BT16B03
BT16B03
    TNK(讯康)
    SMD
BT16B03 数据手册
100 Base-T single port transformer Module Designed to meet IEEE802.3u requirement Designed to meet IR 255℃ peak requirement Primary inductance 350uH min with 8mA DC Bias @100KHz,0.1V ROHS Compliant Operating temperature range:0℃to+70℃ Storage temperature range:-25℃to+125℃ Electrical Specifications @ 25℃ Part Number BT16B03 Turn Insertion Return Loss Cross Talk DMRR Ratio Loss (dB Min) (dB Min) (dB Min) LK DCR CWW Hi-Pot (Max) (Max) (Max) (Vrms) 0.5 uH 1.2Ω 28pF 1500 Tx Rx 1:1 1:1 0.3~100MHz 30 60 80 0.3-60 60-100 0.50-100 (dB Max) MHz MHz MHz MHz MHz MHz -18 -14 -12 -45 -35 -30 -1.15 Mechanical Schematics 8.89 1.27 6.86 2.03 BT16B03 6.73 YYWW 0.64 12.7±0.5 1 TD 2 3 6 0.5 5.68±0.5 9.4±0.5 1.27 Dimension:mm Unless otherwise specified,tolerances:±0.25(mm) Data sheet subject to change without notice 东莞市讯康电子科技股份有限公司 地址:广东省东莞市塘厦镇林村里牙塘工业区 145 号 TEL:(86)769-87923451 FAX:(86)769-87923450 WEBSITE:http://www.tnk.net.cn RD 7 8 1CT:1CT 1CT:1CT 16 15 14 TX 11 10 RX 9
BT16B03 价格&库存
很抱歉,暂时无法提供与“BT16B03”相匹配的价格&库存,您可以联系我们找货
