3239-16-1-0500-010-1-TS
    CNC
3239-16-1-0500-010-1-TS 数据手册
UL3239 Silicone Rubber Wire C-UL type TV-3 UL & cUL Recognition No.: E205197 150°C 3KV-DC Tinned Copper Conductor Silicone Rubber Insulation P/N: 3239-XX-1-0500-0XX-1-TS Conductor Insulation Electrical Character Solid Diameter Composition Insulation Overall Test Sparking Maximum or Stranding No/Diameter of Thickness Diameter / Voltage Test Conductor Diameter AWG Component Wire (mm²) (mm) (mm) (mm) (V/30 min) 0.8 Sec. Ω/km 20°C 24AWG 11/0.16 0.65 1.90(±0.15) 6000-DC 3000AC 96.5 (0.22mm²) Tinned Strands 22AWG 17/0.16 0.65 2.05(±0.15) 6000-DC 3000AC 59.4 (0.33mm²) Tinned Strands 20AWG 21/0.18 0.65 2.25(±0.15) 6000-DC 3000AC 37.4 (0.53mm²) Tinned Strands 18AWG 34/0.18 Tinned Strands 0.65 2.5(±0.15) 6000-DC 3000AC 23.5 (0.84mm²) 16/0.26 Tinned Strands 16AWG 26/0.254 0.65 2.8(±0.15) 6000-DC 3000AC 14.6 (1.25mm²) Tinned Strands 14AWG 37/0.254 0.65 3.3(±0.2) 6000-DC 3000AC 9.15 (2.1mm²) Tinned Strands 12AWG 67/0.254 0.75 4.0(±0.2) 6000-DC 3000AC 5.75 (3.39mm²) Tinned Strands 10AWG 105/0.254 0.85 4.8(±0.2) 6000-DC 3000AC 3.55 (5.3mm²) Tinned Strands Resistance 1. Scope: Concerning on UL758 the size from 24AWG to 10AWG working temperature 150°C UL authorized 3KV-DC to 30KV-DC, this specification is only for 3KV-DC 2. Conductor: Material of Conductor: Tinned Copper Composition of conductor for sizes within the UL 758 specified being showed as Table. 3. Insulation Material: Compound Silicone Rubber. Average thickness of insulation being showed as Table Minimum thickness of insulation at any point: Omission 4. Surface Printing: E205197 AWM STYLE 3239 3KV-DC 150°C □□AWG TYPE TV-3 SILICONE RUBBER 150°C □□AWG VW-1 FT1 EASSAN 5. Electrical and Physical character: Unaged: Elongation:250% Tensile Strength: 1200lbf/in² After aged: Test specimens being kept in an air oven with 158°C(±1°C) for 60days Elongation:25% result of unaged test specimen Tensile Strength: 60% result of the unaged test specimen. Sparking test: 3KV AC/0.8 Second Resistant to: Oil, extremes of hot & cold, flexing, high Voltage spikes Flame Test: VW-1 & FT1 : Conforming to UL758 method to test 6. Electronical Voltage Test: 3 KV DC test / 1 minutes, no break down. 7. Dielectric Voltage-withstand test of insulation: 7000 VDC/min 8. Environmental Approvals: Conforms all RoHS directives as laid out in (RoHS) Directive 2011/65/EU, 2015/863/EU Annex II, without Exemption. 9. Packing: 500ft per reel, Tolerance -1% 10. Country of origin: Taiwan P/N’s & COLORS 3239-XX-1-0500-001-1-TS 3239-XX-1-0500-002-1-TS 3239-XX-1-0500-003-1-TS 3239-XX-1-0500-004-1-TS 3239-XX-1-0500-005-1-TS BLACK WHITE YELLOW RED BLUE 3239-XX-1-0500-006-1-TS 3239-XX-1-0500-007-1-TS 3239-XX-1-0500-008-1-TS 3239-XX-1-0500-011-1-TS BROWN GREEN ORANGE GREEN + YELLOW
3239-16-1-0500-010-1-TS 价格&库存
很抱歉,暂时无法提供与“3239-16-1-0500-010-1-TS”相匹配的价格&库存,您可以联系我们找货
