YLNP-03V
YLNP-03V
    JST
    P=4.5mm
    1X3P 4.5MM
YLNP-03V 数据手册
YLN CONNECTOR 4.5 mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications • Current rating: 1  0 A AC/DC (7 A when retainers are mounted) • Voltage rating: 300 V AC/DC • Temperature range: -25℃ to +90℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 7 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #26 to #16 0.13 to 1.25 mm2 YLN CONNECTOR * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. The YLN connector adds variations in shape to the existing color variations of the YL connector in order to improve identification of connectors. Moreover, this connector has a mechanism to prevent incomplete mating by utilizing the inertial force generated when the plug and receptacle are mated and therefore, ensures complete mating. Note: The current rating differs depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. No. of circuits #16 #18 3 9 4 6 2 10 7 Wire size(AWG) #20 #22 Current unit : A #24 #26 4 3 2 4 4 3 2 3 3 2 2 5 4 6 4 9 6 8 5 3 2 Note: Secondary retainers cannot be used with AWG #16 wires. ●D  esign to prevent incidental mating with the YL connector ● Inertial force mechanism ● Interchangeability ● Finger friendly design ® Standards Recognized E60389 Certified LR20812 R9351052 ® ® ® ® Assembly layout 10.8 17.05 (including retainer) (35.1) (35.1) (38.7) (including retainer) (38.7) (including retainer) 1 YLN CONNECTOR YLコネクタ表2 Contact Applicable wire Model No. Pin contact Insulation O.D. (mm) SYM-01T-P0.5A SYF-01T-P0.5A 0.13~0.5 26~20 1.3~2.5 0.5~1.25 20~16 2.0~3.4 0.3+0.3~ 0.5+0.5 22+22~ 20+20 1.5+1.5~ 2.0+2.0 2 SYM-41T-P0.5A SYF-41T-P0.5A 19.5 mm2 Socket contact 2 Q’ty/ reel 4,000 (     ) SYM-01T-P0.5A 5,000 Material and Finish 0.5 1.1 4.4 AWG # Pin contact Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance Note: 1 . Contact JST for special products. 2. Retainers cannot be used with electric wire whose insulation O.D. exceeds 2.7 mm and AWG #16. 2.8 Socket contact Crimping machine Crimp applicator Contact 14.2 2 4.4 SYM-01T-P0.5A 1.1 SYF-01T-P0.5A 1.8 SYM-41T-P0.5A Applicator Crimp applicator with dies Dies MK/SYF/M-01-05 APLMK SYF/M01-05 AP-K2N MKS-L MK/SYF/M-41-05 APLMK SYF/M41-05 SYF-41T-P0.5A Note: Contact JST for fully automatic crimping applicator. Housing Material: H  ousing...PA 66, UL94V-0, natural (white) Retainer...Glass-filled PA 66, UL94V-0, natural (ivory) No. of Voltage Current circuits rating rating Receptacle housing (for pin contact) YLNR-02VF Q’ty/ bag Q’ty/ bag YLNP-03V 16.1 26.6 Q’ty/ bag YLNP-04V 15.3 Q’ty/ bag Q’ty/ bag 12.8 250 15.3 1,000 2.9 Q’ty/ bag YLS-03V (Used with both housings with 3 and 6 circuits) Q’ty/ bag L JST 12.8 3 6 2 5 4 200 200 1 1 4 JST 15.5 18.3 6.5 2 5 L No.1 hole mark 20.9 RoHS2 compliance Note: Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 2 YLS-02V (Used with both housings with 2 and 4 circuits) 8.3 3 1 YLNP-06V 3 6 5A Q’ty/ bag No.1 hole mark 20.9 26.6 16.1 11 250 1 YLNR-06VF (8 A) 1,000 2.9 2 4 13.8 3 6.5 2 4 JST No.1 hole mark 300 V Q’ty/ bag L JST L 6 500 No.1 hole mark 20.9 6A (9 A) YLS-03V (Used with both housings with 3 and 6 circuits) JST 1 YLNR-04VF 300 V 1,000 1 L 2 15.5 18.3 6.5 2 L JST 250 No.1 hole mark 4 Q’ty/ bag 2.9 Q’ty/ bag 10.2 8.3 JST L 20.9 26.6 500 No.1 hole mark 3 6A (9 A) YLS-02V (Used with both housings with 2 and 4 circuits) 3 10.8 1 1 YLNR-03VF 300 V Q’ty/ bag 10.2 250 No.1 hole mark 3 YLNP-02V 11 13.8 6.5 L JST 7A 300 V (10 A) 2 2 26.6 Retainer 2 10.8 Plug housing (for socket contact) No.1 hole mark 2.9 1,000
YLNP-03V 价格&库存
很抱歉,暂时无法提供与“YLNP-03V”相匹配的价格&库存,您可以联系我们找货
YLNP-03V
    • 1+1.751911+0.22600
    • 10+1.3752510+0.17741
    • 50+1.0161150+0.13108
    • 100+0.93727100+0.12091
    • 500+0.88472500+0.11413
    • 1000+0.858441000+0.11074
    • 2000+0.849682000+0.10961
    库存:295
    YLNP-03V
      • 10+2.46184
      • 130+2.40768
      • 250+2.35249
      库存:2840
      YLNP-03V
        • 500+0.49500
        库存:3000
        YLNP-03V
          • 500+1.77244
          • 1000+1.72766
          • 2000+1.70162
          库存:2840
