RH1B-ULD-DC24V
RH1B-ULD-DC24V
    IDEC(日本和泉)
    插件,14x27.5mm
    无锁存
RH1B-ULD-DC24V 数据手册
Relays & Sockets RH Switches & Pilot Lights RH Series Compact Power Relays Key features • SPDT through 4PDT, 10A contacts • Compact power type relays • Miniature power relays with a large capacity • 10A contact capacity • Compact size saves space Signaling Lights Part Number Selection Part Number Contact Standard RH1B-U 0 RH1V2-U 0 With Indicator RH1B-UL 0 — With Check Button RH1B-UC 0 — With Indicator and Check Button RH1B-ULC 0 — Top Bracket Mounting RH1B-UT 0 — With Diode (DC coil only) RH1B-UD 0 RH1V2-UD 0 DC6V, DC12V, DC24V, DC48V, DC110V With Indicator and Diode (DC coil only) RH1B-ULD 0 — DC12V, DC24V, DC48V, DC110V Standard RH2B-U 0 RH2V2-U 0 With Indicator RH2B-UL 0 RH2V2-UL 0 With Check Button RH2B-UC 0 — With Indicator and Check Button RH2B-ULC 0 — Top Bracket Mounting RH2B-UT 0 — With Diode (DC coil only) RH2B-UD 0 RH2V2-UD 0 With Indicator and Diode (DC coil only) RH2B-ULD 0 RH2V2-ULD 0 Standard RH3B-U 0 RH3V2-U 0 With Indicator RH3B-UL 0 RH3V2-UL 0 With Check Button RH3B-UC 0 — With Indicator and Check Button RH3B-ULC 0 — Top Bracket Mounting RH3B-UT 0 — With Diode (DC coil only) RH3B-UD 0 — With Indicator and Diode (DC coil only) RH3B-ULD 0 — Standard RH4B-U 0 RH4V2-U 0 With Indicator RH4B-UL 0 RH4V2-UL 0 With Check Button RH4B-UC 0 — With Indicator and Check Button RH4B-ULC 0 — Top Bracket Mounting RH4B-UT 0 — With Diode (DC coil only) RH4B-UD 0 RH4V2-UD 0 With Indicator and Diode (DC coil only) RH4B-ULD 0 — AC6V, AC12V, AC24V, AC110-120V, AC220-240V DC6V, DC12V, DC24V, DC48V, DC100-110V DC6V, DC12V, DC24V, DC48V, DC100-110V AC6V, AC12V, AC24V, AC110V, AC120V, AC220V, AC240V DC6V, DC12V, DC24V, DC48V, DC110V DC6V, DC12V, DC24V, DC48V, DC110V AC6V, AC12V, AC24V, AC110V, AC120V, AC220V, AC240V DC6V, DC12V, DC24V, DC48V, DC110V DC6V, DC12V, DC24V, DC48V, DC110V Circuit Breakers PCB terminal relays are designed to mount directly to a circuit board without any socket. AC6V, AC12V, AC24V, AC110V, AC120V, AC220V, AC240V DC6V, DC12V, DC24V, DC48V, DC110V Terminal Blocks 4PDT Coil Voltage Code (Standard Stock in bold) Contactors 3PDT PCB Terminal Timers DPDT Blade Terminal Relays & Sockets SPDT Model Ordering Information When ordering, specify the Part No. and coil voltage code: (example) RH3B-U 800-262-IDEC (4332) • USA & Canada Part No. AC120V Coil Voltage Code 773 Relays & Sockets Signaling Lights Switches & Pilot Lights RH Sockets (for Blade Terminal Models) Relays Standard DIN Rail Mount 1 Finger-safe DIN Rail Mount 1 Through Panel Mount PCB Mount RH1B SH1B-05 SH1B-O5C SH1B-51 SH1B-62 RH2B SH2B-05 SH2B-05C SH2B-51 SH2B-62 RH3B SH3B-05 SH3B-05C SH3B-51 SH3B-62 RH4B SH4B-05 SH4B-05C SH4B-51 SH4B-62 1. DIN Rail mount socket comes with two horseshoe clips. Do not use unless you plan to insert pullover wire spring. Replacement horseshoe clip part number is Y778-011. Hold Down Springs & Clips Appearance Relay For DIN Mount Socket RH1B SY2S-02F1 2 RH2B SY4S-02F1 RH3B SH3B-05F1 2 RH4B SH4B-02F1 2 Leaf Spring (side latch) RH1B, RH2B, RH3B, RH4B SFA-202 3 SFA-302 3 Leaf Spring (top latch) RH1B, RH2B, RH3B, RH4B SFA-101 3 SFA-301 3 Item Relays & Sockets Pullover Wire Spring For Through Panel & PCB Mount Socket 2. Must use horseshoe clip when mounting in DIN mount socket. Replacement horseshoe clip part number is Y778-011. 3. Two required per relay. 2 SY4S-51F1 AC Coil Ratings Circuit Breakers Terminal Blocks Contactors Timers Rated Current (mA) ±15% at 20°C Voltage (V) AC 50Hz SPDT Coil Resistance (Ω) ±10% at 20°C AC 60Hz DPDT 3PDT 4PDT SPDT DPDT 3PDT 4PDT SPDT DPDT 3PDT Operation Characteristics (against rated values at 20ºC) 4PDT 6 170 240 330 387 150 200 280 330 330 9.4 6.4 5.4 12 86 121 165 196 75 100 140 165 165 39.3 25.3 21.2 24 42 60.5 81 98 37 50 70 83 83 153 103 84.5 110 9.6 — 18.1 21.6 8.4 — 15.5 18.2 18.2 — 2,200 1,800 110-120 — 9.410.8 — — — 8.0-9.2 — — — — — — 120 8.6 — 16.4 19.5 7.5 — 14.2 16.5 16.5 — 10,800 7,360 220 4.7 — 8.8 10.7 4.1 — 7.7 9.1 9.1 — 10,800 7,360 220-240 — 4.7-5.4 — — — 4.0-4.6 — — 18,820 — — 240 4.9 — 8.2 9.8 4.3 — 7.1 8.3 — 12,100 9,120 8.3 Max. Continuous Applied Voltage Pickup Voltage Dropout Voltage 110% 80% maximum 30% minimum DC Coil Ratings Voltage (V) Coil Resistance (Ω) ±10% at 20°C Rated Current (mA) ±15% at 20°C SPDT DPDT 3PDT 4PDT 6 128 150 240 250 47 12 64 75 120 125 188 24 32 36.9 60 62 750 48 18 18.5 30 31 100-110 — 8.2-9.0 — 110 8 — 12.8 774 SPDT DPDT Operation Characteristics (against rated values at 20ºC) 3PDT 4PDT 40 25 24 160 100 96 650 400 388 2,660 2,600 1,600 1,550 — — 12,250 — — 15 13,800 — 8,600 7,340 Max. Continuous Applied Voltage Pickup Voltage Dropout Voltage 110% 80% maximum 10% minimum www.IDEC.com Standard coil voltages are in BOLD. Relays & Sockets UL Ratings Resistive Maximum Contact Capacity Model Continuous Current SPDT 10A Resistive Load Inductive Load 1540VA 300W 990VA 210W 1650VA 300W 10A 1100VA 225W Rated Load Ind. Load RH1 RH2 RH3 240V AC 10A General Use RH4 RH1 RH2 RH3 7.5A 7.5A 7A Horsepower Rating RH4 RH1 RH2 RH3 RH4 6.5A 5A 1/3 HP 1/3 HP — Voltage (V) Res. Load 110 AC 10A 7A 120V AC — 10A 10A — 7.5A 7.5A 1/6 HP 1/6 HP — 220 AC 7A 4.5A 30V DC 10A 10A — 7A — — — — — 28V DC — — 10A — — — — — — 30 DC 10A 7A 110 AC 10A 7.5A 220 AC 7.5A 5A 30 DC 10A 7.5A CSA Ratings Resistive Voltage Note: Inductive load for the rated load — cos ø = 0.3, L/R = 7 ms 240V AC TÜV Ratings RH1 RH2 RH3 RH4 240V AC 10A 10A 7.5A 7.5A 30V DC 10A 10A 10A 10A Horsepower Rating General Use RH1 RH2 RH3 RH4 RH1 RH2 RH3 RH4 RH1, 2, 3 10A 10A — 7.5A 7A 7A 7A 5A 1/3 HP 120V AC 10A 10A 10A 10A 7.5A 7.5A — 7.5A 1/6 HP 30V DC 10A 10A 10A 10A 7A 7.5A — — — Relays & Sockets Voltage Signaling Lights DPDT 3PDT 4PDT Allowable Contact Power Voltage Switches & Pilot Lights Contact Ratings RH AC: cos ø = 1.0, DC: L/R = 0 ms Socket Specifications Sockets Terminal Electrical Rating Wire Size Torque Maximum up to 2–#12AWG SH2B-05 SH3B-05 SH4B-05 M3.5 screws with captive wire clamp 300V, 10A Maximum up to 2–#12AWG 9 - 11.5 in•lbs SH1B-05C (coil) M3 screws 250V, 10A (contact) M3.5 screws with captive wire clamp, fingersafe Maximum up to 2–#12AWG 5.5 - 9 in•lbs 9 - 11.5 in•lbs SH2B-05C SH3B-05C SH4B-05C M3.5 screws with captive wire clamp, fingersafe 300V, 10A Maximum up to 2–#12AWG 9 - 11.5 in•lbs Through Panel Mount Socket SH1B-51 SH2B-51 SH3B-51 SH4B-51 Solder 300V, 10A — — SH1B-62 PCB mount 250V, 10A — — PCB Mount Socket SH2B-62 SH3B-62 SH4B-62 PCB mount 300V, 10A — — DIN Rail Mount Sockets Finger-safe DIN Rail Mount Contactors 250V, 10A 5.5 - 9 in•lbs 9 - 11.5 in•lbs Timers SH1B-05 (Coil) M3 screws (contact) M3.5 screws with captive wire clamp Terminal Blocks Accessories Item Appearance Part No. Remarks Aluminum DIN Rail (1 meter length) All DIN rail sockets BNDN1000 The BNDN1000 is designed to accommodate DIN mount sockets. Made of durable extruded aluminum, the BNDN1000 measures 0.413 (10.5mm) in height and 1.37 (35mm) in width (DIN standard). Standard length is 39” (1,000mm). DIN Rail End Stop DIN rail BNL5 9.1 mm wide. Replacement Hold-Down Spring Anchor DIN mount sockets and hold down springs. Y778-011 For use on DIN rail mount socket when using pullover wire hold down spring. 2 pieces included with each socket. 800-262-IDEC (4332) • USA & Canada Circuit Breakers Use with 775 Relays & Sockets Timers Relays & Sockets Signaling Lights Switches & Pilot Lights RH Specifications Contact Material Silver cadmium oxide Contact Resistance 1 50mΩ maximum Minimum Applicable Load Operating Time 2 Release Time 2 Power Consumption (approx.) 24V DC, 30 mA; 5V DC, 100 mA (reference value) SPDT DPDT 20ms maximum 3PDT 4PDT 25ms maximum SPDT DPDT 20ms maximum 3PDT 4PDT 25ms maximum SPDT AC: 1.1VA (50Hz), 1VA (60Hz) DC: 0.8W DPDT AC: 1.4VA (50Hz), 1.2VA (60Hz) DC: 0.9W 3PDT AC: 2VA (50Hz), 1.7VA (60Hz) DC: 1.5W 4PDT AC: 2.5VA (50Hz), 2VA (60Hz) DC: 1.5W Insulation Resistance Dielectric Strength 100MΩ minimum (500V DC megger) SPDT Between live and dead parts: 2,000V AC, 1 minute Between contact and coil: 2,000V AC, 1 minute Between contacts of the same pole: 1,000V AC, 1 minute DPDT 3PDT 4PDT Between live and dead parts: 2,000V AC, 1 minute Between contact and coil: 2,000V AC, 1 minute Between contacts of different poles: 2,000V AC, 1 minute Between contacts of the same pole: 1,000V AC, 1 minute 3 Operating Frequency Electrical: Mechanical: 1,800 operations/hour maximum 18,000 operations/hour maximum Vibration Resistance Damage limits: Operating extremes: 10 to 55Hz, amplitude 0.5 mm 10 to 55Hz, amplitude 0.5 mm Shock Resistance Damage limits: 1,000m/s2 (100G) Operating extremes: 200m/s2 (20G - SPDT, DPDT) 100m/s2 (10G - 3PDT, 4PDT) Mechanical Life Operating Temperature 4 500,000 operations minimum (120V AC, 10A) SPDT 3PDT 4PDT 200,000 operations minimum (120V AC, 10A) SPDT DPDT 3PDT 4PDT –25 to +70°C (no freezing) Operating Humidity 45 to 85% RH (no condensation) Weight (approx.) SPDT: 24g, DPDT: 37g, 3PDT: 50g, 4PDT: 74g Note: Above values are initial values. 1. Measured using 5V DC, 1A voltage drop method 2. Measured at the rated voltage (at 20°C), excluding contact bouncing Release time of relays with diode: 40 ms maximum 3. Relays with indicator or diode: 1000V AC, 1 minute 4. For use under different temperature conditions, refer to Continuous Load Current vs. Operating Temperature Curve. The operating temperature range of relays with indicator or diode is –25 to +40°C. Circuit Breakers Terminal Blocks Contactors Electrical Life 50,000,000 operations minimum DPDT 776 www.IDEC.com Relays & Sockets RH Switches & Pilot Lights Characteristics (Reference Data) Electrical Life Curves AC Load DC Load 1000 1000 (RH1) 120V AC resistive (RH1) Life (¥ 10,000 operations) 500 100 50 20 30V DC inductive 240V AC inductive 1 2 3 120V AC inductive 4 20 240V AC resistive 5 6 7 Load Current (A) 8 9 100V DC inductive 10 10 (RH2) 120V AC resistive 3 4 5 6 Load Current (A) 7 8 9 10 7 8 9 10 7 8 9 10 30V DC resistive 500 Life (¥ 10,000 operations) Life (× 10,000 operations) 2 1000 500 100 50 100 50 240V AC resistive 120V AC inductive 240V AC inductive 30V DC inductive 100V DC resistive 100V DC inductive 20 20 1 2 3 4 5 6 7 Load Current (A) 8 9 10 10 (RH3/RH4) (RH3/RH4) 1000 Life (¥ 10,000 operations) 1 2 3 240V AC resistive 120V AC inductive 4 5 6 Load Current (A) 7 8 9 5 6 Load Current (A) 30V DC inductive 100 50 20 240V AC inductive 4 Contactors 50 3 30V DC resistive 500 100 2 1000 120V AC resistive 500 1 Timers 10 Life (× 10,000 operations) 1 Relays & Sockets (RH2) 1000 10 50 100V DC resistive 10 20 30V DC resistive 100 Signaling Lights Life (× 10,000 operations) 500 100V DC resistive 100V DC inductive 10 10 1 2 3 4 5 6 Load Current (A) (RH2/RH3/RH4) (RH1) 10.0 10.0 AC resistive AC resistive 5.0 AC inductive DC resistive 1.0 1 5 10 AC inductive DC resistive 1.0 DC inductive Circuit Breakers DC inductive 0.5 Load Current (A) Load Current (A) 5.0 0.1 Terminal Blocks Maximum Switching Capacity 0.5 50 100 200 300 Load Voltage (V) 800-262-IDEC (4332) • USA & Canada 0.1 1 5 10 50 100 200 300 Load Voltage (V) 777 Relays & Sockets Continuous Load Current vs. Operating Temperature Curve (Basic Type, With Check Button, and Top Bracket Mounting Type) 90 (RH3/RH4) Note: The rated voltage is applied to the coil. 100 90 90 80 DC Coil 70 60 AC Coil 50 40 30 20 10 80 DC Coil 70 60 50 AC Coil 40 30 20 0 1 2 3 4 5 6 7 8 9 10 Load Current (A) 80 70 60 50 AC/DC Coil 40 30 20 10 10 0 Note: The rated voltage is applied to the coil. 100 Operating Temperature (°C) Operating Temperature (°C) (RH2) Note: The rated voltage is applied to the coil. 100 Operating Temperature (°C) (RH1) Signaling Lights Switches & Pilot Lights RH 0 1 2 3 4 5 6 7 8 9 10 Load Current (A) 1 2 3 4 5 6 7 8 9 10 Load Current (A) Internal Connection (View from Bottom) Basic Type DPDT 3PDT 4PDT Relays & Sockets SPDT With Check Button 1 2 3 4 5 6 7 8 9 10 11 Front Pushbutton 12 Contacts can be operated by pressing the check button. (+) 14 13 (–) With Indicator (-L type) SPDT 3PDT Timers 1 1 5 Below 100V AC/DC 9 13 (–) 14 (+) Contactors 10 13 ( – ) 5 9 13 (–) 6 9 1 100V AC/DC and over 2 5 14 (+) 4PDT 4 1 8 2 5 12 6 9 ( + )14 10 DPDT 3 4 7 8 11 13( – ) 12 ( + )14 1 2 4 1 2 3 4 5 6 8 5 6 7 8 9 10 12 9 10 11 12 13 (–) (+) 14 13 (–) 4 9 12 13( – ) 8 ( + )14 1 4 9 12 13( – ) ( + )14 5 24V AC/ DC and over (+) 14 1 5 Below 24V AC/ DC 8 When the relay is energized, the indicator goes on. • Relay coils less than 100V DC do not contain a protection diode (except DPDT). • Relay coils below 100V use LED indicator, coils above 100V use neon lamp indicator. • LED color of DPDT model is green With Diode (-D type) DPDT 1 1 5 9 13 (–) 14 (+) 3PDT 4 1 5 8 5 9 12 9 13 (–) (+) 14 13 (–) 2 4PDT 4 1 6 8 5 6 7 8 10 12 9 10 11 12 (+) 14 13 (–) Circuit Breakers Terminal Blocks SPDT 778 www.IDEC.com 2 3 4 (+) 14 Contains a diode to absorb the back emf generated when the coil is de-energized. The release time is slightly longer. Available for DC coil only. • Diode Characteristics Reverse withstand voltage: 1,000V Forward current: 1A Relays & Sockets RH SPDT 3PDT 4PDT DPDT 1 5 9 Below 100V DC 13 (–) 14 (+) 14( + ) 9 12 8 ( + )14 13( – ) Contains an LED indicator and a surge absorber, and has the same height as the basic type. 1 4 9 12 5 24V AC/ DC and over 9 13 ( – ) 4 8 13 (–) Signaling Lights 5 1 5 Below 24V AC/ DC 1 100V DC and over Switches & Pilot Lights With Indicator LED & Diode (-LD type) LED color of DPDT model is green. 14 (+) RH2B-U/RH2B-UL/RH2B-UD/RH2B-ULD Dimensions in the ( ) include a hold-down spring. Total length from panel surface including relay socket SH3B-05: 61.5 (63.5) max., SH3B-51: 39.6 (41.6) max. Dimensions in the ( ) include a hold-down spring. ø2.6 hole Dimensions in the ( ) include a hold-down spring. 4.7 4.7 ø2.6 hole 4 5 8 9 12 13 14 35.6 max. 6.4 6.4 21 RH1B-UT 6 8 9 10 11 14 6.4 31 RH2B-UT 4.7 0.5 ø2.6 hole 4.7 0.5 ø2.6 hole Contactors Dimensions in the ( ) include a hold-down spring. 4.7 10 4.7 Total length from panel surface including relay socket SH4B-05: 61.5 (63.5) max., SH4B-51: 39.6 (41.6) max. 1 3.5 14.5 2 3 5 6 7 8 9 10 11 12 5.4 6.4 2 21.5 35.6 max. 12 13 14 27.5 5.9 3.5 8 9 6.4 14 6.4 Terminal Blocks 13 2 35.6 max. 4 4 5 27.5 0.5 1 4.7 6.6 14 43.2 38 9 13 1 27.5 43.2 38 5.9 5 ø2.6 hole 35.6 max. 4 5 13 35.6 max. RH4B-U/RH4B-UL/RH4B-UD/RH4B-ULD 2 1 Timers 14 0.5 1 0.5 0.5 13 14 5.4 35.6 max. 27.5 5 9 27.5 1 7.25 ø2.6 hole RH3B-U/RH3B-UL/RH3B-UD/RH3B-ULD Total length from panel surface including relay socket SH2B-05: 61.5 (63.5) max., SH2B-51: 39.6 (41.6) max. 27.5 Total length from panel surface including relay socket SH1B-05: 61.5 (63.5) max., SH1B-51: 39.6 (41.6) max. 4.7 RH1B-U/RH1B-UL/RH1B-UD/RH1B-ULD Relays & Sockets Dimensions (mm) 41 RH4B-UT 0.5 4.7 2 ø2.6 hole 4 14 2 3 31.5 35.6 max. 6.4 35.6 max. 6.4 7.25 2 7.25 21.5 42 max. 800-262-IDEC (4332) • USA & Canada 4 5 6 7 8 9 10 11 12 13 28 8 12 5.9 1 6 10 44 38 2 5 9 28 43.2 38 5.9 1 13 3.5 0.5 4.7 ø2.6 hole Circuit Breakers 3.5 4.7 10 10 10 10 4.7 10 RH3B-UT 14 28 41.5 779 Relays & Sockets Dimensions con’t (mm) RH1V2-U/RH1V2-UD RH2V2-U/RH2V2-UL/RH2V2-UD 8-ø2.4 holes 4.7 0.5 3-ø2.4 holes 12 14 7.8 10 2 14 8 9 35.6 max. 4.4 RH3V2-U/RH3V2-UL/RH3V2-D 21 4.6 14.2 RH4V2-U/RH4V2-UL/RH4V2-UD 11-ø2.4 holes 10 30 10 10 7.25 31 4 6 7 8 9 10 11 12 14 0.5 4.6 13.15 3 7.8 2 5 13 7.25 14 13 27.5 1 0.5 8 11 7.8 4 10 0.5 35.6 max. 2 6 9 27.5 0.5 Relays & Sockets 1 5 13.15 2 2 14-ø2.4 holes 4.7 4.6 4.7 Signaling Lights 35.6 max. 4 5 13 27.5 1 5 14 12.5 0.5 9 6.6 27.5 5 13 13.15 0.5 1 7.25 0.5 2 4.7 7.15 0.5 2 2-ø2 holes 1.5 Switches & Pilot Lights RH 41 35.6 max. 4.6 Standard DIN Rail Mount Sockets SH1B-05 SH2B-05 22 DIN Rail (BNDN) 4.2 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 67 7.9 max. (Top View) 5.9 max. SH3B-05 5 1 5.5 min. 14 13 12 26 14.5 9 30 25 (Top View) 7.9 max. ø3.6 min. SH4B-05 31.5 18 47 67 8 6 5 4 2 1 36 5.5 min. 14 12 14.5 25 7.9 max. 780 18 DIN Rail (BNDN) 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 5.5 min. 9 46 50 www.IDEC.com Terminal Arrangement 8 4 6 7 3 2 11 10 5 1 46 13 10 (Top View) ø3.6 min. M3.5 Terminal Screw 4.4 max. Circuit Breakers 40 8 Terminal Arrangement 4.4 max. 36 31.5 42 DIN Rail (BNDN) 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 4.2 M3.5 Terminal Screw 47 8 67 32 2.5 8 4 (For terminals 13 and 14) 2.5 Contactors Terminal Arrangement 26 4.2 2.5 25 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 4.4 max. 13 ø3.2 min. ø3.6 min. DIN Rail (BNDN) 18 9 4 max. 14.5 20 14 2.5 47 4.4 max. (For terminals 1, 5, and 9) Terminal Blocks 1 4.8 min. 5.5 min. 16 M3.5 Terminal Screw 5 16 M3 Terminal Screw 31.5 8 Terminal Arrangement 47 18 M3.5 Terminal Screw 67 Timers 8 4.2 31.5 17 14.5 25 7.9 max. 14 12 13 9 (Top View) ø3.6 min. Relays & Sockets RH Switches & Pilot Lights Dimensions con’t (mm) Finger-safe DIN Rail Mount Sockets SH1B-05C DIN Rail (BNDN) 48 69 18.7 29.5 9 (Top View) 29.5 Ring terminals cannot be used. 9 (Top View) 36 25 Terminal Arrangement 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 8 4 6 2 25 7 5 1 12 18.7 29.5 Ring terminals cannot be used. 8 4 7 3 6 5 2 1 11 10 46 13 10 Terminal Arrangement 49 49 36 DIN Rail (BAA/BAP) 2-ø4.2 Mounting Holes (or M4 Tapped Holes) ø5 4.2 4.2 When using BAA/BAP: 33 42 DIN Rail (BNDN) 69 M3.5 Terminal Screw 9 14 (Top View) 12   Relays & Sockets 69 13 12 SH4B-05C 14 1.7 14   ø5 40 18.7 26 30 5 1 26 13 SH3B-05C 36 8 4 Signaling Lights Ring terminals cannot be used. Terminal Arrangement 2-ø4.2 Mounting Holes (or M4 Tapped Holes) 69 4.2 1 14 20 7 DIN Rail (BNDN) 16 16 32 25 ø5 5 2-ø4.2 Mounting Holes (or M4 Tapped Holes) M3 Terminal Screw 1.7 Terminal Arrangement 36 49 ø5 M3.5 Terminal Screw 7 4.2 25 1.7 7 22 36 M3.5 Terminal Screw 1.7 17 SH2B-05C 46 50 18.7 Ring type crimping terminals cannot be used. 13 9 (Top View) 29.5 Through Panel Mount Socket SH2B-51 Timers SH1B-51 Contactors   SH3B-51 SH4B-51 Terminal Blocks   Circuit Breakers 800-262-IDEC (4332) • USA & Canada 781 Relays & Sockets Dimensions con’t (mm) PCB Mount Sockets SH2B-62 (Bottom View) 15 (Tolerance ±0.1) 5.65 14 15.5 10 6.6 25.4 2-ø2 holes 2 8-ø2.4 holes (Tolerance 0.1) * 34 min. when using hold-down springs 45 (Tolerance 0.1) 14 (Bottom View) 31 min.* 6.6 Contactors Terminal Blocks Circuit Breakers 782 13 2 39.2 * 36 min. when using hold-down springs 2 3 4 6 7 8 10 11 12 15 11-ø2.4 holes Timers 30.2 31 min.* 2 6.85 1 5 9 11 11 15 3 Terminal Arrangement www.IDEC.com * 36 min. when using hold-down springs 45 min. 31.3 10 10 10 6.6 25.4 10 10 0.3 14 21.3 31 13 (Bottom View) 7.35 4.7 2 4 6 8 10 12 12.5 6.65 25.4 0.3 31 3 36 1 5 9 4.7 6.65 SH4B-62 36 min. 12.5 SH3B-62 Terminal Arrangement Relays & Sockets 13 21.5 min. 2.85 11 * 36 min. when using hold-down springs 12.2 4 8 12 29 min.* 15 0.3 29 31 min.* Signaling Lights 2 1.5 3 21.2 1 5 9 4.7 6.95 (Bottom View) 11 5.95 3 Terminal Arrangement 18 min. 4.4 11.85 0.3 13 14 18 6.8 3-ø2.4 holes 1 5 9 4.7 25.4 Terminal Arrangement 12.5 SH1B-62 31 Switches & Pilot Lights RH 14-ø2.4 holes (Tolerance 0.1) Relays & Sockets Operating Instructions Driving Circuit for Relays Protection for Relay Contacts 1. To ensure correct relay operation, apply rated voltage to the relay coil. 1. The contact ratings show maximum values. Make sure that these values are not exceeded. When an inrush current flows through the load, the contact may become welded. If this is the case, connect a contact protection circuit, such as a current limiting resistor. Pulsation Smoothing Capacitor + – Emin Emax R Relay Ripple Factor (%) DC Emean Emax – Emin Emean 2. Contact protection circuit: When switching an inductive load, arcing causes carbides to form on the contacts, resulting in increased contact resistance. In consideration of contact reliability, contact life, and noise suppression, use of a surge absorbing circuit is recommended. Note that the release time of the load becomes slightly longer. Check the operation using the actual load. Incorrect use of a contact protection circuit will adversely affect switching characteristics. Four typical examples of contact protection circuits are shown in the following table: ¥ 100% Incorrect Correct TE R R R Ind. Load RC C This protection circuit can be used for both AC and DC load power circuits. R: Resistor of approximately the same resistance value as the load C: 0.1 to 1 µF Diode 3. Leakage current while relay is off: When driving an element at the same time as the relay operation, special consideration is needed for the circuit design. As shown in the incorrect circuit below, leakage current (Io) flows through the relay coil while the relay is off. Leakage current causes coil release failure or adversely affects the vibration resistance and shock resistance. Design a circuit as shown in the correct example. Power + Power D Ind. Load – Varistor Varistor Power C Power C Power Load Load Contactors – R Relay This protection circuit can be used for both AC and DC load power circuits. For a best result, when using a power voltage of 24 to 48V AC/DC, connect a varistor across the load. When using a power voltage of 100 to 240V AC/DC, connect a varistor across the contacts. 3. Do not use a contact protection circuit as shown below: Back emf suppressing diode + Ind. Load This protection circuit can be used for DC load power circuits. Use a diode with the following ratings. Reverse withstand voltage: Power voltage of the load circuit x 10 Forward current: More than the load current Timers Io 4. Surge suppression for transistor driving circuits: When the relay coil is turned off, a high-voltage pulse is generated, causing a transistor to deteriorate and sometimes to break. Be sure to connect a diode to suppress the back electromotive force. Then, the coil release time becomes slightly longer. To shorten the coil release time, connect a Zener diode between the collector and emitter of the transistor. Select a Zener diode with a Zener voltage slightly higher than the power voltage. This protection circuit can be used when the load impedance is smaller than the RC impedance in an AC load power circuit. • R: Resistor of approximately the same resistance value as the load • C:0.1 to 1 µF Relays & Sockets Emax = Maximum of pulsating current Emin = Minimum of pulsating current Emean = DC mean value Signaling Lights 2. Input voltage for the DC coil: A complete DC voltage is best for the coil power to make sure of stable relay operation. When using a power supply containing a ripple voltage, suppress the ripple factor within 5%. When power is supplied through a rectification circuit, the relay operating characteristics, such as pickup voltage and dropout voltage, depend on the ripple factor. Connect a smoothing capacitor for better operating characteristics as shown below. Switches & Pilot Lights Operating Instructions This protection circuit is very effective in arc suppression when opening the contacts. But, the capacitor is charged while the contacts are opened. When the contacts are closed, the capacitor is discharged through the contacts, increasing the possibility of contact welding. Generally, switching a DC inductive load is more difficult than switching a DC resistive load. Using an appropriate arc suppressor, however, will improve the switching characteristics of a DC inductive load. Terminal Blocks This protection circuit is very effective in arc suppression when opening the contacts. But, when the contacts are closed, a current flows to charge the capacitor, causing contact welding. Soldering Circuit Breakers 1. When soldering the relay terminals, use a soldering iron of 30 to 60W, and quickly complete soldering (within approximately 3 seconds). 2. Use a non-corrosive rosin flux. 800-262-IDEC (4332) • USA & Canada 817 Relays & Sockets Relays & Sockets Signaling Lights Switches & Pilot Lights Operating Instructions Operating Instructions con’t Other Precautions 2. UL and CSA ratings may differ from product rated values determined by IDEC. 1. General notice: To maintain the initial characteristics, do not drop or shock the relay. The relay cover cannot be removed from the base during normal operation. To maintain the initial characteristics, do not remove the relay cover. 3. Do not use relays in the vicinity of strong magnetic field, as this may affect relay operation. Use the relay in environments free from condensation, dust, sulfur dioxide (SO2), and hydrogen sulfide (H2S). Make sure that the coil voltage does not exceed applicable coil voltage range. Safety Precautions • Turn off the power to the relay before starting installation, removal, wiring, maintenance, and inspection of the relays. Failure to turn power off may cause electrical shock or fire hazard. • Observe specifications and rated values, otherwise electrical shock or fire hazard may be caused. • Use wires of the proper size to meet voltage and current requirements. Tighten the terminal screws on the relay socket to the proper tightening torque. • Before operating the latching lever of the RU relay, turn off the power to the RU relay. After checking the circuit, return the latching lever to the original position. • Do not use the latching lever as a switch. The durability of the latching lever is a minimum of 100 operations. • When using DC loads on 4PDT relays, apply a positive voltage to terminals of neighboring poles and a negative voltage to the other terminals of neighboring poles to prevent the possibility of short circuits. • DC relays with a diode have a polarity in the coil terminals. Apply the DC voltage to the correct terminals. Circuit Breakers Terminal Blocks Contactors Timers • Surge absorbing elements on AC relays with RC or DC relays with diode are provided to absorb the back electromotive force generated by the coil. When the relay is subject to an excessive external surge voltage, the surge absorbing element may be damaged. Add another surge absorbing provision to the relay to prevent damage. Precautions for the RU Relays 818 www.IDEC.com
RH1B-ULD-DC24V 价格&库存
很抱歉,暂时无法提供与“RH1B-ULD-DC24V”相匹配的价格&库存,您可以联系我们找货
RH1B-ULD-DC24V
  • 1+168.276931+21.83380
  • 10+149.8796610+19.44677
  • 25+143.1240925+18.57024
  • 50+138.2128350+17.93300
  • 100+133.46555100+17.31705
  • 250+127.43570250+16.53468
  • 500+123.05161500+15.96585
库存:558
