SWR-201-NRTN-S02-SA
SWR-201-NRTN-S02-SA
    SULLINS
    SWR-201-NRTN-S02-SA
SWR-201-NRTN-S02-SA 数据手册
Wafers SWR201 Series Single Row Wafer 2.0 mm [.079”] Contact Centers, Straight/Right Angle SPECIFICATIONS • • • • • • • • • • Insulator Material: Nylon, UL 94V-0 Color: White Contact Material: Brass Contact Resistance: 20 milli Ohms Max Contact Plating: .000020” Min. Nickel Underplate, Pure Tin, Bright Overall Current Rating: 1 Amp Dielectric Withstanding Voltage: 800 VAC Insulator Resistance: 1000 Megohms Minimum Operating Temperature: -25°C to +85°C Voltage Rating: 125 VAC/DC Mates with SWH201 Series Single Row Housing PCB LAYOUT A 2.00 [.079”] 0.80±0.05 [.031” ±.002”] Wafers P.C. BOARD THICKNESS: 0.80 [.031”] - 1.60 [.063”] PART NUMBER OPTIONS SWR201-NRTN-S16 -SA - WH TERMINATION TYPE SA = End Pins Kink Right RL = Right Angle With Kinked End Pins NUMBER OF POSITIONS 02 thru 16 See Chart Below PART NUMBER POSITIONS/ CONTACTS SWR201-NRTN-S02-_ _-WH SWR201-NRTN-S03-_ _-WH SWR201-NRTN-S04-_ _-WH SWR201-NRTN-S05-_ _-WH SWR201-NRTN-S06-_ _-WH SWR201-NRTN-S07-_ _-WH SWR201-NRTN-S08-_ _-WH SWR201-NRTN-S09-_ _-WH SWR201-NRTN-S10-_ _-WH SWR201-NRTN-S11-_ _-WH SWR201-NRTN-S12-_ _-WH SWR201-NRTN-S13-_ _-WH SWR201-NRTN-S14-_ _-WH SWR201-NRTN-S15-_ _-WH SWR201-NRTN-S16-_ _-WH 02/02 03/03 04/04 05/05 06/06 07/07 08/08 09/09 10/10 11/11 12/12 13/13 14/14 15/15 16/16 A mm 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 B in 0.079 0.157 0.236 0.315 0.394 0.472 0.551 0.630 0.709 0.787 0.866 0.945 1.024 1.102 1.181 mm 5.90 7.90 9.90 11.90 13.90 15.90 17.90 19.90 21.90 23.90 25.90 27.90 29.90 31.90 33.90 in 0.232 0.311 0.390 0.469 0.547 0.626 0.705 0.783 0.862 0.941 1.020 1.098 1.177 1.256 1.335 DIMENSIONS Dimensions in [ ] are in inches, all others are in millimeters. SWR201-NRTN-S_ _-SA-WH SWR201-NRTN-S_ _-RL-WH 6.00 [.236] 6.00 [.236] 3.40 [.134] B 2.00 [.079] TYP 0.50 [.020] SQ. A ±0.20 [±.008] B 4.80 [.189] 1.70 ±0.20 [.067 ±.008] 3.40 [.134] 0.50 [.020] SQ. 4.60 [.181] 2.00 [.079] TYP. A 132 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
SWR-201-NRTN-S02-SA 价格&库存
很抱歉,暂时无法提供与“SWR-201-NRTN-S02-SA”相匹配的价格&库存,您可以联系我们找货
