Preliminary Datasheet
LP28303A
2.5A Synchronous Buck Li-ion Charger
General Description
Features
The LP28303A is a 2.5A Li-Ion battery charger. It
Input voltage range 4.5V~5.5V
utilizes a 600KHz synchronous buck
Dynamic input current allocation for maximum
converter
topology to reduce power dissipation during charging.
charging rate
Low power dissipation and internal MOSFET allow a
2.5A Maximum Charge Current
physically small charger that can be embedded in a
No External MOSFETs and Blocking Diode
wide range of handheld applications. The LP28303A
includes
complete
charge
termination
circuitry,
automatic recharge and ±1% 4.2V float voltage.
Battery
charge
current,
charge
timeout
Required
Efficiency up to 90%
Constant-Current/Constant-Voltage
with Thermal Regulation to Maximize Charge
and
Rate Without Risk of Overheating
end-of-charge indication parameters are set with
external components. Additional features include
Optional Battery Temperature Monitoring Before
and During Charge Automatic Sleep Mode for
shorted cell detection; temperature qualified charging
Low-Power
and overvoltage protection. The LP28303A is available
in a low profile ESOP8&TDFN-10 and package.
Operation
Over Current Protection
Consumption Available in ESOP8 &
TDFN-10 3*3mm
Order Information
RoHS Compliant and 100% Lead (Pb)-Free
LP28303A
F: Pb-Free
Package Type
SP: ESOP-8
QV: TDFN-10
Typical Application Circuit
VIN
CIN
22uF
LED1
R2
2KΩ
LED2
1
2
3
R4
10KΩ
VIN
SW
CHRG
CS
FULL
BAT
NTC
AGND
VBAT
6
5
L
4.7uH
RCS
25mΩ
CBAT
22uF
4
7
PGND
9
Portable Media Players
Cellular and Smart mobile phone
PDA/DSC
Handheld Battery-Powered Devices
Handheld Computers
Charging Docks and Cradles
Apr.-2017
R1
2KΩ
R3
10KΩ
Applications
LP28303A-00
8
Marking Information
Device
Marking
Package
Shipping
LP28303ASPF
LPS
ESOP8
4K/REEL
LP28303AQVF
LP28303A
TDFN10
5K/REEL
YWX
Marking indication:
Y:Production year W:Production week X: Series Number
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 8
LP28303A
Functional Pin Description
ESOP8
Package Type
Pin
Configurations
CHRG
1
FULL
2
9(PAD)
PGND
TDFN-10
8
VIN
7
AGND
NTC
3
6
SW
VBAT
4
5
CS
AGND
1
10
SW
PGND
2
9
SW
VIN
3
8
CS
CHRG
4
7
BAT
FULL
5
6
NTC
PGND
TDFN-10
TOP VIEW
ESOP-8
(Top View)
Pin Description
Pin No.
ESOP8
TDFN-10
4
1
5
2
Name
CHRG
FULL
6
3
Description
Open-Drain charge status output. When the battery is charging, this pin is pulled low
by an internal N-channel MOSFET.
Open-Drain charge status output. When charging is complete, this pin is pulled low
Negative Temperature Coefficient Thermistor Input. This pin senses the
NTC
temperature of the battery pack and stops the charger when the temperature is out
of range. Connect to GND for disabling this function.
4
7
VBAT
5
8
CS
Current Sense pin.
6
9/10
SW
Switch pin. Connect to external inductor.
7
1
AGND
8
9(PAD)
LP28303A-00
3
2
VIN
PGND
Apr.-2017
Battery pin.
Analog (signal) Ground
Positive Supply Voltage Input. Decouple with a 10µF or larger surface mounted
ceramic capacitor.
Power Ground.
Page 2 of 8
LP28303A
Absolute Maximum Ratings Note 1
VIN pin to GND ------------------------------------------------------------------------------------------------------------ 7V
VBAT pin to GND ---------------------------------------------------------------------------------------------------------- 7V
Other pin to GND ---------------------------------------------------------------------------------------------------------- 7V
Maximum Junction Temperature ---------------------------------------------------------------------------------- 150℃
Operating Ambient Temperature Range (TA) -------------------------------------------------------- -20℃ to 85℃
Maximum Soldering Temperature (at leads, 10 sec) --------------------------------------------------------- 260℃
Note 1.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational
sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect
device reliability.
Thermal Information
Maximum Power Dissipation (ESOP8, PD, TA=25℃) ----------------------------------------------------------- 2W
Thermal Resistance (ESOP8, θJA) ----------------------------------------------------------------------------- 50℃/W
Recommended Operating Conditions
Ambient Temperature Range --------------------------------------------------------------------------- -20℃ to 85℃
ESD Susceptibility
HBM(Human Body Mode) --------------------------------------------------------------------------------------------- 2KV
MM(Machine Mode) --------------------------------------------------------------------------------------------------- 200V
LP28303A-00
Apr.-2017
Page 3 of 8
LP28303A
Electrical Characteristics
(The specifications which apply over the full operating temperature range, otherwise specifications are at
TA=25℃, VIN = 5V, unless otherwise noted.)
Symbol
Parameter
VIN
Adapter/USB Voltage Range
ICC
Input Supply Current
VFLOAT
Regulated Output (Float) Voltage
VCS
IBAT
Current Sense Reference Voltage
(For CS to BAT)
BAT Pin Current
Condition
Min
Typ
4.5
Standby Mode
Max
Units
5.5
V
0.1
(Charge Terminated)
4.158
4.2
mA
4.242
V
VTRIKL
很抱歉,暂时无法提供与“LP28303ASPF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.05956
- 50+1.85998
- 150+1.77444
- 500+1.48429
- 2500+1.44200
- 4000+1.41662
- 国内价格
- 1+1.75714
- 100+1.40140
- 1000+1.25048
- 2000+1.18580
- 4000+1.12112
