ACM3225F2SF-102T15
ACM3225F2SF-102T15
    TAI-TECH(台庆)
    SMD,3.2x2.5x2.2mm
    共模电感 SMD,3.2x2.5x2.2mm
ACM3225F2SF-102T15 数据手册
TAI-TECH P1 Wire Wound Type Common Mode Filter ACM3225F2SF-102T15 ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 18/03/21 新發行 楊祥忠 林志鴻 張嘉玲 備 註 www.tai-tech.com.tw TAI-TECH P2 Wire Wound Type Common Mode Filter ACM3225F2SF-102T15 1. Features 1. High common mode impedance at high frequency effects excellent noise Halogen Pb Halogen-free Pb-free suppression performance. 2. ACM3225F2SF series realizes small size and low profile 3.2x2.5x2.2 mm 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Dimension A C Recommended PC Board Pattern D D B D D Series A(mm) B(mm) C(mm) D1(mm) D2(mm) L(mm) H(mm) G1(mm) G2(mm) 3225F2SF 3.2±0.2 2.5±0.2 2.2±0.2 0.65±0.1 1.0±0.1 4.4 3.5 2.3 0.8 Units: mm 3. Part Numbering ACM 3225 A B F 2 S F C D E F - 102 T 15 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Lead free G: Impedance 102=1000Ω H: Packaging T=Taping and Reel I: Rated Current 15=1500mA 4. Specification TAI-TECH Part Number ACM3225F2SF-102T15 Common mode Impedance (Ω) Test Frequency (MHz) 1000±25% 100 DC Rated Resistance Current (Ω) max. (mA)max. Note: 1. Test Frequency:Impedance:100MHz 2. Testing Instrument : L:Agilent-4291A,Agilent-16197A DCR: Agilent-4338B 3. Operating temperature -40℃ ~ +85℃ 4. All test data is referenced to 25℃ ambient. www.tai-tech.com.tw 0.10 1500 Rated Volt. (Vdc)max. IR (MΩ) min. 60 10 TAI-TECH P3 ACM3225F2SF-102 10000 Common Mode IMPEDANCE(Ohm) 1000 100 10 Normal Mode 1 0.1 1 10 100 1000 FREQUENCY(MHz) 5. Schematic Diagram 6. MEASURING CIRCUITS 2LINE 7. Materials No. Description Specification a. Upper Plate Ferrite b. Core Ferrite Core c Termination Tin (Pb Free) d Wire Enameled Copper Wire www.tai-tech.com.tw 10000 TAI-TECH P4 8. Reliability and Test Condition Item Performance Operating temperature -40~+85℃ (Including self - temperature rise) Storage temperature -40~+85℃ (on board) Test Condition Electrical Performance Test Z(common mode) DCR Agilent-4291A+ Agilent -16197A Refer to standard electrical characteristics list. I.R. Temperature Rise Test Agilent-4338B Agilent4339 Rated Current < 1A ∆T 20℃Max 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Rated Current ≧ 1A ∆T 40℃Max Reliability Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles) Temperature:85±2℃ Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪R.H, Load Humidity Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Moisture Resistance Appearance:No damage. Inductance:within±10% of initial value Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:25±2℃ ≦0.5min Step3:85±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs Oscillation Frequency: 10~2K~10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration www.tai-tech.com.tw TAI-TECH Item P5 Performance Bending Shock Solder ability Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value More than 95% of the terminal electrode should be covered with solder。 Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
ACM3225F2SF-102T15
1. 物料型号:ACM3225F2SF-102T15,这是一个共模滤波器的型号。
2. 器件简介: - 该共模滤波器具有高频下高共模阻抗,能有效抑制噪声。 - 尺寸小,低轮廓,尺寸为3.2x2.5x2.2 mm。 - 符合RoHS标准,无铅和无卤素。
3. 引脚分配:文档中未明确列出引脚分配图,但提到了该器件适用于双线制应用。
4. 参数特性: - 共模阻抗:1000±25%,测试频率为100MHz。 - 最大直流电阻:0.10欧姆。 - 最大额定电流:1500mA。 - 最大额定电压:60Vdc。 - 初始直流电阻(IR):最小10毫欧姆。
5. 功能详解: - 提供了共模和差模的阻抗曲线图,展示了不同频率下的阻抗值。 - 提供了测量电路图,包括共模和差模的测量方法。
6. 应用信息:文档中未明确列出具体的应用场景,但共模滤波器通常用于抑制电源线或信号线上的共模噪声。
7. 封装信息: - 封装类型:Taping and Reel。 - 封装尺寸:3.2±0.2 x 2.5±0.2 x 2.2±0.2 mm。
8. 材料:包括磁芯、铜线、端子等,具体材料规格在文档中有详细列出。
9. 可靠性和测试条件:文档列出了一系列测试条件和性能要求,包括工作温度、存储温度、电气性能测试、温升测试、寿命测试、湿热测试、热冲击测试、振动测试等。
10. 焊接和安装:提供了焊接和安装的建议,包括焊接剂的选择、焊接温度曲线、手工焊接的注意事项等。
11. 包装信息:提供了卷轴尺寸、胶带尺寸、包装数量和撕离力等信息。
12. 应用注意事项:包括存储条件、运输注意事项等。
ACM3225F2SF-102T15 价格&库存
很抱歉,暂时无法提供与“ACM3225F2SF-102T15”相匹配的价格&库存,您可以联系我们找货
