S-304H-CCT
S-304H-CCT
    CINCH
    S-304H-CCT
S-304H-CCT 数据手册
Jones Plugs/Sockets Series 300 Multiple Density Solder Eyelet ■ Solder lug terminals with .093" x .062" (2.36mm x 1.57mm) wiring holes. ■ Two-contact "Jones" connector is round, all others are rectangular. ■ For use in cable-to-panel and cable-to-cable applications. FEATURES ■ Designed for light and medium duty. ■ Plug prongs are .156" (3.96mm) wide and .047" (1.19mm) thick. ■ Polarized to prevent wrong-way insertion. ■ Plugs have projecting flat blades, sockets have recessed twin bellows. ■ Cable clamps of zinc and clear irridite-plated steel used for strain relief. ■ UL Recognized-file E170218 (UL 1977), E130965 (UL1863). ■ CSA-LR31996. ■ See Panel Cutout dimension on page (2-38). MATERIALS Insulation Material: Molded monoblock, general purpose phenolic, black UL94V-1 Contact Material: Plug: Brass Socket: Phosphor bronze Contact Plating: Cadmium Operating Temperature: Up to +105°C ELECTRICAL Hood Material: UL 94V-0 rated thermoplastic Operating Voltage: Current Rating: Contact Resistance: 250 VAC RMS maximum 10 Amps 16 Milliohms maximum Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-36 Jones Plugs/Sockets Series 300 Multiple Density Solder Eyelet Polarizing Patterns - 300 Series Marketed exclusively through distribution. 2-37 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic Multiple Density Solder Eyelet Mounting Dimensions A Reference 2 in B mm in C mm in D mm in mm 303 .453 11.51 1.016 25.81 .750 19.05 - - 304 .719 18.26 .781 19.84 1.000 25.40 - - 306 .719 18.26 1.031 26.19 1.000 25.40 - - 308 .719 18.26 1.281 32.54 1.000 25.40 - - 310 .719 18.26 1.578 40.08 1.000 25.40 - - 312 .953 24.21 1.266 32.16 1.250 31.75 - - 315-12 .953 24.21 1.516 38.51 1.250 31.75 - - 315 1.016 25.81 1.641 41.68 1.375 34.93 - - 318 1.016 25.81 1.953 49.61 1.375 34.93 .625 15.88 321 1.016 25.81 2.266 57.56 1.375 34.93 .469 11.91 324 1.016 25.81 2.578 65.48 1.375 34.93 .625 15.88 327 1.016 25.81 2.891 73.43 1.375 34.93 .781 19.84 330 1.016 25.81 3.203 81.36 1.375 34.93 .938 23.83 333 1.016 25.81 3.516 89.31 1.375 34.93 1.094 27.79 NOTE: For 300 Series 2 through 33 contact angle bracket connectors. All mounting holes are .156" (3.96mm) dia. Maximum chassis thickness is .063" (1.59mm) for bottom mounting. Mounting holes are located on center line unless otherwise shown. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-38 Jones Plugs/Sockets Series 300 No. of Contacts 2 3 4 6 8 10 12 15* 15 18 21 24 27 30 33 [.050” Multiple (1.27mm) Density Density Solder SolderCup/Wire Eyelet With Angle D-Microminiature] Bracket/Less Angle Bracket With Angle Bracket Catalog No. Catalog No. Plug Socket P-302-AB S-302-AB P-303-AB S-303-AB P-304-AB S-304-AB P-306-AB S-306-AB N/A N/A P-310-AB N/A P-312-AB N/A N/A S-315-12-AB P-315-AB S-315-AB P-318-AB S-318-AB P-321-AB S-321-AB P-324-AB S-324-AB P-327-AB S-327-AB P-330-AB S-330-AB P-333-AB S-333-AB Less Angle Bracket Catalog No. Catalog No. Plug Socket P-302-LAB S-302-LAB P-303-LAB S-303-LAB P-304-LAB S-304-LAB P-306-LAB S-306-LAB N/A N/A P-310-LAB N/A P-312-LAB N/A N/A S-315-12-LAB P-315-LAB S-315-LAB P-318-LAB S-318-LAB P-321-LAB S-321-LAB P-324-LAB S-324-LAB P-327-LAB S-327-LAB P-330-LAB S-330-LAB P-333-LAB S-333-LAB No. of Contacts 2 3 4 6 8 10 12 15 15 18 21 24 27 30 33 X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. No. of Contacts 2 3 4 6 8 10 12 15* A in .656 1.000 .750 1.000 -1.562 1.250 1.500 B mm in 16.67 25.40 19.05 25.40 -39.69 31.75 38.10 .438 .688 .688 -.688 .938 .938 C mm 11.11 17.46 17.46 -17.46 23.81 23.81 D in mm in mm .969 .750 1.000 1.000 -1.000 1.250 1.250 24.61 19.05 25.40 25.40 -25.40 31.75 31.75 1.219 1.062 1.312 1.312 -1.312 1.562 1.562 30.96 26.99 33.34 33.34 -33.34 39.69 39.69 *Special 15 contact arrangement to allow 12-position mating. L Reference 15 18 21 24 27 30 33 M in mm 1.625 1.938 2.250 2.563 2.875 3.188 3.500 41.28 49.23 57.15 65.10 73.03 80.98 88.90 in See note 1.250 .938 1.250 1.562 1.875 2.188 Polarizing Pin mm 31.75 23.81 31.75 39.69 47.63 55.58 NO NO NO 14 14 14 17 NOTE: 15-position plug and socket require only two mounting brackets, mounted on center of connector. Marketed exclusively through distribution. 2-39 Call Toll Free: 1 (800) 323-9612 2 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Flush Plate 300 Series with Flush Plate (FP) 2 No. of Catalog No. Catalog No. Contacts Plug Socket 2 P-302-FP S-302-FP 3 P-303-FP S-303-FP 4 P-304-FP S-304-FP 6 P-306-FP S-306-FP 8 N/A N/A 10 P-310-FP N/A 12 P-312-FP N/A NOTE: Not available in contact sizes 15-33. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions - Plug or Socket No. of Contacts 2 3 4 6 8 10 12 A in 2.063 2.063 2.063 2.063 -2.563 2.563 B mm 52.40 52.40 52.40 52.40 -65.10 65.10 in 1.250 1.250 1.250 1.250 -1.750 1.750 C mm 31.75 31.75 31.75 31.75 -44.45 44.45 in 1.750 1.750 1.750 1.750 -2.250 2.250 D mm 44.45 44.45 44.45 44.45 -57.15 57.15 in .938 .688 .938 -1.500 1.188 mm 23.81 17.46 23.81 -38.10 30.16 E Max. in mm .719 18.26 .500 12.70 .750 19.05 .750 19.05 --.750 19.05 1.000 25.40 Panel Cutout Dimensions A Reference 303-FP 304-FP 306-FP 308-FP 310-FP 312-FP in .953 .703 .953 -1.516 1.203 B mm 24.21 17.86 24.21 -38.51 30.56 in .516 .766 .766 -.766 1.016 C mm 13.11 19.46 19.46 -19.46 25.81 in 1.750 1.750 1.750 -2.250 2.250 mm 44.45 44.45 44.45 -57.15 57.15 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-40 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] End Brackets 300 Series with End Brackets (EB) No. of Contacts 15 18 21 24 28 30 33 Catalog No. Plug P-315-EB P-318-EB P-321-EB P-324-EB P-328-EB P-330-EB P-333-EB Catalog No. Socket S-315-EB S-318-EB S-321-EB S-324-EB S-328-EB S-330-EB S-333-EB 2 NOTE: Not available in contact sizes 2-12. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions No. of Contacts 15 18 21 24 27 30 33 L ± .031 (.79mm) 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 3.875 98.43 4.188 106.38 M ± .031 (.79mm) 2.000 50.80 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 3.875 98.43 P ± .063 (1.59mm) 1.625 41.28 1.938 49.23 2.250 57.15 2.563 65.10 2.875 73.03 3.188 80.98 3.500 88.90 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 315-EB 318-EB 321-EB 324-EB 327-EB 330-EB 333-EB in 1.641 1.953 2.266 2.578 2.891 3.203 3.516 B mm 41.68 49.61 57.56 65.48 73.43 81.36 89.31 in 1.016 1.016 1.016 1.016 1.016 1.016 1.016 C mm 25.81 25.81 25.81 25.81 25.81 25.81 25.81 in 2.000 2.313 2.625 2.938 3.250 3.563 3.875 mm 50.80 58.75 66.68 74.63 82.55 90.50 98.43 Marketed exclusively through distribution. 2-41 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic Multiple Density Solder Eyelet Recessed Plate 300 Series with Recessed Plate (RP) 2 No. of Contacts 2 3 4 6 8 10 12 Catalog No. Plug P-302-RP P-303-RP P-304-RP P-306-RP N/A P-310-RP P-312-RP Catalog No. Socket S-302-RP S-303-RP S-304-RP S-306-RP N/A N/A N/A NOTE: Not available in contact sizes 15-33. Y = length of plug or socket tails. Dimensions No. of Contacts 2 3 4 6 8 10 12 A in 2.063 2.063 2.063 2.063 -2.563 2.563 B mm 52.40 52.40 52.40 52.40 -65.10 65.10 in 1.500 1.500 1.500 1.500 -2.000 2.000 C mm 38.10 38.10 38.10 38.10 -50.80 50.80 in 1.750 1.750 1.750 1.750 -2.250 2.250 mm 44.45 44.45 44.45 44.45 -57.15 57.15 D Max. in mm 1.350 34.29 1.350 34.29 1.350 34.29 1.350 34.29 --1.850 46.99 1.850 46.99 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-42 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Shallow Bracket 300 Series with Shallow Bracket (SB) No. of Contacts 15 18 21 24 27 30 33 Catalog No. Plug P-315-SB P-318-SB P-321-SB P-324-SB P-327-SB P-330-SB P-333-SB Catalog No. Socket S-315-SB S-318-SB S-321-SB S-324-SB S-327-SB S-330-SB S-333-SB 2 NOTE: Not available in contact sizes 2-12. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions No. of Polarizing Contacts 15 18 21 24 27 30 33 A ± .031 (.79mm) in mm 1.688 42.86 2.000 50.80 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 M ± .031 (.79mm) in mm 2.125 53.98 2.438 61.93 2.750 69.85 2.063 52.40 3.375 85.73 3.688 93.68 4.000 101.60 L ± .063 (1.59mm) in mm 2.547 64.69 2.859 72.62 3.172 80.57 3.484 88.49 3.797 96.44 4.109 104.38 4.422 112.32 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 315-SB 318-SB 321-SB 324-SB 327-SB 330-SB 333-SB in 1.750 2.063 2.375 2.688 3.000 3.313 3.625 B mm 44.45 52.40 60.33 68.28 76.20 84.15 92.08 in 1.156 1.156 1.156 1.156 1.156 1.156 1.156 C mm 29.36 29.36 29.36 29.36 29.36 29.36 29.36 in 2.125 2.438 2.750 3.062 3.376 3.688 4.000 mm 53.98 61.93 69.85 77.77 85.75 93.68 101.60 Marketed exclusively through distribution. 2-43 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Deep Bracket 300 Series Deep Bracket (DB) 2 No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-DB P-303-DB P-304-DB P-306-DB N/A N/A P-312-DB P-315-DB P-318-DB P-321-DB P-324-DB P-327-DB P-330-DB P-333-DB Catalog No. Socket S-302-DB S-303-DB S-304-DB S-306-DB N/A N/A N/A S-315-DB S-318-DB S-321-DB S-324-DB S-327-DB S-330-DB S-333-DB Dimensions Y = length of plug or socket tails. L ± .063 (1.60mm) in mm 2.813 71.44 3.125 79.38 3.437 87.31 3.750 95.25 4.063 103.19 4.375 111.13 4.688 119.06 No. of Contacts 15 18 21 24 27 30 33 M ± .031 (.79mm) in mm 2.375 60.33 2.688 68.28 3.000 76.20 3.313 84.15 3.625 92.08 3.938 100.03 4.250 107.95 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 302-DB thru 312-DB 315-DB 318-DB 321-DB 324-DB 327-DB 330-DB 333-DB B C in mm in mm in mm 1.453 2.000 2.313 2.625 2.938 3.250 3.562 3.875 36.91 50.80 58.75 66.68 74.63 82.55 90.47 98.43 1.125 1.438 1.438 1.438 1.438 1.438 1.438 1.438 28.58 36.53 36.53 36.53 36.53 36.53 36.53 36.53 1.750 2.376 2.688 3.000 3.312 3.626 3.938 4.250 38.10 60.35 68.28 76.20 84.12 92.10 100.03 107.95 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-44 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet With Hood & 90° Clamp D-Microminiature] 300 Series with Hood and 90° Cable Clamp (CCE) No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-CCE P-303-CCE P-304-CCE P-306-CCE N/A P-310-CCE P-312-CCE P-315-CCE P-318-CCE P-321-CCE P-324-CCE P-327-CCE P-330-CCE P-333-CCE Catalog No. Socket S-302-CCE S-303-CCE S-304-CCE S-306-CCE N/A N/A N/A S-315-CCE S-318-CCE S-321-CCE S-324-CCE S-327-CCE S-330-CCE S-333-CCE 2 Dimensions No. of Contacts 2 3 4 6 8 10 12 A +.016 (.41mm) in mm .691 17.55 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 No. of Contacts 15 18 21 24 27 30 33 B +.016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 C +.031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 .078 27.38 --1.203 30.56 1.203 30.56 E in 2.514 2.826 3.139 3.451 3.764 4.076 4.389 L mm 63.85 71.78 79.73 87.66 95.61 103.53 111.48 in 1.795 2.107 2.420 2.732 3.045 3.357 3.670 mm 45.59 53.52 61.47 69.39 77.34 85.27 93.22 G in .313 .344 .453 .469 -.359 .422 mm 7.95 8.74 11.51 11.91 -9.12 10.72 Cable Opening in mm .563 14.30 .563 14.30 .625 15.88 .625 15.88 .625 15.88 .750 19.05 .750 19.05 Cable "D" Opening in mm .313 7.95 .250 6.35 .375 9.53 .438 11.13 --.500 12.70 .563 14.30 Polarizing Pin NO NO NO 14 14 14 17 Marketed exclusively through distribution. 2-45 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic [.050” (1.27mm) Density Multiple Density Solder Eyelet Solder Cup/Wire With Hood & 180° Clamp D-Microminiature] 300 Series with Hood and 180° Cable Clamp (CCT) 2 No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-CCT P-303-CCT P-304-CCT P-306-CCT N/A P-310-CCT P-312-CCT P-315-CCT P-318-CCT P-321-CCT P-324-CCT P-327-CCT P-330-CCT P-333-CCT Catalog No. Socket S-302-CCT S-303-CCT S-304-CCT S-306-CCT N/A N/A N/A S-315-CCT S-318-CCT S-321-CCT S-324-CCT S-327-CCT S-330-CCT S-333-CCT Dimensions No. of Contacts 2 3 4 6 8 10 12 A ± .016 (.41mm) in mm .691 17.55 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 No. of Contacts 15 18 21 24 27 30 33 B ± .016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 L in 1.795 2.107 2.420 2.732 3.045 3.357 3.670 mm 45.59 53.52 61.47 69.39 77.34 85.27 93.22 C ± .031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 1.078 27.38 --1.203 30.56 1.203 30.56 Cable Opening in mm .563 14.30 .563 14.30 .625 15.88 .625 15.88 .625 15.88 .750 19.05 .750 19.05 “D” Cable Opening in mm .375 9.53 .313 7.95 .375 9.53 .438 11.13 --.500 12.70 .563 14.30 E ± .031 (.79mm) in mm .359 9.12 .359 9.12 .469 11.91 .484 12.29 --.500 12.70 .469 11.91 Polarizing Pin NO NO NO 14 14 14 17 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-46 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] 180° Clamp w/Locks 300 Series Plug with Hood and Lock (CCT-L) and Socket with Hood and Keeper (CCT-K) No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Catalog No. Plug w/ Lock Socket w/ Keeper P-302-CCT-L S-302-CCT-K P-303-CCT-L S-303-CCT-K P-304-CCT-L S-304-CCT-K P-306-CCT-L S-306-CCT-K N/A N/A P-310-CCT-L N/A P-312-CCT-L N/A P-315-CCT-L S-315-CCT-K P-318-CCT-L S-318-CCT-K P-321-CCT-L S-321-CCT-K P-324-CCT-L S-324-CCT-K P-327-CCT-L S-327-CCT-K P-330-CCT-L S-330-CCT-K P-333-CCT-L S-333-CCT-K Socket 2 Plug Dimensions No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 A ± .016 (.41mm) in mm .691 17.5 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 1.795 45.59 2.107 53.52 2.420 61.47 2.732 69.39 3.045 77.34 3.357 85.27 3.670 93.22 B ± .016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 C ± .031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 1.078 27.38 --1.203 30.56 1.203 30.56 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 F in .359 .359 .469 .484 -.500 .469 .712 .712 .712 .712 .712 .712 .712 mm 9.12 9.12 11.91 12.29 -12.70 11.91 18.08 18.08 18.08 18.08 18.08 18.08 18.08 “D” Cable Opening Polarizing in mm Pin .375 9.53 -.313 7.94 -.375 9.53 -.438 11.13 ----.500 12.70 -.563 14.30 -.563 14.30 NO .563 14.30 NO .625 15.88 NO .625 15.88 14 .625 15.88 14 .750 19.05 14 .750 19.05 17 Marketed exclusively through distribution. 2-47 Call Toll Free: 1 (800) 323-9612 DURA-CON® High Reliability Miscellaneous All-Plastic [.050” (1.27mm) Density Multiple Density Solder Cup/Wire Solder Eyelet D-Microminiature] JONES PLUGS AND SOCKETS 300 SERIES MATING CHART PLUGS MOUNTING CONFIG. AB 2 AB DB FP RP EB SB CCE CCT •* • •* • • • • • • • • • • • • • • • • •* •* •* •* •* •* •* •* • • •* •* •* • • DB FP SOCKETS RP EB SB CCE CCT • • • • • CCT-L CCT-K LAB • • • • • • • • • CCT-L • • CCT-K • LAB • • • • • • • • • • These are recommended configurations. •* These are possible configurations, but not normally recommended. NOTE: Cinch layout S315-12 is available only in “AB” or “LAB”. Replacement Drive Pins for Series 300 Plugs and Sockets with Cable Caps and Clamps Dimensions No. of Contacts 2 3 4,6,8,10* 12 15-33* Ordering Information Dim. L +.005 (.13mm) in mm .687 17.45 .468 11.89 .718 18.24 .953 28.58 1.125 28.58 No. of Contacts 2 3 4,6,8,10* 12 15-33* Catalog No. 302R 303R 304R 312R 333R *10 contact size and 15 through 33 contact sizes require two pins per unit; all other sizes require only one. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-48
S-304H-CCT 价格&库存
很抱歉,暂时无法提供与“S-304H-CCT”相匹配的价格&库存,您可以联系我们找货
S-304H-CCT
  • 1000+26.705661000+3.46157
