Switchcraft : Specification
Page 1 of 2
U.S. Manufacturer of Industrial and Pro Audio/Broadcast Products Since 1946.
Mega-Con-X Cable Connector
Utilizing a separate o-ring,Mega Con X connectors are
available up to 31-#20 pins/sockets. Can be ordered with
quick connect type or threaded type coupling. Meets NEMA 6P
when mated.
Typical Specifications
Rating: 0.9 thru 2.3A, 600V
Conductor Size: 20 thru 24 AWG
Configuration: 31 - #20 Contacts
Certification:
◦ UL Recognized File #E150822 - 600V AC/DC
◦ CSA Certified File #181200 - 600V
◦ U.L. Temperature 75ºC max.
◦ Not for current interruption
Material Specifications
Cable Pin/Socket
Mechanical Backshell (Threaded): Nylon, UL Recognized, Black
Strap: Nylon, UL Recognized, Black
Screws: Stainless Steel
Grommet: Santoprene Rubber, Black
Coupling Ring: Nylon, UL Recognized, Black
Contacts: Brass, Gold over Nickel
Connector Body: Nylon, UL Recognized, Black
O-Ring: Neoprene Rubber, Black
Panel Mount
Panel Body: Nylon, UL Recognized, Black
Gasket: Neoprene Rubber, Black
Hex Nut: Nylon, UL Recognized, Black
Gasket, O-Ring, & Grommet materials are suitable for storage -40ºC to +90ºC (40ºF to +194ºF).
• Consult factory for higher temperature requirements.
Mechanical Specifications
• Durability: Minimum 300 mate/unmate cycles without mechanical or electrical failure
• Vibration: Coupling rings have overriding locking feature to prevent loosening or
separation of connector
• Hex Nut Torque: All series hex nut to withstand 10-12 inch/lb tightening torque
http://www.conxall.com/Specification.aspx?Parent=853
8/7/2012
Page 2 of 2
Electrical Specifications
• Voltage: 600V
• Current: See Electrical Current Rating Chart
Environmental Specifications
• Storage Temperature Rating: -40ºC to +115ºC (-40ºF to +239ºF)
• Corrosion: 300 Hr salt spray contacts
• Weathertight: Consult factory with specific application
Molded Cable Assemblies
• Watertight: NEMA 6P, 13: IEC IP67
8/7/2012
很抱歉,暂时无法提供与“23282-31PG-350”相匹配的价格&库存,您可以联系我们找货
