2002-403
2002-403
    WAGO(万可电子)
2002-403 数据手册
Data sheet | Item number: 2002-403 Jumper; 3-way; insulated; light gray https://www.wago.com/2002-403 Color: light gray Electrical data Ratings per IEC/EN Ex information Nominal voltage (III/3) 800 V Rated current 25 A Rated current (Ex e II) 20 A . . Physical data Width 13.8 mm / 0.543 inches Height 4.1 mm / 0.161 inches Depth 19 mm / 0.748 inches Jumper assignment 1-2-3 . Material Data Note (material data) Information on material specifications can be found here Color light gray Fire load 0.01 MJ Weight 1.4 g . Commercial data Product Group 22 (TOPJOB S) eCl@ss 10.0 27-14-11-40 eCl@ss 9.0 27-14-11-40 ETIM 8.0 EC000489 ETIM 7.0 EC000489 PU (SPU) 25 pcs Packaging type Bag Country of origin DE GTIN 4055143687331 Customs tariff number 85366990990 . Page 1/3 Version 04.11.2022 Continued on next page Data sheet | Item number: 2002-403 https://www.wago.com/2002-403 Approvals and certificates Declarations of conformity and manufacturer's declarations Approval Standard Certificate name Railway WAGO GmbH & Co. KG - Railway Ready . Downloads Environmental Product Compliance Compliance Search Environmental Product Compliance 2002-403 . Documentation Additional Information Technical Section Bid Text pdf 2142.18 KB 2002-403 19.02.2019 xml 2.51 KB 27.04.2017 doc 23.50 KB 2002-403 . . CAD/CAE-Data CAD data CAE data 2D/3D Models 2002-403 EPLAN Data Portal 2002-403 WSCAD Universe 2002-403 . ZUKEN Portal 2002-403 . Installation notes Commoning Insert push-in type jumper bar and push down until it hits backstop. Removing a push-in type jumper bar: Insert the operating tool between the jum­ per and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers for up to five contacts (see abo­ ve), or alternately on both sides for jum­ pers with more than five contacts. . Page 2/3 Version 04.11.2022 Continued on next page Data sheet | Item number: 2002-403 https://www.wago.com/2002-403 Commoning Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Marking with a felt-tip pen. . Commoning Stepping down via push-in type jumper bar. Stepping down via push-in type jumper bar: Commoning via closed terminal side with end plate allows jumpering over two cross-section sizes, e.g., from 16 mm² (6 AWG) to 6 mm² (10 AWG) or from 6 mm² (10 AWG) to 2.5 mm² (14 AWG) (see illus­ tration above). Stepping down via push-in type jumper bar: Commoning via open terminal side with end plate allows jumpering over two cross-section sizes for 16 mm² (6 AWG) and 10 mm² (8 AWG) and one cross-sec­ tion size for 6/4/2.5 mm² (10/12/14 AWG). An example: from 16 mm² (6 AWG) to 6 mm² (10 AWG) (see illustration above) or from 10 mm² (8 AWG) to 4 mm² (12 AWG). . Subject to changes. Please also observe the further product documentation! Current addresses can be found at: w w w.wago.com Page 3/3 Version 04.11.2022 Note: The total current of the outgoing circuits must not exceed the nominal current of the step-down jumper/push-in type jum­ per bar.
2002-403 价格&库存
很抱歉,暂时无法提供与“2002-403”相匹配的价格&库存,您可以联系我们找货
    库存:237
    2002-403
      • 10+12.67052
      库存:1610
      2002-403
      • 1+18.178361+2.36264
        • 150+6.13014
        库存:237
        2002-403
          库存:75
          2002-403
