BF1608-N5R5NANT/LF
BF1608-N5R5NANT/LF
    ACX(璟德)
    FILTER-3P_1.6X0.8MM_SM
    BF1608-N5R5NANT/LF
BF1608-N5R5NANT/LF 数据手册
ACX Advanced Ceramic X BF 1608 Series Multilayer Chip Band-Pass Filters Features  Ultra small SMD type with low loss at passband and high attenuation at stop-band.  RoHS compliant Applications Mobile communication systems. Specifications Frequency Range (MHz) Part Number BF1608N5R5NAN_ 5150~5950 Insertion Loss @ BW (dB) 0.8 max. @-40~+85°C 1.0 max. @+85~+105°C Q’ty/Reel (pcs) Operating Temperature Range Storage Temperature Range Storage Period Power Capacity Return Loss @ BW (dB) Frequency (MHz) Attenuation (dB) 13 min. 700 ~ 2690 3400 ~ 3800 6900 7250 ~ 7800 10300 ~ 11700 40 min. 45 min. 20 min. 20 min. 20 min. : 4,000 : -40 ~ +105 oC : -40 ~ +105 oC : 12 months max. : 3W max. Part Number BF  1608  - N  5R5  NAN    /LF   Type BF : Band-Pass Filter  Dimensions ( L × W )  Material Code N  Frequency Range 5R5=5500MHz  Specification Code NAN  Packaging T: Tape & Reel B: Bulk  Soldering /LF=lead-free BF1608-N5R5NANT/LF REV:6 PAGE:1/7 1.6 × 0.8 mm ACX Advanced Ceramic X Terminal Configuration    No. Terminal Name No. Terminal Name  IN  OUT  GND Dimensions and Recommended PC Board Pattern Unit: mm c a W b d * e T L L < Bottom View> Mark Dimensions < Side View> L W T a b c d e 1.6  0.8  0.59 0.25  0.4  0.23  0.55  0.60  0.15 0.15 +0.1/-0.2 0.1 0.1 0.05 0.10 0.10 Solder Resist 0.4 Land 0.21 0.245 * 0.55 * Through-hole ( 0.3, 0.23) 0.22 0.28 * Line width should be designed to match 50  characteristic impedance, depending on PCB material and thickness. BF1608-N5R5NANT/LF REV:6 PAGE:2/7 ACX Advanced Ceramic X Measuring Diagram Port 1 Network Analyzer (50) Port 2 (50) I/O I/O GND Electrical Characteristics (T=25oC) 0 dB(S(2,2)) dB(S(2,1)) dB(S(1,1)) -10 -20 -30 -40 -50 -60 0.5 2.5 4.5 6.5 8.5 10.5 12.5 freq, GHz Notes The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your order. BF1608-N5R5NANT/LF REV:6 PAGE:3/7 ACX Advanced Ceramic X Taping Specifications Tape Dimensions (Unit: mm) & Quantity A’ T 1.75 ± 0.1 D E F C PAPER B TAPE Type A A A’ B C D E F T 4.0± 4.0± 1.10± 1.92± 2.0± 3.5± 8.0± 0.75± 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.05 1608 Quantity/reel Tape material 4,000pcs Paper Reel Dimensions (Unit: mm) 1.4 ± 0.2 Label 178± 1 60±1 Label: Customer’s Name, ACX P/N, Q’ty, Date, ACX Corp. 13.5±0.5 B A Type A B 1608 2.3±0.5 9.0±0.3 Leader and Trailer Tape Trailer End Trailer (160 mm min.) Empty Compartments with Cover Tape (500 mm min.) BF1608-N5R5NANT/LF REV:6 PAGE:4/7 ACX Advanced Ceramic X Peel-off Force Top Cover Tape Peeling Direction
BF1608-N5R5NANT/LF 价格&库存
很抱歉,暂时无法提供与“BF1608-N5R5NANT/LF”相匹配的价格&库存,您可以联系我们找货
