BRFL7N60
BRFL7N60
    BLUEROCKET(蓝箭电子)
    TO220FL
BRFL7N60 数据手册
BRFL7N60 Rev.E Dec.-2017 描述 / DATA SHEET Descriptions TO-220FL 塑封封装 N 沟道 MOS 场效应管。N-CHANNEL MOSFET in a TO-220FL Plastic Package. 特征 / Features 低栅电荷,低反馈电容,开关速度快。 Low gate charge, low crss, fast switching. 用途 / Applications 用于高功率 DC/DC 转换和功率开关。 These devices are well suited for high efficiency switching DC/DC converters and switch mode power supplies. 内部等效电路 引脚排列 1 2 / Equivalent Circuit / Pinning 3 PIN1:G 放大及印章代码 PIN 2:D PIN 3:S / hFE Classifications & Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/7 BRFL7N60 Rev.E Dec.-2017 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit VDSS 600 V Drain Current ID(Tc=25℃) 7.0 A Drain Current ID(Tc=100℃) 4.4 A IDM 28 A Gate-Source Voltage VGSS ±30 V Single Pulsed Avalanche Energy EAS 420 mJ Repetitive Avalanche Energy EAR 14.7 mJ Avalanche Current IAR 7.0 A Power Dissipation PD(Tc=25℃) 48 W TJ,TSTG -55 to 150 ℃ Drain-Source Voltage Drain Current - Pulsed Operating and Storage Temperature Range http://www.fsbrec.com 2/7 BRFL7N60 Rev.E Dec.-2017 电性能参数 DATA SHEET / Electrical Characteristics(Ta=25℃) 参数 Parameter 符号 Symbol Drain-Source Breakdown Voltage BVDSS Zero Gate Voltage Drain Current IDSS Gate-Body Leakage Current, Forward IGSS 测试条件 Test Conditions VGS=0V ID=250μA VDS=600V VGS=0V VDS=480V 最小值 典型值 最大值 单位 Min Typ Max Unit 600 V 1 μA TC=125℃ 100 μA VGS=±30V VDS=0V ±100 nA 4.0 V 1.2 Ω Gate Threshold Voltage VGS(th) VDS=VGS ID=250μA Static Drain-Source On-Resistance RDS(on) VGS=10V ID=3.5A 1.0 gFS VDS=40V ID=3.5A 8.2 VSD VGS=0V IS=7.0A VDS=25V f=1.0MHz VGS=0V Forward Transconductance Drain-Source Diode Forward Voltage Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg ID =7.0A VGS = 10V VDS = 480V 2.0 S 1.4 V 1100 1500 pF 110 150 pF 12 16 pF 25.9 nC 6 nC nC Gate-to-Source Charge Qgs Gate-to-Drain Charge Qgd 9.2 Turn-On Delay Time td(on) 15 40 ns Turn-On Rise Time tr 30 70 ns Turn-Off Delay Time td(off) 110 230 ns 40 90 ns Turn-Off Fall Time http://www.fsbrec.com tf VDD=300V RG=25Ω ID=7.0A 3/7 BRFL7N60 Rev.E Dec.-2017 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 4/7 BRFL7N60 Rev.E Dec.-2017 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 5/7 BRFL7N60 Rev.E Dec.-2017 印章说明 / DATA SHEET Marking Instructions BR 7N60 ****  说明: 为公司代码 BR: 7N60:  为型号代码 ****:  为生产批号代码,随生产批号变化。  Company Code Note: BR:   7N60: ****: http://www.fsbrec.com Product Type.  Lot No. Code, code change with Lot No. 6/7 BRFL7N60 Rev.E Dec.-2017 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 Package Type 封装形式 使用说明 Temp.:270±5℃ Time:10±1 sec / Packaging SPEC. 套管包装 TO-220FL 时间:10±1 sec. / TUBE Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 50 20 1,000 5 5,000 532×33×7.0 555×164×50 575×290×180 / Notices http://www.fsbrec.com 7/7
BRFL7N60 价格&库存
很抱歉,暂时无法提供与“BRFL7N60”相匹配的价格&库存,您可以联系我们找货
BRFL7N60
  • 1+2.95920
  • 10+2.31120
  • 30+2.03040
库存:7
