AITCONNECTOR
Board-to-wire/Wire-to-wire
Features
●Compliant with the Standard 0.64 Unsealed USCAR
Footprints and USCAR Performance Standards
●Variations in PCB mountings
0.64 unsealed connector series compliant with the
standard USCAR footprints.
Variations of Keying / Color options and PC Board
mounting features are available to satisfy customer's
needs.
Specifications
JST
K-A
¡Current rating: 5A DC max.
¡Voltage rating: 14V DC
¡Temperature range: -40°C to +100°C
(including temperature rise in applying
electrical current)
¡Contact resistance: Initial value/15mΩ max.
After environmental testing/15mΩ max.
¡Insulation resistance: 100MΩ min.
¡Applicable wire: SAE/ AVSS / CAVS
0.3mm2 to 0.8mm2
∗ Compliant with ELV/RoHS.
∗ Contact JST for details.
1
AIT CONNECTOR
Female terminal
Applicable wire range
Size
1.6
S
M
14
Model No.
Conductor
(mm2)
Insulation O.D. Q’ty/reel
(mm)
qSAIT-A03T-M064
0.3 to 0.5
1.9
6,500
wSAIT-A03GF-M064
0.3 to 0.5
1.9
6,500
qSAIT-A02T-M064
0.75 to 0.8
1.9
6,500
wSAIT-A02GF-M064
0.75 to 0.8
1.9
6,500
Material and Finish
qCopper alloy, tin-plated (reflow treatment)
wCopper alloy, Contact area; gold -plated
Barrel area; tin-plated
2.25
6.5
Male terminal
Size
S
M
6.4
7.5
Model No.
Conductor
(mm2)
(mm)
qSAITW-A03T-064
0.3 to 0.5
1.9
7,000
wSAITW-A03GF-064
0.3 to 0.5
1.9
7,000
qSAITW-A02T-064
0.75 to 0.8
1.9
7,000
wSAITW-A02GF-064
0.75 to 0.8
1.9
7,000
Material and Finish
qBrass, tin-plated (reflow treatment)
wBrass, Contact area; gold-plated
(22.7)
2
AIT CONNECTOR
Male connector
Top entry type
21.7
22.5
With boss
¡20 circuits
16.78
11
10
2.54
1
(7.21)
31.74
2.54
Screw hole type
¡8 circuits
21.7
22.5
21.7
22.5
¡16 circuits
16.78
16.5
26.66
26.32
8
9
16
21.2
1
2.54
8
(7.21)
5
21.2
4
2.54
1
(7.21)
36.48
2.54
2.54
20.32
30.48
¡18 circuits
21.7
22.5
Circuits
8
16
16.78
18
20.32
29.2
18
2.54
39.02
21.2
10
(7.21)
9
2.54
1
33.02
3
Model No.
Q’ty/box
Housing
Color
B08B-AIT-A2B-HS
96
Gray
B08B-AIT-A2A-KS
96
Black
B16B-AIT-A2A-KS
60
Black
B16B-AIT-A2B-HS
60
Gray
B18B-AIT-A2F-SS
60
Natural (White)
B20B2-AIT-A2A-KS-(M)
510
Black
B20B2-AIT-A2C-KS-(M)
510
Brown
Material and Finish
Housing: Glass-filled PA
Pin: Brass, tin-plated
AIT CONNECTOR
Male connector
Side entry type
¡52 circuits
24.6
24.6
¡34 circuits
60.66
16 circuits
Circuit No.
1
8
1
9
9
16
10
18
22.7
18 circuits
2.54
Circuit No.
2.54
18 circuits
16 circuits
18 circuits
1
9
1
8
1
9
10
18
9
16
10
18
22.7
82.55
88.46
2.54
54.75
2.54
20.5
22.5
¡20 circuits
Screw hole type
¡10 circuits
31.75
31.74
43.16
43.16
10
JST
A
K-A
1
10
11
17.73
1
2.54
Circuit No.
Circuit No.
2.54
9× 2.54
Reinforcement type
¡4 circuits
19.7
19.7
¡8 circuits
16.51
26.67
19.05
29.21
Circuit No.
4
1
3× 2.54
¡20 circuits
21.7
Circuits
88
Black
S08B1-AIT-A1A-KS
56
Black
Black
22.7
Circuit No.
11
Housing
Color
S04B1-AIT-A1A-KS
Q’ty/box
8
1 Block
34.29
Model No.
4
10
1
8
7× 2.54
Type
31.74
17.73
1
17.73
Circuit No.
∗S10B-AIT-A1A-KS-(M)
S20B-AIT-A2B-HS
24
Gray
S20B-AIT-A2A-KS
24
Black
S20B1-AIT-A2A-KS
36
Black
S20B1-AIT-A2B-HS
36
Gray
2 Block
34
∗S34B-AIT-A22-SS-(M)
Natural (White)
3 Block
52
∗S52B-AIT-A23-SS-(M)
Natural (White)
Material and Finish
Housing: Glass-filled PBT
9× 2.54
∗Marked products display (LF)(SN) on a label.
∗∗Please contact JST.
4
AIT CONNECTOR
Male connector
¡10 circuits
Circuits
Model No.
Q’ty/box
AITWSB-10-2AK
16.6
10
100
37
Material
Housing: Glass-filled PBT, black
TPA: Glass-filled PBT, red
2.54
20.4
23
C
A
2.54
PC board layout
Top entry type
Screw hole type
¡8 circuits
7.62
33.02±0.05
φ3.4+0.1
2.54±0.05
2.72±0.05
φ1.1+0.1
2.54±0.05
22.86±0.05
φ3.4+0.1
2.54±0.05
¡18 circuits
30.48±0.05
2.72±0.05
2.72±0.05
φ1.1+0.1
(Tin-plated)
2.54±0.05
¡16 circuits
20.32±0.05
2.54±0.05
2.54±0.05
φ1.35+0.1
(No plating)
φ1.1+0.1
φ3.4+0.1
2.54±0.05
2.5±0.05
With boss
¡20 circuits
φ1.1+0.1
2.54±0.05
20.32
Side entry type
Screw hole type
¡10 circuits
¡34 circuits
25.26
3.74
17.78
φ1.2±0.05
0.1 G H
×34
20.32
2.54
¡20 circuits
22.86
2.54
22.86±0.05
φ1.2±0.05
2.54
0.1 G H
H
φ1.1+0.1
H
0.1 G H
×3
G
Reinforcement type
¡4 circuits
53.06
35.56±0.05
0.1 G H
×52
2.54
(25.26)
φ3.2+0.1
27.8
0.1 G H
×4
φ1.1+0.1
13.97±0.05
φ3+0.1
(Cu plated)
(27.8)
53.06
φ1.1+0.1
24.13±0.05
φ3+0.1
29.21±0.05
(Cu plated)
Crimping machine, Applicator
Crimping
machine
Crimp applicator MKS-L
Dies
Crimp applicator with dies
SAIT-A03( )-M064
MK/SAIT-A03-064
APLMK SAIT-A03-064
SAIT-A02( )-M064
MK/SAIT-A02-064
APLMK SAIT-A02-064
MK/SAITW-A03-064
APLMK SAITW-A03-064
MK/SAITW-A02-064
APLMK SAITW-A02-064
SAITW-A03( )-064
SAITW-A02( )-064
AP-K2N
Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal.
5
φ3+0.1
(Cu plated)
Note: 1. Tolerances are non-cumulative.
2. Hole dimensions differ according to the type of PC board and piercing method.
The dimensions above should serve as guideline. Contact JST for details.
80.86
Strip terminal
φ1.1+0.1
20.32
2.54
2.54
9.4±0.05
17.78
2.54
22.86±0.05
2.54±0.05
±0.05
2.54±0.05
3
20.32
¡20 circuits
17.78±0.05
9.4±0.05
27.8
9.4±0.05
3.74
¡8 circuits
7.62±0.05
G
H
φ3.4+0.1
53.06
¡52 circuits
φ1.2±0.05
φ3.2+0.1
0.1 G H
φ3.2+0.1
6±0.05
6
3
3.9
2.54±0.05
3±0.05
G
很抱歉,暂时无法提供与“SAIT-A03T-M064”相匹配的价格&库存,您可以联系我们找货
