AB34S
AB34S
    MDD(辰达半导体)
    ABS
    耐压:40V 电流:3A
AB34S 数据手册
AB34S THRU AB320S Voltage Range - 40 to 200 V olts Current - 3.0 Ampere SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS Features ABS  Ideal for printed circuit board  Reliable low cost construction utilizing molded plastic technique  High temperature soldering guaranteed: 260°/10 seconds at 5 lbs., (2.3kg) tension  Small size, simple installation  High surge current capability Mechanical Data (1) (2) - Case : JEDEC ABS Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.003 ounce, 0.098 grams + ~ ~ (3) (4) Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS MDD AB34S MDD AB36S MDD AB38S MDD AB310S MDD AB320S UNITS VRRM VRMS VDC IF(AV) 40 28 40 60 42 60 80 56 80 3.0 100 70 100 200 140 200 V V V A Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage drop per leg at 3A TA=25°C Maximum DC reverse current at rated DC blocking voltage TA=100°C Typical thermal resistance Typical junction capacitance Operating temperature range storage temperature range IFSM 80 VF 0.55 IR 0.5 10 0.70 RθJA Cj A 70 0.85 0.3 5 60 250 TJ TSTG 160 -55 to +125 -55 to +150 0.95 V mA mA °C/W pF °C °C NOTE:1.Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. http://www.microdiode.com Rev:2024A2 Page :1 AB34S THRU AB320S Voltage Range - 40 to 200 V olts Current - 3.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.5 100LFM 3.0 2.5 2.0 1.5 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.5 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =75°C 10 2 AB34S AB36S-AB320S 10 1 T J =25°C 10 0 0 Lead Temperature (°C) 20 40 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 500 20 Junction Capacitance (pF) Instaneous Forward Current (A) T J =100°C 10 3 10 1.0 AB34S AB36S/AB38S AB310S AB320S 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 T J =25°C 200 100 50 AB32S/AB34S 20 AB36S-AB320S 10 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surge Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surge Current 100 8.3 ms Single Half Sine Wave (JEDEC Method) 80 60 AB34S/AB36S AB38S~AB320S 40 20 00 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 AB34S THRU AB320S Voltage Range - 40 to 200 V olts Current - 3.0 Ampere Suggested Pad Layout Q1 P1 Dim Min P1 5.72 P2 4.00 Q1 1.00 Q2 0.90 Q2 P2 Dimensions in millimeters http://www.microdiode.com Rev:2024A2 Page :3
AB34S 价格&库存
很抱歉,暂时无法提供与“AB34S”相匹配的价格&库存,您可以联系我们找货
AB34S
  • 5+1.40346
  • 50+1.13951
  • 150+1.02633
  • 500+0.88517
  • 2500+0.72393
  • 5000+0.68624
库存:10
