BRD50P06
BRD50P06
    BLUEROCKET(蓝箭电子)
    TO-252(DPAK)
BRD50P06 数据手册
BRD50P06 Rev.F Nov.-2019 DATA SHEET 描述 / Descriptions TO-252 塑封封装 P 沟道 MOS 场效应管。P-CHANNEL MOSFET in a TO-252 Plastic Package. 特征 / Features RDS(on)小,门电荷低,Crss 小,开关速度快。无卤产品。 Low RDS(on),low gate charge, low Crss, fast switching. Halogen-free Product. 用途 / Applications 用于低压电路如:汽车电路、DC/DC 转换、便携式产品的电源高效转换。 Suited for low voltage applications such as automotive, DC/DC Converters, and high efficiency switching for power management in portable and battery operated products. 内部等效电路 / Equivalent Circuit 引脚排列 / Pinning 4 1 2 3 PIN1:G PIN 2:D PIN 3:S PIN 4:D 放大及印章代码 / hFE Classifications & Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/6 BRD50P06 Rev.F Nov.-2019 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter Drain-Source Voltage 符号 Symbol VDSS 数值 Rating -60 单位 Unit V Drain Current ID(Tc=25℃) -50 A Drain Current ID(Tc=100℃) -35.4 A Drain Current - Pulsed IDM -200 A Gate-Source Voltage VGS ±20 V Single Pulsed Avalanche Energy EAS 490 mJ Repetitive Avalanche Energy EAR 12 mJ 85 W Junction Temperature Range PD(Tc=25℃) Tj 150 ℃ Storage Temperature Range Tstg -55~150 ℃ Power Dissipation 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 符号 测试条件 Parameter Symbol Test Conditions Drain-Source Breakdown Voltage BVDSS VGS=0V ID=-250μA Zero Gate Voltage Drain Current Gate-Body Leakage Current Forward Gate Threshold Voltage Total Gate Charge Static Drain-Source On-Resistance Drain-Source Diode Forward Voltage Input Capacitance 最小值 典型值 Min Typ -60 最大值 Max 单位 Unit V VDS=-60V VGS=0V -1.0 VDS=-48V TC=150℃ -10 IGSS VGS=±20V VDS=0V ±0.1 μA VGS(th) VDS=VGS VDS=-48V VGS=-10V ID=-250μA ID=-50A -3 V 32 42 nC VGS=-10V ID=-25A 0.018 0.027 Ω VGS=0V IS=-50A -1.5 V 1050 1365 pF VDS=-25V f=1.0MHz VGS=0V 460 600 pF IDSS Qg RDS(on) VSD Ciss -1 μA Output Capacitance Coss Reverse Transfer Capacitance Crss 70 90 pF Turn-On Delay Time td(on) 20 50 ns Turn-On Rise Time tr 100 210 ns Turn-Off Delay Time td(off) 80 170 ns 85 180 ns Turn-Off Fall Time http://www.fsbrec.com tf VDD=-30V RG=25Ω ID=-25A 2/6 BRD50P06 Rev.F Nov.-2019 DATA SHEET 电参数曲线图 / Electrical Characteristic Curve http://www.fsbrec.com 3/6 BRD50P06 Rev.F Nov.-2019 DATA SHEET 外形尺寸图 / Package Dimensions http://www.fsbrec.com 4/6 BRD50P06 Rev.F Nov.-2019 DATA SHEET 印章说明 / Marking Instructions BR 50P06 **** 说明: BR: 为公司代码 50P06: 为型号代码 ****: 为生产批号代码,随生产批号变化。 Note: BR: Company Code 50P06: Product Type. ****: Lot No. Code, code change with Lot No. http://www.fsbrec.com 5/6 BRD50P06 Rev.F Nov.-2019 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 150~180℃,时间 60~90sec; 1.Preheating:150~180℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 时间:10±1 sec. Temp.:260±5℃ Time:10±1 sec 包装规格 / Packaging SPEC. 卷盘包装 / REEL Package Type 封装形式 TO-252 Dimension 包装尺寸 (unit:mm3) Units 包装数量 Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Reel Inner Box 盒 Outer Box 箱 2,500 2 5,000 5 25,000 13〞×16 360×360×50 385×257×392 套管包装 / TUBE Package Type 封装形式 TO-251/252 Dimension 包装尺寸 (unit:mm3) Units 包装数量 Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 75 48 3,600 5 18,000 526×20.5×5.25 555×164×50 575×290×180 使用说明 / Notices http://www.fsbrec.com 6/6
BRD50P06 价格&库存
很抱歉,暂时无法提供与“BRD50P06”相匹配的价格&库存,您可以联系我们找货
BRD50P06
  • 5+2.40365
  • 50+1.88212
  • 150+1.65856
库存:19
