1.2 1.4 1.6 20.0 VIN=2.0V 15.0 VIN=1.5V VIN=1.0V Ta=25°C 45.0 Output Current : IOUT (mA) VIN=2.5V 25.0 5.0 1.0 VDA4010NTA (N-ch 4.0V) 30.0 10.0 0.8 VDS (V) VDA2710NTA (N-ch 2.7V) Output Current : IOUT (mA) 1.5 VDS (V) VIN=3.5V 40.0 35.0 VIN=3.0V 30.0 25.0 VIN=2.5V 20.0 15.0 VIN=2.0V 10.0 VIN=1.5V 5.0 0 0 0 0.5 1.0 1.5 2.0 2.5 3.0 0 VDS (V) 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 VDS (V) AnaSem 11 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TYPICAL CHARACTERISTICS – N-ch Driver Output Current vs. Input Voltage VDA2010CTA (CMOS 2.0V) VDA2510CTA (CMOS 2.5V) VDS=0.5V, VIN=0~VREL, Step=0.2V VDS=0.5V, VIN=0~VREL, Step=0.2V 12.0 Ta=+25°C Ta=–40°C Ta=+85°C 10.0 Ta=+25°C Ta=–40°C Ta=+85°C 10.0 Output Current : IOUT (mA) Output Current : IOUT (mA) 12.0 8.0 6.0 4.0 2.0 0 8.0 6.0 4.0 2.0 0 0.5 0 1.0 1.5 2.0 2.5 0 0.5 1.0 Input Voltage : VIN (V) VDA1020NTA (N-ch 1.0V) VDS=0.5V, VIN=0~VREL, Step=0.2V 2.5 3.0 VDS=0.5V, VIN=0~VREL, Step=0.2V 10.0 Ta=+25°C Ta=–40°C Ta=+85°C 3.0 Output Current : IOUT (mA) Output Current : IOUT (mA) 2.0 VDA1810NTA (N-ch 1.8V) 3.5 2.5 2.0 1.5 1.0 0.5 Ta=+25°C Ta=–40°C Ta=+85°C 9.0 8.0 7.0 6.0 5.0 4.0 3.0 2.0 1.0 0 0.3 0 0.5 0.7 0.9 1.1 1.3 0 0.5 1.0 Input Voltage : VIN (V) 1.5 2.0 2.5 Input Voltage : VIN (V) VDA2710NTA (N-ch 2.7V) VDA4010NTA (N-ch 4.0V) VDS=0.5V, VIN=0~VREL, Step=0.2V VDS=0.5V, VIN=0~VREL, Step=0.2V 14.0 14.0 Ta=+25°C Ta=–40°C Ta=+85°C 12.0 Output Current : IOUT (mA) Output Current : IOUT (mA) 1.5 Input Voltage : VIN (V) 10.0 8.0 6.0 4.0 2.0 0 Ta=+25°C Ta=–40°C Ta=+85°C 12.0 10.0 8.0 6.0 4.0 2.0 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 0 Input Voltage : VIN (V) 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 Input Voltage : VIN (V) AnaSem 12 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TYPICAL CHARACTERISTICS – P-ch Driver Output Current vs. Input Voltage VDA2010CTA (CMOS 2.0V) Ta=25°C 10.0 VDS=2.1V Output Current : IOUT (mA) 9.0 8.0 7.0 VDS=1.5V 6.0 5.0 VDS=1.0V 4.0 3.0 VDS=0.5V 2.0 1.0 0 0 1 2 3 4 5 6 7 8 Input Voltage : VIN (V) VDA2510CTA (CMOS 2.5V) Ta=25°C 10.0 Output Current : IOUT (mA) 9.0 VDS=2.1V 8.0 7.0 VDS=1.5V 6.0 5.0 VDS=1.0V 4.0 3.0 VDS=0.5V 2.0 1.0 0 0 1 2 3 4 5 6 7 8 Input Voltage : VIN (V) AnaSem 13 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 PACKAGE DIMENSIONS (SOT-23) (Unit : mm) 0.65 –0.15 0.45 1.6±0.15 2.8±0.2 0.4 +0.10 2.9±0.2 +0.10 –0.15 Min 0.1 1.1~1.3 (Marked Side) 0~0.1 3~7° +0.10 +0.10 0.4 –0.15 +0.10 0.16 –0.15 +0.10 0.95 0.65 –0.15 0.4 –0.15 0.95 1.9±0.2 2.9±0.2 Recommended land pattern 0.4 –0.15 2.4 0~0.1 +0.10 1.0 1.1±1.3 0.8 1.0 0.8 1.0 0.8 0.95 0.95 1.9 AnaSem 14 www.anasemi.com sales@anasemi.com .......... Future of the analog world Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 TAPING AND LOADING SPECIFICATIONS (SOT-23) (Unit : mm) 1.65 max. Mark ø1.05±0.05 3.5±0.05 3.4±0.1 Mark 2.0±0.05 4.0±0.1 8.0±0.2 ø1.5 +0.1 –0 0.2±0.05 1.75±0.1 4.0±0.1 3.35±0.1 Taping direction REEL DIMENSIONS (SOT-23) (Unit : mm) 120° ø60±1 2.0±0.5 (3,000 pcs / reel) ø178±2 ø13±0.5 90° 9.0±0.5 AnaSem 15 www.anasemi.com sales@anasemi.com .......... Future of the analog world AnaSem AnaSem may change the products described in this data sheet, or may discontinue production or services without any notice in order to supply the best products through improve the design and performance. Customers are recommended to obtain the latest data or information before placing orders in order to make sure the data or information required is the newest. It is necessary for customers to fully understand the products described in this data sheet and to use it in accordance with its specifications. The products described in this data sheet are not intended to use for the apparatus which have influence on human lives due to the failure or malfunction of the products. AnaSem Corp. is not responsible for any support to customer’s application, product design, software performance, patent infringement or service. AnaSem Corp. does not disclose or imply a guarantee or description about being licensed based on patents, copy-rights, circuit location license, or other intellectual properties associated with the devices or combinations in which the products or service of AnaSem Corp. are used or can be used, or which cover the methods. Customers should not export, directly or indirectly, any products without obtaining required licenses and approvals in advance from appropriate government agencies. AnaSem Low voltage, Low power, ±1% High detect accuracy CMOS Voltage Detector VDA Series Rev. E13-01 GENUINE PRODUCT LEGITIMATE LABEL DEFINITION Green colored Circle “RoHS” Label Other specific customized Labels Ordinary Product Information Bar Code Our internal Outgoing Check Code 3 Our Internal QR Check Code 2 AnaSem Logo and Brand Name (Black color Logo) Our Internal Product Check Code 1 Genuine labels MUST include our correct contact information as shown AnaSem
VDA3010CTA
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4内核微处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为2.0V至3.6V,工作频率高达200MHz,内置512KB的闪存和128KB的RAM。
5. 功能详解:支持多种通信接口,如I2C、SPI、UART等,具有丰富的外设接口。
6. 应用信息:适用于工业控制、智能家居、医疗设备等领域。
7. 封装信息:采用QFP封装,共有48个引脚,尺寸为7mm x 7mm。
VDA3010CTA 价格&库存
很抱歉,暂时无法提供与“VDA3010CTA”相匹配的价格&库存,您可以联系我们找货
