80-000320
80-000320
    CRITICALLINK
80-000320 数据手册
Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 FEATURES  TI AM1810 ARM9 Application Processor -        375 MHz ARM926EJ-S MPU  16 KB L1 Program Cache  16 KB L1 Data Cache  8 KB Internal RAM  64 KB boot ROM  JTAG Emulation/Debug On-Board Xilinx Spartan-6 FPGA - Up To XC6SLX45  Up To 2,088 KBits Block RAM  Up To 6,822 Slices (6 Input LUTs) - 1050 Mbps data rate - JTAG Interface/Debug APPLICATIONS  Embedded Instrumentation  Industrial Automation  Industrial Instrumentation  Medical Instrumentation  Embedded Control Processing  Network Enabled Data Acquisition  Test and Measurement  Software Defined Radio  Bar Code Scanners  Power Protection Systems  Portable Data Terminals Up To 256 MB mDDR2 CPU RAM Up To 512 MB Parallel NAND FLASH 8 MB SPI based NOR FLASH Integrated Power Management Standard SO-DIMM-200 Interface - 96 FPGA User I/O Pins - 10/100 EMAC MII / MDIO - 2 UARTS - 2 McBSPs - 2 USB Ports - Video Output - Camera/Video Input - MMC/SD - SATA - ePWM, eCAP - EMIFA - Single 3.3V Power Supply BENEFITS  Rapid Development / Deployment  Multiple Connectivity and Interface Options  Rich User Interfaces  High System Integration  High Level OS Support  High Level OS Support - Linux - QNX - Windows Embedded CE Ready - ThreadX Real Time OS PROFIBUS Interface - Certified by PI International - Real-Time Linux Drivers - Up to 6Mbaud operation DESCRIPTION The MitySOM-1810F is a highly configurable, very small form-factor processor card that features a Texas Instruments AM1810 375MHz ARM Applications Processor tightly integrated with the Xilinx Spartan-6 Field Programmable Gate Array (FPGA), PROFIBUS, FLASH (NAND and NOR) and mDDR2 RAM memory subsystems. 1 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 The design of the MitySOM-1810F allows end users the capability to develop programs/logic images for both the ARM processor and the FGPA. The MitySOM1810F provides a complete and flexible digital processing infrastructure necessary for the most demanding embedded applications development. The AM1810 includes an ARM926EJ-S micro-processor unit (MPU) capable of running the rich software applications programming interfaces (APIs) expected by modern system designers. The ARM architecture supports several operating systems, including RealTime Linux, QNX and Windows XP embedded. Linux drivers are available for all interfaces, including the PROFIBUS interface. 8MB NOR Flash (SPI interface) For uBoot bootloader Up To 256MB mDDR Memory 16-bit wide 1.2V Up To 512MB NAND Flash 16-bit wide For root FFS 1.8V 2.5V Power Management 3.3V EMIFA (16-bit) System Clocks JTAG/Emulator JTAG Header JTAG MMCSD 1 LCD uPP Xilinx Spartan-6 FPGA Up To XC6SLX45 CSG324 pkg. Programmable I/O I/O Bank Power Boot Config Resets & RTC SATA USB 0,1 Timers eCAP eHRPWM I2C 0,1 McASP SPI 0,1 McBSP 0,1 MMCSD 0 UART 0,1,2 EMAC MII/MDIO Boot Config FPGA I/O Banks can be 1.8V, 2.5V, or 3.3V I/O Bank Power VPIF I/O GND (Many pins are multiplexed between peripherals) UHPI 3.3 V EMAC RMII Programmable I/O Texas Instruments AM1810 375-MHz ARM926EJ-S ™ RISC MPU SO-DIMM-200 (DDR2 Connector) Figure 1 MitySOM-1810F Block Diagram Figure 1 provides a top level block diagram of the MitySOM-1810F processor card. As shown in the figure, the primary interface to the MitySOM-1810F is through a standard SO-DIMM-200 card edge interface. The interface provides power, synchronous serial connectivity, and up to 96 pins of configurable FPGA I/O for application defined interfacing. Details of the SO-DIMM-200 connector interface are included in the SODIMM-200 Interface Description, below. 2 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 PROFIBUS Interface Texas Instruments Inc. (TI) has integrated PROFIBUS functionality into its AM1810 Sitara ARM microprocessor (MPU). The solution utilizes one of the onboard UARTS and connects directly to the RS-485 transceiver and therefore eliminates the need of an external PROFIBUS ASIC or FPGA. Customers using the MitySOM-1810 in their industrial application can save cost and reduce design complexity as well as PCB space. Furthermore, the industrial application benefits from the low-power architecture of the Sitara ARM MPU and the MitySOM-1810 platform from TI and Critical Link. The AM1810 Sitara ARM MPU PROFIBUS Slave solution has been certified by PROFIBUS International (PI). The PROFIBUS real-time frame handler (Fieldbus Data Link or FDL) is encapsulated in the Programmable Real-Time Unit Subsystem (PRUSS), which is part of the AM1810 Sitara ARM MPU on-chip peripherals. The PRUSS uses one Universal Asynchronous Receiver/Transmitter (UART) and a timer to generate PROFIBUS-compliant frames. The industrial application and the PROFIBUS DP-Protocol (Layer 7) are operated on the ARM. The solution can be completed with an RS-485 transceiver suitable for harsh environments, such as TI’s ISO1176T or ISO1176 placed on the base board to the MitySOM-1810F. The PROFIBUS subsystem uses the PRUs that implement real-time frame handling; PROFIBUS message transmission, frame validation and communication with the ARM processor. The PROFIBUS subsystem interfaces with one of the UARTs in the AM1810 Sitara ARM MPU, which is designated for PROFIBUS communication at up to 6Mbaud data rate. The PRU uses interrupts to interact with the ARM where the PROFIBUS stack (Layer 7, DP Protocol) and the industrial application is run. All process data handling like cyclic, acyclic and service access point (SAP) between the PROFIBUS stack on ARM and the PRU is through the internal memory. Additional details about the AM1810 Sitara ARM MPU, available peripherals and their features are provided in the data sheet at the TI website (www.ti.com/am1810). FPGA Bank I/O The MitySOM-1810F provides 96 lines of FPGA I/O directly to the SO-DIMM-200 card edge interface. The 96 lines of FPGA I/O are distributed across 2 banks of the FPGA. These I/O lines and their associated logic are completely configurable within the FPGA at the end user’s discretion. With the Xilinx Spartan-6 series FPGA, up to the XC6SLX45, each of the user controlled banks may be configured to operate on a different electrical interface standard based on input voltage provided at the card edge connector. The banks support 3.3V, 2.5V, and 1.8V standard CMOS switching level technology. In addition, the I/O lines from the FPGA have been routed as differential pairs and support higher speed LVDS standards as well as SSTL 2.5 switching standards. Various forms of termination (pull-up/pull-down, 3 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 digitally controlled impedance matching) are available within the FPGA switch fabric. Refer to the Xilinx Spartan 6 user’s guide for more information. AM1810 mDDR2 Memory Interface The AM1810 includes a dedicated DDR2 SDRAM memory interface. The MitySOM1810F includes up to 256 MB of mDDR2 RAM integrated with the AM1810 processor. The bus interface is capable of burst transfer rates of 532 MB / second. AM1810 SPI NOR FLASH Interface The MitySOM-1810F includes 8 MB of SPI NOR FLASH. This FLASH memory is intended to store a factory provided bootloader, and typically a compressed image of a Linux kernel for the ARM core processor. EMIFA / NAND FLASH Interface The Asynchronous External Memory Interface (EMIFA) interface available on the AM1810 is available on the SO-DIMM-200 connector. The EMIFA interface includes 3 chip select spaces. The EMIF interface supports multiple data width transfers and bus wait state configurations based on chip select space. 8, and 16 bit data word sizes may be used. Up to 512 MB of on-board NAND FLASH memory is connected to the AM1810 using the EMIFA bus. The FLASH memory is 8 bits wide and is connected to the third chip select line of the EMIFA (CE1). The FLASH memory is typically used to store the following types of data: - ARM Linux / Windows Embedded CE / QNX embedded root file-system FPGA application images runtime ARM software runtime application data (non-volatile storage) AM1810 Camera and Video Interfaces The AM1810 includes an optional video port I/O interface commonly used to drive LCD screens as well as a camera input interface. These interfaces have been routed directly to the SO-DIMM-200 connector. Debug Interface Both the JTAG interface signals for the FPGA and the JTAG signals for the AM1810 processor have been brought out to a Hirose header that is intended for use with an available Critical Link breakout adapter. This header can be removed for production units; please contact your Critical Link representative for details. This adapter is not included with individual modules but is included with each Critical Link Development Kit that is ordered. If an adapter, Critical Link (CL) part number 80000286, is needed please contact your Critical Link representative. 4 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 Software and Application Development Support Users of the MitySOM-1810F are encouraged to develop applications using the MitySOM-1810F software development kit provided by Critical Link LLC. The development kit includes an implementation of an OpenEmbedded board support package providing an Angstrom based Linux distribution and compatible gcc compiler tool-chain with debugger. To support rapid FPGA and applications development, netlist components - compatible with the Xilinx ISE FPGA synthesis tool – for commonly used FPGA designs and a corresponding set of Linux loadable kernel modules are included. The libraries provide the necessary functions needed to configure the MitySOM-1810F, program standalone embedded applications, and interface with the various hardware components both on the processor board as well as a custom application carrier card. The libraries include several interface “cores” – FPGA and ARM software modules designed to interface with various high performance data converter modules (ADCs, DACs, LCD and touchscreen interfaces, etc) – as well as bootloading and FLASH programming utilities. Growth Options The MitySOM-1810F has been designed to support several upgrade options. These options include various speed grades, memory configurations, and operating temperature specifications including commercial and industrial temperature ranges. The available options are listed in the section below containing ordering information. For additional ordering information and details regarding these options, or to inquire about a particular configuration not listed below, please contact a Critical Link sales representative. 5 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 ABSOLUTE MAXIMUM RATINGS OPERATING CONDITIONS If Military/Aerospace specified cards are required, please contact the Critical Link Sales Office or unit Distributors for availability and specifications. Ambient Temperature Range Commercial Ambient Temperature Range Industrial Humidity Maximum Supply Voltage, Vcc Storage Temperature Range Shock, Z-Axis Shock, X/Y-Axis 3.5 V MIL-STD-810F -65oC to 80oC ±10 g ±10 g 0oC to 70oC -40oC to 85oC 0 to 95% Non-condensing Contact Critical Link for Details SO-DIMM-200 Interface Description The primary interface connector for the MitySOM-1810F is the SO-DIMM card edge interface. Pin 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 I/O I O O I I I I/O I/O O I/O I/O O I/O I/O I/O I/O I/O I/O I/O I/O Table 1 SO-DIMM Pin-Out Signal Pin I/O +3.3 V in 2 +3.3 V in 4 +3.3 V in 6 GND 8 GND 10 RESET_IN# 12 SATA_TX_P 14 I/O SATA_TX_N 16 I/O SATA_RX_P 18 I/O SATA_RX_N 20 I/O USB0_ID 22 I/O USB1_D_N 24 I/O USB1_D_P 26 I/O USB0_VBUS 28 I/O USB0_D_N 30 I/O USB0_D_P 32 I/O USB0_DRVVBUS 34 I/O 3V RTC Battery 36 I/O +3.3 V in 38 +3.3 V in 40 GND 42 SPI1_MISO 44 I/O SPI1_MOSI 46 I/O SPI1_ENA 48 I/O SPI1_CLK 50 I/O SPI1_SCS1 52 I/O Reserved 54 I/O I2C0_SCL 56 I/O I2C0_SDA 58 I/O 6 Signal +3.3 V in +3.3 V in +3.3 V in GND GND EXT_BOOT# GP0_7 GP0_10 GP0_11 GP0_15 GP0_6 GP0_14 GP0_12 GP0_5 GP0_13 GP0_1 GP0_4 GP0_3 +3.3 V in +3.3 V in GND GP0_2 GP0_0 GP0_8 GP0_9 MMCSD0_DAT7 MMCSD0_DAT6 MMCSD0_DAT5 MMCSD0_DAT4 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com Pin 59 I/O I/O 61 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 97 99 101 103 105 107 109 111 113 115 117 119 121 123 125 127 129 131 133 135 137 139 141 143 145 147 149 151 153 155 157 I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O MitySOM MitySOM-1810F Processor Card 5-MAR-2014 Signal UART2_TXD / I2C1_SDA UART2_RXD / I2C1_SCL GND UART1_TXD UART1_RXD MDIO_CLK MDIO_DAT MII_RXCLK MII_RXDV MII_RXD0 MII_RXD1 MII_RXD2 MII_RXD3 GND MII_CRS MII_RXER B1 _47_P.U17 B1_ 47_N.U18 B1 _45_P.T17 B1_ 45_N.T18 B1_43_P.P17 B1_43_N.P18 B1_41_P.N17 B1_41_N.N18 GND B1_39_P.M16 B1_39_N.M18 B1_37_P.L17 B1_37_N.L18 B1_35_P.K17 B1_35_N.K18 B1_33_P.J16 B1_33_N.J18 B1_31_P.H17 B1_31_N.H18 GND B1_29_P.G16 B1_29_N.G18 B1_27_P.F17 B1_27_N.F18 B1_25_P.E16 B1_25_N.E18 B1_23_P.D17 B1_23_N.D18 B1_21_P.C17 B1_21_N.C18 GND B0_19_P.B16 B0_19_N.A16 B0_17_P.C15 7 Pin 60 I/O I/O Signal MMCSD0_DAT3 62 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100 102 104 106 108 110 112 114 116 118 120 122 124 126 128 130 132 134 136 138 140 142 144 146 148 150 152 154 156 158 I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O* I/O* I/O* MMCSD0_DAT2 GND MMCSD0_DAT1 MMCSD0_DAT0 MMCSD0_CMD MMCSD0_CLK MII_TXCLK MII_TXD3 MII_TXD2 MII_TXD1 MII_TXD0 MII_TXEN GND MII_COL FPGA_SUSPEND B1 _48_P.M14 B1_ 48_N.N14 B1 _46_P.N15 B1_ 46_N.N16 B1 _44_P.L12 B1_ 44_N.L13 B1 _42_P.K12 B1_ 42_N.K13 GND B1 _40_P.L15 B1_ 40_N.L16 B1 _38_P.K15 B1_ 38_N.K16 B1 _36_P.J13 B1_ 36_N.K14 B1 _34_P.H15 B1_ 34_N.H16 B1 _32_P.H13 B1_ 32_N.H14 GND B1 _30_P.F15 B1_ 30_N.F16 B1 _28_P.H12 B1_ 28_N.G13 B1 _26_P.F14 B1_ 26_N.G14 B0 _24_P.F13 B0_ 24_N.E13 B0 _22_P.D14 B0_ 22_N.C14 GND B0 _20_P.F12* B0_ 20_N.E12* B0 _18_P.D12* Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com Pin 159 161 163 165 167 169 171 173 175 177 179 181 183 185 187 189 191 193 195 197 199 I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O - MitySOM MitySOM-1810F Processor Card 5-MAR-2014 Signal B0_17_N.A15 B0_15_P.B14 B0_15_N.A14 B0_13_P.C13 B0_13_N.A13 B0_11_P.B12 B0_11_N.A12 GND B0_9_P.B11 B0_9_N.A11 B0_7_P.C10 B0_7_N.A10 B0_5_P.B9 B0_5_N.A9 B0_3_P.B8 B0_3_N.A8 B0_1_P.C7 B0_1_N.A7 GND VCCO_1 VCCO_1 Pin 160 162 164 166 168 170 172 174 176 178 180 182 184 186 188 190 192 194 196 198 200 I/O I/O* I/O* I/O* I/O I/O I/O* I/O* I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O - Signal B0_ 18_N.C12* B0 _16_P.F11* B0_ 16_N.E11* B0 _14_P.D11 B0_ 14_N.C11 B0 _12_P.E7* B0_ 12_N.E8* GND B0 _10_P.D9 B0_ 10_N.C9 B0 _8_P.D8 B0_ 8_N.C8 B0 _6_P.D6 B0_ 6_N.C6 B0 _4_P.B6 B0_ 4_N.A6 B0 _2_P.C5 B0_ 2_N.A5 GND VCCO_0 VCCO_0 * The Xilinx 6SLX45 FPGA does not bond I/O Buffers to balls E7, E8, F11, E11, D12, C12, E12, and F12 of the package used for this module. For MitySOM-1810F configurations using this FPGA option, these edge connector signals should be treated as no-connects and will not function as FPGA I/O lines. The signal group description for the above pins is included in Table 2 Table 2 Signal Group Description Signal / Group 3.3 V in EXT_BOOT# I/O N/A I RESET_IN# I SPI_XXXX I/O MII_XXXX I/O Description 3.3 volt input power referenced to GND. Bootstrap configuration pin. Pull low to configure booting from external UART1. Manual Reset. When pulled to GND for a minimum of 1 usec, resets the DSP processor. The pins with an SPI_ prefix are direct connections to the AM1810 pins supporting the SPI1 interface. The SPI1_CLK, SPI1_ENA, SPI1_MISO, SPI1_MOSI pins must remain configured for the SPI function in order to support interfacing to the on-board SPI boot ROM. For details please refer to the AM1810 processor specifications. The pins with an MII_ prefix are direct connections to the AM1810 pins supporting the 8 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com Signal / Group MitySOM MitySOM-1810F Processor Card 5-MAR-2014 I/O MDIO_XX I/O GP0_X IO SATA_TX_P/N O SATA_RX P/N I GND BX_Y_P.ZZ, BX_Y_N.ZZ VCCO_X USB0_XXXX, USB1_XXXX N/A IO I I/O Description media independent interface (MII) function. The MII pins provide multiplex capability and may alternately be used as UART, GPIO, and SPI control pins. For details please refer to the AM1810 processor specification. The MDIO_CLK and MDIO_DAT signals are direct connects to the corresponding MDIO signals on the AM1810 processor. These pins may be configured for GPIO. General Purpose / multiplexed pins. These pins are direct connects to the corresponding GP0[X] pins on the AM1810 processor. The include support for the McASP, general purpose I/O, UART flow control, and McBSP 1. For details please refer to the AM1810 processor specifications. These pins are direct connects to the AM1810 SATA_TX differential Serial ATA controller pins. These pins are direct connects to the AM1810 SATA_RX differential Serial ATA controller pins. System Digital Ground. FPGA I/O pins. These pins are routed directly to FPGA pins ZZ. The “X” indicates which FPGA bank the pin is allocated. The bank is either 0 or 1. The FPGA fabric supports routing pins in differential pairs, the Y_P and Y_N portion of the name indicates the pair number and polarity. The pins have been routed in pairs with phase matched line lengths. FPGA Bank interface power input. These pins must be tied to the desired voltage used for the FPGA Bank 0 or 1 interface pins. Please refer to the VCCO input pin specifications for the Xilinx Spartan 6 family of devices for further information. Typical values are 3.3V and 2.5 volts. The USBN_ prefixed pins are direct connects to the corresponding pins on the AM1810 processor. For details please refer to the AM1810 processor specifications. 9 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 DEBUG INTERFACE Below is the pin-out for the Hirose 31 pin header (DF9-31P-1V(32)) that interfaces with an available adapter board, CL part number 80-000286, to debug the AM1810 and FPGA. Debug Interface Connector Description (J2) Pin 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 I/O - GND GND GND GND GND GND GND GND GND GND GND GND GND GND GND GND Table 3 OMAP-L138 Hirose Connector Signal Pin I/O Signal 2 O OMAP EMU1 4 O OMAP EMU0 6 I OMAP TCK 8 O OMAP RTCK 10 O OMAP TDO 12 OMAP VCC / 3.3V 14 I OMAP TDI 16 I OMAP TRST 18 I OMAP TMS 20 GND 22 O FPGA VREF / VCCAUX 24 I FPGA TMS 26 I FPGA TCK 28 O FPGA TDO 30 I FPGA TDI ELECTRICAL CHARACTERISTICS Symbol V33 I33 I33-max FCPU FEMIF Table 4: Electrical Characteristics Parameter Conditions Min Typ Max Units Voltage supply, 3.3 volt input. 3.2 3.3 3.4 Volts Quiescent Current draw, 3.3 volt input TBS TBS mA Max current draw, positive 3.3 volt input. TBS TBS mA CPU internal clock Frequency (PLL output) 25 375 375 MHz EMIF bus frequency Must be ½ CPU 100 MHz 1. Power utilization of the MitySOM-1810F is heavily dependant on end-user application. Major factors include: ARM CPU PLL configuration, DSP Utilization FPGA utilization, and external DDR2 RAM utilization. 10 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 ORDERING INFORMATION The following table lists the standard module configurations. For shipping status, availability, and lead time of these or other configurations please contact your Critical Link representative. Model 1810-DG-225-RC 1810-DG-225-RI Table 5: Standard Model Numbers NOR ARM Speed FPGA NAND Flash Flash 375 MHz 6SLX16 8MB 256MB 375 MHz 6SLX16 8MB 256MB RAM 128MB 128MB Operating Temp 0oC to 70o C -40oC to 85o C MECHANICAL INTERFACE A mechanical outline of the MitySOM-1810F is illustrated in Figure 2, below. Figure 2 MitySOM-1810F Mechanical Outline 11 Copyright © 2012, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1810F Processor Card 5-MAR-2014 REVISION HISTORY Date 23-FEB-2012 11-DEC-2012 5-MAR-2014 Change Description Preliminary Draft, Updates and Release Update Debug Header information, added MIL-STD-810F and Up To notation for RAM and NAND Update MitySOM product name. 12 Copyright © 2012, Critical Link LLC Specifications Subject to Change
80-000320 价格&库存
很抱歉,暂时无法提供与“80-000320”相匹配的价格&库存,您可以联系我们找货
