PTU1.25A250V
PTU1.25A250V
    CONQUER(功得)
    插件,3.9X11MM
PTU1.25A250V 数据手册
CONQUER Subminiature Fuse Type PTU 3.6ØX10mm Time-Lag Ceramic Tube Fuse with Pig-Tail Series Approval VDE CSA Acceptance UL Recognized CCC KTL 250mA~6.3A 250mA~6.3A 250mA~6.3A 250mA~6.3A 250mA~6.3A Electrical Characteristic (IEC-60127-3 STANDARD SHEET 4) Rated 1.5 In 2.1 In 2.75 In Current MIN 250mA~6.3A 60 min MAX 4 In 10 In MIN MAX MIN MAX MIN MAX 2 400 10 150 3 20 150 min ms sec ms sec ms ms Interrupting Rating 35 amperes or 10 x rated current; whichever is greater at 250V AC Catalog Ampere Voltage Nominal Voltage Nominal Number Rating Rating Resistance Drop Melting I2t [ In ] (V) Cold Ohms (mv) MAX A2 Sec 250V 0.7310 0.4720 0.3160 0.2560 0.1700 0.1130 0.0860 0.0640 0.0460 0.0340 0.0260 0.0190 0.0140 0.0100 0.0080 240 220 200 190 180 160 140 130 120 100 100 100 100 100 100 0.3262 0.5255 0.7296 1.3100 2.6179 4.0645 6.6388 14.738 29.768 32.976 61.200 91.197 149.98 188.60 276.76 PTU .250 PTU .315 PTU .400 PTU .500 PTU .630 PTU .800 PTU 001 PTU 1.25 PTU 1.60 PTU 002 PTU 2.50 PTU 3.15 PTU 004 PTU 005 PTU 6.30 250mA 315mA 400mA 500mA 630mA 800mA 1A 1.25A 1.6A 2A 2.5A 3.15A 4A 5A 6.3A Mechanical Dimension Operating Temperature -55°C to +125°C Physical Specification Material Ceramic Body / Nickel Plated Brass Caps Lead Wire: Diameter 0.6 mm, 4A and Less Diameter 0.8 mm, 5A and 6.3A Packaging 1. In Bulk: PTU - 1,000 pcs per box 2. On Axial Tape & Reel 1,500 pcs per reel. 3. Tape & Reel specification: per EIA-296-E & IEC 286-1 @ 10mm Pitch and 56.5mm inside Tape Spacing. Conquer Electronics Co., Ltd. Conquer Electronics Co., Ltd. No.26, Wucyuan 5th Rd., Wugu Dist.,(New Taipei Industrial Park) New Taipei City 24888, Taiwan TEL: 886-2-8990-2189 (Rep.) Offical Website: http://www.conquer.com.tw 30 FAX: 886-2-8990-2577
PTU1.25A250V 价格&库存
很抱歉,暂时无法提供与“PTU1.25A250V”相匹配的价格&库存,您可以联系我们找货
