Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/17/2022
page 1 of 3
MODEL: SJ-63033A | DESCRIPTION: AUDIO JACK
FEATURES
• through hole
• right angle
• 3 conductor
• threaded with nut
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
12
rated input current
contact resistance
between terminal and mating plug
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
Vdc
1
A
30
mΩ
100
insertion/withdrawal force
0.4
operating temperature
-25
life
MΩ
500
Vac
3
kg
70
5,000
flammability rating
see material table
RoHS
yes
units
°C
cycles
SOLDERABILITY
parameter
hand soldering
for 3~5 seconds
min
typ
360
cuidevices.com
max
units
°C
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: SJ-63033A | DESCRIPTION: AUDIO JACK
date 08/17/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
earth terminal
phosphor bronze
silver
2
tip spring
phosphor bronze
silver
3
ring spring
phosphor bronze
silver
4
housing
PBT (UL94V-0)
black
5
cover
PC (UL94V-2)
transparent
6
nut
steel
nickel
7
washer
steel
nickel
Recommended PCB Layout
Top View
Model No.
31
Ø6.35 MATING PLUG
SJ-63033A
Schematic
PIN
1
sleeve
2
tip
3
ring
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/17/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
08/11/2020
1.01
logo, datasheet style update
08/17/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SJ-63033A”相匹配的价格&库存,您可以联系我们找货
