50-44SN-1
50-44SN-1
    CINCH
    插件,P=3.96mm
    3.96MM P数:44P
50-44SN-1 数据手册
Omega Catalog belfuse.com/cinch About Bel Bel is a publicly traded company that has been operated by the same family for over 65 years. Our history of organic growth and acquisitions have broadened our product portfolio. This has established Bel as a world leader with a diverse offering of power, protection and interconnect products. We design and manufacture these products which are primarily used in the networking, telecommunications, computing, military, aerospace, transportation and broadcasting industries. Bel’s portfolio of products also finds application in the automotive, medical and consumer electronics markets. About Omega The Omega product series consists of a family of connectors qualified to the MIL-C-26500 general purpose specification. The Omega line has been expanded to also include many qualified products to numerous Boeing BACC45/BACC63 connector specifications. Utilizing the MIL-C-26500 mating interface, Cinch has also designed a high performance series of connectors with attributes for shielding, environmental sealing, fluid resistance, and vibration - namely our CN0966/ CN0967/CN1020/CN1021/CN0909 connectors. Our CN0942/CN0944 fixed contact receptacle connectors are designed specifically for custom board mount, flex circuit, and soldered wire applications. These CN series of connectors are designed to meet all electrical and mechanical requirements of the MIL-C-26500 military specification. Table of Contents MIL-C-26500 C48 Series CN0966 Series Introduction 3 Self-Locking Plugs C48 Series Connectors CN0967 Series Ordering Information 4 Vibration-Resistant Receptacle Inserts Arrangement 5 Plug Connectors 6 Receptacle Connectors 7 9 CN1020 Series Vibration-Resistant Plug Connector 18 Vibration-Resistant Plug Receptacle 19 CN909A MMB Series CN0942/CN0944, C48 Series Connectors Vibration-Resistant Plug Connector Short Receptacle Connectors, Non-Removable Contacts 11 CN0942 Series: Fluorosilicone Inserts 12 C48 Series & C48 Family CN0944 Series: Fluorosilicone Inserts 13 Mounting Panel Data C48 Series Accessories Cable Support Assembly 17 CN1021 Series CN0915, C48 Series Connectors Limited Wiring Space Receptacle Connectors, Crimp Removal Tool 16 14 Contacts 15 20 21 MIL-C-26500 C48 SERIES Introduction The C48 Series describes a family of connectors qualified to MIL-C-26500. While maintaining the MIL-C-26500 mating interface, this product has also been expanded to include qualifications to numerous Boeing specifications to satisfy general purpose requirements and unique product challenges for shielding, environmental sealing, fluid resistance, and vibration. The expanded Cinch C48 product family offers numerous product options qualified to Boeing high-performance requirements and product solutions developed for alternate termination styles/low-profile packaging. • Qualified to MIL-C-26500 • Styles qualified to Boeing BACC45 Series • Styles qualified to Boeing BACC63 Series • Power contact sizes: 20, 16, and 12 • Coax contacts available: size 12 and 8 • Contacts: crimp - front release • Optional fixed contacts: PC termination • Coupling styles: bayonet and threaded • Environmentally sealed Materials Shell Aluminum, stainless-steel options available Finish Aluminum - anodize, optional electroless nickel / cadmium over nickel Rubber Silicone / fluorosilicone Dielectric Glass-filled epoxy Environmental Temperature Extremes +200ºC / 392ºF to -55ºC / -65ºF Ozone Resistance 0.015% by volume Temperature Life Internal 238ºC for 1,000 hours Moisture Resistance 1,000 megohms minimum / MIL-STD-202, Method 106 Thermal Shock -55ºC (-67ºC) to 260ºC (500ºF) Electrical Dielectric Strength 1,500 volts VAC RMS Current Rating (Test) Size 20 7.5 Amps D.C. Insulation Resistance 5,000 megohms minimum Size 16 13.0 Amps D.C. Size 12 23.0 Amps D.C. Mechanical Vibration Std - 20 g’s; 12 hours (Synasoidal) MMB / Self-lock - 39.6 g’s RMS, 48 hours (Random) 50 g’s Contact Retention Size 20 - 20 lb minimum Size 16 - 25 lb minimum Durability Threaded - 200 mating cycles Bayonet - 500 mating cycles O N M L K J I G H F E D C Size 12 - 30 lb minimum a. Positive Location Captivated Insert (Mechanical Interlock) b. Insert Face Seal c. Socket Contact, MIL-C-39029/32 d. Pressuring Seal Contact e. Anti-Deflection Disc f. Resilient Socket Insert g. Insert Rim Seal h. Dynamic “O” Ring Shell Seal i. Five-Key Shell Polarization j. Metal-to-Metal Shoulder k. Bayonet or Threaded Coupling, Permanent Captivation l. Contact Retention Clip m. Pin Contact, MIL-C-39029/31 n. Wire Sealing Risers A B o. Grommet 3 C48 Series Connectors Inserts Available C48 Series Ordering Information (Showing Front Face of Socket Inserts) C 4 8 - 0 6 R 2 2 - 5 5 P 6 - 10 2 Series Designation Coupling Style 0 = Threaded 1 = Bayonet Shell Size-10 Shell Size-8 (Y) (Y) Shell Size-12 Order Code (Deviations) 100 = Connector with contacts & cable support (Y) 102(Y)= Connector less cable support with contacts 105 = Connector less contacts with cable support 106 = Shell Connector less contacts & less cable support (Y) Shell Size-14 Size-16 *See order codes for Boeing on page 15 Shell Style 0 = Square flange receptacle 3 = Single-hole mounting receptacle 6 = Straight plug (Y) (Y) Shell Environmental Class Size-18 R = Meets MIL-C-26500 (USAF) Alternate Shell Positions 6, 7, 8, 9, 10, see page 4, Table 1 (Omit for normal position) (Y) Contact Style P = Pin S = Socket Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24 Insert Arrangements (Y) See page 5 Shell Size-20 MS24266 R 22 T 55 P 6 Military Designation MS24264 = Square-flange receptacle Shell MS24265 = Single-hole mounting receptacle Size-22 MS24266 = Straight plug (Y) (Y) (Y) Alternate Shell Positions (Y) N, 6, 7, 8, 9, Y, see page 4, Table 1 Contact Style P = Pin S = Socket Environmental Class R = Meets MIL-C-26500 (USAF) Insert Arrangements (Y) See page 5 (Y) Shell Size 8, 10, 12, 14, 16, 18, 20, 22, orShell 24 Coupling Style Size-24 T = Threaded B = Bayonet (Y) Table 1 - Alternate Shell Positions (Y) (Y) Shell Keying (Front face ofShell receptacle shown) Size-28 Alternate position 6 through Y incorporate special shell polarizing key and keyways. All inserts remain in the normal posiiton. CN096X Connecetor CN102X Size 8 and 10 Alternate Shell Positions face16, of receptacle shown) Connecetor Size(Front 12, 14, 18, 20, 22, 24 and 28 Position A Series BOnly Normal (N) 105º 140º 215º 140º 6 102º 132º 248º 275º 7 80º 118º 230º 140º 8 35º contact is interchangeable 140º† = #1 shielded 205º 275º 9 64º in Boeing Insert140º Style. 155º(Y) = Available 234º 10 or Y* 25º 115º C D with #12 power contact. 220º 275º *Not available in Size 8 Connectors. See indivdual part number systems. NOTE: Alternate positions 6 through Y incorporate special shell polarizing A All inserts remain B in the normal C position. D key and keyways. 105º Positions Normal (N) 6 7 8 9 10 or Y* 140º 215º 265º For Connector Size For Connector Size 8 and 10 12, 14, 16, 18, 20, 22, 24, and 28 A 18º B C 149º D A 192ºB C 259º D 105° 140° 215° 265° 105° 140° 215° 265° 102°92º 132° 248° 152º 320° 18° 222º 149° 192°342º 259° 80° 118° 230° 312° 92° 152° 222° 342° 35°84º 140° 205° 152º 275° 84° 204º 152° 204°342º 334° 64° 155° 234° 304° 24° 135° 199° 240° 25°24º 115° 220° 135º 270° 98° 199º 152° 268°334º 338° *Not available in Size 8 Connector. See individual part number systems. 98º 152º 3-4 268º 338º Call Toll Free: 1 (800) 323-9612 Military Stand Part Numbers You can use MS* as well as C48 Series part numbers when ordering C48 Series connects. *MS part numbers are supplied less cable support. If cable support is desired, it must be ordered separately. 4 3 C48 Series Connectors Inserts Available C48 Series (Showing Front Face of Socket Inserts) Insert Arrangement Showing Front Face of Socket Inserts (Y) 2#20 contacts ShellInsert 8-2(Y) Size-14 Shell Size-12Shell Size 12 ShellShell Size 10 Size-10 Shell Size 8 Shell Size-8 (Y) 2#20 contacts Insert 10-2(Y) 3#20 contacts Insert 8-3(Y) (Y) (Y) (Y) 2#16 contacts Insert 10-20 5#20 contacts Insert 10-5(Y) Shell Size 14 Shell Size-16 3#16 contacts Insert 12-3 Shell Size 16 (Y) (Y) 12#20 contacts Insert 12-12(Y) (Y) Shell Size-18 2#16 contacts 1#2 shielded contact Insert 14-3 4#12 contacts Insert 14-4† 7#16 contacts Insert 14-7 9#20 contacts 3#16 contact Insert 14-12(Y) 15#20 contacts Insert 14-15(Y) 10#16 contacts Insert 16-10 24#20 contacts Insert 16-24(Y) (Y) Shell Size 18 3 Shell Size-20 8#12 contacts Insert 18-8† 10#16 contacts 1#2 shielded contact Insert 18-11 14#16 contacts Insert 18-14 (Y) (Y) 31#20 contacts Insert 18-31(Y) (Y) (Y) Shell Size 20 Shell Size-22 16#16 contacts Insert 20-16 19#20 contacts 6#12 contacts Insert 20-25†(Y) 24#20 contacts 4#12 contacts Insert 20-28†(Y) 37#20 contacts 2#16 contacts Insert 20-39†(Y) (Y) (Y) 41#20 contacts Insert 20-41(Y) Shell Size-24 Shell Size 22 Shell Size-28 12#12 contacts Insert 22-12† (Y) (Y) 19#16 contacts Insert 22-19 (Y) 26#20 contacts 6#12 contacts Insert 22-32†(Y) 55#20 contacts Insert 22-55(Y) Shell Size 28 Shell Size 24 CN096X CN102X Series Only 27#20 contacts 12#16 contacts Insert 22-39(Y) Alternate Shell Positions (Front face of receptacle shown) NOTE: Alternate positions 6 through Y incorporate special shell polarizing key and keyways. All inserts remain in the normal position. For Connector Size For Connector Size 8 and 10 12, 14, 16, 18, 20, 22, 24, and 28 23#20 contacts 2#12 contacts Positions A61#20 contacts B C D 29#16 contacts A B C30#16 contacts D 20#16 contacts 55#20 contacts Insert 24-61(Y) 24-29 140° 24-30 Normal (N) 105° 140° 215° 265° Insert105° 215°Insert265° Insert 24-43(Y) Insert 24-57†(Y) 6 102° 132° 248° 320° 18° 149° 192° 259° 7 80° 118° 230° 312° 92° 152° 222° 342° † = #1 shielded contact is interchangeable 8 35° 140° 205° 275° 84° 152° 204° 334° with #12 power contact. 9 64° 155° 234° 304° 24° 135° 199° 240° (Y) = Available in Boeing Insert Style. 10 or Y* 25° 115° 220° 270° 98° 152° 268° 42#16 contacts Insert 28-42 338° *Not available in Size 8 Connector. See individual part number systems. Call Toll Free: 1 (800) 323-9612 5 C48 Series Connectors C48 Series Plug Connectors C48 PlugSeries Connectors Plug Connectors Threaded Coupling Threaded Couplings C48-06RXX-XXXX C48-06RXX-XXXX MS24266RXXTXXXX 1 MS24266RXXTXXXX Threaded Coupling BACC45FS BACC45FS1 C48-06RXX-XXXX MS24266RXXTXXXX BACC45FS1 3 3 1.345 (34.164) Max. 1.345 (34.164) Max. Bayonet Coupling Bayonet Coupling C48-16RXX-XXXX C48-16RXX-XXXX MS24266RXXBXXXX MS24266RXXBXXXX BACC45FT1 1 Bayonet Coupling BACC45FT C48-16RXX-XXXX MS24266RXXBXXXX BACC45FT1 Shell Size 8 Dimensions 10 1.345 (34.164) Max. 1.345 (34.164) Max. A Diameter B Diameter C Maximum in mm in mm in mm UNEF-2A 0.328 8.331 0.437 11.100 0.776 19.712 0.437-28 0.420 10.668 0.562 14.275 0.906 23.013 0.562-24 14.732 B. Dia. 0.750 C. Max. 19.050 in mm 0.812 20.625 .776 19.712 .906 23.013 0.938 23.825 C. Max. 1.078 27.381 in mm26.975 1.062 1.141 28.982 .776 19.712 1.266 32.157 1.182 30.023 .906 23.013 1.375 34.925 1.078 27.381 1.312 33.325 1.510 38.354 1.141 28.982 1.625 41.275 1.266 32.157 1.432 36.373 1.760 44.704 1.375 34.925 1.510 38.354 1.625 41.275 1.760 44.704 1.078 D. Thread UNEF-2A 1.141 .437-28 .562-241.266 D. Thread .750-20 UNEF-2A .812-201.375 .437-28 .937-20 .562-241.510 1.062-18 .750-20 1.187-181.625 .812-20 1.312-18 .937-201.760 1.437-18 1.062-18 1.187-18 1.312-18 1.437-18 27.381 0.750-20 28.982 0.812-20 32.157 0.937-20 34.925 1.062-18 38.354 1.187-18 41.275 1.312-18 44.704 1.437-18 12 Shell A.0.580 Dia. Size in mm Dimensions 14 0.664 8 .328 8.331 10 .420 0.769 10.668 16 Shell A. Dia. 12 .580 14.732 Size in 0.902 mm 18 14 .664 16.866 8 .328 8.331 16 .769 1.033 19.533 20 10 .420 10.668 18 .902 22.911 12 .580 14.732 22 20 1.033 1.152 26.238 14 .664 16.866 22 1.152 29.261 16 .769 1.282 19.533 24 24 1.282 32.253 18 .902 22.911 20 1.033 26.238 22 1.152 29.261 24 1.282 32.253 in mm 16.866 .437 11.100 .562 19.533 14.275 B. Dia. .750 19.050 in mm 22.911 .812 20.625 .437 11.100 .938 23.825 26.238 14.275 .562 1.062 26.975 .750 19.050 29.261 30.023 1.182 .812 20.625 1.312 33.325 .938 32.253 23.825 1.432 36.373 1.062 26.975 1.182 30.023 1.312 33.325 1.432 36.373 1 1Boeing see page 15 Boeingspecifications, Specifications, see page 3-14. 6 Call Toll Free: see 1 (800) Boeing Specifications, page323-9612 3-14. 1 D Thread 3-5 C48 Series Connectors C48 Series Receptacle C48 Series Connectors Receptacle Connectors Receptacle Connectors Square Flange, Threaded Coupling Square Flange, C48-OORXX-XXXX Threaded Coupling Square Flange, MS24264RXXTXXX C48-OORXX-XXXX Threaded1 Coupling MS24264RXXTXXX BACC45FM 1.407 (35.738) Max. 1.407 (35.738) Max. 1 C48-OORXX-XXXX BACC45FM MS24264RXXTXXX BACC45FM1 Square Flange, Bayonet Coupling C48-1ORXX-XXXX Square Flange, MS24264RXXBXXX Bayonet Coupling 1 BACC45FN Square Flange, C48-1ORXX-XXXX Bayonet Coupling MS24264RXXBXXX 1 C48-1ORXX-XXXX BACC45FN MS24264RXXBXXX BACC45FN1 Shell Size A ±0.005 (0.127) 3 3 1.407 (35.738) Max. 1.407 (35.738) Max. B ±0.005 (0.127) F Maximum G Thread H Thread J Minimum K Minimum in mm in in mm UNEF-2A UNEF-2A in in mm mm 8 0.812 20.625 0.594 15.088 0.125 3.175 0.561 14.250 0.437 11.100 0.562-24 0.437-28 0.620 15.748. 0.447 11.35 10 0.937 23.800 0.719 18.263 0.125 3.175 0.696 17.679 0.562 14.275 0.687-24 0.562-24 0.748 18.999 0.572 14.52 12 1.031 26.188 0.812 20.625 0.125 3.175 0.875 22.225 0.750 19.050 0.875-20 0.750-20 0.913 23.190 0.760 19.30 Dimensions A mm D Maximum in Dimensions in C Maximum Diameter B C 14 1.125 28.575 0.906 23.013 0.125 3.175 +.005 (.127) Max. Dia. Shell +.005 (.127) 16 1.250 A31.750 0.969 24.613 0.125 B Size in mm in mm in C3.175 mm Shell +.005 (.127) .594 +.00515.088 (.127) .125 Max.3.175 Dia. 8 .812 20.625 18 1.343 34.112 1.062 26.975 0.125 3.175 Size .937 in 23.800 mm in 18.263 mm .125 in 3.175 mm 10 .719 20 1.437 36.500 1.156 29.363 0.125 3.175 8 .812 20.625 .594 15.088 .125 3.175 12 1.031 26.188 .812 20.625 .125 3.175 10 .937 23.800 .719 31.750 18.263 0.125 .125 3.175 3.175 14 1.125 .906 .125 22 1.562 28.575 39.675 1.250 23.013 3.175 12 1.031 26.188 .812 20.625 .125 3.175 16 1.250 31.750 .969 24.613 .125 3.175 24 1.703 28.575 43.256 1.375 34.925 0.154 3.912 14 1.125 .906 23.013 .125 3.175 18 1.343 34.112 1.062 26.975 .125 3.175 16 1.250 31.750 .969 24.613 .125 3.175 20 1.437 36.500 1.156 29.363 .125 3.175 18 1.343 39.675 34.112 1.250 1.062 31.750 26.975 .125 .125 3.175 3.175 22 1.562 20 1.437 43.256 36.500 1.375 1.156 34.925 29.363 .154 .125 3.912 3.175 24 1.703 22 specifications, 1.562 39.675 31.750 .125 3.175 1Boeing see page1.250 15 1 1.703 43.256 1.375 34.925 =24Boeing specifications, see page 3-14. .154 3.912 1 = Boeing specifications, see page 3-14. mm mm D F G H J 0.935 23.749 0.812 20.625 0.937-20 0.812-20 0.980 24.892 Max. Max. Thread Thread Min. 1.062 1.062-18 0.937-20 1.107 D mm 0.938 F mm G H J mm in 26.975 in 23.825 UNEF-2A UNEF-2A in 28.119 Max. Max. Thread .437-28 Thread .620 Min. .561 14.250 .437 11.100 .562-24 15.748 1.187 30.150 1.062 26.975 1.187-18 1.062-18 1.209 30.709 in 17.679 mm .562 in 14.275 mm UNEF-2A UNEF-2A .748 in 18.999 mm .696 .687-24 .562-24 1.312 33.325 1.182 30.023 1.312-18 1.187.18 1.337 33.960 .561 14.250 .437 11.100 .562-24 .437-28 .620 15.748 .875 22.225 .750 19.050 .875-20 .750-20 .913 23.190 .69636.500 17.679 1.312 .56233.325 14.275 1.437-18 .687-24 1.312.18 .562-24 1.452 .74836.881 18.999 .935 23.749 .812 20.625 .937-20 .812-20 .980 24.892 1.437 .875 22.225 .750 19.050 .875-20 .750-20 .913 23.190 1.062 26.975 .938 23.825 1.062-18 .937-20 1.107 28.119 1.562 39.675 1.432 36.373 1.562-18 1.437.18 1.577 40.056 .935 23.749 .812 20.625 .937-20 .812-20 .980 24.892 1.187 30.150 1.062 26.975 1.187-18 1.062-18 1.209 30.709 1.062 26.975 .938 23.825 1.062-18 .937-20 1.107 28.119 1.312 33.325 1.182 30.023 1.312-18 1.187-18 1.337 33.960 1.187 36.500 30.150 1.312 1.062 33.325 26.975 1.437-18 1.187-18 1.312-18 1.062-18 1.452 1.209 36.881 30.709 1.437 1.312 39.675 33.325 1.432 1.182 36.373 30.023 1.562-18 1.312-18 1.437-18 1.187-18 1.577 1.337 40.056 33.960 1.562 1.437 36.500 1.312 33.325 1.437-18 1.312-18 1.452 36.881 1.562 39.675 1.432 36.373 1.562-18 1.437-18 1.577 40.056 K 0.822 20.87 Min. 0.948 in K24.07 mm Min. .447 11.354 1.072 27.22 in 14.529 mm .572 1.192 30.27 .447 11.354 .760 19.304 .572 20.879 14.529 .822 1.322 33.57 .760 19.304 .948 24.079 1.442 36.62 .822 20.879 1.072 27.229 .948 24.079 1.192 30.277 1.072 33.579 27.229 1.322 1.192 36.627 30.277 1.442 1.322 33.579 1.442 36.627 7 C48 Series Connectors C48 Series Receptacle Connectors C48 Series Receptacle Connectors Single-Hole Mount, Threaded Coupling Single-Hole Mount, Threaded C48-03RXX-XXXX Single-Hole Mount, MS24265RXXTXXX C48-03RXX-XXXX Threaded Coupling MS24265RXXTXXX C48-03RXX-XXXX Coupling 1.407 (35.738) Max. 1.407 (35.738) Max. MS24265RXXTXXX Single-Hole Mount, Bayonet Coupling 33 C48-13RXX-XXXX Single-Hole Mount, MS24265RXXBXXX Bayonet Coupling Single-Hole Mount, C48-13RXX-XXXX Bayonet Coupling MS24265RXXBXXX C48-13RXX-XXXX MS24265RXXBXXX Shell Size 10 12 14 16 1.407 (35.738) Max. A B Dimensions ±0.005 (0.127) Maximum Dimensions Hex mm A in 8 1.407 (35.738) Max. A in (.127) ShellShell +.005 0.979 24.867 0.828 (.127) +.005 mm B B C ±0.003 (0.076) in CCmm Max. Hex +.003 (.076) 21.031 15.062 Max. Hex0.593 +.003 (.076) D Maximum E Maximum Diameter G Maximum H Thread in D D in E UNEF-2A GG UNEF-2A H H mm mm E Max. 1.068 Max. 27.127 J Thread K Thread UNEF-2A UNEF-2A J K K J Max. Dia.14.249 Max. Max. Thread Thread Thread Thread Thread 0.561 0.437 Thread 0.562-24 0.625-20* 0.437-28 Max. Dia. Size Size in in mmmm in in mm inin mm in mm mm UNEF-2AUNEF-2A UNEF-2A UNEF-2A mm mm in mm inin mm in in mmmm UNEF-2A UNEF-2A 1.104 28.042 0.953 24.206 0.718 18.237 1.192 30.277 0.696 17.678 0.562 0.687-24 0.750-20 0.562-24 8 8 .979.979 24.867 21.031 27.127 .561 .561 14.249 14.249 .437 .43711.100 11.100 .562-24 .562-24 .625-20* .625-20* .437-28 24.867 .828 .828 21.031 .593 .593 15.062 15.062 1.068 1.068 27.127 .437-28 1.291 1.140 28.956 0.905 35.052 .696 0.875 22.225 0.750 0.875-20 0.937-20 0.750-20 1.104 28.042 .953 .953 24.206 .71822.987 18.237 1.380 1.192 30.277 17.678 .562 10 1032.791 1.104 28.042 24.206 .718 18.237 1.192 30.277 .696 17.678 .56214.275 14.275 .687-24 .687-24 .750-20 .750-20.562-24 .562-24 1.291 32.791 1.140 28.956 .905 .905 22.987 22.987 1.380 1.380 12 1235.331 1.291 32.791 28.956 1.391 1.250 1.140 31.750 0.968 24.587 1.505 1.391 35.3311.250 1.250 31.750 .968 .968 24.587 24.587 1.505 1.505 14 14 1.391 35.331 31.750 1.516 1638.506 1.329 33.757 1.0931.09327.762 1.630 1.516 38.506 1.329 33.757 27.762 1.630 16 1.516 38.506 1.329 33.757 1.093 27.762 1.630 18 1.641 41.681 1.455 36.957 1.217 30.912 20 1.766 44.856 1.642 41.707 1.342 34.087 24 2.079 52.807 1.892 48.057 1.592 40.437 1.641 41.681 36.9571.217 1.217 30.912 30.912 41.681 1.455 1.455 36.957 1.740 35.052 35.052 .750 19.050 19.050 .875-20 .875-20 .937-20 .937-20.750-20 .750-20 23.749 .750 0.812 0.937-20 1.000-20 0.812-20 .812 .81220.625 20.625 .937-20 .937-20 1.000-20 1.000-20.812-20 .812-20 41.402 1.062 26.975 0.938 1.062-18 1.062-18 1.125-20*.937-20 0.937-20 41.402 41.402 1.062 1.062 26.975 26.975 .938 .93823.825 23.825 1.062-18 1.125-20* 1.125-20* .937-20 38.227 38.227 38.227 .875 .875 22.225 22.225 0.935 .935 .935 23.749 23.749 44.196 1.187 30.150 1.062 26.975 1.187-18 1.250-20* 1.062-18 1.860 47.244 1.312 33.325 1.182 30.023 1.312-18 1.375-18 1.187-18 2.160 54.864 1.562 39.675 1.432 36.373 1.562-18 1.625-18 1.437-18 18 18 1.641 20 20 1.766 44.856 1.642 41.707 1.342 34.087 1.860 47.244 1.312 33.325 1.182 30.023 1.312-18 1.375-18 1.187-18 1.766 2244.856 1.3421.46734.087 47.244 1.437 1.312 33.325 1.182 1.437-18 1.312-18 1.500-20* 1.375-18 1.187-18 1.954 1.642 49.632 41.707 1.705 43.307 37.262 1.860 2.040 51.816 36.500 1.312 33.325 1.312-18 22 1.954 49.632 1.705 43.307 1.467 37.262 2.040 51.816 1.437 36.500 1.312 33.325 1.437-18 1.500-20* 1.312-18 22 1.954 24 49.632 1.705 1.892 43.307 2.079 52.807 48.0571.467 1.592 37.262 40.437 * Thread: UN-2A 1.740 1.740 2.040 2.160 44.196 1.062 1.062 26.975 44.196 1.187 1.18730.150 30.150 51.816 1.562 1.43739.675 36.500 54.864 1.432 1.312 36.373 * Thread: UN-2A 2.079 NOTES: 52.807 1.892 48.057 1.592 40.437 2.160 54.864 Contact factory for information about Boeing specifications. NOTES: For mounting dimensions and Boeing jam nut specifications. torques, see page 3-20. Contact factory forhole information about * Thread: UN-2A For mounting hole dimensions and jam nut torques, see page 3-20. 24 Call Toll Free: 1 (800) 323-9612 NOTES: NOTES: Call TollBoeing Free:specifications. 1 (800) 323-9612 Contact factory for information about For mounting hole dimensions and jam nut torques, see page 21. 8 3-7 1.562 3-7 39.675 1.432 1.187-18 1.187-18 1.437-18 1.562-18 1.562-18 1.250-20* 1.250-20* 1.062-18 1.062-18 1.500-20* 1.625-18 1.312-18 1.437-18 1.625-18 1.437-18 CN0915, C48 Series Connectors C48/CN0915 Series Receptacle Connecters, Limited Wiring Space Wiring Space Receptacle Connectors CrimpLimited Removal Contacts Crimp Removal Contacts C48/CN0915 Series Limited Wiring Space Receptacle Connectors Square-Flange, Threaded Contacts Coupling Crimp Removal Square-Flange, Threaded Coupling CN0915B-XXXXXXX-XXX CN0915B-XXXXXXX-XXX Square-Flange, Threaded Coupling CN0915B-XXXXXXX-XXX Square-Flange, Bayonet Coupling Square-Flange, Bayonet Coupling CN0915A-XXXXXXX-XXX CN0915A-XXXXXXX-XXX Square-Flange, Bayonet Coupling CN0915A-XXXXXXX-XXX 3 3 Dimensions Shell Size 8 10 12 14 16 18 20 22 24 A B C D F G Shell +.0045 (.114) +.005 (.127) +.004 (.102) Max. +.0015 (.038) Thread Dimensions Size in mm in mm in mm in mm in mm UNEF-2A 8 .812 20.625 .594 15.088 .121 3.073 .561 14.250 .497 12.624 .562-24 A BB C D F A 23.800 C3.073 G 10 .937 .719 (0.127) 18.263 .121 .696 D17.679 .503 F15.799±0.0015 .687-24 ±0.0045 (0.114) ±0.005 ±0.004 (0.102) Maximum (0.038) Shell +.0045 (.114) +.005 (.127) +.004 (.102) Max. +.0015 (.038) Thread 12in 1.031 .121in 3.073mm .875 22.225 .745 18.923 in .875-20 mm 26.187 in.812 20.625 mm in mm mm Size in mm in mm in mm in mm in mm UNEF-2A 14 1.125 28.575 .906 23.012 .121 3.073 .935 23.749 .871 22.123 .937-20 0.812 20.62520.625 0.594 0.1213.0733.073 .561 14.250 0.561 14.250 12.624 8 .812 .594 15.088 .121 .497 .562-24 16 1.150 29.210 .969 15.088 24.613 .121 3.073 1.062 26.975 .995 12.624 25.2730.497 1.062-18 10 .937 23.800 .719 18.263 .121 3.073 .696 17.679 .503 15.799 .687-24 18 1.343 35.382 1.062 26.975 .121 3.073 1.187 30.150 1.058 26.873 1.187-18 0.937 1.031 23.800 0.719 0.121 3.073 .875 22.225 0.696 17.679 0.503.875-20 15.799 12 .812 18.263 20.625 .121 .745 18.923 20 1.437 26.187 36.500 1.156 29.362 .121 3.073 3.073 1.312 33.325 1.184 30.074 1.312-18 14 1.125 28.575 .906 23.012 .121 3.073 .935 23.749 .871 22.123 .937-20 22 1.250 20.625 31.750 .121 1.307 33.1980.745 1.437-18 1.031 1.562 26.18739.675 0.812 0.1213.0733.073 1.437 36.500 0.875 22.225 18.923 16 1.150 .969 24.613 .121 1.062 .995 25.273 24 1.703 29.210 43.256 1.375 34.925 .154 3.073 3.912 1.562 26.975 39.675 1.432 36.373 1.062-18 1.562-18 18 1.343 35.382 1.062 26.975 .121 3.073 1.187 30.150 1.058 26.873 1.187-18 1.125 28.575 0.906 23.012 0.121 3.073 0.935 23.749 0.871 22.123 20 1.437 36.500 1.156 29.362 .121 3.073 1.312 33.325 1.184 30.074 1.312-18 1 1 A 10 A 050.995 P 1.437-18 N - 25.273 000 22 39.675 0.969 1.250 Ordering 31.750 Information .121 36.500 1.307 33.198 Ordering Information 1.150 1.562 29.210 24.613 0.1213.0733.073 1.437 CN0915 1.062 26.975 24 1.703 43.256 1.375 34.925 .154 3.912 1.562 39.675 1.432 36.373 1.562-18 Order Code Series Designation 1.343 1.062 1 Ordering Information1.156 1.437 36.500 1.562 1.703 NOTES: NOTES:: NOTES 35.382 39.675 43.256 1.250 1.375 26.975 CN0915 0.121 3.073 1 Series Modification Ordering Information 29.362 0.121 3.073 A - Bayonet Coupling B - Threaded Coupling Series Designation 31.750 0.121 3.073 CN0915 Shell Size 8, 10, 12, 14, 16, 18, 20, 22, & 24 Series Modification 34.925 0.154 3.912 A - Bayonet Coupling Environmental Class B - Threaded Coupling A - Anodized Aluminum N - Electroless Nickel-Plated Aluminum Shell Size S -10, Stainless 8, 12, 14, Steel 16, 18, 20, 22, & 24 1 For other modifications, classes, etc.,Environmental contact factory. Class • For mounting see page 3-20. Aluminum A - Anodized 1 For other modifications, classes,hole etc.,dimensions, contact factory - Electroless Nickel-Plated Aluminum •hole Uses CRIM-LOK • For mounting NOTES: dimensions, see contacts. page 21 See pageN3-12. S -rhodium Stainless Steel * Former code13- 100 designated plated contacts • Uses CRIM-LOK contacts.order See page 1 For other modifications, classes, etc., contact factory. 3-8 • For mounting hole dimensions, see page 3-20. • Uses CRIM-LOK contacts. See page 3-12. * Former order code - 100 designated rhodium plated contacts 1.187 30.150 1.058 36.500 1.307 1.562 39.675 1.432 0.562-24 0.687-24 0.875-20 0.937-20 1.062-18 26.873000 - Less Contacts 1.187-18 200 - Gold-Plated Contacts CN0915 A 10 A 051.184 P N - 30.074 000 * See below 1.312 33.325 1.437 G Thread UNEF-2A 1.312-18 Order Code Shell Position 33.198000 1.437-18 Less Contacts N, 6,- 7, 8, 9, 10 (See page 3-4) 200 Gold-Plated Contacts Contact Style * See below 36.373P - Pin 1.562-18 S - Socket Shell Position Insert N, 6, 7,Arrangement 8, 9, 10 (See page 3-4) (See page 3-4) Contact Style P - Pin S - Socket Insert Arrangement (See page 3-4) Call Toll Free: 1 (800) 323-9612 9 CN0915, C48 Series Connectors Ordering Information C N 0 915 A 10 A 0 5 P N - 0 0 0 Series Designation CN0915 Series Modification A = Bayonet coupling B = Threaded coupling Shell Size 8, 10, 12, 14, 16, 18, 20, 22, or 24 Environmental Class A = Anodized aluminum N = Electroless nickel-plated aluminum S = Stainless steel NOTES: NOTES: 1 For other modifications, classes, etc., contact factory • For mounting hole dimensions, dimensions, see page 21 • Uses CRIM-LOK contacts. See page 13 * Former order code - 100 designated rhodium plated contacts 10 Order Code 000 = Less contacts 200 = Gold-plated contacts Shell Position N, 6, 7, 8, 9, 10, see page 4, Table 1 Contact Style P = Pin S = Socket Insert Arrangement See page 5 CN0942/CN0944, C48 Series Connectors CN0942/CN0944 Series (C48 Family) Short Receptacle Connectors, Short Receptacle Connectors CN0942/CN0944 Series (C48 Family) Non-Removable Contacts Non-Removable Short ReceptacleContacts Connectors Non-Removable Contacts Single-Hole Mount, Bayonet Coupling Single-Hole Mount, CN0942D XXXXXXXXX Bayonet Coupling Single-Hole Mount, CN0944D XXXXXXXXX CN0942D XXXXXXXXX Bayonet CN0944DCoupling XXXXXXXXX CN0942D XXXXXXXXX CN0944D XXXXXXXXX S** S** T** T** Square Flange, Bayonet Coupling 3 3 Square Flange, CN0942B XXXXXXXXX Bayonet Coupling CN0944B XXXXXXXXX Square Flange, CN0942B XXXXXXXXX Bayonet Coupling CN0944B XXXXXXXXX CN0942B XXXXXXXXX CN0944B XXXXXXXXX S* S* T* T* Shell Size A Maximum in mm Dimensions 8 10 12 14 16 18 20 22 24 0.984 24.994 A Dimensions Shell1.109 Max. 28.169 Size in A mm 1.296 32.919 8 .984Max. 24.994 Shell 10 1.396 1.109 28.169 Size in 35.459 mm 12 32.919 8 1.296 .984 24.994 1.521 38.634 14 10 1.396 1.109 35.459 28.169 16 1.521 38.634 12 1.646 1.296 41.809 32.919 18 1.646 41.809 14 1.771 1.396 44.984 35.459 20 16 1.771 1.521 44.984 38.634 22 1.959 49.759 18 1.959 1.646 49.759 41.809 24 2.084 52.934 20 2.084 1.771 52.934 44.984 22 1.959 49.759 24 2.084 52.934 B Maximum C Maximum D Maximum in mm in mm in mm UNEF-2A in mm in mm in mm 0.828 21.031 1.068 27.127 0.561 14.250 0.625-20* 0.812 20.625 0.594 15.088 0.593 15.062 B 0.953 Max. 24.206 in B mm 1.140 28.956 .828Max. 21.031 .953 24.206 in mm 1.250 31.750 1.140 28.956 .828 21.031 1.329 33.757 1.250 31.750 .953 24.206 1.455 1.329 33.757 1.140 36.957 28.956 1.455 36.957 1.250 31.750 1.642 41.707 1.642 1.329 41.707 33.757 1.705 1.705 43.307 1.455 43.307 36.957 1.892 48.057 1.642 48.057 41.707 1.892 1.705 43.307 1.892 48.057 C 1.192Max. 30.277 in C mm 1.380 35.052 1.068 27.127 Max. 1.192 30.277 in mm 1.505 38.227 1.380 27.127 35.052 1.068 1.630 41.402 1.505 30.277 38.227 1.192 1.740 44.196 1.630 1.380 41.402 35.052 1.740 44.196 1.505 38.227 1.860 47.244 1.860 1.630 47.244 41.402 2.040 51.816 2.040 1.740 51.816 44.196 2.160 54.864 1.860 47.244 2.160 54.864 2.040 51.816 2.160 54.864 D 0.696 Max. 17.679 in D mm 0.875 22.225 .561Max. 14.250 .696 17.679 in mm 0.935 23.749 .875 14.250 22.225 .561 1.062 26.975 .935 17.679 23.749 .696 1.187 1.062 26.975 .875 30.150 22.225 1.187 30.150 .935 23.749 1.312 33.325 1.312 1.062 33.325 26.975 1.437 1.437 36.500 1.187 36.500 30.150 1.562 39.675 1.312 39.675 33.325 1.562 1.437 36.500 1.562 39.675 F Thread J ±0.005 (0.127) K ±0.005 (0.127) L ±0.003 (0.076) F J K L (.127) 0.719+.005 (.127) 0.718 +.00318.237 (.176) Thread 0.937+.005 0.750-20 23.800 18.263 UNEF-2A in J mm in K mm in L mm F 0.937-20 1.031 26.188 0.812 20.625 0.905 22.987 .625-20* .812 20.625 .594 (.127) 15.088 +.003 .593 (.176) 15.062 (.127) +.005 Thread +.005 .750-20 .937 23.800 .719 18.263 .718 18.237 UNEF-2A in mm in mm in mm 1.000-20 1.125 28.575 0.906 23.013 0.968 24.587 .937-20 1.031 26.188 .812 15.088 20.625 .593 .905 15.062 22.987 .625-20* .812 20.625 .594 1.125-20* 1.250 31.750 0.969 24.613 1.093 27.762 1.000-20 1.125 28.575 .906 18.263 23.013 .718 .968 18.237 24.587 .750-20 .937 23.800 .719 1.250-20* 26.975 1.125-20* 1.25034.112 31.7501.062.812 .969 24.6131.217 1.093 27.762 .937-20 1.343 1.031 26.188 20.625 .90530.912 22.987 1.250-20* 1.343 34.112 1.062 26.975 1.217 30.912 1.000-20 1.125 28.575 .906 23.013 .968 24.587 1.375-18 1.437 36.500 1.156 29.363 1.342 34.087 1.375-18 29.363 1.342 1.125-20* 1.437 1.250 36.500 31.750 1.156 .969 24.613 1.093 34.087 27.762 1.500-20* 31.750 1.500-20* 1.562 39.675 1.250 31.750 1.467 37.262 1.250-20*1.562 1.34339.675 34.1121.250 1.062 26.9751.467 1.21737.262 30.912 1.625-18 1.703 43.256 1.375 34.925 1.592 40.437 1.375-18 1.437 36.500 1.156 29.363 1.342 34.087 1.625-18 1.703 43.256 1.375 34.925 1.592 40.437 1.500-20* 1.562 39.675 1.250 31.750 1.467 37.262 1.625-18 1.703 43.256 1.375 34.925 1.592 40.437 * Th’d: UN-2A ** See “S” and “T” dimensions on page 3-10. * Th’d: UN-2A * Th’d: UN-2A ** See “S”**and “T”“S” dimensions on page 11 on page 3-10. See and “T” dimensions Call Toll Free: 1 (800) 323-9612 3-9 11 CN0942/CN0944, C48 Series Connectors CN0942 Series: Fluorosilicone Inserts Ordering Information C N 0 9 4 2 B 10 J 05 P N 01 Termination See table Series Designation Series Modification B = Square-flange mount bayonet coupled C = Square-flange mount thread coupled D = Single-hole mount bayonet coupled E = Single-hole mount thread coupled Shell Size 8, 10, 12, 14, 16, 18, 20, 22, or 24 Class G = Cadmium/nickel finish J = Anodized finish N = Electroless nickel finish Shell Position N, 6, 7, 8, 9, Y, see page 4, Table 1 Contact Style Solder pin terminal P = Pin S = Socket Solder cup terminal X = Pin Y = Socket Wire wrap terminal T = Pin W = Socket Insert Arrangements See page 5 Fluorosilicone Inserts Table 2 - CN0942 Series: Fluorosilicone Inserts Termination Designator Contact Style Termination T Minimum S ±0.002 01* P&S 0.250 0.025 02* X&Y 0.230 N/A 03** P&S 0.144 0.025 04** X&Y 0.124 N/A 06* T&W 0.900 0.025 * Applies to CN0942B/CN0942C ** Applies to CN0942D/CN0942E NOTES: 1 For other modifications, class, etc., consult factory. For mounting hole dimensions, see page 21. 12 CN0942/CN0944, C48 Series Connectors CN0944 Series: Neoprene Inserts Ordering Information C N 0 9 4 4 B 10 R 05 P N C 01 Termination See page 13, table 3 Series Designation Series Modification B = Square-flange mount bayonet coupled C = Square-flange mount thread coupled D = Single-hole mount bayonet coupled E = Single-hole mount thread coupled Termination Type B = Solder pin C = Solder cup W = Wire wrap Shell Size 8, 10, 12, 14, 16, 18, 20, 22, or 24 Shell Position N, 6, 7, 8, 9, Y, see page 4, Table 1 Class G = Cadmium/nickel finish N = Electroless nickel finish R = Anodized finish Contact Style P = Pin S = Socket Insert Arrangements See page 5 Neoprene Inserts Table 3 - CN0942 Series: Neoprene Inserts Termination Designator Termination Type Termination T Minimum S ±0.002 01* B 0.250 0.025 02* C 0.230 N/A 03** B 0.144 0.025 04** C 0.124 N/A 06* W 0.900 0.025 * Applies to CN0944B/CN0944C ** Applies to CN0944D/CN0944E NOTES: 1 For other modifications, class, etc., consult factory. For mounting hole dimensions, see page 21. 13 C48 Series Accessories Cable Support Assembly C48 Series Accessories Cable clamps support cable or wire at the plug or receptacle and prevent twisting and pulling. For use on C48 Series connectors. Cable Support Assembly Cable clamps support cable or wire at the plug or receptacle and prevent twisting and pulling. C Thread Shell Size Cinch Part Number 3 MS Dimensions Part Number A Maximum in mm B ±0.005 (0.381) in A Max. Dia. 0.606 15.393 0.935 MS in mm MS27291-13 .606 15.393 0.731 18.568 0.935 MS27291-1 .731 18.568 MS27291-2 .919 23.343 0.919 23.343 0.935 MS27291-3 .981 24.918 MS27291-4 1.106 28.093 0.981 24.918 1.170 MS27291-5 1.231 31.268 1.106 28.093 1.170 MS27291-14 1.356 34.443 MS27291-6 1.481 37.618 1.231 31.268 1.170 MS27291-15 1.606 40.793 X I.D. ±0.005 (0.127) C Th’D P Maximum X in mm in mm in B I.D. P +.015 (.381) +.005 (.127) C Th’d Max. 23.749 0.186 4.725 0.437-28 0.789 20.042 in mm in mm UNEF-2B in mm .935 23.749 .186 4.725 .437-28 .789 20.042 23.749 0.270 6.858 0.562-24 0.914 23.216 .935 23.749 .270 6.858 .562-24 .914 23.216 .935 .400 10.160 10.160 .750-20 23.74923.7490.400 0.750-20 1.026 1.026 26.061 26.061 1.170 29.718 .460 11.684 .812-20 1.090 27.686 1.170 .610 11.684 15.494 .937-20 29.71829.7180.460 0.812-20 1.250 1.090 31.750 27.686 1.170 29.718 .690 17.526 1.062-18 1.358 34.493 29.71829.7180.610 0.937-20 1.481 1.250 37.619 31.750 1.170 .816 15.494 20.728 1.187-18 1.170 29.718 .940 23.876 1.312-18 1.604 40.742 29.71829.1780.690 1.062-18 1.729 1.358 43.919 34.493 1.170 1.066 17.526 27.078 1.437-18 mm mm 18 C48-2345 MS27291-13 Cinch Size Part No. 8 C48-2840 MS27291-1 10 C48-2341 12 C48-2342 MS27291-2 14 C48-2343 16 C48-2344 MS27291-3 18 C48-2345 MS27291-4 20 C48-2643 22 C48-2346 MS27291-5 24 C48-2644 20 C48-2643 MS27291-14 1.356 34.443 1.170 29.718 0.816 20.728 1.187-18 1.481 37.619 37.619 22 C48-2346 MS27291-6 1.481 37.618 1.170 29.718 0.940 23.876 1.312-18 1.604 40.742 40.742 24 C48-2644 MS27291-15 1.606 40.793 1.170 29.178 1.066 27.078 1.437-18 1.729 43.919 43.919 8 C48-2840 10 C48-2341 12 C48-2342 14 C48-2343 16 C48-2344 Call Toll Free: 1 (800) 323-9612 14 3-11 20.042 23.216 26.061 27.686 31.750 34.493 C48 Series Accessories Contacts When you order Cinch C48 Series connectors with contacts, the contact package contains enough contacts to complete the insert arrangement plus two spares. The package also includes sealing plugs for 15% of the contacts in the inserts, minimum of three. To provide proper sealing, insert unwired contacts and sealing plugs in all unused holes. (Use a #12 contact for a #1 shielded hole.) To order contacts and sealing plugs separately use the part numbers in the table below. Cinch Part Number Contacts Pin Socket MS Part Number Contacts Pin Socket Boeing Part Number Contacts Pin Socket Contact Size (Sheilded) Maxium Wire Size AWG Current Rating Amps No. 1* ** 3 C48-1226-02 C48-1227-02 C48-1226-54 C48-1227-54 **** 1 C48-1226-55 C48-1227-55 ***** 1 C48-2187-02 C48-2188-02 *** 7.5 12 41 14 32 16 22 18 16 20 7.5 22 5.0 24 3.0 No. 2 M32029/31-235 M39029/32-254 BACC47CN3S BACC47CP3S No. 12 M39029/31-229 M39029/32-248 BACC47CN2S BACC47CP2S No. 16 M39029/31-627 M39029/32-260 BACC47CN1S BACC47CP1S No. 20 * ** Fits into No. 12 power contact cavity. Accommodates cables RG174/U, RG179U, RG179A/U, RG187/U, RG188/U, RG161/U, as well as shielded wire. Can also accommodate Cable MIL-C-27500-22 KING (Extruded) or 22 AWG per MIL-C-7078 type II. *** Accommodates Cable MIL-C-27500 KING; 20 KING; 18 KING (Extruded) or 22, 20, 18 AWG, per MIL-C-7078 type II. **** For use with RG195/U and RG180/U, RG180A/U, and RG1808/U. ***** Accommodates Cables RG178/U, RG178A/U, RG1788/U, and RG196/U. Grommet Sealing Plugs MS Part Number Color Code Size MS27488-20-2 Red 20 MS27488-16-2 Green 16 MS27488-12-2 Orange 12 Insertion/Removal Tools Contact Size Insertion Tool Removal Tool Crimp Tool Adjustable Turret M81969/17-03 M81969/19-06 M22520/1-01 MS22520/1-02 No. 20 M81969/17-04 M81969/19-01 M22520/1-01 MS22520/1-02 No. 16 M81969/17-05 M81969/19-02 M22520/1-01 MS22520/1-02 No. 12 Crimp/Insertion/Removal tools are listed only for reference, tools are procured from tool manufacture or authorized distributor. 15 CN0966 Series Self-Locking Plug Connectors Ordering Information C N 0 9 6 6 B 10 S 0 5 P N - 000 Series Designation Order Code 000 = Less contacts 100 = *See below 200 = With gold-plated contact Series Modification A = Ungrounded B = Grounded (conductive) Alternate Shell Positions Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 N, 6, 7, 8, 9, 10 See page 4, table 1 Class A = Anodized aluminum G = Cadmium/nickel-plated aluminum N = Electroless nickel-plated aluminum S = Stainless steel Contact Style P = Pin S = Socket Insert Arrangements See page 5 CN0966 Series (C48 Family) Self-Locking Plug Connectors Threaded Coupling CN0966XXXXXXXX BACC63BP1 Threaded Coupling CN0966XXXXXXXX BACC63BP1 1.345** (34.164) Max. 360° LOCKING ACCESSORY TEETH A ±0.005 (0.127) Size 8 10 12 14 16 18 20 22 24 28 NOTES: 3 in Dimensions 0.835 0.972 Shell 1.165 Size 1.230 8 10 1.355 12 1.470 14 16 1.607 18 1.735 20 22 1.858 24 2.113 28 B Maximum Diameter mm in mm UNEF-2A 21.209 0.306 7.773 0.500-20 A 23.698 + .005 (.127) 27.254 in mm 30.124 .835 21.209 .972 23.698 33.198 1.165 27.254 34.798 1.230 30.124 1.355 33.198 38.100 1.470 34.798 41.148 1.607 38.100 1.735 41.148 44.069 1.858 44.069 52.070 2.113 52.070 B Max. Dia. in mm .306 7.773 .371 9.423 .547 13.894 .613 15.570 .758 19.253 .865 21.971 .986 25.044 1.106 28.092 1.235 31.369 1.485 37.719 Ordering Information2 Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 Class 0.371 C Thread 0.547 UNEF-2A 0.613 .500-20 .625-24 0.758 .750-20 0.865 .875-20 1.000-20 0.986 1.0625-18 1.106 1.1875-18 1.3125-18 1.235 1.4375-18 1.485 1.750-18* 9.423 0.625-24 13.894 0.750-20 15.570 0.875-20 19.253 1.000-20 21.971 1.0625-18 25.044 1.1875-18 28.092 1.3125-18 31.369 1.4375-18 37.719 1.750-18* CN0966 B 10 S 05 P N - 000 Series Designation factory CN0966 1 For modifications, classes, etc. not listed, consult * Th’d: UNS-2A Series Modification ** Size 28 = 1.395 (35.434) A - Ungrounded * Former order code - 100 designated rhodium plated contacts B - Grounded (Conductive) 16 C Thread Order Code (Deviations)1 000 - Less Contacts 100 - * See below 200 - With Gold-Plated Contacts Alternate Shell Positions N, 6, 7, 8, 9, 10 Per table on page 3-4 CN0967 Series Vibration-Resistant Receptacle Ordering Information C N 0 9 67 C 10 S 0 5 P N - 000 Series Designation Order Code 000 = Less contacts 100 = *See below 200 = With gold-plated contact Series Modification C = Square-flange mount G = Square-flange with clinch nuts Alternate Shell Positions N, 6, 7, 8, 9, 10 See table 4, table 1 Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 Class A = Anodized aluminum G = Cadmium/nickel-plated aluminum K = Stainless steel flame resistant N = Electroless nickel-plated aluminum S = Stainless steel Contact Style P = Pin S = Socket Insert Arrangements See page 5 CN0967 (C48 Series) Vibration-Resistant Receptacle Threaded Coupling Threaded Coupling CN0967XXXXXXXX CN0967XXXXXXXX BACC63BV1BACC63BV1 1.407** (35.738) Max. 360° LOCKING ACCESSORY TEETH Size A ±0.0045 (0.114) in 8 10 12 14 16 18 20 22 24 28 mm Dimensions 0.812 20.625 0.937 23.800 A 1.031+.0045 26.187 Shell (.114) Size mm 1.125 in 28.575 8 .812 20.625 1.250 31.750 10 .937 23.800 1.343 12 1.03134.112 26.187 141.4371.12536.500 28.575 16 1.250 31.750 181.5621.34339.675 34.112 201.7031.43743.256 36.500 222.0001.56250.800 39.675 24 1.703 43.256 28 2.000 50.800 B ±0.005 (0.127) C Maximum D Maximum J Thread L Thread in mm in mm in mm UNEF-2A UNEF-2A 0.594 15.088 0.561 14.250 0.328 8.331 0.5265-24 0.5000-20 0.719 18.263 0.696 14.250 0.371 9.423 0.6875-24 0.6250-24 B 0.812 (.127) 20.625 +.005 in mm 0.906 23.012 .594 15.088 0.969 24.613 .719 18.263 1.062 26.975 .812 20.625 .906 23.012 1.156 29.362 .969 24.613 1.250 31.750 1.062 26.975 1.375 34.925 1.156 29.362 1.250 31.750 1.562 39.675 1.375 34.925 1.562 39.675 C Max.0.875 in mm 0.935 .561 14.250 1.062 .696 14.250 1.187 .875 17.679 .935 22.225 1.312 1.062 23.749 1.437 1.187 30.150 1.562 1.312 33.325 1.437 36.500 1.810 1.562 39.675 1.810 45.976 D 17.679 Max. Dia. 0.547 in mm 0.609 22.225 .328 8.331 23.749 0.758 .371 9.423 30.150 .547 13.8940.865 .609 33.325 15.4690.986 .758 19.253 36.500 .865 21.9711.106 39.675 .986 25.0441.235 1.106 45.976 28.0921.485 1.235 31.369 1.485 37.719 J 13.894 Thread UNEF-2A 15.469 .5265-24 19.253 .6875-24 21.971 .8750-20 .9375-20 25.044 1.0625-18 28.092 1.1875-18 31.369 1.3125-18 1.4375-18 37.719 1.5625-18 1.8125-16 L 0.8750-20 Thread UNEF-2A 0.9375-20 .5000-20 1.0625-18 .6250-24 1.875-18 .7500-20 .8750-20 1.3125-18 1.0000-20 1.4375-18 1.0625-18 1.5625-18 1.1875-18 1.3125-18 1.8125-16 1.4375-18 1.750-18* 3 0.7500-20 0.8750-20 1.0000-20 1.0625-18 1.1875-18 1.3125-18 1.4375-18 1.750-18* NOTES: 1 For modifications, classes, etc., not listed, consult factory 2 Ordering Information • For mounting hole dimensions, see page 21 * Th’d: UNS-2A **Size 28 = 1.457 (37.008) Series Designation CN0967 * Former order code - 100 designated rhodium plated contacts CN0967 C 10 S 05 P N - 000 Series Modification C - Square-Flange Mount G - Square-Flange with Clinch Nuts Order Code (Deviations) 000 - Less Contacts 100 - * See below 200 - With Gold-Plated Contacts Alternate Shell Position 17 CN1020 Series Vibration-Proof Plug Connector Ordering Information C N10 2 0 A 10 G 05 P N - 000 Series Designation Series Modification A = Standard plug Order Code 000 = Less contacts 100 = *See below 200 = With gold-plated contact Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 Alternate Shell Positions N, 6, 7, 8, 9, 10 See page 4, table 1 Class A = Anodized aluminum G = Cadmium/nickel-plated aluminum Contact Style P = Pin S = Socket CN1020 Series (C48 Family) Vibration-Proof Plug Connector Insert Arrangements See page 5 Bayonet Coupling Bayonet Coupling CN1020-XXXXXXXX CN1020-XXXXXXXX BACC63CB1BACC63CB1 1.345* * (34.164) Max. 360° LOCKING ACCESSORY TEETH Size 8 10 3 12 14 16 18 20 22 24 28 NOTES: Dimensions Shell Size 8 10 12 14 16 18 20 22 24 28 A ±0.005 (0.127) B Maximum Diameter A in + .005 (.127) 0.765 in mm .765 19.447 0.967 .967 24.561 1.078 1.078 27.381 1.187 30.149 1.187 1.309 33.248 1.309 1.375 34.925 1.505 38.227 1.375 1.625 41.275 1.505 1.755 44.577 2.161 54.889 1.625 B Max. Dia. 19.447 in mm 7.773 24.561 .306 .371 9.423 27.381 .547 13.894 15.570 30.149 .613 .758 19.253 33.248 .865 21.971 25.044 34.925 .986 1.106 28.092 38.227 1.235 31.369 37.719 41.275 1.485 1.755 44.577 2.161 54.889 Ordering Information2 mm mm UNEF-2A 7.773 0.500-20 9.423 0.625-24 13.894 0.750-20 15.570 0.875-20 19.253 1.000-20 21.971 1.0625-18 25.044 1.1875-18 28.092 1.3125-18 1.235 31.369 1.4375-18 1.485 37.719 1.750-18* CN1020 A 10 G 05 P N - 000 Series Designation CN1020 1 For modifications, classes, etc., not listed, consult factory Series Modification • For mounting hole dimensions, see page 21A - Standard Plug * Th’d: UNS-2A Shell Size **Size 28 = 1.395 (35.434) 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 * Former order code - 100 designated rhodium plated contacts 18 C in Thread 0.306 UNEF-2A .500-20 0.371 .625-24 0.547 .750-20 .875-20 0.613 1.000-20 0.758 1.0625-18 1.1875-18 0.865 1.3125-18 0.986 1.4375-18 1.750-18* 1.106 C Thread Environmental Class A - Anodized Aluminum G - Cadmium//Nickel-Plated Aluminum Order Code (Deviations)1 000 - Less Contacts 100 - * See below 200 - With Gold-Plated Contacts Alternate Shell Positions N, 6, 7, 8, 9, 10 Per table on page 3-4. Contact Style P - Pin S - Socket CN1021 Series Vibration-Resistant Receptacle Ordering Information C N10 21 A 10 G 05 P N - 000 Series Designation Order Code 000 = Less contacts 100 = *See below 200 = With gold-plated contact Series Modification A = Square-flange mount C = Square-flange with clinch nuts Alternate Shell Positions N, 6, 7, 8, 9, 10 See page 4, table 1 Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 Class A = Anodized aluminum G = Cadmium/nickel-plated aluminum Contact Style P = Pin S = Socket CN1021 Series (C48 Family) Vibration-Resistant Receptacle Insert Arrangements See page 5 Bayonet Coupling Bayonet Coupling CN1021XXXXXXXX 1 CN1021XXXXXXXX BACC63CC 1.407** (35.738) Max. BACC63CC1 360° LOCKING ACCESSORY TEETH Size Dimensions 8 Shell 10 Size 812 1014 1216 14 1618 1820 2022 22 2424 2828 A ±0.0045 (0.114) in A 0.812 +.0045 (.114) 0.937 in mm 1.031 .812 20.625 1.125 .937 23.800 1.031 26.187 1.250 1.125 28.575 1.343 1.250 31.750 1.437 1.343 34.112 1.437 36.500 1.562 1.562 39.675 1.703 1.703 43.256 2.000 50.800 2.000 mm B 20.625 +.005 (.127) 23.800 in mm 26.187 .594 15.088 28.575 .719 18.263 .812 20.625 31.750 .906 23.012 34.112 .969 24.613 36.500 1.062 26.975 1.156 29.362 39.675 1.250 31.750 43.256 1.375 34.925 1.562 39.675 50.800 B ±0.005 (0.127) in mm C Maximum in C 15.088 D 0.561 Max. Max. Dia. 0.719 18.263 0.696 in mm in mm 0.812 20.625 .561 14.250 .3280.875 8.331 0.906 23.012 .696 14.250 .3710.935 9.423 .875 17.679 .5471.06213.894 0.969 24.613 .935 22.225 .609 15.469 1.062 26.975 1.062 23.749 .7581.18719.253 1.156 29.362 1.187 30.150 .8651.31221.971 1.312 33.325 .9861.43725.044 1.250 31.750 1.437 36.500 1.106 28.092 1.375 34.925 1.2351.56231.369 1.562 39.675 1.810 45.976 1.562 39.675 1.4851.81037.719 0.594 D Maximum Diameter mm in L 0.328 Thread 14.250 0.371 UNEF-2A 17.679 0.547 .500-20 22.225 .625-24 0.609 .750-20 23.749 0.758 .875-20 30.150 0.865 1.000-20 33.3251.0625-18 0.986 1.1875-18 36.500 1.106 1.3125-18 39.6751.4375-18 1.235 45.9761.750-18* 1.485 14.250 L Thread mm UNEF-2A 8.331 0.500-20 9.423 0.625-24 13.894 0.750-20 15.469 0.875-20 19.253 1.000-20 21.971 1.0625-18 25.044 1.1875-18 28.092 1.3125-18 31.369 1.4375-18 37.719 1.750-18* 3 NOTES: 2 1 For modifications, Ordering Information classes, etc., not listed, consult factory • For mounting hole dimensions, see page 21 * Th’d: UNS-2A **Size 28 = 1.457 (37.008) Series Designation * Former order code - 100 designated CN1021 rhodium plated contacts CN1021 A 10 G 05 P N - 000 Series Modification A - Square-Flange Mount C - Square-Flange with Clinch Nuts Order Code (Deviations) 000 - Less Contacts 100 - * See below 200 - With Gold-Plated Contacts Alternate Shell Position 19 CN909A MMB Series Vibration-Proof Plug Connector Ordering Information C 0 9 0 9A 10 - 05 P 8 - XXX Series Designation Order Code 202 = with gold-plated contacts* 106 = Less contacts Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24 Alternate Shell Positions N, 6, 7, 8, 9, 10 See page 4, table 1 Class (Dash) = Anodized aluminum E = Cadmium/nickel-plated aluminum N = Nickel-plated aluminum Contact Style P = Pin S = Socket Insert Arrangements See page 5 Bayonet Coupling CN909AXXXXXXX BACC63BN1 C0909A MMB Series (C48 Family) Vibration-Proof Plug Connector 1.345 (34.164) Max. Bayonet Coupling C0909AXXXXXXX BACC63BN1 A Diameter Size in 3 8 0.328 10 0.420 12 0.580 14 0.664 16 0.769 18 0.902 20 1.033 22 1.152 24 1.282 B Diameter mm in Dimensions 8.331 10.668 Shell Size 14.732 8 16.866 10 12 19.533 14 16 22.911 18 26.238 20 22 29.261 24 32.253 in .328 .420 .580 .664 .769 .902 1.033 1.152 1.282 A Dia. 0.437 0.562 mm 0.750 8.331 0.812 10.668 14.732 0.938 16.866 19.533 1.062 22.911 1.182 26.238 29.261 1.312 32.253 1.432 Ordering Information2 NOTES: 1 For deviations, classes, etc. not listed, consult factory C Maximum mm 11.100 B 14.275 Dia. in mm 19.050 .437 11.100 20.625 .562 14.275 .750 19.050 23.825 .812 20.625 .938 23.825 26.975 1.062 26.975 30.023 30.023 1.182 1.312 33.325 33.325 1.432 36.373 36.373 mm UNEF-2A 0.766 19.456 C 0.906 23.012 Max. in mm 27.381 1.078 .766 19.456 1.141 28.981 .906 23.012 1.078 27.381 1.266 32.156 1.141 28.981 1.266 32.156 1.375 34.925 1.375 34.925 1.510 38.354 1.510 38.354 1.625 41.275 1.625 41.275 1.760 44.704 1.760 44.704 D Thread UNEF-2A .437-28 .562-24 .750-20 .812-20 .937-20 1.062-18 1.187-18 1.312.18 1.437-18 0.437-28 0.562-24 0.750-20 0.812-20 0.937-20 1.062-18 1.187-18 1.312-18 1.437-18 C0909A 10 - 05 P 8 - XXX Series Designation C0909A Shell Size * Former order code - 102 designated rhodium plated contacts 8, 10, 12, 14, 16, 18, 20, 22, 24 20 in D Thread Class (Dash) - Anodized Aluminum E - Cadmium/Nickel-Plated Aluminum N - Nickel-Plated Aluminum Order Code (Deviations) 202 - With Gold-Plated Contacts* 106 - Less Contacts Alternate Shell Positions N, 6, 7, 8, 9, 10 Per table on page 3-4. Contact Style P - Pin Insert S - Socket Insert C48 Series & C48 Family C48 Series & C48 Family Mounting Panel Data Mounting Panel Data Square-Flange Mount Square-Flange Mount 3 Single-Hole Mount(Jam-Nut Mount) Single-Hole Mount (Jam-Nut Mount) Dimensions M Minimum M Size 8 10 12 14 16 18 20 22 Shell in Min. mm Size in mm 8 0.620.62015.748 15.748 10 0.748.74818.999 18.999 12 0.913.91323.190 23.190 14 .980 24.892 16 0.980 1.10724.892 28.119 18 1.107 1.20928.119 30.709 20 1.337 33.906 1.209 30.709 22 1.452 36.881 24 1.337 1.57733.906 40.056 28 1.452 1.82736.881 46.406 24 28 1.577 40.056 N Minimum N in Min. mm in mm 0.447 11.354 .447 11.354 .572 0.572 14.529 14.529 .760 19.304 0.760 19.304 .822 20.879 0.822 24.079 20.879 .948 1.072 0.948 27.229 24.079 1.192 30.277 1.072 27.229 1.322 33.579 1.192 36.627 30.277 1.442 1.760 1.322 44.704 33.579 1.442 G ±0.005 (0.127) G 36.627 1.827 46.406 1.760 44.704 Recommended Minimum Torque for Jam Nut Shell Size Torque (Inch/lb.) 8 28 10 36 Recommended Minimum Torque for Jam Nut H ±0.005 (0.127) K H +.005 +.005in(.127) mm +.005 (.127)in mm (.127) in mm in mm in mm 15.638 0.635 16.129 .605 0.60515.638 .635 16.129 .594 15.088 .730 0.73018.542 19.304 .719 18.263 18.542 .760 0.760 19.304 .917 0.91723.292 .947 24.054 .812 20.625 23.292 0.947 24.054 .980 24.892 1.010 25.654 .906 23.013 24.8921.135 1.010 25.654 1.105 0.98028.067 28.829 .969 24.613 1.225 1.10531.115 32.004 1.062 28.0671.260 1.135 28.829 26.975 1.350 34.290 1.385 35.179 1.156 29.363 1.225 31.115 1.260 32.004 1.475 37.465 1.510 38.354 1.250 31.750 34.2901.635 1.385 35.179 34.925 1.600 1.35040.640 41.529 1.375 1.856 1.47547.143 47.879 1.562 37.4651.885 1.510 38.354 39.675 K ±0.005 (0.127) in mm 0.594 15.088 0.719 18.263 0.812 20.625 0.906 23.013 0.969 24.613 1.062 26.975 1.156 29.363 1.250 31.750 1.600 40.640 1.635 41.529 1.375 34.925 1.856 47.143 1.885 47.879 1.562 39.675 12 56 14 64.5 16 69 18 81 20 102 22 122.5 24 144 Shell Size 8 10 12 14 16 18 20 22 24 Torque (inch/lb) 28 36 56 64.5 69 81 102 122.5 144 3-20 Call Toll Free: 1 (800) 323-9612 21 About Cinch Connectivity Solutions For over 100 years, Cinch Connectivity Solutions has manufactured high-quality and reliable high-performance connectors and cable assemblies. Cinch is recognized as a world class connectivity supplier of RF, fiber optic, hybrid, microwave components, circular, d-subminiatures, modular rectangular, electronic enclosures and cable assemblies. Cinch provides innovative solutions to the military, commercial aerospace, networking, telecommunication, test and measurement, oil and gas and other harsh environment industries. For more information, please contact us: North America +1 507.833.8822 ccsorders@us.cinch.com Asia-Pacific +86 21 5442 7668 ccs.asia.sales@as.cinch.com Europe, Middle East +44 (0) 1245 342060 CinchConnectivity@eu.cinch.com belfuse.com/cinch.com ca-ccs-omega-catalog-11302021 © 2021 Cinch Connectivity Solutions
50-44SN-1
物料型号: 文档中提到了多种连接器型号,包括C48系列、CN0966系列、CN0967系列、CN1020系列、CN1021系列和CN909A MMB系列等。
器件简介: 文档介绍了Omega产品系列,这是一系列符合MIL-C-26500标准的通用连接器。Omega系列已经扩展,包括许多符合Boeing BACC45/BACC63连接器规范的合格产品。
引脚分配: 文档提供了详细的引脚分配信息,包括不同系列连接器的引脚数量和排列,例如C48系列、CN0942/CN0944系列等。
参数特性: 文档列出了连接器的多种参数特性,如电气性能(包括介电强度、电流额定值和绝缘电阻)、机械性能(包括振动测试、接触保持力和耐久性)以及环境性能(包括温度极限、臭氧抵抗、温度寿命、湿度抵抗和热冲击)。
功能详解: 文档详细解释了C48系列连接器的功能,包括其在屏蔽、环境密封、流体抵抗和振动方面的应用。此外,还介绍了CN系列连接器的设计,如CN0942/CN0944固定接触插座连接器,它们专为定制板载、柔性电路和焊接线应用而设计。
应用信息: Omega产品系列的连接器主要用于网络、电信、计算、军事、航空、交通和广播行业。Bel的产品组合也应用于汽车、医疗和消费电子市场。
封装信息: 文档提供了连接器的封装信息,包括不同系列连接器的尺寸、形状和安装方式,如平方法兰安装、单孔安装等。
50-44SN-1 价格&库存
很抱歉,暂时无法提供与“50-44SN-1”相匹配的价格&库存,您可以联系我们找货
50-44SN-1
  • 1000+122.693241000+15.90338
