Data sheet | Item number: 2002-402
Jumper; 2-way; insulated; light gray
https://www.wago.com/2002-402
Color:
light gray
Electrical data
Ratings per IEC/EN
Ex information
Nominal voltage (III/3)
800 V
Rated current
25 A
Rated current (Ex e II)
20 A
Physical data
Width
8.6 mm / 0.339 inches
Height
4.1 mm / 0.161 inches
Depth
19 mm / 0.748 inches
Jumper assignment
1-2
Material Data
Note (material data)
Information on material specifications can be found here
Color
light gray
Fire load
0.007 MJ
Weight
1g
Commercial data
Product Group
22 (TOPJOB S)
eCl@ss 10.0
27-14-11-40
eCl@ss 9.0
27-14-11-40
ETIM 8.0
EC000489
ETIM 7.0
EC000489
PU (SPU)
25 pcs
Packaging type
Bag
Country of origin
DE
GTIN
4055143687171
Customs tariff number
85366990990
Page 1/3
Version 07.11.2022
Continued on next page
Approvals and certificates
Declarations of conformity and manufacturer's declarations
Approval
Standard
Certificate name
Railway
WAGO GmbH & Co. KG
Railway Ready
Downloads
Environmental Product Compliance
Compliance Search
Compliance 2002-402
Documentation
Additional Information
Technical Section
Bid Text
pdf
2142.18 KB
2002-402
19.02.2019
xml
2.51 KB
27.04.2017
doc
23.50 KB
2002-402
CAD/CAE-Data
CAD data
CAE data
2D/3D Models
2002-402
EPLAN Data Portal
2002-402
WSCAD Universe
2002-402
ZUKEN Portal
2002-402
Installation notes
Commoning
Insert push-in type jumper bar and push
down until it hits backstop.
Removing a push-in type jumper bar:
Insert the operating tool between the jum
per and partition wall of the dual jumper
slots, then lift up the jumper.
Place the operating tool in the center of
jumpers for up to five contacts (see abo
ve), or alternately on both sides for jum
pers with more than five contacts.
Page 2/3
Version 07.11.2022
Commoning
Custom jumpers are created by breaking
and removing jumper contacts (2000,
2001, 2002, 2004 Series).
Marking with a felt-tip pen.
Commoning
Stepping down via push-in type jumper
bar.
bar:
Commoning via closed terminal side with
end plate allows jumpering over two
cross-section sizes, e.g., from 16 mm² (6
AWG) to 6 mm² (10 AWG) or from 6 mm²
(10 AWG) to 2.5 mm² (14 AWG) (see illus
tration above).
bar:
Commoning via open terminal side with
cross-section sizes for 16 mm² (6 AWG)
and 10 mm² (8 AWG) and one cross-sec
tion size for 6/4/2.5 mm² (10/12/14 AWG).
An example: from 16 mm² (6 AWG) to 6
mm² (10 AWG) (see illustration above) or
from 10 mm² (8 AWG) to 4 mm² (12 AWG).
Subject to changes. Please also observe the further product documentation!
Current addresses can be found at: w w w.wago.com
Page 3/3
Version 07.11.2022
Note:
The total current of the outgoing circuits
must not exceed the nominal current of
the step-down jumper/push-in type jum
per bar.
很抱歉,暂时无法提供与“2002-402”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+3.70440
- 50+2.85120
- 150+2.48400
- 国内价格 香港价格
- 180+4.74496180+0.61384
- 250+4.55546250+0.58932
- 500+3.30993500+0.42819
