CAN1628T
CAN1628T
    CANAANTEK(迦美)
    QFN9_1.1X1.1MM
    CAN1628T是一款CMOS绝缘体上硅(SOI)单刀三掷(SP3T)射频开关。其高线性性能和低插入损耗使其成为4GLTE和CSFB4GLTE手机应用的理想选择。
CAN1628T 数据手册
1 CAN1628T SP3T Switch Product Datasheet Rev 1.0 July, 2018 This datasheet is intended for customer’s evaluation and application of the CAN1628T device. Under no circumstances it should be circulated outside the customer’s company. This datasheet is preliminary and CanaanTek reserves the right to modify and to improve the data. 2 PRODUCT DESCRIPTION CAN1628T is a CMOS silicon-on-insulator (SOI), APPLICATIONS single-pole, triple-throw (SP3T) switch. The high ⚫ 4G LTE bands and PA mode switching linearity performance and low insertion loss makes ⚫ Antenna switch for multimode systems the device an ideal choice for both the SGLTE and CSFB 4G LTE handsets applications. CAN1628T The CAN1628T SP3T switch is provided in a compact Quad Flat No-Lead (QFN) 1.1 x 1.1 mm package. RF2 A functional block diagram is shown in Figure 1. RF3 The pin configuration and package are shown in RF1 RF4 Figure 2. Signal pin assignments and functional pin descriptions are provided in Table 1. VDD Vc1 Vc2 FEATURES ⚫ Broadband frequency range: 0.1 to 3.0GHz ⚫ Low insertion loss: 0.46 dB @ 2.7 GHz ⚫ High isolation: 25 dB up to 2.7 GHz ⚫ No external DC blocking capacitors required ⚫ Positive low voltage control: VCTL = 1.30 to 3.30 V, VDD = 2.5 to 5.0 V ⚫ HBM ESD exceeds 2kV in all ports ⚫ Small, QFN (9-pin, 1.1 x 1.1 mm) package (MSL1, 260 °C per JEDEC J-STD-020) Figure 1. CAN1628T Block Diagram (QFN Top View) 1 VC1 8 VC2 7 VDD 2 RF4 9 GND 6 GND 3 RF2 4 RF1 5 RF3 Figure 2. CAN1628T Pin out – 9-Pin QFN 3 Table 1. CAN1628T Signal Pin Descriptions Pin Name Description 1 VC1 Switch logic control input 2 RF4 RF port 3 RF2 RF port 4 RF1 Antenna (Common port) 5 RF3 RF port 6 GND Ground 7 VDD Supply Voltage 8 VC2 Switch logic control input 9 GND Ground Note: Exposed pad must be grounded. Functional Description The CAN1628T includes an internal negative voltage generator and decoder that eliminate the need for external DC blocking capacitors on the RF ports. No external components are required for proper operation. DC decoupling capacitors may be added on the VDD and control lines if necessary. Switching is controlled by two control voltage inputs, VC1 and VC2. Depending on the logic voltage level applied to the control pins, the RF1 (RF common) pin is connected to one of three switched RF outputs (RF2, RF3, or RF4) through a low insertion path, while the path between the RF1 pin and the other RF pins is in a high isolation state. Electrical and Mechanical Specifications The absolute maximum ratings of the CAN1628T are provided in Table 2. Electrical specifications are provided in Table 3. The state of the CAN1628T is determined by the logic provided in Table 4. 4 Table 2. CAN1628T Absolute Maximum Ratings (Note 1) Symbol Minimum Maximum Units Supply voltage VDD 2.5 5.0 V Control voltage (Note 2) VCTL 1.30 3.30 V Input power PIN +36 dBm Storage temperature TSTG -40 +125 ℃ Operating temperature TOP -40 +85 ℃ ESD 2000 Electrostatic Discharge: Human Body Model (HBM), Class 2 V Note1: Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed here may result in permanent damage to the device. Note 2: Any bias voltage applied to the VC1, VC2 pins may damage the device if there is no bias voltage also present on the VDD pin. Maximum control voltage cannot exceed VDD. CAUTION: Although this device is designed to be as robust as possible, Electrostatic Discharge (ESD) can damage this device. This device must be protected at all times from ESD. Static charges may easily produce potentials of several kilovolts on the human body or equipment, which can discharge without detection. Industry-standard ESD precautions should be used at all times. 5 Table 3. CAN1628T Electrical Specifications (Note 1) (VDD = 2.85 V, VC1 = VC2 = 1.8V, TOP = +25 °C, PIN = 0 dBm, Characteristic Impedance [Z0] = 50 Ω, Unless Otherwise Noted) Parameter Symbol Test Condition Min Typical Max Units 0.36 0.40 0.46 0.56 0.60 0.70 dB dB dB RF Specifications Insertion loss IL Isolation ISO Return loss |S11| 0.8 to 3.0 GHz Input 0.1 dB compression point P0.1dB 2nd harmonic 3rd harmonic 0.8 to 1.0 GHz 1.0 to 2.2 GHz 2.2 to 3.0 GHz 28 24 20 35 29 25 dB dB dB 18 23 dB 0.8 to 3.0 GHz, RF1 to RF2, RF3 and RF4 +34 dBm 2fo 0.8 to 3.0 GHz, PIN = +26 dBm +88 dBc 3fo 0.8 to 3.0 GHz, PIN = +26 dBm +83 dBc Switching rise time 10/90% RF 250 ns Switching fall time 90/10% RF 250 ns Switching on time 50% VCTL to 10/90% RF 1500 ns Switching off time 50% VCTL to 90/10% RF 1500 ns Startup time Shutdown state to any RF switch state 20 μs 0.8 to 1.0 GHz 1.0 to 2.2 GHz 2.2 to 3.0 GHz DC Specifications Control voltage: High Low VCTL_HIGH 1.30 VCTL_LOW 0 Supply voltage VDD Supply current IDD Control current Ictl Shutdown mode supply current Ioff 2.5 1.80 2.85 3.30 (Note2) 0.4 V 5.0 V V 65 μA V1 = V2 = 1.8 V 1 μA VDD = 2.85V, V1 = V2 = 0 V 10 μA Note1: Performance is guaranteed only under the conditions listed in this Table. Note 2: Control voltage should not exceed supply voltage. 6 Table 4. CAN1628T Truth Table Mode VC1 VC2 RF1-RF3 0 1 RF1-RF2 1 0 RF1-RF4 1 1 Note: “1” = 1.20 to 3.30 V; “0” = 0 to 0.4 V. Any state other than described in this Table places the switch into an undefined state. Evaluation Board Description The CAN1628T Evaluation Board is used to test the performance of the CAN1628T SP3T Switch. The impedance of all RF traces is 50 Ω. An Evaluation Board schematic diagram is provided in Figure 3. An assembly drawing for the Evaluation Board is shown in Figure 4. J1 4 RF1 5 J3 RF3 RF2 3 J2 CAN1628T 6 GND RF4 2 VDD C1 7 J4 VC1 VDD C2 VC1 VC2 1 C3 8 VC2 C4 Figure 3. CAN1628T Evaluation Board Schematic 7 Figure 4. CAN1628T Evaluation Board Assembly Diagram 8 Package Dimensions Package dimensions for the CAN1628T are shown in Figure 5. Package Outline PCB Metal, Solder, and Stencil Patterns Figure 5. CAN1628T Package Dimensions 9 Package and Handling Information Instructions on the shipping container label regarding exposure to moisture after the container seal is broken must be followed. Otherwise, problems related to moisture absorption may occur when the part is subjected to high temperature during solder assembly. The CAN1628T is rated to Moisture Sensitivity Level 1 (MSL1) at 260 °C. It can be used for lead or lead-free soldering. Care must be taken when attaching this product, whether it is done manually or in a production solder reflow environment. Production quantities of this product are shipped in a standard tape and reel format. 10 Revision History Revision Release Date Description Rev1.0 2018.07 First Version
CAN1628T 价格&库存
很抱歉,暂时无法提供与“CAN1628T”相匹配的价格&库存,您可以联系我们找货
