DC-DC Converters PCB Mount Type
Low Profile Isolated
OCP
Safety
Approvals
SUS, SUW-series / SUCS, SUCW-series / SUTS, SUTW-series
Feature
SMD mounting type and through-hole mounting type
High efficiency (synchronous rectifier circuit)
Built-in overcurrent protection circuits
Built-in remote ON/OFF (SU / SUC / SUT 3-10)
High reliability : not built-in aluminum and tantalum electrolytic capacitor
CE marking
Low Voltage Directive
RoHS Directive
Safety agency approvals
UL60950-1, C-UL, EN62368-1
5-year warranty
January 31, 2022
SU.SUC/SUT-1
Ordering information
SUS1R5
SU S 1R5 12 05
1
2
3
4
5
B
6
P
7
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray (SMD type)
R
MODEL
MAX OUTPUT WATTAGE[W]
DC OUTPUT
SUS1R5053R3
1.32
VOLTAGE[V] *1 3.3
CURRENT[A] 0.4
SUS1R50505
1.5
5
0.3
SUS1R50512
1.56
12
0.13
SUS1R50515
1.5
15
0.1
SUS1R5123R3
1.32
3.3
0.4
SUS1R51205
1.5
5
0.3
SUS1R51212
1.56
12
0.13
SUS1R51215
1.5
15
0.1
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
TEMPERATURE REGULATION[mV]
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
OUTPUT VOLTAGE ADJUSTMENT RANGE
OUTPUT VOLTAGE SETTING[V] (t3%)
OVERCURRENT PROTECTION
MODEL
DC OUTPUT
SUS1R5053R3 SUS1R50505 SUS1R50512 SUS1R50515 SUS1R5123R3
DC4.5 - 9
DC9 - 18
0.377typ
0.153typ
0.405typ
0.422typ
0.405typ
70typ
72typ
74typ
74typ
74typ
3.3
3.3
5
12
15
0.4
0.4
0.3
0.13
0.1
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
20max (Minimum input, Io=100%)
Fixed (TRM pin open) t5% adjustable by external VR
3.21 - 3.42
4.90 - 5.21
11.64 - 12.36 14.55 - 15.45 3.21 - 3.42
Works over 105% of rating and recovers automatically
SUS1R5243R3
1.32
VOLTAGE[V] *1 3.3
CURRENT[A] 0.4
SUS1R52405
1.5
5
0.3
SUS1R52412
1.56
12
0.13
SUS1R52415
1.5
15
0.1
SUS1R5483R3
1.32
3.3
0.4
SUS1R51205 SUS1R51212 SUS1R51215
0.164typ
76typ
5
0.3
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.171typ
76typ
12
0.13
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.164typ
76typ
15
0.1
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUS1R54805
1.5
5
0.3
SUS1R54812
1.56
12
0.13
SUS1R54815
1.5
15
0.1
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
SU.SUC/SUT-2
SUS1R5243R3 SUS1R52405 SUS1R52412 SUS1R52415 SUS1R5483R3
DC18 - 36
DC36 - 76
0.076typ
0.038typ
0.082typ
0.084typ
0.081typ
72typ
72typ
76typ
77typ
77typ
3.3
3.3
5
12
15
0.4
0.4
0.3
0.13
0.1
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
50max
50max
150max
180max
80max
80max
80max
240max
290max
20max
20max
20max
48max
60max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUS1R54805 SUS1R54812 SUS1R54815
0.041typ
76typ
5
0.3
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.042typ
77typ
12
0.13
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.041typ
77typ
15
0.1
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUS1R5
GENERAL SPECIFICATIONS
ISOLATION INPUT-OUTPUT
OPERATING TEMP.,HUMID.AND ALTITUDE
STORAGE TEMP.,HUMID.AND ALTITUDE
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C)
-40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max
-40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max
10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis
490.3m/s2 (50G), 11ms, once each along X, Y and Z axis
21.4X6.5X12.2mm [0.84X0.26X0.48 inches] (WXHXD) / 2g max
Convection/Forced air
*1 SUW1R5xx12/SUW1R5xx15 is available as single output, +24V/+30V.
*2 Rated input 5V, 12V, 24V or 48V DC Io=100%
*3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals.
*4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C.
* Parallel operation with other model is not possible.
External view
Model
+Vout
Recommended Pad and Hole dia.
(TOP VIEW)
+Vin
type B
1.4
type C
[0.004]
[0.26]
Adsorption area º6min
6.5
0˚)
[0.13]
[0.24]
23.62 ±0.6
(0-1
1.8 ±0.3
[0.07]
3.2
25.22
[0.99]
0.1min
[0.84]
Pin terminal part details
[0.3]
7.62 ±0.2
21.4
3.2
[0.13]
[0.1]
2.54 ±0.2
[0.48]
12.2
[0.07]
-Vout
[0.02]
0.6 ±0.1
[0.3]
7.62±0.2
-Vin
(1.75)
TRM
[0.06]
1. SMD(type B)
[0.93]
5-º0.9
Coplanarity within 0.1
[0.04]
[0.004]
Unit : 0.1inch
Dimensions in mm, [ ]=inches
2. DIP(type C)
Model
+Vout
¶ Tolerance ±0.5 [±0.02]
¶ Dimensions in mm, [ ]=inches
¶ Pin terminal thickness : 0.3±0.1 [0.012]
¶ Pin terminal material : Copper alloy
¶ Plating treatment of terminal : Lead free plating
¶ Weight : 2g max
+Vin
[0.3]
7.62 ±0.2
21.4
[0.1]
2.54 ±0.2
[0.02]
6.5
[0.26]
[0.48]
[0.3]
-Vin
3.68 ±0.25
[0.14]
12.2
-Vout
0.6±0.1
7.62 ±0.2
TRM
0.1min
[0.84]
[0.004]
20.32
[0.8]
January 31, 2022
SU.SUC/SUT-3
SUW1R5
SU W 1R5 12 12
1
2
3
4
5
DC OUTPUT
P
7
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray (SMD type)
R
MODEL
B
6
SUW1R50512
1.56
VOLTAGE[V] *1 t12 or +24
CURRENT[A] 0.065
SUW1R50515
1.5
t15 or +30
0.05
SUW1R51212
1.56
t12 or +24
0.065
SUW1R51215
1.5
t15 or +30
0.05
SUW1R52412
1.56
t12 or +24
0.065
SUW1R52415
1.5
t15 or +30
0.05
SUW1R54812
1.56
t12 or +24
0.065
SUW1R54815
1.5
t15 or +30
0.05
SUW1R51215 SUW1R52412
DC18 - 36
0.167typ
0.087typ
75typ
75typ
t15(+30)
t12(+24)
SUW1R52415 SUW1R54812
DC36 - 76
0.083typ
0.043typ
75typ
75typ
t15(+30)
t12(+24)
SUW1R54815
0.05
75max
750max
120max
150max
150max
200max
180max
290max
60max
0.05
75max
750max
120max
150max
150max
200max
180max
290max
60max
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
OUTPUT VOLTAGE SETTING[V] (t5%)
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
PROTECTION
CIRCUIT AND
OTHERS
SUW1R50512
DC4.5 - 9
0.433typ
72typ
t12(+24)
SUW1R50515 SUW1R51212
DC9 - 18
0.417typ
0.173typ
72typ
75typ
t15(+30)
t12(+24)
0.065
0.05
0.065
60max
75max
60max
600max
750max
600max
120max
120max
120max
150max
150max
150max
150max
150max
150max
200max
200max
200max
150max
180max
150max
240max
290max
240max
50max
60max
50max
0.065
60max
600max
120max
150max
150max
200max
150max
240max
50max
by external VR
11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75
*1 Output pins can be connected in series to make a 24V/30V output.
SU.SUC/SUT-4
0.065
60max
600max
120max
150max
150max
200max
150max
240max
50max
0.042typ
75typ
t15(+30)
0.05
75max
750max
120max
150max
150max
200max
180max
290max
60max
January 31, 2022
SUW1R5
External view
Model
+Vout
+Vin
(TOP VIEW)
COM
[0.3]
3.2
[0.13]
[0.1]
2.54±0.2
21.4
1.4
[0.1]
7.62±0.2
2.54±0.2
[0.48]
12.2
[0.07]
-Vout
type B
[0.02]
0.6 ±0.1
[0.3]
7.62±0.2
(1.75)
TRM
-Vin
[0.26]
6.5
0˚)
[0.07]
[0.24]
23.62 ±0.6
(0-1
1.8 ±0.3
[0.13]
type C
[0.004]
3.2
25.22
[0.99]
0.1min
[0.84]
[0.06]
1. SMD(type B)
[0.93]
6-º0.9
[0.04]
[0.004]
Unit : 0.1inch
+Vout
Model
+Vin
21.4
[0.84]
7.62 ±0.2
[0.1]
6.5
[0.26]
[0.1]
[0.02]
3.68±0.25
[0.14]
2.54 ±0.2
[0.3]
[0.48]
12.2
-Vout
-Vin
0.6 ±0.1
7.62 ±0.2
TRM
2.54 ±0.2
COM
¶ Weight : 2g max
[0.3]
2. DIP(type C)
0.1min
[0.004]
20.32
[0.8]
January 31, 2022
SU.SUC/SUT-5
SUS3
SU S
1
2
3 12 05 B
3
4
5
DC OUTPUT
P -O
7
8
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7
Packing form
Blank:Plastic cover
P : Tray (SMD type)
8 Optional
G : C apacitor between Input
and Output is removed.
R
MODEL
6
SUS3053R3
1.98
VOLTAGE[V] *1 3.3
CURRENT[A] 0.6
SUS3123R3
1.98
3.3
0.6
SUS31205
3
5
0.6
SUS31212
3
12
0.25
SUS31215
3
15
0.2
SUS3053R3 SUS30505 SUS30512 SUS30515 SUS3123R3
DC4.5 - 9
DC9 - 18
0.780typ
0.760typ
0.760typ
0.536typ
0.218typ
77typ
79typ
79typ
74typ
76typ
5
12
15
3.3
3.3
0.6
0.25
0.2
0.6
0.6
20max
48max
60max
20max
20max
40max
100max
120max
40max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
Provided (Negative logic L : ON, H : OFF)
SUS31205
SUS31212
SUS31215
0.317typ
79typ
5
0.6
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.309typ
81typ
12
0.25
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.313typ
80typ
15
0.2
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUS3483R3
1.98
3.3
0.6
SUS34805
3
5
0.6
SUS34812
3
12
0.25
SUS34815
3
15
0.2
SUS3243R3 SUS32405 SUS32412 SUS32415 SUS3483R3
DC18 - 36
DC36 - 76
0.110typ
0.056typ
0.159typ
0.155typ
0.157typ
75typ
74typ
79typ
81typ
80typ
3.3
3.3
5
12
15
0.6
0.6
0.6
0.25
0.2
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
50max
50max
150max
180max
80max
80max
80max
240max
290max
20max
20max
20max
48max
60max
3.21 - 3.42
4.90 - 5.21
SUS34805
SUS34812
SUS34815
0.080typ
79typ
5
0.6
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.078typ
81typ
12
0.25
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.078typ
81typ
15
0.2
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUS30505
3
5
0.6
SUS30512
3
12
0.25
SUS30515
3
15
0.2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
PROTECTION OVERCURRENT PROTECTION
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUS3243R3
1.98
VOLTAGE[V] *1 3.3
CURRENT[A] 0.6
SUS32405
3
5
0.6
SUS32412
3
12
0.25
SUS32415
3
15
0.2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-6
January 31, 2022
SUS3
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
24X6.5X15.1mm [0.94X0.26X0.59 inches] (WXHXD) / 3g max
*1 SUW3xx12/SUW3xx15 is available as single output, +24V/+30V.
External view
(TOP VIEW)
type B
1.SMD(type B)
+Vout
Model
+Vin
1.4
[0.06]
TRM
RC
-Vout
[0.13]
[1.09]
type C
[0.004]
[0.26]
[0.24]
6-º0.9
[0.04]
0˚)
6.5
(0-1
[0.07]
3.2
27.76
0.1min
[0.94]
1.8 ±0.3
[0.3]
7.62±0.2
2.54±0.2
24
3.2
[0.13]
[0.1]
15.1
[0.59]
[0.07]
(1.8)
[0.02]
0.6 ±0.1
[0.3]
[0.1]
2.54±0.2
7.62±0.2
-Vin
Unit : 0.1inch
26.16 ±0.6
[1.03]
[0.004]
¶ Weight : 3g max
2.DIP(type C)
+Vout
Model
+Vin
TRM
RC
-Vout
3.68 ±0.25
[0.14]
6.5
[0.26]
24
[0.3]
[0.1]
7.62±0.2
0.1min
2.54 ±0.2
[0.59]
15.1
0.6±0.1
[0.02]
[0.3]
[0.1]
2.54±0.2
7.62 ±0.2
-Vin
[0.004]
[0.94]
22.86
[0.9]
January 31, 2022
SU.SUC/SUT-7
SUW3
SU W
1
2
3 12 12 B
3
4
5
6
P -O
7
8
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray (SMD type)
8 Optional
G : Capacitor between
Input and Output is
removed.
R
MODEL
DC OUTPUT
SUW30512
3.12
CURRENT[A] 0.13
SUW30515
3
t15 or +30
0.1
SUW31212
3.12
t12 or +24
0.13
SUW31215
3
t15 or +30
0.1
SUW32412
3.12
t12 or +24
0.13
SUW32415
3
t15 or +30
0.1
SUW34812
3.12
t12 or +24
0.13
SUW34815
3
t15 or +30
0.1
SUW32415 SUW34812
DC36 - 76
0.161typ
0.084typ
78typ
78typ
15
+30
t
t12(+24)
SUW34815
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
ISOLATION
ENVIRONMENT
SAFETY
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
REMOTE ON/OFF
INPUT-OUTPUT
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
SUW30512
DC4.5 - 9
0.822typ
76typ
t12(+24)
SUW30515 SUW31212
DC9 - 18
0.790typ
0.334typ
76typ
78typ
15
+30
t
t12(+24)
SUW31215 SUW32412
DC18 - 36
0.321typ
0.167typ
78typ
78typ
15
+30
t
t12(+24)
0.13
0.1
0.13
0.1
0.13
0.1
0.13
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
SU.SUC/SUT-8
0.081typ
78typ
t15(+30)
0.1
75max
750max
120max
150max
150max
200max
180max
290max
60max
January 31, 2022
SUW3
External view
1.SMD(type B)
(TOP VIEW)
type B
+Vout
COM
Model
+Vin
2.54 ±0.2
1.4
[0.06]
[0.3]
27.76
[0.13]
[1.09]
type C
[0.004]
[0.26]
7-º0.9
[0.04]
0˚)
6.5
[0.24]
(0-1
1.8 ±0.3
3.2
3.2
[0.13]
0.1min
[0.94]
[0.07]
[0.1]
[0.59]
15.1
[0.07]
(1.8)
[0.02]
0.6±0.1
[0.3]
[0.1]
7.62 ±0.2
2.54 ±0.2
24
7.62 ±0.2
-Vout
-Vin
[0.1]
2.54 ±0.2
TRM
RC
Unit : 0.1inch
26.16 ±0.6
[1.03]
[0.004]
[0.26]
[0.1]
0.1min
24
7.62 ±0.2
[0.1]
[0.59]
15.1
0.6 ±0.1
[0.02]
7.62 ±0.2
[0.3]
[0.1]
2.54 ±0.2
[0.14]
6.5
2.54 ±0.2
-Vout
-Vin
2.54 ±0.2
TRM
RC
[0.3]
COM
Model
+Vin
3.68 ±0.25
¶ Weight : 3g max
+Vout
2.DIP(type C)
[0.004]
[0.94]
22.86
[0.9]
January 31, 2022
SU.SUC/SUT-9
SUS6
SU S
1
2
6 12 05 B
3
4
5
DC OUTPUT
P -O
7
8
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7
Packing form
Blank:Plastic cover
P : Tray (SMD type)
8 Optional
R
MODEL
6
SUS6053R3
3.96
VOLTAGE[V] *1 3.3
CURRENT[A] 1.2
SUS6123R3
4.46
3.3
1.35
SUS61205
6
5
1.2
SUS61212
6
12
0.5
SUS61215
6
15
0.4
SUS6053R3 SUS60505 SUS60512 SUS60515 SUS6123R3
DC4.5 - 9
DC9 - 18
1.316typ
1.500typ
1.500typ
1.100typ
0.502typ
76typ
80typ
80typ
72typ
74typ
5
12
15
3.3
3.3
1
0.5
0.4
1.2
1.35
20max
48max
60max
20max
20max
40max
100max
120max
40max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
SUS61205
SUS61212
SUS61215
0.617typ
81typ
5
1.2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.588typ
85typ
12
0.5
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.588typ
85typ
15
0.4
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUS6483R3
4.46
3.3
1.35
SUS64805
6
5
1.2
SUS64812
6
12
0.5
SUS64815
6
15
0.4
SUS6243R3 SUS62405 SUS62412 SUS62415 SUS6483R3
DC18 - 36
DC36 - 76
0.248typ
0.121typ
0.309typ
0.291typ
0.291typ
75typ
77typ
81typ
86typ
86typ
3.3
3.3
5
12
15
1.35
1.35
1.2
0.5
0.4
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
50max
50max
150max
180max
80max
80max
80max
240max
290max
20max
20max
20max
48max
60max
3.21 - 3.42
4.90 - 5.21
SUS64805
SUS64812
SUS64815
0.154typ
81typ
5
1.2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.145typ
86typ
12
0.5
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.145typ
86typ
15
0.4
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUS60505
5
5
1
SUS60512
6
12
0.5
SUS60515
6
15
0.4
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUS6243R3
4.46
VOLTAGE[V] *1 3.3
CURRENT[A] 1.35
SUS62405
6
5
1.2
SUS62412
6
12
0.5
SUS62415
6
15
0.4
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-10
January 31, 2022
SUS6
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
31.6X6.5X18.1mm [1.24X0.26X0.71 inches] (WXHXD) / 4g max
*1 SUW6xx12/SUW6xx15 is available as single output, +24V/+30V.
External view
1.SMD(type B)
(TOP VIEW)
type B
Model
+Vin
0.6 ±0.1
[0.1]
2.54±0.2
RC
[0.02]
-Vout
1.4
type C
[0.004]
[0.28]
6.5
[0.26]
6-º0.9
0˚)
[0.04]
(0-1
33.78 ±0.6
[1.33]
Unit : 0.1inch
Model
+Vin
TRM
0.6 ±0.1
-Vout
-Vin
[0.02]
[0.1]
2.54±0.2
RC
0.1min
31.6
6.5
5.08±0.2
[0.2] 12.7 ±0.2
[0.71]
[0.5]
18.1
12.7±0.2
+Vout
[0.5]
¶ Weight : 4g max
2.DIP(type C)
3.68±0.25
[0.13]
[1.39]
[0.004]
[0.14]
3.2
35.38
Adsorption area º7min
[0.07]
3.2
[0.13]
0.1min
31.6
[1.24]
1.8±0.3
[0.06]
[0.5]
TRM
-Vin
5.08±0.2
[0.2]
12.7 ±0.2
[0.5]
18.1
[0.71]
[0.07]
12.7 ±0.2
(1.69)
+Vout
[0.004]
[1.24]
[0.26]
30.48
[1.2]
January 31, 2022
SU.SUC/SUT-11
SUW6
SU W
1
2
6 12 12 B
3
4
5
6
P -O
7
8
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray (SMD type)
8 Optional
Input and Output is
removed.
R
MODEL
DC OUTPUT
SUW60512
6
CURRENT[A] 0.25
SUW60515
6
t15 or +30
0.2
SUW61212
6
t12 or +24
0.25
SUW61215
6
t15 or +30
0.2
SUW62412
6
t12 or +24
0.25
SUW62415
6
t15 or +30
0.2
SUW64812
6
t12 or +24
0.25
SUW64815
6
t15 or +30
0.2
SUW62415 SUW64812
DC36 - 76
0.291typ
0.145typ
86typ
86typ
15
+30
t
t12(+24)
SUW64815
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
ISOLATION
ENVIRONMENT
SAFETY
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
REMOTE ON/OFF
INPUT-OUTPUT
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
SUW60512
DC4.5 - 9
1.538typ
78typ
t12(+24)
SUW60515 SUW61212
DC9 - 18
1.538typ
0.588typ
78typ
85typ
15
+30
t
t12(+24)
SUW61215 SUW62412
DC18 - 36
0.588typ
0.291typ
85typ
86typ
15
+30
t
t12(+24)
0.25
0.2
0.25
0.2
0.25
0.2
0.25
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
SU.SUC/SUT-12
0.145typ
86typ
t15(+30)
0.2
75max
750max
120max
150max
150max
200max
180max
290max
60max
January 31, 2022
SUW6
External view
1.SMD(type B)
(TOP VIEW)
type B
Model
1.4
[0.06]
[0.1]
12.7±0.2
TRM
[0.13]
[0.28]
[0.2]
0.1min
[0.004]
[0.26]
6.5
7-º0.9
[0.04]
0˚)
(0-1
[0.07]
[0.13]
[1.39]
5.08±0.2
0.6 ±0.1
[0.02]
[0.1]
2.54±0.2
-Vout
31.6
[1.24]
1.8 ±0.3
35.38
type C
RC
-Vin
3.2
3.2
[0.5]
18.1
[0.71]
COM
2.54±0.2
[0.07]
(1.69)
+Vout
[0.5]
12.7±0.2
+Vin
Unit : 0.1inch
33.78 ±0.6
[1.33]
[0.004]
2.54±0.2
[0.1]
[0.2]
18.1
[0.71]
[0.5]
TRM
3.68 ±0.25
[0.14]
-Vout
-Vin
[0.02]
[0.1]
0.6±0.1
RC
2.54±0.2
12.7 ±0.2
COM
5.08±0.2
+Vout
[0.5]
Model
+Vin
12.7 ±0.2
2.DIP(type C)
¶ Weight : 4g max
31.6
6.5
[1.24]
0.1min
[0.004]
[0.26]
30.48
[1.2]
January 31, 2022
SU.SUC/SUT-13
SUS10
SU S 10 12 05 B P -O
1
2
3
4
5
DC OUTPUT
7
8
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7
Packing form
Blank:Plastic cover
P : Tray (SMD type)
8 Optional
R
MODEL
6
SUS10053R3
8.58
VOLTAGE[V] *1 3.3
CURRENT[A] 2.6
SUS100505
10
5
2
SUS100512
10.8
12
0.9
SUS100515
10.5
15
0.7
SUS10123R3
8.58
3.3
2.6
SUS101205
10
5
2
SUS101212
12
12
1
SUS101215
12
15
0.8
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUS10053R3 SUS100505 SUS100512 SUS100515 SUS10123R3
DC4.5 - 9
DC9 - 18
2.12typ
2.41typ
2.54typ
2.47typ
0.872typ
81typ
83typ
85typ
85typ
82typ
3.3
5
12
15
3.3
2.6
2
0.9
0.7
2.6
20max
20max
48max
60max
20max
40max
40max
100max
120max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
SUS10243R3
8.58
VOLTAGE[V] *1 3.3
CURRENT[A] 2.6
SUS102405
10
5
2
SUS102412
12
12
1
SUS102415
12
15
0.8
SUS10483R3
8.58
3.3
2.6
SUS101205 SUS101212 SUS101215
0.980typ
85typ
5
2
20max
40max
80max
120max
120max
200max
50max
80max
20max
1.15typ
87typ
12
1
48max
100max
120max
150max
150max
200max
150max
240max
48max
1.15typ
87typ
15
0.8
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUS104805
10
5
2
SUS104812
12
12
1
SUS104815
12
15
0.8
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-14
SUS10243R3 SUS102405 SUS102412 SUS102415 SUS10483R3
DC18 - 36
DC36 - 76
0.436typ
0.218typ
0.490typ
0.575typ
0.575typ
82typ
82typ
85typ
87typ
87typ
3.3
3.3
5
12
15
2.6
2.6
2
1
0.8
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUS104805 SUS104812 SUS104815
0.245typ
85typ
5
2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.287typ
87typ
12
1
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.287typ
87typ
15
0.8
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUS10
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
39.2X6.5X21.0mm [1.54X0.26X0.83 inches] (W XHXD) / 6g max
*1 SUW10xx12/SUW10xx15 is available as single output, +24V/+30V.
External view
(TOP VIEW)
1.SMD(type B)
type B
Model
+Vout
[0.1]
1.4
[0.06]
7.62±0.2
15.24±0.2
[0.6]
3.2
43
[0.13]
[1.69]
type C
0.1min
39.2
[0.004]
[1.54]
3.2
[0.13]
-Vout
[0.02]
-Vin
0.6±0.1
2.54 ±0.2
RC
TRM
[0.3]
[0.6]
21
[0.83]
[0.09]
15.24 ±0.2
(2.16)
+Vin
Adsorption area º8min
0˚)
6.5
[0.26]
[0.31]
1.8±0.3
(0-1
[0.07]
41.4 ±0.6
6-º0.9
[1.63]
[0.04]
[0.004]
Unit : 0.1inch
¶ Weight : 6g max
2.DIP(type C)
Model
+Vin
0.6 ±0.1
3.68±0.25
[0.14]
-Vout
-Vin
[0.02]
[0.1]
2.54±0.2
RC
0.1min
39.2
6.5
[0.6]
TRM
7.62 ±0.2
[0.3]
15.24±0.2
[0.6]
21
[0.83]
15.24±0.2
+Vout
[0.004]
[1.54]
[0.26]
38.1
[1.5]
January 31, 2022
SU.SUC/SUT-15
SUW10
SU W 10 12 12 B P -O
1
2
3
4
5
6
7
8
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray(SMD type)
8 Optional
Input and Output is
removed.
R
MODEL
DC OUTPUT
SUW100512
10.8
CURRENT[A] 0.45
SUW100515
10.5
t15 or +30
0.35
SUW101212
10.8
t12 or +24
0.45
SUW101215
10.5
t15 or +30
0.35
SUW102412
10.8
t12 or +24
0.45
SUW102415
10.5
t15 or +30
0.35
SUW104812
10.8
t12 or +24
0.45
SUW104815
10.5
t15 or +30
0.35
SUW102415 SUW104812
DC36 - 76
0.509typ
0.262typ
86typ
86typ
15
+30
t
t12(+24)
SUW104815
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
ISOLATION
ENVIRONMENT
SAFETY
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
REMOTE ON/OFF
INPUT-OUTPUT
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
SUW100512
DC4.5 - 9
2.51typ
86typ
t12(+24)
SUW100515 SUW101212
DC9 - 18
2.44typ
1.05typ
86typ
86typ
15
+30
t
t12(+24)
SUW101215 SUW102412
DC18 - 36
1.02typ
0.523typ
86typ
86typ
15
+30
t
t12(+24)
0.45
0.35
0.45
0.35
0.45
0.35
0.45
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
39.2X6.5X21.0mm [1.54X0.26X0.83 inches] (WXHXD) / 6g max
SU.SUC/SUT-16
0.254typ
86typ
t15(+30)
0.35
75max
750max
120max
150max
150max
200max
180max
290max
60max
January 31, 2022
SUW10
External view
1.SMD(type B)
(TOP VIEW)
type B
Model
+Vin
1.4
[0.6]
[0.1]
15.24 ±0.2
[0.06]
43
[0.13]
[1.69]
0.1min
type C
[0.004]
39.2
3.2
[0.13]
6.5
[0.26]
[0.31]
(0-1
0˚)
1.8 ±0.3
-Vout
[1.54]
[0.07]
3.2
[0.3]
0.6±0.1
[0.02]
[0.1]
-Vin
TRM
7.62 ±0.2
21
[0.83]
[0.6]
2.54±0.2
RC
2.54±0.2
COM
[0.09]
15.24±0.2
(2.16)
+Vout
41.4 ±0.6
[1.63]
7-º0.9
[0.004]
[0.04]
Unit : 0.1inch
Model
+Vin
7.62±0.2
2.54±0.2
[0.3]
15.24 ±0.2 [0.1]
+Vout
[0.6]
21
[0.83]
15.24 ±0.2
COM
TRM
0.6 ±0.1
3.68±0.25
[0.14]
-Vout
-Vin
[0.02]
[0.1]
2.54 ±0.2
RC
¶ Weight : 6g max
[0.6]
2.DIP(type C)
0.1min
39.2
[0.004]
[1.54]
6.5
[0.26]
38.1
[1.5]
January 31, 2022
SU.SUC/SUT-17
SUCS1R5
SUC S 1R5 12 05 B P -O
1
2
3
4
5
6
7
8
8 Optional
1 Series name
C : with coating (only
2 Single output
DIP type)*
3 Output wattage
4 Input voltage
*S afety standards
5 Output voltage
are pending
6 Mounting type
B : SMD
C : DIP
7 Packing form
Blank:Plastic cover
P : Tray (SMD type)
R
MODEL
DC OUTPUT
SUCS1R5053R3
1.32
VOLTAGE[V] *1 3.3
CURRENT[A] 0.4
SUCS1R50505
1.5
5
0.3
SUCS1R50512
1.56
12
0.13
SUCS1R50515
1.5
15
0.1
SUCS1R5123R3
1.32
3.3
0.4
SUCS1R51205
1.5
5
0.3
SUCS1R51212
1.56
12
0.13
SUCS1R51215
1.5
15
0.1
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
MODEL
DC OUTPUT
SUCS1R5053R3 SUCS1R50505 SUCS1R50512 SUCS1R50515 SUCS1R5123R3
DC4.5 - 9
DC9 - 18
0.388typ
0.157typ
0.417typ
0.433typ
0.417typ
68typ
70typ
72typ
72typ
72typ
3.3
3.3
5
12
15
0.4
0.4
0.3
0.13
0.1
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
SUCS1R5243R3
1.32
VOLTAGE[V] *1 3.3
CURRENT[A] 0.4
SUCS1R52405
1.5
5
0.3
SUCS1R52412
1.56
12
0.13
SUCS1R52415
1.5
15
0.1
SUCS1R5483R3
1.32
3.3
0.4
SUCS1R51205 SUCS1R51212 SUCS1R51215
0.169typ
74typ
5
0.3
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.176typ
74typ
12
0.13
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.169typ
74typ
15
0.1
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUCS1R54805
1.5
5
0.3
SUCS1R54812
1.56
12
0.13
SUCS1R54815
1.5
15
0.1
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
SU.SUC/SUT-18
SUCS1R5243R3 SUCS1R52405 SUCS1R52412 SUCS1R52415 SUCS1R5483R3
DC18 - 36
DC36 - 76
0.079typ
0.039typ
0.084typ
0.087typ
0.083typ
70typ
70typ
74typ
75typ
75typ
3.3
3.3
5
12
15
0.4
0.4
0.3
0.13
0.1
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
50max
50max
150max
180max
80max
80max
80max
240max
290max
20max
20max
20max
48max
60max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUCS1R54805 SUCS1R54812 SUCS1R54815
0.042typ
74typ
5
0.3
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.043typ
75typ
12
0.13
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.042typ
75typ
15
0.1
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUCS1R5
INPUT-OUTPUT
ISOLATION INPUT-CASE
OUTPUT-CASE
ENVIRONMENT
VIBRATION
IMPACT
SAFETY
AGENCY APPROVALS
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
22.4X7.0X13.2mm [0.88X0.28X0.52 inches] (WXHXD) / 3g max
*1 SUCW1R5xx12/SUCW1R5xx15 is available as single output, +24V/+30V.
External view
(TOP VIEW)
Adsorption area
1. SMD(type B)
Component area
Model
+Vin
type B
1
1.9
1.3
[0.1]
º1.6
[0.06]
Unit : 0.1inch
[0.004]
Component area
Model
+Vin
¶ Weight : 3g max
[0.1]
+0.5
2.44 -0.25
Closeup of part A
Part A
¶ Case thickness : 0.2±0.05 [0.008]
¶ Case material : Brass
¶ Plating treatment of case : Nickel plating
¶ Please keep enough creepage
distance with the pattern on PCB
and other components.
[0.1]
[0.004]
+0.5
0.1min
22.4
[0.88]
2.44 -0.25
0.6 ±0.1
7
[0.3]
TRM
-Vout
[0.28]
7.62 ±0.2
[0.1]
2.54 ±0.2
-Vin
[0.52]
[0.5]
12.7
+Vout
13.2
[0.3]
[0.07]
[0.06]
1.4
+0.5
type C
23.62 ±0.6
2. DIP(type C)
[0.02]
3.2
[0.13]
[0.04]
[0.93]
7.62 ±0.2
[0.99]
5-º0.9
[0.04]
3.68 ±0.25
25.22
+0.5
2.54 -0.25
[0.004]
2
[0.08]
[0.1]
[0.03]
[0.03]
7
[0.28]
(0-1
0.1min
Closeup of part A
[0.88]
2.54 -0.25
Part A
0.8 min
0˚)
1.8 ±0.3
[0.07]
[0.3]
3.2
[0.13]
22.4
[0.05]
0.6 ±0.1
0.7±0.4 [0.02]
-Vout
[0.14]
[0.1]
TRM
7.62 ±0.2
2.54 ±0.2
[0.5]
[0.52]
12.7
13.2
-Vin
[0.3]
7.62
±0.2
+Vout
1
[0.04]
20.32
[0.8]
January 31, 2022
SU.SUC/SUT-19
SUCW1R5
SUC W 1R5 12 12 B P -O
1
2
3
4
5
6
7
8
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray (SMD type)
8Optional
C : with coating (only DIP
type)*
R
* S afety standards are
pending
MODEL
DC OUTPUT
SUCW1R50512
1.56
CURRENT[A] 0.065
SUCW1R50515
1.5
t15 or +30
0.05
SUCW1R51212
1.56
t12 or +24
0.065
SUCW1R51215
1.5
t15 or +30
0.05
SUCW1R52412
1.56
t12 or +24
0.065
SUCW1R52415
1.5
t15 or +30
0.05
SUCW1R54812
1.56
t12 or +24
0.065
SUCW1R54815
1.5
t15 or +30
0.05
SUCW1R52415 SUCW1R54812
DC36 - 76
0.086typ
0.045typ
73typ
73typ
t15(+30)
t12(+24)
SUCW1R54815
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
INPUT-OUTPUT
OUTPUT-CASE
ENVIRONMENT
VIBRATION
IMPACT
SAFETY
AGENCY APPROVALS
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
PROTECTION
CIRCUIT AND
OTHERS
SUCW1R50512
DC4.5 - 9
0.446typ
70typ
t12(+24)
SUCW1R50515 SUCW1R51212
DC9 - 18
0.429typ
0.178typ
70typ
73typ
t15(+30)
t12(+24)
SUCW1R51215 SUCW1R52412
DC18 - 36
0.171typ
0.089typ
73typ
73typ
t15(+30)
t12(+24)
0.065
0.05
0.065
0.05
0.065
0.05
0.065
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
SU.SUC/SUT-20
0.043typ
73typ
t15(+30)
0.05
75max
750max
120max
150max
150max
200max
180max
290max
60max
January 31, 2022
SUCW1R5
External view
(TOP VIEW)
Adsorption area
Component area
Model
[0.13]
1.9
[0.07]
1.3
[0.05]
[0.3]
[0.004]
Closeup of part A
3.2
2
[0.08]
25.22
[0.99]
3.2
[0.13]
type C
[0.1]
22.4
+0.5
Part A
0.1min
2.54 -0.25
2.54 ±0.2
-Vout
[0.03]
0.6 ±0.1
0.7±0.4 [0.02]
TRM
[0.88]
1.4
7.62 ±0.2
[0.52]
[0.5]
13.2
12.7
-Vin
[0.3]
7.62 ±0.2
COM
[0.06]
+Vout
[0.1]
2.54 ±0.2
type B
+Vin
[0.1]
1. SMD(type B)
[0.1]
+0.5
2.54 -0.25
[0.03]
7
[0.28]
º1.6
6-º0.9 [0.06]
1
[0.04]
Unit : 0.1inch
[0.004]
[0.93]
2. DIP(type C)
[0.04]
23.62 ±0.6
+Vout
Model
Component area
2.54±0.2
COM
[0.004]
+0.5
2.44 -0.25
[0.1] 2.54 ±0.2
-Vout
0.1min
[0.3]
[0.1]
7.62±0.2
[0.5]
[0.52]
Part A
TRM
Closeup of part A
+0.5
[0.28]
22.4
[0.88]
¶ Weight : 3g max
1
[0.1]
7
2.44 -0.25
[0.02]
3.68±0.25
[0.14]
13.2
12.7
[0.3]
-Vin
0.6±0.1
7.62 ±0.2
+Vin
[0.1]
0˚)
[0.07]
(0-1
1.8±0.3
0.8 min
[0.04]
20.32
[0.8]
January 31, 2022
SU.SUC/SUT-21
SUCS3
SUC S 3 12 05 B P -O
1
2
3
4
DC OUTPUT
6
7
8
1 Series name
8 Optional
2 Single output
Input and Output is
3 Output wattage
removed.
4 Input voltage
5 Output voltage
6 Mounting type
DIP type)*
B : SMD
C : DIP
* S afety standards
are pending
7 Packing form
Blank:Plastic cover
P : Tray (SMD type)
R
MODEL
5
SUCS3053R3
1.98
VOLTAGE[V] *1 3.3
CURRENT[A] 0.6
SUCS30505
3
5
0.6
SUCS30512
3
12
0.25
SUCS30515
3
15
0.2
SUCS3123R3
1.98
3.3
0.6
SUCS31205
3
5
0.6
SUCS31212
3
12
0.25
SUCS31215
3
15
0.2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUCS3053R3 SUCS30505 SUCS30512 SUCS30515 SUCS3123R3
DC4.5 - 9
DC9 - 18
0.550typ
0.800typ
0.780typ
0.780typ
0.223typ
72typ
75typ
77typ
77typ
74typ
3.3
5
12
15
3.3
0.6
0.6
0.25
0.2
0.6
20max
20max
48max
60max
20max
40max
40max
100max
120max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
SUCS3243R3
1.98
VOLTAGE[V] *1 3.3
CURRENT[A] 0.6
SUCS32405
3
5
0.6
SUCS32412
3
12
0.25
SUCS32415
3
15
0.2
SUCS3483R3
1.98
3.3
0.6
SUCS31205 SUCS31212 SUCS31215
0.325typ
77typ
5
0.6
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.317typ
79typ
12
0.25
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.321typ
78typ
15
0.2
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUCS34805
3
5
0.6
SUCS34812
3
12
0.25
SUCS34815
3
15
0.2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-22
SUCS3243R3 SUCS32405 SUCS32412 SUCS32415 SUCS3483R3
DC18 - 36
DC36 - 76
0.114typ
0.057typ
0.163typ
0.159typ
0.161typ
73typ
72typ
77typ
79typ
78typ
3.3
3.3
5
12
15
0.6
0.6
0.6
0.25
0.2
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUCS34805 SUCS34812 SUCS34815
0.082typ
77typ
5
0.6
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.080typ
79typ
12
0.25
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.080typ
79typ
15
0.2
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUCS3
INPUT-OUTPUT
OUTPUT-CASE
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
25X7.0X16.1mm [0.98X0.28X0.63 inches] (WXHXD) / 5g max
*1 SUCW3xx12/SUCW3xx15 is available as single output, +24V/+30V.
External view
Adsorption area
1.SMD(type B)
+Vout
(TOP VIEW)
type B
Component area
Model
1.9
1.3
º1.6
6-º0.9 [0.06]
[0.16]
[0.04]
Unit : 0.1inch
Component area
Model
+Vout
RC
7.62 ±0.2
0.1min
+0.5
[0.1]
[0.15]
Closeup of part A
3.84 -0.25
2.54 ±0.2
Part A
[0.004]
[0.15]
-Vout
¶ Weight : 5g max
+0.5
-0.25
TRM
3.84
25
[0.98]
[0.3]
[0.63]
[0.61]
15.5
[0.02]
0.6 ±0.1
[0.3]
7.62
7
[0.28]
16.1
-Vin
±0.2
[0.05]
type C
+0.5
3.94 -0.25
[0.04]
+Vin
[0.1]
3.2
[0.13]
[0.004]
26.16 ±0.6
2.DIP(type C)
2.54±0.2
27.76
[1.09]
[1.03]
[0.004]
3.68 ±0.25
[0.07]
1.4
[0.3]
[0.1]
7.62 ±0.2
2.54±0.2
16.1
[0.03]
1.27
[0.05]
[0.14]
2
[0.08]
Closeup of part A
0˚)
7
[0.28]
0.8min
-Vout
1
(0-1
1.8±0.3
[0.07]
[0.63]
3.94 +0.5
-0.25
[0.03]
[0.1]
[0.98]
[0.13]
Part A
0.1min
TRM
25
3.2
[0.16]
0.6 ±0.1
0.7 ±0.4 [0.02]
[0.3]
15.5
[0.61]
-Vin
2.54 ±0.2
7.62 ±0.2
RC
[0.06]
+Vin
1
1.27
[0.05]
[0.04]
22.86
[0.9]
January 31, 2022
SU.SUC/SUT-23
SUCW3
SUC W 3 12 12 B P -O
1
2
3
4
5
6
7
8
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray (SMD type)
8 Optional
Input and Output is
removed.
type)*
R
pending
MODEL
DC OUTPUT
SUCW30512
3.12
CURRENT[A] 0.13
SUCW30515
3
t15 or +30
0.1
SUCW31212
3.12
t12 or +24
0.13
SUCW31215
3
t15 or +30
0.1
SUCW32412
3.12
t12 or +24
0.13
SUCW32415
3
t15 or +30
0.1
SUCW34812
3.12
t12 or +24
0.13
SUCW34815
3
t15 or +30
0.1
SUCW30512 SUCW30515 SUCW31212 SUCW31215 SUCW32412 SUCW32415 SUCW34812
DC4.5 - 9
DC9 - 18
DC18 - 36
DC36 - 76
0.844typ
0.811typ
0.343typ
0.329typ
0.172typ
0.165typ
0.086typ
74typ
74typ
76typ
76typ
76typ
76typ
76typ
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
0.13
0.1
0.13
0.1
0.13
0.1
0.13
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
SUCW34815
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
ISOLATION
ENVIRONMENT
SAFETY
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
REMOTE ON/OFF
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
SU.SUC/SUT-24
January 31, 2022
0.083typ
76typ
t15(+30)
0.1
75max
750max
120max
150max
150max
200max
180max
290max
60max
14.25 - 15.75
SUCW3
External view
[0.05]
[0.1]
1.9
[0.07]
1.3
[0.05]
type C
º1.6
7-º0.9 [0.06]
[0.04]
Unit : 0.1inch
26.16 ±0.6
[1.03]
Model
Component area
[0.3]
7.62 ±0.2
2.54 ±0.2
Part A
0.1min
[0.98]
+0.5
[0.004]
1
[0.15]
+0.5
3.84 -0.25
Closeup of part A
[0.04]
[0.1]
25
7
[0.28]
3.84 -0.25
[0.02]
0.6 ±0.1
-Vout
¶ Weight : 5g max
[0.15]
[0.61]
16.1
15.5
[0.3]
[0.63]
TRM
-Vin
[0.1]
COM
2.54±0.2
+Vout
RC
7.62 ±0.2
3.2
[0.13]
[1.09]
[0.16]
+0.5
3.94-0.25
1.27
+Vin
[0.1]
2.54 ±0.2
3.94+0.5
-0.25
[0.16]
16.1
[0.63]
[0.61]
15.5
[0.03]
(0-1
[0.04]
2.DIP(type C)
2.54 ±0.2
27.76
[0.004]
1
[0.004]
[0.14]
2
[0.08]
Closeup of part A
3.68 ±0.25
3.2
[0.13]
0.1min
[0.98]
[0.03]
7
[0.28]
0˚)
1.8 ±0.3
[0.07]
0.8min
0.6 ±0.1
0.7 ±0.4 [0.02]
[0.3]
[0.1]
Part A
25
1.4
-Vout
7.62 ±0.2
TRM
RC
[0.06]
COM
[0.1]
Model
+Vin
(TOP VIEW)
type B
Component area
[0.3]
+Vout
2.54 ±0.2
Adsorption area
-Vin
2.54 ±0.2
7.62 ±0.2
1.SMD(type B)
1.27
[0.05]
22.86
[0.9]
January 31, 2022
SU.SUC/SUT-25
SUCS6
SUC S 6 12 05 B P -O
1
2
3
4
DC OUTPUT
6
7
8
8 Optional
1 Series name
2 Single output
Input and Output is
3 Output wattage
removed.
4 Input voltage
5 Output voltage
DIP type)*
6 Mounting type
B : SMD
C : DIP
* S afety standards
are pending
7 Packing form
Blank:Plastic cover
P : Tray (SMD type)
R
MODEL
5
SUCS6053R3
3.96
VOLTAGE[V] *1 3.3
CURRENT[A] 1.2
SUCS60505
5
5
1
SUCS60512
6
12
0.5
SUCS60515
6
15
0.4
SUCS6123R3
4.46
3.3
1.35
SUCS61205
6
5
1.2
SUCS61212
6
12
0.5
SUCS61215
6
15
0.4
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUCS6053R3 SUCS60505 SUCS60512 SUCS60515 SUCS6123R3
DC4.5 - 9
DC9 - 18
1.100typ
1.316typ
1.500typ
1.500typ
0.502typ
72typ
76typ
80typ
80typ
74typ
3.3
5
12
15
3.3
1.2
1
0.5
0.4
1.35
20max
20max
48max
60max
20max
40max
40max
100max
120max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
SUCS6243R3
4.46
VOLTAGE[V] *1 3.3
CURRENT[A] 1.35
SUCS62405
6
5
1.2
SUCS62412
6
12
0.5
SUCS62415
6
15
0.4
SUCS6483R3
4.46
3.3
1.35
SUCS61205 SUCS61212 SUCS61215
0.617typ
81typ
5
1.2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.588typ
85typ
12
0.5
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.588typ
85typ
15
0.4
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUCS64805
6
5
1.2
SUCS64812
6
12
0.5
SUCS64815
6
15
0.4
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-26
SUCS6243R3 SUCS62405 SUCS62412 SUCS62415 SUCS6483R3
DC18 - 36
DC36 - 76
0.248typ
0.121typ
0.309typ
0.291typ
0.291typ
75typ
77typ
81typ
86typ
86typ
3.3
3.3
5
12
15
1.35
1.35
1.2
0.5
0.4
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUCS64805 SUCS64812 SUCS64815
0.154typ
81typ
5
1.2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.145typ
86typ
12
0.5
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.145typ
86typ
15
0.4
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUCS6
INPUT-OUTPUT
OUTPUT-CASE
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
32.6X7.0X19.1mm [1.28X0.28X0.75 inches] (WXHXD) / 7g max
*1 SUCW6xx12/SUCW6xx15 is available as single output, +24V/+30V.
External view
Adsorption area
Compornent area
1.4
[0.06]
1.9
1.3
[0.5]
Compornent area
TRM
Part A
32.6
0.1min
[1.28]
[0.004]
[0.11]
[0.02]
¶ Weight : 7g max
-Vout
-Vin
2.85 +0.5
-0.25
0.6 ±0.1
[0.5]
[0.75]
19.1
[0.73]
18.6
[0.5]
5.08 ±0.2
[0.2]
12.7±0.2
+Vout
RC
1
[0.11]
Closeup of part A
2.85 +0.5
-0.25
[0.1]
[0.06]
[1.33]
+Vin
[0.28]
f1.6
Unit : 0.1inch
Model
7
[0.04]
33.78 ±0.6
2.DIP(type C)
2.54 ±0.2
[1.39]
6-f0.9
[0.04]
[0.004]
[0.14]
3.2
[0.13]
[0.12]
[0.12]
2.95 +0.5
-0.25
[0.03]
7
0.8min
[0.28]
(0-
1
3.68 ±0.25
type C
2
[0.08]
35.38
Closeup of part A
10
0.1min
[0.004]
12.7±0.2
2.95 +0.5
-0.25
0.7±0.4
Part A
[0.03]
[0.1]
32.6
[1.28]
1.8 ±0.3
3.2
[0.13]
-Vout
-Vin
[0.07]
12.7 ±0.2
TRM
[0.2]
19.1
[0.75]
18.6
[0.73]
[0.02]
0.6±0.1
[0.5]
12.7 ±0.2
2.54 ±0.2
RC
5.08 ±0.2
+Vout
+Vin
(TOP VIEW)
type B
[0.07]
Model
[0.05]
1.SMD(type B)
[0.04]
30.48
[1.2]
January 31, 2022
SU.SUC/SUT-27
SUCW6
SUC W 6 12 12 B P -O
1
2
3
4
5
6
7
8
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray (SMD type)
8 Optional
Input and Output is
removed.
type)*
R
pending
MODEL
SUCW64812
6
t12 or +24
0.25
SUCW64815
6
t15 or +30
0.2
SUCW60512 SUCW60515 SUCW61212 SUCW61215 SUCW62412 SUCW62415 SUCW64812
DC4.5 - 9
DC9 - 18
DC18 - 36
DC36 - 76
INPUT
1.538typ
1.538typ
0.588typ
0.588typ
0.291typ
0.291typ
0.145typ
78typ
78typ
85typ
85typ
86typ
86typ
86typ
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
0.25
0.2
0.25
0.2
0.25
0.2
0.25
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
OUTPUT
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
PROTECTION OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically
CIRCUIT AND
REMOTE ON/OFF
OTHERS
INPUT-OUTPUT
OUTPUT-CASE
OPERATING TEMP. HUMID.AND ALTITUDE -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max
STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max
ENVIRONMENT
VIBRATION
IMPACT
SAFETY
AGENCY APPROVALS
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
SUCW64815
DC OUTPUT
SUCW60512
6
CURRENT[A] 0.25
SUCW60515
6
t15 or +30
0.2
SUCW61212
6
t12 or +24
0.25
SUCW61215
6
t15 or +30
0.2
SUCW62412
6
t12 or +24
0.25
SUCW62415
6
t15 or +30
0.2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
SU.SUC/SUT-28
January 31, 2022
0.145typ
86typ
t15(+30)
0.2
75max
750max
120max
150max
150max
200max
180max
290max
60max
14.25 - 15.75
SUCW6
External view
Component area
Model
1.9
1.3
[0.05]
[0.07]
1.4
Component area
Model
[0.06]
[0.1]
[0.5]
[0.2]
[0.11]
12.7 ±0.2
2.54 ±0.2
¶ Weight : 7g max
-Vout
-Vin
[0.02]
5.08 ±0.2
[0.75]
19.1
[0.73]
18.6
TRM
RC
2.85 +0.5
-0.25
+Vout
[0.5]
f1.6
Unit : 0.1inch
[1.33]
COM
Part A
7
32.6
0.1min
[0.28]
[1.28]
[0.004]
2.85 +0.5
-0.25
Closeup of part A
1
[0.11]
0.6±0.1
[0.04]
33.78 ±0.6
+Vin
[0.1]
7-f0.9
[0.04]
2.DIP(type C)
12.7 ±0.2
[1.39]
type C
[0.12]
2.95 +0.5
-0.25
0.8min
[0.03]
7
[0.28]
(0-1
1
[0.004]
2.54±0.2
3.2
Closeup of part A
[0.14]
[0.5]
2.54±0.2
[0.1]
[0.2]
2.95 +0.5
-0.25
[0.004]
0˚)
0.1min
2
[0.08] [0.13]
35.38
[0.12]
0.7±0.4
Part A
[0.03]
[0.1]
32.6
[1.28]
3.68±0.25
3.2
[0.13]
-Vout
-Vin
1.8 ±0.3
12.7 ±0.2
TRM
5.08 ±0.2
19.1
COM
[0.75]
[0.73]
18.6
0.6 ±0.1
[0.02]
[0.5]
12.7 ±0.2
2.54±0.2
RC
[0.06]
+Vout
+Vin
[0.07]
(TOP VIEW)
type B
Adsorption area
1.SMD(type B)
[0.04]
30.48
[1.2]
January 31, 2022
SU.SUC/SUT-29
SUCS10
SUC S 10 12 05 B P -O
1
2
3
4
DC OUTPUT
6
7
8
8 Optional
1 Series name
2 Single output
Input and Output is
3 Output wattage
removed.
4 Input voltage
5 Output voltage
DIP type)*
6 Mounting type
B : SMD
C : DIP
* S afety standards
are pending
7 Packing form
Blank:Plastic cover
P : Tray (SMD type)
R
MODEL
5
SUCS10053R3
8.58
VOLTAGE[V] *1 3.3
CURRENT[A] 2.6
SUCS100505
10
5
2
SUCS100512
10.8
12
0.9
SUCS100515
10.5
15
0.7
SUCS10123R3
8.58
3.3
2.6
SUCS101205
10
5
2
SUCS101212
12
12
1
SUCS101215
12
15
0.8
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUCS10053R3 SUCS100505 SUCS100512 SUCS100515 SUCS10123R3
DC4.5 - 9
DC9 - 18
2.12typ
2.41typ
2.54typ
2.47typ
0.872typ
81typ
83typ
85typ
85typ
82typ
3.3
5
12
15
3.3
2.6
2
0.9
0.7
2.6
20max
20max
48max
60max
20max
40max
40max
100max
120max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
SUCS10243R3
8.58
VOLTAGE[V] *1 3.3
CURRENT[A] 2.6
SUCS102405
10
5
2
SUCS102412
12
12
1
SUCS102415
12
15
0.8
SUCS10483R3
8.58
3.3
2.6
SUCS101205 SUCS101212 SUCS101215
0.980typ
85typ
5
2
20max
40max
80max
120max
120max
200max
50max
80max
20max
1.15typ
87typ
12
1
48max
100max
120max
150max
150max
200max
150max
240max
48max
1.15typ
87typ
15
0.8
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUCS104805
10
5
2
SUCS104812
12
12
1
SUCS104815
12
15
0.8
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-30
SUCS10243R3 SUCS102405 SUCS102412 SUCS102415 SUCS10483R3
DC18 - 36
DC36 - 76
0.436typ
0.218typ
0.490typ
0.575typ
0.575typ
82typ
82typ
85typ
87typ
87typ
3.3
3.3
5
12
15
2.6
2.6
2
1
0.8
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUCS104805 SUCS104812 SUCS104815
0.245typ
85typ
5
2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.287typ
87typ
12
1
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.287typ
87typ
15
0.8
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUCS10
INPUT-OUTPUT
OUTPUT-CASE
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
40.2X7.0X22.0mm [1.58X0.28X0.87 inches] (WXHXD) / 10g max
*1 SUCW10xx12/SUCW10xx15 is available as single output, +24V/+30V.
External view
(TOP VIEW)
type B
Adsorption area
Compornent area
1.9
2
3.2
[0.08]
Closeup of part A
3.13 +0.5
-0.25
1.27
6-f0.9
[0.05]
41.4 ±0.6
[0.004]
[0.3]
[0.02]
-Vout 0.1min
[0.004]
40.2
Part A
Closeup of part A
[1.58]
7
[0.28]
3.03 +0.5
-0.25
3.68 ±0.25
¶ Weight : 10g max
[0.12]
[0.1]
0.6 ±0.1
TRM
[0.6]
7.62±0.2
22
[0.85]
21.5
[0.6]
Compornent area
15.24 ±0.2
+Vout
[0.06]
Unit : 0.1inch
3.03 +0.5
-0.25
Model
+Vin
[0.87]
2.DIP(type C)
f1.6
[0.04]
[1.63]
RC
-Vin
type C
[0.12]
(0
[0.04]
3.13 +0.5
-0.25
[0.004]
[0.03]
0.8min
7
0.1min
1
-1
[0.07]
-Vout
Part A
[0.12]
40.2
0˚
1.8 ±0.3
[0.28]
15.24 ±0.2
3.2
[0.13]
[0.12]
0.7±0.4
[0.03]
RC
-Vin
[1.58]
2.54 ±0.2
43
[1.69]
[0.1]
2.54 ±0.2
[0.13]
[0.14]
[0.07]
1.4
[0.06]
[0.6]
1.3
[0.02]
[0.3]
22
[0.85]
[0.87]
0.6 ±0.1
[0.6]
21.5
15.24 ±0.2
TRM
15.24 ±0.2
+Vout
[0.05]
Model
+Vin
7.62 ±0.2
1.SMD(type B)
1
[0.04]
1.27
[0.05]
38.1
[1.5]
January 31, 2022
SU.SUC/SUT-31
SUCW10
SUC W 10 12 12 B P -O
1
2
3
4
5
6
7
8
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Mounting type
B : SMD
C : DIP
7Packing form
Blank:Plastic cover
P : Tray(SMD type)
8 Optional
Input and Output is
removed.
type)*
R
pending
MODEL
DC OUTPUT
SUCW100512
10.8
CURRENT[A] 0.45
SUCW100515
10.5
t15 or +30
0.35
SUCW101212
10.8
t12 or +24
0.45
SUCW101215
10.5
t15 or +30
0.35
SUCW102412
10.8
t12 or +24
0.45
SUCW102415
10.5
t15 or +30
0.35
SUCW104812
10.8
t12 or +24
0.45
SUCW104815
10.5
t15 or +30
0.35
SUCW100512 SUCW100515 SUCW101212 SUCW101215 SUCW102412 SUCW102415 SUCW104812
DC4.5 - 9
DC9 - 18
DC18 - 36
DC36 - 76
2.51typ
2.44typ
1.05typ
1.02typ
0.523typ
0.509typ
0.262typ
86typ
86typ
86typ
86typ
86typ
86typ
86typ
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
0.45
0.35
0.45
0.35
0.45
0.35
0.45
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
SUCW104815
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
ISOLATION
ENVIRONMENT
SAFETY
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
REMOTE ON/OFF
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
SU.SUC/SUT-32
January 31, 2022
0.254typ
86typ
t15(+30)
0.35
75max
750max
120max
150max
150max
200max
180max
290max
60max
14.25 - 15.75
SUCW10
External view
1.SMD(type B)
Compornent area
Model
Compornent area
+Vin
[0.004]
[1.58]
[0.28]
Part A
3.03 +0.5
-0.25
Closeup of part A
1.9
[0.07]
1.3
3.03 +0.5
-0.25
[0.12]
0.1min
40.2
7
¶ Weight : 10g max
[0.12]
0.6 ±0.1
[0.02]
-Vout
RC
-Vin
[0.6]
[0.1]
15.24 ±0.2
7.62 ±0.2
[0.87]
22
[0.85]
21.5
[0.6]
TRM
[0.3]
2.54 ±0.2
+Vout
COM
[0.06]
Unit : 0.1inch
[0.004]
Model
f1.6
[0.04]
2.DIP(type C)
[0.1]
[0.05]
1.4
[0.06]
[0.6]
2.54 ±0.2
[0.1]
7-f0.9
[1.63]
15.24±0.2
type C
1.27
41.4 ±0.6
3.2
[0.13]
[1.69]
[0.12]
[0.004]
Closeup of part A
3.13 +0.5
-0.25
-1
(0
3.13 +0.5
-0.25
0.1min
1
[0.04]
[0.05]
2.54 ±0.2
[0.08]
43
[0.12]
0.7±0.4
Part A
[0.03]
0.8min
7
[0.28]
0˚
[0.03]
40.2
[1.58]
[0.14]
2
3.2
[0.13]
RC
-Vin
3.68±0.25
15.24 ±0.2
[0.3]
22
[0.87]
[0.85]
21.5
[0.6]
0.6 ±0.1
[0.02]
TRM
-Vout
[0.1]
2.54 ±0.2
15.24 ±0.2
COM
7.62 ±0.2
+Vout
+Vin
1.8±0.3
[0.07]
(TOP VIEW)
type B
Adsorption area
1
[0.04]
1.27
[0.05]
38.1
[1.5]
January 31, 2022
SU.SUC/SUT-33
SUTS3
SUT
1
S
2
3
3
12
4
DC OUTPUT
-O
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
G : Capacitor between Input
R
MODEL
05
5
SUTS3053R3
1.98
VOLTAGE[V] *1 3.3
CURRENT[A] 0.6
SUTS30505
3
5
0.6
SUTS30512
3
12
0.25
SUTS30515
3
15
0.2
SUTS3123R3
1.98
3.3
0.6
SUTS31205
3
5
0.6
SUTS31212
3
12
0.25
SUTS31215
3
15
0.2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUTS3053R3 SUTS30505 SUTS30512 SUTS30515 SUTS3123R3
DC4.5 - 9
DC9 - 18
0.550typ
0.800typ
0.780typ
0.780typ
0.223typ
72typ
75typ
77typ
77typ
74typ
3.3
5
12
15
3.3
0.6
0.6
0.25
0.2
0.6
20max
20max
48max
60max
20max
40max
40max
100max
120max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
SUTS3243R3
1.98
VOLTAGE[V] *1 3.3
CURRENT[A] 0.6
SUTS32405
3
5
0.6
SUTS32412
3
12
0.25
SUTS32415
3
15
0.2
SUTS3483R3
1.98
3.3
0.6
SUTS31205 SUTS31212 SUTS31215
0.325typ
77typ
5
0.6
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.317typ
79typ
12
0.25
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.321typ
78typ
15
0.2
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUTS34805
3
5
0.6
SUTS34812
3
12
0.25
SUTS34815
3
15
0.2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-34
SUTS3243R3 SUTS32405 SUTS32412 SUTS32415 SUTS3483R3
DC18 - 36
DC36 - 76
0.114typ
0.057typ
0.163typ
0.159typ
0.161typ
73typ
72typ
77typ
79typ
78typ
3.3
3.3
5
12
15
0.6
0.6
0.6
0.25
0.2
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUTS34805 SUTS34812 SUTS34815
0.082typ
77typ
5
0.6
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.080typ
79typ
12
0.25
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.080typ
79typ
15
0.2
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUTS3
INPUT-OUTPUT
OUTPUT-CASE
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
30.0X23.4X9.15mm [1.18X0.92X0.36 inches] (WXHXD) / 8g max
*1 SUTW3xx12/SUTW3xx15 is available as single output, +24V/+30V.
External view
Model
(TOP VIEW)
6.01
6.85
[0.04]
17.78
±0.2
[0.7]
3.5 ±0.25
[0.02]
1
Part B
[0.14]
0.6 ±0.1
1
[0.04]
6.01
6.85
1.9
[0.24]
[0.27]
[0.07]
+Vout
NC TRM
8.35
+Vin
5.08
[0.36]
6.01
±0.2
[0.2]
-Vout
[0.33]
RC
2.54
±0.2
[0.24]
4-f1.6
[0.06]
Unit : 0.1inch
Dimensions in mm, [
]= inches
¶ Dimensions in mm, [ ]= inches
¶ Please keep enough creepage distance with
the pattern on PCB and other components.
¶ Weight : 8g max
9.15
-Vin
[0.04]
[0.27]
23.4
0.5
[0.02]
Outline
Part A
6.01
7-f0.9
[0.92]
[0.24]
[0.24]
[0.1]
30
[1.18]
¶ Back View
Closeup of part A
Closeup of part B
6.01
6.85
[0.24]
[0.27]
: Conduction Area
January 31, 2022
SU.SUC/SUT-35
SUTW3
SUT W
1
2
3
3
12
4
12
5
-O
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
DC OUTPUT
SUTW30512
3.12
CURRENT[A] 0.13
SUTW30515
3
t15 or +30
0.1
SUTW31212
3.12
t12 or +24
0.13
SUTW31215
3
t15 or +30
0.1
SUTW32412
3.12
t12 or +24
0.13
SUTW32415
3
t15 or +30
0.1
SUTW34812
3.12
t12 or +24
0.13
SUTW34815
3
t15 or +30
0.1
SUTW30512 SUTW30515 SUTW31212 SUTW31215 SUTW32412 SUTW32415 SUTW34812
DC4.5 - 9
DC9 - 18
DC18 - 36
DC36 - 76
0.844typ
0.811typ
0.343typ
0.329typ
0.172typ
0.165typ
0.086typ
74typ
74typ
76typ
76typ
76typ
76typ
76typ
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
0.13
0.1
0.13
0.1
0.13
0.1
0.13
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
SUTW34815
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
ISOLATION
ENVIRONMENT
SAFETY
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
REMOTE ON/OFF
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
UL60950-1, C-UL, EN62368-1
30.0X23.4 X9.15mm [1.18X0.92X0.36 inches] (WXHXD) / 8g max
SU.SUC/SUT-36
January 31, 2022
0.083typ
76typ
t15(+30)
0.1
75max
750max
120max
150max
150max
200max
180max
290max
60max
14.25 - 15.75
SUTW3
External view
Model
6.85
17.78 ±0.2
[0.7]
+Vout
+Vin
6.01
6.85
[0.24]
[0.27]
COM TRM
8.35
RC
5.08
2.54 ±0.2
[0.04]
6.01
[0.24]
4-f1.6
[0.06]
Outline
Unit : 0.1inch
Dimensions in mm, [
]= inches
¶ Weight : 8g max
-Vout
6.01
±0.2
[0.2]
1
[0.04]
7-f0.9
[0.27]
23.4
[0.04]
3.5 ±0.25
[0.02]
Part B
[0.14]
1
[0.33]
0.5
6.01
[0.24]
[0.02]
Part A
0.6 ±0.1
-Vin
[0.92]
(TOP VIEW)
[0.24]
[0.1]
30
[1.18]
¶ Back View
Closeup of part A
Closeup of part B
6.01
6.85
[0.24]
[0.27]
: Conduction Area
January 31, 2022
SU.SUC/SUT-37
Ordering information
DC-DC Converters PCB Mount Type
SUTS6
SUT
1
S
2
6
3
12
4
DC OUTPUT
-O
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
MAX OUTPUT WATTAGE[W]
05
5
SUTS6053R3
3.96
VOLTAGE[V] *1 3.3
CURRENT[A] 1.2
SUTS60505
5
5
1
SUTS60512
6
12
0.5
SUTS60515
6
15
0.4
SUTS6123R3
4.46
3.3
1.35
SUTS61205
6
5
1.2
SUTS61212
6
12
0.5
SUTS61215
6
15
0.4
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
TEMPERATURE REGULATION[mV]
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
OUTPUT VOLTAGE ADJUSTMENT RANGE
OUTPUT VOLTAGE SETTING[V] (t3%)
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUTS6053R3 SUTS60505 SUTS60512 SUTS60515 SUTS6123R3
DC4.5 - 9
DC9 - 18
1.100typ
1.316typ
1.500typ
1.500typ
0.502typ
72typ
76typ
80typ
80typ
74typ
3.3
5
12
15
3.3
1.2
1
0.5
0.4
1.35
20max
20max
48max
60max
20max
40max
40max
100max
120max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
20max (Minimum input, Io=100%)
Fixed (TRM pin open) t5% adjustable by external VR
3.21 - 3.42
4.90 - 5.21
11.64 - 12.36 14.55 - 15.45 3.21 - 3.42
SUTS6243R3
4.46
VOLTAGE[V] *1 3.3
CURRENT[A] 1.35
SUTS62405
6
5
1.2
SUTS62412
6
12
0.5
SUTS62415
6
15
0.4
SUTS6483R3
4.46
3.3
1.35
SUTS61205 SUTS61212 SUTS61215
0.617typ
81typ
5
1.2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.588typ
85typ
12
0.5
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.588typ
85typ
15
0.4
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUTS64805
6
5
1.2
SUTS64812
6
12
0.5
SUTS64815
6
15
0.4
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-38
SUTS6243R3 SUTS62405 SUTS62412 SUTS62415 SUTS6483R3
DC18 - 36
DC36 - 76
0.248typ
0.121typ
0.309typ
0.291typ
0.291typ
75typ
77typ
81typ
86typ
86typ
3.3
3.3
5
12
15
1.35
1.35
1.2
0.5
0.4
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUTS64805 SUTS64812 SUTS64815
0.154typ
81typ
5
1.2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.145typ
86typ
12
0.5
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.145typ
86typ
15
0.4
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUTS6
GENERAL SPECIFICATIONS
INPUT-OUTPUT
OUTPUT-CASE
OPERATING TEMP.,HUMID.AND ALTITUDE
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C)
10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis
490.3m/s2 (50G), 11ms, once each along X, Y and Z axis
37.6X26.4X9.15mm [1.48X1.04X0.36 inches] (WXHXD) / 11g max
Convection/Forced air
*1 SUTW6xx12/SUTW6xx15 is available as single output, +24V/+30V.
*2 Rated input 5V, 12V, 24V or 48V DC Io=100%
*3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals.
*4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C.
* Parallel operation with other model is not possible.
External view
Model
Recommended Pad and Hole dia.
(TOP VIEW)
9.81
[0.7]
[0.06]
RC
+Vout
+Vin
5.08
[0.04]
±0.25
6.85
1.9
[0.39]
[0.27]
[0.07]
NC
TRM
-Vout
9.15
[0.36]
9.81
±0.2
[0.2]
1
9.81
8.35
-Vin
2.54 ±0.2
9.81
[0.39]
[0.27]
6.85
26.4
±0.2
3.5
[0.04]
17.78
[0.14]
[0.02]
1
Part B
[0.33]
0.5
[0.02]
0.6 ±0.1
[0.04]
4-f1.6
Outline
Part A
7-f0.9
[1.04]
[0.39]
Unit : 0.1inch
Dimensions in mm, [
]= inches
¶ Tolerance ±0.5 [±0.02]
¶ Pin terminal thickness : 0.3±0.1 [0.012]
¶ Pin terminal material : Copper alloy
¶ Plating treatment of terminal : Lead free plating
¶ Weight : 11g max
[0.39]
[0.1]
37.6
[1.48]
¶ Back View
Closeup of part A
9.81
[0.39]
Closeup of part B
6.85
[0.27]
: Conduction Area
January 31, 2022
SU.SUC/SUT-39
SUTW6
SUT W
1
2
6
3
12
4
12
5
-O
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
SUTW64812
6
t12 or +24
0.25
SUTW64815
6
t15 or +30
0.2
SUTW60512 SUTW60515 SUTW61212 SUTW61215 SUTW62412 SUTW62415 SUTW64812
DC4.5 - 9
DC9 - 18
DC18 - 36
DC36 - 76
INPUT
1.538typ
1.538typ
0.588typ
0.588typ
0.291typ
0.291typ
0.145typ
78typ
78typ
85typ
85typ
86typ
86typ
86typ
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
0.25
0.2
0.25
0.2
0.25
0.2
0.25
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
OUTPUT
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
CIRCUIT AND
REMOTE ON/OFF
OTHERS
INPUT-OUTPUT
OUTPUT-CASE
ENVIRONMENT
VIBRATION
IMPACT
SAFETY
AGENCY APPROVALS
CASE SIZE/WEIGHT
37.6X26.4X9.15mm [1.84X1.04X0.36 inches] (WXHXD) / 11g max
OTHERS
COOLING METHOD
SUTW64815
DC OUTPUT
SUTW60512
6
VOLTAGE[V] *1 t12 or +24
CURRENT[A] 0.25
SUTW60515
6
t15 or +30
0.2
SUTW61212
6
t12 or +24
0.25
SUTW61215
6
t15 or +30
0.2
SUTW62412
6
t12 or +24
0.25
SUTW62415
6
t15 or +30
0.2
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
OUTPUT VOLTAGE SETTING[V] (t5%)
*1 Output pins can be connected in series to make a 24V/30V output.
SU.SUC/SUT-40
January 31, 2022
0.145typ
86typ
t15(+30)
0.2
75max
750max
120max
150max
150max
200max
180max
290max
60max
14.25 - 15.75
SUTW6
External view
Model
(TOP VIEW)
[0.04]
17.78
±0.2
[0.7]
+Vout
9.81
6.85
1.9
[0.27]
[0.07]
COM TRM
5.08
[0.36]
9.81
±0.2
[0.2]
-Vout
2.54 ±0.2
[0.06]
Unit : 0.1inch
Dimensions in mm, [
]= inches
[0.04]
[0.39]
8.35
+Vin
9.81
[0.39]
4-f1.6
1
[0.33]
RC
[0.04]
Outline
9.15
-Vin
7-f0.9
[0.27]
[1.04]
6.85
[0.02]
1
3.5
0.6 ±0.1
Part B
[0.14]
Part A
±0.25
[0.02]
0.5
26.4
9.81
[0.39]
¶ Weight : 11g max
[0.39]
[0.1]
37.6
[1.48]
¶ Back View
Closeup of part A
9.81
[0.39]
Closeup of part B
6.85
[0.27]
: Conduction Area
January 31, 2022
SU.SUC/SUT-41
SUTS10
SUT S 10 12 05 -O
1
2
3
4
DC OUTPUT
6
1 Series name
2 Single output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
R
MODEL
5
SUTS10053R3
8.58
VOLTAGE[V] *1 3.3
CURRENT[A] 2.6
SUTS100505
10
5
2
SUTS100512
10.8
12
0.9
SUTS100515
10.5
15
0.7
SUTS10123R3
8.58
3.3
2.6
SUTS101205
10
5
2
SUTS101212
12
12
1
SUTS101215
12
15
0.8
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
MODEL
DC OUTPUT
SUTS10053R3 SUTS100505 SUTS100512 SUTS100515 SUTS10123R3
DC4.5 - 9
DC9 - 18
2.12typ
2.41typ
2.54typ
2.47typ
0.872typ
81typ
83typ
85typ
85typ
82typ
3.3
5
12
15
3.3
2.6
2
0.9
0.7
2.6
20max
20max
48max
60max
20max
40max
40max
100max
120max
40max
80max
80max
80max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
120max
120max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
Provided (Negative logic L : ON, H : OFF)
SUTS10243R3
8.58
VOLTAGE[V] *1 3.3
CURRENT[A] 2.6
SUTS102405
10
5
2
SUTS102412
12
12
1
SUTS102415
12
15
0.8
SUTS10483R3
8.58
3.3
2.6
SUTS101205 SUTS101212 SUTS101215
0.980typ
85typ
5
2
20max
40max
80max
120max
120max
200max
50max
80max
20max
1.15typ
87typ
12
1
48max
100max
120max
150max
150max
200max
150max
240max
48max
1.15typ
87typ
15
0.8
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUTS104805
10
5
2
SUTS104812
12
12
1
SUTS104815
12
15
0.8
SPECIFICATIONS
MODEL
VOLTAGE[V]
*2
INPUT
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
OUTPUT
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
CIRCUIT AND
REMOTE ON/OFF
OTHERS
SU.SUC/SUT-42
SUTS10243R3 SUTS102405 SUTS102412 SUTS102415 SUTS10483R3
DC18 - 36
DC36 - 76
0.436typ
0.218typ
0.490typ
0.575typ
0.575typ
82typ
82typ
85typ
87typ
87typ
3.3
3.3
5
12
15
2.6
2.6
2
1
0.8
20max
20max
20max
48max
60max
40max
40max
40max
100max
120max
80max
80max
80max
120max
120max
120max
120max
120max
150max
150max
120max
120max
120max
150max
150max
200max
200max
200max
200max
200max
50max
150max
180max
50max
50max
80max
240max
290max
80max
80max
20max
48max
60max
20max
20max
3.21 - 3.42
4.90 - 5.21
January 31, 2022
SUTS104805 SUTS104812 SUTS104815
0.245typ
85typ
5
2
20max
40max
80max
120max
120max
200max
50max
80max
20max
0.287typ
87typ
12
1
48max
100max
120max
150max
150max
200max
150max
240max
48max
0.287typ
87typ
15
0.8
60max
120max
120max
150max
150max
200max
180max
290max
60max
4.90 - 5.21
SUTS10
45.2X29.3 X9.15mm [1.78X1.15X0.36 inches] (WXHXD) / 14g max
INPUT-OUTPUT
OUTPUT-CASE
ENVIRONMENT
VIBRATION
IMPACT
AGENCY APPROVALS
SAFETY
CASE SIZE/WEIGHT
OTHERS
COOLING METHOD
*1 SUTW10xx12/SUTW10xx15 is available as single output, +24V/+30V.
External view
Model
(TOP VIEW)
±0.25
[0.04]
3.5
0.6 ±0.1
[0.02]
17.78
±0.2
[0.7]
Part B
[0.14]
1
[0.04]
6.85
1.9
[0.54]
[0.27]
[0.07]
9.15
[0.36]
+Vout
+Vin
NC
TRM
-Vout
8.35
RC
5.08
[0.54]
Unit : 0.1inch
Dimensions in mm, [
]= inches
¶ Weight : 14g max
13.61
±0.2
[0.2]
[0.33]
-Vin
13.61
[0.06]
1
13.61
[0.04]
4-f1.6
Outline
Part A
7-f0.9
[0.27]
6.85
[1.15]
[0.54]
[0.02]
0.5
29.3
13.61
2.54 ±0.2
[0.54]
[0.1]
45.2
[1.78]
¶ Back View
Closeup of part A
Closeup of part B
13.61
[0.54]
6.85
[0.27]
: Conduction Area
January 31, 2022
SU.SUC/SUT-43
SUTW10
SUT W 10 12 12 -O
1
2
3
4
5
6
1 Series name
2 Dual output
3 Output wattage
4 Input voltage
5 Output voltage
6 Optional
and Output is removed.
R
MODEL
DC OUTPUT
SUTW100512
10.8
CURRENT[A] 0.45
SUTW100515
10.5
t15 or +30
0.35
SUTW101212
10.8
t12 or +24
0.45
SUTW101215
10.5
t15 or +30
0.35
SUTW102412
10.8
t12 or +24
0.45
SUTW102415
10.5
t15 or +30
0.35
SUTW104812
10.8
t12 or +24
0.45
SUTW104815
10.5
t15 or +30
0.35
SUTW100512 SUTW100515 SUTW101212 SUTW101215 SUTW102412 SUTW102415 SUTW104812
DC4.5 - 9
DC9 - 18
DC18 - 36
DC36 - 76
2.51typ
2.44typ
1.05typ
1.02typ
0.523typ
0.509typ
0.262typ
86typ
86typ
86typ
86typ
86typ
86typ
86typ
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
t15(+30)
t12(+24)
0.45
0.35
0.45
0.35
0.45
0.35
0.45
60max
75max
60max
75max
60max
75max
60max
600max
750max
600max
750max
600max
750max
600max
120max
120max
120max
120max
120max
120max
120max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
150max
200max
200max
200max
200max
200max
200max
200max
150max
180max
150max
180max
150max
180max
150max
240max
290max
240max
290max
240max
290max
240max
50max
60max
50max
60max
50max
60max
50max
11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60
SUTW104815
SPECIFICATIONS
INPUT
OUTPUT
PROTECTION
CIRCUIT AND
OTHERS
ISOLATION
ENVIRONMENT
SAFETY
OTHERS
MODEL
VOLTAGE[V]
*2
CURRENT[A]
*2
EFFICIENCY[%]
VOLTAGE[V]
CURRENT[A]
LINE REGULATION[mV]
LOAD REGULATION[mV]
-20 to +55C *3
RIPPLE[mVp-p]
-40 to -20C *3
-20 to +55C *3
RIPPLE NOISE[mVp-p]
-40 to -20C *3
-20 to +55C
-40 to +55C
*4
DRIFT[mV]
START-UP TIME[ms]
REMOTE ON/OFF
INPUT-OUTPUT
INPUT-CASE
OUTPUT-CASE
VIBRATION
IMPACT
AGENCY APPROVALS
CASE SIZE/WEIGHT
COOLING METHOD
SU.SUC/SUT-44
January 31, 2022
0.254typ
86typ
t15(+30)
0.35
75max
750max
120max
150max
150max
200max
180max
290max
60max
14.25 - 15.75
SUTW10
External view
Model
(TOP VIEW)
13.61
17.78
±0.25
3.5
±0.2
[0.7]
[0.14]
1
[0.04]
0.6 ±0.1
[0.02]
6.85
Part B
1
[0.04]
13.61
6.85
1.9
[0.54]
[0.27]
[0.07]
9.15
+Vout
+Vin
COM TRM
-Vout
5.08
[0.2]
[0.36]
[0.33]
RC
8.35
-Vin
[0.04]
13.61
[0.54]
4-f1.6
[0.06]
Outline
Part A
7-f0.9
[0.27]
29.3
[0.02]
0.5
[1.15]
[0.54]
Unit : 0.1inch
Dimensions in mm, [
]= inches
¶ Weight : 14g max
13.61
±0.2
2.54 ±0.2
[0.54]
[0.1]
45.2
[1.78]
¶ Back View
Closeup of part A
Closeup of part B
13.61
[0.54]
6.85
[0.27]
: Conduction Area
January 31, 2022
SU.SUC/SUT-45
SU-SUC/SUT-series
Pin Configuration
¿ SU/SUC Single Output
Pin No.
View from Above
1
2
Input
3
+Vin
+Vout
RC
TRM
-Vin
-Vout
8
1
2
3
4
5
4
6
Load
7
Case Connecting Pin
6
7
¿ SU/SUC Dual (±) Output
View from Above
1
Input
+Vin
COM
RC
2
3
TRM
-Vin
8
4
+Vout
5
Load
6
Load
Pin Terminal
Name
+Vin
RC
-Vin
+Vout
COM
Function
+DC Input
Remote ON/OFF (excluding 1R5)
-DC Input
+DC Output
GND of Output Voltage (for Dual Output)
Output Voltage Adjustment (please see
TRM
Instruction Manual 1.4)
-Vout
-DC Output
If connected to -Vin, a case potential becomes
Case Connecting
fixed and radiation noise decreases (applicable
Pin
only to SUC series).
Load
-Vout
7
8 Case Connecting Pin
¿ SU/SUC Single Output, Dual (±) Output
Bottom View
8
1
2
3
4
5
Pin No.
8
6
1
2
3
4
7
8
8
5
6
7
8
Pin Terminal
Name
-Vin
RC
+Vin
+Vout
NC (Single output)
COM (Dual output)
TRM
-Vout
Case Connecting
Pin
Function
-DC Input
Remote ON/OFF
+DC Input
+DC Output
-DC Output
fixed and radiation noise decreases.
¡Case Connecting Pin Terminal
Units come with a case connecting pin terminal. If this pin terminal is connected to -Vin, radiation noise from the main body decreases.
Solder the case connecting pin terminal to PCB to improve reliability.
Assembling and Installation Method
Installation
¡You can install the units in any direction. Place them in such a way that there is enough ventilation so that heat does not get accumulated
around them.
¡Do not place a rand or a pattern layout in the hatched area shown in below. Doing so may cause insulation failure on the PCB surface on
which the power supply is mounted.
A
Outline
+Vout
-Vin
-Vout
A: SU Series
2mm
5.2
SUC Series 2.5mm
Area where Pattern Layout should not be Placed for SU/SUC
SU.SUC/SUT-46
2.3
+Vin
4.4
Outer Contour
of the Unit
1.75
2.3
A
Case Connecting Pin
Area where Pattern Layout should not be Placed for SUT
January 31, 2022
SU-SUC/SUT-series
Automatic Mounting (TYPE: BP)
¡To mount SU series automatically, use the transformer area near the center of the PCB as a pickup point. To mount SUC series automatically, use the central area of the case as a pickup point. If the bottom dead point of a suction nozzle is too low when mounting, excessive
force is applied to the transformer, which could cause damage. Please mount carefully. Please see the External View for details of the
pickup point.
Hand Mounting (TYPE:B,C SUT)
push push
¡To mount SU series manually, it must be push the transformer
placed center of PS.
¡To mount SUC series manually, it must be push the center of
case.
¡Due to prevent failure, PS should not be pull after soldering with
PCB.
Soldering Conditions
(1) Reflow Soldering (except SUT, SUC□□C-C)
+Vin
¡Right figure shows conditions for the reflow soldering for SU/SUC
series. Please make sure that the temperatures of pin terminals
+Vin and -Vout shown in right figure . do not exceed the tempera-
-Vout
tures shown in right figure.
¡If time or temperature of the reflow soldering goes beyond the
conditions, reliability of internal components may be compromised.
*View from Above
(C)
Please use the unit under the recommended reflow conditions.
Tp
¡With this reflow profile, internal solder melts down. When transporting the unit within the reflow oven, please do not give vibration
Tx
Ty2
to the unit.
Ty1
¡Please avoid reflow soldering after applying adhesive or coating to
the unit.
¡You can reflow solder up to 2 times. Do not reflow solder when the
power supply is mounted on the back surface of the PCB because
the unit may drop.
A
(2) Flow Soldering : 260C 15 seconds or less
B
B’
C
time(s)
A
A’
(3) Soldering Iron : maximum 360C 5 seconds or less
A’
B
B’
C
1.0 - 5.0C/s
Ty1 : 160 ±20C
Ty2 : 180 ±20C
Ty1 - Ty2 : 120s max
1.0 - 5.0C/s
Tp : Max 245C 10s max
Tx : 220C or more : 70s max
1.0 - 5.0C/s
Stress to Pin Terminals
¡If too much stress is applied to input/output pin terminals of thepower supply, internal connection may come down. If you apply stress as
shown below, please kept it at 19.6N (2kgf) or less vertically.
¡Input/output pin terminals are soldered to the PCB internally. Do not pull or bend a lead powerfully.
¡If it is expected that stress is applied to the input/output pin terminals due to vibration or impact, reduce the stress to the pin terminals by
taking such measures as fixing the unit to the PCB by silicone rubber, etc.
A part
19.6N(2kgf)
or less
19.6N(2kgf)
or less
19.6N(2kgf)
or less
19.6N(2kgf)
or less
Less than
A
Strength of Input/Output Pin Terminals for SU/SUC
19.6N(2kgf)
Strength of Input/Output Pin Terminals for SUT
January 31, 2022
SU.SUC/SUT-47
SU-SUC/SUT-series
Derating
Ambient temperature derating curve
¡It is necessary to note thermal fatigue life by power cycle.Please reduce the temperature fluctuation range as much as possible when the
up and down of temperature are frequently generated.
¡In the case of forced air cooling,Please have sufficient ventilation to keep the temperature of point in Instruction Manual 7 . Please also
make sure that the ambient temperature does not exceed 85C.
¿ SU/SUC1R5
(2) In the case of Forced Air Cooling (1m/s)
(1) In the case of Convection Cooling
100
A
Load Factor [%]
Load Factor [%]
100
B
50
-20
(55) 60
80 (85)
A
50
100
-20
Ambient Temperature [C]
Output Voltage(V)
Input Voltage(V)
5
12
24
48
3.3
5
12
15
±12
±15
A
A
A
B
A
A
A
B
A
A
A
B
A
A
A
B
A
A
A
B
A
A
A
B
Output Voltage(V)
Input Voltage(V)
5
12
24
48
¿ SU/SUC3
60
80 (85)
100
3.3
5
12
15
±12
±15
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
100
100
A
Load Factor [%]
Load Factor [%]
40
B
50
C
-20
(55) 60
(71)
80 (85)
B
100
Input Voltage(V)
5
12
24
48
A
50
-20
Output Voltage(V)
60
80 (85)
100
3.3
5
12
15
±12
±15
A
A
A
B
A
A
A
B
B
B
B
B
B
B
B
B
A
A
A
A
B
B
B
C
Output Voltage(V)
Input Voltage(V)
5
12
24
48
¿ SU/SUC6
3.3
5
12
15
±12
±15
A
A
A
A
B
A
A
A
B
A
B
A
B
A
A
A
B
A
A
A
B
B
B
B
100
100
A
Load Factor [%]
Load Factor [%]
50
B
-20
(55) 60
(71)
80 (85)
100
50
-20
Output Voltage(V)
Input Voltage(V)
5
12
24
48
SU.SUC/SUT-48
A
B
60
(75) 80 (85)
100
3.3
5
12
15
±12
±15
B
B
B
B
B
B
B
B
B
B
B
A
B
B
B
A
B
B
B
A
B
B
B
A
Output Voltage(V)
Input Voltage(V)
5
12
24
48
January 31, 2022
3.3
5
12
15
±12
±15
B
B
B
B
B
B
B
B
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
SU-SUC/SUT-series
Derating
¿ SU/SUC10
100
A
Load Factor [%]
Load Factor [%]
100
50
B
-20
(55) 60
(71)
80 (85)
50
100
-20
Output Voltage(V)
Input Voltage(V)
5
12
24
48
3.3
5
12
15
±12
±15
B
B
B
B
A
A
A
B
A
A
A
B
A
A
A
B
A
A
A
B
A
A
A
B
Output Voltage(V)
Input Voltage(V)
5
12
24
48
40
60
(71)
80 (85)
100
3.3
5
12
15
±12
±15
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
A
A
A
B
A
A
A
B
100
100
A
Load Factor [%]
Load Factor [%]
¿ SUT3
B
50
C
-20
(55) 60
(71)
80 (85)
50
100
Output Voltage(V)
Input Voltage(V)
5
12
24
48
A
B
-20
60
80 (85)
100
3.3
5
12
15
±12
±15
A
A
A
B
A
A
A
B
B
B
B
B
B
B
B
B
A
A
A
A
B
B
B
C
Output Voltage(V)
Input Voltage(V)
5
12
24
48
¿ SUT6
3.3
5
12
15
±12
±15
A
A
A
A
B
A
A
A
B
A
B
A
B
A
A
A
B
A
A
A
B
B
B
B
100
100
A
Load Factor [%]
Load Factor [%]
A
B
B
50
-20
(55) 60
(71)
80
100
A
B
50
-20
Output Voltage(V)
Input Voltage(V)
5
12
24
48
60
(71)
80 (85)
100
3.3
5
12
15
±12
±15
B
B
B
B
B
B
B
B
B
B
B
A
B
B
B
A
B
B
B
A
B
B
B
A
Output Voltage(V)
Input Voltage(V)
5
12
24
48
January 31, 2022
3.3
5
12
15
±12
±15
B
B
B
B
B
B
B
B
B
A
A
A
B
A
A
A
B
A
A
A
B
A
A
A
SU.SUC/SUT-49
SU-SUC/SUT-series
Derating
¿ SUT10
100
B
Load Factor [%]
Load Factor [%]
100
A
C
50
-20
50 (55) 60
(71)
80
A
50
100
-20
Output Voltage(V)
Input Voltage(V)
5
12
24
48
60
(71)
80 (85)
100
3.3
5
12
15
±12
±15
C
B
C
C
C
A
C
C
A
A
C
C
A
A
C
C
C
B
C
C
C
A
B
C
Output Voltage(V)
Input Voltage(V)
5
12
24
48
3.3
5
12
15
±12
±15
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
Instruction Manual
◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product.
Instruction Manual
https://en.cosel.co.jp/product/powersupply/SUS/
Instruction Manual
https://en.cosel.co.jp/product/powersupply/SUW/
Instruction Manual
https://en.cosel.co.jp/product/powersupply/SUCS/
Instruction Manual
https://en.cosel.co.jp/product/powersupply/SUCW/
Instruction Manual
https://en.cosel.co.jp/product/powersupply/SUTS/
Instruction Manual
https://en.cosel.co.jp/product/powersupply/SUTW/
https://en.cosel.co.jp/technical/caution/index.html
SUS
SUCS
SUTS
SUW
SUCW
SUTW
NOTICE
Basic Characteristics Data
Model
Circuit method
Switching
frequency
[kHz]
Inrush
current
protection
Input current
[A]
(reference)
Series/Parallel
operation availability
PCB/Pattern
Single
sided
Material
Double Series Parallel
sided operation operation
SU/SUC1R5
Flyback converter
350 - 1900 Refer to Table1,2
glass fabric base,epoxy resin
Yes
Yes
*1
SU/SUC3
Flyback converter
200 - 1400 Refer to Table1,2
Yes
Yes
*1
SU/SUC6
Flyback converter
230 - 1950 Refer to Table1,2
Yes
Yes
*1
SU/SUC10
Flyback converter
250 - 300 Refer to Table1,2
Yes
Yes
*1
SUT3
Flyback converter
Yes
Yes
*1
SUT6
Flyback converter
Yes
Yes
*1
SUT10
Flyback converter
Yes
Yes
*1
*1 Refer to Instruction Manual.
* The value of input current is measured at rated input and load.
Table1 (SUS*** +5V output)
[A]
Input Voltage
Table2 (SUW*** t12V output)
[A]
Input Voltage
Output
Power
5V
12V
24V
48V
Output
Power
5V
12V
24V
48V
1.5W
0.41
0.16
0.08
0.04
1.5W
0.43
0.17
0.09
0.04
3W
0.78
0.32
0.16
0.08
3W
0.82
0.33
0.17
0.08
6W
1.32
0.62
0.31
0.15
6W
1.54
0.59
0.29
0.15
10W
2.41
0.98
0.49
0.25
10W
2.51
1.05
0.52
0.26
SU.SUC/SUT-50
January 31, 2022
