ABS210(60MIL)
ABS210(60MIL)
    BAOCHENG(宝乘)
    ABS
    ABS210(60MIL)
ABS210(60MIL) 数据手册
ABS2005 thru ABS210 2.0 A Single-Phase Glass Passivated Bridge Rectifiers Rectifier Reverse Voltage 50 to 1000V ABS 0.010(0.25) 0~10 O 0.006(0.15) 0.002(0.05) 0.006(0.15) 0.008(0.2) ----- 0.059(1.50) MAX. 0.193(4.9) 0.048(1.22) 0.21(5.4) 0.056(1.42) 0.150(3.8) 0.006(0.15) Case: Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: Marked on body Mounting Position: Any 0.169(4.3) 0.059(1.5) 0.174(4.4) 0.002(0.05) Mechanical Data 0.173(6.8) This series is UL listed under the Recognized Component Index, file number E142814 The plastic material used carries Underwriters Laboratory flammability recognition 94V-0 Ideal for printed circuit board application High temperature soldering guaranteed 260 C /5 seconds at 5 lbs (2.3kg) tension 0.158(6.2) 0.177(4.5) Features DETAIL "A", SCALE=20/1 A 0.033(0.85) 0.022(0.55) Dimensions in millimeters ( 1mm =0.0394" ) Maximum Ratings & Thermal Characteristics Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz. For Capacitive load derate current by 20%. Symbol ABS 2005 ABS 201 ABS 202 ABS 204 ABS 206 ABS 208 ABS 210 unit Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS bridge input voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Parameter Maximum DC blocking voltage Maximum average forward rectified output current at TA=40 C IF(AV) 2 A Peak forward surge current single sine-wave superimposed on rated load (JEDEC Method) IFSM 50 A I t 15 A sec Typical thermal resistance per element (1) ReJA 25 Operating junction and storage temperature range TJ, TSTG -55 to + 150 Rating for fusing ( t
ABS210(60MIL) 价格&库存
很抱歉,暂时无法提供与“ABS210(60MIL)”相匹配的价格&库存,您可以联系我们找货
