HLR-09VF
HLR-09VF
    JST
    P=3.96mm
    3X3P 3.96MM
HLR-09VF 数据手册
HL CONNECTOR 3.96mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 7A AC, DC max. • Voltage rating: 300V AC, DC max. • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/7m Ω max. After environmental testing/10m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #22 to #18 0.3 to 0.75mm2 • Applicable panel thickness: 0.7 to 2.0mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. • Low insertion force contact • Housing lance • Inner-housing lock • Secondary retainers • Panel lock construction Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and wire size. Current unit: A Circuits 0 #18 2 3 4 8 9 12 Standards –––––––––––––––––––– Recognized E60389 1 Certified LR20812 2 R50171609 Wire size (AWG) #20 7 6 6 4 4 3 5 4 4 3 3 2 #22 4 4 4 3 3 2 Panel layout and Assembly layout 4 circuits : 15.0 8 to 12 circuits : 15.1 (including retainer) (4, 8 and 12 circuits) 9.5 (2 and 3 circuits) 31.6 31.6 34.2 (including retainer) 34.2 (including retainer) 7.5 7.5 Shape II E 0.7 C D 14.7 C D 9.8 Shape I E 3.0 A B A B Circuits Receptacle housing Panel hole shape Panel hole dimensions (mm) A ±0.13 B ±0.13 General tolerance C ±0.1 D ±0.13 E ±0.1 2 6.4 1.0 3 6.4 1.0 12.0 3.2 12.0 3.2 12.0 3.2 4.4 15.7 1 9.5 HLR-02V 4.4 19.7 1 13.5 HLR-03V 5.6 15.7 4 2 9.5 HLR-04V 5.6 23.6 8 2 17.4 HLR-08V 5.6 31.6 12 2 25.3 HLR-12V Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. Applicable panel thickness (mm) 0.7∼2.0 1 HL CONNECTOR Contact Applicable wire Model No. Pin contact Socket contact mm2 AWG # SSM-21T-P1.4 SSF-21T-P1.4 0.3∼0.75 22∼18 Insulation O.D. Q´ty / reel (mm) 1.4 Pin contact 6,000 Material and Finish 17.6 3.8 Phosphor bronze, tin-plated (reflow treatment) 0.5 4.3 1.5∼2.2 RoHS compliance Note: Contact JST for special products. Crimping machine Crimp applicator Contact Socket contact SSM-21T-P1.4 AP-K2N 2.2 SSF-21T-P1.4 12.6 1.0 MKS-L Applicator Dies Crimp applicator with dies MK/SSF/M-21-14 APLMK SSF/M21-14 − − − 1.9 4.3 Contact position location numbers Contact position numbers are stamped Retainer Retainer Receptacle housing Plug housing 2 1 3 1 3 L JST 1 3 L JST 4 7 3 L JST 4 10 3 9 5 1 7 1 1 9 6 5 1 8 4 4 7 7 2 2 3 5 1 2 4 7 6 8 3 7 3 8 5 9 5 11 3 6 9 2 5 8 1 4 7 2 8 1 7 8 7 2 2 12 6 5 4 8 2 8 3 6 12 11 6 10 2 9 7 1 3 9 1 6 9 2 4 1 8 8 3 1 5 10 4 9 6 2 11 5 4 10 5 1 5 L JST 2 L JST 2 6 6 5 11 3 4 6 12 7 12 6 3 7 4 2 1 1 4 8 L JST 8 4 3 2 2 1 2 1 2 3 1 L JST 2 1 3 1 1 4 L JST 2 L JST 2 L JST 2 4 3 3 L JST 2 2 1 Plug housing 3 Receptacle housing HL CONNECTOR Housing Material: Housing...PA 66, UL94V-0, white Retainer...Glass-filled PA 66, UL94V-0, ivory Circuits Voltage Current rating rating Receptacle housing(for pin contact) HLR-02V Plug housing(for socket contact) 3.0 Q´ty / bag Q´ty / bag L JST 2 9.16 HLP-02V Retainer HLS-02V (commonly used for 2-circuit housing and 4-circuit housing) Q´ty / bag 7.16 24.1 9.16 2.5 7A 1 1,000 11.6 7.5 6.1 2.5 1,000 3.8 7.1 1,000 L JST 2 2.6 3.96 2.6 HLR-02VF 1 6.1 2.5 24.1 HLR-03V HLP-03V Q´ty / bag HLS-03V Q´ty / bag 3 3.0 Q´ty / bag 11.12 300V L JST 2 3.0 1 6.1 2 1 500 11.6 3.0 L JST 13.12 1,000 7.1 3.8 7.5 2.5 6.1 1,000 1 13.12 2 6A L JST 300V 2 3 3 6.1 24.1 2.5 HLR-04V 3.0 Q´ty / bag HLP-04V Q´ty / bag 2 4 9.16 HLS-02V (commonly used for 2-circuit housing and 4-circuit housing) Q´ty / bag 3 11.6 L JST 7.5 500 2.5 HLP-08V 1 3.0 1 11.6 17.28 L JST 17.08 13.12 — — 500 16.75 2.5 HLP-12V Q´ty / bag HLS-12V Q´ty / bag 12 2 8 23.0 25.0 500 1,000 3.0 1 1 7 7 L JST 11 10 9 3 8 9 6 4 5 10 4 5 11.6 24.1 11.7 3 11 500 2 6 3A 12 300V L JST 12 25.0 3.0 Q´ty / bag 7.5 Q´ty / bag 9 6 2 4 HLR-12V 1 2 7 3 2.6 3 8 5 7.92 8 5 2 1 17.08 5 6 24.1 8 2 7.1 Q´ty / bag 7 6 7 3 HLP-09V 500 2.5 16.75 1,000 3.8 24.1 Q´ty / bag 9 2.6 Q´ty / bag 500 11.7 5 7 2.5 HLR-09VF 4A HLS-08V 7.5 4 4 3 8 11.6 2.5 11.7 300V 6 4 3.0 Q´ty / bag 500 L JST 9 1,000 24.1 Q´ty / bag L JST 4A 7.1 1 2.5 HLR-08V 300V 3.8 3 L JST 11.7 8 500 11.7 2 4 2.6 3.96 2.6 HLR-04VF 7.16 3 24.1 2.5 6A 1 300V 9.16 2 3.0 4 4 1 L JST 11.7 7.5 3.8 2.5 7.1 11.7 2.5 RoHS compliance 3
HLR-09VF 价格&库存
很抱歉,暂时无法提供与“HLR-09VF”相匹配的价格&库存,您可以联系我们找货
HLR-09VF
    • 500+1.31220
    库存:1500
    HLR-09VF
      • 1+3.00240
      • 10+2.37600
      • 30+2.10600
      • 100+1.77120
      • 500+1.62000
      • 1000+1.52280
      库存:955
