HSBA4048
N-Ch 40V Fast Switching MOSFETs
Product Summary
General Description
100% UIS Tested
Advanced Trench Technology
Low Gate Charge
High Current Capability
RoHS and Halogen-Free Compliant
Applications
VDS
40
V
RDS(ON),max
1.8
mΩ
ID
100
A
PRPAK5X6 Pin Configuration
⚫ SMPS Synchronous Rectification
⚫ DC/DC Converters
⚫ Or-ing
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
40
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
IDM
EAS
IAS
PD@TC=25℃
±20
V
Continuous Drain Current, VGS @
10V1,6
100
A
10V1,6
82
A
400
A
400
mJ
40
A
125
W
Pulsed Drain
Current2
Single Pulse Avalanche
Energy3
Avalanche Current
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
50
℃/W
1
℃/W
1
HSBA4048
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance 2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
40
V
VGS=10V , ID=20A
1.5
1.8
VGS=4.5V , ID=20A
2.0
2.6
VGS=VDS , ID =250uA
1.2
1.6
2.2
VDS=32V , VGS=0V , TJ=25℃
1
VDS=32V , VGS=0V , TJ=55℃
5
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=20A
53
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.0
Qg
Total Gate Charge (4.5V)
45
Qgs
Gate-Source Charge
12
Qgd
Gate-Drain Charge
18.5
Td(on)
VDS=15V , VGS=10V , ID=20A
18.5
Rise Time
VDD=15V , VGS=10V , RG=3.3,
9
Turn-Off Delay Time
ID=20A
58.5
Fall Time
32
Ciss
Input Capacitance
3972
Coss
Output Capacitance
1119
Crss
Reverse Transfer Capacitance
82
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
100
A
VGS=0V , IS=1A , TJ=25℃
1.2
V
Tr
Td(off)
Tf
Turn-On Delay Time
nC
VDS=20V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current 1,6
Voltage 2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.5mH,IAS=40A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as I D and I DM , in real applications , should be limited by total power dissipation.
6.Package limitation current is 100A.
www.hs-semi.cn
Ver 2.0
2
HSBA4048
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs G-S Voltage
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
Fig.5 Normalized VGS(th) vs TJ
www.hs-semi.cn
Fig.6 Normalized RDSON vs TJ
Ver 2.0
3
HSBA4048
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
P DM
SINGLE
T ON
T
D = TON/T
TJpeak = TC+P DMXRθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
10
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
BVDSS
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
Fig.11 Unclamped Inductive Switching
Waveform
www.hs-semi.cn
Ver 2.0
4
HSBA4048
PRPAK5X6 Package Outline Dimensions
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSBA4048”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.69360
- 10+2.92680
- 30+2.59200
- 100+2.19240
- 500+1.74960
- 1000+1.64160
