145-0801-612
145-0801-612
    CINCH
145-0801-612 数据手册
mmWave Catalog belfuse.com/cinch About Bel Bel is a publicly traded company that has been operated by the same family for over 65 years. Our history of organic growth and acquisitions have broadened our product portfolio. This has established Bel as a world leader with a diverse offering of power, protection and interconnect products. We design and manufacture these products which are primarily used in the networking, telecommunications, computing, military, aerospace, transportation and broadcasting industries. Bel’s portfolio of products also finds application in the automotive, medical and consumer electronics markets. About Johnson Johnson™ designs and manufactures an industry-leading line of RF coaxial connectors and adapters, available in both 50 and 75 Ohm versions, operating up to 67GHz. The range of products available within the Johnson product line includes board and cable mount connectors across subminiature, micro-miniature, ultra-miniature and millimeter wave classes as well as semi-rigid, conformable, and flexible RF coaxial cables. Johnson connectors are designed to provide the highest quality data transmission for data, audio, and video applications. Table of Contents 2.92mm 1.0mm Product Specifications 3 Product Specifications 25 End Lauch Connectors 4 End Launch Connectors 27 Sparkplug Connectors 5 Vertical Connectors 28 Adapters 6 Low Profile Connectors 29 Flange Connectors 30 Field Replaceable Connectors 31 Product Specification Table 32 Same Series Adapters 33 Between Series Adapters 34 Terminations 38 1.85mm Product Specifications 7 End Lauch Connectors 8 Vertical Connectors 9 Low Profile Connectors 9 Same Series Adapters 10 Between Series Adapters 10 Tooling Terminations 14 2.92mm Cabled Connectors 39 Application Notes 2.4mm Product Specifications 15 2.92mm Solder Type Straight Plugs for Semi-Ridgid Cables 40 End Launch Connectors 17 Field Replaceable 41 Low Profile Connectors 18 2.92mm (SMK) End Launch Connectors 43 Vertical Connectors 19 Flange Connectors 20 Same Series Adapters 21 Between Series Adapters 22 Terminations 24 2 1.0mm Product Specifications The Johnson 1.0mm Series Connector provides an excellent solution for demanding applications requiring high frequency transmission. • • • • Precision manufacturing allows superior electrical performance > 110 GHz with VSWR performance to > 1.38 Max Connector mating interface per > IEEE 287 GPC Mating interface control provides consistent electrical performance Available in screw-in end launch, panel mount and spark plug connector styles. Same series adapters are also available. Materials Bodies Stainless Steel / Passivated per QQ-S-764 Contacts Beryllium copper / Gold plated per QQ-C-530 Insulater ULTEM 1000 Amber, PEEK, PTFE Environmental Temperature Range -65ºC to +165ºC Thermal Shock MIL-STD-202, Method 107, Condition B Shock MIL-STD-202, Method 213, Condition I Vibration MIL-STD-202, Method 204, Condition D Moisture Resistance MIL-STD-202, Method 106 Electrical Impedance 50 Ohm Frequency Range DC to 110 GHz VSWR 1.38:1 maximum Working Voltage 150 (VRMS maximum at sea level) Dielectric Withstanding Voltage 500 (VRMS maximum at sea level) Insertion Loss < 0.6 dB Insulation Resistance 5000 (megohms minimum) Resistance Center Contact: 4.0 (milliohms maximum) Return Loss -15dB Max DC - 67 GHz -10dB Max 67 - 110 GHz Outer Contact: 2.5 (milliohms maximum) Mechanical Engagement Design IEEE 287 GPC, Series 1.0mm Engagement/Disengagement Force 0.56 N / 0.28 N Maximum Mating Torque 0.45 N m Coupling Proof Torque 0.7 N m Coupling Nut Retention 220 N Minimum Contact Retention 10 N Minimum 3 1.0mm End Launch Connectors Jack, Female End Panel End Launch Part Number Material Impedance Maximum Frequency VSWR 149-0701-601 Stainless Steel/Passivated 50 Ohms 110 GHz > 1.38 Max Jack, Screw-on Type, Female End Launch Jack Part Number Material Impedance Maximum Frequency VSWR 149-0701-801 Gold-Plated Brass 50 Ohms 110 GHz > 1.38 Max Jack, Screw-on Type, Male End Launch Jack Part Number Material Impedance Maximum Frequency VSWR 149-0801-801 Gold-Plated Brass 50 Ohms 110 GHz > 1.38 Max 4 1.0mm Sparkplug Connectors Female Sparkplug Part Number Material Impedance Maximum Frequency VSWR 149-0701-001 Gold-Plated Brass 50 Ohms 110 GHz > 1.38 Max Part Number Material Impedance Maximum Frequency VSWR 149-0801-001 Gold-Plated Brass 50 Ohms 110 GHz > 1.38 Max Male Sparkplug 5 1.0mm Adapters Male to Male Adapter Part Number Material Impedance Maximum Frequency VSWR 149-0901-801 Shell: Stainless Steel/ Passivated Body: Beryllium Copper/Gold Plated 50 Ohms 110 GHz > 1.38 Max Male to Female Adapter Part Number Material Impedance Maximum Frequency VSWR 149-0901-811 Shell: Stainless Steel/ Passivated Body: Beryllium Copper/Gold Plated 50 Ohms 110 GHz > 1.38 Max VSWR Female to Female Adapter Part Number Material Impedance Maximum Frequency 149-0901-821 Shell: Stainless Steel/ Passivated Body: Beryllium Copper/Gold Plated 50 Ohms 110 GHz 6 > 1.38 Max 1.85mm Product Specifications The Johnson 1.85mm Series Connector provides an excellent solution for demanding applications requiring high frequency transmission. • • • • Precision manufacturing allows superior electrical performance to 67GHz with VSWR performance to 1.35 Connector mating interface per IEC 61169-32 Mating interface control provides consistent electrical performance Available in end launch, 2 hole and 4 hole flange mount styles Materials Bodies Stainless steel/passivated per QQ-8-626, gold-plated per MIL-G-45204 0.00005” minimum Contacts Female - beryllium copperper QQ-C-530, gold-plated per MIL-G-45204 0.00005” minimum Insulater Peek; Ultem 1000, PCTFF, KEL-F Environmental (Meets of exceeds the applicable paragraph of MIL-C-39012) Temperature Range -65ºC to +165ºC Thermal Shock MIL-STD-202, Method 107, Condition B Corrosion MIL-STD-202, Method 101, Condition B Shock MIL-STD-202, Method 213, Condition I Vibration MIL-DTL-202, Method 204, Condition D Moisture Resistance MIL-DTL-202, Method 106 Electrical (Meets of exceeds the applicable paragraph of MIL-C-39012) Impedance 50 Ohm Frequency Range 0 - 67 GHz VSWR 1.3 maximum Working Voltage 150 (VRMS maximum at sea level) Dielectric Withstanding Voltage 500 (VRMS maximum at sea level) Insertion Loss 0.05 x Insulation Resistance 5000 (megohms minimum) Insulation Resistance Center Contact: 4.0 (milliohms maximum) RF Leakage -90dB (dB minimum, tested at 2.5GHz) f (GHz) (dB maximum) Outer Contact: 2.5 (milliohms maximum) Mechanical Engagement Design MIL-STD-348, series 1.85mm Engagement/Disengagement Force 2 inch-pounds maximum Mating Torque 7 to 10 inch-pounds Coupling Proof Torque 15 inch-pounds minimum Coupling Nut Retention 60 pounds minimum Contact Retention 6 pounds minimum axial force (captivated contacts) 7 1.85mm Mating Engagement: 1.85mm Series per MIL-STD-348 Plug Minimum Maximum Jack Minimum A 7.01mm 7.11mm Maximum A 7.01mm 7.11mm B 4.72mm C 1.84mm 4.75mm B 4.72mm 4.75mm 1.86mm C 1.84mm D 1.86mm 0.51mm 0.76mm D 0.51mm 0.76mm E 4.37mm 4.62mm E 4.37mm 4.62mm F 1.86mm 2.45mm F 1.86mm 2.45mm G 0 0.08mm G 0 0.08mm H 0.5mm 0.52mm H 0.5mm 0.52mm J 0.79mm 0.81mm J 0.79mm 0.81mm K 1.34mm 1.44mm End Launch Connectors 1.85mm screw-on end launch connectors are designed for use in a variety of applications and markets while delivering superior signal integrity in the most demanding environments. They operate to 67GHz with a VSWR performance up to 1.20. They are easy to assemble and disassemble to a PCB, can be connected with solder or solderless, and adjustable to varying board thicknesses. Jack, Screw-on Type REV 001 PACKAGING MODEL NO. Material 148-0701-301 Stainless Steel/Passivated DATE 12/18/2017 Impedance Maximum Frequency VSWR 67GHz Typical VSWR 1.20-1.25 ONE PCS PER BAG 148-0701-301  .0071 .0118 .0389 50 Ohms PACKAGING MODEL NO. REV 001 PACKAGING MODEL NO. Part Number ECO ECO-17-0033 ONE PCS PER BAG 148-0701-301 ECO ECO-17-0033 DATE 12/18/2017  .0071 .0118 .0389 A DETAIL (9/1) REV 001 LASER MARK:"1480701301" ECO DATE 12/18/2017 ECO-17-0033 A DETAIL (9/1) ONE PCS PER BAG 148-0701-301 M7 X 0.75-6g LASER MARK:"1480701301" M7 X 0.75-6g  .0071 .0118 .0389 .340 .445 .374 A A DETAIL (9/1) .340 .445 .374 LASER MARK:"1480701301" M7 X 0.75-6g .340 .030 .065 .451 .500 SQ .818 .445 .374 148-0801-301 Stainless Steel/Passivated .374 A 1. MATERIAL & FINISH: 1.1 BODY: NICKEL PLATED BRASS 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 BOLT & WASHER: STAINLESS STEEL 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-67 GHz 2.3 VOLTAGE STANDING WAVE RATIO:.065 1.2 MAX 2.4 CONTACT RESISTANCE: .451 2.4.1 CENTER CONTACT: 6 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 INSULATION RESISTANCE: 5000 MOHM MIN.818 2.6 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS 3. MECHANICAL: .500 SQ 3.1 ENGAGMENT/DISENGAGMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20N MIN 3.3 DURABILITY: 500 CYCLES MIN Material .818 NOTES: UNLESS OTHERWISE SPECIFIED 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-67 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENTER CONTACT: 6 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 INSULATION RESISTANCE: 5000 MOHM MIN 2.6 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS .340 Part Number .451 .340 1. MATERIAL & FINISH: 1.1 BODY: NICKEL PLATED BRASS 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 BOLT & WASHER: STAINLESS STEEL .030 .065 .340 .500 SQ NOTES: UNLESS OTHERWISE SPECIFIED Plug, Screw-on Type A .111 +.0016 -.0012 .030 .0787 X2 PCB LAYOUT .0787 X2 3. MECHANICAL: 3.1 ENGAGMENT/DISENGAGMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20N MIN 3.3 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. PACKAGING TEMPERATURE: -55 TO SPECIFIED 125°C MODEL NO. 4.2 OPERATING NOTES: UNLESS OTHERWISE 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I ONE PCS PER BAG METHOD 204, CONDITION D 148-0801-3014.5 VIBRATION: 1. MATERIAL & FINISH: MIL-STD-202, 1.1 BODY: NICKEL PLATED BRASS 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 REV 001 4. ENVIRONMENT: THERMALPACKAGING SHOCK: MIL-STD-202, METHOD 107, CONDITION B. MODEL4.1 NO. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 1.3 INSULATOR: PTFE WHITE ONE PCS PER BAG 148-0801-301 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 1.4 BOLT & WASHER: STAINLESS STEEL 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Impedance  .374   RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. 2011/65/EU   REV 001  C 12/12/2017 DO NOT SCALE DRAWING  NONE Sheet 1 of 1  .111 +.0016 -.0012  2011/65/EU This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. .XXX .02 .XXXX .008 ANGLES 5 50 Ohms 67GHz   END LAUNCH JACK,SCREW-ON TYPE,1.85mm  UNLESS OTHERWISE SPECIFIED UNITS: INCH INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. Johnson 148-0701-301/310 RoHS2  .0071 .0118 .0389 A DETAIL (9/1)  Betty.Yu  12/12/2017  148-0701-301/310  C DO NOT SCALE DRAWING  NONE Typical VSWR 1.20-1.25 .0787 X2 REV 001 A DETAIL (9/1) 3. MECHANICAL: ONE PCS PER BAG 148-0801-301 M7 X 0.75-6H 3.1 ENGAGMENT/DISENGAGMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20N MIN 3.3 DURABILITY: 500 CYCLES MIN ECO ECO-17-0033 DATE 12/18/2017 PCB LAYOUT M7 X 0.75-6H 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD .340 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106  .0071 .0118 .0389 .445 .374 .340 .500 SQ NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: NICKEL PLATED BRASS 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 BOLT & WASHER: STAINLESS STEEL 8 2011/65/EU  ANGLES 5   END LAUNCH JACK,SCREW-ON TYPE,1.85mm  UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX .02 .374 .XXXX .008 INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. Johnson 148-0701-301/310 RoHS2 .445 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. A 8mm HEX NUT  A DETAIL (9/1) A .340  Betty.Yu  12/12/2017  148-0701-301/310  C DO NOT SCALE DRAWING  NONE 001 Sheet 1 of 1 M7 X 0.75-6H LASER MARK:"1480801301" .065 .030 .504 .871 .340 .340 .500 SQ 8mm HEX NUT LASER MARK:"1480801301" .065 .504 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: NICKEL PLATED BRASS 8mm HEX NUT 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 2. ELECTRICAL: 1.4 BOLT & WASHER: STAINLESSLASER STEEL MARK:"1480801301" 2.1 IMPEDANCE: 50 OHMS .065 .340 2.2 FREQUENCY RANGE: 0-67 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX .504 .500 SQ 2. ELECTRICAL: 2.4 CONTACT RESISTANCE: 2.1 IMPEDANCE: 50 OHMS .871 2.4.1 CENTER CONTACT: 6 MILLIOHM MAX 2.2 FREQUENCY RANGE: 0-67 GHz 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.5 INSULATION RESISTANCE: 5000 MOHM MIN 2.4 CONTACT RESISTANCE: .0787 X2 2.6 DIELECTRIC WITHSTANDING VOLTAGE: 500NOTES: VRMS UNLESS OTHERWISE SPECIFIED 2.4.1 CENTER CONTACT: 6 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 3. MECHANICAL: 1. MATERIAL & FINISH: 2.5 INSULATION RESISTANCE: 5000 MOHM MIN 3.1 ENGAGMENT/DISENGAGMENT FORCE: 0.23 NM MAX 1.1 BODY: NICKEL PLATED BRASS 2.6 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS 3.2 COUPLING PROOF TORQUE: 1.65NM MIN 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 3.3 COUPLING NUT RETENTION: 267 N MIN 1.3 INSULATOR: PTFE WHITE 3. MECHANICAL: 3.4 CONTACT RETENTION: 20N MIN 1.4 BOLT & WASHER: STAINLESS STEEL 3.1 ENGAGMENT/DISENGAGMENT FORCE: 0.23 NM MAX 3.5 DURABILITY: 500 CYCLES MIN 3.2 COUPLING PROOF TORQUE: 1.65NM MIN 3.3 COUPLING NUT RETENTION: 267 N MIN 2. ELECTRICAL: 4. ENVIRONMENT: 3.4 CONTACT RETENTION: 20N MIN IMPEDANCE: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, 2.1 CONDITION B. 50 OHMS 3.5 DURABILITY: 500 CYCLES MIN 2.2 FREQUENCY RANGE: 0-67 GHz 4.2 OPERATING TEMPERATURE: -55 TO 125°C 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B .030 .445 .871 A .374 .374 .374 .111 +.0016 -.0012 .030 .111 +.0016 -.0012 PCB LAYOUT .0787 .374 X2 PCB LAYOUT .111 +.0016 -.0012  148-0801-301/310 ECO ECO-17-0033  001 148-0701-301/310 Betty.Yu  VSWR  .0071 .0118 .0389 LAYOUT END LAUNCH JACK,SCREW-ON TYPE,1.85mm  UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX .02 .XXXX .008 ANGLES 5 DATE PCB 12/18/2017 ECO ECO-17-0033 Johnson 148-0701-301/310 Maximum Frequency 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-67 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENTER CONTACT: 6 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 INSULATION RESISTANCE: 5000 MOHM MIN PACKAGING MODELVOLTAGE: NO. 2.6 DIELECTRIC WITHSTANDING 500 VRMS .374 .111 +.0016 -.0012 Johnson 001 Sheet 1 of 1 DATE 12/18/2017 1.85mm Low Profile Connectors – (at 0.375 Height) MODEL NO. PACKAGING 148-0701-802 ONE PCS PER BAG Jack, Screw-on Type, Low profile, 0.005” Pin O.005 O.009 Part Number Material Impedance Maximum Frequency VSWR 148-0701-802 Stainless Steel/Passivated 50 Ohms 67GHz Typical VSWR 1.20 O.029 DETAIL A (15/1) .375 LASER MARK " 1480701802" .250 M7 X P0.75-6g .375 .250 A MODEL NO. PACKAGING 148-0701-812 ONE PCS PER BAG .065 .375 .451 .500 .030 .818 Jack, Screw-on Type, Low profile, 0.007” Pin .375 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 MAIN BODY: PASSIVATED STAINLESS STEEL 1.2 MOUNTING BODY: NICKEL PLATED BRASS 1.3 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.4 MAIN INSULATOR: ULTEM 1000,AMBER 1.5 MOUNTING INSULATOR: PTFE, WHITE 1.6 WASHER, BOLT: STAINLESS STEEL O.007 Part Number Material Impedance Maximum Frequency VSWR 148-0701-812 Stainless Steel/Passivated 50 Ohms 67GHz Typical VSWR 1.20 DETAIL A (9/1) O.012 O.039 O .079 X 2 PCB LAYOUT 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-67 GHz 2.3 RETURN LOSS: -20DB MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN MARK " 1480701812" LASER 2.5 CONTACT RESISTANCE: 2.5.1 CENTER CONTACT: 4 MILLIOHMS MAX M7 X P0.75-6g 2.5.2 OUTER CONTACT: 2.5 MILLIOHMS MAX .375 .250 3. MECHANICAL: 3.1 DURABILITY: 500CYCLES MIN 4. ENVIRONMENT: 4.1 OPERATING TEMPERATURE: -55 TO 125°C .375 .250 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B A .065 .375 .451 .500 .375 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 MAIN BODY: PASSIVATED STAINLESS STEEL 1.2 MOUNTING BODY: NICKEL PLATED BRASS 1.3 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.4 MAIN INSULATOR: ULTEM 1000,AMBER 1.5 MOUNTING INSULATOR: PTFE, WHITE 1.6 WASHER, BOLT: STAINLESS STEEL Vertical Connectors O .079 X 2 PCB LAYOUT 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-65 GHz 2.3 RETURN LOSS: -20DB MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENTER CONTACT: 4 MILLIOHMS MAX 2.5.2 OUTER CONTACT: 2.5 MILLIOHMS MAX 3. MECHANICAL: 3.1 DURABILITY: 500CYCLES MIN Jack, Vertical Launch Solderless PCB Compression Mount, Stripline 4. ENVIRONMENT: 4.1 OPERATING TEMPERATURE: -55 TO 125°C 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. PACKAGING MODEL NO. 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D ONE PCS PER BAG 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 148-0701-202 Part Number Material Impedance Maximum Frequency VSWR 148-0701-202 Stainless Steel/Passivated 50 Ohms 67GHz Typical VSWR 1.20 O .063 ±.001 X 2 LASER MARK: "1480701202" O .394 #0-80 UNF X 2 M7 X 0.75-6g A .2819 u .0012 O .143 .141 ±.0012 O .052 O .022 .282 O .015 RECOMMENDED M .067 MODEL NO. O .067 .223 .430 PACKAGING Jack, Vertical Launch Solderless PCB Compression Mount, Microstrip 148-0701-212 .118 ONE PCS PER BAG .008 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 WASHER: STAINLESS STEEL 1.5 BOLT: SUS302 1.6 LOCK RING: NICKEL PLATED BRASS .002 Part Number Material Impedance Maximum Frequency VSWR 148-0701-212 Stainless Steel/Passivated 50 Ohms 50GHz Typical VSWR 1.20 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-67 GHz 2.3 INSULATION RESISTANCE: 5000 MOHM MIN 2.4 CONTACT RESISTANCE: 2.4.1 CENTER CONTACT: 4 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500VRMS MIN M7 X 0.75-6g 2.6 VOLTAGE STANDING WAVE RATIO (VSWR): 1.3 MAX A DETAIL (10/1) SCA 1. BOARD THICK O .063 ±.001 X2 LASER MARK: "1480701212" O .394 #0-80 UNF X 2 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 7 N MIN 3.3 DURABILITY: 500 CYCLES MIN A .2819 u .0012 O .143 .141 ±.0012 O .052 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -65 TO 165°C 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 O .022 .282 .052 O .015 RECOMMENDED .067 .430 O .067 .223 R.024 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 WASHER: STAINLESS STEEL 9 .118 .008 .002 .0315 A DETAIL (10/1) SC 1.85mm Same Series Adapters 1.85mm same series adapters are precision manufactured to RF component industry specifications, with a maximum frequency of 67GHz, and VSWR up to 1.20. Available in jack to jack, jack to plug, and plug to plug configurations. Plug to Plug Adapter MODEL NO. Part Number Material Impedance 148-0901-701 Stainless Steel/Passivated 50 Ohms 148-0901-701 REV 001 PACKAGING Maximum Frequency VSWR 67GHz 1.20 ONE PCS PER BAG EC ECO-17 .641 M7 X 0.75-6H M7 X 0.75-6H LASER MARK:"1480901701" 8mm HEX NUT 8mm HEX NUT 7mm WRENCH FLATS .791 REF NOTES: UNLESS OTHERWISE SPECIFIED Plug to Jack Adapter MODEL NO. 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 GASKET: SILICONE RED PACKAGING 1.5 C RING: BERYLLIUM COPPER REV 001 ONE PCS PER BAG 148-0901-711 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-67 GHZ 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 INSERTION LOSS: 0.05 X F (GHZ)DB MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.7 INSULATION RESISTANCE: 5000 MOHM MIN Part Number Material Impedance Maximum Frequency VSWR 148-0901-711 Stainless Steel/Passivated 50 Ohms 67GHz 1.20 EC 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65 NM MIN 3.3 COUPLING NUT RETENTION: 267 N MIN 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN .641 M7 X 0.75-6H 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 M7 X 0.75-6g  John 148-0901-701/710  RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2011/65/EU .XXX .02 .XXXX .01 ANGLES 5   ADAPTER ASSEMB PLUG,1.85mm  UNLESS OTHERWISE SPECIFIED UNITS: INCH  Betty.Yu  12/12/2017 148-0901-701/  C DO NOT SCALE DRAWING  NO 8mm HEX NUT 7mm WRENCH FLATS LASER MARK:"1480901711" .836 REF NOTES: UNLESS OTHERWISE SPECIFIED Jack to Jack Adapter 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS PACKAGING MODEL NO. 2.2 FREQUENCY RANGE: 0-67 GHZ 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 INSERTION LOSS: F (GHZ)DB MAX ONE PCS0.05 PER XBAG 148-0901-721 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.7 INSULATION RESISTANCE: 5000 MOHM MIN Part Number Material Impedance Maximum Frequency VSWR 148-0901-721 Stainless Steel/Passivated 50 Ohms 67GHz 1.20 REV 001 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65 NM MIN 3.3 COUPLING NUT RETENTION: 267 N MIN 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I M7 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .641 X 0.75-6g  LASER MARK:"1480901721" M7 X 0.75-6g Joh 148-0901-711/720  RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/65/EU   ADAPTER ASS JACK,1.85mm  UNLESS OTHERWISE SPECIFIED UNITS: INCH INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009.  .XXX .02 .XXXX .01 ANGLES 5 Betty.Yu  12/12/2017 148-0901-7  C DO NOT SCALE DRAWING  7mm WRENCH FLATS .881 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-67 GHZ 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 INSERTION LOSS: 0.05 X F (GHZ)DB MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.7 INSULATION RESISTANCE: 5000 MOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20 N MIN 3.3 DURABILITY: 500 CYCLES MIN 10 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106  J 148-0901-721/730 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not 2011/65/EU    ADAPTER A JACK,1.85m  UNLESS OTHERWISE SPECIFIED UNITS: INCH  1.85mm Between Series Adapters 1.85mm between series adapters are precision manufactured to RF component industry specifications, and adapt to the 2.4mm and SMPM standards, with a maximum frequency of 50 and 65GHz, and VSWR of 1.15-1.25. Available in jack to jack, jack to plug, plug to jack and plug to plug configurations. Adapter Assembly, 1.85mm Jack to 2.4mm Jack R Part Number Material Impedance 134-1000-016 Stainless Steel/Passivated 50 Ohms MODEL NO. 134-1000-016 PACKAGING Maximum Frequency VSWR 67GHz 1.15 ONE PCS PER BAG M7 X 0.75-6g .641 M7 X 0.75-6g LASER MARK:"1341000016" 7mm WRENCH FLATS .881 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER Adapter Assembly, 1.85mm Jack to 2.4mm Plug Part Number Material Impedance 148-0901-711 Stainless Steel/Passivated 50 Ohms PACKAGING MODEL NO. 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz ONE PCS PER BAG 134-1000-017 2.3 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.4 VOLTAGE STANDING WAVE RATIO: DC- 26.5 GHZ: 1.06MAX 26.5 - 40 GHZ: 1.10 MAX 40 - 50 GHZ: 1.15 MAX 2.5 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.6 INSULATION RESISTANCE: 5000 MOHM MIN Maximum Frequency VSWR 67GHz 1.15 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20 N MIN 3.3 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D M7 X 0.75-6g 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .641 LASER MARK:"1341000017"  M7X 0.75-6H 7mm WRENCH FLATS 134-1000-016  RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. 2011/65/EU .XXX .02 .XXXX .01 ANGLES 5   ADAP JACK  UNLESS OTHERWISE SPECIFIED UNITS: INCH  Betty.Yu   12/12/2017 C DO NO DRA 8mm HEX NUT .836 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER Adapter Assembly, 1.85mm Plug to 2.4mm Jack 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS MODEL NO. 134-1000-018 Part Number 134-1000-018 Material Stainless Steel/Passivated Impedance 50 Ohms PACKAGING 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.4 VOLTAGE STANDING WAVE RATIO: DC- 26.5GHZ: 1.06 MAX 26.5- 40 GHZ: 1.10 MAX 40 - 50 GHZ: 1.15 MAX 2.5 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.6 INSULATION RESISTANCE: 5000 MOHM MIN ONE PCS PER BAG Maximum Frequency VSWR 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65NM MIN (2.4MM) 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN (2.4MM) 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN 50GHz 1.15 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 M7 X 0.75-6H  .641 8mm HEX NUT 134-1000-017 INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. 2011/65/EU   RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand.   UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX .02 .XXXX .01 ANGLES 5  Betty.Yu   12/12/2017 C M7X 0.75-6g 7mm WRENCH FLATS LASER MARK:"1341000018" .836 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.4 VOLTAGE STANDING WAVE RATIO: DC- 26.5GHZ: 1.06 MAX 26.5- 40 GHZ: 1.10 MAX 40 - 50 GHZ: 1.15 MAX 2.5 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.6 INSULATION RESISTANCE: 5000 MOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65NM MIN (1.85MM) 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN (1.85MM) 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 11  134-10 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/65/EU  UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX .02  1.85mm MODEL NO. 134-1000-019 Adapter Assembly, 1.85mm Plug to 2.4mm Plug PACKAGING ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 134-1000-019 Stainless Steel/Passivated 50 Ohms 50GHz 1.15 .641 M7X 0.75-6H M7 X 0.75-6H 8mm HEX NUT 8mm HEX NUT 7mm WRENCH FLATS LASER MARK:"1341000019" NOTES: UNLESS OTHERWISE SPECIFIED Adapter Assembly, 1.85mm Jack to 2.92mm Jack .791 REF 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER ULTEM 1000 AMBER PACKAGING MODEL NO. 1.3 INSULATOR: 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER ONE PCS PER BAG 134-1000-020 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.4 VOLTAGE STANDING WAVE RATIO: DC- 26.5GHZ: 1.06 MAX 26.5- 40 GHZ: 1.10 MAX 40 - 50 GHZ: 1.15 MAX 2.5 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.6 INSULATION RESISTANCE: 5000 MOHM MIN Part Number Material Impedance Maximum Frequency VSWR 134-1000-020 Stainless Steel/Passivated 50 Ohms 46.5Hz 1.15 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65NM MIN 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C M7 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .641 X 0.75-6g 1/4-36UNS-2A  1 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. LASER MARK:"1341000020" INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX .02 .XXXX .01 ANGLES 5 7mm WRENCH FLATS .837 Adapter Assembly, 1.85mm Jack to 2.92mm Plug NOTES: UNLESS SPECIFIED PACKAGING MODEL NO. OTHERWISE 1. MATERIAL & FINISH: ONESTAINLESS PCS PER BAG 1.1134-1000-021 BODY: PASSIVATED STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-46.5 GHz 2.3 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.4 VOLTAGE STANDING WAVE RATIO: DC- 4GHZ: 1.05 MAX 4 - 20 GHZ: 1.08 MAX 20-46.5 GHZ: 1.15 MAX 2.5 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.6 INSULATION RESISTANCE: 5000 MOHM MIN Part Number Material Impedance Maximum Frequency VSWR 134-1000-021 Stainless Steel/Passivated 50 Ohms 46.5Hz 1.15 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20 N MIN 3.3 DURABILITY: 500 CYCLES MIN .641 M7 X 0.75-6g LASER MARK:"1341000021" 1/4-36UNS-2B 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -65 TO 165°C 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No RoHS This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/ UNLESS OTHER UNIT INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 7mm WRENCH FLATS .XXX .XXXX ANGL 8mm HEX NUT .865 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-46.5 GHz 2.3 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.4 VOLTAGE STANDING WAVE RATIO: DC- 4 GHZ: 1.05 MAX 4 - 20 GHZ: 1.08 MAX 20 - 46.5GHZ: 1.15 MAX 2.5 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.6 INSULATION RESISTANCE: 5000 MOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.7NM MIN (2.92MM) 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -65 TO 165°C 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. 12 134-1 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v Dra Da 1.85mm Adapter Assembly, 1.85mm Plug to 2.92mm Jack MODEL NO. REV 001 002 PACKAGING 数字签名人 Lin Ma DN:cn=Lin Ma, c=CN, o=Cinch Connectivity Solutions (Shanghai) Co. Ltd, email=lin.ma@cn.cinch.com 日期:2018.08.22 13:59:01 +08'00' 134-1000-022 ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 134-1000-022 Stainless Steel/Passivated 50 Ohms 46.5Hz 1.15 .641 LASER MARK:"1341000022" M7 X 0.75-6H 1/4-36UNS-2A 7mm WRENCH FLATS 8mm HEX NUT .792 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3NO. INSULATOR: ULTEM 1000 AMBER PACKAGING MODEL 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER ONE PCS PER BAG 134-1000-023 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-46.5 GHz 2.3 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.4 VOLTAGE STANDING WAVE RATIO: DC- 4 GHZ: 1.05 MAX 4 - 20 GHZ: 1.08 MAX 20 - 46.5GHZ: 1.15 MAX 2.5 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.6 INSULATION RESISTANCE: 5000 MOHM MIN 数字签名人 Lin Ma DN:cn=Lin Ma, c=CN, o=Cinch Connectivity Solutions (Shanghai) Co. Ltd, email=lin.ma@cn.cinch.com 日期:2018.08.22 13:59:25 +08'00' REV 001 002 Adapter Assembly, 1.85mm Plug to 2.92mm Pkug Part Number Material Impedance Maximum Frequency VSWR 134-1000-023 Stainless Steel/Passivated 50 Ohms 46.5Hz 1.15 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65NM MIN (1.85MM) 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN .641 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 0.75-6H M7 X 4.2 OPERATING TEMPERATURE: -65 TO 165°C 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 1/4-36UNS-2B Model No. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 8mm HEX NUT J 134-1000-022 Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/65/EU Title: 3RD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v ADAPTER A TO 2.92mm Drawing No. Drawn by: Date: Betty.Yu 08/21/2018 134Size C DO NOT SCALE DRAWING Title: ADAPTER A TO 2.92mm LASER MARK:"1341000023" 7mm WRENCH FLATS .820 REF NOTES: UNLESS OTHERWISE SPECIFIED MODEL NO. 134-1000-024 PACKAGING 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ONE PCS PER BAGULTEM 1000 AMBER 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER Adapter Assembly, 1.85mm Jack to SMPM Female 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-46.5 GHz 2.3 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.4 VOLTAGE STANDING WAVE RATIO: DC- 4 GHZ: 1.05 MAX 4 - 20 GHZ: 1.08 MAX 20 - 46.5GHZ: 1.15 MAX 2.5 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.6 INSULATION RESISTANCE: 5000 MOHM MIN Part Number Material Impedance Maximum Frequency VSWR 134-1000-024 Stainless Steel/Passivated 50 Ohms 65GHz 1.25 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65NM MIN (1.85MM);1.7NM MIN (2.92MM) 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -65 TO 165°C 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 LASER MARK:"1341000024" M7 X 0.75-6g Model No. .398 INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v 6mm WRENCH FLATS .518 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN& CONTACT BODY: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-67 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.25 MAX 2.4 CONTACT RESISTANCE: CENTER CONTACT: 6 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 325VRMS MIN 2.6 INSULATION RESISTANCE: 5000 MOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: 0.23 NM MAX (1.85MM) FULL DETENT: 19 N MAX,SMOOTH BORE: 11 N MAX (SMPM) 3.2 DISENGAGEMENT FORCE: 0.23 NM MAX (1.85MM) FULL DETENT: 29 N MAX, SMOOTH BORE: 11N MAX (SMPM) 3.3 CONTACT RETENTION: 20 N MIN 3.4 DURABILITY: 500 CYCLES MIN (1.85MM) FULL DETENT: 100 CYCLES MIN, SMOOTH BORE:500 CYCLES MIN (SMPM) 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 13 J 134-1000-023 Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 3RD ANGLE PROJECTION Drawing No. Drawn by: Date: Betty.Yu 08/21/2018 134Size C DO NOT SCALE DRAWING 1.85mm PACKAGING MODEL NO. ONE PCS PER BAG 134-1000-025 Adapter Assembly, 1.85mm Jack to SMPM Male (Full Detent) Part Number Material Impedance Maximum Frequency VSWR 134-1000-025 Stainless Steel/Passivated 50 Ohms 65GHz 1.25 LASER MARK:"1341000025" .398 M7 X 0.75-6g  .236 6mm WRENCH FLATS .601 PACKAGING MODEL NO. Adapter Assembly, 1.85mm Plug to SMPM Female ONE PCS PER BAG 134-1000-026 Part Number Material 134-1000-026 Stainless Steel/Passivated Impedance NOTES: UNLESS OTHERWISE SPECIFIED Maximum Frequency VSWR 1. MATERIAL & FINISH: 1.1 BODY& CONTACT BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 50 Ohms 65GHz 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-67 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.25 MAX 2.4 CONTACT RESISTANCE: CENTER CONTACT: 6 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 325VRMS MIN 2.6 INSULATION RESISTANCE: 5000 MOHM MIN 1.25 .398 M7 X 0.75-6H 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: 0.23 NM MAX (1.85MM) FULL DETENT: 19 N MAX (SMPM) 3.2 DISENGAGEMENT FORCE: 0.23 NM MAX (1.85MM) FULL DETENT: 29 N MAX (SMPM) 3.3 CONTACT RETENTION: 20 N MIN 3.4 DURABILITY: 500 CYCLES MIN  .236 LASER MARK:"1341000026" 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 8mm HEX NUT  .472 REF PACKAGING MODEL NO. 13 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. Adapter Assembly, 1.85mm Plug to SMPM Male (Full Detent) 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX .02 .XXXX .01 ANGLES 5 NOTES: UNLESS SPECIFIED ONE PCSOTHERWISE PER BAG 134-1000-027 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN& CONTACT BODY: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED Part Number Material Impedance Maximum Frequency VSWR 134-1000-027 Stainless Steel/Passivated 2. ELECTRICAL: 50 Ohms 2.1 IMPEDANCE: 50 OHMS 65GHz 1.25 2.2 FREQUENCY RANGE: 0-67 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.25 MAX 2.4 CONTACT RESISTANCE: CENTER CONTACT: 6 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 325VRMS MIN 2.6 INSULATION RESISTANCE: 5000 MOHM MIN M7 X 0.75-6H .398 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: 0.23 NM MAX (1.85MM) FULL DETENT: 19 N MAX,SMOOTH BORE: 11 N MAX (SMPM) 3.2 DISENGAGEMENT FORCE: 0.23 NM MAX (1.85MM) FULL DETENT: 29 N MAX, SMOOTH BORE: 11N MAX (SMPM) 3.3 COUPLING PROOF TORQUE: 1.65 NM MIN 3.4 COUPLING NUT RETENTION: 267 N MIN 3.5 CONTACT RETENTION: 20 N MIN 3.6 DURABILITY: 500 CYCLES MIN (1.85MM) FULL DETENT: 100 CYCLES MIN, SMOOTH BORE:500 CYCLES MIN (SMPM) 4. ENVIRONMENT: LASER MARK:"1341000027" 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106  .236  8mm HEX NUT RoHS2 .556 REF This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/65 UNLESS OTHERWISE UNITS: INC INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. Terminations Termination Plug (1/4 Watts) Same Series NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY,CONTACT BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-67 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.25 MAX 2.4 CONTACT RESISTANCE: CENTER CONTACT: 6 MILLIOHMS MAX OUTER CONTACT: 2.5 MILLIOHMS MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 325VRMS MIN 2.6 INSULATION RESISTANCE: 5000 MOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: 0.23 NM MAX (1.85MM) FULL DETENT: 19 N MAX,SMOOTH BORE: 11 N MAX (SMPM) 3.2 DISENGAGEMENT FORCE: 0.23 NM MAX (1.85MM) FULL DETENT: 29 N MAX, SMOOTH BORE: 11N MAX (SMPM) 3.3 COUPLING PROOF TORQUE: 1.65 NM MIN 3.4 COUPLING NUT RETENTION: 267 N MIN 3.5 CONTACT RETENTION: 20 N MIN 3.6 DURABILITY: 500 CYCLES MIN Part Number Material Impedance Maximum Frequency VSWR 148-0801-801 Stainless Steel/Passivated 50 Ohms 67GHz 1.30 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106  134-10 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAW ING IN ACCORDANCE W ITH ASME Y14.5-2009. 14 .XXX . .XXXX  ANGLES 2011/65/EU  UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX .02 .XXXX .01 ANGLES 5   1 2.4mm Product Specifications The Johnson 2.4mm Series Connector provides an excellent solution for demanding applications requiring high frequency transmission. • • • • Precision manufacturing allows superior electrical performance with maximum VSWR of 1.30 at 50 GHz Connector mating interface per MIL-STD-348, and intermateable with 1.85mm connector series. Mating interface control provides consistent electrical performance Available in end launch, 2 hole and 4 hole flange mount styles Materials Bodies Stainless steel/passivated per QQ-8-626, gold-plated per MIL-G-45204 0.00005” minimum Contacts Female - beryllium copperper QQ-C-530, gold-plated per MIL-G-45204 0.00005” minimum Insulater Peek; Ultem 1000, PCTFF, KEL-F Environmental (Meets of exceeds the applicable paragraph of MIL-C-39012) Temperature Range -65ºC to +165ºC Thermal Shock MIL-STD-202, Method 107, Condition B Corrosion MIL-STD-202, Method 101, Condition B Shock MIL-STD-202, Method 213, Condition I Vibration MIL-DTL-202, Method 204, Condition D Moisture Resistance MIL-DTL-202, Method 106 Electrical Impedance 50 Ohm Frequency Range 0 - 50 GHz VSWR 1.25 maximum Working Voltage 150 (VRMS Maximum) Dielectric Withstanding Voltage 500 (VRMS minimum) Insertion Loss 0.05 x f (GHz), dB maximum Insulation Resistance 5000 (megohms minimum) Contact Resistance Center Contact: 4.0 (milliohms maximum) RF Leakage -90dB (dB minimum, tested at 2.5GHz) Outer Contact: 2.5 (milliohms maximum) 15 2.4mm Mechanical Engagement Design MIL-STD-348, series 2.4mm Engagement/Disengagement Force 2 inch-pounds maximum Mating Torque 7 to 10 inch-pounds Coupling Proof Torque 15 inch-pounds minimum Coupling Nut Retention 60 pounds minimum Contact Retention 6 pounds minimum axial force (captivated contacts) Mating Engagement: 2.4mm Series per MIL-STD-348 Plug Minimum Maximum A 7.01mm 7.11mm B 4.72mm 4.75mm C 2.39mm 2.41mm D 0.51mm 0.76mm E 3.56mm 3.81mm F 1.85mm 2.67mm G 0mm 0.08mm H 0.5mm 0.52mm J 1.03mm 1.05mm K 1.35mm 1.45mm Jack End Launch Connectors Jack, Screw-On Type Minimum Maximum A 5.79mm 5.89mm B 4.77mm 4.79mm C 2.39mm 2.41mm D 1.03mm 1.05mm E 1.40mm 1.65mm F 5.99mm - G 0mm 0.08mm H 3mm MODEL NO. 147-0701-201 3.1mm PACKAGING 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:55:21 +08'00' REV 001 ECO ECO-17-0032 DATE 11/28/2017 ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 147-0701-201 Stainless Steel/Passivated 50 Ohms 50GHz Typical VSWR 1.20 O .0071 O.0118 O.0389 A DETAIL (9/1) LASER MARK: "1470701201" M7 X P0.75-6g .340 .445 A .065 .340 Plug, Screw-On Type .030 .451 .500 SQ .374 .818 NOTES: UNLESS OTHERWISE PACKAGINGSPECIFIED MODEL NO. Part Number Material Impedance 147-0801-201 Stainless Steel/Passivated 50 Ohms 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:57:37 +08'00' 1. MATERIAL & FINISH: 1.1 BODY: NICKEL PLATED BRASS ONE PCS PER BAG 147-0801-201 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 BOLT & WASHER: STAINLESS STEEL REV 001 EC ECO-17 .375 Maximum Frequency VSWR 50GHz Typical VSWR 1.20-1.25 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENER CONTACT: 6 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN O .0071 O.0118 O.0389 .110 A DETAIL (9/1) O.0787 X2 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20 N MIN 3.3 DURABILITY (MATING): 500 CYCLES MIN PCB LAYOUT M7 X P0.75-6H 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. .340 .445 A INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. .315 HEX 16 .340 .500 SQ LASER MARK: "1470801201" .065 .030 .504 .871 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: NICKEL PLATED BRASS 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 147-0701-201 Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. .374 .374 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v Title: 3RD ANGLE PROJECTION Johnson END LAUNCH JACK, SCREW-ON TYPE,2.4mm Drawing No. Drawn by: Date: Betty.Yu 10/19/2017 147-0701-201 Size C DO NOT SCALE DRAWING Workmanship Std: NONE Rev. 001 Sheet 1 of 1 2.4mm Part Number 147-0701-241 Material Gold-Plated Brass REV ECO DATE 1 ECO-19-0031 7/25/2019 MODEL NUMBER Jack, 0.062” Board thickness, Solder Type 12.70 .500 147-0701-241 Impedance Maximum Frequency 50 Ohms VSWR  0.30 .012 50GHz Typical VSWR 1.5 M7 x 0.75 - 6g 2.29 .090 5.46 .215 3.05 .120 SPECIFICATION: ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-50 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 150 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 500VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 4 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2.5 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz 1.73 .068  7.42 .292 7.87 .310 MECHANICAL: COUPLING TORQUE RECOMMENDED: 0.8 Nm TO 1.1 Nm COUPLING TEST TORQUE: 1.65 Nm DURABILITY: 500 CYCLES MIN ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: IEC 61169-1, SUBCLAUSE 9.4.4 CORROSION: IEC 61169-1, SUBCLAUSE 9.4.6 SHOCK: IEC 61169-1, SUBCLAUSE 9.3.14 VIBRATION: IEC 61169-1, SUBCLAUSE 9.3.3 MOISTURE RESISTANCE: IEC 61169-1, SUBCLAUSE 9.4.3 PC Mount Jack, Thru-Hole, Round Body, Solder Type MATERIAL AND FINISH: BODY: GOLD PLATED BRASS CENTER CONTACT: GOLD PLATED BERYLLIUM COPPER INSULATOR: PTFE (TEFLON)   JOHNSON 147-0701-241 Part Number Material Impedance Maximum Frequency VSWR 147-0701-251 Gold-Plated Brass 50 Ohms 50GHz Typical VSWR 1.5 SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. SEE NOTE  2011/65/EU X 0.2 X.X 0.1 X.XX 0.07 ANGLES 2 DEG   RoHS2 UNLESS OTHERWISE SPECIFIED UNITS: MM  INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009.  2.4mm END LAUNCH JACK FOR .062" BOARD DIA .012" PIN   147-0701-241  R.SHEN   5/9/19 C DO NOT SCALE DRAWING 1 Sheet 1 of 1 MODEL NUMBER 147-0701-251 REV ECO DATE 1 1A ECO-19-0033 ECO-19-0038 7/31/2019 9/9/2019 14.99 .590 4X  0.990.03 (.039.001) BOARD EDGE 5.330.03 (.210.001) 5.33 .210 7.87 .310 2.36 ±0.13 4X .093 ±.005 ±0.05 4X 0.81 .032 ±.002 M7 x 0.75 - 6g 2.080.03 (.082.001) 4.670.03 (.184.001) 4.67 .184 RECOMMENDED MOUNTING HOLE DIMENSIONS 2.08 .082 0.76 .030 SPECIFICATION: MODEL NUMBER Jack, 0.042” Board thickness, Solder Type Part Number 147-0701-261 Material Gold-Plated Brass 147-0701-261 Impedance 50 Ohms ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-50 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 150 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 500VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 4 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2.5 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz 12.70 .500 5.33 .210 3.25 .128 ECO DATE 1 ECO-19-0036 8/22/2019 0.30 ±0.025  .012 ±.001 Maximum Frequency VSWR  7.49 .295 MECHANICAL: COUPLING TORQUE RECOMMENDED: 0.8 Nm TO 1.1 Nm COUPLING TEST TORQUE: 1.65 Nm DURABILITY: 500 CYCLES MIN  0.30 .012 50GHz Typical VSWR 1.5 ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: IEC 61169-1, SUBCLAUSE 9.4.4 M7 x 0.75 - 6g CORROSION: IEC 61169-1, SUBCLAUSE 9.4.6 SHOCK: IEC 61169-1, SUBCLAUSE 9.3.14 VIBRATION: IEC 61169-1, SUBCLAUSE 9.3.3 MOISTURE RESISTANCE: IEC 61169-1, SUBCLAUSE 9.4.3 SPECIFICATION: REV 2.29 .090 5.46 .215 3.05 .120 MATERIAL AND FINISH: BODY: GOLD PLATED BRASS CENTER CONTACT: GOLD PLATED BERYLLIUM COPPER INSULATOR: PTFE (TEFLON)   SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-50 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 150 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 500VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 4 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2.5 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz 2011/65/EU SEE NOTE  JOHNSON 147-0701-251  RoHS2 UNLESS OTHERWISE SPECIFIED UNITS: MM  INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. X 0.2 X.X 0.1 X.XX 0.07 ANGLES 2 DEG   2.4mm END LAUNCH PC MOUNT JACK ROUND BODY DIA .012" PIN   147-0701-251  R.SHEN  7/31/19  C DO NOT SCALE DRAWING 1A Sheet 1 of 1 1.22 .048  7.42 .292 MECHANICAL: COUPLING TORQUE RECOMMENDED: 0.8 Nm TO 1.1 Nm COUPLING TEST TORQUE: 1.65 Nm DURABILITY: 500 CYCLES MIN 7.87 .310 ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: IEC 61169-1, SUBCLAUSE 9.4.4 CORROSION: IEC 61169-1, SUBCLAUSE 9.4.6 SHOCK: IEC 61169-1, SUBCLAUSE 9.3.14 VIBRATION: IEC 61169-1, SUBCLAUSE 9.3.3 MOISTURE RESISTANCE: IEC 61169-1, SUBCLAUSE 9.4.3 MATERIAL AND FINISH: BODY: GOLD PLATED BRASS CENTER CONTACT: GOLD PLATED BERYLLIUM COPPER INSULATOR: PTFE (TEFLON) Jack, 0.093” Board thickness, Solder Type   SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand.  2011/65/EU SEE NOTE  JOHNSON 147-0701-261 RoHS2 X 0.2 X.X 0.1 X.XX 0.07 ANGLES 2 DEG   UNLESS OTHERWISE SPECIFIED UNITS: MM  INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2.4mm END LAUNCH JACK FOR .042" BOARD DIA .012" PIN   147-0701-261  R.SHEN  5/9/19  DO NOT SCALE 1 ECO Sheet 1 of 1 DATE ECO-19-0036 8/22/2019 C REVDRAWING MODEL NUMBER 1 12.70 .500 147-0701-271 Part Number Material Impedance Maximum Frequency VSWR 147-0701-271 Gold-Plated Brass 50 Ohms 50GHz Typical VSWR 1.5  0.30 .012 M7 x 0.75 - 6g 2.29 .090 5.46 .215 3.05 .120 SPECIFICATION: ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-50 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 150 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 500VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 4 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2.5 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz 2.49 .098  7.42 .292 7.87 .310 MECHANICAL: COUPLING TORQUE RECOMMENDED: 0.8 Nm TO 1.1 Nm COUPLING TEST TORQUE: 1.65 Nm DURABILITY: 500 CYCLES MIN ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: IEC 61169-1, SUBCLAUSE 9.4.4 CORROSION: IEC 61169-1, SUBCLAUSE 9.4.6 SHOCK: IEC 61169-1, SUBCLAUSE 9.3.14 VIBRATION: IEC 61169-1, SUBCLAUSE 9.3.3 MOISTURE RESISTANCE: IEC 61169-1, SUBCLAUSE 9.4.3 MATERIAL AND FINISH: BODY: GOLD PLATED BRASS CENTER CONTACT: GOLD PLATED BERYLLIUM COPPER INSULATOR: PTFE (TEFLON)  SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009.  SEE NOTE  JOHNSON 147-0701-271  RoHS2 2011/65/EU  UNLESS OTHERWISE SPECIFIED UNITS: MM X 0.2 X.X 0.1 X.XX 0.07 ANGLES 2 DEG   2.4mm END LAUNCH JACK FOR .093" BOARD DIA .012" PIN   147-0701-271  R.SHEN  5/9/19  C DO NOT SCALE DRAWING 1 Sheet 1 of 1 17 2.4mm Low Profile Connectors – (at 0.375 Height) MODEL NO. PACKAGING 147-0701-822 ONE PCS PER BAG Jack, Screw-on Type, Low profile, 0.005” Pin O.005 O.009 Part Number Material Impedance Maximum Frequency VSWR 147-0701-822 Stainless Steel/Passivated 50 Ohms 50GHz Typical VSWR 1.20 O.029 DETAIL A (15/1) LASER MARK " 1470701822" . . M7 X P0.75-6g .375 .250 A .065 .375 Jack, Screw-on Type, Low profile, 0.007” Pin MODEL NO. PACKAGING 147-0701-832 ONE PCS PER BAG .451 .500 .030 .818 . NOTES: UNLESS OTHERWISE SPECIFIED Part Number Material Impedance 147-0701-832 Stainless Steel/Passivated 50 Ohms 1. MATERIAL & FINISH: 1.1 MAIN BODY: PASSIVATED STAINLESS STEEL 1.2 MOUNTING BODY: NICKEL PLATED BRASS 1.3 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.4 MAIN INSULATOR: ULTEM 1000,AMBER 1.5 MOUNTING INSULATOR: PTFE, WHITE 1.6 WASHER, BOLT: STAINLESS STEEL Maximum Frequency VSWR 50GHz Typical VSWR 1.20 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-50 GHz 2.3 RETURN LOSS: -20DB MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENTER CONTACT: 4 MILLIOHMS MAX 2.5.2 OUTER CONTACT: 2.5 MILLIOHMS MAX 3. MECHANICAL: 3.1 DURABILITY: 500CYCLES MIN O .079 X 2 O.007 PCB L O.012 O.039 DETAIL A (9/1) . LASER MARK " 1470701832" . M7 X P0.75-6g 4. ENVIRONMENT: 4.1 OPERATING TEMPERATURE: -55 TO 125°C 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.6 SALT SPRAY: METHOD 101, CONDITION B .375MIL-STD-202, .250 A .375 .500 .065 .451 . NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 MAIN BODY: PASSIVATED STAINLESS STEEL 1.2 MOUNTING BODY: NICKEL PLATED BRASS 1.3 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.4 MAIN INSULATOR: ULTEM 1000,AMBER 1.5 MOUNTING INSULATOR: PTFE, WHITE 1.6 WASHER, BOLT: STAINLESS STEEL 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-50 GHz 2.3 RETURN LOSS: -20DB MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENTER CONTACT: 4 MILLIOHMS MAX 2.5.2 OUTER CONTACT: 2.5 MILLIOHMS MAX 3. MECHANICAL: 3.1 DURABILITY: 500CYCLES MIN 4. ENVIRONMENT: 4.1 OPERATING TEMPERATURE: -55 TO 125°C 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 18 O .079 X 2 PCB L 2.4mm Vertical Mount Connectors . MODEL NO. PACKAGING Jack, Vertical 2-Hole Flange PCB Compression Mount, Stripline ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 147-0701-211 Stainless Steel/Passivated 50 Ohms 50GHz Typical VSWR 1.20 147-0701-211 O .063 ±.001 X 2 LASER MARK: "1470701211" #0-80 UNF X 2 O .394 M7 X 0.75-6g A .2819 u 0.0012 O .140 O .052 .1409 u 0.0 .282 O .022 O .016 RECOMME .065 MODEL NO. Jack, Vertical 2-Hole Flange PCB Compression Mount, Microstrip Part Number 147-0701-222 Material Stainless Steel/Passivated Impedance 50 Ohms O .067 .223 .430 .1 PACKAGING NOTES: UNLESS OTHERWISE SPECIFIED ONE PCS PER BAG 147-0701-222 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 WASHER: STAINLESS STEEL 1.5 BOLT: SUS302 .003 .006 Maximum Frequency VSWR 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-50 GHz 2.3 INSULATION RESISTANCE: 5000 MOHM MIN 2.4 CONTACT RESISTANCE: 2.4.1 CENTER CONTACT: 4 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500VRMS MIN 2.6 VOLTAGE STANDING WAVE RATION( VSWR): 1.55 MAX 50GHz A DETAIL (10/1) Typical VSWR 1.20 1. BOAR O .063 ±.001 LASER MARK: "1470701222" #0-80 UNF X 2 M7 X 0.75-6g 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 12 N MIN 3.3 DURABILITY: 500 CYCLES MIN O .394 A O .016 .2819 u .0012 O .140 O .052 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -65 TO 165°C 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .141 ±. O .052 .052 .282 O .022 RECOMM .065 .430 O .067 .223 R.024 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 WASHER: STAINLESS STEEL 1.5 BOLT: SUS302 .003 .012 .0315 A DETAIL (10/1) 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-50 GHz 2.3 INSULATION RESISTANCE: 5000 MOHM MIN 2.4 CONTACT RESISTANCE: 2.4.1 CENTER CONTACT: 4 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500VRMS MIN 2.6 VOLTAGE STANDING WAVE RATIO (VSWR): 1.8 MAX 1. BOA 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 12 N MIN 3.3 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -65 TO 165°C 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 19 2.4mm Flange Connectors Plug, 2-Hole Flange Mount Jack Receptacle Part Number 147-0701-601 Material Stainless Steel/Passivated Impedance Maximum Frequency MODEL NO. 50 Ohms VSWR PACKAGING 50GHz 147-0801-601 REV 001 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:58:04 +08'00' Typical VSWR 1.20 ONE PCS PER BAG ECO ECO-17-0032 O .102 +.004 X2 0 M7 X P0.75-6H ACCEPT O .0120 PIN .481 O .626 LASER MARK: "1470801601" .315 HEX .065 NOTES: UNLESS OTHERWISE SPECIFIED .224 .004 .504 REF 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 C RING: BERYLLIUM COPPER 1.5 LOCK RING: GOLD PLATED BRASS 1.6 GASKET: SILICONE RED 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENER CONTACT: 4 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.6 INSULATION RESISTANCE: 5000 MOHM MIN 2-Hole Flange Mount Plug Receptacle Part Number Material Impedance 147-0801-601 Stainless Steel/Passivated 50 Ohms 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX PACKAGING MODEL NO. 3.2 COUPLING PROOF TORQUE: 1.65 NM MIN 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN ONE PER BAG 147-0801-601 3.4 CONTACT RETENTION: 20PCS N MIN 3.5 DURABILITY: 500 CYCLES REV 001 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:58:04 +08'00' Maximum Frequency VSWR 50GHz Typical VSWR 1.20 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. Title: Cage Code 2011/65/EU 3RD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v 11 Johnson 147-0801-601 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. ECO ECO-17-0032 PANEL RECEPTACLE PLUG, ACCEPTS 0.305mm PIN,2.4mm Drawing No. Drawn by: 147-0801-601 Betty.Yu Date: Size C 10/19/2017 DO NOT SCALE DRAWING Workmanship Std: NONE O .102 +.004 X2 0 M7 X P0.75-6H ACCEPT O .0120 PIN .481 O .626 LASER MARK: "1470801601" .315 HEX .065 NOTES: UNLESS OTHERWISE SPECIFIED 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENER CONTACT: 4 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.6 INSULATION RESISTANCE: 5000 MOHM MIN 4-Hole Flange Mount Jack and Plug Receptacle Part Number Material Impedance 147-0701-611 Stainless Steel/Passivated 50 Ohms 147-0801-611 Stainless Steel/Passivated 50 Ohms .224 .004 .504 REF 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 C RING: BERYLLIUM COPPER 1.5 LOCK RING: GOLD PLATED BRASS 1.6 GASKET: SILICONE RED 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65 NM MIN 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES Maximum Frequency MODEL NO. 147-0701-611 VSWR PACKAGING REV 001 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:56:39 +08'00' 50GHz 1.20 50GHz 1.20 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. ONE PCS PER BAG TEMPERATURE: -55 TO 125°C 4.2 OPERATING 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. Title: Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/65/EU 3RD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED UNITS: INCH INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. ECO ECO-17-0032 .XXX u.02 .XXXX u.01 ANGLES u5v DA 11/28 Johnson 147-0801-601 PANEL RECEPTACLE PLUG, 2 HO ACCEPTS 0.305mm PIN,2.4mm Drawing No. Drawn by: 147-0801-601 Betty.Yu Date: 10/19/2017 Size C DO NOT SCALE DRAWING Workmanship Std: S NONE X4 O .102 +.004 0 LASER MARK: "1470701611" M7 X P0.75-6g ACCEPT O .0120 PIN .340 MODEL NO. 147-0801-611 PACKAGING 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:58:30 +08'00' REV 001 ECO ECO-17-0032 DATE 11/28/2017 ONE PCS PER BAG .065 .004 .340 .451 .500 SQ O .102 +.004 X4 0 NOTES: UNLESS OTHERWISE SPECIFIED M7 X P0.75-6H 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 LOCK RING: GOLD PLATED BRASS ACCEPT O .0120 PIN 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENER CONTACT: 4 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.6 INSULATION 5000 MOHM MIN LASER MARK:RESISTANCE: "1470801611" 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23NM MAX 3.2 CONTACT RETENTION: 20 N MIN 3.3 DURABILITY: 500 CYCLES MIN 20 .340 .315 HEX 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. .504 REF 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I NOTES:4.5 UNLESS OTHERWISE SPECIFIED VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 C RING: BERYLLIUM COPPER 1.5 LOCK RING: GOLD PLATED BRASS 1.6 GASKET: SILICONE RED 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENER CONTACT: 4 MILLIOHM MAX .065 .004 .340 .500 SQ Model No. 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v Johnson 147-0701-611 Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. Title: 3RD ANGLE PROJECTION PANEL RECEPTACLE JACK,4 HOLE FL ACCEPTS 0.305mm PIN, 2.4mm Drawing No. Drawn by: Date: Betty.Yu 10/19/2017 147-0701-611 Size C DO NOT SCALE DRAWING Workmanship Std: NONE Shee 2.4mm Same Series Adapters MODEL NO. Plug to Plug Same Series Adapter 147-0901-811 PACKAGING REV 001 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:59:42 +08'00' E ECO ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 147-0801-201 Stainless Steel/Passivated 50 Ohms 50GHz Typical VSWR 1.20-1.25 .641 M7 X P0.75-6H M7 X P0.75-6H LASER MARK:"1470901811" .315 HEX .274 A/F .315 HEX .791 REF Plug to Jack Same Series Adapter MODEL NO. PACKAGING REV 001 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:59:20 +08'00' NOTES: UNLESS OTHERWISE SPECIFIED ONE PCS PER BAG 147-0901-801 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED Part Number Material Impedance Maximum Frequency VSWR 147-0901-801 Stainless Steel/Passivated 50 Ohms 50GHz 1.20 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 500 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 4 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 2.7 INSERTION LOSS: 0.05 X F(GHZ) DB MAX DATE 11/28/2017 M7 X P0.75-6g .641 M7 X P0.75-6H ECO ECO-17-0032 3. MECHANICAL: 3.1 ENGAGEMENT FORCE/DISENGAGEMENT FORCE: 0.23NM MAX 3.2 COUPLING PROOF TORQUE: 1.65 NM MIN 3.3 COUPLING NUT RETENTION: 267 N MIN 3.4 CONTACT RETENTION: 20N MIN 3.5 DURABILITY (MATING): 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. 147-0901-811 .315 HEX .274 A/F INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. Title: Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/65/EU 3RD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v Joh ADAPTER ASSE PLUG,2.4mm Drawing No. Drawn by: Date: 147-0901- Betty.Yu Size C 10/19/2017 Workma DO NOT SCALE DRAWING N LASER MARK: "1470901801" .836 REF Jack to Jack Same Series Adapter NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL PACKAGING MODEL NO. 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 14:00:06 +08'00' REV 001 ECO ECO-17-003 1.3 INSULATOR: ULTEM 1000 AMBER COPPER ONE BERYLLIUM PCS PER BAG 147-0901-821 1.4 C RING: 1.5 GASKET: SILICONE RED Part Number Material Impedance Maximum Frequency VSWR 147-0901-821 Stainless Steel/Passivated 50 Ohms 50GHz Typical VSWR 1.20 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENER CONTACT: 4 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 2.7 INSERTION LOSS: 0.05 X F(GHZ) DB MAX 2.8 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23NM MAX 3.2 COUPLING PROOF TORQUE: 1.65 NM 3.3 COUPLING NUT RETENTION: 267 N MIN 3.4 CONTACT RETENTION: 20N MIN 3.5 DURABILITY (MATING): 500 CYCLES MIN M7 X P0.75-6g M7 X P0.75-6g .641 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. LASER MARK:"1470901821" Johnson 147-0901-801 Title: Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2011/65/EU 3RD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v ADAPTER ASSEMBLY, PLUG TO JACK, 2.4mm Drawing No. Drawn by: Date: Size C DO NOT SCALE DRAWING Workmanship Std: NONE Rev. 001 147-0901-801 Betty.Yu 10/19/2017 Sheet 1 of 1 .274 A/F .881 Right Angle Jack to Jack Same Series Adapter NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER PACKAGING MODEL NO. 1.3 INSULATOR: ULTEM 1000 AMBER Part Number Material Impedance Maximum Frequency VSWR 147-0901-901 Stainless Steel/Passivated 50 Ohms 50GHz Typical VSWR 1.20 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20 N MIN 3.3 DURABILITY (MATING): 500 CYCLES MIN Model No. 147-0901-821 Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v .600 M7 X P0.75-6g .445 M7 X P0.75-6g 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 500 VRMS MIN 1 LASER MARK: "1470901901" INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER ECO ECO-17-0032 .600 .445 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 NOTES: UNLESS OTHERWISE SPECIFIED REV 001 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 14:00:29 +08'00' ONE PCS PER BAG 147-0901-901 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 CONTACT RESISTANCE: 2.4.1 CENER CONTACT: 4 MILLIOHM MAX 2.4.2 OUTER CONTACT: 2.5 MILLIOHM MAX 2.5 INSULATOR RESISTANCE: 5000 MEGOHM MIN 2.6 INSERTION LOSS: 0.05 X F(GHZ) DB MAX 2.7 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 21 Title: 3RD ANGLE PROJECTION Johnso ADAPTER ASSEMBLY JACK, 2.4mm Drawing No. Drawn by: Date: Betty.Yu 10/19/2017 147-0901-821 Size C DO NOT SCALE DRAWING Workmanship Std NONE 2.4mm Between Series Adapters Between Series, 2.4mm Jack to 2.92mm Jack MODEL NO. Part Number Material Impedance 134-1000-008 Stainless Steel/Passivated 50 Ohms 134-1000-008 PACKAGING Maximum Frequency VSWR 40GHz DC - 4GHz 4 - 20GHz 20 - 40GHz ONE PCS PER BAG 1.05 1.08 1.15 .641 M7 X P0.75-6g 1/4-36UNS-2A LASER MARK:"1341000008" .274 A/F .837 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER Between Series, 2.4mm Jack to 2.92mm Plug 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-46 GHz 2.3 INSERTION LOSS: 0.3DB MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN MODEL 2.5NO. VOLTAGE PACKAGING STANDING WAVE RATIO: DC- 4 GHZ: 1.05 MAX 4 -20 GHZ: 1.08 MAX 20-46 GHZ: 1.15 MAX ONE PCS PER BAG 134-1000-009 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTERR CONTACT: 2.5 MILLIOHMS MAX 2.7 INSULATION RESISTANCE: 5000 MOHM MIN Part Number Material Impedance 134-1000-009 Stainless Steel/Passivated 50 Ohms Maximum Frequency VSWR 40GHz DC - 4GHz 4 - 20GHz 20 - 40GHz 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 CONTACT RETENTION: 20 N MIN 3.3 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 1.05 1.08 1.15 .641 Model No RoHS M7 X P0.75-6g 1/4-36UNS-2B LASER MARK:"1341000009" This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. .274 A/F 2011/ UNLESS OTHER UNIT INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. .XXX .XXXX ANGL .315 HEX .865 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER Between Series, 2.4mm Plug to 2.92mm Jack Part Number Material Impedance 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS Maximum Frequency VSWR PACKAGING MODEL2.2 NO.FREQUENCY RANGE: 0-46 GHz 2.3 INSERTION LOSS: 0.3DB MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN ONE PCS PER BAG 134-1000-010 2.5 VOLTAGE STANDING WAVE RATIO: 134-1000-010 Stainless Steel/Passivated 50 Ohms DC- 4 GHZ: 1.05 MAX 4 -20 GHZ: 1.08 MAX 20-46 GHZ: 1.15 MAX 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTERR CONTACT: 2.5 MILLIOHMS MAX 2.7 INSULATION RESISTANCE: 5000 MOHM MIN DC - 4GHz 4 - 20GHz 20 - 40GHz 40GHz 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.7NM MIN (SMK) 3.3 COUPLING NUT RETENTION FORCE: 267 N MIN 3.4 CONTACT RETENTION: 20 N MIN 3.5 DURABILITY: 500 CYCLES MIN 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 14:01:54 +08'00' 1.05 1.08 1.15 LASER MARK:"1341000010" 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C M7B X P0.75-6H 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .641 1/4-36UNS-2A Model No. 134 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. .315 HEX 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v D D .274 A/F .792 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-46 GHz 2.3 INSERTION LOSS: 0.3DB MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.5 VOLTAGE STANDING WAVE RATIO: DC- 4 GHZ: 1.05 MAX 4 -20 GHZ: 1.08 MAX 20-46 GHZ: 1.15 MAX 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTERR CONTACT: 2.5 MILLIOHMS MAX 2.7 INSULATION RESISTANCE: 5000 MOHM MIN 22 3. MECHANICAL: 3.1 ENGAGEMENT FORCE/DISENGAGEMENT FORCE: 0.23NM MAX 3.2 COUPLING PROOF TORQUE: 1.65 NM MIN (2.4MM) 3.3 COUPLING NUT RETENTION: 267 N MIN 3.4 CONTACT RETENTION: 20N MIN 3.5 DURABILITY (MATING): 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I Model No. RoHS2 134-1000-010 Cage Code Title: AD 2.4mm Between Series, 2.4mm Plug to 2.92mm Plug MODEL NO. PACKAGING PACKAGING MODEL NO. 134-1000-011 MODEL NO. ONE PCS PER BAG PACKAGING 134-1000-011 134-1000-011 ONE PCS PER BAG ONE PCS PER BAG Part Number Material Impedance 134-1000-0011 Stainless Steel/Passivated 50 Ohms Maximum Frequency VSWR 40GHz DC - 4GHz 4 - 20GHz 20 - 40GHz 1.05 1.08 1.15 .641 M7 X P0.75-6H 1/4-36UNS-2B .641 .641 M7 X P0.75-6H M7 X P0.75-6H 1/4-36UNS-2B 1/4-36UNS-2B LASER MARK:"1341000011" .315 HEX .315 HEX .315 HEX MODEL NO. Between Series, 2.4mm Jack To SMP Female MODEL NO. 134-1000-012 MODEL NO. 134-1000-012 134-1000-012 .274 A/F .315 HEX .274 A/F .274 A/F .315 HEX .315 HEX .820 REF .820 REF .820 REF PACKAGING NOTES: UNLESS OTHERWISE SPECIFIED PACKAGING ONE PCS PER BAG PACKAGING NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: NOTES: UNLESS OTHERWISE SPECIFIED 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL ONE PCS PER BAG 1. MATERIAL & FINISH: CONTACT PIN : GOLD PLATED BERYLLIUM COPPER ONE PCS 1.2 PER BAG 1.1 &&SHELL: PASSIVATED STAINLESS STEEL 1. MATERIAL FINISH: 1.3 BODY INSULATOR: ULTEM 1000 AMBER 1.2 CONTACT PIN : PASSIVATED GOLD PLATED BERYLLIUM COPPER 1.1 & SHELL: STAINLESS STEEL 1.4 BODY GASKET: SILICONE RED 1.3 ULTEM 1000 AMBER 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.5 INSULATOR: C RING: BERYLLIUM COPPER 1.4 INSULATOR: GASKET: SILICONE 1.3 ULTEMRED 1000 AMBER 1.5 GASKET: C RING: BERYLLIUM COPPER 1.4 SILICONE RED 2. ELECTRICAL: 1.5 IMPEDANCE: C RING: BERYLLIUM COPPER 2.1 50 OHMS 2. ELECTRICAL: 2.2 FREQUENCY RANGE: 0-46 GHz 2.1 INSERTION IMPEDANCE:LOSS: 50 OHMS 2. ELECTRICAL: 2.3 0.3DB MAX 2.2 DIELECTRIC FREQUENCYWITHSTANDING RANGE: 2.1 IMPEDANCE: 50 OHMS0-46 GHz 2.4 VOLTAGE: 500 VRMS MIN 2.3 INSERTION LOSS: 0.3DB MAX 2.2 VOLTAGE FREQUENCY RANGE: 0-46 GHz 2.5 STANDING WAVE RATIO: DC- 4 GHZ: 1.05 MAX 2.4 INSERTION DIELECTRICLOSS: WITHSTANDING 500GHZ: VRMS MIN 2.3 0.3DB MAX VOLTAGE: 4 -20 1.08 MAX 2.5 STANDING WAVE RATIO: DC-500 4 GHZ: 1.05 2.4 VOLTAGE DIELECTRIC WITHSTANDING VOLTAGE: VRMS MIN 20-46 1.15 MAX 4 -204GHZ: 1.08 2.5 WAVE RATIO: DCGHZ: 1.05MAX MAX MAX 2.6 VOLTAGE CONTACT STANDING RESISTANCE: CENTER CONTACT: 4 MILLIOHMS 20-46 GHZ: 1.15MAX MAX MAX 4 -20 GHZ: OUTERR CONTACT: 2.5 1.08 MILLIOHMS 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS 20-46 2.7 INSULATION RESISTANCE: 5000 MOHM MINGHZ: 1.15 MAX MAX MILLIOHMS MAX 2.6 CONTACT RESISTANCE: OUTERR CENTER CONTACT: 42.5 MILLIOHMS MAX 2.7 INSULATION RESISTANCE: 5000 MOHM MIN OUTERR CONTACT: 2.5 MILLIOHMS MAX 3. MECHANICAL: M7 X P0.75-6H 2.7ENGAGEMENT INSULATION RESISTANCE: 5000 MOHM MIN 3.1 FORCE/DISENGAGEMENT FORCE: 0.23NM MAX M7 X (2.4MM), P0.75-6H 3.3.2 MECHANICAL: COUPLING PROOF TORQUE: 1.65 NM MIN 1.7 NM MIN (SMK) ENGAGEMENT 0.23NM MAX P0.75-6H 3.3.1 MECHANICAL: 3.3 COUPLING NUTFORCE/DISENGAGEMENT RETENTION: 267 N M7 MIN X FORCE: 3.2 CONTACT COUPLING PROOF TORQUE: 1.65 NM MIN FORCE: (2.4MM),0.23NM 1.7 NM MAX MIN (SMK) 3.1 ENGAGEMENT FORCE/DISENGAGEMENT 3.4 RETENTION: 20N MIN 3.3 NUT RETENTION: 267 NNM MIN 3.2 TORQUE: 1.65 MIN (2.4MM), 1.7 NM MIN (SMK) 3.5 COUPLING DURABILITYPROOF (MATING): 500 CYCLES MIN 3.4 20N MIN 3.3 CONTACT COUPLINGRETENTION: NUT RETENTION: 267 N MIN 3.5 DURABILITY (MATING): 500 MIN CONTACT RETENTION: 20NCYCLES MIN 4.3.4 ENVIRONMENT: 3.5 DURABILITY (MATING): 500 CYCLES MIN 107, CONDITION B. 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 4.4.2 ENVIRONMENT: OPERATING TEMPERATURE: -55 TO 125°C 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.4.3 ENVIRONMENT: SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.2 TEMPERATURE: -55213, TO CONDITION 125°C107, CONDITION 4.1 THERMAL SHOCK: MIL-STD-202, METHOD B. 4.4 OPERATING SHOCK: MIL-STD-202, METHOD I 4.3 SALT SPRAY:MIL-STD-202, MIL-STD-202,METHOD METHOD 101,CONDITION CONDITIOND B 4.2 TEMPERATURE: -55 TO204, 125°C 4.5 OPERATING VIBRATION: 4.4 SALT SHOCK: MIL-STD-202, METHOD 213, CONDITION I106 B 4.3 SPRAY: MIL-STD-202, METHOD 101, CONDITION 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 4.5 MIL-STD-202, METHOD CONDITION D 4.4 VIBRATION: SHOCK: MIL-STD-202, METHOD 213,204, CONDITION I 4.6 VIBRATION: MOISTURE RESISTANCE: 106D 4.5 MIL-STD-202, MIL-STD-202, METHOD 204,METHOD CONDITION 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 R 0 R 0 RE 00 Part Number Material Impedance Maximum Frequency VSWR 134-1000-012 Stainless Steel/Passivated 50 Ohms 40GHz 1.25 Part Number Material 134-1000-013 Stainless Steel/Passivated LASER MARK P/N AND DATE CODE AS BELOW: 134-1000-012 LASER MARK P/N AND DATE CODE AS BELOW: YYWW LASER MARK P/N AND DATE CODE AS BELOW: 134-1000-012 134-1000-012 YYWW YYWW 1/4-36UNS-2A 1/4-36UNS-2A 1/4-36UNS-2A .641 .641 .641 Model No. 134-1000 C RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. This PROPRIETARY Document isINTERPRET property of Cinch Connectivity DRAWING IN Solutions. It is confidential in ACCORDANCE WITH ASME nature, non-transferable, and Y14.5-2009. issued with the clear understanding that Document it is not This PROPRIETARY traced or without is property of copied Cinch Connectivity permissionItand is returnable Solutions. is confidential in demand. nature, upon non-transferable, and issued with the clear INTERPRET understandingDRAWING that it is notIN traced or copied without ACCORDANCE WITH ASME permission and is returnable Y14.5-2009. upon demand. Model No. 2011/65/EU 134-1000 C Drawn by: RoHS2 .XXX u.02 134-1000 BC 2011/65/EU .XXXX u.01 Date: RoHS2 ANGLES u5v by: 2011/65/EU Drawn10/2 3RD ANG UNLESS OTHERWISE SPECIFIED Model UNITS: No.INCH 3RD ANG UNLESS OTHERWISE SPECIFIED UNITS: INCH 3RD ANG B .XXX u.02 .XXXX u.01 ANGLES u5v .XXX u.02 .XXXX .01 UNLESS OTHERWISE SPECIFIED UNITS: INCH INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. Drawn Date: by: B 10/2 u Date: ANGLES u5v 10/2 .274 A/F .274 A/F .274 A/F .792 REF .792 REF .792 REF .315 HEX .315 HEX .315 HEX Between Series, 2.4mm Jack To SMP Female LASER MARK:"1341000011" LASER MARK:"1341000011" REV 001 REV 001 PACKAGING MODEL NO. NOTES: UNLESS OTHERWISE SPECIFIED PACKAGING MODEL NO. NOTES: UNLESS OTHERWISE SPECIFIED ONE PCS PER BAG 134-1000-013 1. MATERIAL & FINISH: NOTES: UNLESS OTHERWISE SPECIFIED 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL ONE PCS PER BAG 134-1000-013 1. MATERIAL & FINISH: 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.1 BODY && SHELL: PASSIVATED STAINLESS STEEL 1. MATERIAL FINISH: 1.3 INSULATOR: ULTEM 1000 AMBER 1.2BODY CONTACT PIN : PASSIVATED GOLD PLATED BERYLLIUM COPPER 1.1 & SHELL: STAINLESS STEEL 1.4 GASKET: SILICONE RED 1.3CONTACT INSULATOR: ULTEM 1000 AMBER 1.2 PIN : GOLD PLATED 1.5 C RING: BERYLLIUM COPPER BERYLLIUM COPPER 1.4INSULATOR: GASKET: SILICONE 1.3 ULTEM RED 1000 AMBER 1.5GASKET: C RING: BERYLLIUM COPPER SILICONE RED 2.1.4 ELECTRICAL: 1.5 RING: BERYLLIUM COPPER 2.1CIMPEDANCE: 50 OHMS 2. ELECTRICAL: 2.2 FREQUENCY RANGE: 0-46 GHz 2.1 IMPEDANCE: 50 OHMS 2. ELECTRICAL: 2.3 INSERTION LOSS: 0.3DB MAX 2.2 FREQUENCY50 RANGE: 2.1 OHMS0-46 GHz 2.4IMPEDANCE: DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.3FREQUENCY INSERTION LOSS: 0.3DB MAX 2.2 RANGE: GHz 2.5 VOLTAGE STANDING 0-46 WAVE RATIO: DC- 4 GHZ: 1.05 MAX 2.4INSERTION DIELECTRICLOSS: WITHSTANDING 500 VRMS MIN 2.3 0.3DB MAX VOLTAGE: 4 -20 GHZ: 1.08 MAX 2.5DIELECTRIC VOLTAGE STANDING WAVE RATIO: DC4 GHZ: 1.05 MAX 2.4 WITHSTANDING VOLTAGE: 500 VRMS1.15 MINMAX 20-46 GHZ: 4 -20 1.08 2.5 WAVE RATIO:CONTACT: DC4 GHZ: 1.05 MAX MAX 2.6VOLTAGE CONTACTSTANDING RESISTANCE: CENTER 4 MILLIOHMS GHZ:1.08 1.15MAX MAX 420-46 -20 GHZ: OUTERR CONTACT: 2.5 MILLIOHMS MAX 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS 20-46 GHZ: 1.15 MAX MAXM7 X P0.75-6H OUTERRCONTACT: CONTACT:42.5 MILLIOHMS MAX CONTACT RESISTANCE: CENTER MILLIOHMS MAX 3.2.6 MECHANICAL: M7 X P0.75-6H OUTERR CONTACT: 2.5 MILLIOHMS MAX 3.1 COUPLING PROOF TORQUE: 1.65 NM MIN (2.4MM) 3. MECHANICAL: 3.1 COUPLING PROOF TORQUE: 1.65 NM MIN (2.4MM) 3. 4.MECHANICAL: ENVIRONMENT: 3.1 COUPLING PROOF TORQUE: 1.65 NM MIN (2.4MM) 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4. ENVIRONMENT: 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4. ENVIRONMENT: 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.2THERMAL OPERATING TEMPERATURE: -55METHOD TO 125°C107, CONDITION B. 4.1 SHOCK: MIL-STD-202, 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.3OPERATING SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.2 TEMPERATURE: -55 TO 125°C 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.4SALT SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.3 SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.5SHOCK: VIBRATION: MIL-STD-202, METHOD CONDITION D 4.4 MIL-STD-202, METHOD 213, 204, CONDITION I 4.6VIBRATION: MOISTURE RESISTANCE: MIL-STD-202, 106D 4.5 MIL-STD-202, METHOD 204, METHOD CONDITION 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Impedance Maximum Frequency VSWR 50 Ohms 40GHz 1.25 .641 1/4-36UNS-2B Model No. 134-1000-012 Title: Cage Code RoHS2 Model No. 3RD ANGLE PROJECTION 2011/65/EU 134-1000-012 This PROPRIETARY Document is property of Cinch Connectivity UNLESS OTHERWISE SPECIFIED Solutions. It is confidential in Cage Code UNITS: INCH nature, non-transferable, and issued with the clear Drawn by: understanding that it is not traced or copied without 3RD Cage ANGLECode PROJECTION permission and is returnable This PROPRIETARY Document upon demand. is property of Cinch Connectivity UNLESS OTHERWISE SPECIFIED Solutions. It is confidential in INTERPRET DRAWING IN Date: UNITS: INCH nature, non-transferable, and ACCORDANCE WITH issued with the clearASME 3RD ANGLE PROJECTION Drawn by: Y14.5-2009. This PROPRIETARY Document understanding that it is not traced copied without is property of or Cinch Connectivity UNLESS OTHERWISE SPECIFIED permission is returnable Solutions. It is and confidential in UNITS: INCH nature, non-transferable, upon demand. and issued with the clear Drawn understanding it is not IN INTERPRETthat DRAWING Date:by: traced or copied WITH withoutASME ACCORDANCE permissionY14.5-2009. and is returnable upon demand. Model No. RoHS2 134-1000-012 2011/65/EU .XXX u.02 Betty.Yu RoHS2 .XXXX u.01 ANGLES u5v 10/27/2017 CODE2011/65/EU AS BELOW: .XXX u.02 .315 HEX .315 HEX MODEL NO. 1/4-36UNS-2B .641 .274 A/F LASER MARK P/N AND DATE Betty.Yu .XXXX u.01 ANGLES 134-1000-013 .XXX u.02u5v Betty.Yu 10/27/2017 LASER MARK P/N AND DATE CODE.XXXX ASu.01BELOW: ANGLES u5v YYWW 10/27/2017 134-1000-013 C ADAPTE DRAW1 Drawing No. Size C Size Date: INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. .315 HEX .274 A/F 2.4 MM ADAPT 2.4 MM Title: Drawing No. Title: ADAPT1 2.4No. MM P Size Drawing DO NOT S C DO NOT1S DRAW DO NOT SC DRAWIN YYWW .315 HEX .820 REF PACKAGING .820 REF NOTES: UNLESS OTHERWISE SPECIFIED ONE PCS PER BAG 134-1000-014 Between Series, 2.4mm Plug To SMP Female NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1. MATERIAL & FINISH: 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.1 & SHELL: PASSIVATED STAINLESS STEEL 1.3 BODY INSULATOR: ULTEM 1000 AMBER 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.4 GASKET: SILICONE RED 1.3 C INSULATOR: ULTEM 1000 AMBER 1.5 RING: BERYLLIUM COPPER 1.4 GASKET: SILICONE RED 1.5 C RING: BERYLLIUM COPPER 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2. ELECTRICAL: 2.2 FREQUENCY RANGE: 0-46 GHz 2.1 50 OHMS 2.3 IMPEDANCE: INSERTION LOSS: 0.3DB MAX 2.2 RANGE: 0-46 GHz 2.4 FREQUENCY DIELECTRIC WITHSTANDING VOLTAGE: 500 VRMS MIN 2.3 VOLTAGE INSERTIONSTANDING LOSS: 0.3DB MAXRATIO: DC- 4 GHZ: 1.05 MAX 2.5 WAVE 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 500GHZ: VRMS MIN 4 -20 1.08 MAX 2.5 VOLTAGE STANDING WAVE RATIO: 20-46 DC- 4 GHZ: GHZ: 1.15 1.05 MAX MAX 4 -20 GHZ: 1.08 MAX MAX 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS 20-46 GHZ: 1.15 MAX MAX OUTERR CONTACT: 2.5 MILLIOHMS 2.6 CONTACT RESISTANCE: CENTER CONTACT: 4 MILLIOHMS MAX OUTERR CONTACT: 2.5 MILLIOHMS MAX 3. MECHANICAL: Part Number Material Impedance Maximum Frequency VSWR 134-1000-014 Stainless Steel/Passivated 50 Ohms 40GHz 1.25 3.1 COUPLING PROOF TORQUE: 1.65 NM MIN (2.4MM); 1.7NM MIN (2.92MM) 3. MECHANICAL: COUPLING PROOF TORQUE: 1.65 NM MIN (2.4MM); 1.7NM MIN (2.92MM) 4.3.1 ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.4.2 ENVIRONMENT: OPERATING TEMPERATURE: -55 TO 125°C 4.1 SALT THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.3 SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.2 OPERATING TEMPERATURE: -55213, TO CONDITION 125°C 4.4 SHOCK: MIL-STD-202, METHOD I 4.3 SPRAY:MIL-STD-202, MIL-STD-202, METHOD 101,CONDITION CONDITION 4.5 SALT VIBRATION: METHOD 204, DB 4.4 MIL-STD-202, METHOD 213, CONDITION 4.6 SHOCK: MOISTURE RESISTANCE: MIL-STD-202, METHODI106 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .543 M7 X P0.75-6H Model No. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. LASER MARK P/N AND DATE CODE AS BELOW: 134-1000-014 YYWW .315 HEX RoHS2 .XXXX u.01 ANGLES u5v UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v .236 A/F .618 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN & CONTACT BODY: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.4 C RING: BERYLLIUM COPPER Cage Code 3RD ANGLE PROJECTION 2011/65/EU 134-1000-013 UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 2011/65/EU 23 J 134-1000-013 RoHS2 Model No. This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is DRAWING confidential in INTERPRET IN nature, non-transferable, and ACCORDANCE WITH ASME issued with the clear Y14.5-2009. understanding that it is not traced or copied without permission and is returnable upon demand. O .276 Cage Code Drawn by: Betty.Yu Title: 10/27/2017 Drawn by: Date: Betty.Yu 10/27/2017 2.4 MM PLU ADAPTERJ Drawing No. Title: 2.4 MM PLU 134-1 ADAPTER 3RD ANGLE PROJECTION Date: Size Drawing No. C Size C DO NOT SCALE DRAWING 134-1 DO NOT SCALE DRAWING 2.4mm upon demand. permission and is returnable traced or copied without understanding that it is not issued with the clear nature, non-transferable, and Solutions. It is confidential in is property of Cinch Connectivity This PROPRIETARY Document 1 ANGLES u5v .XXXX u.01 .XXX u.02 Y14.5-2009. ACCORDANCE WITH ASME INTERPRET DRAWING IN Date: Draw UNITS: INCH UNLESS OTHERWISE SPECIFIED 2011/65/EU 3R RoHS2 134-10 Model No. 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4. ENVIRONMENT: 3.3 DURABILITY: 500 CYCLES MIN 3.2 COTNACT RETENTION: 7 N MIN 3.1 FORCE TO ENGAGE / DISENGAGE: 45 N MAX (SMP) / 9 N MAX (SMP) 3. MECHANICAL: Between Series, 2.4mm Plug To SMP Male (Limited Detent) OUTERR CONTACT: 2.5 MILLIOHMS MAX 2.4 CONTACT RESISTANCE: CENTER CONTACT: 6 MILLIOHMS MAX 2.3 RETURN LOSS: -20DB MAX 2.2 FREQUENCY RANGE: 0-40 GHz 2.1 IMPEDANCE: 50 OHMS 2. ELECTRICAL: Part Number Material Impedance Maximum Frequency VSWR 134-1000-015 Stainless Steel/Passivated 50 Ohms 40GHz 1.25 1.5 GASKET: SILICONE RED 1.4 C RING: BERYLLIUM COPPER 1.3 INSULATOR: ULTEM 1000 AMBER 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1. MATERIAL & FINISH: NOTES: UNLESS OTHERWISE SPECIFIED .731 REF .315 HEX YYWW 134-1000-015 LASER MARK P/N AND DATE CODE AS BELOW: .236 A/F O .276 M7 X P0.75-6H .543 Terminations 134-1000-015 MODEL NO. Termination Jack (1/4 Watts) Same Series MODEL NO. 147-0701-801 ONE PCS PER BAG PACKAGING PACKAGING 数字签名人 lin.ma@cn.cinch. com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:57:06 +08'00' R 0 ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 147-0701-801 Stainless Steel/Passivated 50 Ohms 50GHz 1.30 LASER MARK:"1470701801" M7 X P0.75-6g O .354 .272 A/F .309 A/F .831 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY, BOLT & NUT: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PEEK NATURAL BODY: GOLD PLATED BRASS PACKAGING MODEL1.4 NO. 1.5 RESISTOR: 50 OHMS u1% 1/4 W Termination Plug (1/4 Watts) Same Series 2. ELECTRICAL:ONE PCS PER BAG 147-0801-801 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 RETURN LOSS: -20DB MAX Part Number Material Impedance Maximum Frequency VSWR 147-0801-801 Stainless Steel/Passivated 50 Ohms 50GHz 1.30 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23NM MAX 3.2 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 LASER MARK:"1470801801" M7 X P0.75-6H Model No. 147-0701-801 2011/65/EU 3RD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v Title: Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. TERM OHMS Drawing No. Drawn by: Date: Betty.Yu Size C 10/19/2017 DO NOT DRA O .354 .315 HEX .309 A/F .272 A/F .787 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY, BOLT, SHELL & NUT: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PEEK NATURAL 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED 1.6 RESISTOR: 50 OHMS u1% 1/4 W 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-50 GHz 2.3 RETURN LOSS: -20DB MAX 3. MECHANICAL: 3.1 ENGAGEMENT/ DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING PROOF TORQUE: 1.65 NM MIN 3.3 COUPLING NUT RETENTION: 267 N MIN 3.4 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. 24 147-0801-801 Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v 3RD ANGLE PROJECTION Drawn by: Date: Betty.Yu 10/19/2017 2.92mm Product Specifications The Johnson 2.92mm Series Connector provides an excellent solution for demanding applications requiring high frequency transmission. 2.92mm connectors have a smaller internal body diameter than SMA, utilizing an air dielectric. • • • • • • • • Precision manufactured for superior electrical performance to 40GHz Connector mating interface per IEC 61169-35, and intermateable with 3.5mm and SMA connectors Female contacts in Jack connectors, have a unique three-slot construction, which enhances connectivity by creating a more rugged connector while reducing the chance of intermittent connections The field replaceable jacks are teamed with a high quality hermetic seal feed thru for use in sealed circuit modules The plug connector VSWR is 1.20 maximum to 40GHz and a 12 inch 2.92mm plug to plug cable assembly performs better than 1.35 VSWR to 40GHz The 2.92mm plug interface employs more precise dimensions than an SMA and uses a shorter snub nose male pin such that the connector bodies align before the contacts engage Precise assembly tooling assures excellent, repeatable contact and support bead location on cabled connectors Available in screw on type and solder type end launch, 2 hole and 4 hole flange mount styles Materials Bodies Stainless steel/passivated per QQ-B-626, gold plated per MIL-G-45204 0.00005in mininum or stainless steel/passivated per MIL-F-14072 B (EL) 300 Contacts Female - beryllium copper per QQ-C-530, gold plated per MIL-G-45204 0.00005in minimum Contact Support Beads PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457 or modified PPE resin Seal Rings Silicone rubber per A-A-59588 Environmental (Meets of exceeds the applicable paragraph of MIL-C-39012 [S/S BY MIL-PRF-39012D] Temperature Range -85ºF to +329ºF (-65ºC to +165ºC) Thermal Shock MIL-STD-202, Method 107, Condition B Corrosion MIL-STD-202, Method 101, Condition B Shock MIL-STD-202, Method 213, Condition I Vibration MIL-STD-202, Method 204, Condition D Moisture Resistance MIL-STD-202, Method 106 Dielectric Withstanding Voltage 0.086 Semi-Rigid and Field Replaceable 0.141 Semi-Rigid and Adapters 1000 (VRMS minimum at sea level) 500 (VRMS minimum at sea level) Corona Level 0.086 Semi-Rigid and Field Replaceable 0.141 Semi-Rigid and Adapters 250 (volts minimum at 70,000 feet) 375 (volts minimum at 70,000 feet) Insertion Loss Adapters Straight Semi-Rigid Cable Connectors 0.06 x 0.03 x f (GHz), tested at 6GHz (dB maximum) f (GHz), tested at 10GHz (dB maximum) Insulation Resistance 5,000 megohms minimum Contact Resistance Initial 3.0 (milliohms maximum) 4.0 (milliohms maximum) 6.0 (milliohms maximum) 2.0 (milliohms maximum) 0.5 (milliohms maximum) 5.0 (milliohms maximum) Center Contact Straight Cabled Connectors Center Contact Adapters Field Replaceable Connectors Outer Contact (all connectors) Body to Cable (gold plated connectors) Body to Cable (passivated connectors) RF Leakage After Environmental 4.0 (milliohms maximum) 6.0 (milliohms maximum) 8.0 (milliohms maximum) n/a (milliohms maximum) n/a (milliohms maximum) n/a (milliohms maximum) -90 dB (dB minimum, tested at 2.5GHz) RF High Potential Withstanding Voltage 0.086 Semi-Rigid and Field Replaceable 0.141 Semi-Rigid and Adapters 670 (VRMS minimum tested at 4 and 7MHz) 1000 (VRMS minimum tested at 4 and 7MHz) 25 2.92mm Mechanical Engagement Design MIL-STD-348, series 2.92mm Engagement/Disengagement Force 2 inch-pounds maximum Mating Torque 7 to 10 inch-pounds Coupling Proof Torque 15 inch-pounds minimum Coupling Nut Retention 60 pounds minimum Contact Retention 6 pounds minimum axial force (captivated contacts) Cable Retention 0.086 Semi-Rigid 0.141 Semi-Rigid Axial Force (lbs) 30 60 Torque (in-oz) 16 55 Note: ID of female contact shall meet VSWR and connectivity requirements when mated with dia. 0.0355-0.0365 male pin *See typical return loss graph on next page Mating Engagement: 2.92mm Series per MIL-STD-348 For more information, please see the drawings on the Cinch website at belfuse.com/Cinch and search by part number. 26 2.92mm End Launch Connectors ITEM 1 BODY PART NUMBER ITEM 2 ITEM 3 CONTACT REV ECO DATE 1 1C ECO-18-0028 ECO-19-0032 12/24/2018 7/25/2019 INSULATOR 数字签名人 Lin Ma DN:cn=Lin Ma, c=CN, o=Cinch Connectivity Solutions (Shanghai) Co. Ltd, email=lin.ma@cn.cinch.com 日期:2019.07.25 14:48:39 +08'00' BRASS GOLD PL .00003 MIN OVER NICKEL PL.00005 MIN OVER COPPER 145-0701-821 BERYLLIUM COPPER GOLD PL .00005 MIN OVER NICKEL PL.00005 MIN OVER COPPER TEFLON .460 REF .095 Jack, 0.016” Board Thickness, Straddle Mount, Solder Type Part Number Material Impedance Maximum Frequency VSWR  .012 145-0701-821 Gold-Plated Brass 50 Ohms 40GHz 1.25 MAX DC-26.5GHz 1.5 MAX 26.5GHz-40GHz SPECIFICATION: 1/4-36 UNS-2A .215 ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-40 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 1000VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz .150 .030  .210 2 X .045 .019 ±.001 2 X R .023 MECHANICAL: ENGAGEMENT/DISENGAGEMENT FORCE: 2 INCH-POUNDS MAX ITEM 1 ITEM 2 MATING TORQUE: 7 TO 10 INCH-POUNDS PART NUMBER CONTACT BODY DURABILITY: 500 CYCLES MIN .310 ITEM 3 2 X .046 ECO REV  .295 INSULATOR 1 1A 数字签名人 Lin Ma DN:cn=Lin Ma, c=CN, o=Cinch Connectivity Solutions (Shanghai) Co. Ltd, email=lin. ma@cn.cinch.com 日期:2019.07.25 14:49:31 +08'00' BERYLLIUM COPPER BRASS ENVIRONMENTAL: GOLD PL .00005 MIN 145-0701-841 GOLD PL .00003 MIN OPERATING TEMPERATUR: -40 TO 85°C OVER NICKEL PL.00005 OVER NICKEL PL.00005 THERMAL SHOCK: MIL-STD-202, METHOD CONDITION MIN B OVER COPPER MIN OVER107, COPPER CORROSION: MIL-STD-202, METHOD 101, CONDITION B SHOCK: MIL-STD-202, METHOD 213, CONDITION I VIBRATION: MIL-STD-202, METHOD 204, CONDITION D MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106 TEFLON DATE ECO-19-0006 ECO-19-0032 2/26/2019 7/25/2019 .460 REF Jack, 0.062” Board Thickness, Straddle Mount, Solder Type   .095 SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009.   2011/65/EU SEE NOTE  JOHNSON 145-0701-821 RoHS2 UNLESS OTHERWISE SPECIFIED UNITS: INCH  .XX .01 .XXX .003 .XXXX .0010 ANGLES 100' 2.92mm END LAUNCH JACK FOR .016" BOARD     145-0701-821 R.SHEN   5/28/2018 1C DO NOT SCALE DRAWING B Sheet 1 of 1 Part Number Material Impedance Maximum Frequency VSWR 145-0701-841 Gold-Plated Brass 50 Ohms 40GHz 1.25 MAX DC-26.5GHz 1.5 MAX 26.5GHz-40GHz  .012 1/4-36 UNS-2A SPECIFICATION: .215 .150 ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-40 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 1000VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz .030  .210 .068 MECHANICAL: ENGAGEMENT/DISENGAGEMENT FORCE: 2 INCH-POUNDS MAX MATING 7 TO 10 INCH-POUNDS ITEM TORQUE: 1 ITEM 2 ITEM 3 DURABILITY: 500 CYCLES MIN CONTACT INSULATOR BODY PART NUMBER 145-0701-851 REV ECO DATE 1 1A ECO-19-0008 ECO-19-0032 3/28/2019 7/25/2019  .295 .310 数字签名人 Lin Ma DN:cn=Lin Ma, c=CN, o=Cinch Connectivity Solutions (Shanghai) Co. Ltd, email=lin.ma@cn.cinch.com 日期:2019.07.25 14:50:22 +08'00' ENVIRONMENTAL: BERYLLIUM COPPER TEFLON BRASS OPERATING TEMPERATUR: -40 TO 85°C GOLD PL .00005 MIN GOLD PL .00003 MIN THERMAL SHOCK: MIL-STD-202, METHOD 107,PL.00005 CONDITION B OVER NICKEL OVER NICKEL PL.00005 CORROSION: MIL-STD-202, METHOD 101, CONDITION MIN OVER COPPER B MIN OVER COPPER SHOCK: MIL-STD-202, METHOD 213, CONDITION I VIBRATION: MIL-STD-202, METHOD 204, CONDITION D MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106 .460 Jack, 0.042” Board Thickness, Straddle Mount, Solder Type .095   SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand.   2011/65/EU  2.92mm END LAUNCH JACK FOR .062" BOARD   .XX .01 .XXX .003 .XXXX .0010 ANGLES 100' SEE NOTE  JOHNSON 145-0701-841 RoHS2 UNLESS OTHERWISE SPECIFIED UNITS: INCH   145-0701-841 R.SHEN 1A Part Number Material Impedance Maximum Frequency VSWR  .012 145-0701-851 Gold-Plated Brass 50 Ohms 40GHz 1.25 MAX DC-26.5GHz 1.5 MAX 26.5GHz-40GHz INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009.   2/26/2019 B DO NOT SCALE DRAWING Sheet 1 of 1 1/4-36 UNS-2A .215 .150 SPECIFICATION: .120 ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-40 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 1000VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE ITEM 1 ITEM 2 RF LEAKAGE: -90dB TYPICAL AT 2.5GHz PART NUMBER CONTACT BODY  .210 .048  .295 ITEM 3 BERYLLIUM COPPER BRASS MECHANICAL: GOLD PL .00005 MIN 145-0701-861 GOLD PL .000032 MIN ENGAGEMENT/DISENGAGEMENT FORCE: INCH-POUNDS MAX OVER NICKEL PL.00005 OVER NICKEL PL.00005 MATING TORQUE: 7 TO 10 INCH-POUNDS MIN OVER COPPER MIN OVER COPPER DURABILITY: 500 CYCLES MIN .310 TEFLON Part Number 145-0701-861 Material Gold-Plated Brass Impedance 50 Ohms ECO DATE 1 1A ECO-19-0008 ECO-19-0032 3/28/2019 7/25/2019 数字签名人 Lin Ma DN:cn=Lin Ma, c=CN, o=Cinch Connectivity Solutions (Shanghai) Co. Ltd, email=lin.ma@cn. cinch.com 日期:2019.07.25 14:51:15 +08'00' .460 Jack, 0.093” Board Thickness, Straddle Mount, Solder Type ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B CORROSION: MIL-STD-202, METHOD 101, CONDITION B SHOCK: MIL-STD-202, METHOD 213, CONDITION I VIBRATION: MIL-STD-202, METHOD 204, CONDITION D MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106 REV INSULATOR .095  Maximum Frequency VSWR  SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 40GHz   .012 JOHNSON 145-0701-851  RoHS2 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX .01 .XXX .003 .XXXX .0010 ANGLES 100' SEE NOTE    2.92mm END LAUNCH JACK FOR .042" BOARD    145-0701-851 R.SHEN 1A 1.25 MAX DC-26.5GHz 1.5 MAX 26.5GHz-40GHz INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009.  3/20/2019  DO NOT SCALE DRAWING B Sheet 1 of 1 1/4-36 UNS-2A .150 SPECIFICATION: ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-40 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 1000VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz MECHANICAL: ENGAGEMENT/DISENGAGEMENT FORCE: 2 INCH-POUNDS MAX MATING TORQUE: 7 TO 10 INCH-POUNDS DURABILITY: 500 CYCLES MIN .215 .120  .210 .098  .295 .310 For more information, please see the drawings on the Cinch website at belfuse.com/Cinch and search by part number. ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B CORROSION: MIL-STD-202, METHOD 101, CONDITION B SHOCK: MIL-STD-202, METHOD 213, CONDITION I VIBRATION: MIL-STD-202, METHOD 204, CONDITION D MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106  SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009.  SEE NOTE  27 JOHNSON 145-0701-861  RoHS2 2011/65/EU  UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX .01 .XXX .003 .XXXX .0010 ANGLES 100'   2.92mm END LAUNCH JACK FOR .093" BOARD    145-0701-861 R.SHEN  3/20/2019  B DO NOT SCALE DRAWING 1A Sheet 1 of 1 2.92mm PART NUMBER 145-0701-811 Jack, End Launch, Board Cutout ITEM 1 BODY BRASS GOLD PL .00005 MIN OVER NICKEL PL.00005 MIN OVER COPPER PL.00005 MIN ITEM 2 ITEM 3 CONTACT REV ECO DATE 0 ECO-16-XXXX 9/15/2016 INSULATOR BERYLLIUM COPPER GOLD PL .00005 MIN OVER NICKEL PL.00005 MIN OVER COPPER PL.00005 MIN TEFLON 1/4-36 UNS-2A Part Number Material Impedance Maximum Frequency VSWR 145-0701-811 Gold-Plated Brass 50 Ohms 40GHz 1.25 MAX DC-26.5GHz 1.5 MAX 26.5GHz-40GHz .586 .032  .353 .236 .079 5:1  .020 Part Number Material 145-0701-221 Gold-Plated Brass IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-40 GHz VSWR: 1.5 MAX INSERTION LOSS: 0.05 F dB MAX (F IN GHz) WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 1000VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz MECHANICAL: .010 .112 SPECIFICATION: 2.92mm Jack, PCB Mount .164 .272 .028 Impedance Maximum Frequency 50 Ohms 40GHz VSWR .362 MIN 1.25 MAX DC-26.5GHz 1.5 MAX 26.5GHz-40GHz .276 ENGAGEMENT/DISENGAGEMENT FORCE: 2 INCH-POUNDS MAX CONTACT RETENTION: 6 LBS MIN AXIAL FORCE MATING TORQUE: 7 TO 10 INCH-POUNDS DURABILITY: 500 CYCLES MIN .281 REV .396 MIN MODEL NUMBERMODEL NUMBER ENVIRONMENTAL: RECOMMENDED PCB1/4-36UNS-2A LAYOUT 1/4-36UNS-2A NOTE: THIS PATTERN IS FOR REFERENCE ONLY. PATTERN MAY VARY DEPENDING ON ASSEMBLY PROCESS, BOARD TYPE, OR SPECIFIC ELECTRICAL OR MECHANICAL REQUIREMENTS. 145-0701-221 145-0701-221 OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B CORROSION: MIL-STD-202, METHOD 101, CONDITION B SHOCK: MIL-STD-202, METHOD 213, CONDITION I VIBRATION: MIL-STD-202, METHOD 204, CONDITION D MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106   SEE NOTE .392 .39245° REV ECO 0B 45° This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand.  INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. SEE DETAIL A SEE DETAIL A   2011/65/EU SEE NOTE DATE 145-0701-811 RoHS2 UNLESS OTHERWISE SPECIFIED UNITS: MM  ECO DATE ECO-19-XXXX 0B ECO-19-XXXX 6/10/2019 6/10/201 X 0.2 X.X 0.1 X.XX 0.07 ANGLES 2 DEG 2.92mm END LAUNCH JACK     145-0701-811 R.SHEN   9/15/16 .062 C 0 DO NOT SCALE DRAWING Sheet 1 of 1 .062  .018 ±.001  .018 ±.001 .353 .491 45º PCB Mount Connector .353 .400 .400 .300 .300 .491 .150 .150 .150 .150 .100 SPECIFICATION: SPECIFICATION: ELECTRICAL: ELECTRICAL: IMPEDANCE: IMPEDANCE: 50 OHMS 50 OHMS FREQUENCY FREQUENCY RANGE: 0-40 RANGE: GHz 0-40 GHz VSWR: 1.25VSWR: MAX DC-26.5GHz, 1.25 MAX DC-26.5GHz, 1.5MAX 26.5GHz-40GHz 1.5MAX 26.5GHz-40GHz WORKING VOLTAGE: WORKING VOLTAGE: 250 VRMS MAX 250 VRMS AT SEA MAX LEVEL AT SEA LEVEL DIELECTRIC DIELECTRIC WITHSTANDING WITHSTANDING VOLTAGE: 750 VOLTAGE: VRMS MIN 750 AT VRMS SEAMIN LEVEL AT SEA LEVEL INSULATION INSULATION RESISTANCE: RESISTANCE: 5000 MEGOHM 5000MIN MEGOHM MIN CONTACT RESISTANCE: CONTACT RESISTANCE: CENTER CONTACT CENTER CONTACT - INITIAL 3 -MILLIOHM INITIAL 3 MAX, MILLIOHM AFTER MAX, AFTER ENVIRONMENTAL ENVIRONMENTAL NOT APPLICABLE NOT APPLICABLE OUTER CONDUCTOR OUTER CONDUCTOR - INITIAL 2-MILLIOHM INITIAL 2 MAX, MILLIOHM AFTER MAX, AFTER ENVIRONMENTAL ENVIRONMENTAL NOT APPLICABLE NOT APPLICABLE RF LEAKAGE: RF -90dB LEAKAGE: TYPICAL -90dB ATTYPICAL 2.5GHz AT 2.5GHz .100 2 X .159 2 X .159 Part Number Material Impedance Maximum Frequency VSWR 142-0711-271 Gold-Plated Brass 50 Ohms 18GHz 1.25 MAX DC-26.5GHz 2 X #0-80UNF 2 X #0-80UNF MECHANICAL: MECHANICAL: ENGAGEMENT/DISENGAGEMENT ENGAGEMENT/DISENGAGEMENT FORCE: 2 INCH-POUNDS FORCE: 2 INCH-POUNDS MAX MAX CONTACT RETENTION: CONTACT RETENTION: 6 LBS MIN AXIAL 6 LBS FORCE MIN AXIAL FORCE MATING TORQUE: MATING7TORQUE: TO 10 INCH-POUNDS 7 TO 10 INCH-POUNDS DURABILITY: DURABILITY: 500 CYCLES 500 MIN CYCLES MIN ENVIRONMENTAL: ENVIRONMENTAL: OPERATINGOPERATING TEMPERATUR: TEMPERATUR: -40 TO 85°C-40 TO 85°C THERMAL SHOCK: THERMAL MIL-STD-202, SHOCK: MIL-STD-202, METHOD 107, METHOD CONDITION 107, CONDITION B B CORROSION: CORROSION: MIL-STD-202, MIL-STD-202, METHOD 101, METHOD CONDITION 101, CONDITION B B SHOCK: MIL-STD-202, SHOCK: MIL-STD-202, METHOD 213, METHOD CONDITION 213, CONDITION I I VIBRATION:VIBRATION: MIL-STD-202, MIL-STD-202, METHOD 204, METHOD CONDITION 204, CONDITION D D MOISTURE MOISTURE RESISTANCE: RESISTANCE: MIL-STD-202, MIL-STD-202, MEHTOD 106 MEHTOD 106 MATERIAL AND MATERIAL FINISH: AND FINISH: BODY: GOLD BODY: PLATED GOLD BRASS PLATED BRASS CENTER CONTACT: CENTER CONTACT: GOLD PLATED GOLD BERYLLIUM PLATED BERYLLIUM COPPER COPPER INSULATOR: INSULATOR: PTFE (TEFLON) PTFE (TEFLON) .004 ±.002 .004 ±.002 DETAIL A 20:1 DETAIL A 20:1 For more information, please see the drawings on the Cinch website at belfuse.com/Cinch and search by part number. 28    SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009.  145-0701-221 SEE NOTE RoHS2 2011/65/EU  This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential UNLESS in OTHERWISE SPECIFIED nature, non-transferable, andUNITS:  INCH issued with the clear .XXX .005 ANGLES 2 DEG  INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 145-0701-221  RoHS2    UNLESS OTHERWISE SPECIFIED UNITS: INCH  C   145-0701-221 R.SHEN .XXX .005  DO NOT SCALE ANGLES 2 DEG  6/10/19  2.92MM 45 DEGREE2.92MM PC MOUNT 45 DEGREE JACK PC MOUNT JAC  2011/65/EU  understanding that it is not  .XX .02 traced or copied without .XX .02 SEE NOTE SEE NOTE permission and is returnable R.SHEN  upon demand. 6/10/19 DRAWING  C 145-0701-221 0B DO NOT SCALE Sheet DRAWING 1 of 2  0 Sheet 1 of 2.92mm Jack, Screw-On Type PART NUMBER Part Number Material 145-0701-802 Stainless Steel/Passivated 145-0701-802 ITEM 1 MAIN BODY ITEM 2 MOUNTING BODY ITEM 3 CONTACT ITEM 4 INSULATOR ITEM 5 BOLT X 2 ITEM 6 WASHER X 2 BERYLLIUM COPPER STAINLESS STAINLESS STEEL BRASS ULTEM 1000 (MATING GOLD PL .00004 MIN(MATING END) END) NICKEL PL.00007 MIN STEEL PASSIVATED OVER COPPER STRIKE / .00003 MIN(SOLDER END) OVER /TEFLON (SOLDER END) NICKEL PL.00005 MIN OVER COPPER PL.00005 MIN STAINLESS STEEL Impedance Maximum Frequency 50 Ohms 40GHz REV ECO DATE 1 ECO-17-0010 4/10/2017 .030 VSWR .039 .007 3* 1.25 MAX DC-26.5GHz .012 1.54* MAX 26.5GHz-40GHz DETAIL A 3* SEE DETAIL A 1/4-36UNS-2A 2X #1-72 SCREWS X .445" LENGTH (.062 HEX) 5* 6* .148 4* .340 .394 1* .340 .378 .500 SPECIFICATION: Plug, Screw-On Type Part Number 145-0801-802 ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY 0-40 2GHz ITEM 3 ITEM 1 RANGE: ITEM ITEM 4 ITEM 5 CONTACT MOUNTING BODY VSWR:MAIN DEPENDANT ON APPLICATION BODY INSULATOR BOLT X 2 WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL BERYLLIUM COPPER STAINLESS STAINLESS STEEL BRASS 145-0801-802 ULTEM 1000 (MATING DIELECTRIC WITHSTANDING VOLTAGE: VRMS MINMIN(MATING AT SEA LEVEL GOLD PL .00004 END) END) NICKEL PL.00007 MIN 750 STEEL PASSIVATED INSULATION RESISTANCE: 5000 MEGOHM MIN MIN(SOLDER END) OVER /TEFLON (SOLDER END) STRIKE / .00003 OVER COPPER NICKEL PL.00005 MIN OVER CONTACT RESISTANCE: COPPER PL.00005 MIN CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz PART NUMBER Material Stainless Steel/Passivated .188 2* .375 .749 Impedance ITEM 6 WASHER X 2 STAINLESS STEEL Maximum Frequency 50 Ohms 3* MECHANICAL: ENGAGEMENT/DISENGAGEMENT FORCE: 2 INCH-POUNDS MAX CONTACT RETENTION: 6 LBS MIN AXIAL FORCE MATING TORQUE: 7 TO 10 INCH-POUNDS DURABILITY: 500 CYCLES MIN 3* 1/4-36UNS-2B .079 VSWR DATE ECO-17-0010 4/10/2017 .007 .039 1.25 MAX DC-26.5GHz .012 1.5 MAX 26.5GHz-40GHz DETAIL A 4* 2X #1-72 SCREWS X .445" LENGTH (.062 HEX) RECOMMENDED PCB LAYOUT NOTE: THIS PATTERN 5* IS FOR REFERENCE ONLY. PATTERN MAY VARY DEPENDING ON BOARD TYPE, SPECIFIC ELECTRICAL OR MECHANICAL REQUIREMENTS. SEE DETAIL A 1* ECO 1 .110 40GHz 2X REV .030 .375 ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B CORROSION: MIL-STD-202, METHOD 101, CONDITION B SHOCK: MIL-STD-202, METHOD 213, CONDITION I VIBRATION: MIL-STD-202, METHOD 204, CONDITION D MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106 4* 6* SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. .148 RoHS2 END LAUNCH JACK SCREW-ON TYPE SMK(2.92mm) 2011/65/EU SEE NOTE INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. .340 UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX .02 .XXX .005 ANGLES 2 DEG 145-0701-802 R.SHEN 4/10/17 C DO NOT SCALE DRAWING 1 Sheet 1 of 1 .394 .315 HEX .340 .508 .500 2* .188 .879 .375 SPECIFICATION: ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-40 GHz VSWR: DEPENDANT ON APPLICATION MODEL NO. WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN 145-0711-802 CONTACT RESISTANCE: CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz PACKAGING .375 Low Profile Connectors – (at 0.375” Height) Jack, Screw-on Type, Low profile, 0.005” Pin Part Number Material 145-0711-802 Stainless Steel/Passivated ONE PCS PER BAG MECHANICAL: ENGAGEMENT/DISENGAGEMENT FORCE: 2 INCH-POUNDS MAX CONTACT RETENTION: 6 LBS MIN AXIAL FORCE MATING TORQUE: 7 TO 10 INCH-POUNDS DURABILITY: 500 CYCLES MIN ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B CORROSION: MIL-STD-202, METHOD 101, CONDITION B SHOCK: MIL-STD-202, METHOD 213, CONDITION I VIBRATION: MIL-STD-202, METHOD 204, CONDITION D MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106 .110 2X .079 O.005 O.009 RECOMMENDED PCB LAYOUT NOTE: THIS PATTERN IS FOR REFERENCE ONLY. PATTERN MAY VARY DEPENDING ON BOARD TYPE, SPECIFIC ELECTRICAL OR MECHANICAL REQUIREMENTS. O.029 Impedance Maximum Frequency VSWR 50 Ohms 40GHz 1.25 DETAIL A (15/1) SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. RoHS2 END LAUNCH PLUG SCREW-ON TYPE SMK(2.92mm) 2011/65/EU SEE NOTE INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX .02 .XXX .005 ANGLES 2 DEG 145-0801-802 R.SHEN 4/10/17 C DO NOT SCALE DRAWING 1 Sheet 1 of 1 LASER MARK " 1450711802" 1/4-36UNS-2A .375 .250 MODEL NO. PACKAGING 145-0711-812 ONE PCS PER BAG A .375 .065 .500 .378 .030 .745 Jack, Screw-on Type, Low profile, 0.007” Pin NOTES: UNLESS OTHERWISE SPECIFIED Part Number Material Impedance 145-0711-812 Stainless Steel/Passivated 50 Ohms 1. MATERIAL & FINISH: 1.1 MAIN BODY: PASSIVATED STAINLESS STEEL 1.2 MOUNTING BODY: NICKEL PLATED BRASS 1.3 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.4 MAIN INSULATOR: ULTEM 1000,AMBER 1.5 MOUNTING INSULATOR: PTFE, WHITE 1.6 WASHER, BOLT: STAINLESS STEEL O.007 Maximum Frequency VSWR 40GHz 1.25 DETAIL A (9/1) 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS LASER MARK " 1450711812" 2.2 FREQUENCY RANGE: DC-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS MIN 1/4-36UNS-2A 2.5 CONTACT RESISTANCE: 2.5.1 CENTER CONTACT: 3 MILLIOHMS MAX 2.5.2 OUTER CONTACT: 2 MILLIOHMS MAX O.012 O.039 O .079 X 2 3. MECHANICAL: 3.1 DURABILITY: 500CYCLES MIN .375 .250 4. ENVIRONMENT: 4.1 OPERATING TEMPERATURE: -55 TO 125°C 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .375 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B .500 A .065 .378 .745 For more information, please see the drawings on the Cinch website at belfuse.com/Cinch and search by part number. NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 MAIN BODY: PASSIVATED STAINLESS STEEL 1.2 MOUNTING BODY: NICKEL PLATED BRASS 1.3 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.4 MAIN INSULATOR: ULTEM 1000,AMBER 1.5 MOUNTING INSULATOR: PTFE, WHITE 1.6 WASHER, BOLT: STAINLESS STEEL 29 O .079 X 2 PCB 2.92mm Vertical Connectors MODEL NO. PACKAGING 2-Hole Flange Mount Jack, PCB Compression Mount, Stripline PACKAGING NO. PCS PER BAG 145-0701-202MODEL ONE 145-0701-202 ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 145-0701-202 Stainless Steel/Passivated 50 Ohms 40GHz 1.25 LASER MARK " 1450701202" O .063 ±.001 X 2 #0-80 UNF X 2 LASER MARK " 1450701202" 1/4-36UNS-2A O .016 1/4-36UNS-2A O .063 ±.001 X 2 O .394 #0-80 UNF X 2 O .394 O .140 O .016 O .023 O .140 .2819 ±.0012 O .023 .282 .2819 ±.0012 .141 ±.0012 .282 O .052 A NOTES: UNLESS OTHERWISE SPECIFIED RECOMMENDED MO .223 .065 .430 RECOMME .223 .065 .430 O.112 1. MATERIALNOTES: & FINISH: UNLESS OTHERWISE SPECIFIED 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1. MATERIAL & FINISH: 1.3 INSULATOR: PTFE,PASSIVATED WHITE 1.1 BODY: STAINLESS STEEL 1.4 WASHER: STEEL 1.2STAINLESS CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.5 BOLT: SUS302 1.3 INSULATOR: PTFE, WHITE PACKAGING MODEL NO. 1.4 WASHER: STAINLESS STEEL 2. ELECTRICAL: PACKAGING MODEL NO. 1.5 BOLT: SUS302 2.1 IMPEDANCE: 50 OHMS ONE PCS PER BAG 145-0701-212 2.2 FREQUENCY RANGE: DC-40 GHz 2. ELECTRICAL: ONE PCS PER BAG 145-0701-212 2.3 VOLTAGE WAVE RATIO: 1.35 MAX 2.1STANDING IMPEDANCE: 50 OHMS 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS MIN 2.2 FREQUENCY RANGE: DC-40 GHz 2.5 CONTACT 2.3RESISTANCE: VOLTAGE STANDING WAVE RATIO: 1.35 MAX 2.5.1 CENTER CONTACT:WITHSTANDING 3 MILLIOHMS MAX 2.4 DIELECTRIC VOLTAGE: 750 VRMS MIN 2.5.2 OUTER CONTACT: 2 MILLIOHMS MAX 2.5 CONTACT RESISTANCE: 2.6 INSULATOR2.5.1 RESISTANCE: 5000 MEGOHM MIN CENTER CONTACT: 3 MILLIOHMS MAX 2.5.2 OUTER CONTACT: 2 MILLIOHMS MAX 3. MECHANICAL: 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 3.1 ENGAGEMENT AND DISENGAGEMENT FORCE: 0.23 MN MAX 3.2 CONTACT RETENTION: 22 N MIN 3. MECHANICAL: 3.3 DURABILITY: 500CYCLES MIN 3.1 ENGAGEMENT AND DISENGAGEMENT FORCE: 0.23 MN MAX 3.2 CONTACT RETENTION: 22 N MIN 4. ENVIRONMENT: 3.3 DURABILITY: 500CYCLES MIN 4.1 OPERATING TEMPERATURE: -55 TOLASER 125°C MARK " 1450701212" 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4. ENVIRONMENT: LASER 4.3 SHOCK: 4. MIL-STD-202, METHOD 213, CONDITION I MARK " 1450701212" 1 OPERATING TEMPERATURE: -55 TO 125°C 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION 4.2 THERMAL SHOCK: MIL-STD-202, METHODD107, CONDITION B. 1/4-36UNS-2A 4.5 MOISTURE MIL-STD-202, METHOD 106 4.3 RESISTANCE: SHOCK: MIL-STD-202, METHOD 213, CONDITION I 1/4-36UNS-2A 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B .0028 O.112 O.112 .0067 .0028 O.112 .0067 DETAIL A (10/1) 2-Hole Flange Mount Jack, PCB Compression Mount, Microstrip DETAIL A (10/1) .197 .197 Part Number Material Impedance #0-80 UNF X 2 Maximum Frequency #0-80 UNF X 2 VSWR 145-0701-212 Stainless Steel/Passivated 50 Ohms 40GHz 1.25 #0-80 UNF X 2 #0-80 UNF X 2 1. BOARD THICKNESS: 1.57-2.79m 1. BOARD THICKNESS: O .063 ±.001 X 2 O .063 ±.001 X 2 O .394 O .394 Model No. 145-0701 RoHS2 A .065 O .016 O .016 .223 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1. MATERIAL & FINISH: 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.1 BODY: PASSIVATED STAINLESS STEEL 1.3 INSULATOR: PTFE, WHITE 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.4 WASHER: STAINLESS STEEL 1.3 INSULATOR: PTFE, WHITE 1.5 BOLT: SUS302 1.4 WASHER: STAINLESS STEEL 1.5 BOLT: SUS302 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2. ELECTRICAL: 2.2 FREQUENCY RANGE: DC-40 GHz 2.1 IMPEDANCE: 50 OHMS 2.3 VOLTAGE STANDING WAVE RATIO: 1.35 MAX 2.2 FREQUENCY RANGE: DC-40 GHz 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS MIN 2.3 VOLTAGE STANDING WAVE RATIO: 1.35 MAX 2.5 CONTACT RESISTANCE: 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS MIN 2.5.1 CENTER CONTACT: 3 MILLIOHMS MAX 2.5 CONTACT RESISTANCE: 2.5.2 OUTER CONTACT: 2 MILLIOHMS MAX 2.5.1 CENTER CONTACT: 3 MILLIOHMS MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 2.5.2 OUTER CONTACT: 2 MILLIOHMS MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT AND DISENGAGEMENT FORCE: 0.23 MN MAX 3. MECHANICAL: 3.2 CONTACT RETENTION: 22 N MIN 3.1 ENGAGEMENT AND DISENGAGEMENT FORCE: 0.23 MN MAX 3.3 DURABILITY: 500CYCLES MIN 3.2 CONTACT RETENTION: 22 N MIN 3.3 DURABILITY: 500CYCLES MIN 4. ENVIRONMENT: 4.1 OPERATING TEMPERATURE: -55 TO 125°C 4. ENVIRONMENT: 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.1 OPERATING TEMPERATURE: -55 TO 125°C 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B O.112 O.112 .197 #0-80 UNF X 2 #0-80 UNF X 2 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH 3RD Drawn .XXX u.02 .XXXX u.01 Date: This PROPRIETARY Document ANGLES u5ofv Cinch Connectivity is property 06 Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. .282 ±.0012 .282 ±.0012 .141 ±.0012 .141 ±. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. RECOMMEND RECOM .223 R .0236 R .0236 .430 NOTES: UNLESS OTHERWISE SPECIFIED INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. O .052 O .052 A .065 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. O .140 O .140 O .023 O .023 .282 .051 .282 .051 .430 .141 O .052 A O.112 .003 O.112 .0315 .003 .0315 .0067 .0067 DETAIL A (10/1) DETAIL A (10/1) .197 1. BOARD THICKNESS: 1.57-2.79 1. BOARD THICKNESS: 1. This PRO is propert Solution nature, n issu unders traced permiss u INTERP ACCORD Y 30 2.92mm Flange Connectors 2-Hole Flange Mount Jack and Plug Receptacle, Stripline Part Number Material Impedance Maximum Frequency VSWR 145-0701-601 Stainless Steel/Gold Plated 50 Ohms 40GHz 1.20 145-0701-602 Stainless Steel/Passivated 50 Ohms 40GHz 1.20 145-0801-602 Stainless Steel/Passivated 50 Ohms 40GHz 1.20 ITEM 1 BODY ITEM 1 PART NUMBER PART NUMBER ITEM 2 CONTACT ITEM 2 BODY STAINLESS STEEL PASSIVATED STAINLESS STEEL PASSIVATED 145-0801-602 145-0801-602 CONTACT BERYLLIUM COPPER GOLD PL .00004 MIN BERYLLIUM COPPER OVER NICKEL PL.00005 GOLD PL .00004 MIN MIN OVER COPPER OVER NICKEL PL.00005 MINPL.00005 MIN OVER COPPER PL.00005 MIN ITEM 3 ITEM 4 INSULATOR NUT ITEM 3 ITEM 4 INSULATOR ULTEM 1000 NUT STAINLESS ULTEM 1000 REV ITEM 5 GASKET ITEM 5 GASKET REV 1 SILICONE STEEL STAINLESS PASSIVATED SILICONE STEEL PASSIVATED EC ECO ECO-1 1 ECO-17- ACCEPT .012 .001 PIN ACCEPT .012 .001 PIN 2 X  .102 +.004 0 2 X  .102 +.004 0 1/4-36UNS-2B 1/4-36UNS-2B  .165  .165 .315 HEX  .626  .626 .481 .481 .004 .315 HEX .004 .065 4-Hole Flange Mount Jack and Plug Receptacle Part Number Material Impedance 145-0701-611 Stainless Steel/Gold Plated 50 Ohms 145-0701-612 Stainless Steel/Passivated 50 Ohms 145-0801-612 Stainless Steel/Passivated 50 Ohms .224 .065 .508 REF SPECIFICATION: .508 REF SPECIFICATION: ELECTRICAL: IMPEDANCE: 50 OHMS ELECTRICAL: FREQUENCY50 RANGE: IMPEDANCE: OHMS 0-40 GHz VSWR: 1.2 MAX. FREQUENCY RANGE: 0-40 GHz WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL VSWR: 1.2 MAX. DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVELMIN AT SEA LEVEL INSULATIONWITHSTANDING RESISTANCE: 5000 MEGOHM DIELECTRIC VOLTAGE: 750MIN VRMS MIN AT SEA LEVEL CONTACT RESISTANCE: INSULATION RESISTANCE: 5000 MEGOHM MIN CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER CONTACT RESISTANCE: ENVIRONMENTAL NOTAFTER APPLICABLE CENTER CONTACT - INITIAL 3 MILLIOHM MAX, OUTER CONDUCTOR -ENVIRONMENTAL INITIAL 2 MILLIOHM AFTER NOTMAX, APPLICABLE ENVIRONMENTAL NOTAFTER APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, RF LEAKAGE: -90dB TYPICAL AT 2.5GHz ENVIRONMENTAL NOT APPLICABLE .224 Maximum Frequency VSWR 40GHz 1.20 RF LEAKAGE: -90dB TYPICAL AT 2.5GHz MECHANICAL: ENGAGEMENT/DISENGAGEMENT FORCE: 2 INCH-POUNDS MAX MECHANICAL: CONTACT RETENTION: 6 LBS MINFORCE: AXIAL FORCE ENGAGEMENT/DISENGAGEMENT 2 INCH-POUNDS MAX MATING TORQUE: 7 TO6 10 INCH-POUNDS CONTACT RETENTION: LBS MIN AXIAL FORCE DURABILITY: 500 CYCLES MIN MATING TORQUE: 7 TO 10 INCH-POUNDS DURABILITY: 500 CYCLES MIN ENVIRONMENTAL: OPERATING TEMPERATUR: -40 TO 85°C ENVIRONMENTAL: THERMAL SHOCK: MIL-STD-202, METHOD OPERATING TEMPERATUR: -40 TO 85°C 107, CONDITION B CORROSION: MIL-STD-202, METHOD 101,107, CONDITION B B THERMAL SHOCK: MIL-STD-202, METHOD CONDITION SHOCK: MIL-STD-202, METHOD 213, 101, CONDITION I CORROSION: MIL-STD-202, METHOD CONDITION B VIBRATION: MIL-STD-202, METHOD 204, CONDITION D SHOCK: MIL-STD-202, METHOD 213, CONDITION I MOISTURE MIL-STD-202, RESISTANCE:METHOD MIL-STD-202, MEHTOD 106 VIBRATION: 204, CONDITION D 40GHz 1.20 40GHz 1.20   SEE NOTE  MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and  issued with the clear understanding that it is not traced or copied without permission and is returnable This PROPRIETARY Document upon demand.  is property of Cinch Connectivity Solutions. It is confidential in INTERPRET DRAWING IN nature, non-transferable, andASME  ACCORDANCE WITH issued with the clear Y14.5-2009. understanding that it is not traced or copied without permission and is returnable upon demand. RoHS2 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH RoHS2 SEE NOTE 2011/65/EU .XX .02 SEE NOTE  PART NUMBER 145-0801-612 145-0801-612 ITEM 1 BODY ITEM 1 ITEM 2 CONTACT ITEM 2 BODY STAINLESS STEEL PASSIVATED STAINLESS STEEL PASSIVATED CONTACT BERYLLIUM COPPER GOLD PL .00004 MIN BERYLLIUM COPPER OVER NICKEL PL.00005 GOLD PL .00004 MIN MIN OVER COPPER OVER NICKEL PL.00005 MINPL.00005 MIN OVER COPPER PL.00005 MIN ITEM 3 ITEM 4 INSULATOR NUT ITEM 3 ITEM 4 INSULATOR ULTEM 1000 NUT STAINLESS ULTEM 1000 4 X  .102 +.004 0 4 X  .102 +.004 0 1/4-36UNS-2B  .165  .165 .340 .340 .004 .004 .508 REF .065 .508 REF .340 .340  .500  .500 SPECIFICATION: SPECIFICATION: ELECTRICAL: IMPEDANCE: 50 OHMS ELECTRICAL: FREQUENCY50 RANGE: IMPEDANCE: OHMS 0-40 GHz VSWR: 1.2 MAX. FREQUENCY RANGE: 0-40 GHz WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVEL VSWR: 1.2 MAX. DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS WORKING VOLTAGE: 250 VRMS MAX AT SEA LEVELMIN AT SEA LEVEL INSULATION RESISTANCE: MEGOHM DIELECTRIC WITHSTANDING5000 VOLTAGE: 750MIN VRMS MIN AT SEA LEVEL CONTACT RESISTANCE: INSULATION RESISTANCE: 5000 MEGOHM MIN CENTER CONTACT - INITIAL 3 MILLIOHM MAX, AFTER CONTACT RESISTANCE: ENVIRONMENTAL NOTAFTER APPLICABLE CENTER CONTACT - INITIAL 3 MILLIOHM MAX, OUTER CONDUCTOR -ENVIRONMENTAL INITIAL 2 MILLIOHM AFTER NOTMAX, APPLICABLE ENVIRONMENTAL NOTAFTER APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, RF LEAKAGE: -90dB TYPICAL AT 2.5GHz ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -90dB TYPICAL AT 2.5GHz PANEL RECEPTAC 145-080S 2-HOLE FLANGE   DO NOT SCALE C  C 145-0801 DRAWING DO NOT SCALE DRAWING 1 1/4-36UNS-2B .065 PANEL RECEPT 2-HOLE FLANGE   R.SHEN REV 1 ACCEPT .012 .001 PIN .315 HEX   REV ITEM 5 GASKET ITEM 5 GASKET SILICONE STEEL STAINLESS PASSIVATED SILICONE STEEL PASSIVATED ACCEPT .012 .001 PIN .315 HEX    .XXX .005  ANGLES 2 DEG 4/10/17  .XX .02 R.SHEN .XXX .005  ANGLES 2 DEG 4/10/17 UNLESS OTHERWISE SPECIFIED UNITS: INCH INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. PART NUMBER   SEE NOTE 31 EC ECO ECO-1 ECO-17- 2.92mm Field Receptacle Connectors Jack Receptacle, Thread Mount Field Replaceable Part Number Accepts Pin Size Material 145-0701-001 0.0120 in +/- 0.0005 (0.305 +/- 0.013mm) Stainless Steel/Gold Plated 145-0701-002 0.0120 in +/- 0.0005 (0.305 +/- 0.013mm) Stainless Steel/Passivated Hermetic Seal Feedthru Part Number Item 1 - Outer Ring Item 2 - Insulator Item 3 - Pin 142-1000-033 Kovar Gold pl 0.00005 minimum over Nickel pl 0.00005 minimum Glass Corning 7070 or equivalent Kovar Gold pl 0.00005 minimum over Nickel pl 0.00005 minimum Notes: 1. Reference diagram on page 42 32 2.92mm Product Specification Table Environmental Hermeticity 1x10-8 cc/sec at one atmosphere Solderability MIL-STD-202, Method 209 Operating Temperature -67ºF to 329ºF (-55ºC to 165ºC) Electrical Impedance 50 Ohms Frequency Range DC to 40GHz VSWR Dependent upon application Working Voltage 250 VRMS maximum at sea level Dielectric Withstanding 500 VRMS minimum at sea level Insulation Resistance 5000 megohm minimum Insertion Loss 0.2 dB maximum at 40GHz Notes: 1. The hermetic seal should be mounted as flush as possible with the housing. Excessive recession will create a high impedance air gap between connection and housing which degrades electrical performance. 2. The use of an additional counterbore to accommodate a solder ring for seal mounting is not recommended. A slight chamfer may be used if care is taken to completely fill the area with solder - avoid air gaps. Straight Solder Type Plug, with contact, slide-on nut Part Number Cable Type Material 145-0693-001 0.086 Semi-Rigid (RG-405) Stainless Steel/Gold Plated 145-0694-001 0.141 Semi-Rigid (RG-402) Stainless Steel/Gold Plated 145-0693-002 0.086 Semi-Rigid (RG-405) Stainless Steel/Passivated 145-0694-002 0.141 Semi-Rigid (RG-402) Stainless Steel/Passivated Notes: 1. Stainless steel/passivated coupling nut & gold plated body 2. Assembly instructions on page 41 33 2.92mm Same Series Adapters 2.92mm adapters are offered in same series and between series configurations. They are precision manufactured to RF component industry specifications, with a maximum frequency of 40GHz. Plug to Plug Same Series Adapter Part Number Material Impedance Maximum Frequency VSWR 145-0901-811 Stainless Steel/Gold Plated 50 Ohms 40GHz 1.20 .215 Plug to Jack Same Series Adapter Part Number Material Impedance Maximum Frequency VSWR 145-0901-821 Stainless Steel/Gold Plated 50 Ohms 40GHz 1.20 .215 Jack to Jack Same Series Adapter Part Number Material Impedance Maximum Frequency VSWR 145-0901-801 Stainless Steel/Gold Plated 50 Ohms 40GHz 1.20 .215 34 2.92mm Between Series Adapters Between Series, 2.92mm Jack To SMA Jack MODEL NO. 134-1010-000 PACKAGING ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 134-1010-000 Stainless Steel/Passivated 50 Ohms 26.5GHz 1.30 1/4-36UNS-2A LASER MARK:"1341010000" .274 A/F 1/4-36UNS-2A .274 A/F .896 REF NOTES: UNLESS OTHERWISE SPECIFIED Between Series, 2.92mm Jack To SMA Plug Part Number Material 134-1010-001 Stainless Steel/Passivated 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-26.5 GHz PACKAGING MODEL STANDING NO. 2.3 VOLTAGE WAVE RATIO: 1.3 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 750 VRMS MIN 2.5 CONTACT RESISTANCE: ONE PCS PER BAG 134-1010-001 2.5.1 CENER CONTACT: 3 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN Impedance Maximum Frequency VSWR 50 Ohms 26.5GHz 1.30 3. MECHANICAL: 3.1 ENGAGEMENT/DISENGAGEMENT FORCE: 2 IN-LBS. MAX 3.2 CONTACT RETENTION: 6 LBS MIN 3.3 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 1/4-36UNS-2A .744 REF 1/4-36UNS-2B Model N RoHS This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. .XXX .XXX ANGL .315 HEX .274 A/F LASER MARK:"1341010001" 2011/ UNLESS OTHE UNI INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. .938 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED Between Series, 2.92mm Plug To SMA Jack Part Number Material 134-1010-002 Stainless Steel/Passivated 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-26.5 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.3 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 750 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 3 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN PACKAGING MODEL NO. 3. MECHANICAL: 3.1 ENGAGEMENT / DISENGAGEMENT FORCE: 2 IN-LBS MAX ONE PCS PER BAG 134-1010-002 3.2 COUPLING NUT RETENTION: 60 LBS MIN 3.3 COUPLING PROOF TORQUE: 15 IN-LBS MIN 3.4 CONTACT RETENTION: 6 LBS. MIN 3.5 DURABILITY: 500 CYCLES MIN. Impedance Maximum Frequency VSWR 50 Ohms 26.5GHz 1.30 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. .744 REF 1/4-36UNS-2B LASER MARK:"1341010002" 1/4-36UNS-2A .315 HEX .274 A/F .274 A/F .938 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-26.5 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.3 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 750 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 3 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 1 RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 35 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v 2.92mm Between Series, 2.92mm Plug To SMA Plug PACKAGING MODEL NO. Part Number Material 134-1010-003 Stainless Steel/Passivated 134-1010-003 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:54:48 +08'00' Impedance Maximum Frequency VSWR 50 Ohms 26.5GHz 1.30 ONE PCS PER BAG .744 REF 1/4-36UNS-2B REV 001 ECO ECO-17-0032 DATE 11/28/201 1/4-36UNS-2B LASER MARK:"1341010003" .315 HEX .315 HEX .274 A/F .980 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PTFE WHITE 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-26.5 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.3 MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENTER CONTACT: 3 MILLIOHM MAX PACKAGING MODEL 2.5.2 OUTERNO. CONTACT: 2 MILLIOHM MAX PACKAGING MODELRESISTANCE: NO. 2.6 INSULATOR 5000 MEGOHM MIN Between Series, 2.92mm Jack To SMP Female Part Number Material 134-1000-000 Stainless Steel/Passivated ONE PCS PER BAG 134-1000-000 3. MECHANICAL: ONE PCS PER 2BAG 134-1000-000 3.1 ENGAGEMENT / DISENGAGEMENT FORCE: IN-LBS. MAX 3.2 COUPLING NUT RETENTION: 60 LBS. MIN 3.3 COUPLING PROOF TORQUE: 15 IN-LBS. MIN 3.4 CONTACT RETENTION: 6 LBS. MIN 3.5 DURABILITY: 500 CYCLES MIN Impedance Maximum Frequency VSWR 50 Ohms 40GHz 1.25 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. 134-1010-003 Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. LASER MARK " 1341000000" LASER MARK " 1341000000" INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 1/4-36UNS-2A 1/4-36UNS-2A 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH .XXX u.02 .XXXX u.01 ANGLES u5v Title: 3RD ANGLE PROJECTION Johnson ADAPTER ASSEMBLY, 2.92mm(SMK) PLUG TO SMA PLUG R Drawing No. Drawn by: Date: Betty.Yu 10/10/2017 134-1010-003 Size C DO NOT SCALE DRAWING Workmanship Std: NONE 0 Sheet 1 o .514 .514 O .276 O .276 .236 A/F .236 A/F .590 .590 MODEL NO. PACKAGING NOTES: UNLESS OTHERWISE SPECIFIED ONE PCS PER BAG SPECIFIED NOTES: UNLESS OTHERWISE 134-1000-001 1. MATERIAL & FINISH: BODY: PASSIVATED 1.1.1 MATERIAL & FINISH: STAINLESS STEEL 1.2 PIN, RING &STAINLESS CONTACT BODY: 1.1CONTACT BODY: PASSIVATED STEEL GOLD PLATED BERYLLIUM COPPER 1.3 PEEK NATURAL 1.2INSULATOR: CONTACT PIN, RING & CONTACT BODY: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PEEK NATURAL 2. ELECTRICAL: IMPEDANCE: 50 OHMS 2.2.1 ELECTRICAL: 2.2 0-40 GHz 2.1FREQUENCY IMPEDANCE:RANGE: 50 OHMS 2.3 STANDING RATIO: 1.25 MAX 2.2VOLTAGE FREQUENCY RANGE:WAVE 0-40 GHz 2.4 WITHSTADING 500MAX VRMS MIN 2.3DIELECTRIC VOLTAGE STANDING WAVEVOLTAGE: RATIO: 1.25 2.5 RESISTANCE: 2.4CONTACT DIELECTRIC WITHSTADING VOLTAGE: 500 VRMS MIN CENERRESISTANCE: CONTACT: 6 MILLIOHM MAX 2.52.5.1 CONTACT 2.5.2 2.5.1OUTER CENERCONTACT: CONTACT:26MILLIOHM MILLIOHMMAX MAX 2.6 INSULATOR RESISTANCE: MEGOHM 2.5.2 OUTER CONTACT: 2 5000 MILLIOHM MAXMIN LASER MARK:"1341000001" 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: FULL DETENT 68 N MAX, LIMITED DETENT 45 N MAX, SMOOTH BORE 9 N MAX (SMP) 3. MECHANICAL: 0.23 NM MAX (SMK) 3.1 ENGAGEMENT FORCE: FULL DETENT 68 N MAX, LIMITED DETENT 45 N MAX, SMOOTH BORE 9 N MAX (SMP) 3.2 DISENGAGEMENT FORCE: FULL 22 N MIN, LIMITED DETENT 9 N MIN, SMOOTH BORE 2.2 N MIN (SMP) 1/4-36UNS-2A 0.23 NMDETENT MAX (SMK) NM MAX (SMK) 3.2 DISENGAGEMENT FORCE:0.23 FULL DETENT 22 N MIN, LIMITED DETENT 9 N MIN, SMOOTH BORE 2.2 N MIN (SMP) 3.3 CONTACT RETENTION: 22N MIN .514 0.23 NM MAX (SMK) 3.4 500CYCLES22N MINMIN (SMK) 3.3DURABILITY: CONTACT RETENTION: DETENTMIN 100(SMK) CYCLES MIN, LIMITED DETENT 500 CYCLES MIN, SMOOTH BORE 1000CYCLES MIN (SMP) 3.4 DURABILITY:FULL 500CYCLES FULL DETENT 100 CYCLES MIN, LIMITED DETENT 500 CYCLES MIN, SMOOTH BORE 1000CYCLES MIN (SMP) 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4. ENVIRONMENT: 4.2 TEMPERATURE: -55TO 125°C 107, CONDITION B. 4.1OPERATING THERMAL SHOCK: MIL-STD-202, METHOD 4.3 SPRAY: MIL-STD-202, METHOD CONDITION B 4.2SALT OPERATING TEMPERATURE: -55TO 101, 125°C 4.4 MIL-STD-202, METHOD 213, CONDITION I 4.3SHOCK: SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.5 MIL-STD-202, METHOD 204, CONDITION 4.4VIBRATION: SHOCK: MIL-STD-202, METHOD 213, CONDITION I D 4.6 RESISTANCE: METHOD 106 D 4.5MOISTURE VIBRATION: MIL-STD-202,MIL-STD-202, METHOD 204, CONDITION 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Between Series, 2.92mm Jack To SMP Male Part Number Material 134-1000-001 Stainless Steel/Passivated Impedance Maximum Frequency VSWR 50 Ohms 40GHz 1.25 O .276 This PRO is prope Solutio nature, iss under Thi trace is p permis S na INTER ACCORu p IN AC .236 A/F .703 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & CONTACT BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PEEK NATURAL 36 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.25 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 500 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 6 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 2.92mm Between Series, 2.92mm Plug To SMP Female MODEL NO. 134-1000-002 PACKAGING ONE PCS PER BAG Part Number Material Impedance Maximum Frequency VSWR 134-1000-002 Stainless Steel/Passivated 50 Ohms 40GHz 1.25 .514 1/4-36UNS-2B O .276 LASER MARK:"1341000002" .236 A/F .315 HEX .618 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 RING, CONTACT PIN & CONTACT BODY : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PEEK NATURAL 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED Between Series, 2.92mm Plug To SMP Male 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.25 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 500 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 6 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: FULL DETENT 68 N MAX, LIMITED DETENT 45 N MAX, SMOOTH BORE 9 N MAX (SMP) 0.23 NM MAX (SMK) 3.2 DISENGAGEMENT FORCE: FULL DETENT 22 N MIN, LIMITED DETENT 9 N MIN, SMOOTH BORE 2.2 N MIN (SMP) 0.23 NM MAX (SMK) 3.3 COUPLING NUT RETENTION: 267 N MIN 3.4 COUPLING PROOF TORQUE: 1.7 NM MIN 3.5 CONTACT RETENTION: 22 N MIN 3.6 DURABILITY: 500 CYCLES MIN (SMK) FULL DETENT 100 CYCLES MIN, LIMITED DETENT 500 CYCLES MIN, SMOOTH BORE 1000 CYCLES MIN (SMP) Part Number Material Impedance 134-1000-003 Stainless Steel/Passivated 50 Ohms Maximum Frequency MODEL NO. VSWR PACKAGING 40GHz 1.25 4. ENVIRONMENT: ONE PCSMETHOD PER BAG 107, CONDITION B. 134-1000-003 4.1 THERMAL SHOCK: MIL-STD-202, 4.2 OPERATING TEMPERATURE: -55TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .514 1/4-36UNS-2B O .276 LASER MARK:"1341000003" .315 HEX .236 A/F .731 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY, CONTACT BODY & SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN : GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR: PEEK NATURAL 1.4 C RING: BERYLLIUM COPPER 1.5 GASKET: SILICONE RED Between Series, 2.92mm Jack To SMPM Female MODEL NO. Part Number Material Impedance 134-1000-004 Stainless Steel/Passivated 50 Ohms 134-1000-004 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.25 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 500 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 6 MILLIOHM MAX PACKAGING 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN ONE PCS PER BAG Maximum Frequency VSWR 40GHz 1.25 3. MECHANICAL: 3.1 ENGAGEMENT / DISENGAGEMENT FORCE: 0.23 NM MAX(SMK) , 45 N MAX/ 9N MIN (SMP) 3.2 COUPLING NUT RETENTION: 267 N MIN 3.3 COUPLING PROOF TORQUE: 1.7 NM MIN 3.4 CONTACT RETENTION: 22N MIN 3.5 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 .785 LASER MARK:"1341000004" O .315 O .354 1/4-36UNS-2A .309 A/F .272 A/F .861 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN& CONTACT BODY: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR1: ULTEM1000 AMBER 1.4 INSULATOR2: PTFE WHITE 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.3MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 325 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 6 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: 0.23 NM MAX (SMK) FULL DETENT 19 N MAX; SMOOTH BORE: 11 N MAX (SMPM) 3.2 DISENGAGEMENT FORCE: 0.23 NM MAX (SMK) FULL DETENT 29 N MAX; SMOOTH BORE: 11 N MAX (SMPM) 3.3 CONTACT RETENTION: 22 N MIN 3.4 DURABILITY: 500 CYCLES MIN (SMK) FULL DETENT 100 CYCLES MIN, SMOOTH BORE: 500 CYCLES MIN (SMPM) 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 37 Model No. RoHS2 134-1000-004 Cage Code 3RD ANGLE PROJECTION 2.92mm Between Series, 2.92mm Jack To SMPM Male Part Number Material Impedance Maximum Frequency VSWR 134-1000-005 Stainless Steel/Passivated 50 Ohms 40GHz 1.25 PACKAGING MODEL NO. 134-1000-005 ONE PCS PER BAG REV 001 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:51:54 +08'00' ECO ECO-17-0032 DATE 11/28/2017 .785 LASER MARK:"1341000005" O .315 1/4-36UNS-2A .309 A/F O .354 .272 A/F .944 REF NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY& COTACT BODY: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR1: ULTEM1000 AMBER 1.4 INSULATOR2: PTFE WHITE 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.3 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 325 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 6 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN Between Series, 2.92mm Plug To SMPM Female 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: 0.23 NM MAX (SMK);FULL DETENT 19 N MAX (SMPM) 3.2 DISENGAGEMENT FORCE: 0.23 NM MAX (SMK); FULL DETENT 29 N MAX (SMPM) 3.3 CONTACT RETENTION: 22 N MIN 3.4 DURABILITY: 500 CYCLES (SMK); FULL DETENT: 100 CYCLES MIN(SMPM) 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.2 OPERATING TEMPERATURE: -55TO 125°C 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Model No. Material Impedance Maximum Frequency VSWR 134-1000-006 Stainless Steel/Passivated 50 Ohms 40GHz 1.25 MODEL NO. 134-1000-006 PACKAGING ONE PCS PER BAG 134-1000-005 Cage Code RoHS2 Part Number This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. .XXX u.02 .XXXX u.01 ANGLES u5v Title: 3RD ANGLE PROJECTION Johnson ADAPTER ASSEMBLY,SMK(2.92mm) JACK TO SMPM PLUG Rev Drawing No. Drawn by: Date: Betty.Yu 10/10/2017 00 134-1000-005 Size Workmanship Std: DO NOT SCALE DRAWING C 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:52:18 +08'00' NONE REV 001 ECO ECO-17-0032 Sheet 1 of DATE 11/28/2017 .785 1/4-36UNS-2B O .315 .315 HEX .309 A/F .272 A/F LASER MARK:"1341000006" NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY& SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN& CONTACT BODY: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR1: ULTEM1000 AMBER 1.4 INSULATOR2: PTFE WHITE 1.5 C RING: BERYLLIUM COPPER 1.6 GASKET: SILICONE RED O .354 .890 REF 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.3 MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 325 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 6 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN Between Series, 2.92mm Plug To SMPM Male 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: 0.23 NM MAX (SMK) FULL DETENT 19 N MAX, SMOOTH BORE 11 N MAX (SMPM) 3.2 DISENGAGEMENT FORCE: 0.23 NM MAX (SMK) FULL DETENT 29 N MAX, SMOOTH BORE 11N MAX (SMPM) 3.3 COUPLING PROOF TORQUE: 1.7 NM MIN.(SMK) 3.4 COUPLING NUT RETENTION: 267N MIN 3.5 CONTACT RETENTION: 22 N MIN 3.6 DURABILITY: 500 CYCLES MIN (SMK) FULL DETENT 100 CYCLES MIN, SMOOTH BORE 500 CYCLES MIN (SMPM) MODEL NO. PACKAGING R 0 数字签名人 lin.ma@cn.cinch.com DN:cn=lin.ma@cn.cinch.com 日期:2017.12.05 13:53:02 +08'00' 4. ENVIRONMENT: 4.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. ONE PCS PER BAG 134-1000-007 4.2 OPERATING TEMPERATURE: -55TO 125°C Part Number 134-1000-007 Material Stainless Steel/Passivated 4.3 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 4.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.6 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 Impedance 50 Ohms Model No. Maximum Frequency VSWR 40GHz .315 HEX 1. MATERIAL & FINISH: 1.1 BODY,CONTACT BODY& SHELL: PASSIVATED STAINLESS STEEL 1.2 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.3 INSULATOR1: ULTEM1000 AMBER 1.4 INSULATOR2: PTFE WHITE 1.5 C RING: BERYLLIUM COPPER 1.6 GASKET: SILICONE RED 38 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: 0-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.23MAX 2.4 DIELECTRIC WITHSTADING VOLTAGE: 325 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENER CONTACT: 6 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 3. MECHANICAL: 3.1 ENGAGEMENT FORCE: 0.23NM MAX (SMK),FULL DETENT 19 N MAX (SMPM) 3.2 DISENGAGEMENT FORCE: 0.23NM MAX (SMK),FULL DETENT 29 N MAX (SMPM) 3.3 COUPLING PROOF TORQUE: 1.7 NM MIN. 3.4 COUPLING NUT RETENTION: 267 N MIN 3.5 CONTACT RETENTION: 22 N MIN 3.6 DURABILITY: 500 CYCLES MIN (SMK), FULL DETENT 100 CYCLES MIN (SMPM) .XXX u.02 .XXXX u.01 ANGLES u5v .785 O .315 NOTES: UNLESS OTHERWISE SPECIFIED 2011/65/EU UNLESS OTHERWISE SPECIFIED UNITS: INCH 1.25 1/4-36UNS-2B .309 A/F .272 A/F LASER MARK:"1341000007" .972 REF 134-1000-006 Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. O .354 Title: 3RD ANGLE PROJECTION Johnson ADAPTER ASSEMBLY,SMK(2.92mm) PLUG TO SMPM JACK Rev Drawing No. Drawn by: Date: Betty.Yu 10/10/2017 134-1000-006 Size C DO NOT SCALE DRAWING Workmanship Std: NONE 00 Sheet 1 of 2.92mm Terminations Termination Jack MODEL NO. Part Number Material Impedance 145-0701-881 Stainless Steel/Passivated 50 Ohms 145-0701-881 PACKAGING ONE PCS PER BAG Maximum Frequency VSWR 40GHz 1.30 LASER MARK " 1450701881" 1/4-36UNS-2A  .350 8mm WRENCH FLATS .642 NOTES: UNLESS OTHERWISE SPECIFIED 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 INNER BODY: GOLD PLATED BRASS 1.3 CONTACT PIN: GOLD PLATED BERYLLIUM COPPER 1.4 INSULATOR: PEEK, NATURAL 1.5 RESITOR: 50 OHMS +/- 1% 1/4W Termination Plug PACKAGING 2. ELECTRICAL: MODEL NO. 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-40 GHz 145-0801-811 ONE PCS PER BAG 2.3 RETURN LOSS: -20DB MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENTER CONTACT: 3 MILLIOHMS MAX 2.5.2 OUTER CONTACT: 2 MILLIOHMS MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 2.7 WORKING VOLTAGE: 250 VRMS MAX Part Number Material Impedance Maximum Frequency VSWR 145-0701-881 Stainless Steel/Passivated 50 Ohms 40GHz 1.30 3. MECHANICAL: 3.1 ENGAGEMENT AND DISENGAGEMENT FORCE: 0.23 MN MAX 3.2 COUPLING TORQUE RECOMMENDED: 0.8 NM TO 1.1 NM 3.3 COUPLING TORQUE PROOF: 1.7 NM 3.4 CONTACT RETENTION: 22 N MIN 3.5 DURABILITY: 500CYCLES MIN 4. ENVIRONMENT: LASER MARK " 1450801811" 4.1 OPERATING TEMPERATURE: -55 TO 125°C 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B. 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 1/4-36UNS-2B 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.6 SALT SPRAY: MIL-STD-202, METHOD 101, CONDITION B 8mm HEX  145-0701-881/890   RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2011/65/EU   UNLESS OTHERWISE SPECIFIED UNITS: INCH  .XXX .02 Betty.Yu  .XXXX .01 ANGLES 5   C 05/31/2019  .354 8mm WRENCH FLATS 7mm WRENCH FLATS NOTES: UNLESS OTHERWISE SPECIFIED .800 REF 1. MATERIAL & FINISH: 1.1 BODY & NUT: PASSIVATED STAINLESS STEEL 1.2 INNER BODY: GOLD PLATED BRASS 1.3 CONTACT PIN, C RING: GOLD PLATED BERYLLIUM COPPER 1.4 INSULATOR: PEEK, NATURAL 1.5 GASKET: SILICONE RED 1.6 RESITOR: 50 OHMS +/- 1% 1/4W 2. ELECTRICAL: 2.1 IMPEDANCE: 50 OHMS 2.2 FREQUENCY RANGE: DC-40 GHz 2.3 VOLTAGE STANDING WAVE RATIO: 1.2 MAX 2.4 DIELECTRIC WITHSTANDING VOLTAGE: 750 VRMS MIN 2.5 CONTACT RESISTANCE: 2.5.1 CENTER CONTACT: 3 MILLIOHM MAX 2.5.2 OUTER CONTACT: 2 MILLIOHM MAX 2.6 INSULATOR RESISTANCE: 5000 MEGOHM MIN 2.7 WORKING VOLTAGE: 250 VRMS MAX 3. MECHANICAL: 3.1 ENGAGEMENT AND DISENGAGEMENT FORCE: 0.23 NM MAX 3.2 COUPLING TORQUE RECOMMENDED: 0.8 NM TO 1.1 NM 3.3 COUPLING PROOF TORQUE: 1.7 NM 3.4 COUPLING NUT RETENTION: 267 NM 3.5 CONTACT RETENTION: 22 NM 3.6 DURABILITY: 500 CYCLES MIN 4. ENVIRONMENT: 4.1 OPERATING TEMPERATURE: -55 TO 125°C 4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B 4.3 SHOCK: MIL-STD-202, METHOD 213, CONDITION I 4.4 VIBRATION: MIL-STD-202, METHOD 204, CONDITION D 4.5 MOISTURE RESISTANCE: MIL-STD-202, METHOD 106 4.6 SALT SPRAY: MIL-STD-202 METHOD 101, CONDITION B  145-0801-811/820  RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 39 2011/65/EU   2.9 CH  UNLESS OTHERWISE SPECIFIED UNITS: INCH  .XXX .02 .XXXX .01 ANGLES 5 Betty.Yu  05/31/2019  C DO Tooling 2.92mm Cabled Connectors Accurate assembly of the 2.92mm cabled connectors is obtained with the tools listed below. Industry standard devices are used if possible for customer convenience and tool compatibility. Item Part Number Description A 140-0000-962 Semi-rigid cable vise (does not include inserts(B) or vise stop (F)) B 140-0000-964 140-0000-965 Cable clamp inserts, 0.086 semi-rigid Cable clamp inserts, 0.141 semi-rigid C 140-0000-960 140-0000-961 Contact soldering tool, 0.086 plug Contact soldering tool, 0.141 plug D 140-0000-958 140-0000-959 Body soldering tool, 0.086 plug Body soldering tool, 0.141 plug E 140-0000-957 Bead assembly tool, Semi-rigid plugs, all cables F 140-0000-968 Vise stop, (2.92mm) 40 Application Notes 2.92mm Solder Type Straight Plugs for Semi-Rigid Cables 1 2 1 Identify connector parts (5 piece parts) and tools (5 tools.) 2 Strip cable jacket and dielectric to dimension shown. 3 3 4 4 Remove excess solder from contact with a sharp blade and clean contact. Check for presence of excess solder by sliding body soldering tool over the contact. Remove soldering tool. 5 Place connector nut and body on cable. Place connector body soldering tool over contact and thread the coupling nut and connector body firmly to the tool. Place cable subassembly into cable soldering vise. Clamp cable and soldering tool securely to insure the cable dielectric expansion will not disturb the cable in the vise during soldering, Place hot soldering iron on the connector body sleeve and apply solder from the opposite side. A low temp solder, such as 60/40 Sn/Pb is recommended for the body solder joint. Allow the soldered joint to cool and remove from fixture. Check contact location to the body. The best electrical results are achieved when the contact location is within a tolerance of 0.060 +/- 0.001. 6 Place bead onto neck portion of the tool. Thread Bead Assembly tool firmly Into the coupling nut. Push the tool’s plunger between your thumb and fingers to assemble the bead. Check bead location. Assemble seal ring onto body. 5 6 Place center contact onto center conductor. Slide contact soldering tool onto contact. Clamp the cable contact and tool into cable soldering vise and solder contact to center conductor. High temperature solder, such as 95/5 Sn/Ag is recommended so that contact solder joint remains stable during body soldering operation. Solder paste is recommended for the contact solder joint to minimize excess solder. The assembled dimension should be as shown. Tool 145-0693-001/002 145-0694-001/002 (for 0.086 semi-rigid) (for 0.141 semi-rigid) Semi-Rigid Cable Vise 140-0000-962 140-0000-962 Vise Stop 140-0000-968 140-0000-968 Bead Assy. Tool 140-0000-957 140-0000-957 Contact Soldering Tool 140-0000-960 140-0000-961 Body Soldering Tool 140-0000-958 140-0000-959 Cable Clamp Insert 140-0000-964 140-0000-965 41 Application Notes Field Replaceable The field replaceable connectors manufactured by Johnson, are easy to install and replace. The hermetic seal is mounted into the circuit module wall and the connector can be removed and replaced without destroying the hermeticity of the circuit housing. The field replaceable connector creates a transition from microstrip circuitry to a coaxial transmission line. The 2.92mm seal pin diameter is 0.012 (0.030) to minimize the capacitive effects on the circuit trace. For optimum electrical performance, ihe transition from the hermetic seal to the microstrip trace must be properly compensated. Compensation involves adjusting the microstrip trace width to minimize any impedance discontinuities found in the transition area. The plot shown below is representative of the typical return loss of a Johnson field replaceable 2.92mm connector. To produce the data shown below, a test fixture is created using the Johnson 2.92mm hermetic seal. The fixture consists of a suitably thick spacer plate with the hermetic seal mounted flush to both surfaces. Two connectors are mounted back to back around the fixture and the VSWR of this test assembly is measured. The calculated return loss trace shown Is equivalent to the square root of the measured VSWR of the test assembly. Since the connectors tested are of identical design. it can be stated with fair accuracy that the calculated data shown represents the response of a single field replaceable connector and its transition to the hermetic seal. Although Johnson does not publish a VSWR specification for field replaceable connectors, typical connector return loss can be expected to be less than -20 dB through 40GHz. A VSWR specification is not stated because an industry standard method for testing field replaceable connectors does not exist. The actual performance of the connector is dependent upon the following: 1. For optimum electrical performance, Johnson recommends the use of our standard 142-1000-033 hermetic seal with a pin diameter of 0.0120 (0.305) ±0.0005 (0.013). 2. It is recommended that the hermetic seal be mounted flush with the circuit housing. Tolerance variations between the hermetic seal and machined housing do not always guarantee an optimum transition to the connector. Some manufacturers recommend an additional counterbore in the circuit housing to accommodate a solder washer during installation of the seal. Johnson does not recommend this type of installation because if the counterbore is not completely filled with solder, electrical discontinuities may be created. 3. The transition between the hermetic seal pin and the microstrip trace will effect electrical performance, as stated above. Several different methods of hermetic seal mounting and seal pin to microstrip trace attachment are used in the industry. Field Replaceable Test Assembly Typical Return Loss Seal Pin & Two 2.92mm Connectors 42 Single 2.92mm Connector, Calculated Application Notes 2.92mm (SMK) End SMK(2.92mm) End Launch Connectors SMK(2.92mm) End Launch Connectors PC Mounting Instructions (Screw-on Type) Launch Connectors PC Mounting Instructions (Screw-on Type) Step A. Position the end launch connector on the pc board and make sure the connector body is fit tightly against the board Step A. Position the end launch connector on the pc board and board edge. edge. Step A. Position make the endsure launch on the pc is board and make sure the the theconnector connector body fit tightly against connector body edge. is fit tightly against board edge. spring washer, Step B. Insert mounting screw # through Step B. board Insert mounting screw the # 1-72 1-72 through spring washer, Step B. Insert mounting screw # 1-72 through spring washer, mounting body,adjust mounting body, pc board and bottom Slightly mounting body, pc board and bottom base. base. Slightly adjust the the pc board and bottom base. Slightly adjust the location and make sure location and make sure the contact pin is centered on Step B. Insert mounting screw # 1-72 through spring washer, location and make sure the contact pin is centered on the the signal mounting body, pc and bottom base. Slightly adjust the the contact pin istrace. centered on board the signal trace. signal trace. location and make sure the contact pin is centered Step C. Tighten the screws and the torque force should not exceed 20 in-oz.on the Step C. Tighten the screws and the torque force should signal trace. Step C. Tighten the screws and the torque force should not not exceed exceed 20 in-oz. 20 in-oz. Optional: C. the Tighten and trace the torque force should not exceed Step D.Step Solder contactthe pin screws on the signal by using a minimal amount of Optional: 20 in-oz. Optional: solder. Ensure the solder flows along with the length of the outside pin to Step D. Solder the contact Step Solder thejoint. contact pin pin on on the the signal signal trace trace by by using using a a minimal minimal createD.a good solder of solder. Ensure the solder flows along with the Optional: amount amount of solder. Ensure the solder flows along with the Step E. Remove any excess solder and clean all flux and other residues from the length of the outside pin to create a good solder joint. Step D. Solder the contact pin on the signal trace by using a minimal length of the outside pin to create a good solder joint. solder joint area. (Note: Any excess solder or flux will affect performance.) amount of solder. Ensure the solder flows along with the Step E. Remove any excess solder and all flux other length of the outside to create a good joint. Step E. Remove any excesspin solder and clean clean all solder flux and and other residues from the solder joint area. residues from the solder joint area. (Note: flux will performance.) Step E. Remove anyexcess excesssolder solderor all flux and other (Note: Any Any excess solder orand fluxclean will affect affect performance.) residues from the solder joint area. (Note: Any excess solder or flux will affect performance.) Step A.Instructions Position the end launch connector PC Mounting (Screw-on Type) on the pc board and make sure the connector body is fit tightly against the 43                                                                     Application Notes Test Data with Coplanar Waveguide Circuit Board DUT information: SMK(2.92mm) End Launch C SMK(2.92mm) End Launch Connector Test Data with Coplanar Waveguide Circuit Board Test Data with Coplanar Waveguide Circuit Board 2.92mm End Launch Screw-on Type (Connector P/N.145-0701-802) DUTJack info: Rogers RO3003DUT Circuitinfo: Board (0.010” Substrate Thickness, 1oz Copper Foil) End Launch Screw-on Type Jack (Connector P/N.145-0701-802) Signal Trace: Grounded Coplanar2.92mm Waveguide (GCPW) ( ) 2.92mm End Launch Type Jack (Connector P/N.145-0701-802) .010” Substrate Thickness, 1oz Copper Foil RogersScrew-on RO3003 Circuit Board ( ) (Note: GCPW is the recommended transmission line structure on the circuit board for this connector, but other type trace line .010” Substrate Copper Foil Rogers RO3003 Circuit Board Signal Trace: Grounded Coplanar Thickness, Waveguide1oz (GCPW) such as microstrip also can be used and resulted in good performance.) Signal Trace: Grounded Coplanar (GCPW) (Note: GCPW is the Waveguide recommended transmission line structure on the circuit board for this co (Note: GCPW other is the type recommended transmission line structure circuit forinthis connector, but trace line such as microstrip also can on be the used and board resulted good performance. other type trace line such as microstrip also can be used and resulted in good performance.) 44 About Cinch Connectivity Solutions For over 100 years, Cinch Connectivity Solutions has manufactured high-quality and reliable high-performance connectors and cable assemblies. Cinch is recognized as a world class connectivity supplier of RF, fiber optic, hybrid, microwave components, circular, d-subminiatures, modular rectangular, electronic enclosures and cable assemblies. Cinch provides innovative solutions to the military, commercial aerospace, networking, telecommunication, test and measurement, oil and gas and other harsh environment industries. For more information, please contact us: North America +1 507.833.8822 ccsorders@us.cinch.com Asia-Pacific +86 21 5442 7668 ccs.asia.sales@as.cinch.com Europe, Middle East +44 (0) 1245 342060 CinchConnectivity@eu.cinch.com belfuse.com/cinch.com ca-ccs-john-mmwave-catalog-05252022 © 2022 Cinch Connectivity Solutions
145-0801-612 价格&库存
很抱歉,暂时无法提供与“145-0801-612”相匹配的价格&库存,您可以联系我们找货
  • 4+278.14142
  • 9+272.96647
  • 17+267.79152
  • 34+262.70121
  • 50+257.52626
库存:85
