80-000639
80-000639
    CRITICALLINK
80-000639 数据手册
Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 FEATURES MitySOM-5CSX Development Board MitySOM-5CSX SoM Module Additional Hardware Included:    UART to USB Cable Ethernet Cable AC to DC 24V 2.7A Adapter Software and Documentation: Integrated +2.5V/+3.3V/+5V/+12V Power Supplies    ATX Power Supply Compatible    Digital Interfaces:      10/100/1000 MBit Ethernet Interface Debug UART to USB USB OTG Interface Dual Electrically Isolated CAN Bus Interfaces SD/MMC Card Socket APPLICATIONS        Expansion    Linux Kernel uBoot Development Environment - Virtual Machine Development Board Schematics Development Board Gerber Files Development Board BOM Full HSMC Interface Partial HSMC Interface PCI-e x4 MitySOM-5CSX Evaluation Test and Measurement Factory Automation Industrial Automation Embedded Instrumentation Test and Measurement Rapid Prototyping DESCRIPTION The MitySOM-5CSX Development Kit provides all the hardware and software support for system designers and developers to evaluate the Critical Link MitySOM-5CSX System on Module. The MitySOM-5CSX Development Kit comes complete with the MitySOM-5CSX module that meets your project’s needs. The MitySOM-5CSX Development Kit includes on-board Debug UART to USB converter, 10/100/1000 GBit Ethernet, Universal Serial Bus (USB 2.0) USB-On-The-Go (OTG) communication interfaces. Full and Partial HSMC connectors are compatible with a wide range of existing add-on cards, dual electrically isolated CAN and PCI-e x4 expansion ports provide a comprehensive set of interface options. Multi Media Card (MMC) interface supporting Secure Digital (SD) cards. Configuration dip-switches, debug switches, RTC battery and a SOM current input monitoring circuit round out the Development Kit. All powered from a single 24VDC input (adapter included) or a standard ATX PC power supply with onboard +2.5V/+3.3V/+5V/12V power supplies. 1 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 A block diagram of the MitySOM-5CSX Development Kit is illustrated in Figure 1 on the following page. Control of the on-board interface hardware and connected Expansion IO cards require proper configuration of the MitySOM-5CSX Module. While not required, it is strongly recommended that the MitySOM software development kit and supplied API be used to manage these interfaces. MitySOM-5CSX Development Kit MitySOM-5CSX HID / Thumb drive USB OTG PC Serial Port UART to USB Bridge SD Card SD Connector Ethernet 10/100/1000 RJ-45 & Magnetics Full HSMC Interface (89 IO Pins Connected) Micrel KSZ9031 Ethernet PHY 160-Pin HSMC Full HSMC JTAG Debug Interface 10-pin Header Partial HSMC Interface (20 IO Pins Connected) 160-Pin HSMC PC/Modules PCIe 4X Header Altera Cyclone V SX/SE SoC Dual Arm Cortex-A8 Up to 925MHz SATA Header Status/Debug Indicators LED’s Reset and Debug Buttons Configuration Switches Dip Switches CAN 1 10-pin Header ISO 1050 CAN 2 10-pin Header ISO 1050 Battery (RTC) +1.8V From MityArm Module +5V MityArm Module +18V to 24V or ATX Power Supply Input Power Management +3.3V Peripherals +5V ISO 2 (CAN 2) +1.2V Ethernet +12V PCIe Figure 1: MitySOM-5CSX Development Kit Block Diagram Additional details about the Cyclone V SX/SE SoC, available peripherals, their features and FPGA IO details are provided in the data sheet at the Altera website (http://www.altera.com/devices/processor/soc-fpga/cyclone-v-soc/cyclone-v-soc.html). 2 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 Feature Descriptions Debug UART to USB Interface Description .................................................................... 4 USB 2.0 Interface Description ......................................................................................... 4 MultiMedia Card (SD) Interface Description ................................................................... 4 Gigabit Ethernet Interface Description ............................................................................. 4 SATA Interface Description ............................................................................................ 4 RTC Battery (VBat) ........................................................................................................ 4 Full HSMC Interface Description .................................................................................... 5 Full HSMC JTAG Debug Interface Description............................................................... 5 Partial HSMC Interface Description ................................................................................ 5 PCI-e x4 Interface Description ........................................................................................ 5 Dual CAN Interface Description...................................................................................... 5 Debug/User Switch Descriptions ..................................................................................... 5 Boot Configuration Dip-Switch Description .................................................................... 6 Electrical Interface Descriptions Input Power – J601 and J600 ........................................................................................... 8 Main Power Switch – S600 ............................................................................................. 8 MultiMedia Card (SD) Interface – J403 ........................................................................... 8 Debug/Boot UART - USB Interface – J400 ..................................................................... 8 USB 2.0 Interface (OTG) – J401 ..................................................................................... 8 Dual CAN Interface – J404 & J405 ................................................................................. 9 SATA Interface – J402 .................................................................................................... 9 PCIe Interface – J200 .................................................................................................... 10 Full HSMC Interface- J300............................................................................................ 11 Full HSMC JTAG Debug Interface – J302 .................................................................... 14 Partial HSMC Interface – J301 ...................................................................................... 15 10/100/1000 Ethernet Interface – J500........................................................................... 17 Boot Configuration header – J106 ................................................................................. 17 3 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 Debug UART to USB Interface Description The on-board UART to USB Bridge, FTDI FT230X, provides a serial interface at data rates up to 115,200 baud. The USB serial interface, J400 - Console, is routed to the primary MitySOM serial bootloading port, UART0. It allows for general module debug, remote code download and FLASH upgrades on an attached MitySOM from this connector when interfaced with a PC. When connected to a Windows XP, Vista, 7 or 8 PC no drivers are required as Windows Update is used to obtain the drivers. USB 2.0 Interface Description The on-board USB OTG interface utilizes a mini B type connector J401 and interfaces with the USB phy on the MitySOM-5CSX module. This phy is connected to the USB0 controller within the Cyclone V SoC HPS. Linux drivers are available. This interface allows for a connection to either a PC or a USB device through the use of a USB-OTG to USB A type adapter, not included. MultiMedia Card (SD) Interface Description The on-board MultiMedia Card (MMC) slot uses a Secure Digital connector J403 which supports standard (3.3V) cards. U-Boot configuration information and Linux drivers are available. Gigabit Ethernet Interface Description The on-board Ethernet interface features a Micrel KSZ9031 Ethernet PHY capable of running at 10/100/1000Mbit including link auto-negotiation and RGMII/MDIO capability. An industry standard RJ-45 connector is provided for external connection. This Ethernet interface may be used to perform remote code download via U-Boot and FLASH upgrades on an attached MitySOM-5CSX module in addition to standard network interfacing. SATA Interface Description The on-board SATA connector allows for connection to the MitySOM-5CSX module gigabit transceivers. To take advantage of the SATA interface an IP core needs to be used. There are a number of companies that offer such cores and you can contact your Critical Link representative for a recommendation. RTC Battery (VBat) The MitySOM-5CSX Development Board includes a 3V battery to power the RTC on the module. This battery is identifier B600 and is a Panasonic BR1225-1VC. Note that if the battery gets discharged, below 1.2V, a new battery may be required for proper module function. If the battery voltage is between 1.2V and 1.8V a slower JTAG clock frequency may be needed for JTAG debugging. Please contact a Critical Link representative for details. 4 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 Full HSMC Interface Description The Full High Speed Mezzanine Card (HSMC) interface allows for the use of add-on cards that are designed for the Altera Cyclone V on the MitySOM-5CSX module. A number of “off the shelf” boards/kits are available from Critical Link and other third parties that are compatible with this interface. Full HSMC JTAG Debug Interface Description The 10-pin JTAG header J302 is available onboard for debugging of a device that is connected to the Full HSMC connector, J300. Partial HSMC Interface Description The Full High Speed Mezzanine Card (HSMC) interface allows for the use of add-on cards that are designed for the Altera Cyclone V on the MitySOM-5CSX module. This interface offers access to a single Gigabit transceiver interface as well. PCI-e x4 Interface Description The on-board 4-channel PCI-e interface provides both root port and endpoint mode support for PCI-e x1, x2 and x4 devices when a MitySOM-5CSX is used. In addition an on-board 100MHz clock is provided as well as +12V and +3.3V external power supplies. Dual CAN Interface Description The on-board CAN provides a set of CAN V2.0B compliant interfaces. These interfaces are managed by the MitySOM-5CSX module directly. The galvanic isolation is provided by a dedicated TI ISO1050 transceiver for each interface. The ISO1050 is powered by an isolated power supply with 1000V* isolation from the primary supply. Jumpers JP400 (CAN 1) and JP401 (CAN 0) can provide dedicated bus termination of 120Ohm. To enable termination, place shorting jumper across JP504. The electrical interfaces are provided via J404 (CAN1) and J405 (CAN0), 10-pin shrouded headers. Linux Driver and API examples are available to support CAN functionality. Debug/User Switch Descriptions A total of 5 switches are present on the 5CSX Development Kit. S400, S401 and S402 are tied to HPS GPIO pins on the module edge connector; pins 252, 264 and 266 respectively. These switches can be utilized for any user defined functions. S403 is for the HPS Warm Reset which just causes the MitySOM Cyclone V SoC to perform a soft reset. S404 is for the Cold Reset which causes the MitySOM input power supply to be toggled. 5 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 Boot Configuration Dip-Switch Description The 5CSX Development Kit features a series of 10 clock and boot configuration dipswitches. These dip switches determine the order of peripherals for a valid boot image as well as the clock source selection. MSEL (5 Switches), CLKSEL (2 Switches) and BOOTSEL (3 Switches) are configured via S100. By default the MitySOM-5CSX Development Kits is required to boot initially from the MMC/SD card. 6 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 ABSOLUTE MAXIMUM RATINGS OPERATING CONDITIONS If Military/Aerospace specified cards are required, please contact the Critical Link Sales Office or unit Distributors for availability and specifications. Ambient Temperature Range Humidity Maximum Supply Voltage Storage Temperature Range -40 to 85C 0 to 95% Non-condensing 25.2 V -40 to 85C ELECTRICAL CHARACTERISTICS Symbol Parameter Conditions Typical Maximum Power Supply Output IMax 24V Supply (AC Adapter) all components 1 IMax 12.0V Supply for external components 1 IMax 5.0V Supply for external components 1 IMax 3.3V Supply for external components Power Dissipation VS Supply Voltage 2 IS Supply Current 24±5% 250 Limit Units (Limits) 2.7 2.0 2.0 3.0 A A A A V mA Notes: 1. The maximum current supplied to external components should be limited to the specified maximum for all externally connected power supplies 2. PCI-e/HSMC cards not attached, 100% ARM utilization, RS-232 and Ethernet are enabled and active. 7 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 ELECTRICAL INTERFACE DESCRIPTIONS Input Power – J601 and J600 The MitySOM-5CSX Development Kit power interface, J601, requires a single +24Volt power supply. A recommended input supply rating of at least 2A is recommended and a 2.7A supply is included with each Development Kit. Table 1: Input Power Interface Pin Description Signal J601 Position +24V 1 GND 2 Additionally the MitySOM-5CSX Development Kit provides a standard ATX PC power supply connector, J600, which can be utilized; power supply not included. Any supply capable of 100W or more is recommended. When this type of input supply is used J601 should NOT be connected. Note that when an ATX power supply is used there is no control logic on the Development Kit so when connected the Development Kit will be powered unless an external switch is used or the supply is unplugged from AC power. Main Power Switch – S600 An input power switch is present on the Development Kit, S600, which controls the power input, on or off, from J601. It has no effect on the ATX power supply input, J600. MultiMedia Card (SD) Interface – J403 The MitySOM-5CSXx Development Kit provides a MMC interface that uses a standard Secure Digital (SD) card slot for the physical interface. Through the use of SD card adapters MicroSD and MiniSD cards can be used in this slot. By default the slot is supplied with 3.3V for use with standard SD cards and the R140 resistor can be depopulated while R139 is populated to provide a 1.8V supply for SDHC cards. Debug/Boot UART - USB Interface – J400 Table 2: J400 Mini USB Connector Pin Assignments Pin 1 2 3 4 5 Signal VBUS DD+ GND SHIELD Type Power I/O I/O GND GND Standard USB 2.0 USB 2.0 - Notes USB data minus line USB data plus line USB 2.0 Interface (OTG) – J401 Table 3: J401 Pin Assignments Pin 1 2 3 4 5 Signal USB1_VBUS USB1_D_N USB1_D_P USB1_ID GND Type POWER I/O I/O I/O POWER Standard USB 2.0 USB 2.0 - 8 Notes USB data minus line USB data plus line Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 Dual CAN Interface – J404 & J405 Table 4: J404 CAN1 & J405 CAN0 Connector1 Pin Assignments Pin 1 2 3 4 5 6 7 8 9 10 Signal RESERVED CANL GND_ISOCANx2 RESERVED RESERVED RESERVED CANH RESERVED +5V_CANx2 RESERVED Type I/O Power I/O Power - Standard - Notes CAN Bus Signal L CAN Bus Isolated Ground - CAN Bus Signal H - Isolated +5V Output, 20mA Max Note 1: Please see Figure 2 for physical pin-out of connector Note 2: The ‘x’ at the end of the signal names is either a 1 or a 0 depending on which CAN interface you are using. 5 4 3 2 1 10 9 8 7 6 Figure 2: J404 and J405 Pin-out (Top View) SATA Interface – J402 Table 5 describes the pin-out of the SATA connector on the MitySOM-5CSX development board. A SATA core is needed in the FPGA fabric to utilize this interface. Table 5: J402 Pin Assignments Pin 1 2 3 4 5 6 7 Signal GND SATA_RX_C_P SATA_RX_C_N GND SATA_TX_C_N SATA_TX_C_P GND SoM Pin 232 234 241 239 - Type POWER I I POWER O O POWER Standard - 9 Notes Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 PCIe Interface – J200 Table 6 describes the pin-out of the PCI-e x4 capable interface on the MitySOM-5CSX development board. The I/O “type” is in reference to the signal direction from the SoM/development board. Table 6: J200 Pin Assignments Pin A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 A16 A17 A18 A19 A20 A21 A22 A23 A24 A25 A26 A27 A28 A29 A30 A31 A32 B1 B2 B3 B4 B5 B6 B7 B8 B9 B10 B11 B12 B13 B14 B15 B16 B17 Signal GND +12V_EXT +12V_EXT GND JTAG2 JTAG3 JTAG4 JTAG5 +3.3V_EXT +3.3V_EXT PCIE1_PERST_SJN GND PCIE_CLK0_R_P PCIE_CLK0_R_N GND PCIE1_RX_0_P PCIE1_RX_0_N GND RESERVED GND PCIE1_RX_1_P PCIE1_RX_1_N GND GND PCIE1_RX_2_P PCIE1_RX_2_N GND GND PCIE1_RX_3_P PCIE1_RX_3_N GND RESERVED +12V_EXT +12V_EXT +12V_EXT GND PCIE1_SMCLK PCIE1_SMDAT GND +3.3V_EXT JTAG1 +3.3V_EXT PCIE1_WAKEN RESERVED GND PCIE_TX_0_P PCIE_TX_0_N GND PCIE1_X1_PRSNT2N SoM Pin 21 204 202 208 210 214 216 226 228 69 71 83 209 211 101 Type POWER POWER POWER POWER NC NC NC POWER POWER I POWER O O POWER I I POWER POWER I I POWER POWER I I POWER POWER I I POWER POWER POWER POWER POWER I I/O POWER POWER NC POWER O POWER O O POWER I 10 Standard 1A Max 1A Max 1A Max 1A Max 1A Max 1A Max - Notes Note 2 Note 2 TCK – 2.2k ohm resistor to ground TDI – No connect TDO – No connect TMS – No connect Note 1 Note 1 100MHz clock, U200, to PCI-e device 100MHz clock, U200, to PCI-e device Note 1 TRSTn – No connect Note 1 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com B18 B19 B20 B21 B22 B23 B24 B25 B26 B27 B28 B29 B30 B31 B32 MitySOM-5CSX Development Kit 6 August 2014 GND PCIE_TX_1_P PCIE_TX_1_N GND GND PCIE_TX_2_P PCIE_TX_2_N GND GND PCIE_TX_3_P PCIE_TX_3_N GND RESERVED PCIE1_X4_PRSNT2N GND 215 217 221 223 233 235 162 - POWER O O POWER POWER O O POWER POWER O O POWER I POWER - Notes: 1. The maximum total current supplied to external components from the +3.3V supply should be limited to less than 3.0A. The maximum current allowed per connector pin is 1A. 2. The maximum total current supplied to external components from the +12V supply should be limited to less than 2.0A. The maximum current allowed per connector pin is 1A. Full HSMC Interface- J300 Table 7 describes the pin-out of the Full HSMC interface on the MitySOM-5CSX development board. The I/O “type” is in reference to the signal direction from the SoM/development board. Table 7: J300 Connector Pin Assignments Pin 1 - 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 Schematic Signal RESERVED HSMC1_SMSDA HSMC1_SMSCL HSMC1_JTAG_TCK HSMC1_JTAG_TMS HSMC1_JTAG_TDO HSMC1_JTAG_TDI HSMC1_CLKOUT0 HSMC1_CLKIN0 HSMC1_D0 HSMC1_D1 HSMC1_D2 HSMC1_D3 +3.3V +12V HSMC1_TX0_P HSMC1_RX0_P HSMC1_TX0_N HSMC1_RX0_N +3.3V +12V HSMC1_TX1_P HSMC1_RX1_P HSMC1_TX1_N HSMC1_RX1_N SoM Pin 54 56 160 99 74 90 76 106 68 87 70 89 78 91 80 93 Type I/O O O I I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Standard 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 11 Notes Bank 4A Bank 4A J302 – Pin 1 J302 – Pin 5 J302 – Pin 3 J302 – Pin 9 Bank 3B Bank 3B Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 +3.3V +12V HSMC1_TX2_P HSMC1_RX2_P HSMC1_TX2_N HSMC1_RX2_N +3.3V +12V HSMC1_TX3_P HSMC1_RX3_P HSMC1_TX3_N HSMC1_RX3_N +3.3V +12V HSMC1_TX4_P HSMC1_RX4_P HSMC1_TX4_N HSMC1_RX4_N +3.3V +12V HSMC1_TX5_P HSMC1_RX5_P HSMC1_TX5_N HSMC1_RX5_N +3.3V +12V HSMC1_TX6_P HSMC1_RX6_P HSMC1_TX6_N HSMC1_RX6_N +3.3V +12V HSMC1_TX7_P HSMC1_RX7_P HSMC1_TX7_N HSMC1_RX7_N +3.3V +12V HSMC1_CLKOUT1_P HSMC1_CLKIN1_P HSMC1_CLKOUT1_N HSMC1_CLKIN1_N +3.3V +12V HSMC1_TX8_P HSMC1_RX8_P HSMC1_TX8_N HSMC1_RX8_N +3.3V +12V HSMC1_TX9_P HSMC1_RX9_P HSMC1_TX9_N HSMC1_RX9_N +3.3V +12V HSMC1_TX10_P HSMC1_RX10_P HSMC1_TX10_N MitySOM-5CSX Development Kit 6 August 2014 82 95 84 97 86 105 88 107 94 109 96 111 98 113 100 115 102 121 104 123 110 133 112 135 114 177 116 179 118 137 120 139 122 141 124 143 138 145 140 Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power O I O I Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 12 Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 8A Bank 4A Bank 8A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 3B Bank 3B Bank 3B Bank 3B Note 1 Note 2 Bank 3B Bank 3B Bank 3B Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 - 172 HSMC1_RX10_N +3.3V +12V HSMC1_TX11_P HSMC1_RX11_P HSMC1_TX11_N HSMC1_RX11_N +3.3V +12V HSMC1_TX12_P HSMC1_RX12_P HSMC1_TX12_N HSMC1_RX12_N +3.3V +12V HSMC1_TX13_P HSMC1_RX13_P HSMC1_TX13_N HSMC1_RX13_N +3.3V +12V HSMC1_TX14_P HSMC1_RX14_P HSMC1_TX14_N HSMC1_RX14_N +3.3V +12V HSMC1_TX15_P HSMC1_RX15_P HSMC1_TX15_N HSMC1_RX15_N +3.3V +12V HSMC1_TX16_P HSMC1_RX16_P HSMC1_TX16_N HSMC1_RX16_N +3.3V +12V HSMC1_CLKOUT2_P HSMC1_CLKIN2_P HSMC1_CLKOUT2_N HSMC1_CLKIN2_N +3.3V HSMC1_PRSNTN GND MitySOM-5CSX Development Kit 6 August 2014 147 142 149 144 151 146 155 148 157 150 159 152 161 154 163 156 165 164 167 166 169 168 171 170 173 178 172 180 174 85 - I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power O I O I Power O Power 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 2.5V Bank 3B Note 1 Note 2 Bank 3B Bank 3B Bank 3B Bank 3B Note 1 Note 2 Bank 3B Bank 3B Bank 3B Bank 3B Note 1 Note 2 Bank 3B Bank 3B Bank 3B Bank 3B Note 1 Note 2 Bank 3B Bank 3B Bank 3B Bank 3B Note 1 Note 2 Bank 3B Bank 3B Bank 3B Bank 3B Note 1 Note 2 Bank 3B Bank 3B Bank 3B Bank 3B Note 1 Note 2 Bank 8A Bank 8A Bank 8A Bank 8A Note 1 Bank 4A Notes: 1. The maximum total current supplied to external components from the +3.3V supply should be limited to less than 3.0A. The maximum current allowed per connector pin is 1A. 2. The maximum total current supplied to external components from the +12V supply should be limited to less than 2.0A. The maximum current allowed per connector pin is 1A. Please see the following Altera documentation concerning the HSMC specification (http://www.altera.com/literature/ds/hsmc_spec.pdf). 13 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 Full HSMC JTAG Debug Interface – J302 Table 8 describes the pin-out of the Full HSMC JTAG interface on the MitySOM-5CSX development board. This allows for debug of JTAG supported HSMC cards/devices. Table 8: J101 JTAG Pin Assignments Pin 1 2 3 4 5 6–8 9 10 Schematic Signal HSMC1_JTAG_TCK GND HSMC1_JTAG_TDO +3.3V_EXT HSMC1_JTAG_TMS RESERVED HSMC1_JTAG_TDI GND SoM Pin - Type Power Power Power Standard Notes J300 – Pin 35 1A Max J300 – Pin 37 Note 1 J300 – Pin 36 J300 – Pin 38 14 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 Partial HSMC Interface – J301 Table 9 describes the pin-out of the partial HSMC interface on the MitySOM-5CSX development board. The I/O “type” is in reference to the signal direction from the SoM/development board. Table 9: J506 Connector Pin Assignments Pin 1 - 28 29 30 31 32 33 34 35 – 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 Schematic Signal RESERVED HSMC2_GTX0_P HSMC2_GRX0_P HSMC2_GTX0_N HSMC2_GRX0_N HSMC2_SMSDA HSMC2_SMSCL RESERVED HSMC2_D1_P HSMC2_D2_P HSMC2_D1_N HSMC2_D2_N +3.3V +12V HSMC2_TX0_P HSMC2_RX0_P HSMC2_TX0_N HSMC2_RX0_N +3.3V +12V HSMC2_TX1_P HSMC2_RX1_P HSMC2_TX1_N HSMC2_RX1_N +3.3V +12V HSMC2_TX2_P HSMC2_RX2_P HSMC2_TX2_N HSMC2_RX2_N +3.3V +12V HSMC2_TX3_P HSMC2_RX3_P HSMC2_TX3_N HSMC2_RX3_N +3.3V +12V HSMC2_TX4_P HSMC2_RX4_P HSMC2_TX4_N HSMC2_RX4_N +3.3V +12V HSMC2_TX5_P HSMC2_RX5_P HSMC2_TX5_N HSMC2_RX5_N +3.3V +12V J303 Pin 17 16 19 13 18 14 21 11 20 12 23 9 21 10 25 7 24 8 - SoM Pin 245 238 247 240 58 56 65 61 67 63 64 77 66 79 62/196 73 198 71 192 203 194 205 188 199 190 201 184 195 186 197 42 191 44 193 - Type O I O I I/O O I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power 15 Standard Notes Transceiver Transceiver Transceiver Transceiver Bank 4A Bank 4A 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Bank 4A Bank 4A Bank 4A Bank 4A Note 1 Note 2 Note 3 Bank 4A Note 3 Bank 4A Note 1 Note 2 Note 3 Note 3 Note 3 Note 3 Note 1 Note 2 Note 3 Note 3 Note 3 Note 3 Note 1 Note 2 Note 3 Note 3 Note 3 Note 3 Note 1 Note 2 Note 3 Note 3 Note 3 Note 3 Note 1 Note 2 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com 83 84 85 86 87 88 89 90 91 92 93 94 95 - 98 99 100 101 - 104 105 106 107 - 110 111 112 113 - 116 117 118 119 - 122 123 124 125 - 128 129 130 131 - 134 135 136 137 - 140 141 142 143 - 146 147 148 149 - 152 153 154 155 156 157 158 159 160 161 - 172 HSMC2_TX6_P HSMC2_RX6_P HSMC2_TX6_N HSMC2_RX6_N +3.3V +12V HSMC2_TX7_P HSMC2_RX7_P HSMC2_TX7_N HSMC2_RX7_N +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V RESERVED +3.3V +12V HSMC2_CLK_P RESERVED HSMC2_CLK_N RESERVED +3.3V HSMC2_PRSNTN GND MitySOM-5CSX Development Kit 6 August 2014 27 5 26 6 29 3 28 4 - 53 187 55 189 47 183 49 185 60 - I/O I/O I/O I/O Power Power I/O I/O I/O I/O Power Power Power Power Power Power Power Power Power Power Power Power Power Power Power Power Power Power Power Power Power Power O O Power I Power 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max 2.5V 2.5V 2.5V 2.5V 1A Max 1A Max Note 3 Note 3 Note 3 Note 3 Note 1 Note 2 Note 3 Note 3 Note 3 Note 3 Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 1A Max 1A Max Note 1 Note 2 100MHz clock, U102, to HSMC device 100MHz clock, U102, to HSMC device 1A Max Note 1 Bank 4A Notes: 1. The maximum total current supplied to external components from the +3.3V supply should be limited to less than 3.0A. The maximum current allowed per connector pin is 1A. 2. The maximum total current supplied to external components from the +12V supply should be limited to less than 2.0A. The maximum current allowed per connector pin is 1A. 3. These pins are only connected when using a module with expanded IO capabilities. Please see the following Altera documentation concerning the HSMC specification (http://www.altera.com/literature/ds/hsmc_spec.pdf). 16 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 10/100/1000 Ethernet Interface – J500 The MitySOM-5CSX Development Kit provides a RJ-45 connection for a Gigabit 10/100/1000 Ethernet connection. This connection follows standard TIA/EIA-568B pinout as shown in Table 10 below. The Ethernet PHY, Micrel KSZ9031, will auto negotiate to the speed of the device it is connected to. Table 10: J500 Ethernet RJ45 Pin Assignments Pin 1 2 3 4 5 6 7 8 Signal TXRXA_P TXRXA_N TXRXB_P TXRXB_N TXRXC_P TXRXC_N TXRXD_P TXRXD_N Type I/O I/O I/O I/O I/O I/O I/O I/O Standard Notes Boot Configuration header – J106 The boot mode, as determined by the 10 CONFIG switches, is selected on the rising edge of the PWRONRSTn Reset Input Pin of the Cyclone V processor which is controlled by the PMIC of the MitySOM-5CSX module. Each boot configuration pin on the development kit is connected to a weak pull up, ‘1’, unless a switch is closed which pulls that configuration pin down to ground, ‘0’. The MitySOM-5CSX Development Kits default boot configuration mode is shown in Figure 3 below. As seen this equates to a boot configuration setting of S1 to S10, 0000011101. Please reference the Cyclone V Technical Reference Manual for complete details on how the vast array of boot mode options. Figure 3: Default Development Kit Boot Jumper Mode 17 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 Included Components The following table lists the components that are included with a MitySOM-5CSX Development Kit. See Table 12 for specific development kit ordering information. Table 11: Included Items Description Interface Port MitySOM-5CSX Development Kit Board n/a MitySOM-5CSX Module J100 Mini USB Cable for Debug Console J400 24V 2.7A AC to DC Supply J601 Ethernet cable – 7 foot J500 USB Drive with Development Environment n/a Development Kit Schematic Files n/a Development Kit Gerber Drawings n/a Development Kit Bill Of Materials n/a Development Kit Quick Start Guide n/a Qty. Included Qty. 1 Qty. 1 Qty. 1 Qty. 1 Qty. 1 Qty. 1 MitySOM-5CSX Development Kit Board with MitySOM-5CSX Module 18 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 ORDERING INFORMATION Development Kits The following table lists the standard MitySOM-5CSX Development Kit configurations. For shipping status, availability, and lead time of these or other configurations please contact your Critical Link representative. Table 12: Standard Model Numbers Development Kit Model Module Included Module Junction Temp 80-000640 5CSX-H6-42A-RC 0oC to 90o C 80-000639 5CSX-H6-42A-RI -40oC to 105o C MECHANICAL INTERFACE DESCRIPTION Main Board Interface / Mounting Figure 4: MitySOM-5CSX Development Kit Outline, Mounting Hole Locations, (Top View, inches) 19 Copyright © 2007-2013, Critical Link LLC Critical Link, LLC www.CriticalLink.com MitySOM-5CSX Development Kit 6 August 2014 REVISION HISTORY Date 12-JAN-2014 31-APR-2014 6-AUG-2014 Change Description Initial revision. Updates and changes from review and initial release. Updates and changes to encompass more detailed pinout. 20 Copyright © 2007-2013, Critical Link LLC
80-000639 价格&库存
很抱歉,暂时无法提供与“80-000639”相匹配的价格&库存,您可以联系我们找货
