π132U31
π132U31
    2PAISEMI(荣湃)
    SOIC-16
π132U31 数据手册
2Pai Semi Enhanced ESD, 3.0 kV rms/5.0 kV rms 150Kbps Triple-Channel Digital Isolators π130U/π131U Data Sheet FEATURES Ultra-low power consumption (150Kbps): 0.62mA/Channel High data rate: 150kbps High common-mode transient immunity: 150 kV/µs typical High robustness to radiated and conducted noise Isolation voltages: π13xx3x: AC 3000Vrms π13xx6x: AC 5000Vrms High ESD rating: ESDA/JEDEC JS-001-2017 Human body model (HBM) ±8kV, all pins Safety and regulatory approvals (Pending): UL certificate number: E494497 3000Vrms/5000Vrms for 1 minute per UL 1577 CSA Component Acceptance Notice 5A VDE certificate number: 40047929 DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 VIORM = 707V peak/1200V peak CQC certification per GB4943.1-2011 3 V to 5.5 V level translation Wide temperature range: -40°C to 125°C 16-lead, RoHS-compliant, SOIC_N, SOIC_W and SSOP package APPLICATIONS General-purpose multichannel isolation Industrial field bus isolation Isolation Industrial automation systems Isolated switch mode supplies Isolated ADC, DAC Motor control GENERAL DESCRIPTION The π1xxxxx is a 2PaiSemi digital isolators product family that includes over hundreds of digital isolator products. By using maturated standard semiconductor CMOS technology and 2PaiSEMI iDivider technology, these isolation components provide outstanding performance characteristics and reliability superior to alternatives such as optocoupler devices and other integrated isolators. Intelligent voltage divider technology (iDivider technology) is a new generation digital isolator technology invented by 2PaiSEMI. It uses the principle of capacitor voltage divider to transmit voltage signal directly cross the isolator capacitor without signal modulation and demodulation. The π1xxxxx isolator data channels are independent and are available in a variety of configurations with a withstand voltage rating of 1.5 kV rms to 5.0 kV rms and the data rate from DC up to 600Mbps (see the Ordering Guide). The devices operate with the supply voltage on either side ranging from 3.0 V to 5.5 V, providing compatibility with lower voltage systems as well as enabling voltage translation functionality across the isolation barrier. The fail-safe state is available in which the outputs transition to a preset state when the input power supply is not applied. FUNCTIONAL BLOCK DIAGRAMS π130X3X π130X6X VDD1 1 16 VDD2 GND1 2 15 GND2 VOA VIA 3 14 VOA VOB VIB 4 13 VOB 12 VOC VIC 5 12 VOC 6 11 NC NC 6 11 NC NC 7 10 EN2 9 GND2 VDD1 1 GND1 2 15 GND2 VIA 3 14 VIB 4 13 VIC 5 NC 16 VDD2 NC 7 10 NC GND1 8 9 GND2 π131X3X GND1 8 VDD1 1 16 VDD 2 GND1 2 15 GND 2 π131X6X VDD1 1 16 VDD2 GND1 2 15 GND2 VIA 3 14 VOA VIA 3 14 VOA VIB 4 13 VOB VIB 4 13 VOB VOC 5 12 V IC VOC 5 12 V IC NC 6 11 NC NC 6 11 NC NC 7 10 NC EN1 7 10 EN2 GND 8 9 8 9 GND 2 1 GND2 GND1 Figure 1.π130xxx/π131xxx functional Block Diagram VDD1 VDD2 CIN COUT 0.1uF 0.1uF 1 2 3 4 5 6 7 8 VIN_A VIN_B VIN_C GND1 VDD1 GND1 VIA VIB VIC NC NC GND1 VDD2 GND2 VOA VOB VOC NC NC GND2 16 15 14 13 12 11 10 9 VOUT_A VOUT_B VOUT_C GND2 Figure 2.π130x3x Typical Application Circuit Rev.1.6 Information furnished by 2Pai semi is believed to be accurate and reliable. However, no responsibility is assumed by 2Pai semi for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of 2Pai semi. Trademarks and registered trademarks are the property of their respective owners. Room 308-309, No.22, Boxia Road, Pudong New District, Shanghai, 201203, China 021-50850681 2Pai Semiconductor Co., Limited. All rights reserved. http://www.rpsemi.com/ π130U/π131U Data Sheet PIN CONFIGURATIONS AND FUNCTIONS Table 1.π130Uxx Pin Function Descriptions Pin No. Name Description 1 VDD1 Supply Voltage for Isolator Side 1. 2 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 3 VIA Logic Input A. 4 VIB Logic Input B. 5 VIC Logic Input C. 6 NC No connect. 7 NC No connect. 8 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 9 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 10 NC/EN2 DD1 DD2 1 11 NC No connect for π130U3X. Output enable for π130U6X. Output pins on side 2 are enabled when EN2 is high or open and in high-impedance state when EN2 is low. No connect. 12 VOC Logic Output C. 13 VOB Logic Output B. 14 VOA Logic Output A. 15 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 16 VDD2 Supply Voltage for Isolator Side 2. 2 IA OA IB OB IC OC /EN2 1 2 Figure 3.π130Uxx Pin Configuration Table 2.π131Uxx Pin Function Descriptions Pin No. Name Description 1 VDD1 Supply Voltage for Isolator Side 1. 2 GND1 Ground 1. This pin is the ground reference for Isolator Side 1. 3 VIA Logic Input A. IA OA 4 VIB Logic Input B. IB OB 5 VOC Logic Output C. 6 NC No connect. 7 NC DD1 2 OC 8 GND1 No connect for π131U3X. Output enable for π131U6X. Output pins on side 1 are enabled when EN1 is high or open and in high-impedance state when EN1 is low. Ground 1. This pin is the ground reference for Isolator Side 1. 9 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 10 NC 11 NC No connect for π131U3X. Output enable for π131U6X. Output pins on side 2 are enabled when EN2 is high or open and in high-impedance state when EN2 is low. No connect. 12 VIC Logic Input C. 13 VOB Logic Output B. 14 VOA Logic Output A. 15 GND2 Ground 2. This pin is the ground reference for Isolator Side 2. 16 VDD2 Supply Voltage for Isolator Side 2. Rev. 1.6 | Page 2 of 17 DD2 1 IC /EN2 /EN1 1 2 Figure 4.π131Uxx Pin Configuration π130U/π131U Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3.Absolute Maximum Ratings4 TA = 25°C, unless otherwise noted. Parameter Rating Supply Voltages (VDD1-GND1, VDD2-GND2) −0.5 V to +7.0 V Input Voltages (VIA, VIB)1 −0.5 V to VDDx + 0.5 V Output Voltages (VOA, VOB)1 −0.5 V to VDDx + 0.5 V Average Output Current per Pin2 Side 1 Output Current (IO1) −10 mA to +10 mA Average Output Current per Pin2 Side 2 Output Current (IO2) −10 mA to +10 mA Common-Mode Transients Immunity 3 −200 kV/µs to +200 kV/µs Storage Temperature (TST) Range −65°C to +150°C Ambient Operating Temperature (TA) Range −40°C to +125°C Notes: 1 VDDx is the side voltage power supply VDD, where x = 1 or 2. 2 See Figure 5 for the maximum rated current values for various temperatures. 3 See Figure 15 for Common-mode transient immunity (CMTI) measurement. 4 Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. RECOMMENDED OPERATING CONDITIONS Table 4.Recommended Operating Conditions Parameter Symbol Supply Voltage High Level Input Signal Voltage Low Level Input Signal Voltage High Level Output Current Low Level Output Current Maximum Data Rate Junction Temperature Ambient Operating Temperature VDDx 1 VIH VIL IOH IOL TJ TA Min Typ 3 0.7*VDDx1 0 -6 Max Unit 5.5 VDDx1 0.3*VDDx1 V V V mA mA Kbps °C °C 6 150 150 125 0 -40 -40 Notes: 1V DDx is the side voltage power supply VDD, where x = 1 or 2. Truth Tables Table 5.π130U3x/π131U3x Truth Table VIx Input1 VDDI State1 VDDO State1 Low High Open Don’t Care4 Don’t Care4 Powered2 Powered2 Powered2 Unpowered3 Powered2 Powered2 Powered2 Powered2 Powered2 Unpowered3 Default Low Default High VOx Output1 VOx Output1 Low High Low Low High Impedance Low High High High High Impedance Test Conditions /Comments Normal operation Normal operation Default output Default output5 Notes: 1 VIx/VOx are the input/output signals of a given channel (A or B). VDDI/VDDO are the supply voltages on the input/output signal sides of this given channel. 2 Powered means VDDx≥ 2.9 V 3 Unpowered means VDDx < 2.3V 4 Input signal (VIx) must be in a low state to avoid powering the given VDDI1 through its ESD protection circuitry. 5 If the VDDI goes into unpowered status, the channel outputs the default logic signal after around 1us. If the VDDI goes into powered status, the channel outputs the input status logic signal after around 3us. Rev. 1.6 | Page 3 of 17 π130U/π131U Data Sheet Table 6.π130U6x/π131U6x Truth Table VIx Input1 EN1/2 State VDDI State1 VDDO State1 Low High Don’t Care4 Open Don’t Care4 Don’t Care4 Don’t Care4 High or NC High or NC L High or NC High or NC L Don’t Care4 Powered2 Powered2 Powered2 Powered2 Unpowered3 Unpowered3 Powered2 Powered2 Powered2 Powered2 Powered2 Powered2 Powered2 Unpowered3 Default Low VOx Output1 Low High High Impedance Low Low High Impedance High Impedance Default High VOx Output1 Low High High Impedance High High High Impedance High Impedance Test Conditions /Comments Normal operation Normal operation Disabled Default output5 Default output5 Notes: 1VIx/VOx are the input/output signals of a given channel (A or B). VDDI/VDDO are the supply voltages on the input/output signal sides of this given channel. 2Powered means VDDx≥ 2.9 V 3Unpowered means V DDx < 2.3V 4Input signal (V ) must be in a low state to avoid powering the given V 1 Ix DDI through its ESD protection circuitry. 5If the VDDI goes into unpowered status, the channel outputs the default logic signal after around 1us. If the VDDI goes into powered status, the channel outputs the input status logic signal after around 3us. SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 7.Switching Specifications VDD1 - VGND1 = VDD2 - VGND2 = 3.3VDC±10% or 5VDC±10%, TA=25°C, unless otherwise noted. Parameter Symbol Min Typ Max Unit Minimum Pulse Width Maximum Data Rate Propagation Delay Time1,4 Pulse Width Distortion4 Part to Part Propagation Delay Skew4 Channel to Channel Propagation Delay Skew4 Output Signal Rise/Fall Time4 Common-Mode Transient Immunity3 ESD(HBM - Human body model) PW 6.5 us Kbps 3.0 4.5 us 3.2 4.8 us 0 0.02 0.2 us 0 0.02 0.2 us 0.3 us 0.3 us 0 0.2 us 0 0.2 us 150 tpHL, tpLH PWD tPSK tCSK tr/tf CMTI ESD 100 1.5 ns 150 kV/µs ±8 kV Notes: 1 tpLH = low-to-high propagation delay time, tpHL = high-to-low propagation delay time. See Figure 13. 2 VDDx is the side voltage power supply VDD, where x = 1 or 2. 3 See Figure 15 for Common-mode transient immunity (CMTI) measurement. 4 Output Signal Terminated 50Ω Table 8.DC Specifications VDD1 - VGND1 = VDD2 - VGND2 = 3.3VDC±10% or 5VDC±10%, TA=25°C, unless otherwise noted. Rev. 1.6 | Page 4 of 17 Test Conditions/Comments Within pulse width distortion (PWD) limit Within PWD limit The different time between 50% input signal to 50% output signal 50% @ 5VDC supply @ 3.3VDC supply The max different time between tpHL and tpLH@ 5VDC supply. And The value is | tpHL - tpLH | @ 3.3VDC supply The max different propagation delay time between any two devices at the same temperature, load and voltage @ 5VDC supply @ 3.3VDC supply The max amount propagation delay time differs between any two output channels in the single device @ 5VDC supply. @ 3.3VDC supply 10% to 90% signal terminated 50Ω,See Figure 12. VIN = VDDx2 or 0V, VCM = 1000 V All pins π130U/π131U Data Sheet Symbol Rising Input Signal Voltage Threshold Falling Input Signal Voltage Threshold High Level Output Voltage Low Level Output Voltage VIT+ VITVOH 1 Min Typ 0.3* VDDX1 VDDx − 0.1 VDDx − 0.2 VOL Input Current per Signal Channel VDDx1 Undervoltage Rising Threshold VDDx1 Undervoltage Falling Threshold VDDx1 Hysteresis IIN VDDxUV+ VDDxUV− VDDxUVH Max 1 −10 2.5 2.4 0.6*VDDx 0.4* VDDX1 VDDx VDDx − 0.1 0 0.1 0.5 2.8 2.65 0.15 0.7*VDDx Unit 1 Test Conditions/Comments V V V V V V µA V V V 0.1 0.2 10 2.95 2.75 −20 µA output current −2 mA output current 20 µA output current 2 mA output current 0 V ≤ Signal voltage ≤ VDDX1 Notes: 1V DDx is the side voltage power supply VDD, where x = 1 or 2. Table 9.Quiescent Supply Current VDD1 - VGND1 = VDD2 - VGND2 = 3.3VDC±10% or 5VDC±10%, TA=25°C, CL = 0 pF, unless otherwise noted. Parameter Symbol Min Typ Max π130Uxx Quiescent Supply Current @ 5VDC Supply π130Uxx Quiescent Supply Current @ 3.3VDC Supply π131Uxx Quiescent Supply Current @ 5VDC Supply π131Uxx Quiescent Supply Current @ 3.3VDC Supply Unit Test Conditions IDD1 (Q) IDD2 (Q) IDD1 (Q) IDD2 (Q) 0.28 1.12 0.11 1.21 0.35 1.40 0.14 1.51 0.45 1.83 0.18 1.96 mA mA mA mA 0V Input signal 0V Input signal 5V Input signal 5V Input signal IDD1 (Q) 0.21 0.27 0.35 mA 0V Input signal IDD2 (Q) 1.10 1.38 1.79 mA 0V Input signal IDD1 (Q) 0.10 0.13 0.17 mA 3.3V Input signal IDD2 (Q) 1.19 1.49 1.94 mA 3.3V Input signal IDD1 (Q) IDD2 (Q) IDD1 (Q) IDD2 (Q) 0.56 0.85 0.49 0.85 0.70 1.06 0.61 1.07 0.90 1.38 0.79 1.39 mA mA mA mA 0V Input signal 0V Input signal 5V Input signal 5V Input signal IDD1 (Q) 0.51 0.63 0.82 mA 0V Input signal IDD2 (Q) 0.81 1.01 1.32 mA 0V Input signal IDD1 (Q) 0.48 0.61 0.79 mA 3.3V Input signal IDD2 (Q) 0.84 1.05 1.37 mA 3.3V Input signal Table 10.Total Supply Current vs. Data Throughput (CL = 0 pF) VDD1 - VGND1 = VDD2 - VGND2 = 3.3VDC±10% or 5VDC±10%, TA=25°C, CL = 0 pF, unless otherwise noted. 2 Kbps 50Kbps Parameter Symbol Min Typ Max Min Typ Max π130Uxx Supply Current@ 5VDC @ 3.3VDC π131Uxx Supply Current@ 5VDC @ 3.3VDC 150Kbps Min Typ Max Unit IDD1 0.24 0.36 0.24 0.36 0.25 0.38 mA IDD2 1.45 2.18 1.47 2.21 1.49 2.24 mA IDD1 0.18 0.27 0.18 0.27 0.18 0.27 mA IDD2 1.41 2.12 1.42 2.13 1.43 2.15 mA IDD1 0.60 0.90 0.61 0.92 0.62 0.93 mA IDD2 1.05 1.58 1.07 1.61 1.09 1.64 mA IDD1 0.55 0.83 0.56 0.84 0.57 0.86 mA IDD2 1.03 1.55 1.05 1.58 1.07 1.61 mA Rev. 1.6 | Page 5 of 17 π130U/π131U Data Sheet INSULATION AND SAFETY RELATED SPECIFICATIONS Table 11.Insulation Specifications Parameter Rated Dielectric Insulation Voltage Minimum External Air Gap (Clearance) Minimum External Tracking (Creepage) Minimum Internal Gap (Internal Clearance) Tracking Resistance (Comparative Tracking Index) Symbol Value Unit Test Conditions/Comments π13xU3x π13xU6x 3000 5000 L (CLR) 4 8 mm min L (CRP) 4 8 mm min 11 21 µm min Insulation distance through insulation >600 >600 V DIN EN 60112 (VDE 0303-11):2010-05 I I CTI Material Group V rms 1-minute duration Measured from input terminals to output terminals, shortest distance through air Measured from input terminals to output terminals, shortest distance path along body IEC 60112:2003 + A1:2009 PACKAGE CHARACTERISTICS Table 12.Package Characteristics Parameter Resistance (Input to Output)1 Capacitance (Input to Output)1 Symbol Typical Value Unit π13xU3x π13xU6x RI-O 10 11 10 11 Ω Test Conditions/Comments CI-O 1.5 1.5 pF @1MHz Input Capacitance2 CI 3 3 pF @1MHz IC Junction to Ambient Thermal Resistance θJA 100 45 °C/W Thermocouple located at center of package underside Notes: 1The device is considered a 2-terminal device; SOIC-16 Pin 1 - Pin 8(WSOIC-16 Pin 1-Pin8 and SSOP16 Pin 1-Pin8) are shorted together as the one terminal, and SOIC-16 Pin 9- Pin 16(WSOIC-16 Pin 9-Pin16 and SSOP16 Pin 9-Pin16) are shorted together as the other terminal. 2Testing from the input signal pin to ground. REGULATORY INFORMATION See Table 13 and the Insulation Lifetime section for details regarding recommended maximum working voltages for specific cross isolation waveforms and insulation levels. Table 13.Regulatory Regulatory π13xU3x π13xU6x UL Recognized under UL 1577 Component Recognition Program1 Single Protection, 3000 V rms Isolation Voltage File (E494497) Recognized under UL 1577 Component Recognition Program1 Single Protection, 5000 V rms Isolation Voltage File (pending) CSA Approved under CSA Component Acceptance Notice 5A CSA 60950-1-07+A1+A2 and IEC 60950-1, second edition, +A1+A2: Basic insulation at 500 V rms (707 V peak) Reinforced insulation at 250 V rms (353 V peak) File (pending) Approved under CSA Component Acceptance Notice 5A CSA 60950-1-07+A1+A2 and IEC 60950-1, second edition, +A1+A2: Basic insulation at 845 V rms (1200 V peak) Reinforced insulation at 422 V rms (600 V peak) File (pending) VDE DIN V VDE V 0884-10 (VDE V 0884-10):2006-122 Basic insulation, VIORM = 707 V peak, VIOSM = 4615 V peak File (40047929) DIN V VDE V 0884-10 (VDE V 0884-10):2006-122 Basic insulation, VIORM = 1200 V peak, VIOSM = 7000V peak File (pending) CQC Certified under CQC11-471543-2012 Certified under CQC11-471543-2012 Rev. 1.6 | Page 6 of 17 π130U/π131U Data Sheet Regulatory π13xU3x π13xU6x GB4943.1-2011 Basic insulation at 500 V rms (707 V peak) working voltage Reinforced insulation at 250 V rms (353 V peak) File (pending) GB4943.1-2011 Basic insulation at 845 V rms (1200 V peak) working voltage Reinforced insulation at 422 V rms (600 V peak) File (pending) Notes: 1 In accordance with UL 1577, each π130U3X/π131U3X is proof tested by applying an insulation test voltage ≥ 3600 V rms for 1 sec; each π130U6X/π131U6X is proof tested by applying an isulation test voltage ≥ 7200 V rms for 1 sec 2 In accordance with DIN V VDE V 0884-10, each π130U3X/π131U3X is proof tested by applying an insulation test voltage ≥ 1326 V peak for 1 sec (partial discharge detection limit = 5 pC); each π130U6X/π131U6X is proof tested by ≥ 2250 V peak for 1 sec. The * marking branded on the component designates DIN V VDE V 0884-10 approval. DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS These isolators are suitable for reinforced electrical isolation only within the safety limit data. Protective circuits ensure the maintenance of the safety data. The * marking on packages denotes DIN V VDE V 0884-10 approval. Table 14.VDE Insulation Characteristics Description Test Conditions/Comments Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150 V rms For Rated Mains Voltage ≤ 300 V rms For Rated Mains Voltage ≤ 400 V rms Climatic Classification Pollution Degree per DIN VDE 0110, Table 1 Maximum Working Insulation Voltage Input to Output Test Voltage, Method B1 VIORM × 1.875 = Vpd (m), 100% production test, tini = tm = 1 sec, partial discharge < 5 pC Symbol Characteristic Unit π13xU3x π13xU6x VIORM I to IV I to III I to III 40/105/21 2 707 I to IV I to III I to III 40/105/21 2 1200 V peak Vpd (m) 1326 2250 V peak Vpd (m) 1061 1800 V peak 849 1440 V peak VIOTM 4200 7071 V peak VIOSM 4615 Input to Output Test Voltage, Method A After Environmental Tests Subgroup 1 After Input and/or Safety Test Subgroup 2 and Subgroup 3 Highest Allowable Overvoltage Surge Isolation Voltage Basic Surge Isolation Voltage Reinforced Safety Limiting Values Maximum Junction Temperature Total Power Dissipation at 25°C Insulation Resistance at TS VIORM × 1.5 = Vpd (m), tini = 60 sec, tm = 10 sec, partial discharge < 5 pC VIORM × 1.2 = Vpd (m), tini = 60 sec, tm = 10 sec, partial discharge < 5 pC Basic insulation, 1.2 µs rise time, 50 µs, 50% fall time Reinforced insulation, 1.2 µs rise time, 50 µs, 50% fall time Maximum value allowed in the event of a failure (see Figure 5) VIOSM TS PS RS VIO = 800 V Rev. 1.6 | Page 7 of 17 V peak V peak 150 1.67 >109 150 2.78 >109 °C W Ω π130U/π131U Data Sheet 3 3.2 2.9 Propagation Delay Time(uS) Power Supply Undervoltage Threshold Figure 5.Thermal Derating Curve, Dependence of Safety Limiting Values with Ambient Temperature per VDE (left: π13xU3x; right: π13xU6x) 2.8 2.7 2.6 2.5 2.4 VDDxUV+(V) VDDxUV−(V) 2.3 3 2.8 2.6 tpLH(uS)@3.3V 2.4 tpHL(uS)@5V tpLH(uS)@5V 2.2 2.2 0 50 100 0 150 50 100 150 Free-Air Temperature ( °C) Free-Air Temperature ( °C) Figure 6.UVLO vs. Free-Air Temperature Figure 7.Propagation Delay Time vs. Free-Air Temperature 1.2 1.4 1.0 0.8 0.6 0.4 IDD1@ 0V Input IDD2@ 0V Input IDD1@ 3.3V Input IDD2@ 3.3V Input 0.2 0.0 0 50 100 Free-Air Temperature ( °C) 150 Figure 8.π130Uxx Quiescent Supply Current with 3.3V Supply vs. Free-Air Temperature π130Uxx Quiescent Supply Current (mA) π130Uxx Quiescent Supply Current (mA) tpHL(uS)@3.3V 1.2 1.0 0.8 0.6 IDD1@ 0V Input IDD2@ 0V Input IDD1@ 5V Input IDD2@ 5V Input 0.4 0.2 0.0 0 50 100 Free-Air Temperature ( °C) 150 Figure 9.π130Uxx Quiescent Supply Current with 5V Supply vs. Free-Air Temperature Rev. 1.6 | Page 8 of 17 π130U/π131U 0.9 1.0 0.8 0.9 π131Uxx Quiescent Supply Current (mA) π131Uxx Quiescent Supply Current (mA) Data Sheet 0.7 0.6 0.5 0.4 0.3 IDD1@ 0V Input 0.2 IDD1@ 3.3V Input IDD2@ 0V Input IDD2@ 3.3V Input 0.1 0.0 0 50 100 Free-Air Temperature ( °C) 150 Figure 10.π131Uxx Quiescent Supply Current with 3.3V Supply vs. Free-Air Temperature Figure 12.Transition time waveform measurement 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 IDD1@ 0V Input IDD2@ 0V Input IDD1@ 5V Input IDD2@ 5V Input 0.0 0 50 100 Free-Air Temperature ( °C) 150 Figure 11.π131Uxx Quiescent Supply Current with 5V Supply vs. Free-Air Temperature Figure 13. Propagation delay time waveform measurement Rev. 1.6 | Page 9 of 17 π130U/π131U Data Sheet APPLICATIONS INFORMATION OVERVIEW The π1xxxxx are 2PaiSemi digital isolators product family based on 2PaiSEMI unique iDivider technology. Intelligent voltage Divider technology (iDivider technology) is a new generation digital isolator technology invented by 2PaiSEMI. It uses the principle of capacitor voltage divider to transmit signal directly cross the isolator capacitor without signal modulation and demodulation. Compare to the traditional Opto-couple technology, icoupler technology, OOK technology, iDivider is a more essential and concise isolation signal transmit technology which leads to greatly simplification on circuit design and therefore significantly improves device performance, such as lower power consumption, faster speed, enhanced antiinterference ability, lower noise. By using maturated standard semiconductor CMOS technology and the innovative iDivider design, these isolation components provide outstanding performance characteristics and reliability superior to alternatives such as optocoupler devices and other integrated isolators. The π1xxxxx isolator data channels are independent and are available in a variety of configurations with a withstand voltage rating of 1.5 kV rms to 5.0 kV rms and the data rate from DC up to 600Mbps (see the Ordering Guide). The π130Uxx/π131Uxx are the outstanding 150Kbps Triple-channel digital isolators with the enhanced ESD capability. the devices transmit data across an isolation barrier by layers of silicon dioxide isolation. The devices operate with the supply voltage on either side ranging from 3.0 V to 5.5 V, offering voltage translation of 3.3 V, and 5 V logic. The π130Uxx/π131Uxx have very low propagation delay and high speed. The input/output design techniques allow logic and supply voltages over a wide range from 3.0 V to 5.5 V, offering voltage translation of 3.3 V and 5 V logic. The architecture is designed for high common-mode transient immunity and high immunity to electrical noise and magnetic interference. See the Ordering Guide for the model numbers that have the failsafe output state of low or high. Avoid reducing the isolation capability, Keep the space underneath the isolator device free from metal such as planes, pads, traces and vias. To minimize the impedance of the signal return loop, keep the solid ground plane directly underneath the high-speed signal path, the closer the better. The return path will couple between the nearest ground plane to the signal path. Keep suitable trace width for controlled impedance transmission lines interconnect. To reduce the rise time degradation, keep the length of input/output signal traces as short as possible, and route low inductance loop for the signal path and It’s return path. VDD1 VDD2 GND1 GND2 VIA/VOA VIB VIC/VOC VOA/VIA VOB VOC/VIC NC NC GND1 NC NC GND2 Figure 14.Recommended Printed Circuit Board Layout CMTI MEASUREMENT To measure the Common-Mode Transient Immunity (CMTI) of π1xxxxx isolator under specified common-mode pulse magnitude (VCM) and specified slew rate of the common-mode pulse (dVCM/dt) and other specified test or ambient conditions, The common-mode pulse generator (G1) will be capable of providing fast rising and falling pulses of specified magnitude and duration of the commonmode pulse (VCM) and the maximum common-mode slew rates (dVCM/dt) can be applied to π1xxxxx isolator coupler under measurement. The common-mode pulse is applied between one side ground GND1 and the other side ground GND2 of π1xxxxx isolator and shall be capable of providing positive transients as well as negative transients. PCB LAYOUT The low-ESR ceramic bypass capacitors must be connected between VDD1 and GND1 and between VDD2 and GND2. The bypass capacitors are placed on the PCB as close to the isolator device as possible. The recommended bypass capacitor value is between 0.1 μF and 10 μF. The user may also include resistors (50–300 Ω) in series with the inputs and outputs if the system is excessively noisy, or in order to enhance the anti ESD ability of the system. Figure 15.Common-mode transient immunity (CMTI) measurement Rev.1.6 | Page 10 of 17 π130U/π131U Data Sheet OUTLINE DIMENSIONS Figure 16. 16-Lead Narrow Body SOIC [NB SOIC-16] Outline Package Figure 17.16-Lead Wide Body Outline Package [16-Lead SOIC_W] Rev.1.6 | Page 11 of 17 π130U/π131U Data Sheet Figure 18.16-Lead SSOP Outline Package [SSOP16] Land Patterns 16-Lead Narrow Body SOIC [NB SOIC-16] The figure below illustrates the recommended land pattern details for the π1xxxxx in a 16-pin narrow-body SOIC. The table below lists the values for the dimensions shown in the illustration. Figure 19.16-Lead Narrow Body SOIC [NB SOIC-16] Land Pattern Table 15.16-Lead Narrow Body SOIC [NB SOIC-16] Land Pattern Dimensions Dimension Feature C1 Pad column spacing E Pad row pitch X1 Pad width Y1 Pad length Parameter 5.40 1.27 0.60 1.55 Note: 1.This land pattern design is based on IPC -7351 2.All feature sizes shown are at maximum material condition and a card fabrication tolerance of 0.05 mm is assumed. Rev.1.6 | Page 12 of 17 Unit mm mm mm mm π130U/π131U Data Sheet 16-Lead SOIC_W The figure below illustrates the recommended land pattern details for the π1xxxxx in a 16-pin wide-body SOIC package. The table lists the values for the dimensions shown in the illustration. Figure 20.16-Lead Wide Body SOIC [WB SOIC-16] Land Pattern Table 16. 16-Lead Wide Body SOIC Land Pattern Dimensions Dimension Feature C1 Pad column spacing E Pad row pitch X1 Pad width Y1 Pad length Parameter 9.40 1.27 0.60 1.90 Unit mm mm mm mm Note: 1.This land pattern design is based on IPC -7351 2.All feature sizes shown are at maximum material condition and a card fabrication tolerance of 0.05 mm is assumed. 16-Lead SSOP The figure below illustrates the recommended land pattern details for the π1xxxxx in a 16-Lead SSOP package. The table lists the values for the dimensions shown in the illustration. Figure 21. 16-Lead SSOP Land Pattern Table 17. 16-Lead SSOP Land Pattern Dimensions Dimension Feature C1 Pad column spacing E Pad row pitch X1 Pad width Y1 Pad length Parameter 5.40 0.635 0.40 1.55 Note: 1.This land pattern design is based on IPC -7351 2.All feature sizes shown are at maximum material condition and a card fabrication tolerance of 0.05 mm is assumed. Rev.1.6 | Page 13 of 17 Unit mm mm mm mm π130U/π131U Data Sheet Top Marking Line 1 Line 2 Line 3 πXXXXXX=Product name YY = Work Year WW = Work Week ZZ=Manufacturing code from assembly house XXXX, no special meaning REEL INFORMATION 16-Lead Narrow Body SOIC [NB SOIC-16] Note:The Pin 1 of the chip is in the quadrant Q1 16-Lead Wide Body SOIC [WB SOIC-16] Rev.1.6 | Page 14 of 17 π130U/π131U Data Sheet Note:The Pin 1of the chip is in the quadrant Q1 16-Lead SSOP ORDERING GUIDE No. of Withstand Fail-Safe No. of Inputs, Package Inputs, VDD1 Voltage Rating Output MSL Peak Temp 2 VDD2 Side Description Side (kV rms) State π130U31 −40 to 125°C 3 0 3 High NB SOIC-16 Level-3-260C-168 HR π130U30 −40 to 125°C 3 0 3 Low NB SOIC-16 Level-3-260C-168 HR π131U31 −40 to 125°C 2 1 3 High NB SOIC-16 Level-3-260C-168 HR π131U30 −40 to 125°C 2 1 3 Low NB SOIC-16 Level-3-260C-168 HR π130U61 −40 to 125°C 3 0 5 High WB SOIC-16 Level-3-260C-168 HR π130U60 −40 to 125°C 3 0 5 Low WB SOIC-16 Level-3-260C-168 HR π131U61 −40 to 125°C 2 1 5 High WB SOIC-16 Level-3-260C-168 HR π131U60 −40 to 125°C 2 1 5 Low WB SOIC-16 Level-3-260C-168 HR π130U31S −40 to 125°C 3 0 3 High 16-Lead SSOP Level-3-260C-168 HR π130U30S −40 to 125°C 3 0 3 Low 16-Lead SSOP Level-3-260C-168 HR π131U31S −40 to 125°C 2 1 3 High 16-Lead SSOP Level-3-260C-168 HR π131U30S −40 to 125°C 2 1 3 Low 16-Lead SSOP Level-3-260C-168 HR 1. Pai1xxxxx is equals to π1xxxxx in the customer BOM. 2. MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. Model Name 1 Temperature Range Rev.1.6 | Page 15 of 17 Quantity per reel 2500 2500 2500 2500 1500 1500 1500 1500 4000 4000 4000 4000 π130U/π131U Data Sheet PART NUMBER NAMED RULE π(1)(2)(0)(A)(3)(0)(S) SeriesNumber: 1,2,3... Total Channel Am ount: N=N Channels N=2,3,4,5,6... Reverse Channel Amount: N=N Channels N=0,1,2,3... Data Rate:A=600Mbps E=200Mbps M=10Mbps U=150Kbps Isolation Voltag es: N=3 3KVrms AC N=4 4KVrms AC N=6 5 or 6KVrms AC Fail-Safe Output Stat e: 0=Logic Low 1=Logic High Optional: S=SSOP Package Q=AEC-Q100 Qualified Notes: Pai1xxxxx is equals to π1xxxxx in the customer BOM IMPORTANT NOTICE AND DISCLAIMER 2Pai semi intends to provide customers with the latest, accurate, and in-depth documentation. However, no responsibility is assumed by 2Pai semi for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Characterization data, available modules, and "Typical" parameters provided can and do vary in different applications. Application examples described herein are for illustrative purposes only. 2Pai semi reserves the right to make changes without further notice and limitation to product information, specifications, and descriptions herein, and does not give warranties as to the accuracy or completeness of the included information. 2Pai semi shall have no liability for the consequences of use of the information supplied herein. Trademarks and registered trademarks are the property of their respective owners. This document does not imply, or express copyright licenses granted hereunder to design or fabricate any integrated circuits. Room 308-309, No.22, Boxia Road, Pudong New District, Shanghai, 201203, China 021-50850681 2Pai Semiconductor Co., Limited. All rights reserved. http://www.rpsemi.com/ Rev.1.6 | Page 16 of 17 π130U/π131U Data Sheet REVISION HISTORY Revision Updated Date Page 1 Victory 2018/ 09/20 All 2 Victory 2018/ 11/28 P1,P11 3 Devin 2019/ 09/08 P1,P7,P11,P13,P 14,P15 Page1,11,14 Page 5 Page 6 Page7 4 Mr. Han 2020/ 03/20 Page8 Page 11 Page 12 Page 14 Page 15 Page 16 Change Record Initial version Changed CIN,COUT in Figure2 from 0.1uF to 1uF. Changed the recommended bypass capacitor value from between 0.1 μF and 1 μF to between 0.1 μF and 10 μF. P1: Changed the address from ‘Room 19307, Building 8, No.498, GuoShouJing Road’ to ‘Room 308-309, No.22, Boxia Road’; Changed ‘(W)SOIC package’ to ‘SOIC_N, SOIC_W and SSOP package’; Add iDivider technology description in General Description. Changed CIN,COUT in Figure2 from 1uF to 0.1uF. P7: Add ‘and SSOP16 Pin 1-Pin8’ and ‘and SSOP16 Pin 9-Pin16’ in note 1. P11: Add iDivider technology description in overview. P13: Add Figure19. 16-Lead SSOP Outline Package drawing P14: Add 16-Lead SSOP Reel drawing; Updated 16-Lead SOIC_W reel drawing. P15: Add character ‘S’ and ‘Q’ in part number named rule; Changed the SOIC_W quantity from ‘1000 per reel’ to ‘1500 per reel’; Add ‘π130U31S、π130U30S、 π131U31S、π131U30S’ in ordering guide Changed the Isolation voltages ofπ12xx6x from 6kV to 5kV. Changed minimum” VDDx Undervoltage Rising Threshold” from 2.45V to 2.5V Changed typical” VDDx Undervoltage Rising Threshold” from 2.65V to 2.8V Changed maximum” VDDx Undervoltage Rising Threshold” from 2.9V to 2.95V Changed minimum” VDDx Undervoltage Falling Threshold” from 2.3V to 2.4V Changed typical” VDDx Undervoltage Falling Threshold” from 2.5V to 2.65V Change CTI from “>400” to “>600”, changed “Material Group” from “II” to” I” Changed” Capacitance (Input to Output)” from 0.6pF to 1.5pF Old version: Single Protection,6000V rms Isolation Voltage New version: Single Protection, 5000V rms Isolation Voltage Old version: To enhance the robustness of a design, the user may also include resistors (50–300 Ω) in series with the inputs and outputs if the system is excessively noisy. New version: The user may also include resistors (50–300 Ω) in series with the inputs and outputs if the system is excessively noisy, or in order to enhance the anti ESD ability of the system. Added “Land Patterns” Added “Top Marking” Updated “REEL INFORMATION” Added “MSL peak temp” in tab ORDERING GUIDE Added “IMPORTANT NOTICE AND DISCLAIMER” Rev.1.6 | Page 17 of 17
π132U31 价格&库存
很抱歉,暂时无法提供与“π132U31”相匹配的价格&库存,您可以联系我们找货
